path: root/lib/Makefile
2009-03-28Merge branch 'linus' into core/iommuIngo Molnar
Conflicts: arch/x86/Kconfig
2009-03-27Merge branch 'core/percpu' into percpu-cpumask-x86-for-linus-2Ingo Molnar
Conflicts: arch/parisc/kernel/irq.c arch/x86/include/asm/fixmap_64.h arch/x86/include/asm/setup.h kernel/irq/handle.c Semantic merge: arch/x86/include/asm/fixmap.h Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-26Merge branch 'sched-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (46 commits) sched: Add comments to find_busiest_group() function sched: Refactor the power savings balance code sched: Optimize the !power_savings_balance during fbg() sched: Create a helper function to calculate imbalance sched: Create helper to calculate small_imbalance in fbg() sched: Create a helper function to calculate sched_domain stats for fbg() sched: Define structure to store the sched_domain statistics for fbg() sched: Create a helper function to calculate sched_group stats for fbg() sched: Define structure to store the sched_group statistics for fbg() sched: Fix indentations in find_busiest_group() using gotos sched: Simple helper functions for find_busiest_group() sched: remove unused fields from struct rq sched: jiffies not printed per CPU sched: small optimisation of can_migrate_task() sched: fix typos in documentation sched: add avg_overlap decay x86, sched_clock(): mark variables read-mostly sched: optimize ttwu vs group scheduling sched: TIF_NEED_RESCHED -> need_reshed() cleanup sched: don't rebalance if attached on NULL domain ...
2009-03-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (61 commits) Dynamic debug: fix pr_fmt() build error Dynamic debug: allow simple quoting of words dynamic debug: update docs dynamic debug: combine dprintk and dynamic printk sysfs: fix some bin_vm_ops errors kobject: don't block for each kobject_uevent sysfs: only allow one scheduled removal callback per kobj Driver core: Fix device_move() vs. dpm list ordering, v2 Driver core: some cleanup on drivers/base/sys.c Driver core: implement uevent suppress in kobject vcs: hook sysfs devices into object lifetime instead of "binding" driver core: fix passing platform_data driver core: move platform_data into platform_device sysfs: don't block indefinitely for unmapped files. driver core: move knode_bus into private structure driver core: move knode_driver into private structure driver core: move klist_children into private structure driver core: create a private portion of struct device driver core: remove polling for driver_probe_done(v5) sysfs: reference sysfs_dirent from sysfs inodes ... Fixed conflicts in drivers/sh/maple/maple.c manually
2009-03-24dynamic debug: combine dprintk and dynamic printkJason Baron
This patch combines Greg Bank's dprintk() work with the existing dynamic printk patchset, we are now calling it 'dynamic debug'. The new feature of this patchset is a richer /debugfs control file interface, (an example output from my system is at the bottom), which allows fined grained control over the the debug output. The output can be controlled by function, file, module, format string, and line number. for example, enabled all debug messages in module 'nf_conntrack': echo -n 'module nf_conntrack +p' > /mnt/debugfs/dynamic_debug/control to disable them: echo -n 'module nf_conntrack -p' > /mnt/debugfs/dynamic_debug/control A further explanation can be found in the documentation patch. Signed-off-by: Greg Banks <gnb@sgi.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-05dma-debug: add header file and core data structuresJoerg Roedel
Impact: add groundwork for DMA-API debugging Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-03-04netlink: Move netlink attribute parsing support to libGeert Uytterhoeven
Netlink attribute parsing may be used even if CONFIG_NET is not set. Move it from net/netlink to lib and control its inclusion based on the new config symbol CONFIG_NLATTR, which is selected by CONFIG_NET. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-01-16sched: make plist a library facilityPeter Zijlstra
Ingo Molnar wrote: > here's a new build failure with tip/sched/rt: > > LD .tmp_vmlinux1 > kernel/built-in.o: In function `set_curr_task_rt': > sched.c:(.text+0x3675): undefined reference to `plist_del' > kernel/built-in.o: In function `pick_next_task_rt': > sched.c:(.text+0x37ce): undefined reference to `plist_del' > kernel/built-in.o: In function `enqueue_pushable_task': > sched.c:(.text+0x381c): undefined reference to `plist_del' Eliminate the plist library kconfig and make it available unconditionally. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-08bzip2/lzma: centralize format detectionH. Peter Anvin
Centralize the compression format detection to a common routine in the lib directory, and use it for both initramfs and initrd. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-01-05bzip2/lzma: proper Kconfig dependencies for the ramdisk optionsH. Peter Anvin
Impact: Partial resolution of build failure Make all the compression algorithms properly configurable, and make sure the ramdisk options pull in the proper compression algorithms, as they should. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-01-04bzip2/lzma: config and initramfs support for bzip2/lzma decompressionAlain Knaff
Impact: New code for initramfs decompression, new features This is the second part of the bzip2/lzma patch The bzip patch is based on an idea by Christian Ludwig, includes support for compressing the kernel with bzip2 or lzma rather than gzip. Both compressors give smaller sizes than gzip. Lzma's decompresses faster than bzip2. It also supports ramdisks and initramfs' compressed using these two compressors. The functionality has been successfully used for a couple of years by the udpcast project This version applies to "tip" kernel 2.6.28 This part contains: - support for new compressions (bzip2 and lzma) in initramfs and old-style ramdisk - config dialog for kernel compression (but new kernel compressions not yet supported) Signed-off-by: Alain Knaff <alain@knaff.lu> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-01-01bitmap: find_last_bit()Rusty Russell
Impact: New API As the name suggests. For the moment everyone uses the generic one. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-11-14CRED: Inaugurate COW credentialsDavid Howells
Inaugurate copy-on-write credentials management. This uses RCU to manage the credentials pointer in the task_struct with respect to accesses by other tasks. A process may only modify its own credentials, and so does not need locking to access or modify its own credentials. A mutex (cred_replace_mutex) is added to the task_struct to control the effect of PTRACE_ATTACHED on credential calculations, particularly with respect to execve(). With this patch, the contents of an active credentials struct may not be changed directly; rather a new set of credentials must be prepared, modified and committed using something like the following sequence of events: struct cred *new = prepare_creds(); int ret = blah(new); if (ret < 0) { abort_creds(new); return ret; } return commit_creds(new); There are some exceptions to this rule: the keyrings pointed to by the active credentials may be instantiated - keyrings violate the COW rule as managing COW keyrings is tricky, given that it is possible for a task to directly alter the keys in a keyring in use by another task. To help enforce this, various pointers to sets of credentials, such as those in the task_struct, are declared const. The purpose of this is compile-time discouragement of altering credentials through those pointers. Once a set of credentials has been made public through one of these pointers, it may not be modified, except under special circumstances: (1) Its reference count may incremented and decremented. (2) The keyrings to which it points may be modified, but not replaced. The only safe way to modify anything else is to create a replacement and commit using the functions described in Documentation/credentials.txt (which will be added by a later patch). This patch and the preceding patches have been tested with the LTP SELinux testsuite. This patch makes several logical sets of alteration: (1) execve(). This now prepares and commits credentials in various places in the security code rather than altering the current creds directly. (2) Temporary credential overrides. do_coredump() and sys_faccessat() now prepare their own credentials and temporarily override the ones currently on the acting thread, whilst preventing interference from other threads by holding cred_replace_mutex on the thread being dumped. This will be replaced in a future patch by something that hands down the credentials directly to the functions being called, rather than altering the task's objective credentials. (3) LSM interface. A number of functions have been changed, added or removed: (*) security_capset_check(), ->capset_check() (*) security_capset_set(), ->capset_set() Removed in favour of security_capset(). (*) security_capset(), ->capset() New. This is passed a pointer to the new creds, a pointer to the old creds and the proposed capability sets. It should fill in the new creds or return an error. All pointers, barring the pointer to the new creds, are now const. (*) security_bprm_apply_creds(), ->bprm_apply_creds() Changed; now returns a value, which will cause the process to be killed if it's an error. (*) security_task_alloc(), ->task_alloc_security() Removed in favour of security_prepare_creds(). (*) security_cred_free(), ->cred_free() New. Free security data attached to cred->security. (*) security_prepare_creds(), ->cred_prepare() New. Duplicate any security data attached to cred->security. (*) security_commit_creds(), ->cred_commit() New. Apply any security effects for the upcoming installation of new security by commit_creds(). (*) security_task_post_setuid(), ->task_post_setuid() Removed in favour of security_task_fix_setuid(). (*) security_task_fix_setuid(), ->task_fix_setuid() Fix up the proposed new credentials for setuid(). This is used by cap_set_fix_setuid() to implicitly adjust capabilities in line with setuid() changes. Changes are made to the new credentials, rather than the task itself as in security_task_post_setuid(). (*) security_task_reparent_to_init(), ->task_reparent_to_init() Removed. Instead the task being reparented to init is referred directly to init's credentials. NOTE! This results in the loss of some state: SELinux's osid no longer records the sid of the thread that forked it. (*) security_key_alloc(), ->key_alloc() (*) security_key_permission(), ->key_permission() Changed. These now take cred pointers rather than task pointers to refer to the security context. (4) sys_capset(). This has been simplified and uses less locking. The LSM functions it calls have been merged. (5) reparent_to_kthreadd(). This gives the current thread the same credentials as init by simply using commit_thread() to point that way. (6) __sigqueue_alloc() and switch_uid() __sigqueue_alloc() can't stop the target task from changing its creds beneath it, so this function gets a reference to the currently applicable user_struct which it then passes into the sigqueue struct it returns if successful. switch_uid() is now called from commit_creds(), and possibly should be folded into that. commit_creds() should take care of protecting __sigqueue_alloc(). (7) [sg]et[ug]id() and co and [sg]et_current_groups. The set functions now all use prepare_creds(), commit_creds() and abort_creds() to build and check a new set of credentials before applying it. security_task_set[ug]id() is called inside the prepared section. This guarantees that nothing else will affect the creds until we've finished. The calling of set_dumpable() has been moved into commit_creds(). Much of the functionality of set_user() has been moved into commit_creds(). The get functions all simply access the data directly. (8) security_task_prctl() and cap_task_prctl(). security_task_prctl() has been modified to return -ENOSYS if it doesn't want to handle a function, or otherwise return the return value directly rather than through an argument. Additionally, cap_task_prctl() now prepares a new set of credentials, even if it doesn't end up using it. (9) Keyrings. A number of changes have been made to the keyrings code: (a) switch_uid_keyring(), copy_keys(), exit_keys() and suid_keys() have all been dropped and built in to the credentials functions directly. They may want separating out again later. (b) key_alloc() and search_process_keyrings() now take a cred pointer rather than a task pointer to specify the security context. (c) copy_creds() gives a new thread within the same thread group a new thread keyring if its parent had one, otherwise it discards the thread keyring. (d) The authorisation key now points directly to the credentials to extend the search into rather pointing to the task that carries them. (e) Installing thread, process or session keyrings causes a new set of credentials to be created, even though it's not strictly necessary for process or session keyrings (they're shared). (10) Usermode helper. The usermode helper code now carries a cred struct pointer in its subprocess_info struct instead of a new session keyring pointer. This set of credentials is derived from init_cred and installed on the new process after it has been cloned. call_usermodehelper_setup() allocates the new credentials and call_usermodehelper_freeinfo() discards them if they haven't been used. A special cred function (prepare_usermodeinfo_creds()) is provided specifically for call_usermodehelper_setup() to call. call_usermodehelper_setkeys() adjusts the credentials to sport the supplied keyring as the new session keyring. (11) SELinux. SELinux has a number of changes, in addition to those to support the LSM interface changes mentioned above: (a) selinux_setprocattr() no longer does its check for whether the current ptracer can access processes with the new SID inside the lock that covers getting the ptracer's SID. Whilst this lock ensures that the check is done with the ptracer pinned, the result is only valid until the lock is released, so there's no point doing it inside the lock. (12) is_single_threaded(). This function has been extracted from selinux_setprocattr() and put into a file of its own in the lib/ directory as join_session_keyring() now wants to use it too. The code in SELinux just checked to see whether a task shared mm_structs with other tasks (CLONE_VM), but that isn't good enough. We really want to know if they're part of the same thread group (CLONE_THREAD). (13) nfsd. The NFS server daemon now has to use the COW credentials to set the credentials it is going to use. It really needs to pass the credentials down to the functions it calls, but it can't do that until other patches in this series have been applied. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-20ftrace: rename FTRACE to FUNCTION_TRACERSteven Rostedt
Due to confusion between the ftrace infrastructure and the gcc profiling tracer "ftrace", this patch renames the config options from FTRACE to FUNCTION_TRACER. The other two names that are offspring from FTRACE DYNAMIC_FTRACE and FTRACE_MCOUNT_RECORD will stay the same. This patch was generated mostly by script, and partially by hand. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-16driver core: basic infrastructure for per-module dynamic debug messagesJason Baron
Base infrastructure to enable per-module debug messages. I've introduced CONFIG_DYNAMIC_PRINTK_DEBUG, which when enabled centralizes control of debugging statements on a per-module basis in one /proc file, currently, <debugfs>/dynamic_printk/modules. When, CONFIG_DYNAMIC_PRINTK_DEBUG, is not set, debugging statements can still be enabled as before, often by defining 'DEBUG' for the proper compilation unit. Thus, this patch set has no affect when CONFIG_DYNAMIC_PRINTK_DEBUG is not set. The infrastructure currently ties into all pr_debug() and dev_dbg() calls. That is, if CONFIG_DYNAMIC_PRINTK_DEBUG is set, all pr_debug() and dev_dbg() calls can be dynamically enabled/disabled on a per-module basis. Future plans include extending this functionality to subsystems, that define their own debug levels and flags. Usage: Dynamic debugging is controlled by the debugfs file, <debugfs>/dynamic_printk/modules. This file contains a list of the modules that can be enabled. The format of the file is as follows: <module_name> <enabled=0/1> . . . <module_name> : Name of the module in which the debug call resides <enabled=0/1> : whether the messages are enabled or not For example: snd_hda_intel enabled=0 fixup enabled=1 driver enabled=0 Enable a module: $echo "set enabled=1 <module_name>" > dynamic_printk/modules Disable a module: $echo "set enabled=0 <module_name>" > dynamic_printk/modules Enable all modules: $echo "set enabled=1 all" > dynamic_printk/modules Disable all modules: $echo "set enabled=0 all" > dynamic_printk/modules Finally, passing "dynamic_printk" at the command line enables debugging for all modules. This mode can be turned off via the above disable command. [gkh: minor cleanups and tweaks to make the build work quietly] Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-03[SCSI] lib: add generic helper to print sizes rounded to the correct SI rangeJames Bottomley
This patch adds the ability to print sizes in either units of 10^3 (SI) or 2^10 (Binary) units. It rounds up to three significant figures and can be used for either memory or storage capacities. Oh, and I'm fully aware that 64 bits is only 16EiB ... the Zetta and Yotta units are added for future proofing against the day we have 128 bit computers ... [fujita.tomonori@lab.ntt.co.jp: fix missed unsigned long long cast] Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-26lib: generic show_mem()Johannes Weiner
This implements a platform-independent version of show_mem(). Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Bryan Wu <cooloney@kernel.org> Cc: Chris Zankel <chris@zankel.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jeff Dike <jdike@addtoit.com> Cc: David S. Miller <davem@davemloft.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: David Howells <dhowells@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26task_current_syscallRoland McGrath
This adds the new function task_current_syscall() on machines where the asm/syscall.h interface is supported (CONFIG_HAVE_ARCH_TRACEHOOK). It's exported for modules to use in the future. This function safely samples the state of a blocked thread to collect what system call it is blocked in, and the six system call argument registers. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Reviewed-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24rtc: BCD codeshrinkDavid Brownell
This updates <linux/bcd.h> to define the key routines as constant functions, which the macros will then call. Newer code can now call bcd2bin() instead of SCREAMING BCD2BIN() TO THE FOUR WINDS. This lets each driver shrink their codespace by using N function calls to a single (global) copy of those routines, instead of N inlined copies of these functions per driver. These routines aren't used in speed-critical code. Almost all callers are in the RTC framework. Typical per-driver savings is near 300 bytes. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Adrian Bunk <bunk@kernel.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-17ftrace: do not trace library functionsIngo Molnar
make function tracing more robust: do not trace library functions. We've already got a sizable list of exceptions: ifdef CONFIG_FTRACE # Do not profile string.o, since it may be used in early boot or vdso CFLAGS_REMOVE_string.o = -pg # Also do not profile any debug utilities CFLAGS_REMOVE_spinlock_debug.o = -pg CFLAGS_REMOVE_list_debug.o = -pg CFLAGS_REMOVE_debugobjects.o = -pg CFLAGS_REMOVE_find_next_bit.o = -pg CFLAGS_REMOVE_cpumask.o = -pg CFLAGS_REMOVE_bitmap.o = -pg endif ... and the pattern has been that random library functionality showed up in ftrace's critical path (outside of its recursion check), causing hard to debug lockups. So be a bit defensive about it and exclude all lib/*.o functions by default. It's not that they are overly interesting for tracing purposes anyway. Specific ones can still be traced, in an opt-in manner. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-17ftrace: fix lockup with MAXSMPIngo Molnar
MAXSMP brings in lots of use of various bitops in smp_processor_id() and friends - causing ftrace to lock up during bootup: calling anon_inode_init+0x0/0x130 initcall anon_inode_init+0x0/0x130 returned 0 after 0 msecs calling acpi_event_init+0x0/0x57 [ hard hang ] So exclude the bitops facilities from tracing. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (102 commits) [SCSI] scsi_dh: fix kconfig related build errors [SCSI] sym53c8xx: Fix bogus sym_que_entry re-implementation of container_of [SCSI] scsi_cmnd.h: remove double inclusion of linux/blkdev.h [SCSI] make struct scsi_{host,target}_type static [SCSI] fix locking in host use of blk_plug_device() [SCSI] zfcp: Cleanup external header file [SCSI] zfcp: Cleanup code in zfcp_erp.c [SCSI] zfcp: zfcp_fsf cleanup. [SCSI] zfcp: consolidate sysfs things into one file. [SCSI] zfcp: Cleanup of code in zfcp_aux.c [SCSI] zfcp: Cleanup of code in zfcp_scsi.c [SCSI] zfcp: Move status accessors from zfcp to SCSI include file. [SCSI] zfcp: Small QDIO cleanups [SCSI] zfcp: Adapter reopen for large number of unsolicited status [SCSI] zfcp: Fix error checking for ELS ADISC requests [SCSI] zfcp: wait until adapter is finished with ERP during auto-port [SCSI] ibmvfc: IBM Power Virtual Fibre Channel Adapter Client Driver [SCSI] sg: Add target reset support [SCSI] lib: Add support for the T10 (SCSI) Data Integrity Field CRC [SCSI] sd: Move scsi_disk() accessor function to sd.h ...
2008-07-12[SCSI] lib: Add support for the T10 (SCSI) Data Integrity Field CRCMartin K. Petersen
The SCSI Block Protocol uses this 16-bit CRC to verify the integrity of each data sector. crc_t10dif() is used by sd_dif.c when performing I/O to or from disks formatted with protection information. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-23ftrace: use the new kbuild CFLAGS_REMOVE for lib directorySteven Rostedt
This patch removes the Makefile turd and uses the nice CFLAGS_REMOVE macro in the lib directory. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-23ftrace: remove function tracing from spinlock debugSteven Rostedt
The debug functions in spin_lock debugging pollute the output of the function tracer. This patch adds the debug files in the lib director to those that should not be compiled with mcount tracing. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-23ftrace: do not profile lib/string.oSteven Rostedt
Most archs define the string and memory compare functions in assembly. Some do not. But these functions may be used in some archs at early boot up. Since most archs define this code in assembly and they are not usually traced, there's no need to trace them when they are not defined in assembly. This patch removes the -pg from the CFLAGS for lib/string.o. This prevents the string functions use in either vdso or early bootup from crashing the system. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-30infrastructure to debug (dynamic) objectsThomas Gleixner
We can see an ever repeating problem pattern with objects of any kind in the kernel: 1) freeing of active objects 2) reinitialization of active objects Both problems can be hard to debug because the crash happens at a point where we have no chance to decode the root cause anymore. One problem spot are kernel timers, where the detection of the problem often happens in interrupt context and usually causes the machine to panic. While working on a timer related bug report I had to hack specialized code into the timer subsystem to get a reasonable hint for the root cause. This debug hack was fine for temporary use, but far from a mergeable solution due to the intrusiveness into the timer code. The code further lacked the ability to detect and report the root cause instantly and keep the system operational. Keeping the system operational is important to get hold of the debug information without special debugging aids like serial consoles and special knowledge of the bug reporter. The problems described above are not restricted to timers, but timers tend to expose it usually in a full system crash. Other objects are less explosive, but the symptoms caused by such mistakes can be even harder to debug. Instead of creating specialized debugging code for the timer subsystem a generic infrastructure is created which allows developers to verify their code and provides an easy to enable debug facility for users in case of trouble. The debugobjects core code keeps track of operations on static and dynamic objects by inserting them into a hashed list and sanity checking them on object operations and provides additional checks whenever kernel memory is freed. The tracked object operations are: - initializing an object - adding an object to a subsystem list - deleting an object from a subsystem list Each operation is sanity checked before the operation is executed and the subsystem specific code can provide a fixup function which allows to prevent the damage of the operation. When the sanity check triggers a warning message and a stack trace is printed. The list of operations can be extended if the need arises. For now it's limited to the requirements of the first user (timers). The core code enqueues the objects into hash buckets. The hash index is generated from the address of the object to simplify the lookup for the check on kfree/vfree. Each bucket has it's own spinlock to avoid contention on a global lock. The debug code can be compiled in without being active. The runtime overhead is minimal and could be optimized by asm alternatives. A kernel command line option enables the debugging code. Thanks to Ingo Molnar for review, suggestions and cleanup patches. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Greg KH <greg@kroah.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29isolate ratelimit from printk.c for other useDave Young
Due to the rcupreempt.h WARN_ON trigged, I got 2G syslog file. For some serious complaining of kernel, we need repeat the warnings, so here I isolate the ratelimit part of printk.c to a standalone file. Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-26x86: generic versions of find_first_(zero_)bit, convert i386Alexander van Heukelum
Generic versions of __find_first_bit and __find_first_zero_bit are introduced as simplified versions of __find_next_bit and __find_next_zero_bit. Their compilation and use are guarded by a new config variable GENERIC_FIND_FIRST_BIT. The generic versions of find_first_bit and find_first_zero_bit are implemented in terms of the newly introduced __find_first_bit and __find_first_zero_bit. This patch does not remove the i386-specific implementation, but it does switch i386 to use the generic functions by setting GENERIC_FIND_FIRST_BIT=y for X86_32. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-21Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (202 commits) [POWERPC] Fix compile breakage for 64-bit UP configs [POWERPC] Define copy_siginfo_from_user32 [POWERPC] Add compat handler for PTRACE_GETSIGINFO [POWERPC] i2c: Fix build breakage introduced by OF helpers [POWERPC] Optimize fls64() on 64-bit processors [POWERPC] irqtrace support for 64-bit powerpc [POWERPC] Stacktrace support for lockdep [POWERPC] Move stackframe definitions to common header [POWERPC] Fix device-tree locking vs. interrupts [POWERPC] Make pci_bus_to_host()'s struct pci_bus * argument const [POWERPC] Remove unused __max_memory variable [POWERPC] Simplify xics direct/lpar irq_host setup [POWERPC] Use pseries_setup_i8259_cascade() in pseries_mpic_init_IRQ() [POWERPC] Turn xics_setup_8259_cascade() into a generic pseries_setup_i8259_cascade() [POWERPC] Move xics_setup_8259_cascade() into platforms/pseries/setup.c [POWERPC] Use asm-generic/bitops/find.h in bitops.h [POWERPC] 83xx: mpc8315 - fix USB UTMI Host setup [POWERPC] 85xx: Fix the size of qe muram for MPC8568E [POWERPC] 86xx: mpc86xx_hpcn - Temporarily accept old dts node identifier. [POWERPC] 86xx: mark functions static, other minor cleanups ...
2008-04-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6.26Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6.26: (1090 commits) [NET]: Fix and allocate less memory for ->priv'less netdevices [IPV6]: Fix dangling references on error in fib6_add(). [NETLABEL]: Fix NULL deref in netlbl_unlabel_staticlist_gen() if ifindex not found [PKT_SCHED]: Fix datalen check in tcf_simp_init(). [INET]: Uninline the __inet_inherit_port call. [INET]: Drop the inet_inherit_port() call. SCTP: Initialize partial_bytes_acked to 0, when all of the data is acked. [netdrvr] forcedeth: internal simplifications; changelog removal phylib: factor out get_phy_id from within get_phy_device PHY: add BCM5464 support to broadcom PHY driver cxgb3: Fix __must_check warning with dev_dbg. tc35815: Statistics cleanup natsemi: fix MMIO for PPC 44x platforms [TIPC]: Cleanup of TIPC reference table code [TIPC]: Optimized initialization of TIPC reference table [TIPC]: Remove inlining of reference table locking routines e1000: convert uint16_t style integers to u16 ixgb: convert uint16_t style integers to u16 sb1000.c: make const arrays static sb1000.c: stop inlining largish static functions ...
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-03-28[LIB]: Drop the pcounter itself.Pavel Emelyanov
The knock-out. The pcounter abstraction is not used any longer in the kernel. Not sure whether this should go via netdev tree, but as far as I remember it was added via this one, and besides Eric thinks that Andrew shouldn't mind this. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-13[LIB]: Make PowerPC LMB code generic so sparc64 can use it too.David S. Miller
2008-02-08lib/scatterlist.o needed by a module only - link it in unconditionallyGuennadi Liakhovetski
lib/scatterlist.c is needed by drivers/media/video/videobuf-dma-sg.c, and we would like to be able to use the latter without PCI too, for example, on PXA270 ARM CPU. It is then possible to create a configuration with CONFIG_BLOCK=n, where only module code will need scatterlist.c. Therefore it must be in obj-y. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05iommu sg: add IOMMU helper functions for the free area managementFUJITA Tomonori
This adds IOMMU helper functions for the free area management. These functions take care of LLD's segment boundary limit for IOMMUs. They would be useful for IOMMUs that use bitmap for the free area management. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-28[LIB]: Introduce struct pcounterArnaldo Carvalho de Melo
This just generalises what was introduced by Eric Dumazet for the struct proto inuse field in 286ab3d46058840d68e5d7d52e316c1f7e98c59f: [NET]: Define infrastructure to keep 'inuse' changes in an efficent SMP/NUMA way. Please look at the comment in there to see the rationale. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28SG: Move functions to lib/scatterlist.c and add sg chaining allocator helpersJens Axboe
Manually doing chained sg lists is not trivial, so add some helpers to make sure that drivers get it right. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-11-14lib: move bitmap.o from lib-y to obj-y.Paul Mundt
mac80211 has a reference to __bitmap_empty() via bitmap_empty(). In lib/bitmap.c this is flagged with an EXPORT_SYMBOL(), but this is ultimately ineffective due to bitmap.o being linked in lib-y, resulting in: ERROR: "__bitmap_empty" [net/mac80211/mac80211.ko] undefined! Moving bitmap.o to obj-y fixes this up. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Cc: "John W. Linville" <linville@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Fix cpusets update_cpumaskPaul Menage
Cause writes to cpuset "cpus" file to update cpus_allowed for member tasks: - collect batches of tasks under tasklist_lock and then call set_cpus_allowed() on them outside the lock (since this can sleep). - add a simple generic priority heap type to allow efficient collection of batches of tasks to be processed without duplicating or missing any tasks in subsequent batches. - make "cpus" file update a no-op if the mask hasn't changed - fix race between update_cpumask() and sched_setaffinity() by making sched_setaffinity() post-check that it's not running on any cpus outside cpuset_cpus_allowed(). [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Paul Menage <menage@google.com> Cc: Paul Jackson <pj@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17lib: floating proportionsPeter Zijlstra
Given a set of objects, floating proportions aims to efficiently give the proportional 'activity' of a single item as compared to the whole set. Where 'activity' is a measure of a temporal property of the items. It is efficient in that it need not inspect any other items of the set in order to provide the answer. It is not even needed to know how many other items there are. It has one parameter, and that is the period of 'time' over which the 'activity' is measured. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12Driver core: exclude kobject_uevent.c for !CONFIG_HOTPLUGKay Sievers
Move uevent specific logic from the core into kobject_uevent.c, which does no longer require to link the unused string array if hotplug is not compiled in. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-07Move kasprintf.o to obj-yAlexey Dobriyan
Modulat lguest started giving linking errors MODPOST 1 modules ERROR: "kasprintf" [drivers/lguest/lg.ko] undefined! Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-22Introduce CONFIG_CHECK_SIGNATUREGeert Uytterhoeven
Introduce CONFIG_CHECK_SIGNATURE to control inclusion of check_signature() and avoid problems on platforms that don't have readb(). Let the few legacy (ISA || PCI || X86) drivers that need check_signature() select CONFIG_CHECK_SIGNATURE. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31lib: move kasprintf to a separate fileSam Ravnborg
kasprintf pulls in kmalloc which proved to be fatal for at least bootimage target on alpha. Move it to a separate file so only users of kasprintf are exposed to the dependency on kmalloc. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Meelis Roos <mroos@linux.ee> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Jay Estabrook <jay.estabrook@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-18add argv_split()Jeremy Fitzhardinge
argv_split() is a helper function which takes a string, splits it at whitespace, and returns a NULL-terminated argv vector. This is deliberately simple - it does no quote processing of any kind. [ Seems to me that this is something which is already being done in the kernel, but I couldn't find any other implementations, either to steal or replace. Keep an eye out. ] Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Randy Dunlap <randy.dunlap@oracle.com>
2007-07-17CRC7 supportJan Nikitenko
Add CRC7 routines, used for example in MMC over SPI communication. Kerneldoc updates [akpm@linux-foundation.org: fix funny mix of const and non-const] Signed-off-by: Jan Nikitenko <jan.nikitenko@gmail.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Make check_signature depend on CONFIG_HAS_IOMEMLinus Torvalds
This should avoid build problems on architectures without a "readb()", that got bitten by check_signature() being uninlined. Noted by Heiko Carstens. Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16uninline check_signature()Andrew Morton
This is a rather bizarre thing to have inlined in io.h. Stick it in lib/ instead. While we're there, despaghetti it a bit, and fix its off-by-one behaviour when passed a zero length. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10Add LZO1X algorithm to the kernelRichard Purdie
This is a hybrid version of the patch to add the LZO1X compression algorithm to the kernel. Nitin and myself have merged the best parts of the various patches to form this version which we're both happy with (and are jointly signing off). The performance of this version is equivalent to the original minilzo code it was based on. Bytecode comparisons have also been made on ARM, i386 and x86_64 with favourable results. There are several users of LZO lined up including jffs2, crypto and reiser4 since its much faster than zlib. Signed-off-by: Nitin Gupta <nitingupta910@gmail.com> Signed-off-by: Richard Purdie <rpurdie@openedhand.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
