path: root/lib/ratelimit.c
2017-10-12lib/ratelimit.c: use deferred printk() versionSergey Senozhatsky
commit 656d61ce9666209c4c4a13c71902d3ee70d1ff6f upstream. printk_ratelimit() invokes ___ratelimit() which may invoke a normal printk() (pr_warn() in this particular case) to warn about suppressed output. Given that printk_ratelimit() may be called from anywhere, that pr_warn() is dangerous - it may end up deadlocking the system. Fix ___ratelimit() by using deferred printk(). Sasha reported the following lockdep error: : Unregister pv shared memory for cpu 8 : select_fallback_rq: 3 callbacks suppressed : process 8583 (trinity-c78) no longer affine to cpu8 : : ====================================================== : WARNING: possible circular locking dependency detected : 4.14.0-rc2-next-20170927+ #252 Not tainted : ------------------------------------------------------ : migration/8/62 is trying to acquire lock: : (&port_lock_key){-.-.}, at: serial8250_console_write() : : but task is already holding lock: : (&rq->lock){-.-.}, at: sched_cpu_dying() : : which lock already depends on the new lock. : : : the existing dependency chain (in reverse order) is: : : -> #3 (&rq->lock){-.-.}: : __lock_acquire() : lock_acquire() : _raw_spin_lock() : task_fork_fair() : sched_fork() : copy_process.part.31() : _do_fork() : kernel_thread() : rest_init() : start_kernel() : x86_64_start_reservations() : x86_64_start_kernel() : verify_cpu() : : -> #2 (&p->pi_lock){-.-.}: : __lock_acquire() : lock_acquire() : _raw_spin_lock_irqsave() : try_to_wake_up() : default_wake_function() : woken_wake_function() : __wake_up_common() : __wake_up_common_lock() : __wake_up() : tty_wakeup() : tty_port_default_wakeup() : tty_port_tty_wakeup() : uart_write_wakeup() : serial8250_tx_chars() : serial8250_handle_irq.part.25() : serial8250_default_handle_irq() : serial8250_interrupt() : __handle_irq_event_percpu() : handle_irq_event_percpu() : handle_irq_event() : handle_level_irq() : handle_irq() : do_IRQ() : ret_from_intr() : native_safe_halt() : default_idle() : arch_cpu_idle() : default_idle_call() : do_idle() : cpu_startup_entry() : rest_init() : start_kernel() : x86_64_start_reservations() : x86_64_start_kernel() : verify_cpu() : : -> #1 (&tty->write_wait){-.-.}: : __lock_acquire() : lock_acquire() : _raw_spin_lock_irqsave() : __wake_up_common_lock() : __wake_up() : tty_wakeup() : tty_port_default_wakeup() : tty_port_tty_wakeup() : uart_write_wakeup() : serial8250_tx_chars() : serial8250_handle_irq.part.25() : serial8250_default_handle_irq() : serial8250_interrupt() : __handle_irq_event_percpu() : handle_irq_event_percpu() : handle_irq_event() : handle_level_irq() : handle_irq() : do_IRQ() : ret_from_intr() : native_safe_halt() : default_idle() : arch_cpu_idle() : default_idle_call() : do_idle() : cpu_startup_entry() : rest_init() : start_kernel() : x86_64_start_reservations() : x86_64_start_kernel() : verify_cpu() : : -> #0 (&port_lock_key){-.-.}: : check_prev_add() : __lock_acquire() : lock_acquire() : _raw_spin_lock_irqsave() : serial8250_console_write() : univ8250_console_write() : console_unlock() : vprintk_emit() : vprintk_default() : vprintk_func() : printk() : ___ratelimit() : __printk_ratelimit() : select_fallback_rq() : sched_cpu_dying() : cpuhp_invoke_callback() : take_cpu_down() : multi_cpu_stop() : cpu_stopper_thread() : smpboot_thread_fn() : kthread() : ret_from_fork() : : other info that might help us debug this: : : Chain exists of: : &port_lock_key --> &p->pi_lock --> &rq->lock : : Possible unsafe locking scenario: : : CPU0 CPU1 : ---- ---- : lock(&rq->lock); : lock(&p->pi_lock); : lock(&rq->lock); : lock(&port_lock_key); : : *** DEADLOCK *** : : 4 locks held by migration/8/62: : #0: (&p->pi_lock){-.-.}, at: sched_cpu_dying() : #1: (&rq->lock){-.-.}, at: sched_cpu_dying() : #2: (printk_ratelimit_state.lock){....}, at: ___ratelimit() : #3: (console_lock){+.+.}, at: vprintk_emit() : : stack backtrace: : CPU: 8 PID: 62 Comm: migration/8 Not tainted 4.14.0-rc2-next-20170927+ #252 : Call Trace: : dump_stack() : print_circular_bug() : check_prev_add() : ? add_lock_to_list.isra.26() : ? check_usage() : ? kvm_clock_read() : ? kvm_sched_clock_read() : ? sched_clock() : ? check_preemption_disabled() : __lock_acquire() : ? __lock_acquire() : ? add_lock_to_list.isra.26() : ? debug_check_no_locks_freed() : ? memcpy() : lock_acquire() : ? serial8250_console_write() : _raw_spin_lock_irqsave() : ? serial8250_console_write() : serial8250_console_write() : ? serial8250_start_tx() : ? lock_acquire() : ? memcpy() : univ8250_console_write() : console_unlock() : ? __down_trylock_console_sem() : vprintk_emit() : vprintk_default() : vprintk_func() : printk() : ? show_regs_print_info() : ? lock_acquire() : ___ratelimit() : __printk_ratelimit() : select_fallback_rq() : sched_cpu_dying() : ? sched_cpu_starting() : ? rcutree_dying_cpu() : ? sched_cpu_starting() : cpuhp_invoke_callback() : ? cpu_disable_common() : take_cpu_down() : ? trace_hardirqs_off_caller() : ? cpuhp_invoke_callback() : multi_cpu_stop() : ? __this_cpu_preempt_check() : ? cpu_stop_queue_work() : cpu_stopper_thread() : ? cpu_stop_create() : smpboot_thread_fn() : ? sort_range() : ? schedule() : ? __kthread_parkme() : kthread() : ? sort_range() : ? kthread_create_on_node() : ret_from_fork() : process 9121 (trinity-c78) no longer affine to cpu8 : smpboot: CPU 8 is now offline Link: http://lkml.kernel.org/r/20170928120405.18273-1-sergey.senozhatsky@gmail.com Fixes: 6b1d174b0c27b ("ratelimit: extend to print suppressed messages on release") Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Reported-by: Sasha Levin <levinsasha928@gmail.com> Reviewed-by: Petr Mladek <pmladek@suse.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Borislav Petkov <bp@suse.de> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-02ratelimit: extend to print suppressed messages on releaseBorislav Petkov
Extend the ratelimiting facility to print the amount of suppressed lines when it is being released. This use case is aimed at short-termed, burst-like users for which we want to output the suppressed lines stats only once, after it has been disposed of. For an example, see /dev/kmsg usage in a follow-on patch. Also, change the printk() line we issue on release to not use "callbacks" as it is misleading: we're not suppressing callbacks but printk() calls. This has been separated from a previous patch by Linus. Link: http://lkml.kernel.org/r/20160716061745.15795-2-bp@alien8.de Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Dave Young <dyoung@redhat.com> Cc: Franck Bui <fbui@suse.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-21ratelimit: fix bug in time interval by resetting right begin timeJaewon Kim
rs->begin in ratelimit is set in two cases. 1) when rs->begin was not initialized 2) when rs->interval was passed For case #2, current ratelimit sets the begin to 0. This incurrs improper suppression. The begin value will be set in the next ratelimit call by 1). Then the time interval check will be always false, and rs->printed will not be initialized. Although enough time passed, ratelimit may return 0 if rs->printed is not less than rs->burst. To reset interval properly, begin should be jiffies rather than 0. For an example code below: static DEFINE_RATELIMIT_STATE(mylimit, 1, 1); for (i = 1; i <= 10; i++) { if (__ratelimit(&mylimit)) printk("ratelimit test count %d\n", i); msleep(3000); } test result in the current code shows suppression even there is 3 seconds sleep. [ 78.391148] ratelimit test count 1 [ 81.295988] ratelimit test count 2 [ 87.315981] ratelimit test count 4 [ 93.336267] ratelimit test count 6 [ 99.356031] ratelimit test count 8 [ 105.376367] ratelimit test count 10 Signed-off-by: Jaewon Kim <jaewon31.kim@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-07lib: reduce the use of module.h wherever possiblePaul Gortmaker
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map them onto including export.h -- or if the file isn't even using those, then just delete the include. Fix up any implicit include dependencies that were being masked by module.h along the way. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-09-13locking, printk: Annotate logbuf_lock as rawThomas Gleixner
The logbuf_lock lock can be taken in atomic context and therefore cannot be preempted on -rt - annotate it. In mainline this change documents the low level nature of the lock - otherwise there's no functional difference. Lockdep and Sparse checking will work as usual. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> [ merged and fixed it ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-07ratelimit: fix the return value when __ratelimit() fails to acquire the lockYong Zhang
The log of commit edaac8e3167501cda336231d00611bf59c164346 ("ratelimit: Fix/allow use in atomic contexts"), indicates that we want to suppress the callback when the trylock fails. Signed-off-by: Yong Zhang <yong.zhang@windriver.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-07ratelimit: annotate ___ratelimit()Yong Zhang
To prevent from wrongly using the return value. [akpm@linux-foundation.org: fix spello] Signed-off-by: Yong Zhang <yong.zhang@windriver.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-23ratelimit: Make suppressed output messages more usefulChristian Borntraeger
Today I got: [39648.224782] Registered led device: iwl-phy0::TX [40676.545099] __ratelimit: 246 callbacks suppressed [40676.545103] abcdef[23675]: segfault at 0 ... as you can see the ratelimit message contains a function prefix. Since this is always __ratelimit, this wont help much. This patch changes __ratelimit and printk_ratelimit to print the function name that calls ratelimit. This will pinpoint the responsible function, as long as not several different places call ratelimit with the same ratelimit state at the same time. In that case we catch only one random function that calls ratelimit after the wait period. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Dave Young <hidave.darkstar@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> CC: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <200910231458.11832.borntraeger@de.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-22printk: Remove ratelimit.h from kernel.hIngo Molnar
Decouple kernel.h from ratelimit.h: the global declaration of printk's ratelimit_state is not needed, and it leads to messy circular dependencies due to ratelimit.h's (new) adding of a spinlock_types.h include. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: David S. Miller <davem@davemloft.net> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-22ratelimit: Fix/allow use in atomic contextsIngo Molnar
I'd like to use printk_ratelimit() in NMI context, but it's not robust right now due to spinlock usage in lib/ratelimit.c. If an NMI is unlucky enough to hit just that spot we might lock up trying to take the spinlock again. Fix that by using a trylock variant. If we contend on that lock we can genuinely skip the message because the state is just being accessed by another CPU (or by this CPU). ( We could use atomics for the suppressed messages field, but i doubt it matters in practice and it makes the code heavier. ) Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: David S. Miller <davem@davemloft.net> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-22ratelimit: Use per ratelimit context lockingIngo Molnar
I'd like to use printk_ratelimit() in atomic context, but that's not possible right now due to the spinlock usage this commit introduced more than a year ago: 717115e: printk ratelimiting rewrite As a first step push the lock into the ratelimit state structure. This allows us to deal with locking failures to be considered as an event related to that state being too busy. Also clean up the code a bit (without changing functionality): - tidy up the definitions - clean up the code flow This also shrinks the code a tiny bit: text data bss dec hex filename 264 0 4 268 10c ratelimit.o.before 255 0 0 255 ff ratelimit.o.after ( Whole-kernel data size got a bit larger, because we have two ratelimit-state data structures right now. ) Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: David S. Miller <davem@davemloft.net> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-28__ratelimit() cpu flags can't be staticAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25printk ratelimiting rewriteDave Young
All ratelimit user use same jiffies and burst params, so some messages (callbacks) will be lost. For example: a call printk_ratelimit(5 * HZ, 1) b call printk_ratelimit(5 * HZ, 1) before the 5*HZ timeout of a, then b will will be supressed. - rewrite __ratelimit, and use a ratelimit_state as parameter. Thanks for hints from andrew. - Add WARN_ON_RATELIMIT, update rcupreempt.h - remove __printk_ratelimit - use __ratelimit in net_ratelimit Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29isolate ratelimit from printk.c for other useDave Young
Due to the rcupreempt.h WARN_ON trigged, I got 2G syslog file. For some serious complaining of kernel, we need repeat the warnings, so here I isolate the ratelimit part of printk.c to a standalone file. Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
