path: root/lib/locking-selftest.c
2013-02-19lockdep: Selftest: convert spinlock to raw spinlockYong Zhang
To make the lockdep selftest working on RT we need to convert the spinlock tests to a raw spinlock. Otherwise we cannot run the irq context checks. For mainline this is just annotational as spinlocks are mapped to raw_spinlocks anyway. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Link: http://lkml.kernel.org/r/1334559716-18447-2-git-send-email-yong.zhang0@gmail.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-03-07lib: reduce the use of module.h wherever possiblePaul Gortmaker
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map them onto including export.h -- or if the file isn't even using those, then just delete the include. Fix up any implicit include dependencies that were being masked by module.h along the way. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-05-26rcu: Fix unpaired rcu_irq_enter() from locking selftestsFrederic Weisbecker
HARDIRQ_ENTER() maps to irq_enter() which calls rcu_irq_enter(). But HARDIRQ_EXIT() maps to __irq_exit() which doesn't call rcu_irq_exit(). So for every locking selftest that simulates hardirq disabled, we create an imbalance in the rcu extended quiescent state internal state. As a result, after the first missing rcu_irq_exit(), subsequent irqs won't exit dyntick-idle mode after leaving the interrupt handler. This means that RCU won't see the affected CPU as being in an extended quiescent state, resulting in long grace-period delays (as in grace periods extending for hours). To fix this, just use __irq_enter() to simulate the hardirq context. This is sufficient for the locking selftests as we don't need to exit any extended quiescent state or perform any check that irqs normally do when they wake up from idle. As a side effect, this patch makes it possible to restore "rcu: Decrease memory-barrier usage based on semi-formal proof", which eventually helped finding this bug. Reported-and-tested-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stable <stable@kernel.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2009-03-13locking: rename trace_softirq_[enter|exit] => lockdep_softirq_[enter|exit]Ingo Molnar
Impact: cleanup The naming clashes with upcoming softirq tracepoints, so rename the APIs to lockdep_*(). Requested-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-12-07[PATCH] lockdep: show more details about self-test failuresIngo Molnar
Make the locking self-test failures (of 'FAILURE' type) easier to debug by printing more information. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: allow read_lock() recursion of same classIngo Molnar
From: Ingo Molnar <mingo@elte.hu> lockdep so far only allowed read-recursion for the same lock instance. This is enough in the overwhelming majority of cases, but a hostap case triggered and reported by Miles Lane relies on same-class different-instance recursion. So we relax the restriction on read-lock recursion. (This change does not allow rwsem read-recursion, which is still forbidden.) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: coreIngo Molnar
Do 'make oldconfig' and accept all the defaults for new config options - reboot into the kernel and if everything goes well it should boot up fine and you should have /proc/lockdep and /proc/lockdep_stats files. Typically if the lock validator finds some problem it will print out voluminous debug output that begins with "BUG: ..." and which syslog output can be used by kernel developers to figure out the precise locking scenario. What does the lock validator do? It "observes" and maps all locking rules as they occur dynamically (as triggered by the kernel's natural use of spinlocks, rwlocks, mutexes and rwsems). Whenever the lock validator subsystem detects a new locking scenario, it validates this new rule against the existing set of rules. If this new rule is consistent with the existing set of rules then the new rule is added transparently and the kernel continues as normal. If the new rule could create a deadlock scenario then this condition is printed out. When determining validity of locking, all possible "deadlock scenarios" are considered: assuming arbitrary number of CPUs, arbitrary irq context and task context constellations, running arbitrary combinations of all the existing locking scenarios. In a typical system this means millions of separate scenarios. This is why we call it a "locking correctness" validator - for all rules that are observed the lock validator proves it with mathematical certainty that a deadlock could not occur (assuming that the lock validator implementation itself is correct and its internal data structures are not corrupted by some other kernel subsystem). [see more details and conditionals of this statement in include/linux/lockdep.h and Documentation/lockdep-design.txt] Furthermore, this "all possible scenarios" property of the validator also enables the finding of complex, highly unlikely multi-CPU multi-context races via single single-context rules, increasing the likelyhood of finding bugs drastically. In practical terms: the lock validator already found a bug in the upstream kernel that could only occur on systems with 3 or more CPUs, and which needed 3 very unlikely code sequences to occur at once on the 3 CPUs. That bug was found and reported on a single-CPU system (!). So in essence a race will be found "piecemail-wise", triggering all the necessary components for the race, without having to reproduce the race scenario itself! In its short existence the lock validator found and reported many bugs before they actually caused a real deadlock. To further increase the efficiency of the validator, the mapping is not per "lock instance", but per "lock-class". For example, all struct inode objects in the kernel have inode->inotify_mutex. If there are 10,000 inodes cached, then there are 10,000 lock objects. But ->inotify_mutex is a single "lock type", and all locking activities that occur against ->inotify_mutex are "unified" into this single lock-class. The advantage of the lock-class approach is that all historical ->inotify_mutex uses are mapped into a single (and as narrow as possible) set of locking rules - regardless of how many different tasks or inode structures it took to build this set of rules. The set of rules persist during the lifetime of the kernel. To see the rough magnitude of checking that the lock validator does, here's a portion of /proc/lockdep_stats, fresh after bootup: lock-classes: 694 [max: 2048] direct dependencies: 1598 [max: 8192] indirect dependencies: 17896 all direct dependencies: 16206 dependency chains: 1910 [max: 8192] in-hardirq chains: 17 in-softirq chains: 105 in-process chains: 1065 stack-trace entries: 38761 [max: 131072] combined max dependencies: 2033928 hardirq-safe locks: 24 hardirq-unsafe locks: 176 softirq-safe locks: 53 softirq-unsafe locks: 137 irq-safe locks: 59 irq-unsafe locks: 176 The lock validator has observed 1598 actual single-thread locking patterns, and has validated all possible 2033928 distinct locking scenarios. More details about the design of the lock validator can be found in Documentation/lockdep-design.txt, which can also found at: http://redhat.com/~mingo/lockdep-patches/lockdep-design.txt [bunk@stusta.de: cleanups] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: locking API self testsIngo Molnar
Introduce DEBUG_LOCKING_API_SELFTESTS, which uses the generic lock debugging code's silent-failure feature to run a matrix of testcases. There are 210 testcases currently: +----------------------- | Locking API testsuite: +------------------------------+------+------+------+------+------+------+ | spin |wlock |rlock |mutex | wsem | rsem | -------------------------------+------+------+------+------+------+------+ A-A deadlock: ok | ok | ok | ok | ok | ok | A-B-B-A deadlock: ok | ok | ok | ok | ok | ok | A-B-B-C-C-A deadlock: ok | ok | ok | ok | ok | ok | A-B-C-A-B-C deadlock: ok | ok | ok | ok | ok | ok | A-B-B-C-C-D-D-A deadlock: ok | ok | ok | ok | ok | ok | A-B-C-D-B-D-D-A deadlock: ok | ok | ok | ok | ok | ok | A-B-C-D-B-C-D-A deadlock: ok | ok | ok | ok | ok | ok | double unlock: ok | ok | ok | ok | ok | ok | bad unlock order: ok | ok | ok | ok | ok | ok | --------------------------------------+------+------+------+------+------+ recursive read-lock: | ok | | ok | --------------------------------------+------+------+------+------+------+ non-nested unlock: ok | ok | ok | ok | --------------------------------------+------+------+------+ hard-irqs-on + irq-safe-A/12: ok | ok | ok | soft-irqs-on + irq-safe-A/12: ok | ok | ok | hard-irqs-on + irq-safe-A/21: ok | ok | ok | soft-irqs-on + irq-safe-A/21: ok | ok | ok | sirq-safe-A => hirqs-on/12: ok | ok | ok | sirq-safe-A => hirqs-on/21: ok | ok | ok | hard-safe-A + irqs-on/12: ok | ok | ok | soft-safe-A + irqs-on/12: ok | ok | ok | hard-safe-A + irqs-on/21: ok | ok | ok | soft-safe-A + irqs-on/21: ok | ok | ok | hard-safe-A + unsafe-B #1/123: ok | ok | ok | soft-safe-A + unsafe-B #1/123: ok | ok | ok | hard-safe-A + unsafe-B #1/132: ok | ok | ok | soft-safe-A + unsafe-B #1/132: ok | ok | ok | hard-safe-A + unsafe-B #1/213: ok | ok | ok | soft-safe-A + unsafe-B #1/213: ok | ok | ok | hard-safe-A + unsafe-B #1/231: ok | ok | ok | soft-safe-A + unsafe-B #1/231: ok | ok | ok | hard-safe-A + unsafe-B #1/312: ok | ok | ok | soft-safe-A + unsafe-B #1/312: ok | ok | ok | hard-safe-A + unsafe-B #1/321: ok | ok | ok | soft-safe-A + unsafe-B #1/321: ok | ok | ok | hard-safe-A + unsafe-B #2/123: ok | ok | ok | soft-safe-A + unsafe-B #2/123: ok | ok | ok | hard-safe-A + unsafe-B #2/132: ok | ok | ok | soft-safe-A + unsafe-B #2/132: ok | ok | ok | hard-safe-A + unsafe-B #2/213: ok | ok | ok | soft-safe-A + unsafe-B #2/213: ok | ok | ok | hard-safe-A + unsafe-B #2/231: ok | ok | ok | soft-safe-A + unsafe-B #2/231: ok | ok | ok | hard-safe-A + unsafe-B #2/312: ok | ok | ok | soft-safe-A + unsafe-B #2/312: ok | ok | ok | hard-safe-A + unsafe-B #2/321: ok | ok | ok | soft-safe-A + unsafe-B #2/321: ok | ok | ok | hard-irq lock-inversion/123: ok | ok | ok | soft-irq lock-inversion/123: ok | ok | ok | hard-irq lock-inversion/132: ok | ok | ok | soft-irq lock-inversion/132: ok | ok | ok | hard-irq lock-inversion/213: ok | ok | ok | soft-irq lock-inversion/213: ok | ok | ok | hard-irq lock-inversion/231: ok | ok | ok | soft-irq lock-inversion/231: ok | ok | ok | hard-irq lock-inversion/312: ok | ok | ok | soft-irq lock-inversion/312: ok | ok | ok | hard-irq lock-inversion/321: ok | ok | ok | soft-irq lock-inversion/321: ok | ok | ok | hard-irq read-recursion/123: ok | soft-irq read-recursion/123: ok | hard-irq read-recursion/132: ok | soft-irq read-recursion/132: ok | hard-irq read-recursion/213: ok | soft-irq read-recursion/213: ok | hard-irq read-recursion/231: ok | soft-irq read-recursion/231: ok | hard-irq read-recursion/312: ok | soft-irq read-recursion/312: ok | hard-irq read-recursion/321: ok | soft-irq read-recursion/321: ok | --------------------------------+-----+---------------- Good, all 210 testcases passed! | --------------------------------+ Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
