path: root/lib/decompress_unlzo.c
2015-09-10lib/decompressors: use real out buf size for gunzip with kernelYinghai Lu
When loading x86 64bit kernel above 4GiB with patched grub2, got kernel gunzip error. | early console in decompress_kernel | decompress_kernel: | input: [0x807f2143b4-0x807ff61aee] | output: [0x807cc00000-0x807f3ea29b] 0x027ea29c: output_len | boot via startup_64 | KASLR using RDTSC... | new output: [0x46fe000000-0x470138cfff] 0x0338d000: output_run_size | decompress: [0x46fe000000-0x47007ea29b] <=== [0x807f2143b4-0x807ff61aee] | | Decompressing Linux... gz... | | uncompression error | | -- System halted the new buffer is at 0x46fe000000ULL, decompressor_gzip is using 0xffffffb901ffffff as out_len. gunzip in lib/zlib_inflate/inflate.c cap that len to 0x01ffffff and decompress fails later. We could hit this problem with crashkernel booting that uses kexec loading kernel above 4GiB. We have decompress_* support: 1. inbuf[]/outbuf[] for kernel preboot. 2. inbuf[]/flush() for initramfs 3. fill()/flush() for initrd. This bug only affect kernel preboot path that use outbuf[]. Add __decompress and take real out_buf_len for gunzip instead of guessing wrong buf size. Fixes: 1431574a1c4 (lib/decompressors: fix "no limit" output buffer length) Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Alexandre Courbot <acourbot@nvidia.com> Cc: Jon Medhurst <tixy@linaro.org> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08initramfs: support initramfs that is bigger than 2GiBYinghai Lu
Now with 64bit bzImage and kexec tools, we support ramdisk that size is bigger than 2g, as we could put it above 4G. Found compressed initramfs image could not be decompressed properly. It turns out that image length is int during decompress detection, and it will become < 0 when length is more than 2G. Furthermore, during decompressing len as int is used for inbuf count, that has problem too. Change len to long, that should be ok as on 32 bit platform long is 32bits. Tested with following compressed initramfs image as root with kexec. gzip, bzip2, xz, lzma, lzop, lz4. run time for populate_rootfs(): size name Nehalem-EX Westmere-EX Ivybridge-EX 9034400256 root_img : 26s 24s 30s 3561095057 root_img.lz4 : 28s 27s 27s 3459554629 root_img.lzo : 29s 29s 28s 3219399480 root_img.gz : 64s 62s 49s 2251594592 root_img.xz : 262s 260s 183s 2226366598 root_img.lzma: 386s 376s 277s 2901482513 root_img.bz2 : 635s 599s Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Rashika Kheria <rashika.kheria@gmail.com> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Kyungsik Lee <kyungsik.lee@lge.com> Cc: P J P <ppandit@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Cc: "Daniel M. Weeks" <dan@danweeks.net> Cc: Alexandre Courbot <acourbot@nvidia.com> Cc: Jan Beulich <JBeulich@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-20lib/lzo: Rename lzo1x_decompress.c to lzo1x_decompress_safe.cMarkus F.X.J. Oberhumer
Rename the source file to match the function name and thereby also make room for a possible future even slightly faster "non-safe" decompressor version. Signed-off-by: Markus F.X.J. Oberhumer <markus@oberhumer.com>
2012-01-12unlzo: fix input buffer freeSascha Hauer
unlzo modifies the pointer to in_buf, so we have to free the original buffer, not the modified pointer. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Cc: Lasse Collin <lasse.collin@tukaani.org> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Decompressors: fix callback-to-callback mode in decompress_unlzo.cLasse Collin
Callback-to-callback decompression mode is used for initrd (not initramfs). The LZO wrapper is broken for this use case for two reasons: - The argument validation is needlessly too strict by requiring that "posp" is non-NULL when "fill" is non-NULL. - The buffer handling code didn't work at all for this use case. I tested with LZO-compressed kernel, initramfs, initrd, and corrupt (truncated) initramfs and initrd images. Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alain Knaff <alain@knaff.lu> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Decompressors: check input size in decompress_unlzo.cLasse Collin
The code assumes that the input is valid and not truncated. Add checks to avoid reading past the end of the input buffer. Change the type of "skip" from u8 to int to fix a possible integer overflow. Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alain Knaff <alain@knaff.lu> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Decompressors: check for write errors in decompress_unlzo.cLasse Collin
The return value of flush() is not checked in unlzo(). This means that the decompressor won't stop even if the caller doesn't want more data. This can happen e.g. with a corrupt LZO-compressed initramfs image. Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alain Knaff <alain@knaff.lu> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Decompressors: include <linux/slab.h> in <linux/decompress/mm.h>Lasse Collin
Currently users of mm.h need to include <linux/slab.h> to use the macros malloc() and free() provided by mm.h. This fixes it. Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alain Knaff <alain@knaff.lu> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Decompressors: get rid of set_error_fn() macroLasse Collin
set_error_fn() has become a useless complication after c1e7c3ae59 ("bzip2/lzma/gzip: pre-boot malloc doesn't return NULL on failure") fixed the use of error() in malloc(). Only decompress_unlzma.c had some use for it and that was easy to change too. This also gets rid of the static function pointer "error", which should have been marked as __initdata. Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alain Knaff <alain@knaff.lu> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-24lib: fix the use of LZO to decompress initramfs imagesAlbin Tonnerre
This patch fixes 2 issues with the LZO decompressor: - It doesn't handle the case where a block isn't compressed at all. In this case, calling lzo1x_decompress_safe will fail, so we need to just use memcpy() instead (the upstream LZO code does something similar) - Since commit 54291362d2a5738e1b0495df2abcb9e6b0563a3f ("initramfs: add missing decompressor error check") , the decompressor return code is checked in the init/initramfs.c The LZO decompressor didn't return the expected value, causing the initramfs code to falsely believe a decompression error occured Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Tested-by: bert schulze <spambemyguest@googlemail.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11lib: add support for LZO-compressed kernelsAlbin Tonnerre
This patch series adds generic support for creating and extracting LZO-compressed kernel images, as well as support for using such images on the x86 and ARM architectures, and support for creating and using LZO-compressed initrd and initramfs images. Russell King said: : Testing on a Cortex A9 model: : - lzo decompressor is 65% of the time gzip takes to decompress a kernel : - lzo kernel is 9% larger than a gzip kernel : : which I'm happy to say confirms your figures when comparing the two. : : However, when comparing your new gzip code to the old gzip code: : - new is 99% of the size of the old code : - new takes 42% of the time to decompress than the old code : : What this means is that for a proper comparison, the results get even better: : - lzo is 7.5% larger than the old gzip'd kernel image : - lzo takes 28% of the time that the old gzip code took : : So the expense seems definitely worth the effort. The only reason I : can think of ever using gzip would be if you needed the additional : compression (eg, because you have limited flash to store the image.) : : I would argue that the default for ARM should therefore be LZO. This patch: The lzo compressor is worse than gzip at compression, but faster at extraction. Here are some figures for an ARM board I'm working on: Uncompressed size: 3.24Mo gzip 1.61Mo 0.72s lzo 1.75Mo 0.48s So for a compression ratio that is still relatively close to gzip, it's much faster to extract, at least in that case. This part contains: - Makefile routine to support lzo compression - Fixes to the existing lzo compressor so that it can be used in compressed kernels - wrapper around the existing lzo1x_decompress, as it only extracts one block at a time, while we need to extract a whole file here - config dialog for kernel compression [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: cleanup] Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Tested-by: Wu Zhangjin <wuzhangjin@gmail.com> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Tested-by: Russell King <rmk@arm.linux.org.uk> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
