path: root/lib/gen_crc32table.c
2012-10-06sections: fix const sections for crc32 tableJoe Mario
Fix the const sections for the code generated by crc32 table. There's no ro version of the cacheline aligned section, so we cannot put in const data without a conflict Just don't make the crc tables const for now. [ak@linux.intel.com: some fixes and new description] [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Joe Mario <jmario@redhat.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23crc32: bolt on crc32cDarrick J. Wong
Reuse the existing crc32 code to stamp out a crc32c implementation. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Bob Pearson <rpearson@systemfabricworks.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23crc32: add slice-by-8 algorithm to existing codeBob Pearson
Add slicing-by-8 algorithm to the existing slicing-by-4 algorithm. This consists of: - extend largest BITS size from 32 to 64 - extend tables from tab[4][256] to up to tab[8][256] - Add code for inner loop. [djwong@us.ibm.com: Minor changelog tweaks] Signed-off-by: Bob Pearson <rpearson@systemfabricworks.com> Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23crc32: make CRC_*_BITS definition correspond to actual bit countsBob Pearson
crc32.c provides a choice of one of several algorithms for computing the LSB and LSB versions of the CRC32 checksum based on the parameters CRC_LE_BITS and CRC_BE_BITS. In the original version the values 1, 2, 4 and 8 respectively selected versions of the alrogithm that computed the crc 1, 2, 4 and 32 bits as a time. This patch series adds a new version that computes the CRC 64 bits at a time. To make things easier to understand the parameter has been reinterpreted to actually stand for the number of bits processed in each step of the algorithm so that the old value 8 has been replaced with the value 32. This also allows us to add in a widely used crc algorithm that computes the crc 8 bits at a time called the Sarwate algorithm. [djwong@us.ibm.com: Minor changelog tweaks] Signed-off-by: Bob Pearson <rpearson@systemfabricworks.com> Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23crc32: miscellaneous cleanupsBob Pearson
Misc cleanup of lib/crc32.c and related files. - remove unnecessary header files. - straighten out some convoluted ifdef's - rewrite some references to 2 dimensional arrays as 1 dimensional arrays to make them correct. I.e. replace tab[i] with tab[0][i]. - a few trivial whitespace changes - fix a warning in gen_crc32tables.c caused by a mismatch in the type of the pointer passed to output table. Since the table is only used at kernel compile time, it is simpler to make the table big enough to hold the largest column size used. One cannot make the column size smaller in output_table because it has to be used by both the le and be tables and they can have different column sizes. [djwong@us.ibm.com: Minor changelog tweaks] Signed-off-by: Bob Pearson <rpearson@systemfabricworks.com> Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25crc32: major optimizationJoakim Tjernlund
Precompute more crc32 values(0xcc00, 0xcc0000 and 0xcc000000) into tables. This increases the table size from 1KB to 4KB but the performance benfit makes it worth it: 28% faster on MPC8321, 266 MHz 2x faster on Core 2 Duo, 3.1GHz [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
