path: root/lib/semaphore-sleepers.c
2005-09-05[PATCH] unify x86/x86-64 semaphore codeBenjamin LaHaise
This patch moves the common code in x86 and x86-64's semaphore.c into a single file in lib/semaphore-sleepers.c. The arch specific asm stubs are left in the arch tree (in semaphore.c for i386 and in the asm for x86-64). There should be no changes in code/functionality with this patch. Signed-off-by: Benjamin LaHaise <benjamin.c.lahaise@intel.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
