path: root/lib/audit.c
2014-03-20audit: Add generic compat syscall supportAKASHI Takahiro
lib/audit.c provides a generic function for auditing system calls. This patch extends it for compat syscall support on bi-architectures (32/64-bit) by adding lib/compat_audit.c. What is required to support this feature are: * add asm/unistd32.h for compat system call names * select CONFIG_AUDIT_ARCH_COMPAT_GENERIC Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Acked-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2011-05-04audit: support the "standard" <asm-generic/unistd.h>Chris Metcalf
Many of the syscalls mentioned in the audit code are not present for architectures that implement only the "standard" set of Linux syscalls (e.g. openat, but not open, etc.). This change adds proper #ifdefs for all those syscalls. Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2007-05-11[PATCH] audit signal recipientsAmy Griffis
When auditing syscalls that send signals, log the pid and security context for each target process. Optimize the data collection by adding a counter for signal-related rules, and avoiding allocating an aux struct unless we have more than one target process. For process groups, collect pid/context data in blocks of 16. Move the audit_signal_info() hook up in check_kill_permission() so we audit attempts where permission is denied. Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2007-05-11[PATCH] add SIGNAL syscall class (v3)Amy Griffis
Add a syscall class for sending signals. Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-09-22[PATCH] fix missing ifdefs in syscall classes hookup for generic targetsAl Viro
several targets have no ....at() family and m32r calls its only chown variant chown32(), with __NR_chown being undefined. creat(2) is also absent in some targets. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-12[PATCH] syscall class hookup for all normal targetsAl Viro
Take default arch/*/kernel/audit.c to lib/, have those with special needs (== biarch) define AUDIT_ARCH in their Kconfig. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
