path: root/lib/Kconfig.debug
2007-07-19lockstat: core infrastructurePeter Zijlstra
Introduce the core lock statistics code. Lock statistics provides lock wait-time and hold-time (as well as the count of corresponding contention and acquisitions events). Also, the first few call-sites that encounter contention are tracked. Lock wait-time is the time spent waiting on the lock. This provides insight into the locking scheme, that is, a heavily contended lock is indicative of a too coarse locking scheme. Lock hold-time is the duration the lock was held, this provides a reference for the wait-time numbers, so they can be put into perspective. 1) lock 2) ... do stuff .. unlock 3) The time between 1 and 2 is the wait-time. The time between 2 and 3 is the hold-time. The lockdep held-lock tracking code is reused, because it already collects locks into meaningful groups (classes), and because it is an existing infrastructure for lock instrumentation. Currently lockdep tracks lock acquisition with two hooks: lock() lock_acquire() _lock() ... code protected by lock ... unlock() lock_release() _unlock() We need to extend this with two more hooks, in order to measure contention. lock_contended() - used to measure contention events lock_acquired() - completion of the contention These are then placed the following way: lock() lock_acquire() if (!_try_lock()) lock_contended() _lock() lock_acquired() ... do locked stuff ... unlock() lock_release() _unlock() (Note: the try_lock() 'trick' is used to avoid instrumenting all platform dependent lock primitive implementations.) It is also possible to toggle the two lockdep features at runtime using: /proc/sys/kernel/prove_locking /proc/sys/kernel/lock_stat (esp. turning off the O(n^2) prove_locking functionaliy can help) [akpm@linux-foundation.org: build fixes] [akpm@linux-foundation.org: nuke unneeded ifdefs] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16SLUB: support slub_debug on by defaultChristoph Lameter
Add a new configuration variable CONFIG_SLUB_DEBUG_ON If set then the kernel will be booted by default with slab debugging switched on. Similar to CONFIG_SLAB_DEBUG. By default slab debugging is available but must be enabled by specifying "slub_debug" as a kernel parameter. Also add support to switch off slab debugging for a kernel that was built with CONFIG_SLUB_DEBUG_ON. This works by specifying slub_debug=- as a kernel parameter. Dave Jones wanted this feature. http://marc.info/?l=linux-kernel&m=118072189913045&w=2 [akpm@linux-foundation.org: clean up switch statement] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-09sched: scheduler debugging, enable in KconfigIngo Molnar
enable CONFIG_SCHED_DEBUG in lib/Kconfig.debug. the runtime overhead of this option is very small. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-06-01timer stats: speedupsIngo Molnar
Make timer-stats have almost zero overhead when enabled in the config but not used. (this way distros can enable it more easily) Also update the documentation about overhead of timer_stats - it was written for the first version which had a global lock and a linear list walk based lookup ;-) Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23prohibit rcutorture from being compiled into the kernelPaul E. McKenney
There have been a number of instances where people have accidentally compiled rcutorture into the kernel (CONFIG_RCU_TORTURE_TEST=y), which has never been useful, and has often resulted in great frustration. The attached patch prohibits rcutorture from being compiled into the kernel. It may be excluded altogether or compiled as a module. People wishing to have rcutorture hammer their machine immediately upon boot are free to hand-edit lib/Kconfig.debug to remove the "depends on m" line. Thanks to Randy Dunlap for the trick that makes this work. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Josh Triplett <josh@kernel.org> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-12fault injection: disable stacktrace filter for x86-64Akinobu Mita
Disable stacktrace filter support for x86-64 for now. Will be enable when we can get the dwarf2 unwinder back. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Move LOG_BUF_SHIFT to a more sensible placeAlistair John Strachan
Several people have observed that perhaps LOG_BUF_SHIFT should be in a more obvious place than under DEBUG_KERNEL. Under some circumstances (such as the PARISC architecture), DEBUG_KERNEL can increase kernel size, which is an undesirable trade off for something as trivial as increasing the kernel log buffer size. Instead, move LOG_BUF_SHIFT into "General Setup", so that people are more likely to be able to change it such a circumstance that the default buffer size is insufficient. Signed-off-by: Alistair John Strachan <s0348365@sms.ed.ac.uk> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08kconfig: centralize the selection of semaphore debugging in lib/Kconfig.debugRobert P. J. Day
Remove the Kconfig selection of semaphore debugging from the ALPHA and FRV Kconfig files, and centralize it in lib/Kconfig.debug. There doesn't seem to be much point in letting individual architectures independently define the same Kconfig option when it can just as easily be put in a single Kconfig file and made dependent on a subset of architectures. that way, at least the option shows up in the same relative location in the menu each time. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: David Howells <dhowells@redhat.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07blackfin architectureBryan Wu
This adds support for the Analog Devices Blackfin processor architecture, and currently supports the BF533, BF532, BF531, BF537, BF536, BF534, and BF561 (Dual Core) devices, with a variety of development platforms including those avaliable from Analog Devices (BF533-EZKit, BF533-STAMP, BF537-STAMP, BF561-EZKIT), and Bluetechnix! Tinyboards. The Blackfin architecture was jointly developed by Intel and Analog Devices Inc. (ADI) as the Micro Signal Architecture (MSA) core and introduced it in December of 2000. Since then ADI has put this core into its Blackfin processor family of devices. The Blackfin core has the advantages of a clean, orthogonal,RISC-like microprocessor instruction set. It combines a dual-MAC (Multiply/Accumulate), state-of-the-art signal processing engine and single-instruction, multiple-data (SIMD) multimedia capabilities into a single instruction-set architecture. The Blackfin architecture, including the instruction set, is described by the ADSP-BF53x/BF56x Blackfin Processor Programming Reference http://blackfin.uclinux.org/gf/download/frsrelease/29/2549/Blackfin_PRM.pdf The Blackfin processor is already supported by major releases of gcc, and there are binary and source rpms/tarballs for many architectures at: http://blackfin.uclinux.org/gf/project/toolchain/frs There is complete documentation, including "getting started" guides available at: http://docs.blackfin.uclinux.org/ which provides links to the sources and patches you will need in order to set up a cross-compiling environment for bfin-linux-uclibc This patch, as well as the other patches (toolchain, distribution, uClibc) are actively supported by Analog Devices Inc, at: http://blackfin.uclinux.org/ We have tested this on LTP, and our test plan (including pass/fails) can be found at: http://docs.blackfin.uclinux.org/doku.php?id=testing_the_linux_kernel [m.kozlowski@tuxland.pl: balance parenthesis in blackfin header files] Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Aubrey Li <aubrey.li@analog.com> Signed-off-by: Jie Zhang <jie.zhang@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02kconfig.debug: clarify CONFIG_DEBUG_INFO help textAndreas Dilger
The following patch adds some extra clarification to the CONFIG_DEBUG_INFO Kconfig help text. The current text is mostly a recursive definition and doesn't really say much of anything. When I first read this I thought it was going to enable extra verbosity in debug messages or something, but it is only enabling the "gcc -g" compile option in the Makefile. Signed-off-by: Andreas Dilger <adilger@clusterfs.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-04-27[MIPS] Don't force frame pointers for lockdep on MIPSFranck Bui-Huu
Stacktrace support on MIPS doesn't use frame pointers. Since this option considerably increases the size of the kernel code, force lockdep to not use it. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-20[PATCH] fault injection: split up stacktrace filter Kconfig optionAkinobu Mita
There is no prompt for CONFIG_STACKTRACE, so FAULT_INJECTION cannot be selected without LOCKDEP enabled. (found by Paolo 'Blaisorblade' Giarrusso) In order to fix such broken Kconfig dependency, this patch splits up the stacktrace filter support for fault injection by new Kconfig option, which enables to use fault injection on the architecture which doesn't have general stacktrace support. Cc: "Paolo 'Blaisorblade' Giarrusso" <blaisorblade@yahoo.it> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] Add debugging feature /proc/timer_statIngo Molnar
Add /proc/timer_stats support: debugging feature to profile timer expiration. Both the starting site, process/PID and the expiration function is captured. This allows the quick identification of timer event sources in a system. Sample output: # echo 1 > /proc/timer_stats # cat /proc/timer_stats Timer Stats Version: v0.1 Sample period: 4.010 s 24, 0 swapper hrtimer_stop_sched_tick (hrtimer_sched_tick) 11, 0 swapper sk_reset_timer (tcp_delack_timer) 6, 0 swapper hrtimer_stop_sched_tick (hrtimer_sched_tick) 2, 1 swapper queue_delayed_work_on (delayed_work_timer_fn) 17, 0 swapper hrtimer_restart_sched_tick (hrtimer_sched_tick) 2, 1 swapper queue_delayed_work_on (delayed_work_timer_fn) 4, 2050 pcscd do_nanosleep (hrtimer_wakeup) 5, 4179 sshd sk_reset_timer (tcp_write_timer) 4, 2248 yum-updatesd schedule_timeout (process_timeout) 18, 0 swapper hrtimer_restart_sched_tick (hrtimer_sched_tick) 3, 0 swapper sk_reset_timer (tcp_delack_timer) 1, 1 swapper neigh_table_init_no_netlink (neigh_periodic_timer) 2, 1 swapper e1000_up (e1000_watchdog) 1, 1 init schedule_timeout (process_timeout) 100 total events, 25.24 events/sec [ cleanups and hrtimers support from Thomas Gleixner <tglx@linutronix.de> ] [bunk@stusta.de: nr_entries can become static] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] Debug shared irqsDavid Woodhouse
Drivers registering IRQ handlers with SA_SHIRQ really ought to be able to handle an interrupt happening before request_irq() returns. They also ought to be able to handle an interrupt happening during the start of their call to free_irq(). Let's test that hypothesis.... [bunk@stusta.de: Kconfig fixes] Signed-off-by: David Woodhouse <dwmw2@infradead.org> Cc: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Remove references to obsolete kernel config option DEBUG_RWSEMSRobert P. J. Day
Remove the few references to the obsolete kernel config option DEBUG_RWSEMS. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-15Remove stack unwinder for nowLinus Torvalds
It has caused more problems than it ever really solved, and is apparently not getting cleaned up and fixed. We can put it back when it's stable and isn't likely to make warning or bug events worse. In the meantime, enable frame pointers for more readable stack traces. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-12Fix typo in new debug options.Dave Jones
Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-10[PATCH] Kconfig refactoring for better menu nestingDon Mullis
Refactor Kconfig content to maximize nesting of menus by menuconfig and xconfig. Tested by simultaneously running `make xconfig` with and without patch, and comparing displays. Signed-off-by: Don Mullis <dwm@meer.net> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] fault-injection: stacktrace filtering kconfig fixAndrew Morton
`select' doesn't work very well. With alpha `make allmodconfig' we end up with CONFIG_STACKTRACE enabled, so we end up with undefined save_stacktrace() at link time. Cc: Akinobu Mita <akinobu.mita@gmail.com> Cc: Don Mullis <dwm@meer.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] fault-injection Kconfig cleanupAndrew Morton
- Fix some spelling and grammatical errors - Make the Kconfig menu more conventional. First you select fault-injection, then under that you select particular clients of it. Cc: Akinobu Mita <akinobu.mita@gmail.com> Cc: Don Mullis <dwm@meer.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] fault injection: stacktrace filteringAkinobu Mita
This patch provides stacktrace filtering feature. The stacktrace filter allows failing only for the caller you are interested in. For example someone may want to inject kmalloc() failures into only e100 module. they want to inject not only direct kmalloc() call, but also indirect allocation, too. - e100_poll --> netif_receive_skb --> packet_rcv_spkt --> skb_clone --> kmem_cache_alloc This patch enables to detect function calls like this by stacktrace and inject failures. The script Documentaion/fault-injection/failmodule.sh helps it. The range of text section of loaded e100 is expected to be [/sys/module/e100/sections/.text, /sys/module/e100/sections/.exit.text) So failmodule.sh stores these values into /debug/failslab/address-start and /debug/failslab/address-end. The maximum stacktrace depth is specified by /debug/failslab/stacktrace-depth. Please see the example that demonstrates how to inject slab allocation failures only for a specific module in Documentation/fault-injection/fault-injection.txt [dwm@meer.net: reject failure if any caller lies within specified range] Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Don Mullis <dwm@meer.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] fault-injection capability for disk IOAkinobu Mita
This patch provides fault-injection capability for disk IO. Boot option: fail_make_request=<probability>,<interval>,<space>,<times> <interval> -- specifies the interval of failures. <probability> -- specifies how often it should fail in percent. <space> -- specifies the size of free space where disk IO can be issued safely in bytes. <times> -- specifies how many times failures may happen at most. Debugfs: /debug/fail_make_request/interval /debug/fail_make_request/probability /debug/fail_make_request/specifies /debug/fail_make_request/times Example: fail_make_request=10,100,0,-1 echo 1 > /sys/blocks/hda/hda1/make-it-fail generic_make_request() on /dev/hda1 fails once per 10 times. Cc: Jens Axboe <axboe@suse.de> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] fault-injection capability for alloc_pages()Akinobu Mita
This patch provides fault-injection capability for alloc_pages() Boot option: fail_page_alloc=<interval>,<probability>,<space>,<times> <interval> -- specifies the interval of failures. <probability> -- specifies how often it should fail in percent. <space> -- specifies the size of free space where memory can be allocated safely in pages. <times> -- specifies how many times failures may happen at most. Debugfs: /debug/fail_page_alloc/interval /debug/fail_page_alloc/probability /debug/fail_page_alloc/specifies /debug/fail_page_alloc/times /debug/fail_page_alloc/ignore-gfp-highmem /debug/fail_page_alloc/ignore-gfp-wait Example: fail_page_alloc=10,100,0,-1 The page allocation (alloc_pages(), ...) fails once per 10 times. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] fault-injection capability for kmallocAkinobu Mita
This patch provides fault-injection capability for kmalloc. Boot option: failslab=<interval>,<probability>,<space>,<times> <interval> -- specifies the interval of failures. <probability> -- specifies how often it should fail in percent. <space> -- specifies the size of free space where memory can be allocated safely in bytes. <times> -- specifies how many times failures may happen at most. Debugfs: /debug/failslab/interval /debug/failslab/probability /debug/failslab/specifies /debug/failslab/times /debug/failslab/ignore-gfp-highmem /debug/failslab/ignore-gfp-wait Example: failslab=10,100,0,-1 slab allocation (kmalloc(), kmem_cache_alloc(),..) fails once per 10 times. Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] fault-injection capabilities infrastructureAkinobu Mita
This patch provides base functions implement to fault-injection capabilities. - The function should_fail() is taken from failmalloc-1.0 (http://www.nongnu.org/failmalloc/) [akpm@osdl.org: cleanups, comments, add __init] Cc: <okuji@enbug.org> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Don Mullis <dwm@meer.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] Generic BUG for i386Jeremy Fitzhardinge
This makes i386 use the generic BUG machinery. There are no functional changes from the old i386 implementation. The main advantage in using the generic BUG machinery for i386 is that the inlined overhead of BUG is just the ud2a instruction; the file+line(+function) information are no longer inlined into the instruction stream. This reduces cache pollution, and makes disassembly work properly. Signed-off-by: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Andi Kleen <ak@muc.de> Cc: Hugh Dickens <hugh@veritas.com> Cc: Michael Ellerman <michael@ellerman.id.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] Generic BUG implementationJeremy Fitzhardinge
This patch adds common handling for kernel BUGs, for use by architectures as they wish. The code is derived from arch/powerpc. The advantages of having common BUG handling are: - consistent BUG reporting across architectures - shared implementation of out-of-line file/line data - implement CONFIG_DEBUG_BUGVERBOSE consistently This means that in inline impact of BUG is just the illegal instruction itself, which is an improvement for i386 and x86-64. A BUG is represented in the instruction stream as an illegal instruction, which has file/line information associated with it. This extra information is stored in the __bug_table section in the ELF file. When the kernel gets an illegal instruction, it first confirms it might possibly be from a BUG (ie, in kernel mode, the right illegal instruction). It then calls report_bug(). This searches __bug_table for a matching instruction pointer, and if found, prints the corresponding file/line information. If report_bug() determines that it wasn't a BUG which caused the trap, it returns BUG_TRAP_TYPE_NONE. Some architectures (powerpc) implement WARN using the same mechanism; if the illegal instruction was the result of a WARN, then report_bug(Q) returns CONFIG_DEBUG_BUGVERBOSE; otherwise it returns BUG_TRAP_TYPE_BUG. lib/bug.c keeps a list of loaded modules which can be searched for __bug_table entries. The architecture must call module_bug_finalize()/module_bug_cleanup() from its corresponding module_finalize/cleanup functions. Unsetting CONFIG_DEBUG_BUGVERBOSE will reduce the kernel size by some amount. At the very least, filename and line information will not be recorded for each but, but architectures may decide to store no extra information per BUG at all. Unfortunately, gcc doesn't have a general way to mark an asm() as noreturn, so architectures will generally have to include an infinite loop (or similar) in the BUG code, so that gcc knows execution won't continue beyond that point. gcc does have a __builtin_trap() operator which may be useful to achieve the same effect, unfortunately it cannot be used to actually implement the BUG itself, because there's no way to get the instruction's address for use in generating the __bug_table entry. [randy.dunlap@oracle.com: Handle BUG=n, GENERIC_BUG=n to prevent build errors] [bunk@stusta.de: include/linux/bug.h must always #include <linux/module.h] Signed-off-by: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Andi Kleen <ak@muc.de> Cc: Hugh Dickens <hugh@veritas.com> Cc: Michael Ellerman <michael@ellerman.id.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] kconfig: PRINTK_TIME depends on PRINTKRandy Dunlap
Make PRINTK_TIME depend on PRINTK. Only display/offer it if PRINTK is enabled. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[ARM] 3909/1: Disable UWIND_INFO for ARM (again)Kevin Hilman
According to Daniel Jacobowitz, UNWIND_INFO is not useful on ARM, and in fact doesn't even compile. This patch disables the option for ARM. Signed-off-by: Kevin Hilman <khilman@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-13[PATCH] uml shouldn't do HEADERS_CHECKAl Viro
The lack of asm-um/Kbuild is deliberate. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] Add CONFIG_HEADERS_CHECK option to automatically run 'make ↵David Woodhouse
headers_check' In order to encourage people to notice when they break the exported headers, add a config option which automatically runs the sanity checks when building vmlinux. That way, those who use allyesconfig will notice failures. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] Disable DETECT_SOFTLOCKUP for s390Heiko Carstens
We got several false bug reports because of enabled CONFIG_DETECT_SOFTLOCKUP. Disable soft lockup detection on s390, since it doesn't work on a virtualized architecture. Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] Linux Kernel Dump Test ModuleAnkita Garg
A simple module to test Linux Kernel Dump mechanism. This module uses jprobes to install/activate pre-defined crash points. At different crash points, various types of crashing scenarios are created like a BUG(), panic(), exception, recursive loop and stack overflow. The user can activate a crash point with specific type by providing parameters at the time of module insertion. Please see the file header for usage information. The module is based on the Linux Kernel Dump Test Tool by Fernando <http://lkdtt.sourceforge.net>. This module could be merged with mainline. Jprobes is used here so that the context in which crash point is hit, could be maintained. This implements all the crash points as done by LKDTT except the one in the middle of tasklet_action(). Signed-off-by: Ankita Garg <ankita@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] Debug variants of linked list macrosDave Jones
Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27sh: Enable verbose BUG() support.Paul Mundt
Add SH to the list of platforms interested in Verbose BUG(). Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-09-27sh: Use generic CONFIG_FRAME_POINTER.Paul Mundt
We had our own version, which serves no purpose. Simply hook SH in to the generic one. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-09-26Merge branch 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6Linus Torvalds
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6: (225 commits) [PATCH] Don't set calgary iommu as default y [PATCH] i386/x86-64: New Intel feature flags [PATCH] x86: Add a cumulative thermal throttle event counter. [PATCH] i386: Make the jiffies compares use the 64bit safe macros. [PATCH] x86: Refactor thermal throttle processing [PATCH] Add 64bit jiffies compares (for use with get_jiffies_64) [PATCH] Fix unwinder warning in traps.c [PATCH] x86: Allow disabling early pci scans with pci=noearly or disallowing conf1 [PATCH] x86: Move direct PCI scanning functions out of line [PATCH] i386/x86-64: Make all early PCI scans dependent on CONFIG_PCI [PATCH] Don't leak NT bit into next task [PATCH] i386/x86-64: Work around gcc bug with noreturn functions in unwinder [PATCH] Fix some broken white space in ia32_signal.c [PATCH] Initialize argument registers for 32bit signal handlers. [PATCH] Remove all traces of signal number conversion [PATCH] Don't synchronize time reading on single core AMD systems [PATCH] Remove outdated comment in x86-64 mmconfig code [PATCH] Use string instructions for Core2 copy/clear [PATCH] x86: - restore i8259A eoi status on resume [PATCH] i386: Split multi-line printk in oops output. ...
2006-09-26Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6: (47 commits) Driver core: Don't call put methods while holding a spinlock Driver core: Remove unneeded routines from driver core Driver core: Fix potential deadlock in driver core PCI: enable driver multi-threaded probe Driver Core: add ability for drivers to do a threaded probe sysfs: add proper sysfs_init() prototype drivers/base: check errors drivers/base: Platform notify needs to occur before drivers attach to the device v4l-dev2: handle __must_check add CONFIG_ENABLE_MUST_CHECK add __must_check to device management code Driver core: fixed add_bind_files() definition Driver core: fix comments in drivers/base/power/resume.c sysfs_remove_bin_file: no return value, dump_stack on error kobject: must_check fixes Driver core: add ability for devices to create and remove bin files Class: add support for class interfaces for devices Driver core: create devices/virtual/ tree Driver core: add device_rename function Driver core: add ability for classes to handle devices properly ...
2006-09-26[PATCH] avr32 architectureHaavard Skinnemoen
This adds support for the Atmel AVR32 architecture as well as the AT32AP7000 CPU and the AT32STK1000 development board. AVR32 is a new high-performance 32-bit RISC microprocessor core, designed for cost-sensitive embedded applications, with particular emphasis on low power consumption and high code density. The AVR32 architecture is not binary compatible with earlier 8-bit AVR architectures. The AVR32 architecture, including the instruction set, is described by the AVR32 Architecture Manual, available from http://www.atmel.com/dyn/resources/prod_documents/doc32000.pdf The Atmel AT32AP7000 is the first CPU implementing the AVR32 architecture. It features a 7-stage pipeline, 16KB instruction and data caches and a full Memory Management Unit. It also comes with a large set of integrated peripherals, many of which are shared with the AT91 ARM-based controllers from Atmel. Full data sheet is available from http://www.atmel.com/dyn/resources/prod_documents/doc32003.pdf while the CPU core implementation including caches and MMU is documented by the AVR32 AP Technical Reference, available from http://www.atmel.com/dyn/resources/prod_documents/doc32001.pdf Information about the AT32STK1000 development board can be found at http://www.atmel.com/dyn/products/tools_card.asp?tool_id=3918 including a BSP CD image with an earlier version of this patch, development tools (binaries and source/patches) and a root filesystem image suitable for booting from SD card. Alternatively, there's a preliminary "getting started" guide available at http://avr32linux.org/twiki/bin/view/Main/GettingStarted which provides links to the sources and patches you will need in order to set up a cross-compiling environment for avr32-linux. This patch, as well as the other patches included with the BSP and the toolchain patches, is actively supported by Atmel Corporation. [dmccr@us.ibm.com: Fix more pxx_page macro locations] [bunk@stusta.de: fix `make defconfig'] Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Dave McCracken <dmccr@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] Don't force frame pointers for lockdepAndi Kleen
Now that stacktrace supports dwarf2 don't force frame pointers for lockdep anymore Cc: mingo@elte.hu Signed-off-by: Andi Kleen <ak@suse.de>
2006-09-25add CONFIG_ENABLE_MUST_CHECKAndrew Morton
Those 1500 warnings can be a bit of a pain. Add a config option to shut them up. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-14[PATCH] let the the lockdep options depend on DEBUG_KERNELAdrian Bunk
The lockdep options should depend on DEBUG_KERNEL since: - they are kernel debugging options and - they do otherwise break the DEBUG_KERNEL menu structure Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: kconfigIngo Molnar
Offer the following lock validation options: CONFIG_PROVE_LOCKING Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: coreIngo Molnar
Do 'make oldconfig' and accept all the defaults for new config options - reboot into the kernel and if everything goes well it should boot up fine and you should have /proc/lockdep and /proc/lockdep_stats files. Typically if the lock validator finds some problem it will print out voluminous debug output that begins with "BUG: ..." and which syslog output can be used by kernel developers to figure out the precise locking scenario. What does the lock validator do? It "observes" and maps all locking rules as they occur dynamically (as triggered by the kernel's natural use of spinlocks, rwlocks, mutexes and rwsems). Whenever the lock validator subsystem detects a new locking scenario, it validates this new rule against the existing set of rules. If this new rule is consistent with the existing set of rules then the new rule is added transparently and the kernel continues as normal. If the new rule could create a deadlock scenario then this condition is printed out. When determining validity of locking, all possible "deadlock scenarios" are considered: assuming arbitrary number of CPUs, arbitrary irq context and task context constellations, running arbitrary combinations of all the existing locking scenarios. In a typical system this means millions of separate scenarios. This is why we call it a "locking correctness" validator - for all rules that are observed the lock validator proves it with mathematical certainty that a deadlock could not occur (assuming that the lock validator implementation itself is correct and its internal data structures are not corrupted by some other kernel subsystem). [see more details and conditionals of this statement in include/linux/lockdep.h and Documentation/lockdep-design.txt] Furthermore, this "all possible scenarios" property of the validator also enables the finding of complex, highly unlikely multi-CPU multi-context races via single single-context rules, increasing the likelyhood of finding bugs drastically. In practical terms: the lock validator already found a bug in the upstream kernel that could only occur on systems with 3 or more CPUs, and which needed 3 very unlikely code sequences to occur at once on the 3 CPUs. That bug was found and reported on a single-CPU system (!). So in essence a race will be found "piecemail-wise", triggering all the necessary components for the race, without having to reproduce the race scenario itself! In its short existence the lock validator found and reported many bugs before they actually caused a real deadlock. To further increase the efficiency of the validator, the mapping is not per "lock instance", but per "lock-class". For example, all struct inode objects in the kernel have inode->inotify_mutex. If there are 10,000 inodes cached, then there are 10,000 lock objects. But ->inotify_mutex is a single "lock type", and all locking activities that occur against ->inotify_mutex are "unified" into this single lock-class. The advantage of the lock-class approach is that all historical ->inotify_mutex uses are mapped into a single (and as narrow as possible) set of locking rules - regardless of how many different tasks or inode structures it took to build this set of rules. The set of rules persist during the lifetime of the kernel. To see the rough magnitude of checking that the lock validator does, here's a portion of /proc/lockdep_stats, fresh after bootup: lock-classes: 694 [max: 2048] direct dependencies: 1598 [max: 8192] indirect dependencies: 17896 all direct dependencies: 16206 dependency chains: 1910 [max: 8192] in-hardirq chains: 17 in-softirq chains: 105 in-process chains: 1065 stack-trace entries: 38761 [max: 131072] combined max dependencies: 2033928 hardirq-safe locks: 24 hardirq-unsafe locks: 176 softirq-safe locks: 53 softirq-unsafe locks: 137 irq-safe locks: 59 irq-unsafe locks: 176 The lock validator has observed 1598 actual single-thread locking patterns, and has validated all possible 2033928 distinct locking scenarios. More details about the design of the lock validator can be found in Documentation/lockdep-design.txt, which can also found at: http://redhat.com/~mingo/lockdep-patches/lockdep-design.txt [bunk@stusta.de: cleanups] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: locking API self testsIngo Molnar
Introduce DEBUG_LOCKING_API_SELFTESTS, which uses the generic lock debugging code's silent-failure feature to run a matrix of testcases. There are 210 testcases currently: +----------------------- | Locking API testsuite: +------------------------------+------+------+------+------+------+------+ | spin |wlock |rlock |mutex | wsem | rsem | -------------------------------+------+------+------+------+------+------+ A-A deadlock: ok | ok | ok | ok | ok | ok | A-B-B-A deadlock: ok | ok | ok | ok | ok | ok | A-B-B-C-C-A deadlock: ok | ok | ok | ok | ok | ok | A-B-C-A-B-C deadlock: ok | ok | ok | ok | ok | ok | A-B-B-C-C-D-D-A deadlock: ok | ok | ok | ok | ok | ok | A-B-C-D-B-D-D-A deadlock: ok | ok | ok | ok | ok | ok | A-B-C-D-B-C-D-A deadlock: ok | ok | ok | ok | ok | ok | double unlock: ok | ok | ok | ok | ok | ok | bad unlock order: ok | ok | ok | ok | ok | ok | --------------------------------------+------+------+------+------+------+ recursive read-lock: | ok | | ok | --------------------------------------+------+------+------+------+------+ non-nested unlock: ok | ok | ok | ok | --------------------------------------+------+------+------+ hard-irqs-on + irq-safe-A/12: ok | ok | ok | soft-irqs-on + irq-safe-A/12: ok | ok | ok | hard-irqs-on + irq-safe-A/21: ok | ok | ok | soft-irqs-on + irq-safe-A/21: ok | ok | ok | sirq-safe-A => hirqs-on/12: ok | ok | ok | sirq-safe-A => hirqs-on/21: ok | ok | ok | hard-safe-A + irqs-on/12: ok | ok | ok | soft-safe-A + irqs-on/12: ok | ok | ok | hard-safe-A + irqs-on/21: ok | ok | ok | soft-safe-A + irqs-on/21: ok | ok | ok | hard-safe-A + unsafe-B #1/123: ok | ok | ok | soft-safe-A + unsafe-B #1/123: ok | ok | ok | hard-safe-A + unsafe-B #1/132: ok | ok | ok | soft-safe-A + unsafe-B #1/132: ok | ok | ok | hard-safe-A + unsafe-B #1/213: ok | ok | ok | soft-safe-A + unsafe-B #1/213: ok | ok | ok | hard-safe-A + unsafe-B #1/231: ok | ok | ok | soft-safe-A + unsafe-B #1/231: ok | ok | ok | hard-safe-A + unsafe-B #1/312: ok | ok | ok | soft-safe-A + unsafe-B #1/312: ok | ok | ok | hard-safe-A + unsafe-B #1/321: ok | ok | ok | soft-safe-A + unsafe-B #1/321: ok | ok | ok | hard-safe-A + unsafe-B #2/123: ok | ok | ok | soft-safe-A + unsafe-B #2/123: ok | ok | ok | hard-safe-A + unsafe-B #2/132: ok | ok | ok | soft-safe-A + unsafe-B #2/132: ok | ok | ok | hard-safe-A + unsafe-B #2/213: ok | ok | ok | soft-safe-A + unsafe-B #2/213: ok | ok | ok | hard-safe-A + unsafe-B #2/231: ok | ok | ok | soft-safe-A + unsafe-B #2/231: ok | ok | ok | hard-safe-A + unsafe-B #2/312: ok | ok | ok | soft-safe-A + unsafe-B #2/312: ok | ok | ok | hard-safe-A + unsafe-B #2/321: ok | ok | ok | soft-safe-A + unsafe-B #2/321: ok | ok | ok | hard-irq lock-inversion/123: ok | ok | ok | soft-irq lock-inversion/123: ok | ok | ok | hard-irq lock-inversion/132: ok | ok | ok | soft-irq lock-inversion/132: ok | ok | ok | hard-irq lock-inversion/213: ok | ok | ok | soft-irq lock-inversion/213: ok | ok | ok | hard-irq lock-inversion/231: ok | ok | ok | soft-irq lock-inversion/231: ok | ok | ok | hard-irq lock-inversion/312: ok | ok | ok | soft-irq lock-inversion/312: ok | ok | ok | hard-irq lock-inversion/321: ok | ok | ok | soft-irq lock-inversion/321: ok | ok | ok | hard-irq read-recursion/123: ok | soft-irq read-recursion/123: ok | hard-irq read-recursion/132: ok | soft-irq read-recursion/132: ok | hard-irq read-recursion/213: ok | soft-irq read-recursion/213: ok | hard-irq read-recursion/231: ok | soft-irq read-recursion/231: ok | hard-irq read-recursion/312: ok | soft-irq read-recursion/312: ok | hard-irq read-recursion/321: ok | soft-irq read-recursion/321: ok | --------------------------------+-----+---------------- Good, all 210 testcases passed! | --------------------------------+ Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: s390 CONFIG_FRAME_POINTER supportHeiko Carstens
CONFIG_FRAME_POINTER support for s390. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: stacktrace subsystem, coreIngo Molnar
Framework to generate and save stacktraces quickly, without printing anything to the console. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: remove mutex deadlock checking codeIngo Molnar
With the lock validator we detect mutex deadlocks (and more), the mutex deadlock checking code is both redundant and slower. So remove it. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[PATCH] Add EXPORT_UNUSED_SYMBOL and EXPORT_UNUSED_SYMBOL_GPLArjan van de Ven
Temporarily add EXPORT_UNUSED_SYMBOL and EXPORT_UNUSED_SYMBOL_GPL. These will be used as a transition measure for symbols that aren't used in the kernel and are on the way out. When a module uses such a symbol, a warning is printk'd at modprobe time. The main reason for removing unused exports is size: eacho export takes roughly between 100 and 150 bytes of kernel space in the binary. This patch gives users the option to immediately get this size gain via a config option. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] fix rt-mutex defaults and dependenciesRoman Zippel
Fix defaults and dependencies. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
