commit 7d63fb3af87aa67aa7d24466e792f9d7c57d8e79 upstream.
This removes needless use of '%p', and refactors the printk calls to
use pr_*() helpers instead.
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
[bwh: Backported to 4.14:
- Adjust filename
- Remove "swiotlb: " prefix from an additional log message]
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit d0bc0c2a31c95002d37c3cc511ffdcab851b3256 upstream.
TTM tries to allocate coherent memory in chunks of 2MB first to improve
TLB efficiency and falls back to allocating 4K pages if that fails.
Suppress the warning when the 2MB allocations fails since there is a
valid fall back path.
Signed-off-by: Christian König <christian.koenig@amd.com>
Reported-by: Mike Galbraith <efault@gmx.de>
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Bug: https://bugs.freedesktop.org/show_bug.cgi?id=104082
Add warnings to let the user know when bounce buffers are being used for
DMA when SME is active. Since the bounce buffers are not in encrypted
memory, these notifications are to allow the user to determine some
appropriate action - if necessary. Actions can range from utilizing an
IOMMU, replacing the device with another device that can support 64-bit
DMA, ignoring the message if the device isn't used much, etc.
Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Brijesh Singh <brijesh.singh@amd.com>
Cc: Dave Young <dyoung@redhat.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Larry Woodman <lwoodman@redhat.com>
Cc: Matt Fleming <matt@codeblueprint.co.uk>
Cc: Michael S. Tsirkin <mst@redhat.com>
Cc: Radim Krčmář <rkrcmar@redhat.com>
Cc: Toshimitsu Kani <toshi.kani@hpe.com>
Cc: kasan-dev@googlegroups.com
Cc: kvm@vger.kernel.org
Cc: linux-doc@vger.kernel.org
Cc: linux-efi@vger.kernel.org
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/d112564053c3f2e86ca634a8d4fa4abc0eb53a6a.1500319216.git.thomas.lendacky@amd.com
Since DMA addresses will effectively look like 48-bit addresses when the
memory encryption mask is set, SWIOTLB is needed if the DMA mask of the
device performing the DMA does not support 48-bits. SWIOTLB will be
initialized to create decrypted bounce buffers for use by these devices.
Link: http://lkml.kernel.org/r/aa2d29b78ae7d508db8881e46a3215231b9327a7.1500319216.git.thomas.lendacky@amd.com
Some drivers do depend on page mappings to be page aligned.
Swiotlb already enforces such alignment for mappings greater than page,
extend that to page-sized mappings as well.
Without this fix, nvme hits BUG() in nvme_setup_prps(), because that routine
assumes page-aligned mappings.
Signed-off-by: Nikita Yushchenko <nikita.yoush@cogentembedded.com>
Reviewed-by: Sagi Grimberg <sagi@grimberg.me>
Signed-off-by: Konrad Rzeszutek Wilk <konrad@kernel.org>
So they can figure out what is the optimal number of pages
that can be contingously stitched together without fear of
bounce buffer.
We also expose an mechanism for sub-users of SWIOTLB API, such
as Xen-SWIOTLB to set the max segment value. And lastly
if swiotlb=force is set (which mandates we bounce buffer everything)
we set max_segment so at least we can bounce buffer one 4K page
instead of a giant 512KB one for which we may not have space.
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Reported-and-Tested-by: Juergen Gross <jgross@suse.com>
On architectures like arm64, swiotlb is tied intimately to the core
architecture DMA support. In addition, ZONE_DMA cannot be disabled.
To aid debugging and catch devices not supporting DMA to memory outside
the 32-bit address space, add a kernel command line option
"swiotlb=noforce", which disables the use of bounce buffers.
If specified, trying to map memory that cannot be used with DMA will
fail, and a rate-limited warning will be printed.
Note that io_tlb_nslabs is set to 1, which is the minimal supported
value.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Convert the flag swiotlb_force from an int to an enum, to prepare for
the advent of more possible values.
Suggested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
I am updating the paths so that instead of trying to pass
"attr | DMA_ATTR_SKIP_CPU_SYNC" we instead just OR the value into attr and
then pass it since attr will not be used after we make the unmap call.
I realized there was one spot I had missed when I was applying the DMA
attribute to the DMA mapping exception handling. This change corrects that.
Finally it looks like there is a stray blank line at the end of the
swiotlb_unmap_sg_attrs function that can be dropped.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
As a first step to making DMA_ATTR_SKIP_CPU_SYNC apply to architectures
beyond just ARM I need to make it so that the swiotlb will respect the
flag. In order to do that I also need to update the swiotlb-xen since it
heavily makes use of the functionality.
There are no users for swiotlb_map_sg or swiotlb_unmap_sg so we might as
well just drop them.
Acked-by: Christoph Hellwig <hch@infradead.org>
If the system runs out of SW-IOMMU space, changes are high successive
requests will fail, too, flooding the kernel log. This is true
especially for streaming DMA, which is typically used repeatedly outside
the driver's initialization routine. Add rate-limiting to fix this.
While at it, get rid of the open-coded dev_name() handling by using the
appropriate dev_err_*() variant.
The dma-mapping core and the implementations do not change the DMA
attributes passed by pointer. Thus the pointer can point to const data.
However the attributes do not have to be a bitfield. Instead unsigned
long will do fine:
1. This is just simpler. Both in terms of reading the code and setting
attributes. Instead of initializing local attributes on the stack
and passing pointer to it to dma_set_attr(), just set the bits.
2. It brings safeness and checking for const correctness because the
attributes are passed by value.
Semantic patches for this change (at least most of them):
virtual patch
virtual context
@r@
identifier f, attrs;
f(...,
- struct dma_attrs *attrs
+ unsigned long attrs
identifier r.f;
f(...,
- NULL
+ 0
and
// Options: --all-includes
virtual patch
virtual context
@r@
type t;
t f(..., struct dma_attrs *attrs);
identifier r.f;
f(...,
- NULL
+ 0
Link: http://lkml.kernel.org/r/1468399300-5399-2-git-send-email-k.kozlowski@samsung.com
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Robin Murphy <robin.murphy@arm.com>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no>
Acked-by: Mark Salter <msalter@redhat.com> [c6x]
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> [cris]
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> [drm]
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
Acked-by: Joerg Roedel <jroedel@suse.de> [iommu]
Acked-by: Fabien Dessenne <fabien.dessenne@st.com> [bdisp]
Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com> [vb2-core]
Acked-by: David Vrabel <david.vrabel@citrix.com> [xen]
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [xen swiotlb]
Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon]
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> [m68k]
Acked-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> [s390]
Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> [avr32]
Acked-by: Vineet Gupta <vgupta@synopsys.com> [arc]
Acked-by: Robin Murphy <robin.murphy@arm.com> [arm64 and dma-iommu]
Pull asm/scatterlist.h removal from Jens Axboe:
"We don't have any specific arch scatterlist anymore, since parisc
finally switched over. Kill the include"
* 'for-4.2/sg' of git://git.kernel.dk/linux-block:
remove scatterlist.h generation from arch Kbuild files
remove <asm/scatterlist.h>
Print a warning when all allocation tries have been failed
and the function is about to return NULL.
This prepares for calling the function with __GFP_NOWARN to
suppress allocation failure warnings before all fall-backs
have failed - which we'll do to improve kdump behavior.
Signed-off-by: Joerg Roedel <jroedel@suse.de>
Acked-by: Baoquan He <bhe@redhat.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Jörg Rödel <joro@8bytes.org>
Cc: Vivek Goyal <vgoyal@redhat.com>
Cc: kexec@lists.infradead.org
Link: http://lkml.kernel.org/r/1433500202-25531-2-git-send-email-joro@8bytes.org
The map_single() function is not defined as static, even though it
doesn't seem to be used anywhere else in the kernel. Make it static to
avoid namespace pollution since this is a rather generic symbol.
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
We don't have any arch specific scatterlist now that parisc switched over
to the generic one.
Signed-off-by: Jens Axboe <axboe@fb.com>
In 2.6.29 io_tlb_orig_addr[] got converted from storing virtual addresses
to storing physical ones. While checking virtual addresses against NULL
is a legitimate thing to catch invalid entries, checking physical ones
against zero isn't: There's no guarantee that PFN 0 is reserved on a
particular platform.
Since it is unclear whether the check in swiotlb_tbl_unmap_single() is
actually needed, retain it but check against a guaranteed invalid physical
address. This requires setting up the array in a suitable fashion. And
since the original code failed to invalidate array entries when regions
get unmapped, this is being fixed at once along with adding a similar
check to swiotlb_tbl_sync_single().
Obviously the less intrusive change would be to simply drop the check in
swiotlb_tbl_unmap_single().
Signed-off-by: Jan Beulich <jbeulich@suse.com>
The DMA Contiguous Memory Allocator support on x86 is disabled when
swiotlb config option is enabled. So DMA CMA is always disabled on
x86_64 because swiotlb is always enabled. This attempts to support for
DMA CMA with enabling swiotlb config option.
The contiguous memory allocator on x86 is integrated in the function
dma_generic_alloc_coherent() which is .alloc callback in nommu_dma_ops
for dma_alloc_coherent().
x86_swiotlb_alloc_coherent() which is .alloc callback in swiotlb_dma_ops
tries to allocate with dma_generic_alloc_coherent() firstly and then
swiotlb_alloc_coherent() is called as a fallback.
The main part of supporting DMA CMA with swiotlb is that changing
x86_swiotlb_free_coherent() which is .free callback in swiotlb_dma_ops
for dma_free_coherent() so that it can distinguish memory allocated by
dma_generic_alloc_coherent() from one allocated by
swiotlb_alloc_coherent() and release it with dma_generic_free_coherent()
which can handle contiguous memory. This change requires making
is_swiotlb_buffer() global function.
This also needs to change .free callback in the dma_map_ops for amd_gart
and sta2x11, because these dma_ops are also using
dma_generic_alloc_coherent().
Acked-by: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Don Dutile <ddutile@redhat.com>
Cc: Yinghai Lu <yinghai@kernel.org>
The new memblock_virt APIs are used to replaced old bootmem API.
We need to allocate page below 4G for swiotlb.
That should fix regression on Andrew's system that is using swiotlb.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/swiotlb
Pull swiotlb bug-fixes from Konrad Rzeszutek Wilk:
- Don't DoS with 'swiotlb is full' message.
- Documentation update.
* tag 'stable/for-linus-3.14-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/swiotlb:
swiotlb: Don't DoS us with 'swiotlb buffer is full' (v2)
swiotlb: update format
Switch to memblock interfaces for early memory allocator instead of
bootmem allocator. No functional change in beahvior than what it is in
current code from bootmem users points of view.
Archs already converted to NO_BOOTMEM now directly use memblock
interfaces instead of bootmem wrappers build on top of memblock. And
the archs which still uses bootmem, these new apis just fallback to
exiting bootmem APIs.
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Grygorii Strashko <grygorii.strashko@ti.com>
Cc: Paul Walmsley <paul@pwsan.com>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Tejun Heo <tj@kernel.org>
Cc: Tony Lindgren <tony@atomide.com>
There is no need for that so lets use ratelimiting.
Also add some extra information to be helpful.
Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
[v2: s/ld/zs on the printk]
stable/for-linus-3.13
* stefano/swiotlb-xen-9.1:
swiotlb-xen: fix error code returned by xen_swiotlb_map_sg_attrs
swiotlb-xen: static inline xen_phys_to_bus, xen_bus_to_phys, xen_virt_to_bus and range_straddles_page_boundary
grant-table: call set_phys_to_machine after mapping grant refs
arm,arm64: do not always merge biovec if we are running on Xen
swiotlb: print a warning when the swiotlb is full
swiotlb-xen: use xen_dma_map/unmap_page, xen_dma_sync_single_for_cpu/device
xen: introduce xen_dma_map/unmap_page and xen_dma_sync_single_for_cpu/device
swiotlb-xen: use xen_alloc/free_coherent_pages
xen: introduce xen_alloc/free_coherent_pages
arm64/xen: get_dma_ops: return xen_dma_ops if we are running as xen_initial_domain
arm/xen: get_dma_ops: return xen_dma_ops if we are running as xen_initial_domain
swiotlb-xen: introduce xen_swiotlb_set_dma_mask
xen/arm,arm64: enable SWIOTLB_XEN
xen: make xen_create_contiguous_region return the dma address
xen/x86: allow __set_phys_to_machine for autotranslate guests
arm/xen,arm64/xen: introduce p2m
arm64: define DMA_ERROR_CODE
arm: make SWIOTLB available
arch/arm/include/asm/dma-mapping.h
drivers/xen/swiotlb-xen.c
[Conflicts arose b/c "arm: make SWIOTLB available" v8 was in Stefano's
branch, while I had v9 + Ack from Russel. I also fixed up white-space
issues]
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Changes in v7:
- use dev_warn instead of pr_warn.
Tracepoints are only created when Xen support is enabled, but they are
also referenced within lib/swiotlb.c. So unless Xen support is enabled
the tracepoints will be missing, therefore causing builds to fail. Fix
this by moving the tracepoint creation to lib/swiotlb.c, which works
nicely because the Xen swiotlb support selects the generic swiotlb
support.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Ftrace is currently not able to detect when SWIOTLB has to do double buffering.
Under Xen you can only see it indirectly in function_graph, when
xen_swiotlb_map_page() doesn't stop after range_straddles_page_boundary(), but
calls spinlock functions, memcpy() and xen_phys_to_bus() as well. This patch
introduces the swiotlb:swiotlb_bounced event, which also prints out the
following informations to help you find out why bouncing happened:
dev_name: 0000:08:00.0 dma_mask=ffffffffffffffff dev_addr=9149f000 size=32768
swiotlb_force=0
If you use Xen, and (dev_addr + size + 1) > dma_mask, the buffer is out of the
device's DMA range. If swiotlb_force == 1, you should really change the kernel
parameters. Otherwise, the buffer is not contiguous in mfn space.
Signed-off-by: Zoltan Kiss <zoltan.kiss@citrix.com>
[v1: Don't print 'swiotlb_force=X', just print swiotlb_force if it is enabled]
This patch replace dma_length in "lib/swiotlb.c" to sg_dma_len() macro,
because the build error can occur if CONFIG_NEED_SG_DMA_LENGTH is not
set, and CONFIG_SWIOTLB is set.
Singed-off-by: EunBong Song <eunb.song@samsung.com>
Chao said that kdump does does work well on his system on 3.8
without extra parameter, even iommu does not work with kdump.
And now have to append crashkernel_low=Y in first kernel to make
kdump work.
We have now modified crashkernel=X to allocate memory beyong 4G (if
available) and do not allocate low range for crashkernel if the user
does not specify that with crashkernel_low=Y. This causes regression
if iommu is not enabled. Without iommu, swiotlb needs to be setup in
first 4G and there is no low memory available to second kernel.
Set crashkernel_low automatically if the user does not specify that.
For system that does support IOMMU with kdump properly, user could
specify crashkernel_low=0 to save that 72M low ram.
-v3: add swiotlb_size() according to Konrad.
-v4: add comments what 8M is for according to hpa.
also update more crashkernel_low= in kernel-parameters.txt
-v5: update changelog according to Vivek.
-v6: Change description about swiotlb referring according to HATAYAMA.
Reported-by: WANG Chao <chaowang@redhat.com>
Tested-by: WANG Chao <chaowang@redhat.com>
Link: http://lkml.kernel.org/r/1366089828-19692-2-git-send-email-yinghai@kernel.org
Acked-by: Vivek Goyal <vgoyal@redhat.com>
Normal boot path on system with iommu support:
swiotlb buffer will be allocated early at first and then try to initialize
iommu, if iommu for intel or AMD could setup properly, swiotlb buffer
will be freed.
The early allocating is with bootmem, and could panic when we try to use
kdump with buffer above 4G only, or with memmap to limit mem under 4G.
for example: memmap=4095M$1M to remove memory under 4G.
According to Eric, add _nopanic version and no_iotlb_memory to fail
map single later if swiotlb is still needed.
-v2: don't pass nopanic, and use -ENOMEM return value according to Eric.
panic early instead of using swiotlb_full to panic...according to Eric/Konrad.
-v3: make swiotlb_init to be notpanic, but will affect:
arm64, ia64, powerpc, tile, unicore32, x86.
-v4: cleanup swiotlb_init by removing swiotlb_init_with_default_size.
Suggested-by: Eric W. Biederman <ebiederm@xmission.com>
Link: http://lkml.kernel.org/r/1359058816-7615-36-git-send-email-yinghai@kernel.org
Reviewed-and-tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Joerg Roedel <joro@8bytes.org>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Andrzej Pietrasiewicz <andrzej.p@samsung.com>
Cc: linux-mips@linux-mips.org
Cc: xen-devel@lists.xensource.com
Cc: virtualization@lists.linux-foundation.org
Cc: Shuah Khan <shuahkhan@gmail.com>
Currently swiotlb is the only consumer for swiotlb_bounce. Since that is the
case it doesn't make much sense to be exporting it so make it a static
function only.
In addition we can save a few more lines of code by making it so that it
accepts the DMA address as a physical address instead of a virtual one. This
is the last piece in essentially pushing all of the DMA address values to use
physical addresses in swiotlb.
In order to clarify things since we now have 2 physical addresses in use
inside of swiotlb_bounce I am renaming phys to orig_addr, and dma_addr to
tlb_addr. This way is should be clear that orig_addr is contained within
io_orig_addr and tlb_addr is an address within the io_tlb_addr buffer.
This change makes it so that the sync functionality also uses physical
addresses. This helps to further reduce the use of virt_to_phys and
phys_to_virt functions.
inside of swiotlb_tbl_sync_single I am renaming phys to orig_addr, and
dma_addr to tlb_addr. This way is should be clear that orig_addr is
contained within io_orig_addr and tlb_addr is an address within the
io_tlb_addr buffer.
This change makes it so that the unmap functionality also uses physical
inside of swiotlb_tbl_unmap_single I am renaming phys to orig_addr, and
io_tlb_addr buffer.
This change makes it so that swiotlb_tbl_map_single will return a physical
address instead of a virtual address when called. The advantage to this once
again is that we are avoiding a number of virt_to_phys and phys_to_virt
translations by working with everything as a physical address.
One change I had to make in order to support using physical addresses is that
I could no longer trust 0 to be a invalid physical address on all platforms.
So instead I made it so that ~0 is returned on error. This should never be a
valid return value as it implies that only one byte would be available for
use.
inside of swiotlb_tbl_map_single I am renaming phys to orig_addr, and
io_tlb_addr buffer.
This change makes it so that we can avoid virt_to_phys overhead when using the
io_tlb_overflow_buffer. My original plan was to completely remove the value
and replace it with a constant but I had seen that there were recent patches
that stated this couldn't be done until all device drivers that depended on
that functionality be updated.
This change replaces all references to the virtual address for io_tlb_start
with references to the physical address io_tlb_end. The main advantage of
replacing the virtual address with a physical address is that we can avoid
having to do multiple translations from the virtual address to the physical
one needed for testing an existing DMA address.
This change replaces all references to the virtual address for io_tlb_end
This enables the caller to initialize swiotlb with its own iotlb
memory late in the bootup.
See git commit eb605a5754d050a25a9f00d718fb173f24c486ef
"swiotlb: add swiotlb_tbl_map_single library function" which will
explain the full details of what it can be used for.
CC: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
[v1: Fold in smatch warning]
Print swiotlb info in a style consistent with the %pR style used elsewhere
in the kernel. For example:
-Placing 64MB software IO TLB between ffff88007a662000 - ffff88007e662000
-software IO TLB at phys 0x7a662000 - 0x7e662000
+software IO TLB [mem 0x7a662000-0x7e661fff] (64MB) mapped at [ffff88007a662000-ffff88007e661fff]
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull cleanup of fs/ and lib/ users of module.h from Paul Gortmaker:
"Fix up files in fs/ and lib/ dirs to only use module.h if they really
need it.
These are trivial in scope vs the work done previously. We now have
things where any few remaining cleanups can be farmed out to arch or
subsystem maintainers, and I have done so when possible. What is
remaining here represents the bits that don't clearly lie within a
single arch/subsystem boundary, like the fs dir and the lib dir.
Some duplicate includes arising from overlapping fixes from
independent subsystem maintainer submissions are also quashed."
Fix up trivial conflicts due to clashes with other include file cleanups
(including some due to the previous bug.h cleanup pull).
* tag 'module-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
lib: reduce the use of module.h wherever possible
fs: reduce the use of module.h wherever possible
includecheck: delete any duplicate instances of module.h
Signed-off-by: Cong Wang <amwang@redhat.com>
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map
them onto including export.h -- or if the file isn't even
using those, then just delete the include. Fix up any implicit
include dependencies that were being masked by module.h along
the way.
As a mechanism to detect whether SWIOTLB is enabled or not.
We also fix the spelling - it was swioltb instead of
swiotlb.
[v1: Ripped out swiotlb_enabled]
By default the io_tlb_nslabs is set to zero, and gets set to
whatever value is passed in via swiotlb_init_with_tbl function.
The default value passed in is 64MB. However, if the user provides
the 'swiotlb=<nslabs>' the default value is ignored and
the value provided by the user is used... Except when the SWIOTLB
is used under Xen - there the default value of 64MB is used and
the Xen-SWIOTLB has no mechanism to get the 'io_tlb_nslabs' filled
out by setup_io_tlb_npages functions. This patch provides a function
for the Xen-SWIOTLB to call to see if the io_tlb_nslabs is set
and if so use that value.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
swiotlb's map_page wrongly calls panic() when it can't find a buffer fit
for device's dma mask. It should return an error instead.
Devices with an odd dma mask (i.e. under 4G) like b44 network card hit
this bug (the system crashes):
http://marc.info/?l=linux-kernel&m=129648943830106&w=2
If swiotlb returns an error, b44 driver can use the own bouncing
mechanism.
Reported-by: Chuck Ebbert <cebbert@redhat.com>
Tested-by: Arkadiusz Miskiewicz <arekm@maven.pl>
Cc: <stable@kernel.org>
"gadget", "through", "command", "maintain", "maintain", "controller", "address",
"between", "initiali[zs]e", "instead", "function", "select", "already",
"equal", "access", "management", "hierarchy", "registration", "interest",
"relative", "memory", "offset", "already",
We could call free_bootmem_late() if swiotlb is not used, and
it will shrink to page alignment.
So alloc them with page alignment at first, to avoid lose two pages
before patch:
[ 0.000000] memblock_x86_reserve_range: [00d3600000, 00d7600000] swiotlb buffer
[ 0.000000] memblock_x86_reserve_range: [00d7e7ef40, 00d7e9ef40] swiotlb list
[ 0.000000] memblock_x86_reserve_range: [00d7e3ef40, 00d7e7ef40] swiotlb orig_ad
[ 0.000000] memblock_x86_reserve_range: [000008a000, 0000092000] swiotlb overflo
after patch will get
[ 0.000000] memblock_x86_reserve_range: [00d7e7e000, 00d7e9e000] swiotlb list
[ 0.000000] memblock_x86_reserve_range: [00d7e3e000, 00d7e7e000] swiotlb orig_ad
Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: Becky Bruce <beckyb@kernel.crashing.org>
We don't need to export io_tlb_overflow_buffer. I'll remove
io_tlb_overflow_buffer completely in the long term though.
We put the functions dealing with the operations on
the SWIOTLB buffer in the header and make those functions non-static.
And also make the functions exported via EXPORT_SYMBOL_GPL.
See "swiotlb: swiotlb: add swiotlb_tbl_map_single library function" for
full description of patchset.
[v2: swiotlb_sync_single_range_for_* no more. Remove usage.]
Tested-by: Albert Herranz <albert_herranz@yahoo.es>
.. to catch anybody doing something funky.
[v2: swiotlb_sync_single_range_* no more - removed usage]
[v3: enum dma_data_direction direction -> enum dma_data_direction dir]
