path: root/lib/kstrtox.c
2016-10-28lib: add "on"/"off" support to kstrtoboolKees Cook
commit a81a5a17d44b26521fb1199f8ccf27f4af337a67 upstream. Add support for "on" and "off" when converting to boolean. Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Amitkumar Karwar <akarwar@marvell.com> Cc: Andy Shevchenko <andy.shevchenko@gmail.com> Cc: Daniel Borkmann <daniel@iogearbox.net> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Joe Perches <joe@perches.com> Cc: Kalle Valo <kvalo@codeaurora.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Nishant Sarmukadam <nishants@marvell.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Steve French <sfrench@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28lib: move strtobool() to kstrtobool()Kees Cook
commit ef951599074ba4fad2d0efa0a977129b41e6d203 upstream. Create the kstrtobool_from_user() helper and move strtobool() logic into the new kstrtobool() (matching all the other kstrto* functions). Provides an inline wrapper for existing strtobool() callers. Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Joe Perches <joe@perches.com> Cc: Andy Shevchenko <andy.shevchenko@gmail.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Daniel Borkmann <daniel@iogearbox.net> Cc: Amitkumar Karwar <akarwar@marvell.com> Cc: Nishant Sarmukadam <nishants@marvell.com> Cc: Kalle Valo <kvalo@codeaurora.org> Cc: Steve French <sfrench@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-10kstrto*: accept "-0" for signed conversionAlexey Dobriyan
strtol(3) et al accept "-0", so should we. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: Jan Kara <jack@suse.cz> Cc: Joel Becker <jlbec@evilplan.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23lib/kstrtox.c: remove redundant cleanupFelipe Contreras
We can't reach the cleanup code unless the flag KSTRTOX_OVERFLOW is not set, so there's not no point in clearing a bit that we know is not set. Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Acked-by: Levente Kurusa <levex@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17kstrto*: add documentationEldad Zack
As Bruce Fields pointed out, kstrto* is currently lacking kerneldoc comments. This patch adds kerneldoc comments to common variants of kstrto*: kstrto(u)l, kstrto(u)ll and kstrto(u)int. Signed-off-by: Eldad Zack <eldad@fogrefinery.com> Cc: J. Bruce Fields <bfields@fieldses.org> Cc: Joe Perches <joe@perches.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Rob Landley <rob@landley.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-07lib: reduce the use of module.h wherever possiblePaul Gortmaker
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map them onto including export.h -- or if the file isn't even using those, then just delete the include. Fix up any implicit include dependencies that were being masked by module.h along the way. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-02-09Reduce the number of expensive division instructions done by _parse_integer()David Howells
_parse_integer() does one or two division instructions (which are slow) per digit parsed to perform the overflow check. Furthermore, these are particularly expensive examples of division instruction as the number of clock cycles required to complete them may go up with the position of the most significant set bit in the dividend: if (*res > div_u64(ULLONG_MAX - val, base)) which is as maximal as possible. Worse, on 32-bit arches, more than one of these division instructions may be required per digit. So, assuming we don't support a base of more than 16, skip the check if the top nibble of the result is not set at this point. Signed-off-by: David Howells <dhowells@redhat.com> [ Changed it to not dereference the pointer all the time - even if the compiler can and does optimize it away, the code just looks cleaner. And edited the top nybble test slightly to make the code generated on x86-64 better in the loop - test against a hoisted constant instead of shifting and testing the result ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31lib/kstrtox: common code between kstrto*() and simple_strto*() functionsAlexey Dobriyan
Currently termination logic (\0 or \n\0) is hardcoded in _kstrtoull(), avoid that for code reuse between kstrto*() and simple_strtoull(). Essentially, make them different only in termination logic. simple_strtoull() (and scanf(), BTW) ignores integer overflow, that's a bug we currently don't have guts to fix, making KSTRTOX_OVERFLOW hack necessary. Almost forgot: patch shrinks code size by about ~80 bytes on x86_64. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25lib: make _tolower() publicAndy Shevchenko
This function is required by *printf and kstrto* functions that are located in the different modules. This patch makes _tolower() public. However, it's good idea to not use the helper outside of mentioned functions. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25lib: add kstrto*_from_user()Alexey Dobriyan
There is quite a lot of code which does copy_from_user() + strict_strto*() or simple_strto*() combo in slightly different ways. Before doing conversions all over tree, let's get final API correct. Enter kstrtoull_from_user() and friends. Typical code which uses them looks very simple: TYPE val; int rv; rv = kstrtoTYPE_from_user(buf, count, 0, &val); if (rv < 0) return rv; [use val] return count; There is a tiny semantic difference from the plain kstrto*() API -- the latter allows any amount of leading zeroes, while the former copies data into buffer on stack and thus allows leading zeroes as long as it fits into buffer. This shouldn't be a problem for typical usecase "echo 42 > /proc/x". The point is to make reading one integer from userspace _very_ simple and very bug free. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-14kstrtox: simpler code in _kstrtoull()Alexey Dobriyan
2011-03-22kstrto*: converting strings to integers done (hopefully) rightAlexey Dobriyan
1. simple_strto*() do not contain overflow checks and crufty, libc way to indicate failure. 2. strict_strto*() also do not have overflow checks but the name and comments pretend they do. 3. Both families have only "long long" and "long" variants, but users want strtou8() 4. Both "simple" and "strict" prefixes are wrong: Simple doesn't exactly say what's so simple, strict should not exist because conversion should be strict by default. The solution is to use "k" prefix and add convertors for more types. Enter kstrtoull() kstrtoll() kstrtoul() kstrtol() kstrtouint() kstrtoint() kstrtou64() kstrtos64() kstrtou32() kstrtos32() kstrtou16() kstrtos16() kstrtou8() kstrtos8() Include runtime testsuite (somewhat incomplete) as well. strict_strto*() become deprecated, stubbed to kstrto*() and eventually will be removed altogether. Use kstrto*() in code today! Note: on some archs _kstrtoul() and _kstrtol() are left in tree, even if they'll be unused at runtime. This is temporarily solution, because I don't want to hardcode list of archs where these functions aren't needed. Current solution with sizeof() and __alignof__ at least always works. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
