path: root/lib/ioremap.c
2012-03-07lib: reduce the use of module.h wherever possiblePaul Gortmaker
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map them onto including export.h -- or if the file isn't even using those, then just delete the include. Fix up any implicit include dependencies that were being masked by module.h along the way. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-01-12ACPI, APEI, Generic Hardware Error Source POLL/IRQ/NMI notification type supportHuang Ying
Generic Hardware Error Source provides a way to report platform hardware errors (such as that from chipset). It works in so called "Firmware First" mode, that is, hardware errors are reported to firmware firstly, then reported to Linux by firmware. This way, some non-standard hardware error registers or non-standard hardware link can be checked by firmware to produce more valuable hardware error information for Linux. This patch adds POLL/IRQ/NMI notification types support. Because the memory area used to transfer hardware error information from BIOS to Linux can be determined only in NMI, IRQ or timer handler, but general ioremap can not be used in atomic context, so a special version of atomic ioremap is implemented for that. Known issue: - Error information can not be printed for recoverable errors notified via NMI, because printk is not NMI-safe. Will fix this via delay printing to IRQ context via irq_work or make printk NMI-safe. v2: - adjust printk format per comments. Signed-off-by: Huang Ying <ying.huang@intel.com> Reviewed-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-07-09x86, ioremap: Fix incorrect physical address handling in PAE modeKenji Kaneshige
Current x86 ioremap() doesn't handle physical address higher than 32-bit properly in X86_32 PAE mode. When physical address higher than 32-bit is passed to ioremap(), higher 32-bits in physical address is cleared wrongly. Due to this bug, ioremap() can map wrong address to linear address space. In my case, 64-bit MMIO region was assigned to a PCI device (ioat device) on my system. Because of the ioremap()'s bug, wrong physical address (instead of MMIO region) was mapped to linear address space. Because of this, loading ioatdma driver caused unexpected behavior (kernel panic, kernel hangup, ...). Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> LKML-Reference: <4C1AE680.7090408@jp.fujitsu.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2007-10-17lib/ioremap.c should #include <linux/io.h>Adrian Bunk
Every file should include the headers containing the prototypes for its global functions (in this case ioremap_page_range()). Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-13[PATCH] uml problems with linux/io.hAl Viro
Remove useless includes of linux/io.h, don't even try to build iomap_copy on uml (it doesn't have readb() et.al., so...) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Generic ioremap_page_range: flush_cache_vmapHaavard Skinnemoen
The existing implementation of ioremap_page_range(), which was taken from i386, does this: flush_cache_all(); /* modify page tables */ flush_tlb_all(); I think this is a bit defensive, so this patch changes the generic implementation to do: /* modify page tables */ flush_cache_vmap(start, end); instead, which is similar to what vmalloc() does. This should still be correct because we never modify existing PTEs. According to James Bottomley: The problem the flush_tlb_all() is trying to solve is to avoid stale tlb entries in the ioremap area. We're just being conservative by flushing on both map and unmap. Technically what vmalloc/vfree does (only flush the tlb on unmap) is just fine because it means that the only tlb entries in the remap area must belong to in-use mappings. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Mikael Starvik <starvik@axis.com> Cc: Andi Kleen <ak@suse.de> Cc: <linux-m32r@ml.linux-m32r.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@parisc-linux.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Generic ioremap_page_range: implementationHaavard Skinnemoen
This patch adds a generic implementation of ioremap_page_range() in lib/ioremap.c based on the i386 implementation. It differs from the i386 version in the following ways: * The PTE flags are passed as a pgprot_t argument and must be determined up front by the arch-specific code. No additional PTE flags are added. * Uses set_pte_at() instead of set_pte() [bunk@stusta.de: warning fix] ]dhowells@redhat.com: nommu build fix] Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Mikael Starvik <starvik@axis.com> Cc: Andi Kleen <ak@suse.de> Cc: <linux-m32r@ml.linux-m32r.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@parisc-linux.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
