Introduce helper any_tag_set() rather than repeat the same code sequence 4
times.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Reiser4 uses radix trees to solve a trouble reiser4_readdir has serving nfs
requests.
Unfortunately, radix tree api lacks an operation suitable for modifying
existing entry. This patch adds radix_tree_lookup_slot which returns pointer
to found item within the tree. That location can be then updated.
Both Nick and Christoph Lameter have patches which need this as well.
- added typedef unsigned int __nocast gfp_t;
- replaced __nocast uses for gfp flags with gfp_t - it gives exactly
the same warnings as far as sparse is concerned, doesn't change
generated code (from gcc point of view we replaced unsigned int with
typedef) and documents what's going on far better.
Fix the sparse warning "implicit cast to nocast type"
Signed-off-by: Victor Fusco <victor@cetuc.puc-rio.br>
Signed-off-by: Domen Puncer <domen@coderock.org>
cases
Simple patch to radix_tree_tag_get() to return different values for non
present node and tag unset.
The function is not used by any in-kernel callers (yet), but this
information is definitely useful.
- There is frequent use of indirections in the radix code. This patch
removes those indirections, makes the code more readable and allows
the compilers to generate better code.
- Removing indirections allows the removal of several casts.
- Removing indirections allows the reduction of the radix_tree_path
size from 3 to 2 words.
- Use pathp-> consistently.
- Remove unnecessary tmp variable in radix_tree_insert
- Separate the upper layer processing from the lowest layer in __lookup()
in order to make it easier to understand what is going on and allow
compilers to generate better code for the loop.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Add a new section called ".data.read_mostly" for data items that are read
frequently and rarely written to like cpumaps etc.
If these maps are placed in the .data section then these frequenly read
items may end up in cachelines with data is is frequently updated. In that
case all processors in an SMP system must needlessly reload the cachelines
again and again containing elements of those frequently used variables.
The ability to share these cachelines will allow each cpu in an SMP system
to keep local copies of those shared cachelines thereby optimizing
performance.
Signed-off-by: Alok N Kataria <alokk@calsoftinc.com>
Signed-off-by: Shobhit Dayal <shobhit@calsoftinc.com>
Signed-off-by: Christoph Lameter <christoph@scalex86.org>
Signed-off-by: Shai Fultheim <shai@scalex86.org>
infrastructure for it.
Let it rip!
