path: root/lib/iomap_copy.c
2006-06-20[PATCH] add __iowrite64_copyBrice Goglin
Introduce __iowrite64_copy. It will be used by the Myri-10G Ethernet driver to post requests to the NIC. This driver will be submitted soon. __iowrite64_copy copies to I/O memory in units of 64 bits when possible (on 64 bit architectures). It reverts to __iowrite32_copy on 32 bit architectures. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-18[PATCH] iomap_copy fallout (m68k)Al Viro
added __raw_writel(), sanitized include order in iomap_copy.c Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-02-01[PATCH] Introduce __iowrite32_copyBryan O'Sullivan
This arch-independent routine copies data to a memory-mapped I/O region, using 32-bit accesses. The naming is double-underscored to make it clear that it does not guarantee write ordering, nor does it perform a memory barrier afterwards; the kernel doc also explicitly states this. This style of access is required by some devices. This change also introduces include/linux/io.h, at Andrew's suggestion. It only has one occupant at the moment, but is a logical destination for oft-replicated contents of include/asm-*/{io,iomap}.h to migrate to. Signed-off-by: Bryan O'Sullivan <bos@pathscale.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
