path: root/lib/hexdump.c
2010-05-25lib: introduce common method to convert hex digitsAndy Shevchenko
hex_to_bin() is a little method which converts hex digit to its actual value. There are plenty of places where such functionality is needed. [akpm@linux-foundation.org: use tolower(), saving 3 bytes, test the more common case first - it's quicker] [akpm@linux-foundation.org: relocate tolower to make it even faster! (Joe)] Signed-off-by: Andy Shevchenko <ext-andriy.shevchenko@nokia.com> Cc: Tilman Schmidt <tilman@imap.cc> Cc: Duncan Sands <duncan.sands@free.fr> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: "Richard Russon (FlatCap)" <ldm@flatcap.org> Cc: John W. Linville <linville@tuxdriver.com> Cc: Len Brown <lenb@kernel.org> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25lib/hexdump.c: reduce stack variable size and cleanupsJoe Perches
Reduce char linebuf[200] to the actual size required., which is 32 * 3 + 2 + 32 + 1, ie: linebuf[131]. Change examples to use bool true not int 1. Align multiline argument indentation to open parenthesis. Use temporary for ptr[j] so trigraph fits on single line. Convert printk ptr from %*p, (int)(2 * sizeof(void *)) to %p as %p uses the same calculation for size. Signed-off-by: Joe Perches <joe@perches.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16hexdump: remove the trailing spaceLi Zefan
For example: hex_dump_to_buffer("AB", 2, 16, 1, buf, 100, 0); pr_info("[%s]\n", buf); I'd expect the output to be "[41 42]", but actually it's "[41 42 ]" This patch also makes the required buf to be minimum. To print the hex format of "AB", a buf with size 6 should be sufficient, but hex_dump_to_buffer() required at least 8. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14lib: create common ascii hex arrayHarvey Harrison
Add a common hex array in hexdump.c so everyone can use it. Add a common hi/lo helper to avoid the shifting masking that is done to get the upper and lower nibbles of a byte value. Pull the pack_hex_byte helper from kgdb as it is opencoded many places in the tree that will be consolidated. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-29hexdump: don't print bytes with bit 7 setRandy Dunlap
As Herbert Xu pointed out, bytes (chars) with bit 7 (0x80) set are true with isprint() but they may not be isascii() but be Unicode instead, so don't try to print them in hex dumps. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-11hex_dump: add missing "const" qualifiersAlan Stern
Add missing "const" qualifiers to the print_hex_dump_bytes() library routines. (akpm: rumoured to fix some compile warning somewhere) Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-09hexdump: use const notationArtem Bityutskiy
Trivial fix: mark the buffer to hexdump as const so callers could avoid casting their const buffers when calling print_hex_dump(). The patch is really trivial and I suggest to consider it as a fix (it fixes GCC warnings) and push it to current tree. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-08hexdump: more output formattingRandy Dunlap
Add a prefix string parameter. Callers are responsible for any string length/alignment that they want to see in the output. I.e., callers should pad strings to achieve alignment if they want that. Add rowsize parameter. This is the number of raw data bytes to be printed per line. Must be 16 or 32. Add a groupsize parameter. This allows callers to dump values as 1-byte, 2-byte, 4-byte, or 8-byte numbers. Default is 1-byte numbers. If the total length is not an even multiple of groupsize, 1-byte numbers are printed. Add an "ascii" output parameter. This causes ASCII data output following the hex data output. Clean up some doc examples. Align the ASCII output on all lines that are produced by one call. Add a new interface, print_hex_dump_bytes(), that is a shortcut to print_hex_dump(), using default parameter values to print 16 bytes in byte-size chunks of hex + ASCII output, using printk level KERN_DEBUG. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11lib/hexdumpRandy Dunlap
Based on ace_dump_mem() from Grant Likely for the Xilinx SystemACE CompactFlash interface. Add print_hex_dump() & hex_dumper() to lib/hexdump.c and linux/kernel.h. This patch adds the functions print_hex_dump() & hex_dumper(). print_hex_dump() can be used to perform a hex + ASCII dump of data to syslog, in an easily viewable format, thus providing a common text hex dump format. hex_dumper() provides a dump-to-memory function. It converts one "line" of output (16 bytes of input) at a time. Example usages: print_hex_dump(KERN_DEBUG, DUMP_PREFIX_ADDRESS, frame->data, frame->len); hex_dumper(frame->data, frame->len, linebuf, sizeof(linebuf)); Example output using %DUMP_PREFIX_OFFSET: 0009ab42: 40414243 44454647 48494a4b 4c4d4e4f-@ABCDEFG HIJKLMNO Example output using %DUMP_PREFIX_ADDRESS: ffffffff88089af0: 70717273 74757677 78797a7b 7c7d7e7f-pqrstuvw xyz{|}~. [akpm@linux-foundation.org: cleanups, add export] Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
