[ Upstream commit b7e9728f3d7fc5c5c8508d99f1675212af5cfd49 ]
Attempting to allocate an entry at 0xffffffff when one is already
present would succeed in allocating one at 2^32, which would confuse
everything. Return -ENOSPC in this case, as expected.
Signed-off-by: Matthew Wilcox (Oracle) <willy@infradead.org>
commit 7a4deea1aa8bddfed4ef1b35fc2b6732563d8ad5 upstream.
If the radix tree underlying the IDR happens to be full and we attempt
to remove an id which is larger than any id in the IDR, we will call
__radix_tree_delete() with an uninitialised 'slot' pointer, at which
point anything could happen. This was easiest to hit with a single
entry at id 0 and attempting to remove a non-0 id, but it could have
happened with 64 entries and attempting to remove an id >= 64.
Roman said:
The syzcaller test boils down to opening /dev/kvm, creating an
eventfd, and calling a couple of KVM ioctls. None of this requires
superuser. And the result is dereferencing an uninitialized pointer
which is likely a crash. The specific path caught by syzbot is via
KVM_HYPERV_EVENTD ioctl which is new in 4.17. But I guess there are
other user-triggerable paths, so cc:stable is probably justified.
Matthew added:
We have around 250 calls to idr_remove() in the kernel today. Many of
them pass an ID which is embedded in the object they're removing, so
they're safe. Picking a few likely candidates:
drivers/firewire/core-cdev.c looks unsafe; the ID comes from an ioctl.
drivers/gpu/drm/amd/amdgpu/amdgpu_ctx.c is similar
drivers/atm/nicstar.c could be taken down by a handcrafted packet
Link: http://lkml.kernel.org/r/20180518175025.GD6361@bombadil.infradead.org
Fixes: 0a835c4f090a ("Reimplement IDR and IDA using the radix tree")
Reported-by: <syzbot+35666cba7f0a337e2e79@syzkaller.appspotmail.com>
Debugged-by: Roman Kagan <rkagan@virtuozzo.com>
Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com>
Cc: <stable@vger.kernel.org>
commit 9f418224e8114156d995b98fa4e0f4fd21f685fe upstream.
Fix a race in the multi-order iteration code which causes the kernel to
hit a GP fault. This was first seen with a production v4.15 based
kernel (4.15.6-300.fc27.x86_64) utilizing a DAX workload which used
order 9 PMD DAX entries.
The race has to do with how we tear down multi-order sibling entries
when we are removing an item from the tree. Remember for example that
an order 2 entry looks like this:
struct radix_tree_node.slots[] = [entry][sibling][sibling][sibling]
where 'entry' is in some slot in the struct radix_tree_node, and the
three slots following 'entry' contain sibling pointers which point back
to 'entry.'
When we delete 'entry' from the tree, we call :
radix_tree_delete()
radix_tree_delete_item()
replace_slot()
replace_slot() first removes the siblings in order from the first to the
last, then at then replaces 'entry' with NULL. This means that for a
brief period of time we end up with one or more of the siblings removed,
so:
struct radix_tree_node.slots[] = [entry][NULL][sibling][sibling]
This causes an issue if you have a reader iterating over the slots in
the tree via radix_tree_for_each_slot() while only under
rcu_read_lock()/rcu_read_unlock() protection. This is a common case in
mm/filemap.c.
The issue is that when __radix_tree_next_slot() => skip_siblings() tries
to skip over the sibling entries in the slots, it currently does so with
an exact match on the slot directly preceding our current slot.
Normally this works:
V preceding slot
^ current slot
This lets you find the first sibling, and you skip them all in order.
But in the case where one of the siblings is NULL, that slot is skipped
and then our sibling detection is interrupted:
V preceding slot
^ current slot
This means that the sibling pointers aren't recognized since they point
all the way back to 'entry', so we think that they are normal internal
radix tree pointers. This causes us to think we need to walk down to a
struct radix_tree_node starting at the address of 'entry'.
In a real running kernel this will crash the thread with a GP fault when
you try and dereference the slots in your broken node starting at
'entry'.
We fix this race by fixing the way that skip_siblings() detects sibling
nodes. Instead of testing against the preceding slot we instead look
for siblings via is_sibling_entry() which compares against the position
of the struct radix_tree_node.slots[] array. This ensures that sibling
entries are properly identified, even if they are no longer contiguous
with the 'entry' they point to.
Link: http://lkml.kernel.org/r/20180503192430.7582-6-ross.zwisler@linux.intel.com
Fixes: 148deab223b2 ("radix-tree: improve multiorder iterators")
Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Reported-by: CR, Sapthagirish <sapthagirish.cr@intel.com>
Cc: Matthew Wilcox <willy@infradead.org>
Cc: Dan Williams <dan.j.williams@intel.com>
__radix_tree_preload() only disables preemption if no error is returned.
So we really need to make sure callers always check the return value.
idr_preload() contract is to always disable preemption, so we need
to add a missing preempt_disable() if an error happened.
Similarly, ida_pre_get() only needs to call preempt_enable() in the
case no error happened.
Link: http://lkml.kernel.org/r/1504637190.15310.62.camel@edumazet-glaptop3.roam.corp.google.com
Fixes: 7ad3d4d85c7a ("ida: Move ida_bitmap to a percpu variable")
Cc: Matthew Wilcox <mawilcox@microsoft.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Cc: <stable@vger.kernel.org> [4.11+]
Pull networking updates from David Miller:
1) Support ipv6 checksum offload in sunvnet driver, from Shannon
Nelson.
2) Move to RB-tree instead of custom AVL code in inetpeer, from Eric
Dumazet.
3) Allow generic XDP to work on virtual devices, from John Fastabend.
4) Add bpf device maps and XDP_REDIRECT, which can be used to build
arbitrary switching frameworks using XDP. From John Fastabend.
5) Remove UFO offloads from the tree, gave us little other than bugs.
6) Remove the IPSEC flow cache, from Florian Westphal.
7) Support ipv6 route offload in mlxsw driver.
8) Support VF representors in bnxt_en, from Sathya Perla.
9) Add support for forward error correction modes to ethtool, from
Vidya Sagar Ravipati.
10) Add time filter for packet scheduler action dumping, from Jamal Hadi
Salim.
11) Extend the zerocopy sendmsg() used by virtio and tap to regular
sockets via MSG_ZEROCOPY. From Willem de Bruijn.
12) Significantly rework value tracking in the BPF verifier, from Edward
Cree.
13) Add new jump instructions to eBPF, from Daniel Borkmann.
14) Rework rtnetlink plumbing so that operations can be run without
taking the RTNL semaphore. From Florian Westphal.
15) Support XDP in tap driver, from Jason Wang.
16) Add 32-bit eBPF JIT for ARM, from Shubham Bansal.
17) Add Huawei hinic ethernet driver.
18) Allow to report MD5 keys in TCP inet_diag dumps, from Ivan
Delalande.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1780 commits)
i40e: point wb_desc at the nvm_wb_desc during i40e_read_nvm_aq
i40e: avoid NVM acquire deadlock during NVM update
drivers: net: xgene: Remove return statement from void function
drivers: net: xgene: Configure tx/rx delay for ACPI
drivers: net: xgene: Read tx/rx delay for ACPI
rocker: fix kcalloc parameter order
rds: Fix non-atomic operation on shared flag variable
net: sched: don't use GFP_KERNEL under spin lock
vhost_net: correctly check tx avail during rx busy polling
net: mdio-mux: add mdio_mux parameter to mdio_mux_init()
rxrpc: Make service connection lookup always check for retry
net: stmmac: Delete dead code for MDIO registration
gianfar: Fix Tx flow control deactivation
cxgb4: Ignore MPS_TX_INT_CAUSE[Bubble] for T6
cxgb4: Fix pause frame count in t4_get_port_stats
cxgb4: fix memory leak
tun: rename generic_xdp to skb_xdp
tun: reserve extra headroom only when XDP is set
net: dsa: bcm_sf2: Configure IMP port TC2QOS mapping
net: dsa: bcm_sf2: Advertise number of egress queues
The following new APIs are added:
int idr_alloc_ext(struct idr *idr, void *ptr, unsigned long *index,
unsigned long start, unsigned long end, gfp_t gfp);
void *idr_remove_ext(struct idr *idr, unsigned long id);
void *idr_find_ext(const struct idr *idr, unsigned long id);
void *idr_replace_ext(struct idr *idr, void *ptr, unsigned long id);
void *idr_get_next_ext(struct idr *idr, unsigned long *nextid);
Signed-off-by: Chris Mi <chrism@mellanox.com>
Signed-off-by: Jiri Pirko <jiri@mellanox.com>
This was the competing idea long ago, but it was only with the rewrite
of the idr as an radixtree and using the radixtree directly ourselves,
along with the realisation that we can store the vma directly in the
radixtree and only need a list for the reverse mapping, that made the
patch performant enough to displace using a hashtable. Though the vma ht
is fast and doesn't require any extra allocation (as we can embed the node
inside the vma), it does require a thread for resizing and serialization
and will have the occasional slow lookup. That is hairy enough to
investigate alternatives and favour them if equivalent in peak performance.
One advantage of allocating an indirection entry is that we can support a
single shared bo between many clients, something that was done on a
first-come first-serve basis for shared GGTT vma previously. To offset
the extra allocations, we create yet another kmem_cache for them.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Tvrtko Ursulin <tvrtko.ursulin@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20170816085210.4199-5-chris@chris-wilson.co.uk
The current implementation of the reclaim lockup detection can lead to
false positives and those even happen and usually lead to tweak the code
to silence the lockdep by using GFP_NOFS even though the context can use
__GFP_FS just fine.
See
http://lkml.kernel.org/r/20160512080321.GA18496@dastard
as an example.
[ INFO: inconsistent lock state ]
4.5.0-rc2+ #4 Tainted: G O
inconsistent {RECLAIM_FS-ON-R} -> {IN-RECLAIM_FS-W} usage.
kswapd0/543 [HC0[0]:SC0[0]:HE1:SE1] takes:
(&xfs_nondir_ilock_class){++++-+}, at: xfs_ilock+0x177/0x200 [xfs]
{RECLAIM_FS-ON-R} state was registered at:
mark_held_locks+0x79/0xa0
lockdep_trace_alloc+0xb3/0x100
kmem_cache_alloc+0x33/0x230
kmem_zone_alloc+0x81/0x120 [xfs]
xfs_refcountbt_init_cursor+0x3e/0xa0 [xfs]
__xfs_refcount_find_shared+0x75/0x580 [xfs]
xfs_refcount_find_shared+0x84/0xb0 [xfs]
xfs_getbmap+0x608/0x8c0 [xfs]
xfs_vn_fiemap+0xab/0xc0 [xfs]
do_vfs_ioctl+0x498/0x670
SyS_ioctl+0x79/0x90
entry_SYSCALL_64_fastpath+0x12/0x6f
CPU0
lock(&xfs_nondir_ilock_class);
<Interrupt>
*** DEADLOCK ***
3 locks held by kswapd0/543:
stack backtrace:
CPU: 0 PID: 543 Comm: kswapd0 Tainted: G O 4.5.0-rc2+ #4
Call Trace:
lock_acquire+0xd8/0x1e0
down_write_nested+0x5e/0xc0
xfs_reflink_cancel_cow_range+0x150/0x300 [xfs]
xfs_fs_evict_inode+0xdc/0x1e0 [xfs]
evict+0xc5/0x190
dispose_list+0x39/0x60
prune_icache_sb+0x4b/0x60
super_cache_scan+0x14f/0x1a0
shrink_slab.part.63.constprop.79+0x1e9/0x4e0
shrink_zone+0x15e/0x170
kswapd+0x4f1/0xa80
kthread+0xf2/0x110
ret_from_fork+0x3f/0x70
To quote Dave:
"Ignoring whether reflink should be doing anything or not, that's a
"xfs_refcountbt_init_cursor() gets called both outside and inside
transactions" lockdep false positive case. The problem here is lockdep
has seen this allocation from within a transaction, hence a GFP_NOFS
allocation, and now it's seeing it in a GFP_KERNEL context. Also note
that we have an active reference to this inode.
So, because the reclaim annotations overload the interrupt level
detections and it's seen the inode ilock been taken in reclaim
("interrupt") context, this triggers a reclaim context warning where
it thinks it is unsafe to do this allocation in GFP_KERNEL context
holding the inode ilock..."
This sounds like a fundamental problem of the reclaim lock detection.
It is really impossible to annotate such a special usecase IMHO unless
the reclaim lockup detection is reworked completely. Until then it is
much better to provide a way to add "I know what I am doing flag" and
mark problematic places. This would prevent from abusing GFP_NOFS flag
which has a runtime effect even on configurations which have lockdep
disabled.
Introduce __GFP_NOLOCKDEP flag which tells the lockdep gfp tracking to
skip the current allocation request.
While we are at it also make sure that the radix tree doesn't
accidentaly override tags stored in the upper part of the gfp_mask.
Link: http://lkml.kernel.org/r/20170306131408.9828-3-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Suggested-by: Peter Zijlstra <peterz@infradead.org>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Chris Mason <clm@fb.com>
Cc: David Sterba <dsterba@suse.cz>
Cc: Jan Kara <jack@suse.cz>
Cc: Brian Foster <bfoster@redhat.com>
Cc: Darrick J. Wong <darrick.wong@oracle.com>
Cc: Nikolay Borisov <nborisov@suse.com>
There's a relatively rare race where we look at the per-cpu preallocated
IDA bitmap, see it's NULL, allocate a new one, and atomically update it.
If the kmalloc() happened to sleep and we were rescheduled to a different
CPU, or an interrupt came in at the exact right time, another task
might have successfully allocated a bitmap and already deposited it.
I forgot what the semantics of cmpxchg() were and ended up freeing the
wrong bitmap leading to KASAN reporting a use-after-free.
Dmitry found the bug with syzkaller & wrote the patch. I wrote the test
case that will reproduce the bug without his patch being applied.
Pull IDR rewrite from Matthew Wilcox:
"The most significant part of the following is the patch to rewrite the
IDR & IDA to be clients of the radix tree. But there's much more,
including an enhancement of the IDA to be significantly more space
efficient, an IDR & IDA test suite, some improvements to the IDR API
(and driver changes to take advantage of those improvements), several
improvements to the radix tree test suite and RCU annotations.
The IDR & IDA rewrite had a good spin in linux-next and Andrew's tree
for most of the last cycle. Coupled with the IDR test suite, I feel
pretty confident that any remaining bugs are quite hard to hit. 0-day
did a great job of watching my git tree and pointing out problems; as
it hit them, I added new test-cases to be sure not to be caught the
same way twice"
Willy goes on to expand a bit on the IDR rewrite rationale:
"The radix tree and the IDR use very similar data structures.
Merging the two codebases lets us share the memory allocation pools,
and results in a net deletion of 500 lines of code. It also opens up
the possibility of exposing more of the features of the radix tree to
users of the IDR (and I have some interesting patches along those
lines waiting for 4.12)
It also shrinks the size of the 'struct idr' from 40 bytes to 24 which
will shrink a fair few data structures that embed an IDR"
* 'idr-4.11' of git://git.infradead.org/users/willy/linux-dax: (32 commits)
radix tree test suite: Add config option for map shift
idr: Add missing __rcu annotations
radix-tree: Fix __rcu annotations
radix-tree: Add rcu_dereference and rcu_assign_pointer calls
radix tree test suite: Run iteration tests for longer
radix tree test suite: Fix split/join memory leaks
radix tree test suite: Fix leaks in regression2.c
radix tree test suite: Fix leaky tests
radix tree test suite: Enable address sanitizer
radix_tree_iter_resume: Fix out of bounds error
radix-tree: Store a pointer to the root in each node
radix-tree: Chain preallocated nodes through ->parent
radix tree test suite: Dial down verbosity with -v
radix tree test suite: Introduce kmalloc_verbose
idr: Return the deleted entry from idr_remove
radix tree test suite: Build separate binaries for some tests
ida: Use exceptional entries for small IDAs
radix-tree: Add radix_tree_iter_delete
Many places were missing __rcu annotations. A few places needed a few
lines of explanation about why it was safe to not use RCU accessors.
Add a custom CFLAGS setting to the Makefile to ensure that new patches
don't miss RCU annotations.
Some of these have been missing for many years. Others were recently
introduced by me. Fortunately, we have tools that help us find such
things.
The address sanitizer occasionally finds an out of bounds error while
running the test-suite. It turned out to be a read of the pointer
immediately next to the tree root, but this out of bounds error could
have occurred elsewhere. This happens because radix_tree_iter_resume()
dereferences 'slot' before checking whether we've come to the end of
the chunk. We can just delete this line; the value was never used.
Instead of having this mysterious private_data in each radix_tree_node,
store a pointer to the root, which can be useful for debugging. This also
relieves the mm code from the duty of updating it.
Chaining through the ->private_data member means we have to zero
->private_data after removing preallocated nodes from the list.
We're about to initialise ->parent anyway, so we can avoid zeroing it.
We can use the root entry as a bitmap and save allocating a 128 byte
bitmap for an IDA that contains only a few entries (30 on a 32-bit
machine, 62 on a 64-bit machine). This costs about 300 bytes of kernel
text on x86-64, so as long as 3 IDAs fall into this category, this
is a net win for memory consumption.
Thanks to Rasmus Villemoes for his work documenting the problem and
collecting statistics on IDAs.
When we preload the IDA, we allocate an IDA bitmap. Instead of storing
that preallocated bitmap in the IDA, we store it in a percpu variable.
Generally there are more IDAs in the system than CPUs, so this cuts down
on the number of preallocated bitmaps that are unused, and about half
of the IDA users did not call ida_destroy() so they were leaking IDA
bitmaps.
The IDR is very similar to the radix tree. It has some functionality that
the radix tree did not have (alloc next free, cyclic allocation, a
callback-based for_each, destroy tree), which is readily implementable on
top of the radix tree. A few small changes were needed in order to use a
tag to represent nodes with free space below them. More extensive
changes were needed to support storing NULL as a valid entry in an IDR.
Plain radix trees still interpret NULL as a not-present entry.
The IDA is reimplemented as a client of the newly enhanced radix tree. As
in the current implementation, it uses a bitmap at the last level of the
tree.
Signed-off-by: Matthew Wilcox <willy@infradead.org>
Tested-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: Tejun Heo <tj@kernel.org>
Factor the deletion code out into __radix_tree_delete() and provide a
nice iterator-based wrapper around it. If we free the node, advance
the iterator to avoid reading from freed memory.
The counterpart to radix_tree_iter_tag_set(), used by the IDR code
Reviewed-by: Rehas Sachdeva <aquannie@gmail.com>
It will be used in drivers/md/raid5-cache.c
Signed-off-by: Song Liu <songliubraving@fb.com>
Signed-off-by: Shaohua Li <shli@fb.com>
If we're just getting the value of a tag, or looking up an entry,
we won't modify the radix tree, so we can declare these functions as
taking a const pointer. Mostly for documentation purposes, though it
might help code generation.
The newly introduced warning in radix_tree_free_nodes() was testing the
wrong variable; it should have been 'old' instead of 'node'.
Fixes: ea07b862ac8e ("mm: workingset: fix use-after-free in shadow node shrinker")
Link: http://lkml.kernel.org/r/20170118163746.GA32495@cmpxchg.org
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Several people report seeing warnings about inconsistent radix tree
nodes followed by crashes in the workingset code, which all looked like
use-after-free access from the shadow node shrinker.
Dave Jones managed to reproduce the issue with a debug patch applied,
which confirmed that the radix tree shrinking indeed frees shadow nodes
while they are still linked to the shadow LRU:
WARNING: CPU: 2 PID: 53 at lib/radix-tree.c:643 delete_node+0x1e4/0x200
CPU: 2 PID: 53 Comm: kswapd0 Not tainted 4.10.0-rc2-think+ #3
Call Trace:
__radix_tree_delete_node+0xd/0x10
shadow_lru_isolate+0xe6/0x220
__list_lru_walk_one.isra.4+0x9b/0x190
list_lru_walk_one+0x23/0x30
scan_shadow_nodes+0x2e/0x40
shrink_slab.part.44+0x23d/0x5d0
shrink_node+0x22c/0x330
kswapd+0x392/0x8f0
This is the WARN_ON_ONCE(!list_empty(&node->private_list)) placed in the
inlined radix_tree_shrink().
The problem is with 14b468791fa9 ("mm: workingset: move shadow entry
tracking to radix tree exceptional tracking"), which passes an update
callback into the radix tree to link and unlink shadow leaf nodes when
tree entries change, but forgot to pass the callback when reclaiming a
shadow node.
While the reclaimed shadow node itself is unlinked by the shrinker, its
deletion from the tree can cause the left-most leaf node in the tree to
be shrunk. If that happens to be a shadow node as well, we don't unlink
it from the LRU as we should.
Consider this tree, where the s are shadow entries:
root->rnode
[0 n]
[s ] [sssss]
Now the shadow node shrinker reclaims the rightmost leaf node through
the shadow node LRU:
root->rnode
[0 ]
[s ]
Because the parent of the deleted node is the first level below the
root and has only one child in the left-most slot, the intermediate
level is shrunk and the node containing the single shadow is put in
its place:
root->rnode
[s ]
The shrinker again sees a single left-most slot in a first level node
and thus decides to store the shadow in root->rnode directly and free
the node - which is a leaf node on the shadow node LRU.
root->rnode
s
Without the update callback, the freed node remains on the shadow LRU,
where it causes later shrinker runs to crash.
Pass the node updater callback into __radix_tree_delete_node() in case
the deletion causes the left-most branch in the tree to collapse too.
Also add warnings when linked nodes are freed right away, rather than
wait for the use-after-free when the list is scanned much later.
Fixes: 14b468791fa9 ("mm: workingset: move shadow entry tracking to radix tree exceptional tracking")
Reported-by: Dave Chinner <david@fromorbit.com>
Reported-by: Hugh Dickins <hughd@google.com>
Reported-by: Andrea Arcangeli <aarcange@redhat.com>
Reported-and-tested-by: Dave Jones <davej@codemonkey.org.uk>
Cc: Chris Leech <cleech@redhat.com>
Cc: Lee Duncan <lduncan@suse.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Matthew Wilcox <mawilcox@linuxonhyperv.com>
[ This resurrects commit 53855d10f456, which was reverted in
2b41226b39b6. It depended on commit d544abd5ff7d ("lib/radix-tree:
Convert to hotplug state machine") so now it is correct to apply ]
Patch "lib/radix-tree: Convert to hotplug state machine" breaks the test
suite as it adds a call to cpuhp_setup_state_nocalls() which is not
currently emulated in the test suite. Add it, and delete the emulation
of the old CPU hotplug mechanism.
Link: http://lkml.kernel.org/r/1480369871-5271-36-git-send-email-mawilcox@linuxonhyperv.com
radix_tree_join() was freeing nodes with a non-zero ->exceptional count,
and radix_tree_split() wasn't zeroing ->exceptional when it allocated
the new node. Fix this by making all callers of radix_tree_node_alloc()
pass in the new counts (and some other always-initialised fields), which
will prevent the problem recurring if in future we decide to do
something similar.
Link: http://lkml.kernel.org/r/1481667692-14500-3-git-send-email-mawilcox@linuxonhyperv.com
When replacing an entry with NULL, we need to delete any sibling
entries. Also account deleting exceptional entries properly. Also fix
a bug with radix_tree_iter_replace() where we would fail to remove
entirely freed nodes. Also fix accounting bug when switching between
normal and exceptional entries with replace_slot. Also add testcases
for all these bugs.
Link: http://lkml.kernel.org/r/1480369871-5271-61-git-send-email-mawilcox@linuxonhyperv.com
Calculate how many nodes we need to allocate to split an old_order entry
into multiple entries, each of size new_order. The test suite checks
that we allocated exactly the right number of nodes; neither too many
(checked by rtp->nr == 0), nor too few (checked by comparing
nr_allocated before and after the call to radix_tree_split()).
Link: http://lkml.kernel.org/r/1480369871-5271-60-git-send-email-mawilcox@linuxonhyperv.com
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
This new function splits a larger multiorder entry into smaller entries
(potentially multi-order entries). These entries are initialised to
RADIX_TREE_RETRY to ensure that RCU walkers who see this state aren't
confused. The caller should then call radix_tree_for_each_slot() and
radix_tree_replace_slot() in order to turn these retry entries into the
intended new entries. Tags are replicated from the original multiorder
entry into each new entry.
Link: http://lkml.kernel.org/r/1480369871-5271-59-git-send-email-mawilcox@linuxonhyperv.com
This new function allows for the replacement of many smaller entries in
the radix tree with one larger multiorder entry. From the point of view
of an RCU walker, they may see a mixture of the smaller entries and the
large entry during the same walk, but they will never see NULL for an
index which was populated before the join.
Link: http://lkml.kernel.org/r/1480369871-5271-58-git-send-email-mawilcox@linuxonhyperv.com
This is an exceptionally complicated function with just one caller
(tag_pages_for_writeback). We devote a large portion of the runtime of
the test suite to testing this one function which has one caller. By
introducing the new function radix_tree_iter_tag_set(), we can eliminate
all of the complexity while keeping the performance. The caller can now
use a fairly standard radix_tree_for_each() loop, and it doesn't need to
worry about tricksy things like 'start' wrapping.
The test suite continues to spend a large amount of time investigating
this function, but now it's testing the underlying primitives such as
radix_tree_iter_resume() and the radix_tree_for_each_tagged() iterator
which are also used by other parts of the kernel.
Link: http://lkml.kernel.org/r/1480369871-5271-57-git-send-email-mawilcox@linuxonhyperv.com
This rather complicated function can be better implemented as an
iterator. It has only one caller, so move the functionality to the only
place that needs it. Update the test suite to follow the same pattern.
Link: http://lkml.kernel.org/r/1480369871-5271-56-git-send-email-mawilcox@linuxonhyperv.com
Acked-by: Konstantin Khlebnikov <koct9i@gmail.com>
This fixes several interlinked problems with the iterators in the
presence of multiorder entries.
1. radix_tree_iter_next() would only advance by one slot, which would
result in the iterators returning the same entry more than once if
there were sibling entries.
2. radix_tree_next_slot() could return an internal pointer instead of
a user pointer if a tagged multiorder entry was immediately followed by
an entry of lower order.
3. radix_tree_next_slot() expanded to a lot more code than it used to
when multiorder support was compiled in. And I wasn't comfortable with
entry_to_node() being in a header file.
Fixing radix_tree_iter_next() for the presence of sibling entries
necessarily involves examining the contents of the radix tree, so we now
need to pass 'slot' to radix_tree_iter_next(), and we need to change the
calling convention so it is called *before* dropping the lock which
protects the tree. Also rename it to radix_tree_iter_resume(), as some
people thought it was necessary to call radix_tree_iter_next() each time
around the loop.
radix_tree_next_slot() becomes closer to how it looked before multiorder
support was introduced. It only checks to see if the next entry in the
chunk is a sibling entry or a pointer to a node; this should be rare
enough that handling this case out of line is not a performance impact
(and such impact is amortised by the fact that the entry we just
processed was a multiorder entry). Also, radix_tree_next_slot() used to
force a new chunk lookup for untagged entries, which is more expensive
than the out of line sibling entry skipping.
Link: http://lkml.kernel.org/r/1480369871-5271-55-git-send-email-mawilcox@linuxonhyperv.com
Print the indices of the entries as unsigned (instead of signed)
integers and print the parent node of each entry to help navigate around
larger trees where the layout is not quite so obvious. Print the
indices covered by a node. Rearrange the order of fields printed so the
indices and parents line up for each type of entry.
Link: http://lkml.kernel.org/r/1480369871-5271-53-git-send-email-mawilcox@linuxonhyperv.com
Since this function is specialised to the radix tree, pass in the node
and tag to calculate the address of the bitmap in
radix_tree_find_next_bit() instead of the caller. Likewise, there is no
need to pass in the size of the bitmap.
Link: http://lkml.kernel.org/r/1480369871-5271-52-git-send-email-mawilcox@linuxonhyperv.com
Similar to node_tag_clear(), factor node_tag_set() out of
radix_tree_range_tag_if_tagged().
Link: http://lkml.kernel.org/r/1480369871-5271-51-git-send-email-mawilcox@linuxonhyperv.com
I want to be able to reference node->parent after freeing node.
Currently node->parent is in a union with rcu_head, so it is overwritten
when the node is put on the RCU list. We know that private_list is not
referenced after the node is freed, so it is safe for these two members
to share space.
Link: http://lkml.kernel.org/r/1480369871-5271-50-git-send-email-mawilcox@linuxonhyperv.com
Merge updates from Andrew Morton:
- various misc bits
- most of MM (quite a lot of MM material is awaiting the merge of
linux-next dependencies)
- kasan
- printk updates
- procfs updates
- MAINTAINERS
- /lib updates
- checkpatch updates
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (123 commits)
init: reduce rootwait polling interval time to 5ms
binfmt_elf: use vmalloc() for allocation of vma_filesz
checkpatch: don't emit unified-diff error for rename-only patches
checkpatch: don't check c99 types like uint8_t under tools
checkpatch: avoid multiple line dereferences
checkpatch: don't check .pl files, improve absolute path commit log test
scripts/checkpatch.pl: fix spelling
checkpatch: don't try to get maintained status when --no-tree is given
lib/ida: document locking requirements a bit better
lib/rbtree.c: fix typo in comment of ____rb_erase_color
lib/Kconfig.debug: make CONFIG_STRICT_DEVMEM depend on CONFIG_DEVMEM
MAINTAINERS: add drm and drm/i915 irc channels
MAINTAINERS: add "C:" for URI for chat where developers hang out
MAINTAINERS: add drm and drm/i915 bug filing info
MAINTAINERS: add "B:" for URI where to file bugs
get_maintainer: look for arbitrary letter prefixes in sections
printk: add Kconfig option to set default console loglevel
printk/sound: handle more message headers
printk/btrfs: handle more message headers
printk/kdb: handle more message headers
Currently, we track the shadow entries in the page cache in the upper
bits of the radix_tree_node->count, behind the back of the radix tree
implementation. Because the radix tree code has no awareness of them,
we rely on random subtleties throughout the implementation (such as the
node->count != 1 check in the shrinking code, which is meant to exclude
multi-entry nodes but also happens to skip nodes with only one shadow
entry, as that's accounted in the upper bits). This is error prone and
has, in fact, caused the bug fixed in d3798ae8c6f3 ("mm: filemap: don't
plant shadow entries without radix tree node").
To remove these subtleties, this patch moves shadow entry tracking from
the upper bits of node->count to the existing counter for exceptional
entries. node->count goes back to being a simple counter of valid
entries in the tree node and can be shrunk to a single byte.
This vastly simplifies the page cache code. All accounting happens
natively inside the radix tree implementation, and maintaining the LRU
linkage of shadow nodes is consolidated into a single function in the
workingset code that is called for leaf nodes affected by a change in
the page cache tree.
This also removes the last user of the __radix_delete_node() return
value. Eliminate it.
Link: http://lkml.kernel.org/r/20161117193211.GE23430@cmpxchg.org
Support handing __radix_tree_replace() a callback that gets invoked for
all leaf nodes that change or get freed as a result of the slot
replacement, to assist users tracking nodes with node->private_list.
This prepares for putting page cache shadow entries into the radix tree
root again and drastically simplifying the shadow tracking.
Link: http://lkml.kernel.org/r/20161117193134.GD23430@cmpxchg.org
Suggested-by: Jan Kara <jack@suse.cz>
Page cache shadow entry handling will be a lot simpler when it can use a
single generic replacement function for pages, shadow entries, and
emptying slots.
Make __radix_tree_replace() properly account insertions and deletions in
node->count and garbage collect nodes as they become empty. Then
re-implement radix_tree_delete() on top of it.
Link: http://lkml.kernel.org/r/20161117193058.GC23430@cmpxchg.org
The bug in khugepaged fixed earlier in this series shows that radix tree
slot replacement is fragile; and it will become more so when not only
NULL<->!NULL transitions need to be caught but transitions from and to
exceptional entries as well. We need checks.
Re-implement radix_tree_replace_slot() on top of the sanity-checked
__radix_tree_replace(). This requires existing callers to also pass the
radix tree root, but it'll warn us when somebody replaces slots with
contents that need proper accounting (transitions between NULL entries,
real entries, exceptional entries) and where a replacement through the
slot pointer would corrupt the radix tree node counts.
Link: http://lkml.kernel.org/r/20161117193021.GB23430@cmpxchg.org
The way the page cache is sneaking shadow entries of evicted pages into
the radix tree past the node entry accounting and tracking them manually
in the upper bits of node->count is fraught with problems.
These shadow entries are marked in the tree as exceptional entries,
which are a native concept to the radix tree. Maintain an explicit
counter of exceptional entries in the radix tree node. Subsequent
patches will switch shadow entry tracking over to that counter.
DAX and shmem are the other users of exceptional entries. Since slot
replacements that change the entry type from regular to exceptional must
now be accounted, introduce a __radix_tree_replace() function that does
replacement and accounting, and switch DAX and shmem over.
The increase in radix tree node size is temporary. A followup patch
switches the shadow tracking to this new scheme and we'll no longer need
the upper bits in node->count and shrink that back to one byte.
Link: http://lkml.kernel.org/r/20161117192945.GA23430@cmpxchg.org
This reverts commit 53855d10f4567a0577360b6448d52a863929775b.
It shouldn't have come in yet - it depends on the changes in linux-next
that will come in during the next merge window. As Matthew Wilcox says,
the test suite is broken with the current state without the revert.
Requested-by: Matthew Wilcox <mawilcox@microsoft.com>
Install the callbacks via the state machine.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: rt@linutronix.de
Link: http://lkml.kernel.org/r/20161103145021.28528-6-bigeasy@linutronix.de
When the underflow checks were added to workingset_node_shadow_dec(),
they triggered immediately:
kernel BUG at ./include/linux/swap.h:276!
invalid opcode: 0000 [#1] SMP
Modules linked in: isofs usb_storage fuse xt_CHECKSUM ipt_MASQUERADE nf_nat_masquerade_ipv4 tun nf_conntrack_netbios_ns nf_conntrack_broadcast ip6t_REJECT nf_reject_ipv6
soundcore wmi acpi_als pinctrl_sunrisepoint kfifo_buf tpm_tis industrialio acpi_pad pinctrl_intel tpm_tis_core tpm nfsd auth_rpcgss nfs_acl lockd grace sunrpc dm_crypt
CPU: 0 PID: 20929 Comm: blkid Not tainted 4.8.0-rc8-00087-gbe67d60ba944 #1
Hardware name: System manufacturer System Product Name/Z170-K, BIOS 1803 05/06/2016
task: ffff8faa93ecd940 task.stack: ffff8faa7f478000
RIP: page_cache_tree_insert+0xf1/0x100
Call Trace:
__add_to_page_cache_locked+0x12e/0x270
add_to_page_cache_lru+0x4e/0xe0
mpage_readpages+0x112/0x1d0
blkdev_readpages+0x1d/0x20
__do_page_cache_readahead+0x1ad/0x290
force_page_cache_readahead+0xaa/0x100
page_cache_sync_readahead+0x3f/0x50
generic_file_read_iter+0x5af/0x740
blkdev_read_iter+0x35/0x40
__vfs_read+0xe1/0x130
vfs_read+0x96/0x130
SyS_read+0x55/0xc0
entry_SYSCALL_64_fastpath+0x13/0x8f
Code: 03 00 48 8b 5d d8 65 48 33 1c 25 28 00 00 00 44 89 e8 75 19 48 83 c4 18 5b 41 5c 41 5d 41 5e 5d c3 0f 0b 41 bd ef ff ff ff eb d7 <0f> 0b e8 88 68 ef ff 0f 1f 84 00
RIP page_cache_tree_insert+0xf1/0x100
This is a long-standing bug in the way shadow entries are accounted in
the radix tree nodes. The shrinker needs to know when radix tree nodes
contain only shadow entries, no pages, so node->count is split in half
to count shadows in the upper bits and pages in the lower bits.
Unfortunately, the radix tree implementation doesn't know of this and
assumes all entries are in node->count. When there is a shadow entry
directly in root->rnode and the tree is later extended, the radix tree
implementation will copy that entry into the new node and and bump its
node->count, i.e. increases the page count bits. Once the shadow gets
removed and we subtract from the upper counter, node->count underflows
and triggers the warning. Afterwards, without node->count reaching 0
again, the radix tree node is leaked.
Limit shadow entries to when we have actual radix tree nodes and can
count them properly. That means we lose the ability to detect refaults
from files that had only the first page faulted in at eviction time.
Fixes: 449dd6984d0e ("mm: keep page cache radix tree nodes in check")
Reported-and-tested-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: stable@vger.kernel.org
The fixes to the radix tree test suite show that the multi-order case is
broken. The basic reason is that the radix tree code uses tagged
pointers with the "internal" bit in the low bits, and calculating the
pointer indices was supposed to mask off those bits. But gcc will
notice that we then use the index to re-create the pointer, and will
avoid doing the arithmetic and use the tagged pointer directly.
This cleans the code up, using the existing is_sibling_entry() helper to
validate the sibling pointer range (instead of open-coding it), and
using entry_to_node() to mask off the low tag bit from the pointer. And
once you do that, you might as well just use the now cleaned-up pointer
directly.
[ Side note: the multi-order code isn't actually ever used in the kernel
right now, and the only reason I didn't just delete all that code is
that Kirill Shutemov piped up and said:
"Well, my ext4-with-huge-pages patchset[1] uses multi-order entries.
It also converts shmem-with-huge-pages and hugetlb to them.
I'm okay with converting it to other mechanism, but I need
something. (I looked into Konstantin's RFC patchset[2]. It looks
okay, but I don't feel myself qualified to review it as I don't
know much about radix-tree internals.)"
[1] http://lkml.kernel.org/r/20160915115523.29737-1-kirill.shutemov@linux.intel.com
[2] http://lkml.kernel.org/r/147230727479.9957.1087787722571077339.stgit@zurg ]
Reported-by: Matthew Wilcox <mawilcox@microsoft.com>
Cc: Cedric Blancher <cedric.blancher@gmail.com>
Radix trees may be used not only for storing page cache pages, so
unconditionally accounting radix tree nodes to the current memory cgroup
is bad: if a radix tree node is used for storing data shared among
different cgroups we risk pinning dead memory cgroups forever.
So let's only account radix tree nodes if it was explicitly requested by
passing __GFP_ACCOUNT to INIT_RADIX_TREE. Currently, we only want to
account page cache entries, so mark mapping->page_tree so.
Fixes: 58e698af4c63 ("radix-tree: account radix_tree_node to memory cgroup")
Link: http://lkml.kernel.org/r/1470057188-7864-1-git-send-email-vdavydov@virtuozzo.com
Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com>
Cc: <stable@vger.kernel.org> [4.6+]
