commit e39435ce68bb4685288f78b1a7e24311f7ef939f upstream.
I got a bug report yesterday from Laszlo Ersek in which he states that
his kvm instance fails to suspend. Laszlo bisected it down to this
commit 1cf7e9c68fe8 ("virtio_blk: blk-mq support") where virtio-blk is
converted to use the blk-mq infrastructure.
After digging a bit, it became clear that the issue was with the queue
drain. blk-mq tracks queue usage in a percpu counter, which is
incremented on request alloc and decremented when the request is freed.
The initial hunt was for an inconsistency in blk-mq, but everything
seemed fine. In fact, the counter only returned crazy values when
suspend was in progress.
When a CPU is unplugged, the percpu counters merges that CPU state with
the general state. blk-mq takes care to register a hotcpu notifier with
the appropriate priority, so we know it runs after the percpu counter
notifier. However, the percpu counter notifier only merges the state
when the CPU is fully gone. This leaves a state transition where the
CPU going away is no longer in the online mask, yet it still holds
private values. This means that in this state, percpu_counter_sum()
returns invalid results, and the suspend then hangs waiting for
abs(dead-cpu-value) requests to complete which of course will never
happen.
Fix this by clearing the state earlier, so we never have a case where
the CPU isn't in online mask but still holds private state. This bug
has been there since forever, I guess we don't have a lot of users where
percpu counters needs to be reliable during the suspend cycle.
Signed-off-by: Jens Axboe <axboe@fb.com>
Reported-by: Laszlo Ersek <lersek@redhat.com>
Tested-by: Laszlo Ersek <lersek@redhat.com>
These variables are only used when CONFIG_HOTPLUG_CPU is enabled, they are
ifdef'ed everywhere else. So don't define them when CONFIG_HOTPLUG_CPU is
not enabled.
Signed-off-by: Glauber Costa <glommer@parallels.com>
The percpu_counter::lock can be taken in atomic context and therefore
cannot be preempted on -rt - annotate it.
In mainline this change documents the low level nature of
the lock - otherwise there's no functional difference. Lockdep
and Sparse checking will work as usual.
this_cpu() options.
The this_cpu_* options can be used to optimize __percpu_counter_add a bit. Avoids
some address arithmetic and saves 12 bytes.
Before:
00000000000001d3 <__percpu_counter_add>:
1d3: 55 push %rbp
1d4: 48 89 e5 mov %rsp,%rbp
1d7: 41 55 push %r13
1d9: 41 54 push %r12
1db: 53 push %rbx
1dc: 48 89 fb mov %rdi,%rbx
1df: 48 83 ec 08 sub $0x8,%rsp
1e3: 4c 8b 67 30 mov 0x30(%rdi),%r12
1e7: 65 4c 03 24 25 00 00 add %gs:0x0,%r12
1ee: 00 00
1f0: 4d 63 2c 24 movslq (%r12),%r13
1f4: 48 63 c2 movslq %edx,%rax
1f7: 49 01 f5 add %rsi,%r13
1fa: 49 39 c5 cmp %rax,%r13
1fd: 7d 0a jge 209 <__percpu_counter_add+0x36>
1ff: f7 da neg %edx
201: 48 63 d2 movslq %edx,%rdx
204: 49 39 d5 cmp %rdx,%r13
207: 7f 1e jg 227 <__percpu_counter_add+0x54>
209: 48 89 df mov %rbx,%rdi
20c: e8 00 00 00 00 callq 211 <__percpu_counter_add+0x3e>
211: 4c 01 6b 18 add %r13,0x18(%rbx)
215: 48 89 df mov %rbx,%rdi
218: 41 c7 04 24 00 00 00 movl $0x0,(%r12)
21f: 00
220: e8 00 00 00 00 callq 225 <__percpu_counter_add+0x52>
225: eb 04 jmp 22b <__percpu_counter_add+0x58>
227: 45 89 2c 24 mov %r13d,(%r12)
22b: 5b pop %rbx
22c: 5b pop %rbx
22d: 41 5c pop %r12
22f: 41 5d pop %r13
231: c9 leaveq
232: c3 retq
After:
1d3: 55 push %rbp
1d4: 48 63 ca movslq %edx,%rcx
1d7: 48 89 e5 mov %rsp,%rbp
1da: 41 54 push %r12
1dc: 53 push %rbx
1dd: 48 89 fb mov %rdi,%rbx
1e0: 48 8b 47 30 mov 0x30(%rdi),%rax
1e4: 65 44 8b 20 mov %gs:(%rax),%r12d
1e8: 4d 63 e4 movslq %r12d,%r12
1eb: 49 01 f4 add %rsi,%r12
1ee: 49 39 cc cmp %rcx,%r12
1f1: 7d 0a jge 1fd <__percpu_counter_add+0x2a>
1f3: f7 da neg %edx
1f5: 48 63 d2 movslq %edx,%rdx
1f8: 49 39 d4 cmp %rdx,%r12
1fb: 7f 21 jg 21e <__percpu_counter_add+0x4b>
1fd: 48 89 df mov %rbx,%rdi
200: e8 00 00 00 00 callq 205 <__percpu_counter_add+0x32>
205: 4c 01 63 18 add %r12,0x18(%rbx)
209: 48 8b 43 30 mov 0x30(%rbx),%rax
20d: 48 89 df mov %rbx,%rdi
210: 65 c7 00 00 00 00 00 movl $0x0,%gs:(%rax)
217: e8 00 00 00 00 callq 21c <__percpu_counter_add+0x49>
21c: eb 04 jmp 222 <__percpu_counter_add+0x4f>
21e: 65 44 89 20 mov %r12d,%gs:(%rax)
222: 5b pop %rbx
223: 41 5c pop %r12
225: c9 leaveq
226: c3 retq
Reviewed-by: Pekka Enberg <penberg@kernel.org>
Reviewed-by: Tejun Heo <tj@kernel.org>
Reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Signed-off-by: Christoph Lameter <cl@linux.com>
this_cpu_ptr() avoids an array lookup and can use the percpu offset of the
local cpu directly.
Cc: Tejun Heo <tj@kernel.org>
All percpu counters are linked to a global list on initialization and
removed from it on destruction. The list is walked during CPU up/down.
If a percpu counter is freed without being properly destroyed, the system
will oops only on the next CPU up/down making it pretty nasty to track
down. This patch adds debugobj support for percpu counters so that such
problems can be found easily.
As percpu counters don't make sense on stack and can't be statically
initialized, debugobj support is pretty simple. It's initialized and
activated on counter initialization, and deactivatd and destroyed on
counter destruction. With this patch applied, the bug fixed by commit
602586a83b719df0fbd94196a1359ed35aeb2df3 (shmem: put_super must
percpu_counter_destroy) triggers the following warning on tmpfs unmount
and the system won't oops on the next cpu up/down operation.
WARNING: at lib/debugobjects.c:259 debug_print_object+0x5c/0x70()
Hardware name: Bochs
ODEBUG: free active (active state 0) object type: percpu_counter
Modules linked in:
Pid: 3999, comm: umount Not tainted 2.6.36-rc2-work+ #5
Call Trace:
[<ffffffff81083f7f>] warn_slowpath_common+0x7f/0xc0
[<ffffffff81084076>] warn_slowpath_fmt+0x46/0x50
[<ffffffff813b45cc>] debug_print_object+0x5c/0x70
[<ffffffff813b50e5>] debug_check_no_obj_freed+0x125/0x210
[<ffffffff811577d3>] kfree+0xb3/0x2f0
[<ffffffff81132edd>] shmem_put_super+0x1d/0x30
[<ffffffff81162e96>] generic_shutdown_super+0x56/0xe0
[<ffffffff81162f86>] kill_anon_super+0x16/0x60
[<ffffffff81162ff7>] kill_litter_super+0x27/0x30
[<ffffffff81163295>] deactivate_locked_super+0x45/0x60
[<ffffffff81163cfa>] deactivate_super+0x4a/0x70
[<ffffffff8117d446>] mntput_no_expire+0x86/0xe0
[<ffffffff8117df7f>] sys_umount+0x6f/0x360
[<ffffffff8103f01b>] system_call_fastpath+0x16/0x1b
---[ end trace cce2a341ba3611a7 ]---
Acked-by: Thomas Gleixner <tglxlinutronix.de>
WARNING: at lib/list_debug.c:26 __list_add+0x3f/0x81()
Hardware name: Express5800/B120a [N8400-085]
list_add corruption. next->prev should be prev (ffffffff81a7ea00), but was dead000000200200. (next=ffff88080b872d58).
Modules linked in: aoe ipt_MASQUERADE iptable_nat nf_nat autofs4 sunrpc bridge 8021q garp stp llc ipv6 cpufreq_ondemand acpi_cpufreq freq_table dm_round_robin dm_multipath kvm_intel kvm uinput lpfc scsi_transport_fc igb ioatdma scsi_tgt i2c_i801 i2c_core dca iTCO_wdt iTCO_vendor_support pcspkr shpchp megaraid_sas [last unloaded: aoe]
Pid: 54, comm: events/3 Tainted: G W 2.6.34-vanilla1 #1
Call Trace:
[<ffffffff8104bd77>] warn_slowpath_common+0x7c/0x94
[<ffffffff8104bde6>] warn_slowpath_fmt+0x41/0x43
[<ffffffff8120fd2e>] __list_add+0x3f/0x81
[<ffffffff81212a12>] __percpu_counter_init+0x59/0x6b
[<ffffffff810d8499>] bdi_init+0x118/0x17e
[<ffffffff811f2c50>] blk_alloc_queue_node+0x79/0x143
[<ffffffff811f2d2b>] blk_alloc_queue+0x11/0x13
[<ffffffffa02a931d>] aoeblk_gdalloc+0x8e/0x1c9 [aoe]
[<ffffffffa02aa655>] aoecmd_sleepwork+0x25/0xa8 [aoe]
[<ffffffff8106186c>] worker_thread+0x1a9/0x237
[<ffffffffa02aa630>] ? aoecmd_sleepwork+0x0/0xa8 [aoe]
[<ffffffff81065827>] ? autoremove_wake_function+0x0/0x39
[<ffffffff810616c3>] ? worker_thread+0x0/0x237
[<ffffffff810653ad>] kthread+0x7f/0x87
[<ffffffff8100aa24>] kernel_thread_helper+0x4/0x10
[<ffffffff8106532e>] ? kthread+0x0/0x87
[<ffffffff8100aa20>] ? kernel_thread_helper+0x0/0x10
It's because there is no initialization code for a list_head contained in
the struct backing_dev_info under CONFIG_HOTPLUG_CPU, and the bug comes up
when block device drivers calling blk_alloc_queue() are used. In case of
me, I got them by using aoe.
Signed-off-by: Masanori Itoh <itoumsn@nttdata.co.jp>
Cc: <stable@kernel.org>
Add percpu_counter_compare that allows for a quick but accurate comparison
of percpu_counter with a given value.
A rough count is provided by the count field in percpu_counter structure,
without accounting for the other values stored in individual cpu counters.
The actual count is a sum of count and the cpu counters. However, count
field is never different from the actual value by a factor of
batch*num_online_cpu. We do not need to get actual count for comparison
if count is different from the given value by this factor and allows for
quick comparison without summing up all the per cpu counters.
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
rcu: fix rcutorture bug
rcu: eliminate synchronize_rcu_xxx macro
rcu: make treercu safe for suspend and resume
rcu: fix rcutree grace-period-latency bug on small systems
futex: catch certain assymetric (get|put)_futex_key calls
futex: make futex_(get|put)_key() calls symmetric
locking, percpu counters: introduce separate lock classes
swiotlb: clean up EXPORT_SYMBOL usage
swiotlb: remove unnecessary declaration
swiotlb: replace architecture-specific swiotlb.h with linux/swiotlb.h
swiotlb: add support for systems with highmem
swiotlb: store phys address in io_tlb_orig_addr array
swiotlb: add hwdev to swiotlb_phys_to_bus() / swiotlb_sg_to_bus()
For NR_CPUS >= 16 values, FBC_BATCH is 2*NR_CPUS
Considering more and more distros are using high NR_CPUS values, it makes
sense to use a more sensible value for FBC_BATCH, and get rid of NR_CPUS.
A sensible value is 2*num_online_cpus(), with a minimum value of 32 (This
minimum value helps branch prediction in __percpu_counter_add())
We already have a hotcpu notifier, so we can adjust FBC_BATCH dynamically.
We rename FBC_BATCH to percpu_counter_batch since its not a constant
anymore.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
core/urgent
Impact: fix lockdep false positives
Classify percpu_counter instances similar to regular lock objects --
that is, per instantiation site.
The networking code has increased its use of percpu_counters, which
leads to false positives if they are treated as a single class.
Revert
commit e8ced39d5e8911c662d4d69a342b9d053eaaac4e
Author: Mingming Cao <cmm@us.ibm.com>
Date: Fri Jul 11 19:27:31 2008 -0400
percpu_counter: new function percpu_counter_sum_and_set
As described in
revert "percpu counter: clean up percpu_counter_sum_and_set()"
the new percpu_counter_sum_and_set() is racy against updates to the
cpu-local accumulators on other CPUs. Revert that change.
This means that ext4 will be slow again. But correct.
Reported-by: Eric Dumazet <dada1@cosmosbay.com>
Cc: Mingming Cao <cmm@us.ibm.com>
Cc: <linux-ext4@vger.kernel.org>
Cc: <stable@kernel.org> [2.6.27.x]
Revert
commit 1f7c14c62ce63805f9574664a6c6de3633d4a354
Date: Thu Oct 9 12:50:59 2008 -0400
Before this patch we had the following:
percpu_counter_sum(): return the percpu_counter's value
percpu_counter_sum_and_set(): return the percpu_counter's value, copying
that value into the central value and zeroing the per-cpu counters before
returning.
After this patch, percpu_counter_sum_and_set() has gone, and
percpu_counter_sum() gets the old percpu_counter_sum_and_set()
functionality.
Problem is, as Eric points out, the old percpu_counter_sum_and_set()
functionality was racy and wrong. It zeroes out counters on "other" cpus,
without holding any locks which will prevent races agaist updates from
those other CPUS.
This patch reverts 1f7c14c62ce63805f9574664a6c6de3633d4a354. This means
that percpu_counter_sum_and_set() still has the race, but
percpu_counter_sum() does not.
Note that this is not a simple revert - ext4 has since started using
percpu_counter_sum() for its dirty_blocks counter as well.
Note that this revert patch changes percpu_counter_sum() semantics.
Before the patch, a call to percpu_counter_sum() will bring the counter's
central counter mostly up-to-date, so a following percpu_counter_read()
will return a close value.
After this patch, a call to percpu_counter_sum() will leave the counter's
central accumulator unaltered, so a subsequent call to
percpu_counter_read() can now return a significantly inaccurate result.
If there is any code in the tree which was introduced after
e8ced39d5e8911c662d4d69a342b9d053eaaac4e was merged, and which depends
upon the new percpu_counter_sum() semantics, that code will break.
We should first delete the counter from percpu_counters list
before freeing memory, or a percpu_counter_hotcpu_callback()
could dereference a NULL pointer.
percpu_counter_sum_and_set() and percpu_counter_sum() is the same except
the former updates the global counter after accounting. Since we are
taking the fbc->lock to calculate the precise value of the counter in
percpu_counter_sum() anyway, it should simply set fbc->count too, as the
percpu_counter_sum_and_set() does.
This patch merges these two interfaces into one.
Signed-off-by: Mingming Cao <cmm@us.ibm.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Delayed allocation need to check free blocks at every write time.
percpu_counter_read_positive() is not quit accurate. delayed
allocation need a more accurate accounting, but using
percpu_counter_sum_positive() is frequently is quite expensive.
This patch added a new function to update center counter when sum
per-cpu counter, to increase the accurate rate for next
percpu_counter_read() and require less calling expensive
percpu_counter_sum().
Provide a place in sysfs (/sys/class/bdi) for the backing_dev_info object.
This allows us to see and set the various BDI specific variables.
In particular this properly exposes the read-ahead window for all relevant
users and /sys/block/<block>/queue/read_ahead_kb should be deprecated.
With patient help from Kay Sievers and Greg KH
[mszeredi@suse.cz]
- split off NFS and FUSE changes into separate patches
- document new sysfs attributes under Documentation/ABI
- do bdi_class_init as a core_initcall, otherwise the "default" BDI
won't be initialized
- remove bdi_init_fmt macro, it's not used very much
[akpm@linux-foundation.org: fix ia64 warning]
Cc: Kay Sievers <kay.sievers@vrfy.org>
Acked-by: Greg KH <greg@kroah.com>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Some of the per-cpu counters and thus their locks are accessed from IRQ
contexts. This can cause a deadlock if it interrupts a cpu-offline thread
which is transferring a dead-cpu's counts to the global counter.
Add appropriate IRQ protection in the cpu-hotplug callback path.
Signed-off-by: Gautham R Shenoy <ego@in.ibm.com>
provide a way to tell lockdep about percpu_counters that are supposed to be
used from irq safe contexts.
alloc_percpu can fail, propagate that error.
Provide an accurate version of percpu_counter_read.
s/percpu_counter_sum/&_positive/
Because its consitent with percpu_counter_read*
Provide a method to set a percpu counter to a specified value.
percpu_counter is a s64 counter, make _add consitent.
Because the current batch setup has an quadric error bound on the counter,
allow for an alternative setup.
s/percpu_counter_mod/percpu_counter_add/
Because its a better name, _mod implies modulo.
Now that we have implemented hotunplug-time counter spilling,
percpu_counter_sum() only needs to look at online CPUs.
Cc: Gautham R Shenoy <ego@in.ibm.com>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
per-cpu counters presently must iterate over all possible CPUs in the
exhaustive percpu_counter_sum().
But it can be much better to only iterate over the presently-online CPUs. To
do this, we must arrange for an offlined CPU's count to be spilled into the
counter's central count.
We can do this for all percpu_counters in the machine by linking them into a
single global list and walking that list at CPU_DEAD time.
(I hope. Might have race windows in which the percpu_counter_sum() count is
inaccurate?)
free blocks counter
The percpu counter data type are changed in this set of patches to support
more users like ext3 who need more than 32 bit to store the free blocks
total in the filesystem.
- Generic perpcu counters data type changes. The size of the global counter
and local counter were explictly specified using s64 and s32. The global
counter is changed from long to s64, while the local counter is changed from
long to s32, so we could avoid doing 64 bit update in most cases.
- Users of the percpu counters are updated to make use of the new
percpu_counter_init() routine now taking an additional parameter to allow
users to pass the initial value of the global counter.
- Move percpu_counter routines from mm/swap.c to lib/percpu_counter.c
Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org>
