path: root/lib/dynamic_debug.c
2012-05-07Revert "dynamic_debug: remove unneeded includes"Greg Kroah-Hartman
This reverts commit 04db6e5fddca55186b6a74339a62c800150648bc. Odds are, we really don't want to revert all of these, and need to be more careful in the future to make sure we don't break the build of other arches. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-04dynamic_debug: remove unneeded includesJim Cromie
These arent currently needed, so drop them. Some will probably get re-added when static-branches are added, but include loops prevent that at present. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-30dynamic_debug: init with early_initcall, not arch_initcallJim Cromie
1- Call dynamic_debug_init() from early_initcall, not arch_initcall. 2- Call dynamic_debug_init_debugfs() from fs_initcall, not module_init. RFC: This works for me on a 64 bit desktop and a i586 SBC, but is untested on other arches. I presume there is or was a reason original code used arch_initcall, maybe the constraints have changed. This makes facility available as soon as possible. 2nd change has a downside when dynamic_debug.verbose=1; all the vpr_info()s called in the proc-fs code are activated, causing voluminous output from dmesg. TBD: Im unsure of this explanation, but the output is there. This could be fixed by changing those callsites to v2pr_info(if verbose > 1). 1st change is still not early enough to enable pr_debugs in kernel/params, so parsing of boot-args isnt logged. The reparse of those args is however visible after params.dyndbg="+p" is processed. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-30dynamic_debug: add modname arg to exec_query callchainJim Cromie
Pass module name into ddebug_exec_queries(), ddebug_exec_query(), and ddebug_parse_query() as separate parameter. In ddebug_parse_query(), the module name is added into the query struct before the query-string is parsed. This allows the query-string to be shorter: instead of: $modname.dyndbg="module $modname +fp" do this: $modname.dyndbg="+fp" Omitting "module $modname" from the query string is actually required for $modname.dyndbg rules; the set-only-once check added in a previous patch will throw an error if its added again. ddebug_query="..." has no $modname associated with it, so the query string may include it. This also fixes redundant "module $modname" otherwise needed to handle multiple queries per string: $modname.dyndbg="func foo +fp; func bar +fp" Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-30dynamic_debug: print ram usage by ddebug tables if verboseJim Cromie
Print ram usage of dynamic-debug tables and verbose section so user knows cost of enabling CONFIG_DYNAMIC_DEBUG. This only counts the size of the _ddebug tables for builtins and the __verbose section that they refer to, not those used in loadable modules. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-30dynamic_debug: simplify dynamic_debug_init error exitJim Cromie
We dont want errors while parsing ddebug_query to unload ddebug tables, so set success after tables are loaded, and return 0 after query parsing is done. Simplify error handling code since its no longer used for success, and change goto label to out_err to clarify this. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-30dynamic_debug: combine parse_args callbacks togetherJim Cromie
Refactor ddebug_dyndbg_boot_param_cb and ddebug_dyndbg_module_param_cb into a common helper function, and call it from both. The handling of foo.dyndbg is unneeded by the latter, but harmless. The 2 callers differ only by pr_info and the return code they pass to the helper for when an unknown param is handled. I could slightly reduce dmesg clutter by putting the vpr_info in the common helper, after the return on_err, but that loses __func__ context, is overly silent on module_cb unknown param errors, and the clutter is only when dynamic_debug.verbose=1 anyway. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-30dynamic_debug: deprecate ddebug_query, suggest dyndbg insteadJim Cromie
With ddebug_dyndbg_boot_params_cb() handling bare dyndbg params, we dont need ddebug_query param anymore. Add a warning when processing ddebug_query= param that it is deprecated, and to change it to dyndbg= Add a deprecation notice for v3.8 to feature-removal-schedule.txt, and add a suggested deprecation period of 3 releases to the header. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-30dynamic_debug: make dynamic-debug work for module initializationJim Cromie
This introduces a fake module param $module.dyndbg. Its based upon Thomas Renninger's $module.ddebug boot-time debugging patch from https://lkml.org/lkml/2010/9/15/397 The 'fake' module parameter is provided for all modules, whether or not they need it. It is not explicitly added to each module, but is implemented in callbacks invoked from parse_args. For builtin modules, dynamic_debug_init() now directly calls parse_args(..., &ddebug_dyndbg_boot_params_cb), to process the params undeclared in the modules, just after the ddebug tables are processed. While its slightly weird to reprocess the boot params, parse_args() is already called repeatedly by do_initcall_levels(). More importantly, the dyndbg queries (given in ddebug_query or dyndbg params) cannot be activated until after the ddebug tables are ready, and reusing parse_args is cleaner than doing an ad-hoc parse. This reparse would break options like inc_verbosity, but they probably should be params, like verbosity=3. ddebug_dyndbg_boot_params_cb() handles both bare dyndbg (aka: ddebug_query) and module-prefixed dyndbg params, and ignores all other parameters. For example, the following will enable pr_debug()s in 4 builtin modules, in the order given: dyndbg="module params +p; module aio +p" module.dyndbg=+p pci.dyndbg For loadable modules, parse_args() in load_module() calls ddebug_dyndbg_module_params_cb(). This handles bare dyndbg params as passed from modprobe, and errors on other unknown params. Note that modprobe reads /proc/cmdline, so "modprobe foo" grabs all foo.params, strips the "foo.", and passes these to the kernel. ddebug_dyndbg_module_params_cb() is again called for the unknown params; it handles dyndbg, and errors on others. The "doing" arg added previously contains the module name. For non CONFIG_DYNAMIC_DEBUG builds, the stub function accepts and ignores $module.dyndbg params, other unknowns get -ENOENT. If no param value is given (as in pci.dyndbg example above), "+p" is assumed, which enables all pr_debug callsites in the module. The dyndbg fake parameter is not shown in /sys/module/*/parameters, thus it does not use any resources. Changes to it are made via the control file. Also change pr_info in ddebug_exec_queries to vpr_info, no need to see it all the time. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> CC: Thomas Renninger <trenn@suse.de> CC: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-30dynamic_debug: replace if (verbose) pr_info with macro vpr_infoJim Cromie
Use vpr_info to declutter code, reduce indenting, and change one additional pr_info call in ddebug_exec_queries. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-24dynamic_debug: process multiple debug-queries on a lineJim Cromie
Insert ddebug_exec_queries() in place of ddebug_exec_query(). It splits the query string on [;\n], and calls ddebug_exec_query() on each. All queries are processed independent of errors, allowing a query to fail, for example when a module is not installed. Empty lines and comments are skipped. Errors are counted, and the last error seen (negative) or the number of callsites found (0 or positive) is returned. Return code checks are altered accordingly. With this, multiple queries can be given in ddebug_query, allowing more selective enabling of callsites. As a side effect, a set of commands can be batched in: cat cmd-file > $DBGMT/dynamic_debug/control We dont want a ddebug_query syntax error to kill the dynamic debug facility, so dynamic_debug_init() zeros ddebug_exec_queries()'s return code after logging the appropriate message, so that ddebug tables are preserved and $DBGMT/dynamic_debug/control file is created. This would be appropriate even without accepting multiple queries. This patch also alters ddebug_change() to return number of callsites matched (which typically is the same as number of callsites changed). ddebug_exec_query() also returns the number found, or a negative value if theres a parse error on the query. Splitting on [;\n] prevents their use in format-specs, but selecting callsites on punctuation is brittle anyway, meaningful and selective substrings are more typical. Note: splitting queries on ';' before handling trailing #comments means that a ';' also terminates a comment, and text after the ';' is treated as another query. This trailing query will almost certainly result in a parse error and thus have no effect other than the error message. The double corner case with unexpected results is: ddebug_query="func foo +p # enable foo ; +p" Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24dynamic_debug: factor vpr_info_dq out of ddebug_parse_queryJim Cromie
Factor pr_info(query) out of ddebug_parse_query, into vpr_info_dq(), for reuse later. Also change the printed labels: file, func to agree with the query-spec keywords accepted in the control file. Pass "" when string is null, to avoid "(null)" output from sprintf. For format print, use precision to skip last char, assuming its '\n', no great harm if not, its a debug msg. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24dynamic_debug: add trim_prefix() to provide source-root relative pathsJim Cromie
trim_prefix(path) skips past the absolute source path root, and returns the pointer to the relative path from there. It is used to shorten the displayed path in $DBGMT/dynamic_debug/control via ddebug_proc_show(), and in ddebug_change() to allow relative filenames to be used in applied queries. For example: ~# echo file kernel/freezer.c +p > $DBGMT/dynamic_debug/control kernel/freezer.c:128 [freezer]cancel_freezing p " clean up: %s\012" trim_prefix(path) insures common prefix before trimming it, so out-of-tree module paths are shown as full absolute paths. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24dynamic_debug: enlarge command/query write bufferJim Cromie
Current query write buffer is 256 bytes, on stack. In comparison, the ddebug_query boot-arg is 1024. Allocate the buffer off heap, and enlarge it to 4096 bytes, big enough for ~100 queries (at 40 bytes each), and error out if not. This makes it play nicely with large query sets (to be added later). The buffer should be enough for most uses, and others should probably be split into subsets. [jbaron@redhat.com: changed USER_BUF_PAGE from 4095 -> 4096 ] Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24dynamic_debug: chop off comments in ddebug_tokenizeJim Cromie
If a token begins with #, the remainder of query string is a comment, so drop it. Doing it here avoids '#' in quoted strings. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24dynamic_debug: early return if _ddebug table is emptyJim Cromie
If _ddebug table is empty (in a CONFIG_DYNAMIC_DEBUG build this shouldn't happen), then warn (error?) and return early. This skips empty table scan and parsing of setup-string, including the pr_info call noting the parse. By inspection, copy return-code handling from 1st ddebug_add_module() callsite to 2nd. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24dynamic_debug: tighten up error checking on debug queriesJim Cromie
Issue error when a match-spec is given multiple times in a rule. Previous code kept last one, but was silent about it. Docs imply only one is allowed by saying match-specs are ANDed together, given that module M cannot match both A and B. Also error when last_line < 1st_line. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24dynamic_debug: describe_flags with '=[pmflt_]*'Jim Cromie
Change describe_flags() to emit '=[pmflt_]+' for current callsite flags, or just '=_' when they're disabled. Having '=' in output allows a more selective grep expression; in contrast '-' may appear in filenames, line-ranges, and format-strings. '=' also has better mnemonics, saying; "the current setting is equal to <flags>". This allows grep "=_" <dbgfs>/dynamic_debug/control to see disabled callsites while avoiding the many occurrences of " = " seen in format strings. Enlarge flagsbufs to handle additional flag char, and alter ddebug_parse_flags() to allow flags=0, so that user can turn off all debug flags via: ~# echo =_ > <dbgfs>/dynamic_debug/control Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24dynamic_debug: drop explicit !=NULL checksJim Cromie
Convert 'if (x !=NULL)' checks into 'if (x)'. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24dynamic_debug: pr_err() call should not depend upon verbosityJim Cromie
Issue keyword/parsing errors even w/o verbose set; uncover otherwize mysterious non-functionality. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24dynamic_debug: replace strcpy with strlcpy, in ddebug_setup_query()Jim Cromie
Replace strcpy with strlcpy, and add define for the size constant. [jbaron@redhat.com: Use DDEBUG_STRING_SIZE for overflow check] Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24dynamic_debug: change verbosity at runtimeJim Cromie
Allow changing dynamic_debug verbosity at run-time, to ease debugging of ddebug queries as you add them, improving usability. at boot time: dynamic_debug.verbose=1 at runtime: root@voyage:~# echo 1 > /sys/module/dynamic_debug/parameters/verbose Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24dynamic_debug: drop enabled field from struct _ddebug, use _DPRINTK_FLAGS_PRINTJim Cromie
Currently any enabled dynamic-debug flag on a pr_debug callsite will enable printing, even if _DPRINTK_FLAGS_PRINT is off. Checking print flag directly allows "-p" to disable callsites without fussing with other flags, so the following disables everything, without altering flags user may have set: echo -p > $DBGFS/dynamic_debug/control Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24dynamic_debug: fix whitespace complaints from scripts/cleanfileJim Cromie
Style cleanups. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-25Merge branch 'driver-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core * 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (38 commits) mm: memory hotplug: Check if pages are correctly reserved on a per-section basis Revert "memory hotplug: Correct page reservation checking" Update email address for stable patch submission dynamic_debug: fix undefined reference to `__netdev_printk' dynamic_debug: use a single printk() to emit messages dynamic_debug: remove num_enabled accounting dynamic_debug: consolidate repetitive struct _ddebug descriptor definitions uio: Support physical addresses >32 bits on 32-bit systems sysfs: add unsigned long cast to prevent compile warning drivers: base: print rejected matches with DEBUG_DRIVER memory hotplug: Correct page reservation checking memory hotplug: Refuse to add unaligned memory regions remove the messy code file Documentation/zh_CN/SubmitChecklist ARM: mxc: convert device creation to use platform_device_register_full new helper to create platform devices with dma mask docs/driver-model: Update device class docs docs/driver-model: Document device.groups kobj_uevent: Ignore if some listeners cannot handle message dynamic_debug: make netif_dbg() call __netdev_printk() dynamic_debug: make netdev_dbg() call __netdev_printk() ...
2011-10-18dynamic_debug: fix undefined reference to `__netdev_printk'Jason Baron
Dynamic debug recently added support for netdev_printk. It uses __netdev_printk() to support this functionality. However, when CONFIG_NET is not set, we get the following error: lib/built-in.o: In function `__dynamic_netdev_dbg': (.text+0x9fda): undefined reference to `__netdev_printk' Fix this by making the call to netdev_printk() contingent upon CONFIG_NET. We could have fixed this by defining netdev_printk() to a 'no-op' in the !CONFIG_NET case. However, this is not consistent with how the networking layer uses netdev_printk. For example, CONFIG_NET is not set, netdev_printk() does not have a 'no-op' definition defined. Signed-off-by: Jason Baron <jbaron@redhat.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-18dynamic_debug: use a single printk() to emit messagesJason Baron
We were using KERN_CONT to combine messages with their prefix. However, KERN_CONT is not smp safe, in the sense that it can interleave messages. This interleaving can result in printks coming out at the wrong loglevel. With the high frequency of printks that dynamic debug can produce this is not desirable. So make dynamic_emit_prefix() fill a char buf[64] instead of doing a printk directly. If we enable printing out of function, module, line, or pid info, they are placed in this 64 byte buffer. In my testing 64 bytes was enough size to fulfill all requests. Even if it's not, we can match up the printk itself to see where it's from, so to me this is no big deal. [akpm@linux-foundation.org: convert dangerous macro to C] Signed-off-by: Jason Baron <jbaron@redhat.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-18dynamic_debug: remove num_enabled accountingJason Baron
The num_enabled accounting isn't actually used anywhere - remove them. Signed-off-by: Jason Baron <jbaron@redhat.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-09-15Remove unneeded version.h include from lib/Jesper Juhl
This patch removes an unneeded include of linux/version.h from lib/dynamic_debug.c - identified by 'make versioncheck'. This is the only file in lib/ with this issue. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-08-22dynamic_debug: make netdev_dbg() call __netdev_printk()Jason Baron
Previously, if dynamic debug was enabled netdev_dbg() was using dynamic_dev_dbg() to print out the underlying msg. Fix this by making sure netdev_dbg() uses __netdev_printk(). Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-22dynamic_debug: Convert printks to pr_<level>Joe Perches
Add pr_fmt(fmt) with __func__. Converts "ddebug:" prefix to "dynamic_debug:". Most likely the if (verbose) outputs could also be converted from pr_info to pr_debug. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-22dynamic_debug: Remove uses of KERN_CONT in dynamic_emit_prefixJoe Perches
Multiple printks with KERN_CONT can be interleaved by other printks. Reduce the likelihood of that interleaving by consolidating multiple calls to printk. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-22dynamic_debug: Consolidate prefix output to single routineJoe Perches
Adding dynamic_dev_dbg duplicated prefix output. Consolidate that output to a single routine. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-22dynamic_debug: Add __dynamic_dev_dbgJoe Perches
Unlike dynamic_pr_debug, dynamic uses of dev_dbg can not currently add task_pid/KBUILD_MODNAME/__func__/__LINE__ to selected debug output. Add a new function similar to dynamic_pr_debug to optionally emit these prefixes. Cc: Aloisio Almeida <aloisio.almeida@openbossa.org> Noticed-by: Aloisio Almeida <aloisio.almeida@openbossa.org> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-03dynamic_debug: add #include <linux/sched.h>Greg Kroah-Hartman
This fixes a build breakage caused by 8ba6ebf583f12da32036fc0f003ab4043e54692e "Dynamic debug: Add more flags" Cc: Bart Van Assche <bvanassche@acm.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-03Dynamic debug: Add more flagsBart Van Assche
Add flags that allow the user to specify via debugfs whether or not the module name, function name, line number and/or thread ID have to be included in the printed message. Signed-off-by: Bart Van Assche <bvanassche@acm.org> Cc: Greg Banks <gnb@fmeh.org> Cc: Konrad Rzeszutek Wilk <konrad@darnok.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-07dynamic debug: Fix build issue with older gccJason Baron
On older gcc (3.3) dynamic debug fails to compile: include/net/inet_connection_sock.h: In function `inet_csk_reset_xmit_timer': include/net/inet_connection_sock.h:236: error: duplicate label declaration `do_printk' include/net/inet_connection_sock.h:219: error: this is a previous declaration include/net/inet_connection_sock.h:236: error: duplicate label declaration `out' include/net/inet_connection_sock.h:219: error: this is a previous declaration include/net/inet_connection_sock.h:236: error: duplicate label `do_printk' include/net/inet_connection_sock.h:236: error: duplicate label `out' Fix, by reverting the usage of JUMP_LABEL() in dynamic debug for now. Cc: <stable@kernel.org> Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Tested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-10-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (31 commits) driver core: Display error codes when class suspend fails Driver core: Add section count to memory_block struct Driver core: Add mutex for adding/removing memory blocks Driver core: Move find_memory_block routine hpilo: Despecificate driver from iLO generation driver core: Convert link_mem_sections to use find_memory_block_hinted. driver core: Introduce find_memory_block_hinted which utilizes kset_find_obj_hinted. kobject: Introduce kset_find_obj_hinted. driver core: fix build for CONFIG_BLOCK not enabled driver-core: base: change to new flag variable sysfs: only access bin file vm_ops with the active lock sysfs: Fail bin file mmap if vma close is implemented. FW_LOADER: fix kconfig dependency warning on HOTPLUG uio: Statically allocate uio_class and use class .dev_attrs. uio: Support 2^MINOR_BITS minors uio: Cleanup irq handling. uio: Don't clear driver data uio: Fix lack of locking in init_uio_class SYSFS: Allow boot time switching between deprecated and modern sysfs layout driver core: remove CONFIG_SYSFS_DEPRECATED_V2 but keep it for block devices ...
2010-10-22Dynamic Debug: Initialize dynamic debug earlier via arch_initcallThomas Renninger
Having the ddebug_query= boot parameter it makes sense to set up dynamic debug as soon as possible. I expect sysfs files cannot be set up via an arch_initcall, because this one is even before fs_initcall. Therefore I splitted the dynamic_debug_init function into an early one and a later one providing /sys/../dynamic_debug/control file. Possibly dynamic_debug can be initialized even earlier, not sure whether this still makes sense then. I picked up arch_initcall as it covers quite a lot already. Dynamic debug needs to allocate memory, therefore it's not easily possible to set it up even before the command line gets parsed. Therefore the boot param query string is stored in a temp string which is applied when dynamic debug gets set up. This has been tested with ddebug_query="file ec.c +p" and I could retrieve pr_debug() messages early at boot during ACPI setup: ACPI: EC: Look up EC in DSDT ACPI: EC: ---> status = 0x08 ACPI: EC: transaction start ACPI: EC: <--- command = 0x80 ACPI: EC: ~~~> interrupt ACPI: EC: ---> status = 0x08 ACPI: EC: <--- data = 0xa4 ... ACPI: Interpreter enabled ACPI: (supports S0 S3 S4 S5) ACPI: Using IOAPIC for interrupt routing ACPI: EC: ---> status = 0x00 ACPI: EC: transaction start ACPI: EC: <--- command = 0x80 Signed-off-by: Thomas Renninger <trenn@suse.de> Acked-by: jbaron@redhat.com Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> CC: linux-acpi@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22Dynamic Debug: Introduce ddebug_query= boot parameterThomas Renninger
Dynamic debug lacks the ability to enable debug messages at boot time. One could patch initramfs or service startup scripts to write to /sys/../dynamic_debug/control, but this sucks. This patch makes it possible to pass a query in the same format one can write to /sys/../dynamic_debug/control via boot param. When dynamic debug gets initialized, this query will automatically be applied. Signed-off-by: Thomas Renninger <trenn@suse.de> Acked-by: jbaron@redhat.com Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22Dynamic Debug: Split out query string parsing/setup from proc_writeThomas Renninger
The parsing and applying of dynamic debug strings is not only useful for /sys/../dynamic_debug/control write access, but can also be used for boot parameter parsing. The boot parameter is introduced in a follow up patch. Signed-off-by: Thomas Renninger <trenn@suse.de> Acked-by: jbaron@redhat.com Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-18jump_label: Use more consistent namingPeter Zijlstra
Now that there's still only a few users around, rename things to make them more consistent. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20101014203625.448565169@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-09-22jump label: Convert dynamic debug to use jump labelsJason Baron
Convert the 'dynamic debug' infrastructure to use jump labels. Signed-off-by: Jason Baron <jbaron@redhat.com> LKML-Reference: <b77627358cea3e27d7be4386f45f66219afb8452.1284733808.git.jbaron@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-07-04module: initialize module dynamic debug laterYehuda Sadeh
We should initialize the module dynamic debug datastructures only after determining that the module is not loaded yet. This fixes a bug that introduced in 2.6.35-rc2, where when a trying to load a module twice, we also load it's dynamic printing data twice which causes all sorts of nasty issues. Also handle the dynamic debug cleanup later on failure. Signed-off-by: Yehuda Sadeh <yehuda@hq.newdream.net> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (removed a #ifdef) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25dynamic_debug: small cleanup in ddebug_proc_write()Dan Carpenter
This doesn't change behavior at all. In the original code, if nwords was zero then ddebug_parse_query() would return -EINVAL, now we just do it earlier. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-15tree-wide: convert open calls to remove spaces to skip_spaces() lib functionAndré Goddard Rosa
Makes use of skip_spaces() defined in lib/string.c for removing leading spaces from strings all over the tree. It decreases lib.a code size by 47 bytes and reuses the function tree-wide: text data bss dec hex filename 64688 584 592 65864 10148 (TOTALS-BEFORE) 64641 584 592 65817 10119 (TOTALS-AFTER) Also, while at it, if we see (*str && isspace(*str)), we can be sure to remove the first condition (*str) as the second one (isspace(*str)) also evaluates to 0 whenever *str == 0, making it redundant. In other words, "a char equals zero is never a space". Julia Lawall tried the semantic patch (http://coccinelle.lip6.fr) below, and found occurrences of this pattern on 3 more files: drivers/leds/led-class.c drivers/leds/ledtrig-timer.c drivers/video/output.c @@ expression str; @@ ( // ignore skip_spaces cases while (*str && isspace(*str)) { \(str++;\|++str;\) } | - *str && isspace(*str) ) Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Cc: Julia Lawall <julia@diku.dk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Neil Brown <neilb@suse.de> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: David Howells <dhowells@redhat.com> Cc: <linux-ext4@vger.kernel.org> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: Patrick McHardy <kaber@trash.net> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-28Dynamic debug: fix typo: -/->Roel Kluin
The member was intended, not the local variable. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Greg Banks <gnb@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24Dynamic debug: allow simple quoting of wordsGreg Banks
Allow simple quoting of words in the dynamic debug control language. This allows more natural specification when using the control language to match against printk formats, e.g #echo -n 'format "Setting node for non-present cpu" +p' > /mnt/debugfs/dynamic_debug/control instead of #echo -n 'format Setting\040node\040for\040non-present\040cpu +p' > /mnt/debugfs/dynamic_debug/control Adjust the dynamic debug documention to describe that and provide a new example. Adjust the existing examples in the documentation to reflect the current whitespace escaping behaviour when reading the control file. Fix some minor documentation trailing whitespace. Signed-off-by: Greg Banks <gnb@melbourne.sgi.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24dynamic debug: combine dprintk and dynamic printkJason Baron
This patch combines Greg Bank's dprintk() work with the existing dynamic printk patchset, we are now calling it 'dynamic debug'. The new feature of this patchset is a richer /debugfs control file interface, (an example output from my system is at the bottom), which allows fined grained control over the the debug output. The output can be controlled by function, file, module, format string, and line number. for example, enabled all debug messages in module 'nf_conntrack': echo -n 'module nf_conntrack +p' > /mnt/debugfs/dynamic_debug/control to disable them: echo -n 'module nf_conntrack -p' > /mnt/debugfs/dynamic_debug/control A further explanation can be found in the documentation patch. Signed-off-by: Greg Banks <gnb@sgi.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
