commit 4675ff05de2d76d167336b368bd07f3fef6ed5a6 upstream.
Fix up makefiles, remove references, and git rm kmemcheck.
Link: http://lkml.kernel.org/r/20171007030159.22241-4-alexander.levin@verizon.com
Cc: Vegard Nossum <vegardno@ifi.uio.no>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Tim Hansen <devtimhansen@gmail.com>
commit e7c52b84fb18f08ce49b6067ae6285aca79084a8 upstream.
We get a lot of very large stack frames using gcc-7.0.1 with the default
-fsanitize-address-use-after-scope --param asan-stack=1 options, which can
easily cause an overflow of the kernel stack, e.g.
drivers/gpu/drm/i915/gvt/handlers.c:2434:1: warning: the frame size of 46176 bytes is larger than 3072 bytes
drivers/net/wireless/ralink/rt2x00/rt2800lib.c:5650:1: warning: the frame size of 23632 bytes is larger than 3072 bytes
lib/atomic64_test.c:250:1: warning: the frame size of 11200 bytes is larger than 3072 bytes
drivers/gpu/drm/i915/gvt/handlers.c:2621:1: warning: the frame size of 9208 bytes is larger than 3072 bytes
drivers/media/dvb-frontends/stv090x.c:3431:1: warning: the frame size of 6816 bytes is larger than 3072 bytes
fs/fscache/stats.c:287:1: warning: the frame size of 6536 bytes is larger than 3072 bytes
To reduce this risk, -fsanitize-address-use-after-scope is now split out
into a separate CONFIG_KASAN_EXTRA Kconfig option, leading to stack
frames that are smaller than 2 kilobytes most of the time on x86_64. An
earlier version of this patch also prevented combining KASAN_EXTRA with
KASAN_INLINE, but that is no longer necessary with gcc-7.0.1.
All patches to get the frame size below 2048 bytes with CONFIG_KASAN=y
and CONFIG_KASAN_EXTRA=n have been merged by maintainers now, so we can
bring back that default now. KASAN_EXTRA=y still causes lots of
warnings but now defaults to !COMPILE_TEST to disable it in
allmodconfig, and it remains disabled in all other defconfigs since it
is a new option. I arbitrarily raise the warning limit for KASAN_EXTRA
to 3072 to reduce the noise, but an allmodconfig kernel still has around
50 warnings on gcc-7.
I experimented a bit more with smaller stack frames and have another
follow-up series that reduces the warning limit for 64-bit architectures
to 1280 bytes (without CONFIG_KASAN).
With earlier versions of this patch series, I also had patches to address
the warnings we get with KASAN and/or KASAN_EXTRA, using a
"noinline_if_stackbloat" annotation.
That annotation now got replaced with a gcc-8 bugfix (see
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=81715) and a workaround for
older compilers, which means that KASAN_EXTRA is now just as bad as
before and will lead to an instant stack overflow in a few extreme
cases.
This reverts parts of commit 3f181b4d8652 ("lib/Kconfig.debug: disable
-Wframe-larger-than warnings with KASAN=y"). Two patches in linux-next
should be merged first to avoid introducing warnings in an allmodconfig
build:
3cd890dbe2a4 ("media: dvb-frontends: fix i2c access helpers for KASAN")
16c3ada89cff ("media: r820t: fix r820t_write_reg for KASAN")
Do we really need to backport this?
I think we do: without this patch, enabling KASAN will lead to
unavoidable kernel stack overflow in certain device drivers when built
with gcc-7 or higher on linux-4.10+ or any version that contains a
backport of commit c5caf21ab0cf8. Most people are probably still on
older compilers, but it will get worse over time as they upgrade their
distros.
The warnings we get on kernels older than this should all be for code
that uses dangerously large stack frames, though most of them do not
cause an actual stack overflow by themselves.The asan-stack option was
added in linux-4.0, and commit 3f181b4d8652 ("lib/Kconfig.debug:
disable -Wframe-larger-than warnings with KASAN=y") effectively turned
off the warning for allmodconfig kernels, so I would like to see this
fix backported to any kernels later than 4.0.
I have done dozens of fixes for individual functions with stack frames
larger than 2048 bytes with asan-stack, and I plan to make sure that
all those fixes make it into the stable kernels as well (most are
already there).
Part of the complication here is that asan-stack (from 4.0) was
originally assumed to always require much larger stacks, but that
turned out to be a combination of multiple gcc bugs that we have now
worked around and fixed, but sanitize-address-use-after-scope (from
v4.10) has a much higher inherent stack usage and also suffers from at
least three other problems that we have analyzed but not yet fixed
upstream, each of them makes the stack usage more severe than it should
be.
Link: http://lkml.kernel.org/r/20171221134744.2295529-1-arnd@arndb.de
Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Mauro Carvalho Chehab <mchehab@kernel.org>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Andrey Konovalov <andreyknvl@google.com>
commit 11af847446ed0d131cf24d16a7ef3d5ea7a49554 upstream.
Rename the unwinder config options from:
CONFIG_ORC_UNWINDER
CONFIG_FRAME_POINTER_UNWINDER
CONFIG_GUESS_UNWINDER
to:
CONFIG_UNWINDER_ORC
CONFIG_UNWINDER_FRAME_POINTER
CONFIG_UNWINDER_GUESS
... in order to give them a more logical config namespace.
Suggested-by: Ingo Molnar <mingo@kernel.org>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Link: http://lkml.kernel.org/r/73972fc7e2762e91912c6b9584582703d6f1b8cc.1507924831.git.jpoimboe@redhat.com
Pull locking fixes from Ingo Molnar:
"Two lockdep fixes for bugs introduced by the cross-release dependency
tracking feature - plus a commit that disables it because performance
regressed in an absymal fashion on some systems"
* 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
locking/lockdep: Disable cross-release features for now
locking/selftest: Avoid false BUG report
locking/lockdep: Fix stacktrace mess
Johan Hovold reported a big lockdep slowdown on his system, caused by lockdep:
> I had noticed that the BeagleBone Black boot time appeared to have
> increased significantly with 4.14 and yesterday I finally had time to
> investigate it.
> Boot time (from "Linux version" to login prompt) had in fact doubled
> since 4.13 where it took 17 seconds (with my current config) compared to
> the 35 seconds I now see with 4.14-rc4.
> I quick bisect pointed to lockdep and specifically the following commit:
> 28a903f63ec0 ("locking/lockdep: Handle non(or multi)-acquisition of a crosslock")
Because the final v4.14 release is close, disable the cross-release lockdep
features for now.
Bisected-by: Johan Hovold <johan@kernel.org>
Debugged-by: Johan Hovold <johan@kernel.org>
Reported-by: Johan Hovold <johan@kernel.org>
Cc: Byungchul Park <byungchul.park@lge.com>
Cc: Tony Lindgren <tony@atomide.com>
Cc: kernel-team@lge.com
Cc: linux-mm@kvack.org
Cc: linux-omap@vger.kernel.org
Link: http://lkml.kernel.org/r/20171014072659.f2yr6mhm5ha3eou7@gmail.com
Expand the "Runtime testing" menu by including more entries inside it
instead of after it. This is just Kconfig symbol movement.
This causes the (arch-independent) Runtime tests to be presented
(listed) all in one place instead of in multiple places.
Link: http://lkml.kernel.org/r/c194e5c4-2042-bf94-a2d8-7aa13756e257@infradead.org
Cc: "Luis R. Rodriguez" <mcgrof@kernel.org>
The parisc architecture has larger stack frames than most other
architectures on 32-bit kernels.
Increase the maximum allowed stack frame to 1280 bytes for parisc to
avoid warnings in the do_sys_poll() and pat_memconfig() functions.
Signed-off-by: Helge Deller <deller@gmx.de>
Add a test module that allows testing that CONFIG_DEBUG_VIRTUAL works
correctly, at least that it can catch invalid calls to virt_to_phys()
against the non-linear kernel virtual address map.
Link: http://lkml.kernel.org/r/20170808164035.26725-1-f.fainelli@gmail.com
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Pull locking updates from Ingo Molnar:
- Add 'cross-release' support to lockdep, which allows APIs like
completions, where it's not the 'owner' who releases the lock, to be
tracked. It's all activated automatically under
CONFIG_PROVE_LOCKING=y.
- Clean up (restructure) the x86 atomics op implementation to be more
readable, in preparation of KASAN annotations. (Dmitry Vyukov)
- Fix static keys (Paolo Bonzini)
- Add killable versions of down_read() et al (Kirill Tkhai)
- Rework and fix jump_label locking (Marc Zyngier, Paolo Bonzini)
- Rework (and fix) tlb_flush_pending() barriers (Peter Zijlstra)
- Remove smp_mb__before_spinlock() and convert its usages, introduce
smp_mb__after_spinlock() (Peter Zijlstra)
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (56 commits)
locking/lockdep/selftests: Fix mixed read-write ABBA tests
sched/completion: Avoid unnecessary stack allocation for COMPLETION_INITIALIZER_ONSTACK()
acpi/nfit: Fix COMPLETION_INITIALIZER_ONSTACK() abuse
locking/pvqspinlock: Relax cmpxchg's to improve performance on some architectures
smp: Avoid using two cache lines for struct call_single_data
locking/lockdep: Untangle xhlock history save/restore from task independence
locking/refcounts, x86/asm: Disable CONFIG_ARCH_HAS_REFCOUNT for the time being
futex: Remove duplicated code and fix undefined behaviour
Documentation/locking/atomic: Finish the document...
locking/lockdep: Fix workqueue crossrelease annotation
workqueue/lockdep: 'Fix' flush_work() annotation
locking/lockdep/selftests: Add mixed read-write ABBA tests
mm, locking/barriers: Clarify tlb_flush_pending() barriers
locking/lockdep: Make CONFIG_LOCKDEP_CROSSRELEASE and CONFIG_LOCKDEP_COMPLETIONS truly non-interactive
locking/lockdep: Explicitly initialize wq_barrier::done::map
locking/lockdep: Rename CONFIG_LOCKDEP_COMPLETE to CONFIG_LOCKDEP_COMPLETIONS
locking/lockdep: Reword title of LOCKDEP_CROSSRELEASE config
locking/lockdep: Make CONFIG_LOCKDEP_CROSSRELEASE part of CONFIG_PROVE_LOCKING
locking/refcounts, x86/asm: Implement fast refcount overflow protection
locking/lockdep: Fix the rollback and overwrite detection logic in crossrelease
Pull x86 asm updates from Ingo Molnar:
- Introduce the ORC unwinder, which can be enabled via
CONFIG_ORC_UNWINDER=y.
The ORC unwinder is a lightweight, Linux kernel specific debuginfo
implementation, which aims to be DWARF done right for unwinding.
Objtool is used to generate the ORC unwinder tables during build, so
the data format is flexible and kernel internal: there's no
dependency on debuginfo created by an external toolchain.
The ORC unwinder is almost two orders of magnitude faster than the
(out of tree) DWARF unwinder - which is important for perf call graph
profiling. It is also significantly simpler and is coded defensively:
there has not been a single ORC related kernel crash so far, even
with early versions. (knock on wood!)
But the main advantage is that enabling the ORC unwinder allows
CONFIG_FRAME_POINTERS to be turned off - which speeds up the kernel
measurably:
With frame pointers disabled, GCC does not have to add frame pointer
instrumentation code to every function in the kernel. The kernel's
.text size decreases by about 3.2%, resulting in better cache
utilization and fewer instructions executed, resulting in a broad
kernel-wide speedup. Average speedup of system calls should be
roughly in the 1-3% range - measurements by Mel Gorman [1] have shown
a speedup of 5-10% for some function execution intense workloads.
The main cost of the unwinder is that the unwinder data has to be
stored in RAM: the memory cost is 2-4MB of RAM, depending on kernel
config - which is a modest cost on modern x86 systems.
Given how young the ORC unwinder code is it's not enabled by default
- but given the performance advantages the plan is to eventually make
it the default unwinder on x86.
See Documentation/x86/orc-unwinder.txt for more details.
- Remove lguest support: its intended role was that of a temporary
proof of concept for virtualization, plus its removal will enable the
reduction (removal) of the paravirt API as well, so Rusty agreed to
its removal. (Juergen Gross)
- Clean up and fix FSGS related functionality (Andy Lutomirski)
- Clean up IO access APIs (Andy Shevchenko)
- Enhance the symbol namespace (Jiri Slaby)
* 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (47 commits)
objtool: Handle GCC stack pointer adjustment bug
x86/entry/64: Use ENTRY() instead of ALIGN+GLOBAL for stub32_clone()
x86/fpu/math-emu: Add ENDPROC to functions
x86/boot/64: Extract efi_pe_entry() from startup_64()
x86/boot/32: Extract efi_pe_entry() from startup_32()
x86/lguest: Remove lguest support
x86/paravirt/xen: Remove xen_patch()
objtool: Fix objtool fallthrough detection with function padding
x86/xen/64: Fix the reported SS and CS in SYSCALL
objtool: Track DRAP separately from callee-saved registers
objtool: Fix validate_branch() return codes
x86: Clarify/fix no-op barriers for text_poke_bp()
x86/switch_to/64: Rewrite FS/GS switching yet again to fix AMD CPUs
selftests/x86/fsgsbase: Test selectors 1, 2, and 3
x86/fsgsbase/64: Report FSBASE and GSBASE correctly in core dumps
x86/fsgsbase/64: Fully initialize FS and GS state in start_thread_common
x86/asm: Fix UNWIND_HINT_REGS macro for older binutils
x86/asm/32: Fix regs_get_register() on segment registers
x86/xen/64: Rearrange the SYSCALL entries
x86/asm/32: Remove a bunch of '& 0xffff' from pt_regs segment reads
The hardlockup detector on x86 uses a performance counter based on unhalted
CPU cycles and a periodic hrtimer. The hrtimer period is about 2/5 of the
performance counter period, so the hrtimer should fire 2-3 times before the
performance counter NMI fires. The NMI code checks whether the hrtimer
fired since the last invocation. If not, it assumess a hard lockup.
The calculation of those periods is based on the nominal CPU
frequency. Turbo modes increase the CPU clock frequency and therefore
shorten the period of the perf/NMI watchdog. With extreme Turbo-modes (3x
nominal frequency) the perf/NMI period is shorter than the hrtimer period
which leads to false positives.
A simple fix would be to shorten the hrtimer period, but that comes with
the side effect of more frequent hrtimer and softlockup thread wakeups,
which is not desired.
Implement a low pass filter, which checks the perf/NMI period against
kernel time. If the perf/NMI fires before 4/5 of the watchdog period has
elapsed then the event is ignored and postponed to the next perf/NMI.
That solves the problem and avoids the overhead of shorter hrtimer periods
and more frequent softlockup thread wakeups.
Fixes: 58687acba592 ("lockup_detector: Combine nmi_watchdog and softlockup detector")
Reported-and-tested-by: Kan Liang <Kan.liang@intel.com>
Cc: dzickus@redhat.com
Cc: prarit@redhat.com
Cc: ak@linux.intel.com
Cc: babu.moger@oracle.com
Cc: peterz@infradead.org
Cc: eranian@google.com
Cc: acme@redhat.com
Cc: stable@vger.kernel.org
Cc: atomlin@redhat.com
Cc: akpm@linux-foundation.org
Cc: torvalds@linux-foundation.org
Link: http://lkml.kernel.org/r/alpine.DEB.2.20.1708150931310.1886@nanos
The syntax to turn Kconfig options into non-interactive ones is to not offer
interactive prompt help texts. Remove them.
Cc: Boqun Feng <boqun.feng@gmail.com>
Cc: Lai Jiangshan <jiangshanlai@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
'complete' is an adjective and LOCKDEP_COMPLETE sounds like 'lockdep is complete',
so pick a better name that uses a noun.
Signed-off-by: Byungchul Park <byungchul.park@lge.com>
Link: http://lkml.kernel.org/r/1502960261-16206-3-git-send-email-byungchul.park@lge.com
Lockdep doesn't have to be made to work with crossrelease and just works
with them. Reword the title so that what the option does is clear.
Link: http://lkml.kernel.org/r/1502960261-16206-2-git-send-email-byungchul.park@lge.com
Crossrelease support added the CONFIG_LOCKDEP_CROSSRELEASE and CONFIG_LOCKDEP_COMPLETE
options. It makes little sense to enable them when PROVE_LOCKING is disabled.
Make them non-interative options and part of PROVE_LOCKING to simplify the UI.
Link: http://lkml.kernel.org/r/1502960261-16206-1-git-send-email-byungchul.park@lge.com
Although wait_for_completion() and its family can cause deadlock, the
lock correctness validator could not be applied to them until now,
because things like complete() are usually called in a different context
from the waiting context, which violates lockdep's assumption.
Thanks to CONFIG_LOCKDEP_CROSSRELEASE, we can now apply the lockdep
detector to those completion operations. Applied it.
Cc: boqun.feng@gmail.com
Cc: kirill@shutemov.name
Cc: npiggin@gmail.com
Cc: walken@google.com
Cc: willy@infradead.org
Link: http://lkml.kernel.org/r/1502089981-21272-10-git-send-email-byungchul.park@lge.com
Lockdep is a runtime locking correctness validator that detects and
reports a deadlock or its possibility by checking dependencies between
locks. It's useful since it does not report just an actual deadlock but
also the possibility of a deadlock that has not actually happened yet.
That enables problems to be fixed before they affect real systems.
However, this facility is only applicable to typical locks, such as
spinlocks and mutexes, which are normally released within the context in
which they were acquired. However, synchronization primitives like page
locks or completions, which are allowed to be released in any context,
also create dependencies and can cause a deadlock.
So lockdep should track these locks to do a better job. The 'crossrelease'
implementation makes these primitives also be tracked.
Link: http://lkml.kernel.org/r/1502089981-21272-6-git-send-email-byungchul.park@lge.com
A couple of Kconfig changes which make it much easier to switch to the
new CONFIG_ORC_UNWINDER:
1) Remove x86 dependencies on CONFIG_FRAME_POINTER for lockdep,
latencytop, and fault injection. x86 has a 'guess' unwinder which
just scans the stack for kernel text addresses. It's not 100%
accurate but in many cases it's good enough. This allows those users
who don't want the text overhead of the frame pointer or ORC
unwinders to still use these features. More importantly, this also
makes it much more straightforward to disable frame pointers.
2) Make CONFIG_ORC_UNWINDER depend on !CONFIG_FRAME_POINTER. While it
would be possible to have both enabled, it doesn't really make sense
to do so. So enforce a sane configuration to prevent the user from
making a dumb mistake.
With these changes, when you disable CONFIG_FRAME_POINTER, "make
oldconfig" will ask if you want to enable CONFIG_ORC_UNWINDER.
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Jiri Slaby <jslaby@suse.cz>
Cc: live-patching@vger.kernel.org
Link: http://lkml.kernel.org/r/9985fb91ce5005fe33ea5cc2a20f14bd33c61d03.1500938583.git.jpoimboe@redhat.com
Add the new ORC unwinder which is enabled by CONFIG_ORC_UNWINDER=y.
It plugs into the existing x86 unwinder framework.
It relies on objtool to generate the needed .orc_unwind and
.orc_unwind_ip sections.
For more details on why ORC is used instead of DWARF, see
Documentation/x86/orc-unwinder.txt - but the short version is
that it's a simplified, fundamentally more robust debugninfo
data structure, which also allows up to two orders of magnitude
faster lookups than the DWARF unwinder - which matters to
profiling workloads like perf.
Thanks to Andy Lutomirski for the performance improvement ideas:
splitting the ORC unwind table into two parallel arrays and creating a
fast lookup table to search a subset of the unwind table.
Link: http://lkml.kernel.org/r/0a6cbfb40f8da99b7a45a1a8302dc6aef16ec812.1500938583.git.jpoimboe@redhat.com
[ Extended the changelog. ]
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random
Pull random updates from Ted Ts'o:
"Add wait_for_random_bytes() and get_random_*_wait() functions so that
callers can more safely get random bytes if they can block until the
CRNG is initialized.
Also print a warning if get_random_*() is called before the CRNG is
initialized. By default, only one single-line warning will be printed
per boot. If CONFIG_WARN_ALL_UNSEEDED_RANDOM is defined, then a
warning will be printed for each function which tries to get random
bytes before the CRNG is initialized. This can get spammy for certain
architecture types, so it is not enabled by default"
* tag 'random_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random:
random: reorder READ_ONCE() in get_random_uXX
random: suppress spammy warnings about unseeded randomness
random: warn when kernel uses unseeded randomness
net/route: use get_random_int for random counter
net/neighbor: use get_random_u32 for 32-bit hash random
rhashtable: use get_random_u32 for hash_rnd
ceph: ensure RNG is seeded before using
iscsi: ensure RNG is seeded before use
cifs: use get_random_u32 for 32-bit lock random
random: add get_random_{bytes,u32,u64,int,long,once}_wait family
random: add wait_for_random_bytes() API
Unfortunately, on some models of some architectures getting a fully
seeded CRNG is extremely difficult, and so this can result in dmesg
getting spammed for a surprisingly long time. This is really bad from
a security perspective, and so architecture maintainers really need to
do what they can to get the CRNG seeded sooner after the system is
booted. However, users can't do anything actionble to address this,
and spamming the kernel messages log will only just annoy people.
For developers who want to work on improving this situation,
CONFIG_WARN_UNSEEDED_RANDOM has been renamed to
CONFIG_WARN_ALL_UNSEEDED_RANDOM. By default the kernel will always
print the first use of unseeded randomness. This way, hopefully the
security obsessed will be happy that there is _some_ indication when
the kernel boots there may be a potential issue with that architecture
or subarchitecture. To see all uses of unseeded randomness,
developers can enable CONFIG_WARN_ALL_UNSEEDED_RANDOM.
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
This adds a new stress test driver for kmod: the kernel module loader.
The new stress test driver, test_kmod, is only enabled as a module right
now. It should be possible to load this as built-in and load tests
early (refer to the force_init_test module parameter), however since a
lot of test can get a system out of memory fast we leave this disabled
for now.
Using a system with 1024 MiB of RAM can *easily* get your kernel OOM
fast with this test driver.
The test_kmod driver exposes API knobs for us to fine tune simple
request_module() and get_fs_type() calls. Since these API calls only
allow each one parameter a test driver for these is rather simple.
Other factors that can help out test driver though are the number of
calls we issue and knowing current limitations of each. This exposes
configuration as much as possible through userspace to be able to build
tests directly from userspace.
Since it allows multiple misc devices its will eventually (once we add a
knob to let us create new devices at will) also be possible to perform
more tests in parallel, provided you have enough memory.
We only enable tests we know work as of right now.
Demo screenshots:
# tools/testing/selftests/kmod/kmod.sh
kmod_test_0001_driver: OK! - loading kmod test
kmod_test_0001_driver: OK! - Return value: 256 (MODULE_NOT_FOUND), expected MODULE_NOT_FOUND
kmod_test_0001_fs: OK! - loading kmod test
kmod_test_0001_fs: OK! - Return value: -22 (-EINVAL), expected -EINVAL
kmod_test_0002_driver: OK! - loading kmod test
kmod_test_0002_driver: OK! - Return value: 256 (MODULE_NOT_FOUND), expected MODULE_NOT_FOUND
kmod_test_0002_fs: OK! - loading kmod test
kmod_test_0002_fs: OK! - Return value: -22 (-EINVAL), expected -EINVAL
kmod_test_0003: OK! - loading kmod test
kmod_test_0003: OK! - Return value: 0 (SUCCESS), expected SUCCESS
kmod_test_0004: OK! - loading kmod test
kmod_test_0004: OK! - Return value: 0 (SUCCESS), expected SUCCESS
kmod_test_0005: OK! - loading kmod test
kmod_test_0005: OK! - Return value: 0 (SUCCESS), expected SUCCESS
kmod_test_0006: OK! - loading kmod test
kmod_test_0006: OK! - Return value: 0 (SUCCESS), expected SUCCESS
XXX: add test restult for 0007
Test completed
You can also request for specific tests:
# tools/testing/selftests/kmod/kmod.sh -t 0001
Test completed
Lastly, the current available number of tests:
# tools/testing/selftests/kmod/kmod.sh --help
Usage: tools/testing/selftests/kmod/kmod.sh [ -t <4-number-digit> ]
Valid tests: 0001-0009
0001 - Simple test - 1 thread for empty string
0002 - Simple test - 1 thread for modules/filesystems that do not exist
0003 - Simple test - 1 thread for get_fs_type() only
0004 - Simple test - 2 threads for get_fs_type() only
0005 - multithreaded tests with default setup - request_module() only
0006 - multithreaded tests with default setup - get_fs_type() only
0007 - multithreaded tests with default setup test request_module() and get_fs_type()
0008 - multithreaded - push kmod_concurrent over max_modprobes for request_module()
0009 - multithreaded - push kmod_concurrent over max_modprobes for get_fs_type()
The following test cases currently fail, as such they are not currently
enabled by default:
# tools/testing/selftests/kmod/kmod.sh -t 0008
# tools/testing/selftests/kmod/kmod.sh -t 0009
To be sure to run them as intended please unload both of the modules:
o test_module
o xfs
And ensure they are not loaded on your system prior to testing them. If
you use these paritions for your rootfs you can change the default test
driver used for get_fs_type() by exporting it into your environment. For
example of other test defaults you can override refer to kmod.sh
allow_user_defaults().
Behind the scenes this is how we fine tune at a test case prior to
hitting a trigger to run it:
cat /sys/devices/virtual/misc/test_kmod0/config
echo -n "2" > /sys/devices/virtual/misc/test_kmod0/config_test_case
echo -n "ext4" > /sys/devices/virtual/misc/test_kmod0/config_test_fs
echo -n "80" > /sys/devices/virtual/misc/test_kmod0/config_num_threads
echo -n "1" > /sys/devices/virtual/misc/test_kmod0/config_num_threads
Finally to trigger:
echo -n "1" > /sys/devices/virtual/misc/test_kmod0/trigger_config
The kmod.sh script uses the above constructs to build different test cases.
A bit of interpretation of the current failures follows, first two
premises:
a) When request_module() is used userspace figures out an optimized
version of module order for us. Once it finds the modules it needs, as
per depmod symbol dep map, it will finit_module() the respective
modules which are needed for the original request_module() request.
b) We have an optimization in place whereby if a kernel uses
request_module() on a module already loaded we never bother userspace
as the module already is loaded. This is all handled by kernel/kmod.c.
A few things to consider to help identify root causes of issues:
0) kmod 19 has a broken heuristic for modules being assumed to be
built-in to your kernel and will return 0 even though request_module()
failed. Upgrade to a newer version of kmod.
1) A get_fs_type() call for "xfs" will request_module() for "fs-xfs",
not for "xfs". The optimization in kernel described in b) fails to
catch if we have a lot of consecutive get_fs_type() calls. The reason
is the optimization in place does not look for aliases. This means two
consecutive get_fs_type() calls will bump kmod_concurrent, whereas
request_module() will not.
This one explanation why test case 0009 fails at least once for
get_fs_type().
2) If a module fails to load --- for whatever reason (kmod_concurrent
limit reached, file not yet present due to rootfs switch, out of
memory) we have a period of time during which module request for the
same name either with request_module() or get_fs_type() will *also*
fail to load even if the file for the module is ready.
This explains why *multiple* NULLs are possible on test 0009.
3) finit_module() consumes quite a bit of memory.
4) Filesystems typically also have more dependent modules than other
modules, its important to note though that even though a get_fs_type()
call does not incur additional kmod_concurrent bumps, since userspace
loads dependencies it finds it needs via finit_module_fd(), it *will*
take much more memory to load a module with a lot of dependencies.
Because of 3) and 4) we will easily run into out of memory failures with
certain tests. For instance test 0006 fails on qemu with 1024 MiB of RAM.
It panics a box after reaping all userspace processes and still not
having enough memory to reap.
[arnd@arndb.de: add dependencies for test module]
Link: http://lkml.kernel.org/r/20170630154834.3689272-1-arnd@arndb.de
Link: http://lkml.kernel.org/r/20170628223155.26472-3-mcgrof@kernel.org
Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org>
Cc: Jessica Yu <jeyu@redhat.com>
Cc: Shuah Khan <shuah@kernel.org>
Cc: Michal Marek <mmarek@suse.com>
Cc: Petr Mladek <pmladek@suse.com>
Split SOFTLOCKUP_DETECTOR from LOCKUP_DETECTOR, and split
HARDLOCKUP_DETECTOR_PERF from HARDLOCKUP_DETECTOR.
LOCKUP_DETECTOR implies the general boot, sysctl, and programming
interfaces for the lockup detectors.
An architecture that wants to use a hard lockup detector must define
HAVE_HARDLOCKUP_DETECTOR_PERF or HAVE_HARDLOCKUP_DETECTOR_ARCH.
Alternatively an arch can define HAVE_NMI_WATCHDOG, which provides the
minimum arch_touch_nmi_watchdog, and it otherwise does its own thing and
does not implement the LOCKUP_DETECTOR interfaces.
sparc is unusual in that it has started to implement some of the
interfaces, but not fully yet. It should probably be converted to a full
[npiggin@gmail.com: fix]
Link: http://lkml.kernel.org/r/20170617223522.66c0ad88@roar.ozlabs.ibm.com
Link: http://lkml.kernel.org/r/20170616065715.18390-4-npiggin@gmail.com
Signed-off-by: Nicholas Piggin <npiggin@gmail.com>
Reviewed-by: Don Zickus <dzickus@redhat.com>
Reviewed-by: Babu Moger <babu.moger@oracle.com>
Tested-by: Babu Moger <babu.moger@oracle.com> [sparc]
Cc: Michael Ellerman <mpe@ellerman.id.au>
The existing tools/testing/selftests/sysctl/ tests include two test
cases, but these use existing production kernel sysctl interfaces. We
want to expand test coverage but we can't just be looking for random
safe production values to poke at, that's just insane!
Instead just dedicate a test driver for debugging purposes and port the
existing scripts to use it. This will make it easier for further tests
to be added.
Subsequent patches will extend our test coverage for sysctl.
The stress test driver uses a new license (GPL on Linux, copyleft-next
outside of Linux). Linus was fine with this [0] and later due to Ted's
and Alans's request ironed out an "or" language clause to use [1] which
is already present upstream.
[0] https://lkml.kernel.org/r/CA+55aFyhxcvD+q7tp+-yrSFDKfR0mOHgyEAe=f_94aKLsOu0Og@mail.gmail.com
[1] https://lkml.kernel.org/r/1495234558.7848.122.camel@linux.intel.com
Link: http://lkml.kernel.org/r/20170630224431.17374-2-mcgrof@kernel.org
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Patch series "lib/interval_tree_test: some debugging improvements".
Here are some patches that update the interval_tree_test module allowing
users to pass finer grained options to run the actual test.
This patch (of 4):
It is a tristate after all, and also serves well for quick debugging.
Link: http://lkml.kernel.org/r/20170518174936.20265-2-dave@stgolabs.net
Signed-off-by: Davidlohr Bueso <dbueso@suse.de>
Pull documentation updates from Jonathan Corbet:
"There has been a fair amount of activity in the docs tree this time
around. Highlights include:
- Conversion of a bunch of security documentation into RST
- The conversion of the remaining DocBook templates by The Amazing
Mauro Machine. We can now drop the entire DocBook build chain.
- The usual collection of fixes and minor updates"
* tag 'docs-4.13' of git://git.lwn.net/linux: (90 commits)
scripts/kernel-doc: handle DECLARE_HASHTABLE
Documentation: atomic_ops.txt is core-api/atomic_ops.rst
Docs: clean up some DocBook loose ends
Make the main documentation title less Geocities
Docs: Use kernel-figure in vidioc-g-selection.rst
Docs: fix table problems in ras.rst
Docs: Fix breakage with Sphinx 1.5 and upper
Docs: Include the Latex "ifthen" package
doc/kokr/howto: Only send regression fixes after -rc1
docs-rst: fix broken links to dynamic-debug-howto in kernel-parameters
doc: Document suitability of IBM Verse for kernel development
Doc: fix a markup error in coding-style.rst
docs: driver-api: i2c: remove some outdated information
Documentation: DMA API: fix a typo in a function name
Docs: Insert missing space to separate link from text
doc/ko_KR/memory-barriers: Update control-dependencies example
Documentation, kbuild: fix typo "minimun" -> "minimum"
docs: Fix some formatting issues in request-key.rst
doc: ReSTify keys-trusted-encrypted.txt
doc: ReSTify keys-request-key.txt
"The main changes in this cycle were:
- Add CONFIG_REFCOUNT_FULL=y to allow the disabling of the 'full'
(robustness checked) refcount_t implementation with slightly lower
runtime overhead. (Kees Cook)
The lighter weight variant is the default. The two variants use the
same API. Having this variant was a precondition by some
maintainers to merge refcount_t cleanups.
- Add lockdep support for rtmutexes (Peter Zijlstra)
- liblockdep fixes and improvements (Sasha Levin, Ben Hutchings)
- ... misc fixes and improvements"
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (30 commits)
locking/refcount: Remove the half-implemented refcount_sub() API
locking/refcount: Create unchecked atomic_t implementation
locking/rtmutex: Don't initialize lockdep when not required
locking/selftest: Add RT-mutex support
locking/selftest: Remove the bad unlock ordering test
rt_mutex: Add lockdep annotations
MAINTAINERS: Claim atomic*_t maintainership
locking/x86: Remove the unused atomic_inc_short() methd
tools/lib/lockdep: Remove private kernel headers
tools/lib/lockdep: Hide liblockdep output from test results
tools/lib/lockdep: Add dummy current_gfp_context()
tools/include: Add IS_ERR_OR_NULL to err.h
tools/lib/lockdep: Add empty __is_[module,kernel]_percpu_address
tools/lib/lockdep: Include err.h
tools/include: Add (mostly) empty include/linux/sched/mm.h
tools/lib/lockdep: Use LDFLAGS
tools/lib/lockdep: Remove double-quotes from soname
tools/lib/lockdep: Fix object file paths used in an out-of-tree build
tools/lib/lockdep: Fix compilation for 4.11
tools/lib/lockdep: Don't mix fd-based and stream IO
This enables an important dmesg notification about when drivers have
used the crng without it being seeded first. Prior, these errors would
occur silently, and so there hasn't been a great way of diagnosing these
types of bugs for obscure setups. By adding this as a config option, we
can leave it on by default, so that we learn where these issues happen,
in the field, will still allowing some people to turn it off, if they
really know what they're doing and do not want the log entries.
However, we don't leave it _completely_ by default. An earlier version
of this patch simply had `default y`. I'd really love that, but it turns
out, this problem with unseeded randomness being used is really quite
present and is going to take a long time to fix. Thus, as a compromise
between log-messages-for-all and nobody-knows, this is `default y`,
except it is also `depends on DEBUG_KERNEL`. This will ensure that the
curious see the messages while others don't have to.
Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com>
RCU's debugging Kconfig options are in the unintuitive location
lib/Kconfig.debug, and there are enough of them that it would be good for
them to be more centralized. This commit therefore extracts RCU's Kconfig
options from init/Kconfig into a new kernel/rcu/Kconfig.debug file.
Reported-by: Ingo Molnar <mingo@kernel.org>
RCU's debugfs tracing used to be the only reasonable low-level debug
information available, but ftrace and event tracing has since surpassed
the RCU debugfs level of usefulness. This commit therefore removes
RCU's debugfs tracing.
The sparse-based checking for non-RCU accesses to RCU-protected pointers
has been around for a very long time, and it is now the only type of
sparse-based checking that is optional. This commit therefore makes
it unconditional.
Cc: Fengguang Wu <fengguang.wu@intel.com>
The PROVE_RCU_REPEATEDLY Kconfig option was initially added due to
the volume of messages from PROVE_RCU: Doing just one per boot would
have required excessive numbers of boots to locate them all. However,
PROVE_RCU messages are now relatively rare, so there is no longer any
reason to need more than one such message per boot. This commit therefore
removes the PROVE_RCU_REPEATEDLY Kconfig option.
The RCU_TORTURE_TEST_SLOW_PREINIT, RCU_TORTURE_TEST_SLOW_PREINIT_DELAY,
RCU_TORTURE_TEST_SLOW_PREINIT_DELAY, RCU_TORTURE_TEST_SLOW_INIT,
RCU_TORTURE_TEST_SLOW_INIT_DELAY, RCU_TORTURE_TEST_SLOW_CLEANUP,
and RCU_TORTURE_TEST_SLOW_CLEANUP_DELAY Kconfig options are only
useful for torture testing, and there are the rcutree.gp_cleanup_delay,
rcutree.gp_init_delay, and rcutree.gp_preinit_delay kernel boot parameters
that rcutorture can use instead. The effect of these parameters is to
artificially slow down grace period initialization and cleanup in order
to make some types of race conditions happen more often.
This commit therefore simplifies Tree RCU a bit by removing the Kconfig
options and adding the corresponding kernel parameters to rcutorture's
.boot files instead. However, this commit also leaves out the kernel
parameters for TREE02, TREE04, and TREE07 in order to have about the
same number of tests slowed as not slowed. TREE01, TREE03, TREE05,
and TREE06 are slowed, and the rest are not slowed.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Now that (PI) futexes have their own private RT-mutex interface and
implementation we can easily add lockdep annotations to the existing
RT-mutex interface.
The filesystem documentation was moved from DocBook to
Documentation/filesystems/. Update it at the sources.
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
Extract the linked list sorting test code into its own source file, to
allow to compile it either to a loadable module, or builtin into the
kernel.
Link: http://lkml.kernel.org/r/1488287219-15832-4-git-send-email-geert@linux-m68k.org
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Allow to compile the array-based sort test code either to a loadable
module, or builtin into the kernel.
Link: http://lkml.kernel.org/r/1488287219-15832-3-git-send-email-geert@linux-m68k.org
Pull documentation update from Jonathan Corbet:
"A reasonably busy cycle for documentation this time around. There is a
new guide for user-space API documents, rather sparsely populated at
the moment, but it's a start. Markus improved the infrastructure for
converting diagrams. Mauro has converted much of the USB documentation
over to RST. Plus the usual set of fixes, improvements, and tweaks.
There's a bit more than the usual amount of reaching out of
Documentation/ to fix comments elsewhere in the tree; I have acks for
those where I could get them"
* tag 'docs-4.12' of git://git.lwn.net/linux: (74 commits)
docs: Fix a couple typos
docs: Fix a spelling error in vfio-mediated-device.txt
docs: Fix a spelling error in ioctl-number.txt
MAINTAINERS: update file entry for HSI subsystem
Documentation: allow installing man pages to a user defined directory
Doc/PM: Sync with intel_powerclamp code behavior
zr364xx.rst: usb/devices is now at /sys/kernel/debug/
usb.rst: move documentation from proc_usb_info.txt to USB ReST book
convert philips.txt to ReST and add to media docs
docs-rst: usb: update old usbfs-related documentation
arm: Documentation: update a path name
docs: process/4.Coding.rst: Fix a couple of document refs
docs-rst: fix usb cross-references
usb: gadget.h: be consistent at kernel doc macros
usb: composite.h: fix two warnings when building docs
usb: get rid of some ReST doc build errors
usb.rst: get rid of some Sphinx errors
usb/URB.txt: convert to ReST and update it
usb/persist.txt: convert to ReST and add to driver-api book
usb/hotplug.txt: convert to ReST and add to driver-api book
AVR32 architecture has been removed from the Linux kernel sources, hence
clean up the architecture related symbols in lib/Kconfig.debug.
Signed-off-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no>
CONFIG_PROVE_LOCKING_SMALL shrinks the memory usage of lockdep so the
kernel text, data, and bss fit in the required 32MB limit, but this
option is not set for every config that enables lockdep.
A 4.10 kernel fails to boot with the console output
Kernel: Using 8 locked TLB entries for main kernel image.
hypervisor_tlb_lock[2000000:0:8000000071c007c3:1]: errors with f
Program terminated
with these config options
CONFIG_LOCKDEP=y
CONFIG_LOCK_STAT=y
CONFIG_PROVE_LOCKING=n
To fix, rename CONFIG_PROVE_LOCKING_SMALL to CONFIG_LOCKDEP_SMALL, and
enable this option with CONFIG_LOCKDEP=y so we get the reduced memory
usage every time lockdep is turned on.
Tested that CONFIG_LOCKDEP_SMALL is set to 'y' if and only if
CONFIG_LOCKDEP is set to 'y'. When other lockdep-related config options
that select CONFIG_LOCKDEP are enabled (e.g. CONFIG_LOCK_STAT or
CONFIG_PROVE_LOCKING), verified that CONFIG_LOCKDEP_SMALL is also
enabled.
Fixes: e6b5f1be7afe ("config: Adding the new config parameter CONFIG_PROVE_LOCKING_SMALL for sparc")
Signed-off-by: Daniel Jordan <daniel.m.jordan@oracle.com>
A bunch of documentation files have moved, correct the paths.
Signed-off-by: Hans Holmberg <hans@pixelmunchies.com>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
"The main change is the uninlining of large refcount_t APIs, plus a
header dependency fix.
Note that the uninlining allowed us to enable the underflow/overflow
warnings unconditionally and remove the debug Kconfig switch: this
might trigger new warnings in buggy code and turn
crashes/use-after-free bugs into less harmful memory leaks"
locking/refcounts: Add missing kernel.h header to have UINT_MAX defined
locking/refcounts: Out-of-line everything
Along with the addition made to Kconfig.debug, the prior existing but
permanently disabled test function has been slightly refactored.
Patch has been tested using QEMU 2.1.2 with a .config obtained through
'make defconfig' (x86_64) and manually enabling the option.
[arnd@arndb.de: move sort self-test into a separate file]
Link: http://lkml.kernel.org/r/20170112110657.3123790-1-arnd@arndb.de
Link: http://lkml.kernel.org/r/HE1PR09MB0394B0418D504DCD27167D4FD49B0@HE1PR09MB0394.eurprd09.prod.outlook.com
Signed-off-by: Kostenzer Felix <fkostenzer@live.at>
Allow to compile the atomic64 test code either to a loadable module, or
Link: http://lkml.kernel.org/r/1483470276-10517-3-git-send-email-geert@linux-m68k.org
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Linus asked to please make this real C code.
And since size then isn't an issue what so ever anymore, remove the
debug knob and make all WARN()s unconditional.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: dwindsor@gmail.com
Cc: elena.reshetova@intel.com
Cc: gregkh@linuxfoundation.org
Cc: ishkamiel@gmail.com
Cc: keescook@chromium.org
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial driver updates from Greg KH:
"Here is the big tty/serial driver patchset for 4.11-rc1.
Not much here, but a lot of little fixes and individual serial driver
updates all over the subsystem. Majority are for the sh-sci driver and
platform (the arch-specific changes have acks from the maintainer).
The start of the "serial bus" code is here as well, but nothing is
converted to use it yet. That work is still ongoing, hopefully will
start to show up across different subsystems for 4.12 (bluetooth is
one major place that will be used.)
All of these have been in linux-next for a while with no reported
issues"
* tag 'tty-4.11-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (109 commits)
tty: pl011: Work around QDF2400 E44 stuck BUSY bit
atmel_serial: Use the fractional divider when possible
tty: Remove extra include in HVC console tty framework
serial: exar: Enable MSI support
serial: exar: Move register defines from uapi header to consumer site
serial: pci: Remove unused pci_boards entries
serial: exar: Move Commtech adapters to 8250_exar as well
serial: exar: Fix feature control register constants
serial: exar: Fix initialization of EXAR registers for ports > 0
serial: exar: Fix mapping of port I/O resources
serial: sh-sci: fix hardware RX trigger level setting
tty/serial: atmel: ensure state is restored after suspending
serial: 8250_dw: Avoid "too much work" from bogus rx timeout interrupt
serdev: ttyport: check whether tty_init_dev() fails
serial: 8250_pci: make pciserial_detach_ports() static
ARM: dts: STiH410-b2260: Enable HW flow-control
ARM: dts: STiH407-family: Use new Pinctrl groups
ARM: dts: STiH407-pinctrl: Add Pinctrl group for HW flow-control
ARM: dts: STiH410-b2260: Identify the UART RTS line
dt-bindings: serial: Update 'uart-has-rtscts' description
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 updates from Will Deacon:
- Errata workarounds for Qualcomm's Falkor CPU
- Qualcomm L2 Cache PMU driver
- Qualcomm SMCCC firmware quirk
- Support for DEBUG_VIRTUAL
- CPU feature detection for userspace via MRS emulation
- Preliminary work for the Statistical Profiling Extension
- Misc cleanups and non-critical fixes
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (74 commits)
arm64/kprobes: consistently handle MRS/MSR with XZR
arm64: cpufeature: correctly handle MRS to XZR
arm64: traps: correctly handle MRS/MSR with XZR
arm64: ptrace: add XZR-safe regs accessors
arm64: include asm/assembler.h in entry-ftrace.S
arm64: fix warning about swapper_pg_dir overflow
arm64: Work around Falkor erratum 1003
arm64: head.S: Enable EL1 (host) access to SPE when entered at EL2
arm64: arch_timer: document Hisilicon erratum 161010101
arm64: use is_vmalloc_addr
arm64: use linux/sizes.h for constants
arm64: uaccess: consistently check object sizes
perf: add qcom l2 cache perf events driver
arm64: remove wrong CONFIG_PROC_SYSCTL ifdef
ARM: smccc: Update HVC comment to describe new quirk parameter
arm64: do not trace atomic operations
ACPI/IORT: Fix the error return code in iort_add_smmu_platform_device()
ACPI/IORT: Fix iort_node_get_id() mapping entries indexing
arm64: mm: enable CONFIG_HOLES_IN_ZONE for NUMA
perf: xgene: Include module.h
Pull networking updates from David Miller:
"Highlights:
1) Support TX_RING in AF_PACKET TPACKET_V3 mode, from Sowmini
Varadhan.
2) Simplify classifier state on sk_buff in order to shrink it a bit.
From Willem de Bruijn.
3) Introduce SIPHASH and it's usage for secure sequence numbers and
syncookies. From Jason A. Donenfeld.
4) Reduce CPU usage for ICMP replies we are going to limit or
suppress, from Jesper Dangaard Brouer.
5) Introduce Shared Memory Communications socket layer, from Ursula
Braun.
6) Add RACK loss detection and allow it to actually trigger fast
recovery instead of just assisting after other algorithms have
triggered it. From Yuchung Cheng.
7) Add xmit_more and BQL support to mvneta driver, from Simon Guinot.
8) skb_cow_data avoidance in esp4 and esp6, from Steffen Klassert.
9) Export MPLS packet stats via netlink, from Robert Shearman.
10) Significantly improve inet port bind conflict handling, especially
when an application is restarted and changes it's setting of
reuseport. From Josef Bacik.
11) Implement TX batching in vhost_net, from Jason Wang.
12) Extend the dummy device so that VF (virtual function) features,
such as configuration, can be more easily tested. From Phil
Sutter.
13) Avoid two atomic ops per page on x86 in bnx2x driver, from Eric
Dumazet.
14) Add new bpf MAP, implementing a longest prefix match trie. From
Daniel Mack.
15) Packet sample offloading support in mlxsw driver, from Yotam Gigi.
16) Add new aquantia driver, from David VomLehn.
17) Add bpf tracepoints, from Daniel Borkmann.
18) Add support for port mirroring to b53 and bcm_sf2 drivers, from
Florian Fainelli.
19) Remove custom busy polling in many drivers, it is done in the core
networking since 4.5 times. From Eric Dumazet.
20) Support XDP adjust_head in virtio_net, from John Fastabend.
21) Fix several major holes in neighbour entry confirmation, from
Julian Anastasov.
22) Add XDP support to bnxt_en driver, from Michael Chan.
23) VXLAN offloads for enic driver, from Govindarajulu Varadarajan.
24) Add IPVTAP driver (IP-VLAN based tap driver) from Sainath Grandhi.
25) Support GRO in IPSEC protocols, from Steffen Klassert"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1764 commits)
Revert "ath10k: Search SMBIOS for OEM board file extension"
net: socket: fix recvmmsg not returning error from sock_error
bnxt_en: use eth_hw_addr_random()
bpf: fix unlocking of jited image when module ronx not set
arch: add ARCH_HAS_SET_MEMORY config
net: napi_watchdog() can use napi_schedule_irqoff()
tcp: Revert "tcp: tcp_probe: use spin_lock_bh()"
net/hsr: use eth_hw_addr_random()
net: mvpp2: enable building on 64-bit platforms
net: mvpp2: switch to build_skb() in the RX path
net: mvpp2: simplify MVPP2_PRS_RI_* definitions
net: mvpp2: fix indentation of MVPP2_EXT_GLOBAL_CTRL_DEFAULT
net: mvpp2: remove unused register definitions
net: mvpp2: simplify mvpp2_bm_bufs_add()
net: mvpp2: drop useless fields in mvpp2_bm_pool and related code
net: mvpp2: remove unused 'tx_skb' field of 'struct mvpp2_tx_queue'
net: mvpp2: release reference to txq_cpu[] entry after unmapping
net: mvpp2: handle too large value in mvpp2_rx_time_coal_set()
net: mvpp2: handle too large value handling in mvpp2_rx_pkts_coal_set()
net: mvpp2: remove useless arguments in mvpp2_rx_{pkts, time}_coal_set
- Implement wraparound-safe refcount_t and kref_t types based on
generic atomic primitives (Peter Zijlstra)
- Improve and fix the ww_mutex code (Nicolai Hähnle)
- Add self-tests to the ww_mutex code (Chris Wilson)
- Optimize percpu-rwsems with the 'rcuwait' mechanism (Davidlohr
Bueso)
- Micro-optimize the current-task logic all around the core kernel
(Davidlohr Bueso)
- Tidy up after recent optimizations: remove stale code and APIs,
clean up the code (Waiman Long)
- ... plus misc fixes, updates and cleanups"
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (50 commits)
fork: Fix task_struct alignment
locking/spinlock/debug: Remove spinlock lockup detection code
lockdep: Fix incorrect condition to print bug msgs for MAX_LOCKDEP_CHAIN_HLOCKS
lkdtm: Convert to refcount_t testing
kref: Implement 'struct kref' using refcount_t
refcount_t: Introduce a special purpose refcount type
sched/wake_q: Clarify queue reinit comment
sched/wait, rcuwait: Fix typo in comment
locking/mutex: Fix lockdep_assert_held() fail
locking/rtmutex: Flip unlikely() branch to likely() in __rt_mutex_slowlock()
locking/rwsem: Reinit wake_q after use
locking/rwsem: Remove unnecessary atomic_long_t casts
jump_labels: Move header guard #endif down where it belongs
locking/atomic, kref: Implement kref_put_lock()
locking/ww_mutex: Turn off __must_check for now
locking/atomic, kref: Avoid more abuse
locking/atomic, kref: Use kref_get_unless_zero() more
locking/atomic, kref: Kill kref_sub()
locking/atomic, kref: Add kref_read()
locking/atomic, kref: Add KREF_INIT()
