path: root/lib/string.c
2006-03-22[PATCH] multiple exports of strpbrkAndrew Morton
Sam's tree includes a new check, which found that we're exporting strpbrk() multiple times. It seems that the convention is that this is exported from the arch files, so reove the lib/string.c export. Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: David Howells <dhowells@redhat.com> Cc: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] lib/string.c cleanup: restore useful memmove constPaul Jackson
A couple of (char *) casts removed in a previous cleanup patch in lib/string.c:memmove() were actually useful, as they suppressed a couple of warnings: assignment discards qualifiers from pointer target type Fix by declaring the local variable const in the first place, so casts aren't needed to strip the const qualifier. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] lib/string.c cleanup: remove pointless explicit castsJesper Juhl
The first two hunks of the patch really belongs in patch 1, but I missed them on the first pass and instead of redoing all 3 patches I stuck them in this one. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] lib/string.c cleanup: remove pointless register keywordJesper Juhl
Removes a few pointless register keywords. register is merely a compiler hint that access to the variable should be optimized, but gcc (3.3.6 in my case) generates the exact same code with and without the keyword, and even if gcc did something different with register present I think it is doubtful we would want to optimize access to these variables - especially since this is generic library code and there are supposed to be optimized versions in asm/ for anything that really matters speed wise. (akpm: iirc, keyword register is a gcc no-op unless using -O0) Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] lib/string.c cleanup: whitespace and CodingStyle cleanupsJesper Juhl
Removes some blank lines, removes some trailing whitespace, adds spaces after commas and a few similar changes. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] documentation for strncpy()walter harms
this clarifies the documentation on the behavier of strncpy(). Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] x86_64: make string func definition work as intendedPaolo 'Blaisorblade' Giarrusso
In include/asm-x86_64/string.h there are such comments: /* Use C out of line version for memcmp */ #define memcmp __builtin_memcmp int memcmp(const void * cs,const void * ct,size_t count); This would mean that if the compiler does not decide to use __builtin_memcmp, it emits a call to memcmp to be satisfied by the C out-of-line version in lib/string.c. What happens is that after preprocessing, in lib/string.i you may find the definition of "__builtin_strcmp". Actually, by accident, in the object you will find the definition of strcmp and such (maybe a trick intended to redirect calls to __builtin_memcmp to the default memcmp when the definition is not expanded); however, this particular case is not a documented feature as far as I can see. Also, the EXPORT_SYMBOL does not work, so it's duplicated in the arch. I simply added some #undef to lib/string.c and removed the (now duplicated) exports in x86-64 and UML/x86_64 subarchs (the second ones are introduced by another patch I just posted for -mm). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> CC: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
