path: root/lib/build_OID_registry
2013-06-19X.509: do not emit any informational outputArnd Bergmann
When building a kernel using 'make -s', I expect to see an empty output, except for build warnings and errors. The build_OID_registry code always prints one line when run, which is not helpful to most people building the kernels, and which makes it harder to automatically check for build warnings. Let's just remove the one line output. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: David Howells <dhowells@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au>
2012-10-08X.509: Implement simple static OID registryDavid Howells
Implement a simple static OID registry that allows the mapping of an encoded OID to an enum value for ease of use. The OID registry index enum appears in the: linux/oid_registry.h header file. A script generates the registry from lines in the header file that look like: <sp*>OID_foo,<sp*>/*<sp*>1.2.3.4<sp*>*/ The actual OID is taken to be represented by the numbers with interpolated dots in the comment. All other lines in the header are ignored. The registry is queries by calling: OID look_up_oid(const void *data, size_t datasize); This returns a number from the registry enum representing the OID if found or OID__NR if not. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
