path: root/lib/cmdline.c
2017-06-29lib/cmdline.c: fix get_options() overflow while parsing rangesIlya Matveychikov
commit a91e0f680bcd9e10c253ae8b62462a38bd48f09f upstream. When using get_options() it's possible to specify a range of numbers, like 1-100500. The problem is that it doesn't track array size while calling internally to get_range() which iterates over the range and fills the memory with numbers. Link: http://lkml.kernel.org/r/2613C75C-B04D-4BFF-82A6-12F97BA0F620@gmail.com Signed-off-by: Ilya V. Matveychikov <matvejchikov@gmail.com> Cc: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-03lib: Add a generic cmdline parse function parse_option_strDave Young
There should be a generic function to parse params like a=b,c Adding parse_option_str in lib/cmdline.c which will return true if there's specified option set in the params. Also updated efi=old_map parsing code to use the new function Signed-off-by: Dave Young <dyoung@redhat.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com>
2014-08-06lib/cmdline.c: add size unit t/p/e to memparseGui Hecheng
For modern filesystems such as btrfs, t/p/e size level operations are common. add size unit t/p/e parsing to memparse Signed-off-by: Gui Hecheng <guihc.fnst@cn.fujitsu.com> Acked-by: David Rientjes <rientjes@google.com> Reviewed-by: Satoru Takeuchi <takeuchi_satoru@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23lib/cmdline.c: declare exported symbols immediatelyFelipe Contreras
WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable +EXPORT_SYMBOL(memparse); WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable +EXPORT_SYMBOL(get_option); WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable +EXPORT_SYMBOL(get_options); Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Cc: Levente Kurusa <levex@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23lib/cmdline.c: fix style issuesFelipe Contreras
WARNING: space prohibited between function name and open parenthesis '(' +int get_option (char **str, int *pint) WARNING: space prohibited between function name and open parenthesis '(' + *pint = simple_strtol (cur, str, 0); ERROR: trailing whitespace + $ WARNING: please, no spaces at the start of a line + $ WARNING: space prohibited between function name and open parenthesis '(' + res = get_option ((char **)&str, ints + i); Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-07lib: reduce the use of module.h wherever possiblePaul Gortmaker
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map them onto including export.h -- or if the file isn't even using those, then just delete the include. Fix up any implicit include dependencies that were being masked by module.h along the way. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2008-07-28generic, memparse(): constify argumentJeremy Fitzhardinge
memparse()'s first argument can be const, so it should be. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-25lib: allow memparse() to accept a NULL and ignorable second parmRobert P. J. Day
Extend memparse() to allow the caller to use a NULL second parameter, which would represent no interest in returning the address of the end of the parsed string. In numerous cases, callers invoke memparse() to parse a possibly-suffixed string (such as "64K" or "2G" or whatever) and define a character pointer to accept the end pointer being returned by memparse() even though they have no interest in it and promptly throw it away. This (backward-compatible) enhancement allows callers to use NULL in the cases where they just don't care about getting back that end pointer. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Numerous fixes to kernel-doc info in source files.Robert P. J. Day
A variety of (mostly) innocuous fixes to the embedded kernel-doc content in source files, including: * make multi-line initial descriptions single line * denote some function names, constants and structs as such * change erroneous opening '/*' to '/**' in a few places * reword some text for clarity Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] get_options to allow a hypenated range for isolcpusDerek Fults
This allows a hyphenated range of positive numbers in the string passed to command line helper function, get_options. Currently the command line option "isolcpus=" takes as its argument a list of cpus. Format: <cpu number>,...,<cpu number> Valid values of <cpu_number> include all cpus, 0 to "number of CPUs in system - 1". This can get extremely long when isolating the majority of cpus on a large system. The kernel isolcpus code would not need any changing to use this feature. To use it, the change would be in the command line format for 'isolcpus=' Format: <cpu number>,...,<cpu number> or <cpu number>-<cpu number> (must be a positive range in ascending order.) or a mixture <cpu number>,...,<cpu number>-<cpu number> Signed-off-by: Derek Fults <dfults@sgi.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
