path: root/lib
2015-08-03__bitmap_parselist: fix bug in empty string handlingChris Metcalf
commit 2528a8b8f457d7432552d0e2b6f0f4046bb702f4 upstream. bitmap_parselist("", &mask, nmaskbits) will erroneously set bit zero in the mask. The same bug is visible in cpumask_parselist() since it is layered on top of the bitmask code, e.g. if you boot with "isolcpus=", you will actually end up with cpu zero isolated. The bug was introduced in commit 4b060420a596 ("bitmap, irq: add smp_affinity_list interface to /proc/irq") when bitmap_parselist() was generalized to support userspace as well as kernelspace. Fixes: 4b060420a596 ("bitmap, irq: add smp_affinity_list interface to /proc/irq") Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-06lib: Fix strnlen_user() to not touch memory after specified maximumJan Kara
commit f18c34e483ff6b1d9866472221e4015b3a4698e4 upstream. If the specified maximum length of the string is a multiple of unsigned long, we would load one long behind the specified maximum. If that happens to be in a next page, we can hit a page fault although we were not expected to. Fix the off-by-one bug in the test whether we are at the end of the specified range. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06lib: memzero_explicit: use barrier instead of OPTIMIZER_HIDE_VARmancha security
commit 0b053c9518292705736329a8fe20ef4686ffc8e9 upstream. OPTIMIZER_HIDE_VAR(), as defined when using gcc, is insufficient to ensure protection from dead store optimization. For the random driver and crypto drivers, calls are emitted ... $ gdb vmlinux (gdb) disassemble memzero_explicit Dump of assembler code for function memzero_explicit: 0xffffffff813a18b0 <+0>: push %rbp 0xffffffff813a18b1 <+1>: mov %rsi,%rdx 0xffffffff813a18b4 <+4>: xor %esi,%esi 0xffffffff813a18b6 <+6>: mov %rsp,%rbp 0xffffffff813a18b9 <+9>: callq 0xffffffff813a7120 <memset> 0xffffffff813a18be <+14>: pop %rbp 0xffffffff813a18bf <+15>: retq End of assembler dump. (gdb) disassemble extract_entropy [...] 0xffffffff814a5009 <+313>: mov %r12,%rdi 0xffffffff814a500c <+316>: mov $0xa,%esi 0xffffffff814a5011 <+321>: callq 0xffffffff813a18b0 <memzero_explicit> 0xffffffff814a5016 <+326>: mov -0x48(%rbp),%rax [...] ... but in case in future we might use facilities such as LTO, then OPTIMIZER_HIDE_VAR() is not sufficient to protect gcc from a possible eviction of the memset(). We have to use a compiler barrier instead. Minimal test example when we assume memzero_explicit() would *not* be a call, but would have been *inlined* instead: static inline void memzero_explicit(void *s, size_t count) { memset(s, 0, count); <foo> } int main(void) { char buff[20]; snprintf(buff, sizeof(buff) - 1, "test"); printf("%s", buff); memzero_explicit(buff, sizeof(buff)); return 0; } With <foo> := OPTIMIZER_HIDE_VAR(): (gdb) disassemble main Dump of assembler code for function main: [...] 0x0000000000400464 <+36>: callq 0x400410 <printf@plt> 0x0000000000400469 <+41>: xor %eax,%eax 0x000000000040046b <+43>: add $0x28,%rsp 0x000000000040046f <+47>: retq End of assembler dump. With <foo> := barrier(): (gdb) disassemble main Dump of assembler code for function main: [...] 0x0000000000400464 <+36>: callq 0x400410 <printf@plt> 0x0000000000400469 <+41>: movq $0x0,(%rsp) 0x0000000000400471 <+49>: movq $0x0,0x8(%rsp) 0x000000000040047a <+58>: movl $0x0,0x10(%rsp) 0x0000000000400482 <+66>: xor %eax,%eax 0x0000000000400484 <+68>: add $0x28,%rsp 0x0000000000400488 <+72>: retq End of assembler dump. As can be seen, movq, movq, movl are being emitted inlined via memset(). Reference: http://thread.gmane.org/gmane.linux.kernel.cryptoapi/13764/ Fixes: d4c5efdb9777 ("random: add and use memzero_explicit() for clearing data") Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: mancha security <mancha1@zoho.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-26LZ4 : fix the data abort issueJeHyeon Yeon
commit d5e7cafd69da24e6d6cc988fab6ea313a2577efc upstream. If the part of the compression data are corrupted, or the compression data is totally fake, the memory access over the limit is possible. This is the log from my system usning lz4 decompression. [6502]data abort, halting [6503]r0 0x00000000 r1 0x00000000 r2 0xdcea0ffc r3 0xdcea0ffc [6509]r4 0xb9ab0bfd r5 0xdcea0ffc r6 0xdcea0ff8 r7 0xdce80000 [6515]r8 0x00000000 r9 0x00000000 r10 0x00000000 r11 0xb9a98000 [6522]r12 0xdcea1000 usp 0x00000000 ulr 0x00000000 pc 0x820149bc [6528]spsr 0x400001f3 and the memory addresses of some variables at the moment are ref:0xdcea0ffc, op:0xdcea0ffc, oend:0xdcea1000 As you can see, COPYLENGH is 8bytes, so @ref and @op can access the momory over @oend. Signed-off-by: JeHyeon Yeon <tom.yeon@windriver.com> Reviewed-by: David Sterba <dsterba@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-02-11lib/checksum.c: fix build for generic csum_tcpudp_nofoldkarl beldan
commit 9ce357795ef208faa0d59894d9d119a7434e37f3 upstream. Fixed commit added from64to32 under _#ifndef do_csum_ but used it under _#ifndef csum_tcpudp_nofold_, breaking some builds (Fengguang's robot reported TILEGX's). Move from64to32 under the latter. Fixes: 150ae0e94634 ("lib/checksum.c: fix carry in csum_tcpudp_nofold") Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Karl Beldan <karl.beldan@rivierawaves.com> Cc: Eric Dumazet <edumazet@google.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-02-11lib/checksum.c: fix carry in csum_tcpudp_nofoldkarl beldan
commit 150ae0e94634714b23919f0c333fee28a5b199d5 upstream. The carry from the 64->32bits folding was dropped, e.g with: saddr=0xFFFFFFFF daddr=0xFF0000FF len=0xFFFF proto=0 sum=1, csum_tcpudp_nofold returned 0 instead of 1. Signed-off-by: Karl Beldan <karl.beldan@rivierawaves.com> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: netdev@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-27decompress_bunzip2: off by one in get_next_block()Dan Carpenter
commit b5c8afe5be51078a979d86ae5ae78c4ac948063d upstream. "origPtr" is used as an offset into the bd->dbuf[] array. That array is allocated in start_bunzip() and has "bd->dbufSize" number of elements so the test here should be >= instead of >. Later we check "origPtr" again before using it as an offset so I don't know if this bug can be triggered in real life. Fixes: bc22c17e12c1 ('bzip2/lzma: library support for gzip, bzip2 and lzma decompression') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: Alain Knaff <alain@knaff.lu> Cc: Yinghai Lu <yinghai@kernel.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21mm: filemap: move radix tree hole searching hereJohannes Weiner
commit e7b563bb2a6f4d974208da46200784b9c5b5a47e upstream. The radix tree hole searching code is only used for page cache, for example the readahead code trying to get a a picture of the area surrounding a fault. It sufficed to rely on the radix tree definition of holes, which is "empty tree slot". But this is about to change, though, as shadow page descriptors will be stored in the page cache after the actual pages get evicted from memory. Move the functions over to mm/filemap.c and make them native page cache operations, where they can later be adapted to handle the new definition of "page cache hole". Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan@kernel.org> Acked-by: Mel Gorman <mgorman@suse.de> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Bob Liu <bob.liu@oracle.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Greg Thelen <gthelen@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Jan Kara <jack@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Luigi Semenzato <semenzato@google.com> Cc: Metin Doslu <metin@citusdata.com> Cc: Michel Lespinasse <walken@google.com> Cc: Ozgun Erdogan <ozgun@citusdata.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Roman Gushchin <klamm@yandex-team.ru> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Tejun Heo <tj@kernel.org> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21lib: radix-tree: add radix_tree_delete_item()Johannes Weiner
commit 53c59f262d747ea82e7414774c59a489501186a0 upstream. Provide a function that does not just delete an entry at a given index, but also allows passing in an expected item. Delete only if that item is still located at the specified index. This is handy when lockless tree traversals want to delete entries as well because they don't have to do an second, locked lookup to verify the slot has not changed under them before deleting the entry. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Minchan Kim <minchan@kernel.org> Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: Mel Gorman <mgorman@suse.de> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Bob Liu <bob.liu@oracle.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Greg Thelen <gthelen@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Jan Kara <jack@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Luigi Semenzato <semenzato@google.com> Cc: Metin Doslu <metin@citusdata.com> Cc: Michel Lespinasse <walken@google.com> Cc: Ozgun Erdogan <ozgun@citusdata.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Roman Gushchin <klamm@yandex-team.ru> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Tejun Heo <tj@kernel.org> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14lib/bitmap.c: fix undefined shift in __bitmap_shift_{left|right}()Jan Kara
commit ea5d05b34aca25c066e0699512d0ffbd8ee6ac3e upstream. If __bitmap_shift_left() or __bitmap_shift_right() are asked to shift by a multiple of BITS_PER_LONG, they will try to shift a long value by BITS_PER_LONG bits which is undefined. Change the functions to avoid the undefined shift. Coverity id: 1192175 Coverity id: 1192174 Signed-off-by: Jan Kara <jack@suse.cz> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14random: add and use memzero_explicit() for clearing dataDaniel Borkmann
commit d4c5efdb97773f59a2b711754ca0953f24516739 upstream. zatimend has reported that in his environment (3.16/gcc4.8.3/corei7) memset() calls which clear out sensitive data in extract_{buf,entropy, entropy_user}() in random driver are being optimized away by gcc. Add a helper memzero_explicit() (similarly as explicit_bzero() variants) that can be used in such cases where a variable with sensitive data is being cleared out in the end. Other use cases might also be in crypto code. [ I have put this into lib/string.c though, as it's always built-in and doesn't need any dependencies then. ] Fixes kernel bugzilla: 82041 Reported-by: zatimend@hotmail.co.uk Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-30lzo: check for length overrun in variable length encoding.Willy Tarreau
commit 72cf90124e87d975d0b2114d930808c58b4c05e4 upstream. This fix ensures that we never meet an integer overflow while adding 255 while parsing a variable length encoding. It works differently from commit 206a81c ("lzo: properly check for overruns") because instead of ensuring that we don't overrun the input, which is tricky to guarantee due to many assumptions in the code, it simply checks that the cumulated number of 255 read cannot overflow by bounding this number. The MAX_255_COUNT is the maximum number of times we can add 255 to a base count without overflowing an integer. The multiply will overflow when multiplying 255 by more than MAXINT/255. The sum will overflow earlier depending on the base count. Since the base count is taken from a u8 and a few bits, it is safe to assume that it will always be lower than or equal to 2*255, thus we can always prevent any overflow by accepting two less 255 steps. This patch also reduces the CPU overhead and actually increases performance by 1.1% compared to the initial code, while the previous fix costs 3.1% (measured on x86_64). The fix needs to be backported to all currently supported stable kernels. Reported-by: Willem Pinckaers <willem@lekkertech.net> Cc: "Don A. Bailey" <donb@securitymouse.com> Signed-off-by: Willy Tarreau <w@1wt.eu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-30Revert "lzo: properly check for overruns"Willy Tarreau
commit af958a38a60c7ca3d8a39c918c1baa2ff7b6b233 upstream. This reverts commit 206a81c ("lzo: properly check for overruns"). As analysed by Willem Pinckaers, this fix is still incomplete on certain rare corner cases, and it is easier to restart from the original code. Reported-by: Willem Pinckaers <willem@lekkertech.net> Cc: "Don A. Bailey" <donb@securitymouse.com> Signed-off-by: Willy Tarreau <w@1wt.eu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-09lib/plist: add plist_requeueDan Streetman
commit a75f232ce0fe38bd01301899ecd97ffd0254316a upstream. Add plist_requeue(), which moves the specified plist_node after all other same-priority plist_nodes in the list. This is essentially an optimized plist_del() followed by plist_add(). This is needed by swap, which (with the next patch in this set) uses a plist of available swap devices. When a swap device (either a swap partition or swap file) are added to the system with swapon(), the device is added to a plist, ordered by the swap device's priority. When swap needs to allocate a page from one of the swap devices, it takes the page from the first swap device on the plist, which is the highest priority swap device. The swap device is left in the plist until all its pages are used, and then removed from the plist when it becomes full. However, as described in man 2 swapon, swap must allocate pages from swap devices with the same priority in round-robin order; to do this, on each swap page allocation, swap uses a page from the first swap device in the plist, and then calls plist_requeue() to move that swap device entry to after any other same-priority swap devices. The next swap page allocation will again use a page from the first swap device in the plist and requeue it, and so on, resulting in round-robin usage of equal-priority swap devices. Also add plist_test_requeue() test function, for use by plist_test() to test plist_requeue() function. Signed-off-by: Dan Streetman <ddstreet@ieee.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Acked-by: Mel Gorman <mgorman@suse.de> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Shaohua Li <shli@fusionio.com> Cc: Hugh Dickins <hughd@google.com> Cc: Dan Streetman <ddstreet@ieee.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com> Cc: Weijie Yang <weijieut@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Bob Liu <bob.liu@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17KEYS: Fix termination condition in assoc array garbage collectionDavid Howells
commit 95389b08d93d5c06ec63ab49bd732b0069b7c35e upstream. This fixes CVE-2014-3631. It is possible for an associative array to end up with a shortcut node at the root of the tree if there are more than fan-out leaves in the tree, but they all crowd into the same slot in the lowest level (ie. they all have the same first nibble of their index keys). When assoc_array_gc() returns back up the tree after scanning some leaves, it can fall off of the root and crash because it assumes that the back pointer from a shortcut (after label ascend_old_tree) must point to a normal node - which isn't true of a shortcut node at the root. Should we find we're ascending rootwards over a shortcut, we should check to see if the backpointer is zero - and if it is, we have completed the scan. This particular bug cannot occur if the root node is not a shortcut - ie. if you have fewer than 17 keys in a keyring or if you have at least two keys that sit into separate slots (eg. a keyring and a non keyring). This can be reproduced by: ring=`keyctl newring bar @s` for ((i=1; i<=18; i++)); do last_key=`keyctl newring foo$i $ring`; done keyctl timeout $last_key 2 Doing this: echo 3 >/proc/sys/kernel/keys/gc_delay first will speed things up. If we do fall off of the top of the tree, we get the following oops: BUG: unable to handle kernel NULL pointer dereference at 0000000000000018 IP: [<ffffffff8136cea7>] assoc_array_gc+0x2f7/0x540 PGD dae15067 PUD cfc24067 PMD 0 Oops: 0000 [#1] SMP Modules linked in: xt_nat xt_mark nf_conntrack_netbios_ns nf_conntrack_broadcast ip6t_rpfilter ip6t_REJECT xt_conntrack ebtable_nat ebtable_broute bridge stp llc ebtable_filter ebtables ip6table_ni CPU: 0 PID: 26011 Comm: kworker/0:1 Not tainted 3.14.9-200.fc20.x86_64 #1 Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 Workqueue: events key_garbage_collector task: ffff8800918bd580 ti: ffff8800aac14000 task.ti: ffff8800aac14000 RIP: 0010:[<ffffffff8136cea7>] [<ffffffff8136cea7>] assoc_array_gc+0x2f7/0x540 RSP: 0018:ffff8800aac15d40 EFLAGS: 00010206 RAX: 0000000000000000 RBX: 0000000000000000 RCX: ffff8800aaecacc0 RDX: ffff8800daecf440 RSI: 0000000000000001 RDI: ffff8800aadc2bc0 RBP: ffff8800aac15da8 R08: 0000000000000001 R09: 0000000000000003 R10: ffffffff8136ccc7 R11: 0000000000000000 R12: 0000000000000000 R13: 0000000000000000 R14: 0000000000000070 R15: 0000000000000001 FS: 0000000000000000(0000) GS:ffff88011fc00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 0000000000000018 CR3: 00000000db10d000 CR4: 00000000000006f0 Stack: ffff8800aac15d50 0000000000000011 ffff8800aac15db8 ffffffff812e2a70 ffff880091a00600 0000000000000000 ffff8800aadc2bc3 00000000cd42c987 ffff88003702df20 ffff88003702dfa0 0000000053b65c09 ffff8800aac15fd8 Call Trace: [<ffffffff812e2a70>] ? keyring_detect_cycle_iterator+0x30/0x30 [<ffffffff812e3e75>] keyring_gc+0x75/0x80 [<ffffffff812e1424>] key_garbage_collector+0x154/0x3c0 [<ffffffff810a67b6>] process_one_work+0x176/0x430 [<ffffffff810a744b>] worker_thread+0x11b/0x3a0 [<ffffffff810a7330>] ? rescuer_thread+0x3b0/0x3b0 [<ffffffff810ae1a8>] kthread+0xd8/0xf0 [<ffffffff810ae0d0>] ? insert_kthread_work+0x40/0x40 [<ffffffff816ffb7c>] ret_from_fork+0x7c/0xb0 [<ffffffff810ae0d0>] ? insert_kthread_work+0x40/0x40 Code: 08 4c 8b 22 0f 84 bf 00 00 00 41 83 c7 01 49 83 e4 fc 41 83 ff 0f 4c 89 65 c0 0f 8f 5a fe ff ff 48 8b 45 c0 4d 63 cf 49 83 c1 02 <4e> 8b 34 c8 4d 85 f6 0f 84 be 00 00 00 41 f6 c6 01 0f 84 92 RIP [<ffffffff8136cea7>] assoc_array_gc+0x2f7/0x540 RSP <ffff8800aac15d40> CR2: 0000000000000018 ---[ end trace 1129028a088c0cbd ]--- Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Don Zickus <dzickus@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17KEYS: Fix use-after-free in assoc_array_gc()David Howells
commit 27419604f51a97d497853f14142c1059d46eb597 upstream. An edit script should be considered inaccessible by a function once it has called assoc_array_apply_edit() or assoc_array_cancel_edit(). However, assoc_array_gc() is accessing the edit script just after the gc_complete: label. Reported-by: Andreea-Cristina Bernat <bernat.ada@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Andreea-Cristina Bernat <bernat.ada@gmail.com> cc: shemming@brocade.com cc: paulmck@linux.vnet.ibm.com Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-07lib/btree.c: fix leak of whole btree nodesMinfei Huang
commit c75b53af2f0043aff500af0a6f878497bef41bca upstream. I use btree from 3.14-rc2 in my own module. When the btree module is removed, a warning arises: kmem_cache_destroy btree_node: Slab cache still has objects CPU: 13 PID: 9150 Comm: rmmod Tainted: GF O 3.14.0-rc2 #1 Hardware name: Inspur NF5270M3/NF5270M3, BIOS CHEETAH_2.1.3 09/10/2013 Call Trace: dump_stack+0x49/0x5d kmem_cache_destroy+0xcf/0xe0 btree_module_exit+0x10/0x12 [btree] SyS_delete_module+0x198/0x1f0 system_call_fastpath+0x16/0x1b The cause is that it doesn't release the last btree node, when height = 1 and fill = 1. [akpm@linux-foundation.org: remove unneeded test of NULL] Signed-off-by: Minfei Huang <huangminfei@ucloud.cn> Cc: Joern Engel <joern@logfs.org> Cc: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-06lz4: add overrun checks to lz4_uncompress_unknownoutputsize()Greg Kroah-Hartman
commit 4a3a99045177369700c60d074c0e525e8093b0fc upstream. Jan points out that I forgot to make the needed fixes to the lz4_uncompress_unknownoutputsize() function to mirror the changes done in lz4_decompress() with regards to potential pointer overflows. The only in-kernel user of this function is the zram code, which only takes data from a valid compressed buffer that it made itself, so it's not a big issue. But due to external kernel modules using this function, it's better to be safe here. Reported-by: Jan Beulich <JBeulich@suse.com> Cc: "Don A. Bailey" <donb@securitymouse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-30lz4: fix another possible overrunGreg Kroah-Hartman
commit 4148c1f67abf823099b2d7db6851e4aea407f5ee upstream. There is one other possible overrun in the lz4 code as implemented by Linux at this point in time (which differs from the upstream lz4 codebase, but will get synced at in a future kernel release.) As pointed out by Don, we also need to check the overflow in the data itself. While we are at it, replace the odd error return value with just a "simple" -1 value as the return value is never used for anything other than a basic "did this work or not" check. Reported-by: "Don A. Bailey" <donb@securitymouse.com> Reported-by: Willy Tarreau <w@1wt.eu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-30idr: fix overflow bug during maximum ID calculation at maximum heightLai Jiangshan
commit 3afb69cb5572b3c8c898c00880803cf1a49852c4 upstream. idr_replace() open-codes the logic to calculate the maximum valid ID given the height of the idr tree; unfortunately, the open-coded logic doesn't account for the fact that the top layer may have unused slots and over-shifts the limit to zero when the tree is at its maximum height. The following test code shows it fails to replace the value for id=((1<<27)+42): static void test5(void) { int id; DEFINE_IDR(test_idr); #define TEST5_START ((1<<27)+42) /* use the highest layer */ printk(KERN_INFO "Start test5\n"); id = idr_alloc(&test_idr, (void *)1, TEST5_START, 0, GFP_KERNEL); BUG_ON(id != TEST5_START); TEST_BUG_ON(idr_replace(&test_idr, (void *)2, TEST5_START) != (void *)1); idr_destroy(&test_idr); printk(KERN_INFO "End of test5\n"); } Fix the bug by using idr_max() which correctly takes into account the maximum allowed shift. sub_alloc() shares the same problem and may incorrectly fail with -EAGAIN; however, this bug doesn't affect correct operation because idr_get_empty_slot(), which already uses idr_max(), retries with the increased @id in such cases. [tj@kernel.org: Updated patch description.] Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-26lz4: ensure length does not wrapGreg Kroah-Hartman
commit 206204a1162b995e2185275167b22468c00d6b36 upstream. Given some pathologically compressed data, lz4 could possibly decide to wrap a few internal variables, causing unknown things to happen. Catch this before the wrapping happens and abort the decompression. Reported-by: "Don A. Bailey" <donb@securitymouse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-26lzo: properly check for overrunsGreg Kroah-Hartman
commit 206a81c18401c0cde6e579164f752c4b147324ce upstream. The lzo decompressor can, if given some really crazy data, possibly overrun some variable types. Modify the checking logic to properly detect overruns before they happen. Reported-by: "Don A. Bailey" <donb@securitymouse.com> Tested-by: "Don A. Bailey" <donb@securitymouse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-26netlink: rate-limit leftover bytes warning and print process nameMichal Schmidt
[ Upstream commit bfc5184b69cf9eeb286137640351c650c27f118a ] Any process is able to send netlink messages with leftover bytes. Make the warning rate-limited to prevent too much log spam. The warning is supposed to help find userspace bugs, so print the triggering command name to implicate the buggy program. [v2: Use pr_warn_ratelimited instead of printk_ratelimited.] Signed-off-by: Michal Schmidt <mschmidt@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-13lib/percpu_counter.c: fix bad percpu counter state during suspendJens Axboe
commit e39435ce68bb4685288f78b1a7e24311f7ef939f upstream. I got a bug report yesterday from Laszlo Ersek in which he states that his kvm instance fails to suspend. Laszlo bisected it down to this commit 1cf7e9c68fe8 ("virtio_blk: blk-mq support") where virtio-blk is converted to use the blk-mq infrastructure. After digging a bit, it became clear that the issue was with the queue drain. blk-mq tracks queue usage in a percpu counter, which is incremented on request alloc and decremented when the request is freed. The initial hunt was for an inconsistency in blk-mq, but everything seemed fine. In fact, the counter only returned crazy values when suspend was in progress. When a CPU is unplugged, the percpu counters merges that CPU state with the general state. blk-mq takes care to register a hotcpu notifier with the appropriate priority, so we know it runs after the percpu counter notifier. However, the percpu counter notifier only merges the state when the CPU is fully gone. This leaves a state transition where the CPU going away is no longer in the online mask, yet it still holds private values. This means that in this state, percpu_counter_sum() returns invalid results, and the suspend then hangs waiting for abs(dead-cpu-value) requests to complete which of course will never happen. Fix this by clearing the state earlier, so we never have a case where the CPU isn't in online mask but still holds private state. This bug has been there since forever, I guess we don't have a lot of users where percpu counters needs to be reliable during the suspend cycle. Signed-off-by: Jens Axboe <axboe@fb.com> Reported-by: Laszlo Ersek <lersek@redhat.com> Tested-by: Laszlo Ersek <lersek@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-14netlink: don't compare the nul-termination in nla_strcmpPablo Neira
[ Upstream commit 8b7b932434f5eee495b91a2804f5b64ebb2bc835 ] nla_strcmp compares the string length plus one, so it's implicitly including the nul-termination in the comparison. int nla_strcmp(const struct nlattr *nla, const char *str) { int len = strlen(str) + 1; ... d = memcmp(nla_data(nla), str, len); However, if NLA_STRING is used, userspace can send us a string without the nul-termination. This is a problem since the string comparison will not match as the last byte may be not the nul-termination. Fix this by skipping the comparison of the nul-termination if the attribute data is nul-terminated. Suggested by Thomas Graf. Cc: Florian Westphal <fw@strlen.de> Cc: Thomas Graf <tgraf@suug.ch> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-28random32: avoid attempt to late reseed if in the middle of seedingSasha Levin
Commit 4af712e8df ("random32: add prandom_reseed_late() and call when nonblocking pool becomes initialized") has added a late reseed stage that happens as soon as the nonblocking pool is marked as initialized. This fails in the case that the nonblocking pool gets initialized during __prandom_reseed()'s call to get_random_bytes(). In that case we'd double back into __prandom_reseed() in an attempt to do a late reseed - deadlocking on 'lock' early on in the boot process. Instead, just avoid even waiting to do a reseed if a reseed is already occuring. Fixes: 4af712e8df99 ("random32: add prandom_reseed_late() and call when nonblocking pool becomes initialized") Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-23partly revert commit 8a10bc9: parisc/sti_console: prefer Linux fonts over ↵Helge Deller
built-in ROM fonts STI console is used on parisc and m68k HP machines. This patch partly reverts my previous commit and as such restores the fonts for the m68k machines. Signed-off-by: Helge Deller <deller@gmx.de> Cc: stable@vger.kernel.org # v3.13
2014-03-04lib/radix-tree.c: swapoff tmpfs radix_tree: remember to rcu_read_unlockHugh Dickins
Running fsx on tmpfs with concurrent memhog-swapoff-swapon, lots of BUG: sleeping function called from invalid context at kernel/fork.c:606 in_atomic(): 0, irqs_disabled(): 0, pid: 1394, name: swapoff 1 lock held by swapoff/1394: #0: (rcu_read_lock){.+.+.+}, at: [<ffffffff812520a1>] radix_tree_locate_item+0x1f/0x2b6 followed by ================================================ [ BUG: lock held when returning to user space! ] 3.14.0-rc1 #3 Not tainted ------------------------------------------------ swapoff/1394 is leaving the kernel with locks still held! 1 lock held by swapoff/1394: #0: (rcu_read_lock){.+.+.+}, at: [<ffffffff812520a1>] radix_tree_locate_item+0x1f/0x2b6 after which the system recovered nicely. Whoops, I long ago forgot the rcu_read_unlock() on one unlikely branch. Fixes e504f3fdd63d ("tmpfs radix_tree: locate_item to speed up swapoff") Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-04dma debug: account for cachelines and read-only mappings in overlap trackingDan Williams
While debug_dma_assert_idle() checks if a given *page* is actively undergoing dma the valid granularity of a dma mapping is a *cacheline*. Sander's testing shows that the warning message "DMA-API: exceeded 7 overlapping mappings of pfn..." is falsely triggering. The test is simply mapping multiple cachelines in a given page. Ultimately we want overlap tracking to be valid as it is a real api violation, so we need to track active mappings by cachelines. Update the active dma tracking to use the page-frame-relative cacheline of the mapping as the key, and update debug_dma_assert_idle() to check for all possible mapped cachelines for a given page. However, the need to track active mappings is only relevant when the dma-mapping is writable by the device. In fact it is fairly standard for read-only mappings to have hundreds or thousands of overlapping mappings at once. Limiting the overlap tracking to writable (!DMA_TO_DEVICE) eliminates this class of false-positive overlap reports. Note, the radix gang lookup is sub-optimal. It would be best if it stopped fetching entries once the search passed a page boundary. Nevertheless, this implementation does not perturb the original net_dma failing case. That is to say the extra overhead does not show up in terms of making the failing case pass due to a timing change. References: http://marc.info/?l=linux-netdev&m=139232263419315&w=2 http://marc.info/?l=linux-netdev&m=139217088107122&w=2 Signed-off-by: Dan Williams <dan.j.williams@intel.com> Reported-by: Sander Eikelenboom <linux@eikelenboom.it> Reported-by: Dave Jones <davej@redhat.com> Tested-by: Dave Jones <davej@redhat.com> Tested-by: Sander Eikelenboom <linux@eikelenboom.it> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Francois Romieu <romieu@fr.zoreil.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Wei Liu <wei.liu2@citrix.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-14Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block IO fixes from Jens Axboe: "Second round of updates and fixes for 3.14-rc2. Most of this stuff has been queued up for a while. The notable exception is the blk-mq changes, which are naturally a bit more in flux still. The pull request contains: - Two bug fixes for the new immutable vecs, causing crashes with raid or swap. From Kent. - Various blk-mq tweaks and fixes from Christoph. A fix for integrity bio's from Nic. - A few bcache fixes from Kent and Darrick Wong. - xen-blk{front,back} fixes from David Vrabel, Matt Rushton, Nicolas Swenson, and Roger Pau Monne. - Fix for a vec miscount with integrity vectors from Martin. - Minor annotations or fixes from Masanari Iida and Rashika Kheria. - Tweak to null_blk to do more normal FIFO processing of requests from Shlomo Pongratz. - Elevator switching bypass fix from Tejun. - Softlockup in blkdev_issue_discard() fix when !CONFIG_PREEMPT from me" * 'for-linus' of git://git.kernel.dk/linux-block: (31 commits) block: add cond_resched() to potentially long running ioctl discard loop xen-blkback: init persistent_purge_work work_struct blk-mq: pair blk_mq_start_request / blk_mq_requeue_request blk-mq: dont assume rq->errors is set when returning an error from ->queue_rq block: Fix cloning of discard/write same bios block: Fix type mismatch in ssize_t_blk_mq_tag_sysfs_show blk-mq: rework flush sequencing logic null_blk: use blk_complete_request and blk_mq_complete_request virtio_blk: use blk_mq_complete_request blk-mq: rework I/O completions fs: Add prototype declaration to appropriate header file include/linux/bio.h fs: Mark function as static in fs/bio-integrity.c block/null_blk: Fix completion processing from LIFO to FIFO block: Explicitly handle discard/write same segments block: Fix nr_vecs for inline integrity vectors blk-mq: Add bio_integrity setup to blk_mq_make_request blk-mq: initialize sg_reserved_size blk-mq: handle dma_drain_size blk-mq: divert __blk_put_request for MQ ops blk-mq: support at_head inserations for blk_execute_rq ...
2014-02-08Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Peter Anvin: "Quite a varied little collection of fixes. Most of them are relatively small or isolated; the biggest one is Mel Gorman's fixes for TLB range flushing. A couple of AMD-related fixes (including not crashing when given an invalid microcode image) and fix a crash when compiled with gcov" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, microcode, AMD: Unify valid container checks x86, hweight: Fix BUG when booting with CONFIG_GCOV_PROFILE_ALL=y x86/efi: Allow mapping BGRT on x86-32 x86: Fix the initialization of physnode_map x86, cpu hotplug: Fix stack frame warning in check_irq_vectors_for_cpu_disable() x86/intel/mid: Fix X86_INTEL_MID dependencies arch/x86/mm/srat: Skip NUMA_NO_NODE while parsing SLIT mm, x86: Revisit tlb_flushall_shift tuning for page flushes except on IvyBridge x86: mm: change tlb_flushall_shift for IvyBridge x86/mm: Eliminate redundant page table walk during TLB range flushing x86/mm: Clean up inconsistencies when flushing TLB ranges mm, x86: Account for TLB flushes only when debugging x86/AMD/NB: Fix amd_set_subcaches() parameter type x86/quirks: Add workaround for AMD F16h Erratum792 x86, doc, kconfig: Fix dud URL for Microcode data
2014-02-07Merge tag 'efi-urgent' into x86/urgentH. Peter Anvin
* Avoid WARN_ON() when mapping BGRT on Baytrail (EFI 32-bit). Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-02-06x86, hweight: Fix BUG when booting with CONFIG_GCOV_PROFILE_ALL=yPeter Oberparleiter
Commit d61931d89b, "x86: Add optimized popcnt variants" introduced compile flag -fcall-saved-rdi for lib/hweight.c. When combined with options -fprofile-arcs and -O2, this flag causes gcc to generate broken constructor code. As a result, a 64 bit x86 kernel compiled with CONFIG_GCOV_PROFILE_ALL=y prints message "gcov: could not create file" and runs into sproadic BUGs during boot. The gcc people indicate that these kinds of problems are endemic when using ad hoc calling conventions. It is therefore best to treat any file compiled with ad hoc calling conventions as an isolated environment and avoid things like profiling or coverage analysis, since those subsystems assume a "normal" calling conventions. This patch avoids the bug by excluding lib/hweight.o from coverage profiling. Reported-by: Meelis Roos <mroos@linux.ee> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/52F3A30C.7050205@linux.vnet.ibm.com Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: <stable@vger.kernel.org>
2014-02-04kbuild: don't enable DEBUG_INFO when building for COMPILE_TESTLinus Torvalds
It really isn't very interesting to have DEBUG_INFO when doing compile coverage stuff (you wouldn't want to run the result anyway, that's kind of the whole point of COMPILE_TEST), and it currently makes the build take longer and use much more disk space for "all{yes,mod}config". There's somewhat active discussion about this still, and we might end up with some new config option for things like this (Andi points out that the silly X86_DECODER_SELFTEST option also slows down the normal coverage tests hugely), but I'm starting the ball rolling with this simple one-liner. DEBUG_INFO isn't that noticeable if you have tons of memory and a good IO subsystem, but it hurts you a lot if you don't - for very little upside for the common use. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-02parisc/sti_console: prefer Linux fonts over built-in ROM fontsHelge Deller
The built-in ROM fonts lack many necessary ASCII characters, which is why it makes sens to prefer the Linux fonts instead if they are available. This makes consoles on STI graphics cards which are not supported by the stifb driver (e.g. Visualize FXe) looks much nicer. Signed-off-by: Helge Deller <deller@gmx.de> Cc: stable@vger.kernel.org # v3.13
2014-01-31Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull SCSI target updates from Nicholas Bellinger: "The highlights this round include: - add support for SCSI Referrals (Hannes) - add support for T10 DIF into target core (nab + mkp) - add support for T10 DIF emulation in FILEIO + RAMDISK backends (Sagi + nab) - add support for T10 DIF -> bio_integrity passthrough in IBLOCK backend (nab) - prep changes to iser-target for >= v3.15 T10 DIF support (Sagi) - add support for qla2xxx N_Port ID Virtualization - NPIV (Saurav + Quinn) - allow percpu_ida_alloc() to receive task state bitmask (Kent) - fix >= v3.12 iscsi-target session reset hung task regression (nab) - fix >= v3.13 percpu_ref se_lun->lun_ref_active race (nab) - fix a long-standing network portal creation race (Andy)" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (51 commits) target: Fix percpu_ref_put race in transport_lun_remove_cmd target/iscsi: Fix network portal creation race target: Report bad sector in sense data for DIF errors iscsi-target: Convert gfp_t parameter to task state bitmask iscsi-target: Fix connection reset hang with percpu_ida_alloc percpu_ida: Make percpu_ida_alloc + callers accept task state bitmask iscsi-target: Pre-allocate more tags to avoid ack starvation qla2xxx: Configure NPIV fc_vport via tcm_qla2xxx_npiv_make_lport qla2xxx: Enhancements to enable NPIV support for QLOGIC ISPs with TCM/LIO. qla2xxx: Fix scsi_host leak on qlt_lport_register callback failure IB/isert: pass scatterlist instead of cmd to fast_reg_mr routine IB/isert: Move fastreg descriptor creation to a function IB/isert: Avoid frwr notation, user fastreg IB/isert: seperate connection protection domains and dma MRs tcm_loop: Enable DIF/DIX modes in SCSI host LLD target/rd: Add DIF protection into rd_execute_rw target/rd: Add support for protection SGL setup + release target/rd: Refactor rd_build_device_space + rd_release_device_space target/file: Add DIF protection support to fd_execute_rw target/file: Add DIF protection init/format support ...
2014-01-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs updates from Chris Mason: "This is a pretty big pull, and most of these changes have been floating in btrfs-next for a long time. Filipe's properties work is a cool building block for inheriting attributes like compression down on a per inode basis. Jeff Mahoney kicked in code to export filesystem info into sysfs. Otherwise, lots of performance improvements, cleanups and bug fixes. Looks like there are still a few other small pending incrementals, but I wanted to get the bulk of this in first" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (149 commits) Btrfs: fix spin_unlock in check_ref_cleanup Btrfs: setup inode location during btrfs_init_inode_locked Btrfs: don't use ram_bytes for uncompressed inline items Btrfs: fix btrfs_search_slot_for_read backwards iteration Btrfs: do not export ulist functions Btrfs: rework ulist with list+rb_tree Btrfs: fix memory leaks on walking backrefs failure Btrfs: fix send file hole detection leading to data corruption Btrfs: add a reschedule point in btrfs_find_all_roots() Btrfs: make send's file extent item search more efficient Btrfs: fix to catch all errors when resolving indirect ref Btrfs: fix protection between walking backrefs and root deletion btrfs: fix warning while merging two adjacent extents Btrfs: fix infinite path build loops in incremental send btrfs: undo sysfs when open_ctree() fails Btrfs: fix snprintf usage by send's gen_unique_name btrfs: fix defrag 32-bit integer overflow btrfs: sysfs: list the NO_HOLES feature btrfs: sysfs: don't show reserved incompat feature btrfs: call permission checks earlier in ioctls and return EPERM ...
2014-01-30percpu_ida: fix a live lockShaohua Li
steal_tags only happens when free tags is more than half of the total tags. This is too strict and can cause live lock. I found that if one cpu has free tags, but other cpu can't steal (thread is bound to specific cpus), threads which want to allocate tags are always sleeping. I found this when I run next patch, but this could happen without it I think. I did performance test too with null_blk. Two cases (each cpu has enough percpu tags, or total tags are limited), no performance changes were observed. Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2014-01-29dma-debug: fix overlap detectionDan Williams
Commit 0abdd7a81b7e ("dma-debug: introduce debug_dma_assert_idle()") was reworked to expand the overlap counter to the full range expressable by 3 tag bits, but it has a thinko in treating the overlap counter as a pure reference count for the entry. Instead of deleting when the reference-count drops to zero, we need to delete when the overlap-count drops below zero. Also, when detecting overflow we can just test the overlap-count > MAX rather than applying special meaning to 0. Regression report available here: http://marc.info/?l=linux-netdev&m=139073373932386&w=2 This patch, now tested on the original net_dma case, sees the expected handful of reports before the eventual data corruption occurs. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Reported-by: Sander Eikelenboom <linux@eikelenboom.it> Cc: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-29lib/genalloc.c: add check gen_pool_dma_alloc() if dma pointer is not NULLLad, Prabhakar
In the gen_pool_dma_alloc() the dma pointer can be NULL and while assigning gen_pool_virt_to_phys(pool, vaddr) to dma caused the following crash on da850 evm: Unable to handle kernel NULL pointer dereference at virtual address 00000000 Internal error: Oops: 805 [#1] PREEMPT ARM Modules linked in: CPU: 0 PID: 1 Comm: swapper Tainted: G W 3.13.0-rc1-00001-g0609e45-dirty #5 task: c4830000 ti: c4832000 task.ti: c4832000 PC is at gen_pool_dma_alloc+0x30/0x3c LR is at gen_pool_virt_to_phys+0x74/0x80 Process swapper, call trace: gen_pool_dma_alloc+0x30/0x3c davinci_pm_probe+0x40/0xa8 platform_drv_probe+0x1c/0x4c driver_probe_device+0x98/0x22c __driver_attach+0x8c/0x90 bus_for_each_dev+0x6c/0x8c bus_add_driver+0x124/0x1d4 driver_register+0x78/0xf8 platform_driver_probe+0x20/0xa4 davinci_init_late+0xc/0x14 init_machine_late+0x1c/0x28 do_one_initcall+0x34/0x15c kernel_init_freeable+0xe4/0x1ac kernel_init+0x8/0xec This patch fixes the above. [akpm@linux-foundation.org: update kerneldoc] Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Cc: Philipp Zabel <p.zabel@pengutronix.de> Cc: Nicolin Chen <b42378@freescale.com> Cc: Joe Perches <joe@perches.com> Cc: Sachin Kamat <sachin.kamat@linaro.org> Cc: <stable@vger.kernel.org> [3.13.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-28kobject: export kobj_sysfs_opsJeff Mahoney
struct kobj_attribute implements the baseline attribute functionality that can be used all over the place. We should export the ops associated with it. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-01-27dynamic_debug: replace obselete simple_strtoul() with kstrtouint()Andrey Ryabinin
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Jason Baron <jbaron@akamai.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-27dynamic_debug: fix ddebug_parse_query()Andrey Ryabinin
This fixes following scenario: $ echo 'file dynamic_debug.c line 1-123 +p' > /sys/kernel/debug/dynamic_debug/control -bash: echo: write error: Invalid argument $ dmesg | grep dynamic_debug dynamic_debug:ddebug_parse_query: last-line:123 < 1st-line:1 dynamic_debug:ddebug_parse_query: query parse failed Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Jason Baron <jbaron@akamai.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-27dynamic_debug: remove wrong error messageAndrey Ryabinin
parse_lineno() returns either negative error code or zero. We don't need to print something here because if parse_lineno fails it will print error message. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Jason Baron <jbaron@akamai.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-27memblock, nobootmem: add memblock_virt_alloc_low()Yinghai Lu
The new memblock_virt APIs are used to replaced old bootmem API. We need to allocate page below 4G for swiotlb. That should fix regression on Andrew's system that is using swiotlb. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-27Merge tag 'stable/for-linus-3.14-rc0-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/swiotlb Pull swiotlb bug-fixes from Konrad Rzeszutek Wilk: - Don't DoS with 'swiotlb is full' message. - Documentation update. * tag 'stable/for-linus-3.14-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/swiotlb: swiotlb: Don't DoS us with 'swiotlb buffer is full' (v2) swiotlb: update format
2014-01-27Merge tag 'firewire-updates' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394 Pull firewire updates from Stefan Richter: "IEEE 1394 (FireWire) subsystem changes: - make remote debugging over 1394 a runtime option instead of a buildtime option - extend remote debug access past the 4 GB barrier on respectively capable hardware - documentation update" * tag 'firewire-updates' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394: firewire: Enable remote DMA above 4 GB firewire: ohci: Turn remote DMA support into a module parameter Documentation/: update FireWire debugging documentation
2014-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) BPF debugger and asm tool by Daniel Borkmann. 2) Speed up create/bind in AF_PACKET, also from Daniel Borkmann. 3) Correct reciprocal_divide and update users, from Hannes Frederic Sowa and Daniel Borkmann. 4) Currently we only have a "set" operation for the hw timestamp socket ioctl, add a "get" operation to match. From Ben Hutchings. 5) Add better trace events for debugging driver datapath problems, also from Ben Hutchings. 6) Implement auto corking in TCP, from Eric Dumazet. Basically, if we have a small send and a previous packet is already in the qdisc or device queue, defer until TX completion or we get more data. 7) Allow userspace to manage ipv6 temporary addresses, from Jiri Pirko. 8) Add a qdisc bypass option for AF_PACKET sockets, from Daniel Borkmann. 9) Share IP header compression code between Bluetooth and IEEE802154 layers, from Jukka Rissanen. 10) Fix ipv6 router reachability probing, from Jiri Benc. 11) Allow packets to be captured on macvtap devices, from Vlad Yasevich. 12) Support tunneling in GRO layer, from Jerry Chu. 13) Allow bonding to be configured fully using netlink, from Scott Feldman. 14) Allow AF_PACKET users to obtain the VLAN TPID, just like they can already get the TCI. From Atzm Watanabe. 15) New "Heavy Hitter" qdisc, from Terry Lam. 16) Significantly improve the IPSEC support in pktgen, from Fan Du. 17) Allow ipv4 tunnels to cache routes, just like sockets. From Tom Herbert. 18) Add Proportional Integral Enhanced packet scheduler, from Vijay Subramanian. 19) Allow openvswitch to mmap'd netlink, from Thomas Graf. 20) Key TCP metrics blobs also by source address, not just destination address. From Christoph Paasch. 21) Support 10G in generic phylib. From Andy Fleming. 22) Try to short-circuit GRO flow compares using device provided RX hash, if provided. From Tom Herbert. The wireless and netfilter folks have been busy little bees too. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (2064 commits) net/cxgb4: Fix referencing freed adapter ipv6: reallocate addrconf router for ipv6 address when lo device up fib_frontend: fix possible NULL pointer dereference rtnetlink: remove IFLA_BOND_SLAVE definition rtnetlink: remove check for fill_slave_info in rtnl_have_link_slave_info qlcnic: update version to 5.3.55 qlcnic: Enhance logic to calculate msix vectors. qlcnic: Refactor interrupt coalescing code for all adapters. qlcnic: Update poll controller code path qlcnic: Interrupt code cleanup qlcnic: Enhance Tx timeout debugging. qlcnic: Use bool for rx_mac_learn. bonding: fix u64 division rtnetlink: add missing IFLA_BOND_AD_INFO_UNSPEC sfc: Use the correct maximum TX DMA ring size for SFC9100 Add Shradha Shah as the sfc driver maintainer. net/vxlan: Share RX skb de-marking and checksum checks with ovs tulip: cleanup by using ARRAY_SIZE() ip_tunnel: clear IPCB in ip_tunnel_xmit() in case dst_link_failure() is called net/cxgb4: Don't retrieve stats during recovery ...
2014-01-25iscsi-target: Fix connection reset hang with percpu_ida_allocNicholas Bellinger
This patch addresses a bug where connection reset would hang indefinately once percpu_ida_alloc() was starved for tags, due to the fact that it always assumed uninterruptible sleep mode. So now make percpu_ida_alloc() check for signal_pending_state() for making interruptible sleep optional, and convert iscsit_allocate_cmd() to set TASK_INTERRUPTIBLE for GFP_KERNEL, or TASK_RUNNING for GFP_ATOMIC. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Kent Overstreet <kmo@daterainc.com> Cc: <stable@vger.kernel.org> #3.12+ Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2014-01-23lib/decompress_unlz4.c: always set an error return code on failuresJan Beulich
"ret", being set to -1 early on, gets cleared by the first invocation of lz4_decompress()/lz4_decompress_unknownoutputsize(), and hence subsequent failures wouldn't be noticed by the caller without setting it back to -1 right after those calls. Reported-by: Matthew Daley <mattjd@gmail.com> Signed-off-by: Jan Beulich <jbeulich@suse.com> Cc: Kyungsik Lee <kyungsik.lee@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
