commit 81d67439855a7f928d90965d832aa4f2fb677342 upstream.
<linux/kernel.h> is needed for min_t. The old version
happened to work on x86 because <asm/unaligned.h>
indirectly includes <linux/kernel.h>, but it didn't
work on ARM.
<linux/kernel.h> includes <asm/byteorder.h> so it's
not necessary to include it explicitly anymore.
Signed-off-by: Lasse Collin <lasse.collin@tukaani.org>
The old code considered valid empty LZMA2 streams to be corrupt.
Note that a typical empty .xz file has no LZMA2 data at all,
and thus most .xz files having no uncompressed data are handled
correctly even without this fix.
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option
is used to configure any non-standard kernel with a much larger scope than
only small devices.
This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes
references to the option throughout the kernel. A new CONFIG_EMBEDDED
option is added that automatically selects CONFIG_EXPERT when enabled and
can be used in the future to isolate options that should only be
considered for embedded systems (RISC architectures, SLOB, etc).
Calling the option "EXPERT" more accurately represents its intention: only
expert users who understand the impact of the configuration changes they
are making should enable it.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Acked-by: David Woodhouse <david.woodhouse@intel.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Greg KH <gregkh@suse.de>
Cc: Robin Holt <holt@sgi.com>
Cc: <linux-arch@vger.kernel.org>
In userspace, the .lzma format has become mostly a legacy file format that
got superseded by the .xz format. Similarly, LZMA Utils was superseded by
XZ Utils.
These patches add support for XZ decompression into the kernel. Most of
the code is as is from XZ Embedded <http://tukaani.org/xz/embedded.html>.
It was written for the Linux kernel but is usable in other projects too.
Advantages of XZ over the current LZMA code in the kernel:
- Nice API that can be used by other kernel modules; it's
not limited to kernel, initramfs, and initrd decompression.
- Integrity check support (CRC32)
- BCJ filters improve compression of executable code on
certain architectures. These together with LZMA2 can
produce a few percent smaller kernel or Squashfs images
than plain LZMA without making the decompression slower.
This patch: Add the main decompression code (xz_dec), testing module
(xz_dec_test), wrapper script (xz_wrap.sh) for the xz command line tool,
and documentation. The xz_dec module is enough to have a usable XZ
decompressor e.g. for Squashfs.
Cc: Alain Knaff <alain@knaff.lu>
Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com>
Cc: Phillip Lougher <phillip@lougher.demon.co.uk>
