path: root/lib/timerqueue.c
2010-12-11timerqueue: Make timerqueue_getnext() static inlineThomas Gleixner
No point in calling a function just to dereference a pointer. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: John Stultz <john.stultz@linaro.org>
2010-12-10timers: Fixup allmodconfig build issueJohn Stultz
Adds missed EXPORT_SYMBOL lines that cause the following build failures with allmodconfig: ERROR: "timerqueue_add" [drivers/rtc/rtc-core.ko] undefined! ERROR: "timerqueue_getnext" [drivers/rtc/rtc-core.ko] undefined! ERROR: "timerqueue_del" [drivers/rtc/rtc-core.ko] undefined! Reported-by: Ingo Molnar <mingo@elte.hu> Reported-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: John Stultz <john.stultz@linaro.org>
2010-12-10timers: Rename timerlist infrastructure to timerqueueJohn Stultz
Thomas pointed out a namespace collision between the new timerlist infrastructure I introduced and the existing timer_list.c So to avoid confusion, I've renamed the timerlist infrastructure to timerqueue. Reported-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: John Stultz <john.stultz@linaro.org>
