path: root/lib/btree.c
2012-06-17btree: fix tree corruption in btree_get_prev()Roland Dreier
commit cbf8ae32f66a9ceb8907ad9e16663c2a29e48990 upstream. The memory the parameter __key points to is used as an iterator in btree_get_prev(), so if we save off a bkey() pointer in retry_key and then assign that to __key, we'll end up corrupting the btree internals when we do eg longcpy(__key, bkey(geo, node, i), geo->keylen); to return the key value. What we should do instead is use longcpy() to copy the key value that retry_key points to __key. This can cause a btree to get corrupted by seemingly read-only operations such as btree_for_each_safe. [akpm@linux-foundation.org: avoid the double longcpy()] Signed-off-by: Roland Dreier <roland@purestorage.com> Acked-by: Joern Engel <joern@logfs.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2010-05-15lib/btree: fix possible NULL pointer dereferencekirjanov@gmail.com
mempool_alloc() can return null in atomic case. Signed-off-by: Denis Kirjanov <kirjanov@gmail.com> Cc: Joern Engel <joern@logfs.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-20[LogFS] add new flash file systemJoern Engel
This is a new flash file system. See Documentation/filesystems/logfs.txt Signed-off-by: Joern Engel <joern@logfs.org>
