path: root/lib/Makefile
2015-04-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull sparc updates from David Miller: "The PowerPC folks have a really nice scalable IOMMU pool allocator that we wanted to make use of for sparc. So here we have a series that abstracts out their code into a common layer that anyone can make use of. Sparc is converted, and the PowerPC folks have reviewed and ACK'd this series and plan to convert PowerPC over as well" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: iommu-common: Fix PARISC compile-time warnings sparc: Make LDC use common iommu poll management functions sparc: Make sparc64 use scalable lib/iommu-common.c functions sparc: Break up monolithic iommu table/lock into finer graularity pools and lock
2015-04-17lib: rename lib/find_next_bit.c to lib/find_bit.cYury Norov
This file contains implementation for all find_*_bit{,_le} So giving it more generic name looks reasonable. Signed-off-by: Yury Norov <yury.norov@gmail.com> Reviewed-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Reviewed-by: George Spelvin <linux@horizon.com> Cc: Alexey Klimov <klimov.linux@gmail.com> Cc: David S. Miller <davem@davemloft.net> Cc: Daniel Borkmann <dborkman@redhat.com> Cc: Hannes Frederic Sowa <hannes@stressinduktion.org> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Mark Salter <msalter@redhat.com> Cc: AKASHI Takahiro <takahiro.akashi@linaro.org> Cc: Thomas Graf <tgraf@suug.ch> Cc: Valentin Rothberg <valentinrothberg@gmail.com> Cc: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17lib: move find_last_bit to lib/find_next_bit.cYury Norov
Currently all 'find_*_bit' family is located in lib/find_next_bit.c, except 'find_last_bit', which is in lib/find_last_bit.c. It seems, there's no major benefit to have it separated. Signed-off-by: Yury Norov <yury.norov@gmail.com> Reviewed-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Reviewed-by: George Spelvin <linux@horizon.com> Cc: Alexey Klimov <klimov.linux@gmail.com> Cc: David S. Miller <davem@davemloft.net> Cc: Daniel Borkmann <dborkman@redhat.com> Cc: Hannes Frederic Sowa <hannes@stressinduktion.org> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Mark Salter <msalter@redhat.com> Cc: AKASHI Takahiro <takahiro.akashi@linaro.org> Cc: Thomas Graf <tgraf@suug.ch> Cc: Valentin Rothberg <valentinrothberg@gmail.com> Cc: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-16sparc: Break up monolithic iommu table/lock into finer graularity pools and lockSowmini Varadhan
Investigation of multithreaded iperf experiments on an ethernet interface show the iommu->lock as the hottest lock identified by lockstat, with something of the order of 21M contentions out of 27M acquisitions, and an average wait time of 26 us for the lock. This is not efficient. A more scalable design is to follow the ppc model, where the iommu_table has multiple pools, each stretching over a segment of the map, and with a separate lock for each pool. This model allows for better parallelization of the iommu map search. This patch adds the iommu range alloc/free function infrastructure. Signed-off-by: Sowmini Varadhan <sowmini.varadhan@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-17move iov_iter.c from mm/ to lib/Al Viro
2015-02-13lib: add kasan test moduleAndrey Ryabinin
This is a test module doing various nasty things like out of bounds accesses, use after free. It is useful for testing kernel debugging features like kernel address sanitizer. It mostly concentrates on testing of slab allocator, but we might want to add more different stuff here in future (like stack/global variables out of bounds accesses and so on). Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Konstantin Serebryany <kcc@google.com> Cc: Dmitry Chernenkov <dmitryc@google.com> Signed-off-by: Andrey Konovalov <adech.fo@gmail.com> Cc: Yuri Gribov <tetra2005@gmail.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-12hexdump: introduce test suiteAndy Shevchenko
Test different scenarios of function calls located in lib/hexdump.c. Currently hex_dump_to_buffer() is only tested and test data is provided for little endian CPUs. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 updates from Martin Schwidefsky: - The remaining patches for the z13 machine support: kernel build option for z13, the cache synonym avoidance, SMT support, compare-and-delay for spinloops and the CES5S crypto adapater. - The ftrace support for function tracing with the gcc hotpatch option. This touches common code Makefiles, Steven is ok with the changes. - The hypfs file system gets an extension to access diagnose 0x0c data in user space for performance analysis for Linux running under z/VM. - The iucv hvc console gets wildcard spport for the user id filtering. - The cacheinfo code is converted to use the generic infrastructure. - Cleanup and bug fixes. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (42 commits) s390/process: free vx save area when releasing tasks s390/hypfs: Eliminate hypfs interval s390/hypfs: Add diagnose 0c support s390/cacheinfo: don't use smp_processor_id() in preemptible context s390/zcrypt: fixed domain scanning problem (again) s390/smp: increase maximum value of NR_CPUS to 512 s390/jump label: use different nop instruction s390/jump label: add sanity checks s390/mm: correct missing space when reporting user process faults s390/dasd: cleanup profiling s390/dasd: add locking for global_profile access s390/ftrace: hotpatch support for function tracing ftrace: let notrace function attribute disable hotpatching if necessary ftrace: allow architectures to specify ftrace compile options s390: reintroduce diag 44 calls for cpu_relax() s390/zcrypt: Add support for new crypto express (CEX5S) adapter. s390/zcrypt: Number of supported ap domains is not retrievable. s390/spinlock: add compare-and-delay to lock wait loops s390/tape: remove redundant if statement s390/hvc_iucv: add simple wildcard matches to the iucv allow filter ...
2015-02-04Merge branch 'for-davem' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs More iov_iter work from Al Viro. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-04vhost: vhost_scsi_handle_vq() should just use copy_from_user()Al Viro
it has just verified that it asks no more than the length of the first segment of iovec. And with that the last user of stuff in lib/iovec.c is gone. RIP. Cc: Michael S. Tsirkin <mst@redhat.com> Cc: Nicholas A. Bellinger <nab@linux-iscsi.org> Cc: kvm@vger.kernel.org Cc: virtualization@lists.linux-foundation.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-01-30rhashtable: Make selftest modularGeert Uytterhoeven
Allow the selftest on the resizable hash table to be built modular, just like all other tests that do not depend on DEBUG_KERNEL. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-29ftrace: allow architectures to specify ftrace compile optionsHeiko Carstens
If the kernel is compiled with function tracer support the -pg compile option is passed to gcc to generate extra code into the prologue of each function. This patch replaces the "open-coded" -pg compile flag with a CC_FLAGS_FTRACE makefile variable which architectures can override if a different option should be used for code generation. Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2014-12-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) New offloading infrastructure and example 'rocker' driver for offloading of switching and routing to hardware. This work was done by a large group of dedicated individuals, not limited to: Scott Feldman, Jiri Pirko, Thomas Graf, John Fastabend, Jamal Hadi Salim, Andy Gospodarek, Florian Fainelli, Roopa Prabhu 2) Start making the networking operate on IOV iterators instead of modifying iov objects in-situ during transfers. Thanks to Al Viro and Herbert Xu. 3) A set of new netlink interfaces for the TIPC stack, from Richard Alpe. 4) Remove unnecessary looping during ipv6 routing lookups, from Martin KaFai Lau. 5) Add PAUSE frame generation support to gianfar driver, from Matei Pavaluca. 6) Allow for larger reordering levels in TCP, which are easily achievable in the real world right now, from Eric Dumazet. 7) Add a variable of napi_schedule that doesn't need to disable cpu interrupts, from Eric Dumazet. 8) Use a doubly linked list to optimize neigh_parms_release(), from Nicolas Dichtel. 9) Various enhancements to the kernel BPF verifier, and allow eBPF programs to actually be attached to sockets. From Alexei Starovoitov. 10) Support TSO/LSO in sunvnet driver, from David L Stevens. 11) Allow controlling ECN usage via routing metrics, from Florian Westphal. 12) Remote checksum offload, from Tom Herbert. 13) Add split-header receive, BQL, and xmit_more support to amd-xgbe driver, from Thomas Lendacky. 14) Add MPLS support to openvswitch, from Simon Horman. 15) Support wildcard tunnel endpoints in ipv6 tunnels, from Steffen Klassert. 16) Do gro flushes on a per-device basis using a timer, from Eric Dumazet. This tries to resolve the conflicting goals between the desired handling of bulk vs. RPC-like traffic. 17) Allow userspace to ask for the CPU upon what a packet was received/steered, via SO_INCOMING_CPU. From Eric Dumazet. 18) Limit GSO packets to half the current congestion window, from Eric Dumazet. 19) Add a generic helper so that all drivers set their RSS keys in a consistent way, from Eric Dumazet. 20) Add xmit_more support to enic driver, from Govindarajulu Varadarajan. 21) Add VLAN packet scheduler action, from Jiri Pirko. 22) Support configurable RSS hash functions via ethtool, from Eyal Perry. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1820 commits) Fix race condition between vxlan_sock_add and vxlan_sock_release net/macb: fix compilation warning for print_hex_dump() called with skb->mac_header net/mlx4: Add support for A0 steering net/mlx4: Refactor QUERY_PORT net/mlx4_core: Add explicit error message when rule doesn't meet configuration net/mlx4: Add A0 hybrid steering net/mlx4: Add mlx4_bitmap zone allocator net/mlx4: Add a check if there are too many reserved QPs net/mlx4: Change QP allocation scheme net/mlx4_core: Use tasklet for user-space CQ completion events net/mlx4_core: Mask out host side virtualization features for guests net/mlx4_en: Set csum level for encapsulated packets be2net: Export tunnel offloads only when a VxLAN tunnel is created gianfar: Fix dma check map error when DMA_API_DEBUG is enabled cxgb4/csiostor: Don't use MASTER_MUST for fw_hello call net: fec: only enable mdio interrupt before phy device link up net: fec: clear all interrupt events to support i.MX6SX net: fec: reset fep link status in suspend function net: sock: fix access via invalid file descriptor net: introduce helper macro for_each_cmsghdr ...
2014-12-10Merge tag 'trace-seq-buf-3.19' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull nmi-safe seq_buf printk update from Steven Rostedt: "This code is a fork from the trace-3.19 pull as it needed the trace_seq clean ups from that branch. This code solves the issue of performing stack dumps from NMI context. The issue is that printk() is not safe from NMI context as if the NMI were to trigger when a printk() was being performed, the NMI could deadlock from the printk() internal locks. This has been seen in practice. With lots of review from Petr Mladek, this code went through several iterations, and we feel that it is now at a point of quality to be accepted into mainline. Here's what is contained in this patch set: - Creates a "seq_buf" generic buffer utility that allows a descriptor to be passed around where functions can write their own "printk()" formatted strings into it. The generic version was pulled out of the trace_seq() code that was made specifically for tracing. - The seq_buf code was change to model the seq_file code. I have a patch (not included for 3.19) that converts the seq_file.c code over to use seq_buf.c like the trace_seq.c code does. This was done to make sure that seq_buf.c is compatible with seq_file.c. I may try to get that patch in for 3.20. - The seq_buf.c file was moved to lib/ to remove it from being dependent on CONFIG_TRACING. - The printk() was updated to allow for a per_cpu "override" of the internal calls. That is, instead of writing to the console, a call to printk() may do something else. This made it easier to allow the NMI to change what printk() does in order to call dump_stack() without needing to update that code as well. - Finally, the dump_stack from all CPUs via NMI code was converted to use the seq_buf code. The caller to trigger the NMI code would wait till all the NMIs finished, and then it would print the seq_buf data to the console safely from a non NMI context One added bonus is that this code also makes the NMI dump stack work on PREEMPT_RT kernels. As printk() includes sleeping locks on PREEMPT_RT, printk() only writes to console if the console does not use any rt_mutex converted spin locks. Which a lot do" * tag 'trace-seq-buf-3.19' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: x86/nmi: Fix use of unallocated cpumask_var_t printk/percpu: Define printk_func when printk is not defined x86/nmi: Perform a safe NMI stack trace on all CPUs printk: Add per_cpu printk func to allow printk to be diverted seq_buf: Move the seq_buf code to lib/ seq-buf: Make seq_buf_bprintf() conditional on CONFIG_BINARY_PRINTF tracing: Add seq_buf_get_buf() and seq_buf_commit() helper functions tracing: Have seq_buf use full buffer seq_buf: Add seq_buf_can_fit() helper function tracing: Add paranoid size check in trace_printk_seq() tracing: Use trace_seq_used() and seq_buf_used() instead of len tracing: Clean up tracing_fill_pipe_page() seq_buf: Create seq_buf_used() to find out how much was written tracing: Add a seq_buf_clear() helper and clear len and readpos in init tracing: Convert seq_buf fields to be like seq_file fields tracing: Convert seq_buf_path() to be like seq_path() tracing: Create seq_buf layer in trace_seq
2014-12-10net, lib: kill arch_fast_hash library bitsDaniel Borkmann
As there are now no remaining users of arch_fast_hash(), lets kill it entirely. This basically reverts commit 71ae8aac3e19 ("lib: introduce arch optimized hash library") and follow-up work, that is f.e., commit 237217546d44 ("lib: hash: follow-up fixups for arch hash"), commit e3fec2f74f7f ("lib: Add missing arch generic-y entries for asm-generic/hash.h") and last but not least commit 6a02652df511 ("perf tools: Fix include for non x86 architectures"). Cc: Francesco Fusco <fusco@ntop.org> Cc: Thomas Graf <tgraf@suug.ch> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-19seq_buf: Move the seq_buf code to lib/Steven Rostedt (Red Hat)
The seq_buf functions are rather useful outside of tracing. Instead of having it be dependent on CONFIG_TRACING, move the code into lib/ and allow other users to have access to it even when tracing is not configured. The seq_buf utility is similar to the seq_file utility, but instead of writing sending data back up to userland, it writes it into a buffer defined at seq_buf_init(). This allows us to send a descriptor around that writes printf() formatted strings into it that can be retrieved later. It is currently used by the tracing facility for such things like trace events to convert its binary saved data in the ring buffer into an ASCII human readable context to be displayed in /sys/kernel/debug/trace. It can also be used for doing NMI prints safely from NMI context into the seq_buf and retrieved later and dumped to printk() safely. Doing printk() from an NMI context is dangerous because an NMI can preempt a current printk() and deadlock on it. Link: http://lkml.kernel.org/p/20140619213952.058255809@goodmis.org Tested-by: Jiri Kosina <jkosina@suse.cz> Acked-by: Jiri Kosina <jkosina@suse.cz> Reviewed-by: Petr Mladek <pmladek@suse.cz> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-11-16reciprocal_div: objects with exported symbols should be obj-y rather than lib-yHannes Frederic Sowa
Otherwise the exported symbols might be discarded because of no users in vmlinux. Reported-by: Jim Davis <jim.epost@gmail.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-14lib: rename TEST_MODULE to TEST_LKMValentin Rothberg
The "_MODULE" suffix is reserved for tristates compiled as loadable kernel modules (LKM). The "TEST_MODULE" feature thereby violates this convention. The feature is used to compile the lib/test_module.c kernel module. Sadly this convention is not made explicit, but the Kconfig code documents it. The following code (./scripts/kconfig/confdata.c) is used to generate the autoconf.h header file during the build process. When a feature is selected as a kernel module ('m'), it is suffixed with "_MODULE" to indicate it. switch (*value) { case 'n': break; case 'm': suffix = "_MODULE"; /* fall through */ This causes problems for static code analysis, which assumes a consistent use of the "_MODULE" suffix. This patch renames the feature and its reference in a Makefile to "TEST_LKM", which still expresses the test of a LKM. Signed-off-by: Valentin Rothberg <valentinrothberg@gmail.com> Cc: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14lib: remove prio_heapLai Jiangshan
The prio_heap code is unused since commit 889ed9ceaa97 ("cgroup: remove css_scan_tasks()"). It should be compiled out to shrink the binary kernel size which can be done via introducing CONFIG_PRIO_HEAD or by removing the code. We can simply recover the code from git when needed, so it would be better to remove it IMO. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Tejun Heo <tj@kernel.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Ingo Molnar <mingo@kernel.org> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Kees Cook <keescook@chromium.org> Cc: Francesco Fusco <ffusco@redhat.com> Cc: Greg Thelen <gthelen@google.com> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: George Spelvin <linux@horizon.com> Cc: Mark Salter <msalter@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-06lib: add lib/glob.cGeorge Spelvin
This is a helper function from drivers/ata/libata_core.c, where it is used to blacklist particular device models. It's being moved to lib/ so other drivers may use it for the same purpose. This implementation in non-recursive, so is safe for the kernel stack. [akpm@linux-foundation.org: fix sparse warning] Signed-off-by: George Spelvin <linux@horizon.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Tejun Heo <tj@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights: 1) Steady transitioning of the BPF instructure to a generic spot so all kernel subsystems can make use of it, from Alexei Starovoitov. 2) SFC driver supports busy polling, from Alexandre Rames. 3) Take advantage of hash table in UDP multicast delivery, from David Held. 4) Lighten locking, in particular by getting rid of the LRU lists, in inet frag handling. From Florian Westphal. 5) Add support for various RFC6458 control messages in SCTP, from Geir Ola Vaagland. 6) Allow to filter bridge forwarding database dumps by device, from Jamal Hadi Salim. 7) virtio-net also now supports busy polling, from Jason Wang. 8) Some low level optimization tweaks in pktgen from Jesper Dangaard Brouer. 9) Add support for ipv6 address generation modes, so that userland can have some input into the process. From Jiri Pirko. 10) Consolidate common TCP connection request code in ipv4 and ipv6, from Octavian Purdila. 11) New ARP packet logger in netfilter, from Pablo Neira Ayuso. 12) Generic resizable RCU hash table, with intial users in netlink and nftables. From Thomas Graf. 13) Maintain a name assignment type so that userspace can see where a network device name came from (enumerated by kernel, assigned explicitly by userspace, etc.) From Tom Gundersen. 14) Automatic flow label generation on transmit in ipv6, from Tom Herbert. 15) New packet timestamping facilities from Willem de Bruijn, meant to assist in measuring latencies going into/out-of the packet scheduler, latency from TCP data transmission to ACK, etc" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1536 commits) cxgb4 : Disable recursive mailbox commands when enabling vi net: reduce USB network driver config options. tg3: Modify tg3_tso_bug() to handle multiple TX rings amd-xgbe: Perform phy connect/disconnect at dev open/stop amd-xgbe: Use dma_set_mask_and_coherent to set DMA mask net: sun4i-emac: fix memory leak on bad packet sctp: fix possible seqlock seadlock in sctp_packet_transmit() Revert "net: phy: Set the driver when registering an MDIO bus device" cxgb4vf: Turn off SGE RX/TX Callback Timers and interrupts in PCI shutdown routine team: Simplify return path of team_newlink bridge: Update outdated comment on promiscuous mode net-timestamp: ACK timestamp for bytestreams net-timestamp: TCP timestamping net-timestamp: SCHED timestamp on entering packet scheduler net-timestamp: add key to disambiguate concurrent datagrams net-timestamp: move timestamp flags out of sk_flags net-timestamp: extend SCM_TIMESTAMPING ancillary data struct cxgb4i : Move stray CPL definitions to cxgb4 driver tcp: reduce spurious retransmits due to transient SACK reneging qlcnic: Initialize dcbnl_ops before register_netdev ...
2014-08-02lib: Resizable, Scalable, Concurrent Hash TableThomas Graf
Generic implementation of a resizable, scalable, concurrent hash table based on [0]. The implementation supports both, fixed size keys specified via an offset and length, or arbitrary keys via own hash and compare functions. Lookups are lockless and protected as RCU read side critical sections. Automatic growing/shrinking based on user configurable watermarks is available while allowing concurrent lookups to take place. Objects to be hashed must include a struct rhash_head. The reason for not using the existing struct hlist_head is that the expansion and shrinking will have two buckets point to a single entry which would lead in obscure reverse chaining behaviour. Code includes a boot selftest if CONFIG_TEST_RHASHTABLE is defined. [0] https://www.usenix.org/legacy/event/atc11/tech/final_files/Triplett.pdf Signed-off-by: Thomas Graf <tgraf@suug.ch> Reviewed-by: Nikolay Aleksandrov <nikolay@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-17test: add firmware_class loader testKees Cook
This provides a simple interface to trigger the firmware_class loader to test built-in, filesystem, and user helper modes. Additionally adds tests via the new interface to the selftests tree. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) Seccomp BPF filters can now be JIT'd, from Alexei Starovoitov. 2) Multiqueue support in xen-netback and xen-netfront, from Andrew J Benniston. 3) Allow tweaking of aggregation settings in cdc_ncm driver, from Bjørn Mork. 4) BPF now has a "random" opcode, from Chema Gonzalez. 5) Add more BPF documentation and improve test framework, from Daniel Borkmann. 6) Support TCP fastopen over ipv6, from Daniel Lee. 7) Add software TSO helper functions and use them to support software TSO in mvneta and mv643xx_eth drivers. From Ezequiel Garcia. 8) Support software TSO in fec driver too, from Nimrod Andy. 9) Add Broadcom SYSTEMPORT driver, from Florian Fainelli. 10) Handle broadcasts more gracefully over macvlan when there are large numbers of interfaces configured, from Herbert Xu. 11) Allow more control over fwmark used for non-socket based responses, from Lorenzo Colitti. 12) Do TCP congestion window limiting based upon measurements, from Neal Cardwell. 13) Support busy polling in SCTP, from Neal Horman. 14) Allow RSS key to be configured via ethtool, from Venkata Duvvuru. 15) Bridge promisc mode handling improvements from Vlad Yasevich. 16) Don't use inetpeer entries to implement ID generation any more, it performs poorly, from Eric Dumazet. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1522 commits) rtnetlink: fix userspace API breakage for iproute2 < v3.9.0 tcp: fixing TLP's FIN recovery net: fec: Add software TSO support net: fec: Add Scatter/gather support net: fec: Increase buffer descriptor entry number net: fec: Factorize feature setting net: fec: Enable IP header hardware checksum net: fec: Factorize the .xmit transmit function bridge: fix compile error when compiling without IPv6 support bridge: fix smatch warning / potential null pointer dereference via-rhine: fix full-duplex with autoneg disable bnx2x: Enlarge the dorq threshold for VFs bnx2x: Check for UNDI in uncommon branch bnx2x: Fix 1G-baseT link bnx2x: Fix link for KR with swapped polarity lane sctp: Fix sk_ack_backlog wrap-around problem net/core: Add VF link state control policy net/fsl: xgmac_mdio is dependent on OF_MDIO net/fsl: Make xgmac_mdio read error message useful net_sched: drr: warn when qdisc is not work conserving ...
2014-06-12Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "This is the main drm merge window pull request, changes all over the place, mostly normal levels of churn. Highlights: Core drm: More cleanups, fix race on connector/encoder naming, docs updates, object locking rework in prep for atomic modeset i915: mipi DSI support, valleyview power fixes, cursor size fixes, execlist refactoring, vblank improvements, userptr support, OOM handling improvements radeon: GPUVM tuning and large page size support, gart fixes, deep color HDMI support, HDMI audio cleanups nouveau: - displayport rework should fix lots of issues - initial gk20a support - gk110b support - gk208 fixes exynos: probe order fixes, HDMI changes, IPP consolidation msm: debugfs updates, misc fixes ast: ast2400 support, sync with UMS driver tegra: cleanups, hdmi + hw cursor for Tegra 124. panel: fixes existing panels add some new ones. ipuv3: moved from staging to drivers/gpu" * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (761 commits) drm/nouveau/disp/dp: fix tmds passthrough on dp connector drm/nouveau/dp: probe dpcd to determine connectedness drm/nv50-: trigger update after all connectors disabled drm/nv50-: prepare for attaching a SOR to multiple heads drm/gf119-/disp: fix debug output on update failure drm/nouveau/disp/dp: make use of postcursor when its available drm/g94-/disp/dp: take max pullup value across all lanes drm/nouveau/bios/dp: parse lane postcursor data drm/nouveau/dp: fix support for dpms drm/nouveau: register a drm_dp_aux channel for each dp connector drm/g94-/disp: add method to power-off dp lanes drm/nouveau/disp/dp: maintain link in response to hpd signal drm/g94-/disp: bash and wait for something after changing lane power regs drm/nouveau/disp/dp: split link config/power into two steps drm/nv50/disp: train PIOR-attached DP from second supervisor drm/nouveau/disp/dp: make use of existing output data for link training drm/gf119/disp: start removing direct vbios parsing from supervisor drm/nv50/disp: start removing direct vbios parsing from supervisor drm/nouveau/disp/dp: maintain receiver caps in response to hpd signal drm/nouveau/disp/dp: create subclass for dp outputs ...
2014-05-12net: filter: BPF testsuiteAlexei Starovoitov
The testsuite covers classic and internal BPF instructions. It is particularly useful for JIT compiler developers. Adds to "net" selftest target. The testsuite can be used as a set of micro-benchmarks. It measures execution time of each BPF program in nsec. This patch adds core framework. Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-05lib: Export interval_treeChris Wilson
lib/interval_tree.c provides a simple interface for an interval-tree (an augmented red-black tree) but is only built when testing the generic macros for building interval-trees. For drivers with modest needs, export the simple interval-tree library as is. v2: Lots of help from Michel Lespinasse to only compile the code as required: - make INTERVAL_TREE a config option - make INTERVAL_TREE_TEST select the library functions and sanitize the filenames & Makefile - prepare interval_tree for being built as a module if required Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Michel Lespinasse <walken@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Reviewed-by: Michel Lespinasse <walken@google.com> [Acked for inclusion via drm/i915 by Andrew Morton.] [danvet: switch to _GPL as per the mailing list discussion.] Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-04-30lib: add fdt_empty_tree.cMark Salter
CONFIG_LIBFDT support does not include fdt_empty_tree.c which is needed by arm64 EFI stub. Add it to libfdt_files. Signed-off-by: Mark Salter <msalter@redhat.com> Signed-off-by: Leif Lindholm <leif.lindholm@linaro.org> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com>
2014-04-12Merge git://git.infradead.org/users/eparis/auditLinus Torvalds
Pull audit updates from Eric Paris. * git://git.infradead.org/users/eparis/audit: (28 commits) AUDIT: make audit_is_compat depend on CONFIG_AUDIT_COMPAT_GENERIC audit: renumber AUDIT_FEATURE_CHANGE into the 1300 range audit: do not cast audit_rule_data pointers pointlesly AUDIT: Allow login in non-init namespaces audit: define audit_is_compat in kernel internal header kernel: Use RCU_INIT_POINTER(x, NULL) in audit.c sched: declare pid_alive as inline audit: use uapi/linux/audit.h for AUDIT_ARCH declarations syscall_get_arch: remove useless function arguments audit: remove stray newline from audit_log_execve_info() audit_panic() call audit: remove stray newlines from audit_log_lost messages audit: include subject in login records audit: remove superfluous new- prefix in AUDIT_LOGIN messages audit: allow user processes to log from another PID namespace audit: anchor all pid references in the initial pid namespace audit: convert PPIDs to the inital PID namespace. pid: get pid_t ppid of task in init_pid_ns audit: rename the misleading audit_get_context() to audit_take_context() audit: Add generic compat syscall support audit: Add CONFIG_HAVE_ARCH_AUDITSYSCALL ...
2014-03-20audit: Add generic compat syscall supportAKASHI Takahiro
lib/audit.c provides a generic function for auditing system calls. This patch extends it for compat syscall support on bi-architectures (32/64-bit) by adding lib/compat_audit.c. What is required to support this feature are: * add asm/unistd32.h for compat system call names * select CONFIG_AUDIT_ARCH_COMPAT_GENERIC Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Acked-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2014-02-07Merge tag 'efi-urgent' into x86/urgentH. Peter Anvin
* Avoid WARN_ON() when mapping BGRT on Baytrail (EFI 32-bit). Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-02-06x86, hweight: Fix BUG when booting with CONFIG_GCOV_PROFILE_ALL=yPeter Oberparleiter
Commit d61931d89b, "x86: Add optimized popcnt variants" introduced compile flag -fcall-saved-rdi for lib/hweight.c. When combined with options -fprofile-arcs and -O2, this flag causes gcc to generate broken constructor code. As a result, a 64 bit x86 kernel compiled with CONFIG_GCOV_PROFILE_ALL=y prints message "gcov: could not create file" and runs into sproadic BUGs during boot. The gcc people indicate that these kinds of problems are endemic when using ad hoc calling conventions. It is therefore best to treat any file compiled with ad hoc calling conventions as an isolated environment and avoid things like profiling or coverage analysis, since those subsystems assume a "normal" calling conventions. This patch avoids the bug by excluding lib/hweight.o from coverage profiling. Reported-by: Meelis Roos <mroos@linux.ee> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/52F3A30C.7050205@linux.vnet.ibm.com Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: <stable@vger.kernel.org>
2014-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) BPF debugger and asm tool by Daniel Borkmann. 2) Speed up create/bind in AF_PACKET, also from Daniel Borkmann. 3) Correct reciprocal_divide and update users, from Hannes Frederic Sowa and Daniel Borkmann. 4) Currently we only have a "set" operation for the hw timestamp socket ioctl, add a "get" operation to match. From Ben Hutchings. 5) Add better trace events for debugging driver datapath problems, also from Ben Hutchings. 6) Implement auto corking in TCP, from Eric Dumazet. Basically, if we have a small send and a previous packet is already in the qdisc or device queue, defer until TX completion or we get more data. 7) Allow userspace to manage ipv6 temporary addresses, from Jiri Pirko. 8) Add a qdisc bypass option for AF_PACKET sockets, from Daniel Borkmann. 9) Share IP header compression code between Bluetooth and IEEE802154 layers, from Jukka Rissanen. 10) Fix ipv6 router reachability probing, from Jiri Benc. 11) Allow packets to be captured on macvtap devices, from Vlad Yasevich. 12) Support tunneling in GRO layer, from Jerry Chu. 13) Allow bonding to be configured fully using netlink, from Scott Feldman. 14) Allow AF_PACKET users to obtain the VLAN TPID, just like they can already get the TCI. From Atzm Watanabe. 15) New "Heavy Hitter" qdisc, from Terry Lam. 16) Significantly improve the IPSEC support in pktgen, from Fan Du. 17) Allow ipv4 tunnels to cache routes, just like sockets. From Tom Herbert. 18) Add Proportional Integral Enhanced packet scheduler, from Vijay Subramanian. 19) Allow openvswitch to mmap'd netlink, from Thomas Graf. 20) Key TCP metrics blobs also by source address, not just destination address. From Christoph Paasch. 21) Support 10G in generic phylib. From Andy Fleming. 22) Try to short-circuit GRO flow compares using device provided RX hash, if provided. From Tom Herbert. The wireless and netfilter folks have been busy little bees too. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (2064 commits) net/cxgb4: Fix referencing freed adapter ipv6: reallocate addrconf router for ipv6 address when lo device up fib_frontend: fix possible NULL pointer dereference rtnetlink: remove IFLA_BOND_SLAVE definition rtnetlink: remove check for fill_slave_info in rtnl_have_link_slave_info qlcnic: update version to 5.3.55 qlcnic: Enhance logic to calculate msix vectors. qlcnic: Refactor interrupt coalescing code for all adapters. qlcnic: Update poll controller code path qlcnic: Interrupt code cleanup qlcnic: Enhance Tx timeout debugging. qlcnic: Use bool for rx_mac_learn. bonding: fix u64 division rtnetlink: add missing IFLA_BOND_AD_INFO_UNSPEC sfc: Use the correct maximum TX DMA ring size for SFC9100 Add Shradha Shah as the sfc driver maintainer. net/vxlan: Share RX skb de-marking and checksum checks with ovs tulip: cleanup by using ARRAY_SIZE() ip_tunnel: clear IPCB in ip_tunnel_xmit() in case dst_link_failure() is called net/cxgb4: Don't retrieve stats during recovery ...
2014-01-23test: check copy_to/from_user boundary validationKees Cook
To help avoid an architecture failing to correctly check kernel/user boundaries when handling copy_to_user, copy_from_user, put_user, or get_user, perform some simple tests and fail to load if any of them behave unexpectedly. Specifically, this is to make sure there is a way to notice if things like what was fixed in commit 8404663f81d2 ("ARM: 7527/1: uaccess: explicitly check __user pointer when !CPU_USE_DOMAINS") ever regresses again, for any architecture. Additionally, adds new "user" selftest target, which loads this module. Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23test: add minimal module for verification testingKees Cook
This is a pair of test modules I'd like to see in the tree. Instead of putting these in lkdtm, where I've been adding various tests that trigger crashes, these don't make sense there since they need to be either distinctly separate, or their pass/fail state don't need to crash the machine. These live in lib/ for now, along with a few other in-kernel test modules, and use the slightly more common "test_" naming convention, instead of "test-". We should likely standardize on the former: $ find . -name 'test_*.c' | grep -v /tools/ | wc -l 4 $ find . -name 'test-*.c' | grep -v /tools/ | wc -l 2 The first is entirely a no-op module, designed to allow simple testing of the module loading and verification interface. It's useful to have a module that has no other uses or dependencies so it can be reliably used for just testing module loading and verification. The second is a module that exercises the user memory access functions, in an effort to make sure that we can quickly catch any regressions in boundary checking (e.g. like what was recently fixed on ARM). This patch (of 2): When doing module loading verification tests (for example, with module signing, or LSM hooks), it is very handy to have a module that can be built on all systems under test, isn't auto-loaded at boot, and has no device or similar dependencies. This creates the "test_module.ko" module for that purpose, which only reports its load and unload to printk. Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-17lib: introduce arch optimized hash libraryFrancesco Fusco
We introduce a new hashing library that is meant to be used in the contexts where speed is more important than uniformity of the hashed values. The hash library leverages architecture specific implementation to achieve high performance and fall backs to jhash() for the generic case. On Intel-based x86 architectures, the library can exploit the crc32l instruction, part of the Intel SSE4.2 instruction set, if the instruction is supported by the processor. This implementation is twice as fast as the jhash() implementation on an i7 processor. Additional architectures, such as Arm64 provide instructions for accelerating the computation of CRC, so they could be added as well in follow-up work. Signed-off-by: Francesco Fusco <ffusco@redhat.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: Thomas Graf <tgraf@redhat.com> Cc: linux-kernel@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-22Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull SCSI target updates from Nicholas Bellinger: "Things have been quiet this round with mostly bugfixes, percpu conversions, and other minor iscsi-target conformance testing changes. The highlights include: - Add demo_mode_discovery attribute for iscsi-target (Thomas) - Convert tcm_fc(FCoE) to use percpu-ida pre-allocation - Add send completion interrupt coalescing for ib_isert - Convert target-core to use percpu-refcounting for se_lun - Fix mutex_trylock usage bug in iscsit_increment_maxcmdsn - tcm_loop updates (Hannes) - target-core ALUA cleanups + prep for v3.14 SCSI Referrals support (Hannes) v3.14 is currently shaping to be a busy development cycle in target land, with initial support for T10 Referrals and T10 DIF currently on the roadmap" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (40 commits) iscsi-target: chap auth shouldn't match username with trailing garbage iscsi-target: fix extract_param to handle buffer length corner case iscsi-target: Expose default_erl as TPG attribute target_core_configfs: split up ALUA supported states target_core_alua: Make supported states configurable target_core_alua: Store supported ALUA states target_core_alua: Rename ALUA_ACCESS_STATE_OPTIMIZED target_core_alua: spellcheck target core: rename (ex,im)plict -> (ex,im)plicit percpu-refcount: Add percpu-refcount.o to obj-y iscsi-target: Do not reject non-immediate CmdSNs exceeding MaxCmdSN iscsi-target: Convert iscsi_session statistics to atomic_long_t target: Convert se_device statistics to atomic_long_t target: Fix delayed Task Aborted Status (TAS) handling bug iscsi-target: Reject unsupported multi PDU text command sequence ib_isert: Avoid duplicate iscsit_increment_maxcmdsn call iscsi-target: Fix mutex_trylock usage in iscsit_increment_maxcmdsn target: Core does not need blkdev.h target: Pass through I/O topology for block backstores iser-target: Avoid using FRMR for single dma entry requests ...
2013-11-21Merge branch 'for-linus2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "In this patchset, we finally get an SELinux update, with Paul Moore taking over as maintainer of that code. Also a significant update for the Keys subsystem, as well as maintenance updates to Smack, IMA, TPM, and Apparmor" and since I wanted to know more about the updates to key handling, here's the explanation from David Howells on that: "Okay. There are a number of separate bits. I'll go over the big bits and the odd important other bit, most of the smaller bits are just fixes and cleanups. If you want the small bits accounting for, I can do that too. (1) Keyring capacity expansion. KEYS: Consolidate the concept of an 'index key' for key access KEYS: Introduce a search context structure KEYS: Search for auth-key by name rather than target key ID Add a generic associative array implementation. KEYS: Expand the capacity of a keyring Several of the patches are providing an expansion of the capacity of a keyring. Currently, the maximum size of a keyring payload is one page. Subtract a small header and then divide up into pointers, that only gives you ~500 pointers on an x86_64 box. However, since the NFS idmapper uses a keyring to store ID mapping data, that has proven to be insufficient to the cause. Whatever data structure I use to handle the keyring payload, it can only store pointers to keys, not the keys themselves because several keyrings may point to a single key. This precludes inserting, say, and rb_node struct into the key struct for this purpose. I could make an rbtree of records such that each record has an rb_node and a key pointer, but that would use four words of space per key stored in the keyring. It would, however, be able to use much existing code. I selected instead a non-rebalancing radix-tree type approach as that could have a better space-used/key-pointer ratio. I could have used the radix tree implementation that we already have and insert keys into it by their serial numbers, but that means any sort of search must iterate over the whole radix tree. Further, its nodes are a bit on the capacious side for what I want - especially given that key serial numbers are randomly allocated, thus leaving a lot of empty space in the tree. So what I have is an associative array that internally is a radix-tree with 16 pointers per node where the index key is constructed from the key type pointer and the key description. This means that an exact lookup by type+description is very fast as this tells us how to navigate directly to the target key. I made the data structure general in lib/assoc_array.c as far as it is concerned, its index key is just a sequence of bits that leads to a pointer. It's possible that someone else will be able to make use of it also. FS-Cache might, for example. (2) Mark keys as 'trusted' and keyrings as 'trusted only'. KEYS: verify a certificate is signed by a 'trusted' key KEYS: Make the system 'trusted' keyring viewable by userspace KEYS: Add a 'trusted' flag and a 'trusted only' flag KEYS: Separate the kernel signature checking keyring from module signing These patches allow keys carrying asymmetric public keys to be marked as being 'trusted' and allow keyrings to be marked as only permitting the addition or linkage of trusted keys. Keys loaded from hardware during kernel boot or compiled into the kernel during build are marked as being trusted automatically. New keys can be loaded at runtime with add_key(). They are checked against the system keyring contents and if their signatures can be validated with keys that are already marked trusted, then they are marked trusted also and can thus be added into the master keyring. Patches from Mimi Zohar make this usable with the IMA keyrings also. (3) Remove the date checks on the key used to validate a module signature. X.509: Remove certificate date checks It's not reasonable to reject a signature just because the key that it was generated with is no longer valid datewise - especially if the kernel hasn't yet managed to set the system clock when the first module is loaded - so just remove those checks. (4) Make it simpler to deal with additional X.509 being loaded into the kernel. KEYS: Load *.x509 files into kernel keyring KEYS: Have make canonicalise the paths of the X.509 certs better to deduplicate The builder of the kernel now just places files with the extension ".x509" into the kernel source or build trees and they're concatenated by the kernel build and stuffed into the appropriate section. (5) Add support for userspace kerberos to use keyrings. KEYS: Add per-user_namespace registers for persistent per-UID kerberos caches KEYS: Implement a big key type that can save to tmpfs Fedora went to, by default, storing kerberos tickets and tokens in tmpfs. We looked at storing it in keyrings instead as that confers certain advantages such as tickets being automatically deleted after a certain amount of time and the ability for the kernel to get at these tokens more easily. To make this work, two things were needed: (a) A way for the tickets to persist beyond the lifetime of all a user's sessions so that cron-driven processes can still use them. The problem is that a user's session keyrings are deleted when the session that spawned them logs out and the user's user keyring is deleted when the UID is deleted (typically when the last log out happens), so neither of these places is suitable. I've added a system keyring into which a 'persistent' keyring is created for each UID on request. Each time a user requests their persistent keyring, the expiry time on it is set anew. If the user doesn't ask for it for, say, three days, the keyring is automatically expired and garbage collected using the existing gc. All the kerberos tokens it held are then also gc'd. (b) A key type that can hold really big tickets (up to 1MB in size). The problem is that Active Directory can return huge tickets with lots of auxiliary data attached. We don't, however, want to eat up huge tracts of unswappable kernel space for this, so if the ticket is greater than a certain size, we create a swappable shmem file and dump the contents in there and just live with the fact we then have an inode and a dentry overhead. If the ticket is smaller than that, we slap it in a kmalloc()'d buffer" * 'for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (121 commits) KEYS: Fix keyring content gc scanner KEYS: Fix error handling in big_key instantiation KEYS: Fix UID check in keyctl_get_persistent() KEYS: The RSA public key algorithm needs to select MPILIB ima: define '_ima' as a builtin 'trusted' keyring ima: extend the measurement list to include the file signature kernel/system_certificate.S: use real contents instead of macro GLOBAL() KEYS: fix error return code in big_key_instantiate() KEYS: Fix keyring quota misaccounting on key replacement and unlink KEYS: Fix a race between negating a key and reading the error set KEYS: Make BIG_KEYS boolean apparmor: remove the "task" arg from may_change_ptraced_domain() apparmor: remove parent task info from audit logging apparmor: remove tsk field from the apparmor_audit_struct apparmor: fix capability to not use the current task, during reporting Smack: Ptrace access check mode ima: provide hash algo info in the xattr ima: enable support for larger default filedata hash algorithms ima: define kernel parameter 'ima_template=' to change configured default ima: add Kconfig default measurement list template ...
2013-11-19percpu-refcount: Add percpu-refcount.o to obj-yRandy Dunlap
Drop percpu_ida.o from lib-y since it is also listed in obj-y and it doesn't need to be listed in both places. Move percpu-refcount.o from lib-y to obj-y to fix build errors in target_core_mod: ERROR: "percpu_ref_cancel_init" [drivers/target/target_core_mod.ko] undefined! ERROR: "percpu_ref_kill_and_confirm" [drivers/target/target_core_mod.ko] undefined! ERROR: "percpu_ref_init" [drivers/target/target_core_mod.ko] undefined! Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2013-11-14Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core locking changes from Ingo Molnar: "The biggest changes: - add lockdep support for seqcount/seqlocks structures, this unearthed both bugs and required extra annotation. - move the various kernel locking primitives to the new kernel/locking/ directory" * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (21 commits) block: Use u64_stats_init() to initialize seqcounts locking/lockdep: Mark __lockdep_count_forward_deps() as static lockdep/proc: Fix lock-time avg computation locking/doc: Update references to kernel/mutex.c ipv6: Fix possible ipv6 seqlock deadlock cpuset: Fix potential deadlock w/ set_mems_allowed seqcount: Add lockdep functionality to seqcount/seqlock structures net: Explicitly initialize u64_stats_sync structures for lockdep locking: Move the percpu-rwsem code to kernel/locking/ locking: Move the lglocks code to kernel/locking/ locking: Move the rwsem code to kernel/locking/ locking: Move the rtmutex code to kernel/locking/ locking: Move the semaphore core to kernel/locking/ locking: Move the spinlock code to kernel/locking/ locking: Move the lockdep code to kernel/locking/ locking: Move the mutex code to kernel/locking/ hung_task debugging: Add tracepoint to report the hang x86/locking/kconfig: Update paravirt spinlock Kconfig description lockstat: Report avg wait and hold times lockdep, x86/alternatives: Drop ancient lockdep fixup message ...
2013-11-13percpu: add test module for various percpu operationsGreg Thelen
Tests various percpu operations. Enable with CONFIG_PERCPU_TEST=m. Signed-off-by: Greg Thelen <gthelen@google.com> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-06locking: Move the percpu-rwsem code to kernel/locking/Peter Zijlstra
Suggested-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-52bjmtty46we26hbfd9sc9iy@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-06locking: Move the rwsem code to kernel/locking/Peter Zijlstra
Notably: changed lib/rwsem* targets from lib- to obj-, no idea about the ramifications of that. Suggested-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-g0kynfh5feriwc6p3h6kpbw6@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-06locking: Move the spinlock code to kernel/locking/Peter Zijlstra
Suggested-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-b81ol0z3mon45m51o131yc9j@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-24Add a generic associative array implementation.David Howells
Add a generic associative array implementation that can be used as the container for keyrings, thereby massively increasing the capacity available whilst also speeding up searching in keyrings that contain a lot of keys. This may also be useful in FS-Cache for tracking cookies. Documentation is added into Documentation/associative_array.txt Some of the properties of the implementation are: (1) Objects are opaque pointers. The implementation does not care where they point (if anywhere) or what they point to (if anything). [!] NOTE: Pointers to objects _must_ be zero in the two least significant bits. (2) Objects do not need to contain linkage blocks for use by the array. This permits an object to be located in multiple arrays simultaneously. Rather, the array is made up of metadata blocks that point to objects. (3) Objects are labelled as being one of two types (the type is a bool value). This information is stored in the array, but has no consequence to the array itself or its algorithms. (4) Objects require index keys to locate them within the array. (5) Index keys must be unique. Inserting an object with the same key as one already in the array will replace the old object. (6) Index keys can be of any length and can be of different lengths. (7) Index keys should encode the length early on, before any variation due to length is seen. (8) Index keys can include a hash to scatter objects throughout the array. (9) The array can iterated over. The objects will not necessarily come out in key order. (10) The array can be iterated whilst it is being modified, provided the RCU readlock is being held by the iterator. Note, however, under these circumstances, some objects may be seen more than once. If this is a problem, the iterator should lock against modification. Objects will not be missed, however, unless deleted. (11) Objects in the array can be looked up by means of their index key. (12) Objects can be looked up whilst the array is being modified, provided the RCU readlock is being held by the thread doing the look up. The implementation uses a tree of 16-pointer nodes internally that are indexed on each level by nibbles from the index key. To improve memory efficiency, shortcuts can be emplaced to skip over what would otherwise be a series of single-occupancy nodes. Further, nodes pack leaf object pointers into spare space in the node rather than making an extra branch until as such time an object needs to be added to a full node. Signed-off-by: David Howells <dhowells@redhat.com>
2013-09-12Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull SCSI target updates from Nicholas Bellinger: "Lots of activity again this round for I/O performance optimizations (per-cpu IDA pre-allocation for vhost + iscsi/target), and the addition of new fabric independent features to target-core (COMPARE_AND_WRITE + EXTENDED_COPY). The main highlights include: - Support for iscsi-target login multiplexing across individual network portals - Generic Per-cpu IDA logic (kent + akpm + clameter) - Conversion of vhost to use per-cpu IDA pre-allocation for descriptors, SGLs and userspace page pointer list - Conversion of iscsi-target + iser-target to use per-cpu IDA pre-allocation for descriptors - Add support for generic COMPARE_AND_WRITE (AtomicTestandSet) emulation for virtual backend drivers - Add support for generic EXTENDED_COPY (CopyOffload) emulation for virtual backend drivers. - Add support for fast memory registration mode to iser-target (Vu) The patches to add COMPARE_AND_WRITE and EXTENDED_COPY support are of particular significance, which make us the first and only open source target to support the full set of VAAI primitives. Currently Linux clients are lacking upstream support to actually utilize these primitives. However, with server side support now in place for folks like MKP + ZAB working on the client, this logic once reserved for the highest end of storage arrays, can now be run in VMs on their laptops" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (50 commits) target/iscsi: Bump versions to v4.1.0 target: Update copyright ownership/year information to 2013 iscsi-target: Bump default TCP listen backlog to 256 target: Fix >= v3.9+ regression in PR APTPL + ALUA metadata write-out iscsi-target; Bump default CmdSN Depth to 64 iscsi-target: Remove unnecessary wait_for_completion in iscsi_get_thread_set iscsi-target: Add thread_set->ts_activate_sem + use common deallocate iscsi-target: Fix race with thread_pre_handler flush_signals + ISCSI_THREAD_SET_DIE target: remove unused including <linux/version.h> iser-target: introduce fast memory registration mode (FRWR) iser-target: generalize rdma memory registration and cleanup iser-target: move rdma wr processing to a shared function target: Enable global EXTENDED_COPY setup/release target: Add Third Party Copy (3PC) bit in INQUIRY response target: Enable EXTENDED_COPY setup in spc_parse_cdb target: Add support for EXTENDED_COPY copy offload emulation target: Avoid non-existent tg_pt_gp_mem in target_alua_state_check target: Add global device list for EXTENDED_COPY target: Make helpers non static for EXTENDED_COPY command setup target: Make spc_parse_naa_6h_vendor_specific non static ...
2013-09-09idr: Percpu idaKent Overstreet
Percpu frontend for allocating ids. With percpu allocation (that works), it's impossible to guarantee it will always be possible to allocate all nr_tags - typically, some will be stuck on a remote percpu freelist where the current job can't get to them. We do guarantee that it will always be possible to allocate at least (nr_tags / 2) tags - this is done by keeping track of which and how many cpus have tags on their percpu freelists. On allocation failure if enough cpus have tags that there could potentially be (nr_tags / 2) tags stuck on remote percpu freelists, we then pick a remote cpu at random to steal from. Note that there's no cpu hotplug notifier - we don't care, because steal_tags() will eventually get the down cpu's tags. We _could_ satisfy more allocations if we had a notifier - but we'll still meet our guarantees and it's absolutely not a correctness issue, so I don't think it's worth the extra code. From akpm: "It looks OK to me (that's as close as I get to an ack :)) v6 changes: - Add #include <linux/cpumask.h> to include/linux/percpu_ida.h to make alpha/arc builds happy (Fengguang) - Move second (cpu >= nr_cpu_ids) check inside of first check scope in steal_tags() (akpm + nab) v5 changes: - Change percpu_ida->cpus_have_tags to cpumask_t (kmo + akpm) - Add comment for percpu_ida_cpu->lock + ->nr_free (kmo + akpm) - Convert steal_tags() to use cpumask_weight() + cpumask_next() + cpumask_first() + cpumask_clear_cpu() (kmo + akpm) - Add comment for alloc_global_tags() (kmo + akpm) - Convert percpu_ida_alloc() to use cpumask_set_cpu() (kmo + akpm) - Convert percpu_ida_free() to use cpumask_set_cpu() (kmo + akpm) - Drop percpu_ida->cpus_have_tags allocation in percpu_ida_init() (kmo + akpm) - Drop percpu_ida->cpus_have_tags kfree in percpu_ida_destroy() (kmo + akpm) - Add comment for percpu_ida_alloc @ gfp (kmo + akpm) - Move to percpu_ida.c + percpu_ida.h (kmo + akpm + nab) v4 changes: - Fix tags.c reference in percpu_ida_init (akpm) Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: Tejun Heo <tj@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: "Nicholas A. Bellinger" <nab@linux-iscsi.org> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2013-09-02lockref: uninline lockref helper functionsLinus Torvalds
They aren't very good to inline, since they already call external functions (the spinlock code), and we're going to create rather more complicated versions of them that can do the reference count updates locklessly. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09lib: add lz4 compressor moduleChanho Min
This patchset is for supporting LZ4 compression and the crypto API using it. As shown below, the size of data is a little bit bigger but compressing speed is faster under the enabled unaligned memory access. We can use lz4 de/compression through crypto API as well. Also, It will be useful for another potential user of lz4 compression. lz4 Compression Benchmark: Compiler: ARM gcc 4.6.4 ARMv7, 1 GHz based board Kernel: linux 3.4 Uncompressed data Size: 101 MB Compressed Size compression Speed LZO 72.1MB 32.1MB/s, 33.0MB/s(UA) LZ4 75.1MB 30.4MB/s, 35.9MB/s(UA) LZ4HC 59.8MB 2.4MB/s, 2.5MB/s(UA) - UA: Unaligned memory Access support - Latest patch set for LZO applied This patch: Add support for LZ4 compression in the Linux Kernel. LZ4 Compression APIs for kernel are based on LZ4 implementation by Yann Collet and were changed for kernel coding style. LZ4 homepage : http://fastcompression.blogspot.com/p/lz4.html LZ4 source repository : http://code.google.com/p/lz4/ svn revision : r90 Two APIs are added: lz4_compress() support basic lz4 compression whereas lz4hc_compress() support high compression or CPU performance get lower but compression ratio get higher. Also, we require the pre-allocated working memory with the defined size and destination buffer must be allocated with the size of lz4_compressbound. [akpm@linux-foundation.org: make lz4_compresshcctx() static] Signed-off-by: Chanho Min <chanho.min@lge.com> Cc: "Darrick J. Wong" <djwong@us.ibm.com> Cc: Bob Pearson <rpearson@systemfabricworks.com> Cc: Richard Weinberger <richard@nod.at> Cc: Herbert Xu <herbert@gondor.hengli.com.au> Cc: Yann Collet <yann.collet.73@gmail.com> Cc: Kyungsik Lee <kyungsik.lee@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09lib: add support for LZ4-compressed kernelKyungsik Lee
Add support for extracting LZ4-compressed kernel images, as well as LZ4-compressed ramdisk images in the kernel boot process. Signed-off-by: Kyungsik Lee <kyungsik.lee@lge.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Borislav Petkov <bp@alien8.de> Cc: Florian Fainelli <florian@openwrt.org> Cc: Yann Collet <yann.collet.73@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
