path: root/lib/iomap.c
2019-01-22iomap: introduce io{read|write}64_{lo_hi|hi_lo}Logan Gunthorpe
In order to provide non-atomic functions for io{read|write}64 that will use readq and writeq when appropriate. We define a number of variants of these functions in the generic iomap that will do non-atomic operations on pio but atomic operations on mmio. These functions are only defined if readq and writeq are defined. If they are not, then the wrappers that always use non-atomic operations from include/linux/io-64-nonatomic*.h will be used. Signed-off-by: Logan Gunthorpe <logang@deltatee.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Suresh Warrier <warrier@linux.vnet.ibm.com> Cc: Nicholas Piggin <npiggin@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-01-22iomap: Use non-raw io functions for io{read|write}XXbeLogan Gunthorpe
Fix an asymmetry in the io{read|write}XXbe functions in that the big-endian variants make use of the raw io accessors while the little-endian variants use the regular accessors. Some architectures implement barriers to order against both spinlocks and DMA accesses and for these case, the big-endian variant of the API would not be protected. Thus, change the mmio_XXXXbe macros to use the appropriate swab() function wrapping the regular accessor. This is similar to what was done for PIO. When this code was originally written, barriers in the IO accessors were not common and the accessors simply wrapped the raw functions in a conversion to CPU endianness. Since then, barriers have been added in some architectures and are now missing in the big endian variant of the API. This also manages to silence a few sparse warnings that check for using the correct endian types which the original code did not annotate correctly. Signed-off-by: Logan Gunthorpe <logang@deltatee.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Kate Stewart <kstewart@linuxfoundation.org> Cc: Philippe Ombredanne <pombredanne@nexb.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Arnd Bergmann <arnd@arndb.de> Link: http://lkml.kernel.org/r/CAK8P3a25zQDxyaY3iVv+JmSSzs7F6ssGc+HdBkGs54ZfViX+Fg@mail.gmail.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-07Kconfig: rename HAS_IOPORT to HAS_IOPORT_MAPUwe Kleine-König
If the renamed symbol is defined lib/iomap.c implements ioport_map and ioport_unmap and currently (nearly) all platforms define the port accessor functions outb/inb and friend unconditionally. So HAS_IOPORT_MAP is the better name for this. Consequently NO_IOPORT is renamed to NO_IOPORT_MAP. The motivation for this change is to reintroduce a symbol HAS_IOPORT that signals if outb/int et al are available. I will address that at least one merge window later though to keep surprises to a minimum and catch new introductions of (HAS|NO)_IOPORT. The changes in this commit were done using: $ git grep -l -E '(NO|HAS)_IOPORT' | xargs perl -p -i -e 's/\b((?:CONFIG_)?(?:NO|HAS)_IOPORT)\b/$1_MAP/' Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-07lib: reduce the use of module.h wherever possiblePaul Gortmaker
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map them onto including export.h -- or if the file isn't even using those, then just delete the include. Fix up any implicit include dependencies that were being masked by module.h along the way. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-11-28lib: add GENERIC_PCI_IOMAPMichael S. Tsirkin
Many architectures want a generic pci_iomap but not the rest of iomap.c. Split that to a separate .c file and add a new config symbol. select automatically by GENERIC_IOMAP. Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2011-07-22iomap: make IOPORT/PCI mapping functions conditionalJonas Bonn
Use the CONFIG_HAS_IOPORT and CONFIG_PCI options to decide whether or not functions for mapping these areas are provided. Signed-off-by: Jonas Bonn <jonas@southpole.se> Acked-by: Arnd Bergmann <arnd@arndb.de>
2008-07-26Use WARN() in lib/Arjan van de Ven
Use WARN() instead of a printk+WARN_ON() pair; this way the message becomes part of the warning section for better reporting/collection. In addition, one of the if() clauses collapes into the WARN() entirely now. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29iomap: fix 64 bits resources on 32 bitsBenjamin Herrenschmidt
Almost all implementations of pci_iomap() in the kernel, including the generic lib/iomap.c one, copies the content of a struct resource into unsigned long's which will break on 32 bits platforms with 64 bits resources. This fixes all definitions of pci_iomap() to use resource_size_t. I also "fixed" the 64bits arch for consistency. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-24x86-32: Pass the full resource data to ioremap()Linus Torvalds
It appears that 64-bit PCI resources cannot possibly ever have worked on x86-32 even when the RESOURCES_64BIT config option was set, because any driver that tried to [pci_]ioremap() the resource would have been unable to do so because the high 32 bits would have been silently dropped on the floor by the ioremap() routines that only used "unsigned long". Change them to use "resource_size_t" instead, which properly encodes the whole 64-bit resource data if RESOURCES_64BIT is enabled. Acked-by: H. Peter Anvin <hpa@kernel.org> Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08lib: remove fastcall from lib/*Harvey Harrison
[akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17lib/iomap.c:bad_io_access(): print 0x hex prefixRene Herman
Be explicit about printing hex. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-22PCI: Document pci_iomap()Rolf Eike Beer
This useful interface is hardly mentioned anywhere in the in-tree documentation. Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de> Cc: Tejun Heo <htejun@gmail.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-04iomap: make the default iomap functions fail softerLinus Torvalds
We used to BUG_ON() for a badly mapped IO port, which is certainly correct, but actually made it harder to debug the case where the ATA drivers had incorrectly mapped a nonconnected ATA port. So make badly mapped ports trigger a WARN_ON(), and throw the IO away instead (and return all ones for reads). For things like broken driver initialization - which is the most likely cause anyway - that should mean that the machine comes up and is usable (at least that was the case for the ATA breakage that triggered this patch). It tends to be a whole lot easier to do a "dmesg" on a working machine than to try to capture logs off a dead one. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] sort the devres mess outAl Viro
* Split the implementation-agnostic stuff in separate files. * Make sure that targets using non-default request_irq() pull kernel/irq/devres.o * Introduce new symbols (HAS_IOPORT and HAS_IOMEM) defaulting to positive; allow architectures to turn them off (we needed these symbols anyway for dependencies of quite a few drivers). * protect the ioport-related parts of lib/devres.o with CONFIG_HAS_IOPORT. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-09devres: implement pcim_iomap_regions()Tejun Heo
Implement pcim_iomap_regions(). This function takes mask of BARs to request and iomap. No BAR should have length of zero. BARs are iomapped using pcim_iomap_table(). Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09devres: device resource managementTejun Heo
Implement device resource management, in short, devres. A device driver can allocate arbirary size of devres data which is associated with a release function. On driver detach, release function is invoked on the devres data, then, devres data is freed. devreses are typed by associated release functions. Some devreses are better represented by single instance of the type while others need multiple instances sharing the same release function. Both usages are supported. devreses can be grouped using devres group such that a device driver can easily release acquired resources halfway through initialization or selectively release resources (e.g. resources for port 1 out of 4 ports). This patch adds devres core including documentation and the following managed interfaces. * alloc/free : devm_kzalloc(), devm_kzfree() * IO region : devm_request_region(), devm_release_region() * IRQ : devm_request_irq(), devm_free_irq() * DMA : dmam_alloc_coherent(), dmam_free_coherent(), dmam_declare_coherent_memory(), dmam_pool_create(), dmam_pool_destroy() * PCI : pcim_enable_device(), pcim_pin_device(), pci_is_managed() * iomap : devm_ioport_map(), devm_ioport_unmap(), devm_ioremap(), devm_ioremap_nocache(), devm_iounmap(), pcim_iomap_table(), pcim_iomap(), pcim_iounmap() Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-04[PATCH] Arch provides generic iomap missing accessorsLinus Torvalds
Allow architectures to provide their own implementation of the big endian MMIO accessors and "repeat" MMIO accessors for use by the generic iomap. Signed-off-by: Linus Torvalds <torvalds@osdl.org> More-or-less-tested-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-04-16[PATCH] add Big Endian variants of ioread/iowriteJames Bottomley
In the new io infrastructure, all of our operators are expecting the underlying device to be little endian (because the PCI bus, their main consumer, is LE). However, there are a fair few devices and busses in the world that are actually Big Endian. There's even evidence that some of these BE bus and chip types are attached to LE systems. Thus, there's a need for a BE equivalent of our io{read,write}{16,32} operations. The attached patch adds this as io{read,write}{16,32}be. When it's in, I'll add the first consume (the 53c700 SCSI chip driver). Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
