path: root/lib/percpu-refcount.c
2014-06-28percpu-refcount: implement percpu_ref_reinit() and percpu_ref_is_zero()Tejun Heo
Now that explicit invocation of percpu_ref_exit() is necessary to free the percpu counter, we can implement percpu_ref_reinit() which reinitializes a released percpu_ref. This can be used implement scalable gating switch which can be drained and then re-opened without worrying about memory allocation failures. percpu_ref_is_zero() is added to be used in a sanity check in percpu_ref_exit(). As this function will be useful for other purposes too, make it a public interface. v2: Use smp_read_barrier_depends() instead of smp_load_acquire(). We only need data dep barrier and smp_load_acquire() is stronger and heavier on some archs. Spotted by Lai Jiangshan. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Kent Overstreet <kmo@daterainc.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
2014-06-28percpu-refcount: require percpu_ref to be exited explicitlyTejun Heo
Currently, a percpu_ref undoes percpu_ref_init() automatically by freeing the allocated percpu area when the percpu_ref is killed. While seemingly convenient, this has the following niggles. * It's impossible to re-init a released reference counter without going through re-allocation. * In the similar vein, it's impossible to initialize a percpu_ref count with static percpu variables. * We need and have an explicit destructor anyway for failure paths - percpu_ref_cancel_init(). This patch removes the automatic percpu counter freeing in percpu_ref_kill_rcu() and repurposes percpu_ref_cancel_init() into a generic destructor now named percpu_ref_exit(). percpu_ref_destroy() is considered but it gets confusing with percpu_ref_kill() while "exit" clearly indicates that it's the counterpart of percpu_ref_init(). All percpu_ref_cancel_init() users are updated to invoke percpu_ref_exit() instead and explicit percpu_ref_exit() calls are added to the destruction path of all percpu_ref users. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Benjamin LaHaise <bcrl@kvack.org> Cc: Kent Overstreet <kmo@daterainc.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Benjamin LaHaise <bcrl@kvack.org> Cc: Nicholas A. Bellinger <nab@linux-iscsi.org> Cc: Li Zefan <lizefan@huawei.com>
2014-06-28percpu-refcount: use unsigned long for pcpu_count pointerTejun Heo
percpu_ref->pcpu_count is a percpu pointer with a status flag in its lowest bit. As such, it always goes through arithmetic operations which is very cumbersome to do on a pointer. It has to be first casted to unsigned long and then back. Let's just make the field unsigned long so that we can skip the first casts. While at it, rename it to pcpu_counter_ptr to clarify that it's a pointer value. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Kent Overstreet <kmo@daterainc.com> Cc: Christoph Lameter <cl@linux-foundation.org>
2014-06-28percpu-refcount: add helpers for ->percpu_count accessesTejun Heo
* All four percpu_ref_*() operations implemented in the header file perform the same operation to determine whether the percpu_ref is alive and extract the percpu pointer. Factor out the common logic into __pcpu_ref_alive(). This doesn't change the generated code. * There are a couple places in percpu-refcount.c which masks out PCPU_REF_DEAD to obtain the percpu pointer. Factor it out into pcpu_count_ptr(). * The above changes make the WARN_ON_ONCE() conditional at the top of percpu_ref_kill_and_confirm() the only user of REF_STATUS(). Test PCPU_REF_DEAD directly and remove REF_STATUS(). This patch doesn't introduce any functional change. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Kent Overstreet <kmo@daterainc.com> Cc: Christoph Lameter <cl@linux-foundation.org>
2014-06-28percpu-refcount: one bit is enough for REF_STATUSTejun Heo
percpu-refcount currently reserves two lowest bits of its percpu pointer to indicate its state; however, only one bit is used for PCPU_REF_DEAD. Simplify it by removing PCPU_STATUS_BITS/MASK and testing PCPU_REF_DEAD directly. This also allows the compiler to choose a more efficient instruction depending on the architecture. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Kent Overstreet <kmo@daterainc.com> Cc: Christoph Lameter <cl@linux-foundation.org>
2014-01-21percpu-refcount: Add a WARN() for ref going negativeKent Overstreet
AIO had a missing get, which led to an ioctx leak - after percpu_ref_kill() the ref was 0 so percpu_ref_put() never saw it hit 0. This wasn't noticed at the time because it all happened completely silently, this adds a WARN() which would've caught the aio bug. tj: Used WARN_ONCE() instead of WARN(). Signed-off-by: Kent Overstreet <kmo@daterainc.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-10-16percpu_refcount: export symbolsMatias Bjorling
Export the interface to be used within modules. Signed-off-by: Matias Bjorling <m@bjorling.me> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-16percpu-refcount: use RCU-sched insted of normal RCUTejun Heo
percpu-refcount was incorrectly using preempt_disable/enable() for RCU critical sections against call_rcu(). 6a24474da8 ("percpu-refcount: consistently use plain (non-sched) RCU") fixed it by converting the preepmtion operations with rcu_read_[un]lock() citing that there isn't any advantage in using sched-RCU over using the usual one; however, rcu_read_[un]lock() for the preemptible RCU implementation - CONFIG_TREE_PREEMPT_RCU, chosen when CONFIG_PREEMPT - are slightly more expensive than preempt_disable/enable(). In a contrived microbench which repeats the followings, - percpu_ref_get() - copy 32 bytes of data into percpu buffer - percpu_put_get() - copy 32 bytes of data into percpu buffer rcu_read_[un]lock() used in percpu_ref_get/put() makes it go slower by about 15% when compared to using sched-RCU. As the RCU critical sections are extremely short, using sched-RCU shouldn't have any latency implications. Convert to RCU-sched. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Kent Overstreet <koverstreet@google.com> Acked-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Rusty Russell <rusty@rustcorp.com.au>
2013-06-13percpu-refcount: implement percpu_tryget() along with ↵Tejun Heo
percpu_ref_kill_and_confirm() Implement percpu_tryget() which stops giving out references once the percpu_ref is visible as killed. Because the refcnt is per-cpu, different CPUs will start to see a refcnt as killed at different points in time and tryget() may continue to succeed on subset of cpus for a while after percpu_ref_kill() returns. For use cases where it's necessary to know when all CPUs start to see the refcnt as dead, percpu_ref_kill_and_confirm() is added. The new function takes an extra argument @confirm_kill which is invoked when the refcnt is guaranteed to be viewed as killed on all CPUs. While this isn't the prettiest interface, it doesn't force synchronous wait and is much safer than requiring the caller to do its own call_rcu(). v2: Patch description rephrased to emphasize that tryget() may continue to succeed on some CPUs after kill() returns as suggested by Kent. v3: Function comment in percpu_ref_kill_and_confirm() updated warning people to not depend on the implied RCU grace period from the confirm callback as it's an implementation detail. Signed-off-by: Tejun Heo <tj@kernel.org> Slightly-Grumpily-Acked-by: Kent Overstreet <koverstreet@google.com>
2013-06-13percpu-refcount: implement percpu_ref_cancel_init()Tejun Heo
Normally, percpu_ref_init() initializes and percpu_ref_kill() initiates destruction which completes asynchronously. The asynchronous destruction can be problematic in init failure path where the caller wants to destroy half-constructed object - distinguishing half-constructed objects from the usual release method can be painful for complex objects. This patch implements percpu_ref_cancel_init() which synchronously destroys the percpu_ref without invoking release. To avoid unintentional misuses, the function requires the ref to have finished percpu_ref_init() but never used and triggers WARN otherwise. v2: Explain the weird name and usage restriction in the function comment. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Kent Overstreet <koverstreet@google.com>
2013-06-13percpu-refcount: add __must_check to percpu_ref_init() and don't use ↵Tejun Heo
ACCESS_ONCE() in percpu_ref_kill_rcu() Two small changes. * Unlike most init functions, percpu_ref_init() allocates memory and may fail. Let's mark it with __must_check in case the caller forgets. * percpu_ref_kill_rcu() is unnecessarily using ACCESS_ONCE() to dereference @ref->pcpu_count, which can be misleading. The pointer is guaranteed to be valid and visible and can't change underneath the function. Drop ACCESS_ONCE(). Signed-off-by: Tejun Heo <tj@kernel.org>
2013-06-12percpu-refcount: cosmetic updatesTejun Heo
* s/percpu_ref_release/percpu_ref_func_t/ as it's customary to have _t postfix for types and the type is gonna be used for a different type of callback too. * Add @ARG to function comments. * Drop unnecessary and unaligned indentation from percpu_ref_init() function comment. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Kent Overstreet <koverstreet@google.com>
2013-06-03percpu-refcount: Don't use silly cmpxchg()Kent Overstreet
The cmpxchg() was just to ensure the debug check didn't race, which was a bit excessive. The caller is supposed to do the appropriate synchronization, which means percpu_ref_kill() can just do a simple store. Signed-off-by: Kent Overstreet <koverstreet@google.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-06-03percpu: implement generic percpu refcountingKent Overstreet
This implements a refcount with similar semantics to atomic_get()/atomic_dec_and_test() - but percpu. It also implements two stage shutdown, as we need it to tear down the percpu counts. Before dropping the initial refcount, you must call percpu_ref_kill(); this puts the refcount in "shutting down mode" and switches back to a single atomic refcount with the appropriate barriers (synchronize_rcu()). It's also legal to call percpu_ref_kill() multiple times - it only returns true once, so callers don't have to reimplement shutdown synchronization. [akpm@linux-foundation.org: fix build] [akpm@linux-foundation.org: coding-style tweak] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Cc: Tejun Heo <tj@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Tejun Heo <tj@kernel.org>
