[ Upstream commit 9dea44c91469512d346e638694c22c30a5273992 ]
devm_ioremap_resource() does not currently take 'const' arguments,
which results in a warning from the first driver trying to do it
anyway:
drivers/gpio/gpio-amd-fch.c: In function 'amd_fch_gpio_probe':
drivers/gpio/gpio-amd-fch.c:171:49: error: passing argument 2 of 'devm_ioremap_resource' discards 'const' qualifier from pointer target type [-Werror=discarded-qualifiers]
priv->base = devm_ioremap_resource(&pdev->dev, &amd_fch_gpio_iores);
Change the prototype to allow it, as there is no real reason not to.
Fixes: 9bb2e0452508 ("gpio: amd: Make resource struct const")
Link: https://lore.kernel.org/r/20190628150049.1108048-1-arnd@arndb.de
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Reviwed-By: Enrico Weigelt <info@metux.net>
Use to_pci_dev() instead of open-coding it.
Signed-off-by: Geliang Tang <geliangtang@163.com>
Acked-by: Tejun Heo <tj@kernel.org>
The iomap[] array has PCIM_IOMAP_MAX (6) elements and not
DEVICE_COUNT_RESOURCE (16). This bug was found using a static checker.
It may be that the "if (!(mask & (1 << i)))" check means we never
actually go past the end of the array in real life.
Fixes: ec04b075843d ('iomap: implement pcim_iounmap_regions()')
Quoting Arnd:
I was thinking the opposite approach and basically removing all uses
of IORESOURCE_CACHEABLE from the kernel. There are only a handful of
them.and we can probably replace them all with hardcoded
ioremap_cached() calls in the cases they are actually useful.
All existing usages of IORESOURCE_CACHEABLE call ioremap() instead of
ioremap_nocache() if the resource is cacheable, however ioremap() is
uncached by default. Clearly none of the existing usages care about the
cacheability. Particularly devm_ioremap_resource() never worked as
advertised since it always fell back to plain ioremap().
Clean this up as the new direction we want is to convert
ioremap_<type>() usages to memremap(..., flags).
Suggested-by: Arnd Bergmann <arnd@arndb.de>
Implement a resource managed writecombine ioremap function.
Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
As in 4f452e8aa492c0b8028ca9b4bdb4d018ba28c6c7, use resource_size_t
to accomodate sizes greater than the size of an unsigned long int on
platforms that have more than 32 bit physical addresses.
Signed-off-by: Cristian Stoica <cristian.stoica@freescale.com>
Pull timer and time updates from Thomas Gleixner:
"A rather large update of timers, timekeeping & co
- Core timekeeping code is year-2038 safe now for 32bit machines.
Now we just need to fix all in kernel users and the gazillion of
user space interfaces which rely on timespec/timeval :)
- Better cache layout for the timekeeping internal data structures.
- Proper nanosecond based interfaces for in kernel users.
- Tree wide cleanup of code which wants nanoseconds but does hoops
and loops to convert back and forth from timespecs. Some of it
definitely belongs into the ugly code museum.
- Consolidation of the timekeeping interface zoo.
- A fast NMI safe accessor to clock monotonic for tracing. This is a
long standing request to support correlated user/kernel space
traces. With proper NTP frequency correction it's also suitable
for correlation of traces accross separate machines.
- Checkpoint/restart support for timerfd.
- A few NOHZ[_FULL] improvements in the [hr]timer code.
- Code move from kernel to kernel/time of all time* related code.
- New clocksource/event drivers from the ARM universe. I'm really
impressed that despite an architected timer in the newer chips SoC
manufacturers insist on inventing new and differently broken SoC
specific timers.
[ Ed. "Impressed"? I don't think that word means what you think it means ]
- Another round of code move from arch to drivers. Looks like most
of the legacy mess in ARM regarding timers is sorted out except for
a few obnoxious strongholds.
- The usual updates and fixlets all over the place"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (114 commits)
timekeeping: Fixup typo in update_vsyscall_old definition
clocksource: document some basic timekeeping concepts
timekeeping: Use cached ntp_tick_length when accumulating error
timekeeping: Rework frequency adjustments to work better w/ nohz
timekeeping: Minor fixup for timespec64->timespec assignment
ftrace: Provide trace clocks monotonic
timekeeping: Provide fast and NMI safe access to CLOCK_MONOTONIC
seqcount: Add raw_write_seqcount_latch()
seqcount: Provide raw_read_seqcount()
timekeeping: Use tk_read_base as argument for timekeeping_get_ns()
timekeeping: Create struct tk_read_base and use it in struct timekeeper
timekeeping: Restructure the timekeeper some more
clocksource: Get rid of cycle_last
clocksource: Move cycle_last validation to core code
clocksource: Make delta calculation a function
wireless: ath9k: Get rid of timespec conversions
drm: vmwgfx: Use nsec based interfaces
drm: i915: Use nsec based interfaces
timekeeping: Provide ktime_get_raw()
hangcheck-timer: Use ktime_get_ns()
A call to of_iomap does not request the memory region. This patch adds the
function of_io_request_and_map which requests the memory region before
mapping it.
Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
Suggested-by: Thomas Gleixner <tglx@linutronix.de>
Suggested-by: Rob Herring <robh@kernel.org>
Acked-by: Rob Herring <robh@kernel.org>
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
devm_request_and_ioremap() was obsoleted by the commit 7509657
("lib: devres: Introduce devm_ioremap_resource()") and has been
deprecated for a long time. So, let's remove this function.
In addition, all usages of devm_request_and_ioremap() are also
removed.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Fix 3 checkpatch warnings:
'ERROR: "foo * const * bar" should be "foo * const *bar"'
Signed-off-by: Fabian Frederick <fabf@skynet.be>
devm_request_and_ioremap was the only function to use device
instead of dev. This fixes kernel-doc warning.
If the renamed symbol is defined lib/iomap.c implements ioport_map and
ioport_unmap and currently (nearly) all platforms define the port
accessor functions outb/inb and friend unconditionally. So
HAS_IOPORT_MAP is the better name for this.
Consequently NO_IOPORT is renamed to NO_IOPORT_MAP.
The motivation for this change is to reintroduce a symbol HAS_IOPORT
that signals if outb/int et al are available. I will address that at
least one merge window later though to keep surprises to a minimum and
catch new introductions of (HAS|NO)_IOPORT.
The changes in this commit were done using:
$ git grep -l -E '(NO|HAS)_IOPORT' | xargs perl -p -i -e 's/\b((?:CONFIG_)?(?:NO|HAS)_IOPORT)\b/$1_MAP/'
Having a discussion about sparse warnings in the kernel, and that we
should clean them up, I decided to pick a random file to do so. This
happened to be devres.c which gives the following warnings:
CHECK lib/devres.c
lib/devres.c:83:9: warning: cast removes address space of expression
lib/devres.c:117:31: warning: incorrect type in return expression (different address spaces)
lib/devres.c:117:31: expected void [noderef] <asn:2>*
lib/devres.c:117:31: got void *
lib/devres.c:125:31: warning: incorrect type in return expression (different address spaces)
lib/devres.c:125:31: expected void [noderef] <asn:2>*
lib/devres.c:125:31: got void *
lib/devres.c:136:26: warning: incorrect type in assignment (different address spaces)
lib/devres.c:136:26: expected void [noderef] <asn:2>*[assigned] dest_ptr
lib/devres.c:136:26: got void *
lib/devres.c:226:9: warning: cast removes address space of expression
Mostly it's just the use of typecasting to void * without adding
__force, or returning ERR_PTR(-ESOMEERR) without typecasting to a
__iomem type.
I added a helper macro IOMEM_ERR_PTR() that does the typecast to make
the code a little nicer than adding ugly typecasts to the code.
Cc: Tejun Heo <tj@kernel.org>
A misplaced #endif causes link errors related to pcim_*() functions.
This is because pcim_*() functions are related to CONFIG_PCI option,
however these are not related to CONFIG_HAS_IOPORT option. Therefore,
when CONFIG_PCI is enabled and CONFIG_HAS_IOPORT is not enabled, it makes
link errors related to pcim_*() functions as below:
drivers/ata/libata-sff.c:3233: undefined reference to `pcim_iomap_regions'
drivers/ata/libata-sff.c:3238: undefined reference to `pcim_iomap_table'
drivers/built-in.o: In function `ata_pci_sff_init_host':
drivers/ata/libata-sff.c:2318: undefined reference to `pcim_iomap_regions'
drivers/ata/libata-sff.c:2329: undefined reference to `pcim_iomap_table
Cc: Greg KH <greg@kroah.com>
The ERR_PTR() and IS_ERR() macros used by the devm_ioremap_resource()
function are defined in the linux/err.h header. On ARM this seems to be
pulled in by one of the other headers but the build fails at least on
OpenRISC.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
Reported-by: kbuild test robot <fengguang.wu@intel.com>
The devm_request_and_ioremap() function is very useful and helps avoid a
whole lot of boilerplate. However, one issue that keeps popping up is
its lack of a specific error code to determine which of the steps that
it performs failed. Furthermore, while the function gives an example and
suggests what error code to return on failure, a wide variety of error
codes are used throughout the tree.
In an attempt to fix these problems, this patch adds a new function that
drivers can transition to. The devm_ioremap_resource() returns a pointer
to the remapped I/O memory on success or an ERR_PTR() encoded error code
on failure. Callers can check for failure using IS_ERR() and determine
its cause by extracting the error code using PTR_ERR().
devm_request_and_ioremap() is implemented as a wrapper around the new
API and return NULL on failure as before. This ensures that backwards
compatibility is maintained until all users have been converted to the
new API, at which point the old devm_request_and_ioremap() function
should be removed.
A semantic patch is included which can be used to convert from the old
devm_request_and_ioremap() API to the new devm_ioremap_resource() API.
Some non-trivial cases may require manual intervention, though.
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map
them onto including export.h -- or if the file isn't even
using those, then just delete the include. Fix up any implicit
include dependencies that were being masked by module.h along
the way.
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci: (80 commits)
x86/PCI: Expand the x86_msi_ops to have a restore MSIs.
PCI: Increase resource array mask bit size in pcim_iomap_regions()
PCI: DEVICE_COUNT_RESOURCE should be equal to PCI_NUM_RESOURCES
PCI: pci_ids: add device ids for STA2X11 device (aka ConneXT)
PNP: work around Dell 1536/1546 BIOS MMCONFIG bug that breaks USB
x86/PCI: amd: factor out MMCONFIG discovery
PCI: Enable ATS at the device state restore
PCI: msi: fix imbalanced refcount of msi irq sysfs objects
PCI: kconfig: English typo in pci/pcie/Kconfig
PCI/PM/Runtime: make PCI traces quieter
PCI: remove pci_create_bus()
xtensa/PCI: convert to pci_scan_root_bus() for correct root bus resources
x86/PCI: convert to pci_create_root_bus() and pci_scan_root_bus()
x86/PCI: use pci_scan_bus() instead of pci_scan_bus_parented()
x86/PCI: read Broadcom CNB20LE host bridge info before PCI scan
sparc32, leon/PCI: convert to pci_scan_root_bus() for correct root bus resources
sparc/PCI: convert to pci_create_root_bus()
sh/PCI: convert to pci_scan_root_bus() for correct root bus resources
powerpc/PCI: convert to pci_create_root_bus()
powerpc/PCI: split PHB part out of pcibios_map_io_space()
Fix up conflicts in drivers/pci/msi.c and include/linux/pci_regs.h due
to the same patches being applied in other branches.
DEVICE_COUNT_RESOURCE will be bigger than 16 when SRIOV supported is enabled.
Let them pass with int just like pci_enable_resources().
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Almost every platform_driver does the three steps get_resource,
request_mem_region, ioremap. This does not only lead to a lot of code
duplication, but also a huge number of similar error strings and
inconsistent error codes on failure. So, introduce a helper function
which simplifies remapping a resource and make it hard to do something
wrong and add documentation for it.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
While working on devres, I found those make navigating the code a tad
easier.
devres uses the pointer value as key after it's freed, which is safe but
triggers spurious use-after-free warnings on some static analysis tools.
Rearrange code to avoid such warnings.
Signed-off-by: Maxin B. John <maxin.john@gmail.com>
Reviewed-by: Rolf Eike Beer <eike-kernel@sf-tec.de>
'Unamp' should be 'Unmap'.
Signed-off-by: Kulikov Vasiliy <segooon@gmail.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
We provide an ioremap_flags, so this provides a corresponding
devm_ioremap_prot. The slight name difference is at Ben
Herrenschmidt's request as he plans on changing ioremap_flags to
ioremap_prot in the future.
Signed-off-by: Emil Medve <Emilian.Medve@Freescale.com>
Acked-by: Tejun Heo <htejun@gmail.com>
Use a resource_size_t instead of unsigned long since some arch's are
capable of having ioremap deal with addresses greater than the size of a
unsigned long.
Cc: Tejun Heo <htejun@gmail.com>
Cc: Jeff Garzik <jgarzik@pobox.com>
Some drivers need to reserve all PCI BARs to prevent other drivers
misusing unoccupied BARs. pcim_iomap_regions_request_all() requests
all BARs and iomap specified BARs.
Signed-off-by: Tejun Heo <htejun@gmail.com>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Jeff Garzik <jeff@garzik.org>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Implement pcim_iounmap_regions() - the opposite of
pcim_iomap_regions().
Signed-off-by: Tejun heo <htejun@gmail.com>
It appears that the pcim_iomap_regions() function doesn't get the error
handling right. It BUGs early at boot with a backtrace along the lines of:
ahci_init
pci_register_driver
driver_register
ahci_init_one
pcim_iomap_region
pcim_iounmap
The following patch allows me to boot. Only the if(mask..) continue;
part fixes the problem actually, the gotos where changed so that we
don't try to unmap something we couldn't map anyway.
Signed-off-by: Frederik Deweerdt <frederik.deweerdt@gmail.com>
* Split the implementation-agnostic stuff in separate files.
* Make sure that targets using non-default request_irq() pull
kernel/irq/devres.o
* Introduce new symbols (HAS_IOPORT and HAS_IOMEM) defaulting to positive;
allow architectures to turn them off (we needed these symbols anyway for
dependencies of quite a few drivers).
* protect the ioport-related parts of lib/devres.o with CONFIG_HAS_IOPORT.
