path: root/lib/fault-inject.c
2011-10-26fault-inject: export setup_fault_attr()Per Forlin
mmc_core module needs to use setup_fault_attr() in order to set fault injection attributes during module load time. Signed-off-by: Per Forlin <per.forlin@linaro.org> Reviewed-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-10-26fault-inject: export fault injection functionsPer Forlin
Export symbols should_fail() and fault_create_debugfs_attr() in order to let modules utilize the fault injection framework. Signed-off-by: Per Forlin <per.forlin@linaro.org> Acked-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-08-03fault-injection: add ability to export fault_attr in arbitrary directoryAkinobu Mita
init_fault_attr_dentries() is used to export fault_attr via debugfs. But it can only export it in debugfs root directory. Per Forlin is working on mmc_fail_request which adds support to inject data errors after a completed host transfer in MMC subsystem. The fault_attr for mmc_fail_request should be defined per mmc host and export it in debugfs directory per mmc host like /sys/kernel/debug/mmc0/mmc_fail_request. init_fault_attr_dentries() doesn't help for mmc_fail_request. So this introduces fault_create_debugfs_attr() which is able to create a directory in the arbitrary directory and replace init_fault_attr_dentries(). [akpm@linux-foundation.org: extraneous semicolon, per Randy] Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Tested-by: Per Forlin <per.forlin@linaro.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26fault-injection: use debugfs_remove_recursiveAkinobu Mita
Use debugfs_remove_recursive() to simplify initialization and deinitialization of fault injection debugfs files. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26fault-injection: cleanup simple attribute of stacktrace_depthAkinobu Mita
Minor cosmetic changes for simple attribute of stacktrace_depth: - use min_t() - reduce #ifdef by moving a function - do not use partly capitalized function name Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26fault-injection: do not include unneeded headerAkinobu Mita
No need to include linux/kallsyms.h. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-01-06Remove remaining unwinder codeAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Gabor Gombas <gombasg@sztaki.hu> Cc: Jan Beulich <jbeulich@novell.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu>, Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08libfs: allow error return from simple attributesChristoph Hellwig
Sometimes simple attributes might need to return an error, e.g. for acquiring a mutex interruptibly. In fact we have that situation in spufs already which is the original user of the simple attributes. This patch merged the temporarily forked attributes in spufs back into the main ones and allows to return errors. [akpm@linux-foundation.org: build fix] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: <stefano.brivio@polimi.it> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Greg KH <greg@kroah.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-24fault_inject: silence a warningStephen Rothwell
lib/fault-inject.c:168: warning: 'debugfs_create_ul_MAX_STACK_TRACE_DEPTH' defined but not used Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08simplify the stacktrace codeChristoph Hellwig
Simplify the stacktrace code: - remove the unused task argument to save_stack_trace, it's always current - remove the all_contexts flag, it's alwasy 0 Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Andi Kleen <ak@suse.de> Cc: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-20[PATCH] fault injection: split up stacktrace filter Kconfig optionAkinobu Mita
There is no prompt for CONFIG_STACKTRACE, so FAULT_INJECTION cannot be selected without LOCKDEP enabled. (found by Paolo 'Blaisorblade' Giarrusso) In order to fix such broken Kconfig dependency, this patch splits up the stacktrace filter support for fault injection by new Kconfig option, which enables to use fault injection on the architecture which doesn't have general stacktrace support. Cc: "Paolo 'Blaisorblade' Giarrusso" <blaisorblade@yahoo.it> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-15Remove stack unwinder for nowLinus Torvalds
It has caused more problems than it ever really solved, and is apparently not getting cleaned up and fixed. We can put it back when it's stable and isn't likely to make warning or bug events worse. In the meantime, enable frame pointers for more readable stack traces. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] fault-injection: optimize and simplify should_fail()Don Mullis
Trivial optimization and simplification of should_fail(). Do cheaper disqualification tests first (performance gain not quantified). Simplify logic; eliminate goto. Signed-off-by: Don Mullis <dwm@meer.net> Cc: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] fault-injection: Clamp debugfs stacktrace-depth to MAX_STACK_TRACE_DEPTHDon Mullis
Clamp /debug/fail*/stacktrace-depth to MAX_STACK_TRACE_DEPTH. Ensures that a read of /debug/fail*/stacktrace-depth always returns a truthful answer. Signed-off-by: Don Mullis <dwm@meer.net> Cc: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] fault-injection: Use bool-true-false throughoutDon Mullis
Use bool-true-false throughout. Signed-off-by: Don Mullis <dwm@meer.net> Cc: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] fault injection: stacktrace filteringAkinobu Mita
This patch provides stacktrace filtering feature. The stacktrace filter allows failing only for the caller you are interested in. For example someone may want to inject kmalloc() failures into only e100 module. they want to inject not only direct kmalloc() call, but also indirect allocation, too. - e100_poll --> netif_receive_skb --> packet_rcv_spkt --> skb_clone --> kmem_cache_alloc This patch enables to detect function calls like this by stacktrace and inject failures. The script Documentaion/fault-injection/failmodule.sh helps it. The range of text section of loaded e100 is expected to be [/sys/module/e100/sections/.text, /sys/module/e100/sections/.exit.text) So failmodule.sh stores these values into /debug/failslab/address-start and /debug/failslab/address-end. The maximum stacktrace depth is specified by /debug/failslab/stacktrace-depth. Please see the example that demonstrates how to inject slab allocation failures only for a specific module in Documentation/fault-injection/fault-injection.txt [dwm@meer.net: reject failure if any caller lies within specified range] Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Don Mullis <dwm@meer.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] fault injection: process filtering for fault-injection capabilitiesAkinobu Mita
This patch provides process filtering feature. The process filter allows failing only permitted processes by /proc/<pid>/make-it-fail Please see the example that demostrates how to inject slab allocation failures into module init/cleanup code in Documentation/fault-injection/fault-injection.txt Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] fault-injection capabilities infrastructureAkinobu Mita
This patch provides base functions implement to fault-injection capabilities. - The function should_fail() is taken from failmalloc-1.0 (http://www.nongnu.org/failmalloc/) [akpm@osdl.org: cleanups, comments, add __init] Cc: <okuji@enbug.org> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Don Mullis <dwm@meer.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
