path: root/lib/halfmd4.c
2015-02-12lib/halfmd4.c: simplify includesRasmus Villemoes
We only need EXPORT_SYMBOL, so compiler.h and export.h suffice. This means linux/types.h is no longer implicitly included, so add an include of uapi/linux/types.h to linux/cryptohash.h for __u32. Other users of cryptohash.h cannot be affected, since they must already have been including uapi/linux/types.h in order for gcc not to complain about unknown types. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-07lib: reduce the use of module.h wherever possiblePaul Gortmaker
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map them onto including export.h -- or if the file isn't even using those, then just delete the include. Fix up any implicit include dependencies that were being masked by module.h along the way. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
