path: root/lib/decompress_bunzip2.c
2009-08-07lib/decompress_*: only include <linux/slab.h> if STATIC is not definedAlbin Tonnerre
These includes were added by 079effb6933f34b9b1b67b08bd4fd7fb672d16ef ("kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_inflate.c") to fix the build when using kmemtrace. However this is not necessary when used to create a compressed kernel, and actually creates issues (brings a lot of things unavailable in the decompression environment), so don't include it if STATIC is defined. Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-07bzip2/lzma: remove nasty uncompressed size hack in pre-boot environmentPhillip Lougher
decompress_bunzip2 and decompress_unlzma have a nasty hack that subtracts 4 from the input length if being called in the pre-boot environment. This is a nasty hack because it relies on the fact that flush = NULL only when called from the pre-boot environment (i.e. arch/x86/boot/compressed/misc.c). initramfs.c/do_mounts_rd.c pass in a flush buffer (flush != NULL). This hack prevents the decompressors from being used with flush = NULL by other callers unless knowledge of the hack is propagated to them. This patch removes the hack by making decompress (called only from the pre-boot environment) a wrapper function that subtracts 4 from the input length before calling the decompressor. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-03kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_bunzip2.cPekka Enberg
Impact: cleanup lib/decompress_bunzip2.c depends on slab.h without including it: CC lib/decompress_bunzip2.o lib/decompress_bunzip2.c: In function ‘start_bunzip’: lib/decompress_bunzip2.c:636: error: implicit declaration of function ‘kmalloc’ lib/decompress_bunzip2.c:636: warning: assignment makes pointer from integer without a cast lib/decompress_bunzip2.c: In function ‘bunzip2’: lib/decompress_bunzip2.c:682: warning: assignment makes pointer from integer without a cast lib/decompress_bunzip2.c:693: warning: assignment makes pointer from integer without a cast lib/decompress_bunzip2.c:726: error: implicit declaration of function ‘kfree’ make[1]: *** [lib/decompress_bunzip2.o] Error 1 make: *** [lib/] Error 2 It gets included implicitly currently - but this will not be the case with upcoming kmemtrace changes. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> LKML-Reference: <1237886032.25315.48.camel@penberg-laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-04bzip2/lzma: library support for gzip, bzip2 and lzma decompressionAlain Knaff
Impact: Replaces inflate.c with a wrapper around zlib_inflate; new library code This is the first part of the bzip2/lzma patch The bzip patch is based on an idea by Christian Ludwig, includes support for compressing the kernel with bzip2 or lzma rather than gzip. Both compressors give smaller sizes than gzip. Lzma's decompresses faster than bzip2. It also supports ramdisks and initramfs' compressed using these two compressors. The functionality has been successfully used for a couple of years by the udpcast project This version applies to "tip" kernel 2.6.28 This part contains: - changed inflate.c to accomodate rest of patch - implementation of bzip2 compression (not used at this stage yet) - implementation of lzma compression (not used at this stage yet) - Makefile routines to support bzip2 and lzma kernel compression Signed-off-by: Alain Knaff <alain@knaff.lu> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
