commit f5527fffff3f002b0a6b376163613b82f69de073 upstream.
This fixes CVE-2016-8650.
If mpi_powm() is given a zero exponent, it wants to immediately return
either 1 or 0, depending on the modulus. However, if the result was
initalised with zero limb space, no limbs space is allocated and a
NULL-pointer exception ensues.
Fix this by allocating a minimal amount of limb space for the result when
the 0-exponent case when the result is 1 and not touching the limb space
when the result is 0.
This affects the use of RSA keys and X.509 certificates that carry them.
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff8138ce5d>] mpi_powm+0x32/0x7e6
PGD 0
Oops: 0002 [#1] SMP
Modules linked in:
CPU: 3 PID: 3014 Comm: keyctl Not tainted 4.9.0-rc6-fscache+ #278
Hardware name: ASUS All Series/H97-PLUS, BIOS 2306 10/09/2014
task: ffff8804011944c0 task.stack: ffff880401294000
RIP: 0010:[<ffffffff8138ce5d>] [<ffffffff8138ce5d>] mpi_powm+0x32/0x7e6
RSP: 0018:ffff880401297ad8 EFLAGS: 00010212
RAX: 0000000000000000 RBX: ffff88040868bec0 RCX: ffff88040868bba0
RDX: ffff88040868b260 RSI: ffff88040868bec0 RDI: ffff88040868bee0
RBP: ffff880401297ba8 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000047 R11: ffffffff8183b210 R12: 0000000000000000
R13: ffff8804087c7600 R14: 000000000000001f R15: ffff880401297c50
FS: 00007f7a7918c700(0000) GS:ffff88041fb80000(0000) knlGS:0000000000000000
CR2: 0000000000000000 CR3: 0000000401250000 CR4: 00000000001406e0
Stack:
ffff88040868bec0 0000000000000020 ffff880401297b00 ffffffff81376cd4
0000000000000100 ffff880401297b10 ffffffff81376d12 ffff880401297b30
ffffffff81376f37 0000000000000100 0000000000000000 ffff880401297ba8
Call Trace:
[<ffffffff81376cd4>] ? __sg_page_iter_next+0x43/0x66
[<ffffffff81376d12>] ? sg_miter_get_next_page+0x1b/0x5d
[<ffffffff81376f37>] ? sg_miter_next+0x17/0xbd
[<ffffffff8138ba3a>] ? mpi_read_raw_from_sgl+0xf2/0x146
[<ffffffff8132a95c>] rsa_verify+0x9d/0xee
[<ffffffff8132acca>] ? pkcs1pad_sg_set_buf+0x2e/0xbb
[<ffffffff8132af40>] pkcs1pad_verify+0xc0/0xe1
[<ffffffff8133cb5e>] public_key_verify_signature+0x1b0/0x228
[<ffffffff8133d974>] x509_check_for_self_signed+0xa1/0xc4
[<ffffffff8133cdde>] x509_cert_parse+0x167/0x1a1
[<ffffffff8133d609>] x509_key_preparse+0x21/0x1a1
[<ffffffff8133c3d7>] asymmetric_key_preparse+0x34/0x61
[<ffffffff812fc9f3>] key_create_or_update+0x145/0x399
[<ffffffff812fe227>] SyS_add_key+0x154/0x19e
[<ffffffff81001c2b>] do_syscall_64+0x80/0x191
[<ffffffff816825e4>] entry_SYSCALL64_slow_path+0x25/0x25
Code: 56 41 55 41 54 53 48 81 ec a8 00 00 00 44 8b 71 04 8b 42 04 4c 8b 67 18 45 85 f6 89 45 80 0f 84 b4 06 00 00 85 c0 75 2f 41 ff ce <49> c7 04 24 01 00 00 00 b0 01 75 0b 48 8b 41 18 48 83 38 01 0f
RIP [<ffffffff8138ce5d>] mpi_powm+0x32/0x7e6
RSP <ffff880401297ad8>
---[ end trace d82015255d4a5d8d ]---
Basically, this is a backport of a libgcrypt patch:
http://git.gnupg.org/cgi-bin/gitweb.cgi?p=libgcrypt.git;a=patch;h=6e1adb05d290aeeb1c230c763970695f4a538526
Fixes: cdec9cb5167a ("crypto: GnuPG based MPI lib - source files (part 1)")
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
cc: Dmitry Kasatkin <dmitry.kasatkin@gmail.com>
cc: linux-ima-devel@lists.sourceforge.net
Signed-off-by: James Morris <james.l.morris@oracle.com>
commit f2d1362ff7d266b3d2b1c764d6c2ef4a3b457f23 upstream.
Currently, if the number of leading zeros is greater than fits into a
complete limb, mpi_write_sgl() skips them by iterating over them limb-wise.
However, it fails to adjust its internal leading zeros tracking variable,
lzeros, accordingly: it does a
p -= sizeof(alimb);
continue;
which should really have been a
lzeros -= sizeof(alimb);
continue;
Since lzeros never decreases if its initial value >= sizeof(alimb), nothing
gets copied by mpi_write_sgl() in that case.
Instead of skipping the high order zero limbs within the loop as shown
above, fix the issue by adjusting the copying loop's bounds.
Fixes: 2d4d1eea540b ("lib/mpi: Add mpi sgl helpers")
Signed-off-by: Nicolai Stange <nicstange@gmail.com>
commit 3ee0cb5fb5eea2110db1b5cb7f67029b7be8a376 upstream.
The limbs are integers in the host endianness, so we can't simply
iterate over the individual bytes. The current code happens to work on
little-endian, because the order of the limbs in the MPI array is the
same as the order of the bytes in each limb, but it breaks on
big-endian.
Fixes: 0f74fbf77d45 ("MPI: Fix mpi_read_buffer")
Signed-off-by: Michal Marek <mmarek@suse.com>
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic
Pull asm-generic cleanups from Arnd Bergmann:
"The asm-generic changes for 4.4 are mostly a series from Christoph
Hellwig to clean up various abuses of headers in there. The patch to
rename the io-64-nonatomic-*.h headers caused some conflicts with new
users, so I added a workaround that we can remove in the next merge
window.
The only other patch is a warning fix from Marek Vasut"
* tag 'asm-generic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic:
asm-generic: temporarily add back asm-generic/io-64-nonatomic*.h
asm-generic: cmpxchg: avoid warnings from macro-ized cmpxchg() implementations
gpio-mxc: stop including <asm-generic/bug>
n_tracesink: stop including <asm-generic/bug>
n_tracerouter: stop including <asm-generic/bug>
mlx5: stop including <asm-generic/kmap_types.h>
hifn_795x: stop including <asm-generic/kmap_types.h>
drbd: stop including <asm-generic/kmap_types.h>
move count_zeroes.h out of asm-generic
move io-64-nonatomic*.h out of asm-generic
The patch fixes the analysis of the input data which contains an off
by one.
The issue is visible when the SGL contains one byte per SG entry.
The code for checking for zero bytes does not operate on the data byte.
Signed-off-by: Stephan Mueller <smueller@chronox.de>
This header contains a few helpers currenly only used by the mpi
implementation, and not default implementation of architecture code.
Add mpi_read_raw_from_sgl and mpi_write_to_sgl helpers.
Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com>
Change mpi_read_buffer to return a number without leading zeros
so that mpi_read_buffer and mpi_get_buffer return the same thing.
Pull crypto update from Herbert Xu:
"Here is the crypto update for 4.2:
API:
- Convert RNG interface to new style.
- New AEAD interface with one SG list for AD and plain/cipher text.
All external AEAD users have been converted.
- New asymmetric key interface (akcipher).
Algorithms:
- Chacha20, Poly1305 and RFC7539 support.
- New RSA implementation.
- Jitter RNG.
- DRBG is now seeded with both /dev/random and Jitter RNG. If kernel
pool isn't ready then DRBG will be reseeded when it is.
- DRBG is now the default crypto API RNG, replacing krng.
- 842 compression (previously part of powerpc nx driver).
Drivers:
- Accelerated SHA-512 for arm64.
- New Marvell CESA driver that supports DMA and more algorithms.
- Updated powerpc nx 842 support.
- Added support for SEC1 hardware to talitos"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (292 commits)
crypto: marvell/cesa - remove COMPILE_TEST dependency
crypto: algif_aead - Temporarily disable all AEAD algorithms
crypto: af_alg - Forbid the use internal algorithms
crypto: echainiv - Only hold RNG during initialisation
crypto: seqiv - Add compatibility support without RNG
crypto: eseqiv - Offer normal cipher functionality without RNG
crypto: chainiv - Offer normal cipher functionality without RNG
crypto: user - Add CRYPTO_MSG_DELRNG
crypto: user - Move cryptouser.h to uapi
crypto: rng - Do not free default RNG when it becomes unused
crypto: skcipher - Allow givencrypt to be NULL
crypto: sahara - propagate the error on clk_disable_unprepare() failure
crypto: rsa - fix invalid select for AKCIPHER
crypto: picoxcell - Update to the current clk API
crypto: nx - Check for bogus firmware properties
crypto: marvell/cesa - add DT bindings documentation
crypto: marvell/cesa - add support for Kirkwood and Dove SoCs
crypto: marvell/cesa - add support for Orion SoCs
crypto: marvell/cesa - add allhwsupport module parameter
crypto: marvell/cesa - add support for all armada SoCs
Added a mpi_read_buf() helper function to export MPI to a buf provided by
the user, and a mpi_get_size() helper, that tells the user how big the buf is.
Changed mpi_free to use kzfree instead of kfree because it is used to free
crypto keys.
This patch fixes mips compilation error:
lib/mpi/generic_mpih-mul1.c: In function 'mpihelp_mul_1':
lib/mpi/longlong.h:651:2: error: impossible constraint in 'asm'
Signed-off-by: Jaedon Shin <jaedon.shin@gmail.com>
Cc: Linux-MIPS <linux-mips@linux-mips.org>
Patchwork: https://patchwork.linux-mips.org/patch/10546/
If u and v both represent negative integers and their limb counts
happen to differ, mpi_cmp will always return a positive value - this
is obviously bogus. u is smaller than v if and only if it is larger in
absolute value.
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Acked-by: Dmitry Kasatkin <dmitry.kasatkin@gmail.com>
The macro MPN_COPY_INCR this occurs in isn't used anywhere.
The condition preceding 'return 1;' makes my head hurt. At this point,
we know that u and v have the same sign; if they are negative, they
compare opposite to how their absolute values compare (which
mpihelp_cmp found for us), otherwise cmp itself is the
answer. Negating cmp is ok since mpihelp_cmp returns {-1,0,1};
-INT_MIN==INT_MIN won't bite us.
This patch fixes lack of license, otherwise mpi.ko taints kernel.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Remove the compile warning for __udiv_qrnnd not having a prototype.
Use the __builtin_alpha_umulh introduced in gcc 4.0.
Reviewed-and-Tested-by: Matt Turner <mattst88@gmail.com>
Signed-off-by: Matt Turner <mattst88@gmail.com>
Signed-off-by: Richard Henderson <rth@twiddle.net>
'EXTRA_FLAGS=-W'.
For 'while' looping, need stop when 'nbytes == 0', or will cause issue.
('nbytes' is size_t which is always bigger or equal than zero).
The related warning: (with EXTRA_CFLAGS=-W)
lib/mpi/mpicoder.c:40:2: warning: comparison of unsigned expression >= 0 is always true [-Wtype-limits]
Signed-off-by: Chen Gang <gang.chen@asianux.com>
Cc: James Morris <james.l.morris@oracle.com>
Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
The umul_ppmm() macro for parisc uses the xmpyu assembler statement
which does calculation via a floating point register.
But usage of floating point registers inside the Linux kernel are not
allowed and gcc will stop compilation due to the -mdisable-fpregs
compiler option.
Fix this by disabling the umul_ppmm() and udiv_qrnnd() macros. The
mpilib will then use the generic built-in implementations instead.
Signed-off-by: Helge Deller <deller@gmx.de>
Remove MIN, MAX and ABS macros that are duplicates kernel's native
implementation.
Since 4.4 GCC on MIPS no longer recognizes the "h" constraint,
leading to this build failure:
CC lib/mpi/generic_mpih-mul1.o
lib/mpi/generic_mpih-mul1.c:50:3: error: impossible constraint in 'asm'
This patch updates MPI with the latest umul_ppm implementations for MIPS.
Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com>
Cc: Dmitry Kasatkin <dmitry.kasatkin@intel.com>
Patchwork: https://patchwork.linux-mips.org/patch/4612/
Provide a function to read raw data of a predetermined size into an MPI rather
than expecting the size to be encoded within the data. The data is assumed to
represent an unsigned integer, and the resulting MPI will be positive.
The function looks like this:
MPI mpi_read_raw_data(const void *, size_t);
This is useful for reading ASN.1 integer primitives where the length is encoded
in the ASN.1 metadata.
Reinstate and export mpi_cmp() and mpi_cmp_ui() from the MPI library for use by
RSA signature verification as per RFC3447 section 5.2.2 step 1.
Provide count_leading/trailing_zeros() macros based on extant arch bit scanning
functions rather than reimplementing from scratch in MPILIB.
Whilst we're at it, turn count_foo_zeros(n, x) into n = count_foo_zeros(x).
Also move the definition to asm-generic as other people may be interested in
using it.
Cc: Arnd Bergmann <arnd@arndb.com>
MPI library is used by RSA verification implementation.
Few files contains functions which are never called.
James Morris has asked to remove all of them.
Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com>
Requested-by: James Morris <james.l.morris@oracle.com>
This reverts commit 7e8dec918ef8e0f68b4937c3c50fa57002077a4d.
RSA verification implementation does not use this code.
James Morris has asked to remove that.
At the start of the function we assign 'a->d' to 'ap'. Then we use the
RESIZE_IF_NEEDED macro on 'a' - this may free 'a->d' and replace it
with newly allocaetd storage. In that case, we'll be operating on
freed memory further down in the function when we index into 'ap[]'.
Since we don't actually need 'ap' until after the use of the
RESIZE_IF_NEEDED macro we can just delay the assignment to it until
after we've potentially resized, thus avoiding the issue.
While I was there anyway I also changed the integer variable 'n' to be
const. It might as well be since we only assign to it once and use it
as a constant, and then the compiler will tell us if we ever assign to
it in the future.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Acked-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com>
This copy of longlong.h is extremely dated and results in compile
errors on sparc32 when MPILIB is enabled, copy over the more uptodate
implementation from arch/sparc/math/sfp-util_32.h
Reported-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: James Morris <jmorris@namei.org>
Both sparc 32-bit's software divide assembler and MPILIB provide
clz_tab[] with identical contents.
Break it out into a seperate object file and select it when
SPARC32 or MPILIB is set.
Added missing NULL check after mpi_alloc_limb_space().
Reviewed-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Comment explains that existing clients do not call this function
with dsize == 0, which means that 1/0 should not happen.
Buggy client might pass zero nlimbs which is meaningless.
Added check for zero length.
do_encode_md() and mpi_get_keyid() are not parts of mpi library.
They were used early versions of gnupg and in digsig project,
but they are not used neither here nor there anymore.
Divisor length should not be 0.
Definitely better to return error code than to divide by zero.
MPI_NULL is replaced with normal NULL.
Added missing NULL check after mpi_alloc().
Add a missing ENOMEM check.
Acked-by: Mimi Zohar <zohar@us.ibm.com>
We can't call mpi_free() on the elements if the first kzalloc() fails.
Adds the multi-precision-integer maths library which was originally taken
from GnuPG and ported to the kernel by (among others) David Howells.
This version is taken from Fedora kernel 2.6.32-71.14.1.el6.
The difference is that checkpatch reported errors and warnings have been fixed.
This library is used to implemenet RSA digital signature verification
used in IMA/EVM integrity protection subsystem.
Due to patch size limitation, the patch is divided into 4 parts.
This code is unnecessary for RSA digital signature verification,
but for completeness it is included here and can be compiled,
if CONFIG_MPILIB_EXTRA is enabled.
