path: root/lib
2016-03-25kasan: test fix: warn if the UAF could not be detected in kmalloc_uaf2Alexander Potapenko
Signed-off-by: Alexander Potapenko <glider@google.com> Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Andrey Konovalov <adech.fo@gmail.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Konstantin Serebryany <kcc@google.com> Cc: Dmitry Chernenkov <dmitryc@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-25mm, kasan: stackdepot implementation. Enable stackdepot for SLABAlexander Potapenko
Implement the stack depot and provide CONFIG_STACKDEPOT. Stack depot will allow KASAN store allocation/deallocation stack traces for memory chunks. The stack traces are stored in a hash table and referenced by handles which reside in the kasan_alloc_meta and kasan_free_meta structures in the allocated memory chunks. IRQ stack traces are cut below the IRQ entry point to avoid unnecessary duplication. Right now stackdepot support is only enabled in SLAB allocator. Once KASAN features in SLAB are on par with those in SLUB we can switch SLUB to stackdepot as well, thus removing the dependency on SLUB stack bookkeeping, which wastes a lot of memory. This patch is based on the "mm: kasan: stack depots" patch originally prepared by Dmitry Chernenkov. Joonsoo has said that he plans to reuse the stackdepot code for the mm/page_owner.c debugging facility. [akpm@linux-foundation.org: s/depot_stack_handle/depot_stack_handle_t] [aryabinin@virtuozzo.com: comment style fixes] Signed-off-by: Alexander Potapenko <glider@google.com> Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Andrey Konovalov <adech.fo@gmail.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Konstantin Serebryany <kcc@google.com> Cc: Dmitry Chernenkov <dmitryc@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-25mm, kasan: SLAB supportAlexander Potapenko
Add KASAN hooks to SLAB allocator. This patch is based on the "mm: kasan: unified support for SLUB and SLAB allocators" patch originally prepared by Dmitry Chernenkov. Signed-off-by: Alexander Potapenko <glider@google.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Andrey Konovalov <adech.fo@gmail.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Konstantin Serebryany <kcc@google.com> Cc: Dmitry Chernenkov <dmitryc@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-25kasan: modify kmalloc_large_oob_right(), add kmalloc_pagealloc_oob_right()Alexander Potapenko
This patchset implements SLAB support for KASAN Unlike SLUB, SLAB doesn't store allocation/deallocation stacks for heap objects, therefore we reimplement this feature in mm/kasan/stackdepot.c. The intention is to ultimately switch SLUB to use this implementation as well, which will save a lot of memory (right now SLUB bloats each object by 256 bytes to store the allocation/deallocation stacks). Also neither SLUB nor SLAB delay the reuse of freed memory chunks, which is necessary for better detection of use-after-free errors. We introduce memory quarantine (mm/kasan/quarantine.c), which allows delayed reuse of deallocated memory. This patch (of 7): Rename kmalloc_large_oob_right() to kmalloc_pagealloc_oob_right(), as the test only checks the page allocator functionality. Also reimplement kmalloc_large_oob_right() so that the test allocates a large enough chunk of memory that still does not trigger the page allocator fallback. Signed-off-by: Alexander Potapenko <glider@google.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Andrey Konovalov <adech.fo@gmail.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Konstantin Serebryany <kcc@google.com> Cc: Dmitry Chernenkov <dmitryc@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-23parisc,metag: Implement CONFIG_DEBUG_STACK_USAGE optionHelge Deller
On parisc and metag the stack grows upwards, so for those we need to scan the stack downwards in order to calculate how much stack a process has used. Tested on a 64bit parisc kernel. Signed-off-by: Helge Deller <deller@gmx.de>
2016-03-22ubsan: fix tree-wide -Wmaybe-uninitialized false positivesAndrey Ryabinin
-fsanitize=* options makes GCC less smart than usual and increase number of 'maybe-uninitialized' false-positives. So this patch does two things: * Add -Wno-maybe-uninitialized to CFLAGS_UBSAN which will disable all such warnings for instrumented files. * Remove CONFIG_UBSAN_SANITIZE_ALL from all[yes|mod]config builds. So the all[yes|mod]config build goes without -fsanitize=* and still with -Wmaybe-uninitialized. Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-22kernel: add kcov code coverageDmitry Vyukov
kcov provides code coverage collection for coverage-guided fuzzing (randomized testing). Coverage-guided fuzzing is a testing technique that uses coverage feedback to determine new interesting inputs to a system. A notable user-space example is AFL (http://lcamtuf.coredump.cx/afl/). However, this technique is not widely used for kernel testing due to missing compiler and kernel support. kcov does not aim to collect as much coverage as possible. It aims to collect more or less stable coverage that is function of syscall inputs. To achieve this goal it does not collect coverage in soft/hard interrupts and instrumentation of some inherently non-deterministic or non-interesting parts of kernel is disbled (e.g. scheduler, locking). Currently there is a single coverage collection mode (tracing), but the API anticipates additional collection modes. Initially I also implemented a second mode which exposes coverage in a fixed-size hash table of counters (what Quentin used in his original patch). I've dropped the second mode for simplicity. This patch adds the necessary support on kernel side. The complimentary compiler support was added in gcc revision 231296. We've used this support to build syzkaller system call fuzzer, which has found 90 kernel bugs in just 2 months: https://github.com/google/syzkaller/wiki/Found-Bugs We've also found 30+ bugs in our internal systems with syzkaller. Another (yet unexplored) direction where kcov coverage would greatly help is more traditional "blob mutation". For example, mounting a random blob as a filesystem, or receiving a random blob over wire. Why not gcov. Typical fuzzing loop looks as follows: (1) reset coverage, (2) execute a bit of code, (3) collect coverage, repeat. A typical coverage can be just a dozen of basic blocks (e.g. an invalid input). In such context gcov becomes prohibitively expensive as reset/collect coverage steps depend on total number of basic blocks/edges in program (in case of kernel it is about 2M). Cost of kcov depends only on number of executed basic blocks/edges. On top of that, kernel requires per-thread coverage because there are always background threads and unrelated processes that also produce coverage. With inlined gcov instrumentation per-thread coverage is not possible. kcov exposes kernel PCs and control flow to user-space which is insecure. But debugfs should not be mapped as user accessible. Based on a patch by Quentin Casasnovas. [akpm@linux-foundation.org: make task_struct.kcov_mode have type `enum kcov_mode'] [akpm@linux-foundation.org: unbreak allmodconfig] [akpm@linux-foundation.org: follow x86 Makefile layout standards] Signed-off-by: Dmitry Vyukov <dvyukov@google.com> Reviewed-by: Kees Cook <keescook@chromium.org> Cc: syzkaller <syzkaller@googlegroups.com> Cc: Vegard Nossum <vegard.nossum@oracle.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Tavis Ormandy <taviso@google.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com> Cc: Kostya Serebryany <kcc@google.com> Cc: Eric Dumazet <edumazet@google.com> Cc: Alexander Potapenko <glider@google.com> Cc: Kees Cook <keescook@google.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: David Drysdale <drysdale@google.com> Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org> Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com> Cc: Kirill A. Shutemov <kirill@shutemov.name> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-20Merge branch 'core-objtool-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull 'objtool' stack frame validation from Ingo Molnar: "This tree adds a new kernel build-time object file validation feature (ONFIG_STACK_VALIDATION=y): kernel stack frame correctness validation. It was written by and is maintained by Josh Poimboeuf. The motivation: there's a category of hard to find kernel bugs, most of them in assembly code (but also occasionally in C code), that degrades the quality of kernel stack dumps/backtraces. These bugs are hard to detect at the source code level. Such bugs result in incorrect/incomplete backtraces most of time - but can also in some rare cases result in crashes or other undefined behavior. The build time correctness checking is done via the new 'objtool' user-space utility that was written for this purpose and which is hosted in the kernel repository in tools/objtool/. The tool's (very simple) UI and source code design is shaped after Git and perf and shares quite a bit of infrastructure with tools/perf (which tooling infrastructure sharing effort got merged via perf and is already upstream). Objtool follows the well-known kernel coding style. Objtool does not try to check .c or .S files, it instead analyzes the resulting .o generated machine code from first principles: it decodes the instruction stream and interprets it. (Right now objtool supports the x86-64 architecture.) From tools/objtool/Documentation/stack-validation.txt: "The kernel CONFIG_STACK_VALIDATION option enables a host tool named objtool which runs at compile time. It has a "check" subcommand which analyzes every .o file and ensures the validity of its stack metadata. It enforces a set of rules on asm code and C inline assembly code so that stack traces can be reliable. Currently it only checks frame pointer usage, but there are plans to add CFI validation for C files and CFI generation for asm files. For each function, it recursively follows all possible code paths and validates the correct frame pointer state at each instruction. It also follows code paths involving special sections, like .altinstructions, __jump_table, and __ex_table, which can add alternative execution paths to a given instruction (or set of instructions). Similarly, it knows how to follow switch statements, for which gcc sometimes uses jump tables." When this new kernel option is enabled (it's disabled by default), the tool, if it finds any suspicious assembly code pattern, outputs warnings in compiler warning format: warning: objtool: rtlwifi_rate_mapping()+0x2e7: frame pointer state mismatch warning: objtool: cik_tiling_mode_table_init()+0x6ce: call without frame pointer save/setup warning: objtool:__schedule()+0x3c0: duplicate frame pointer save warning: objtool:__schedule()+0x3fd: sibling call from callable instruction with changed frame pointer ... so that scripts that pick up compiler warnings will notice them. All known warnings triggered by the tool are fixed by the tree, most of the commits in fact prepare the kernel to be warning-free. Most of them are bugfixes or cleanups that stand on their own, but there are also some annotations of 'special' stack frames for justified cases such entries to JIT-ed code (BPF) or really special boot time code. There are two other long-term motivations behind this tool as well: - To improve the quality and reliability of kernel stack frames, so that they can be used for optimized live patching. - To create independent infrastructure to check the correctness of CFI stack frames at build time. CFI debuginfo is notoriously unreliable and we cannot use it in the kernel as-is without extra checking done both on the kernel side and on the build side. The quality of kernel stack frames matters to debuggability as well, so IMO we can merge this without having to consider the live patching or CFI debuginfo angle" * 'core-objtool-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (52 commits) objtool: Only print one warning per function objtool: Add several performance improvements tools: Copy hashtable.h into tools directory objtool: Fix false positive warnings for functions with multiple switch statements objtool: Rename some variables and functions objtool: Remove superflous INIT_LIST_HEAD objtool: Add helper macros for traversing instructions objtool: Fix false positive warnings related to sibling calls objtool: Compile with debugging symbols objtool: Detect infinite recursion objtool: Prevent infinite recursion in noreturn detection objtool: Detect and warn if libelf is missing and don't break the build tools: Support relative directory path for 'O=' objtool: Support CROSS_COMPILE x86/asm/decoder: Use explicitly signed chars objtool: Enable stack metadata validation on 64-bit x86 objtool: Add CONFIG_STACK_VALIDATION option objtool: Add tool to perform compile-time stack metadata validation x86/kprobes: Mark kretprobe_trampoline() stack frame as non-standard sched: Always inline context_switch() ...
2016-03-20Merge tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhostLinus Torvalds
Pull virtio/vhost updates from Michael Tsirkin: "New features, performance improvements, cleanups: - basic polling support for vhost - rework virtio to optionally use DMA API, fixing it on Xen - balloon stats gained a new entry - using the new napi_alloc_skb speeds up virtio net - virtio blk stats can now be read while another VCPU is busy inflating or deflating the balloon plus misc cleanups in various places" * tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost: virtio_net: replace netdev_alloc_skb_ip_align() with napi_alloc_skb() vhost_net: basic polling support vhost: introduce vhost_vq_avail_empty() vhost: introduce vhost_has_work() virtio_balloon: Allow to resize and update the balloon stats in parallel virtio_balloon: Use a workqueue instead of "vballoon" kthread virtio/s390: size of SET_IND payload virtio/s390: use dev_to_virtio vhost: rename vhost_init_used() vhost: rename cross-endian helpers virtio_blk: VIRTIO_BLK_F_WCE->VIRTIO_BLK_F_FLUSH vring: Use the DMA API on Xen virtio_pci: Use the DMA API if enabled virtio_mmio: Use the DMA API if enabled virtio: Add improved queue allocation API virtio_ring: Support DMA APIs vring: Introduce vring_use_dma_api() s390/dma: Allow per device dma ops alpha/dma: use common noop dma ops dma: Provide simple noop dma ops
2016-03-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights: 1) Support more Realtek wireless chips, from Jes Sorenson. 2) New BPF types for per-cpu hash and arrap maps, from Alexei Starovoitov. 3) Make several TCP sysctls per-namespace, from Nikolay Borisov. 4) Allow the use of SO_REUSEPORT in order to do per-thread processing of incoming TCP/UDP connections. The muxing can be done using a BPF program which hashes the incoming packet. From Craig Gallek. 5) Add a multiplexer for TCP streams, to provide a messaged based interface. BPF programs can be used to determine the message boundaries. From Tom Herbert. 6) Add 802.1AE MACSEC support, from Sabrina Dubroca. 7) Avoid factorial complexity when taking down an inetdev interface with lots of configured addresses. We were doing things like traversing the entire address less for each address removed, and flushing the entire netfilter conntrack table for every address as well. 8) Add and use SKB bulk free infrastructure, from Jesper Brouer. 9) Allow offloading u32 classifiers to hardware, and implement for ixgbe, from John Fastabend. 10) Allow configuring IRQ coalescing parameters on a per-queue basis, from Kan Liang. 11) Extend ethtool so that larger link mode masks can be supported. From David Decotigny. 12) Introduce devlink, which can be used to configure port link types (ethernet vs Infiniband, etc.), port splitting, and switch device level attributes as a whole. From Jiri Pirko. 13) Hardware offload support for flower classifiers, from Amir Vadai. 14) Add "Local Checksum Offload". Basically, for a tunneled packet the checksum of the outer header is 'constant' (because with the checksum field filled into the inner protocol header, the payload of the outer frame checksums to 'zero'), and we can take advantage of that in various ways. From Edward Cree" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1548 commits) bonding: fix bond_get_stats() net: bcmgenet: fix dma api length mismatch net/mlx4_core: Fix backward compatibility on VFs phy: mdio-thunder: Fix some Kconfig typos lan78xx: add ndo_get_stats64 lan78xx: handle statistics counter rollover RDS: TCP: Remove unused constant RDS: TCP: Add sysctl tunables for sndbuf/rcvbuf on rds-tcp socket net: smc911x: convert pxa dma to dmaengine team: remove duplicate set of flag IFF_MULTICAST bonding: remove duplicate set of flag IFF_MULTICAST net: fix a comment typo ethernet: micrel: fix some error codes ip_tunnels, bpf: define IP_TUNNEL_OPTS_MAX and use it bpf, dst: add and use dst_tclassid helper bpf: make skb->tc_classid also readable net: mvneta: bm: clarify dependencies cls_bpf: reset class and reuse major in da ldmvsw: Checkpatch sunvnet.c and sunvnet_common.c ldmvsw: Add ldmvsw.c driver code ...
2016-03-18Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge second patch-bomb from Andrew Morton: - a couple of hotfixes - the rest of MM - a new timer slack control in procfs - a couple of procfs fixes - a few misc things - some printk tweaks - lib/ updates, notably to radix-tree. - add my and Nick Piggin's old userspace radix-tree test harness to tools/testing/radix-tree/. Matthew said it was a godsend during the radix-tree work he did. - a few code-size improvements, switching to __always_inline where gcc screwed up. - partially implement character sets in sscanf * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (118 commits) sscanf: implement basic character sets lib/bug.c: use common WARN helper param: convert some "on"/"off" users to strtobool lib: add "on"/"off" support to kstrtobool lib: update single-char callers of strtobool() lib: move strtobool() to kstrtobool() include/linux/unaligned: force inlining of byteswap operations include/uapi/linux/byteorder, swab: force inlining of some byteswap operations include/asm-generic/atomic-long.h: force inlining of some atomic_long operations usb: common: convert to use match_string() helper ide: hpt366: convert to use match_string() helper ata: hpt366: convert to use match_string() helper power: ab8500: convert to use match_string() helper power: charger_manager: convert to use match_string() helper drm/edid: convert to use match_string() helper pinctrl: convert to use match_string() helper device property: convert to use match_string() helper lib/string: introduce match_string() helper radix-tree tests: add test for radix_tree_iter_next radix-tree tests: add regression3 test ...
2016-03-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: drivers/rtc: broken link fix drm/i915 Fix typos in i915_gem_fence.c Docs: fix missing word in REPORTING-BUGS lib+mm: fix few spelling mistakes MAINTAINERS: add git URL for APM driver treewide: Fix typo in printk
2016-03-17Merge tag 'arm64-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 updates from Catalin Marinas: "Here are the main arm64 updates for 4.6. There are some relatively intrusive changes to support KASLR, the reworking of the kernel virtual memory layout and initial page table creation. Summary: - Initial page table creation reworked to avoid breaking large block mappings (huge pages) into smaller ones. The ARM architecture requires break-before-make in such cases to avoid TLB conflicts but that's not always possible on live page tables - Kernel virtual memory layout: the kernel image is no longer linked to the bottom of the linear mapping (PAGE_OFFSET) but at the bottom of the vmalloc space, allowing the kernel to be loaded (nearly) anywhere in physical RAM - Kernel ASLR: position independent kernel Image and modules being randomly mapped in the vmalloc space with the randomness is provided by UEFI (efi_get_random_bytes() patches merged via the arm64 tree, acked by Matt Fleming) - Implement relative exception tables for arm64, required by KASLR (initial code for ARCH_HAS_RELATIVE_EXTABLE added to lib/extable.c but actual x86 conversion to deferred to 4.7 because of the merge dependencies) - Support for the User Access Override feature of ARMv8.2: this allows uaccess functions (get_user etc.) to be implemented using LDTR/STTR instructions. Such instructions, when run by the kernel, perform unprivileged accesses adding an extra level of protection. The set_fs() macro is used to "upgrade" such instruction to privileged accesses via the UAO bit - Half-precision floating point support (part of ARMv8.2) - Optimisations for CPUs with or without a hardware prefetcher (using run-time code patching) - copy_page performance improvement to deal with 128 bytes at a time - Sanity checks on the CPU capabilities (via CPUID) to prevent incompatible secondary CPUs from being brought up (e.g. weird big.LITTLE configurations) - valid_user_regs() reworked for better sanity check of the sigcontext information (restored pstate information) - ACPI parking protocol implementation - CONFIG_DEBUG_RODATA enabled by default - VDSO code marked as read-only - DEBUG_PAGEALLOC support - ARCH_HAS_UBSAN_SANITIZE_ALL enabled - Erratum workaround Cavium ThunderX SoC - set_pte_at() fix for PROT_NONE mappings - Code clean-ups" * tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (99 commits) arm64: kasan: Fix zero shadow mapping overriding kernel image shadow arm64: kasan: Use actual memory node when populating the kernel image shadow arm64: Update PTE_RDONLY in set_pte_at() for PROT_NONE permission arm64: Fix misspellings in comments. arm64: efi: add missing frame pointer assignment arm64: make mrs_s prefixing implicit in read_cpuid arm64: enable CONFIG_DEBUG_RODATA by default arm64: Rework valid_user_regs arm64: mm: check at build time that PAGE_OFFSET divides the VA space evenly arm64: KVM: Move kvm_call_hyp back to its original localtion arm64: mm: treat memstart_addr as a signed quantity arm64: mm: list kernel sections in order arm64: lse: deal with clobbered IP registers after branch via PLT arm64: mm: dump: Use VA_START directly instead of private LOWEST_ADDR arm64: kconfig: add submenu for 8.2 architectural features arm64: kernel: acpi: fix ioremap in ACPI parking protocol cpu_postboot arm64: Add support for Half precision floating point arm64: Remove fixmap include fragility arm64: Add workaround for Cavium erratum 27456 arm64: mm: Mark .rodata as RO ...
2016-03-17sscanf: implement basic character setsJessica Yu
Implement basic character sets for the '%[' conversion specifier. The '%[' conversion specifier matches a nonempty sequence of characters from the specified set of accepted (or with '^', rejected) characters between the brackets. The substring matched is to be made up of characters in (or not in) the set. This is useful for matching substrings that are delimited by something other than spaces. This implementation differs from its glibc counterpart in the following ways: (1) No support for character ranges (e.g., 'a-z' or '0-9') (2) The hyphen '-' is not a special character (3) The closing bracket ']' cannot be matched (4) No support (yet) for discarding matching input ('%*[') The bitmap code is largely based upon sample code which was provided by Rasmus. The motivation for adding character set support to sscanf originally stemmed from the kernel livepatching project. An ongoing patchset utilizes new livepatch Elf symbol and section names to store important metadata livepatch needs to properly apply its patches. Such metadata is stored in these section and symbol names as substrings delimited by periods '.' and commas ','. For example, a livepatch symbol name might look like this: .klp.sym.vmlinux.printk,0 However, sscanf currently can only extract "substrings" delimited by whitespace using the "%s" specifier. Thus for the above symbol name, one cannot not use sscanf() to extract substrings "vmlinux" or "printk", for example. A number of discussions on the livepatch mailing list dealing with string parsing code for extracting these '.' and ',' delimited substrings eventually led to the conclusion that such code would be completely unnecessary if the kernel sscanf() supported character sets. Thus only a single sscanf() call would be necessary to extract these substrings. In addition, such an addition to sscanf() could benefit other areas of the kernel that might have a similar need in the future. [akpm@linux-foundation.org: 80-col tweaks] Signed-off-by: Jessica Yu <jeyu@redhat.com> Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Kees Cook <keescook@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-17lib/bug.c: use common WARN helperJosh Poimboeuf
The traceoff_on_warning option doesn't have any effect on s390, powerpc, arm64, parisc, and sh because there are two different types of WARN implementations: 1) The above mentioned architectures treat WARN() as a special case of a BUG() exception. They handle warnings in report_bug() in lib/bug.c. 2) All other architectures just call warn_slowpath_*() directly. Their warnings are handled in warn_slowpath_common() in kernel/panic.c. Support traceoff_on_warning on all architectures and prevent any future divergence by using a single common function to emit the warning. Also remove the '()' from '%pS()', because the parentheses look funky: [ 45.607629] WARNING: at /root/warn_mod/warn_mod.c:17 .init_dummy+0x20/0x40 [warn_mod]() Reported-by: Chunyu Hu <chuhu@redhat.com> Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Tested-by: Prarit Bhargava <prarit@redhat.com> Acked-by: Prarit Bhargava <prarit@redhat.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-17lib: add "on"/"off" support to kstrtoboolKees Cook
Add support for "on" and "off" when converting to boolean. Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Amitkumar Karwar <akarwar@marvell.com> Cc: Andy Shevchenko <andy.shevchenko@gmail.com> Cc: Daniel Borkmann <daniel@iogearbox.net> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Joe Perches <joe@perches.com> Cc: Kalle Valo <kvalo@codeaurora.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Nishant Sarmukadam <nishants@marvell.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Steve French <sfrench@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-17lib: move strtobool() to kstrtobool()Kees Cook
Create the kstrtobool_from_user() helper and move strtobool() logic into the new kstrtobool() (matching all the other kstrto* functions). Provides an inline wrapper for existing strtobool() callers. Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Joe Perches <joe@perches.com> Cc: Andy Shevchenko <andy.shevchenko@gmail.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Daniel Borkmann <daniel@iogearbox.net> Cc: Amitkumar Karwar <akarwar@marvell.com> Cc: Nishant Sarmukadam <nishants@marvell.com> Cc: Kalle Valo <kvalo@codeaurora.org> Cc: Steve French <sfrench@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-17lib/string: introduce match_string() helperAndy Shevchenko
Occasionally we have to search for an occurrence of a string in an array of strings. Make a simple helper for that purpose. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Cc: David Airlie <airlied@linux.ie> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Heikki Krogerus <heikki.krogerus@linux.intel.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Mika Westerberg <mika.westerberg@linux.intel.com> Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: Sebastian Reichel <sre@kernel.org> Cc: Tejun Heo <tj@kernel.org> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-17radix_tree: add radix_tree_dumpMatthew Wilcox
This is debug code which is #if 0 out. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-17radix_tree: add support for multi-order entriesMatthew Wilcox
With huge pages, it is convenient to have the radix tree be able to return an entry that covers multiple indices. Previous attempts to deal with the problem have involved inserting N duplicate entries, which is a waste of memory and leads to problems trying to handle aliased tags, or probing the tree multiple times to find alternative entries which might cover the requested index. This approach inserts one canonical entry into the tree for a given range of indices, and may also insert other entries in order to ensure that lookups find the canonical entry. This solution only tolerates inserting powers of two that are greater than the fanout of the tree. If we wish to expand the radix tree's abilities to support large-ish pages that is less than the fanout at the penultimate level of the tree, then we would need to add one more step in lookup to ensure that any sibling nodes in the final level of the tree are dereferenced and we return the canonical entry that they reference. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-17radix_tree: loop based on shift count, not heightMatthew Wilcox
When we introduce entries that can cover multiple indices, we will need to stop in __radix_tree_create based on the shift, not the height. Split out for ease of bisect. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-17radix_tree: tag all internal tree nodes as indirect pointersMatthew Wilcox
Set the 'indirect_ptr' bit on all the pointers to internal nodes, not just on the root node. This enables the following patches to support multi-order entries in the radix tree. This patch is split out for ease of bisection. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-17lib/bug.c: make panic_on_warn available for all architecturesHeiko Carstens
Christian Borntraeger reported that panic_on_warn doesn't have any effect on s390. The panic_on_warn feature was introduced with 9e3961a09798 ("kernel: add panic_on_warn"). However it did care only for the case when WANT_WARN_ON_SLOWPATH is defined. This is turn is only the case for architectures which do not have an own __WARN_TAINT defined. Other architectures which do have __WARN_TAINT defined call report_bug() for warnings within lib/bug.c which does not call panic() in case panic_on_warn is set. Let's simply enable the panic_on_warn feature by adding the same code like it was added to warn_slowpath_common() in panic.c. This enables panic_on_warn also for arm64, parisc, powerpc, s390 and sh. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Reported-by: Christian Borntraeger <borntraeger@de.ibm.com> Tested-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Prarit Bhargava <prarit@redhat.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Tested-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-17radix-tree: account radix_tree_node to memory cgroupVladimir Davydov
Allocation of radix_tree_node objects can be easily triggered from userspace, so we should account them to memory cgroup. Besides, we need them accounted for making shadow node shrinker per memcg (see mm/workingset.c). A tricky thing about accounting radix_tree_node objects is that they are mostly allocated through radix_tree_preload(), so we can't just set SLAB_ACCOUNT for radix_tree_node_cachep - that would likely result in a lot of unrelated cgroups using objects from each other's caches. One way to overcome this would be making radix tree preloads per memcg, but that would probably look cumbersome and overcomplicated. Instead, we make radix_tree_node_alloc() first try to allocate from the cache with __GFP_ACCOUNT, no matter if the caller has preloaded or not, and only if it fails fall back on using per cpu preloads. This should make most allocations accounted. Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-17Merge tag 'char-misc-4.6-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc updates from Greg KH: "Here is the big char/misc driver update for 4.6-rc1. The majority of the patches here is hwtracing and some new mic drivers, but there's a lot of other driver updates as well. Full details in the shortlog. All have been in linux-next for a while with no reported issues" * tag 'char-misc-4.6-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (238 commits) goldfish: Fix build error of missing ioremap on UM nvmem: mediatek: Fix later provider initialization nvmem: imx-ocotp: Fix return value of imx_ocotp_read nvmem: Fix dependencies for !HAS_IOMEM archs char: genrtc: replace blacklist with whitelist drivers/hwtracing: make coresight-etm-perf.c explicitly non-modular drivers: char: mem: fix IS_ERROR_VALUE usage char: xillybus: Fix internal data structure initialization pch_phub: return -ENODATA if ROM can't be mapped Drivers: hv: vmbus: Support kexec on ws2012 r2 and above Drivers: hv: vmbus: Support handling messages on multiple CPUs Drivers: hv: utils: Remove util transport handler from list if registration fails Drivers: hv: util: Pass the channel information during the init call Drivers: hv: vmbus: avoid unneeded compiler optimizations in vmbus_wait_for_unload() Drivers: hv: vmbus: remove code duplication in message handling Drivers: hv: vmbus: avoid wait_for_completion() on crash Drivers: hv: vmbus: don't loose HVMSG_TIMER_EXPIRED messages misc: at24: replace memory_accessor with nvmem_device_read eeprom: 93xx46: extend driver to plug into the NVMEM framework eeprom: at25: extend driver to plug into the NVMEM framework ...
2016-03-17Merge tag 'driver-core-4.6-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg KH: "Just a few patches this time around for the 4.6-rc1 merge window. Largest is a new firmware driver, but there are some other updates to the driver core in here as well, the shortlog has the details. All have been in linux-next for a while with no reported issues" * tag 'driver-core-4.6-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: Revert "driver-core: platform: probe of-devices only using list of compatibles" firmware: qemu config needs I/O ports firmware: qemu_fw_cfg.c: fix typo FW_CFG_DATA_OFF driver-core: platform: probe of-devices only using list of compatibles driver-core: platform: fix typo in documentation for multi-driver helper component: remove impossible condition drivers: dma-coherent: simplify dma_init_coherent_memory return value devicetree: update documentation for fw_cfg ARM bindings firmware: create directory hierarchy for sysfs fw_cfg entries firmware: introduce sysfs driver for QEMU's fw_cfg device kobject: export kset_find_obj() for module use driver core: bus: use to_subsys_private and to_device_private_bus driver core: bus: use list_for_each_entry* debugfs: Add stub function for debugfs_create_automount(). kernfs: make kernfs_walk_ns() use kernfs_pr_cont_buf[]
2016-03-17Merge branch 'linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6 Pull crypto update from Herbert Xu: "Here is the crypto update for 4.6: API: - Convert remaining crypto_hash users to shash or ahash, also convert blkcipher/ablkcipher users to skcipher. - Remove crypto_hash interface. - Remove crypto_pcomp interface. - Add crypto engine for async cipher drivers. - Add akcipher documentation. - Add skcipher documentation. Algorithms: - Rename crypto/crc32 to avoid name clash with lib/crc32. - Fix bug in keywrap where we zero the wrong pointer. Drivers: - Support T5/M5, T7/M7 SPARC CPUs in n2 hwrng driver. - Add PIC32 hwrng driver. - Support BCM6368 in bcm63xx hwrng driver. - Pack structs for 32-bit compat users in qat. - Use crypto engine in omap-aes. - Add support for sama5d2x SoCs in atmel-sha. - Make atmel-sha available again. - Make sahara hashing available again. - Make ccp hashing available again. - Make sha1-mb available again. - Add support for multiple devices in ccp. - Improve DMA performance in caam. - Add hashing support to rockchip" * 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (116 commits) crypto: qat - remove redundant arbiter configuration crypto: ux500 - fix checks of error code returned by devm_ioremap_resource() crypto: atmel - fix checks of error code returned by devm_ioremap_resource() crypto: qat - Change the definition of icp_qat_uof_regtype hwrng: exynos - use __maybe_unused to hide pm functions crypto: ccp - Add abstraction for device-specific calls crypto: ccp - CCP versioning support crypto: ccp - Support for multiple CCPs crypto: ccp - Remove check for x86 family and model crypto: ccp - memset request context to zero during import lib/mpi: use "static inline" instead of "extern inline" lib/mpi: avoid assembler warning hwrng: bcm63xx - fix non device tree compatibility crypto: testmgr - allow rfc3686 aes-ctr variants in fips mode. crypto: qat - The AE id should be less than the maximal AE number lib/mpi: Endianness fix crypto: rockchip - add hash support for crypto engine in rk3288 crypto: xts - fix compile errors crypto: doc - add skcipher API documentation crypto: doc - update AEAD AD handling ...
2016-03-16Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge first patch-bomb from Andrew Morton: - some misc things - ofs2 updates - about half of MM - checkpatch updates - autofs4 update * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (120 commits) autofs4: fix string.h include in auto_dev-ioctl.h autofs4: use pr_xxx() macros directly for logging autofs4: change log print macros to not insert newline autofs4: make autofs log prints consistent autofs4: fix some white space errors autofs4: fix invalid ioctl return in autofs4_root_ioctl_unlocked() autofs4: fix coding style line length in autofs4_wait() autofs4: fix coding style problem in autofs4_get_set_timeout() autofs4: coding style fixes autofs: show pipe inode in mount options kallsyms: add support for relative offsets in kallsyms address table kallsyms: don't overload absolute symbol type for percpu symbols x86: kallsyms: disable absolute percpu symbols on !SMP checkpatch: fix another left brace warning checkpatch: improve UNSPECIFIED_INT test for bare signed/unsigned uses checkpatch: warn on bare unsigned or signed declarations without int checkpatch: exclude asm volatile from complex macro check mm: memcontrol: drop unnecessary lru locking from mem_cgroup_migrate() mm: migrate: consolidate mem_cgroup_migrate() calls mm/compaction: speed up pageblock_pfn_to_page() when zone is contiguous ...
2016-03-15mm, printk: introduce new format string for flagsVlastimil Babka
In mm we use several kinds of flags bitfields that are sometimes printed for debugging purposes, or exported to userspace via sysfs. To make them easier to interpret independently on kernel version and config, we want to dump also the symbolic flag names. So far this has been done with repeated calls to pr_cont(), which is unreliable on SMP, and not usable for e.g. sysfs export. To get a more reliable and universal solution, this patch extends printk() format string for pointers to handle the page flags (%pGp), gfp_flags (%pGg) and vma flags (%pGv). Existing users of dump_flag_names() are converted and simplified. It would be possible to pass flags by value instead of pointer, but the %p format string for pointers already has extensions for various kernel structures, so it's a good fit, and the extra indirection in a non-critical path is negligible. [linux@rasmusvillemoes.dk: lots of good implementation suggestions] Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-15Merge branch 'smp-hotplug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull cpu hotplug updates from Thomas Gleixner: "This is the first part of the ongoing cpu hotplug rework: - Initial implementation of the state machine - Runs all online and prepare down callbacks on the plugged cpu and not on some random processor - Replaces busy loop waiting with completions - Adds tracepoints so the states can be followed" More detailed commentary on this work from an earlier email: "What's wrong with the current cpu hotplug infrastructure? - Asymmetry The hotplug notifier mechanism is asymmetric versus the bringup and teardown. This is mostly caused by the notifier mechanism. - Largely undocumented dependencies While some notifiers use explicitely defined notifier priorities, we have quite some notifiers which use numerical priorities to express dependencies without any documentation why. - Control processor driven Most of the bringup/teardown of a cpu is driven by a control processor. While it is understandable, that preperatory steps, like idle thread creation, memory allocation for and initialization of essential facilities needs to be done before a cpu can boot, there is no reason why everything else must run on a control processor. Before this patch series, bringup looks like this: Control CPU Booting CPU do preparatory steps kick cpu into life do low level init sync with booting cpu sync with control cpu bring the rest up - All or nothing approach There is no way to do partial bringups. That's something which is really desired because we waste e.g. at boot substantial amount of time just busy waiting that the cpu comes to life. That's stupid as we could very well do preparatory steps and the initial IPI for other cpus and then go back and do the necessary low level synchronization with the freshly booted cpu. - Minimal debuggability Due to the notifier based design, it's impossible to switch between two stages of the bringup/teardown back and forth in order to test the correctness. So in many hotplug notifiers the cancel mechanisms are either not existant or completely untested. - Notifier [un]registering is tedious To [un]register notifiers we need to protect against hotplug at every callsite. There is no mechanism that bringup/teardown callbacks are issued on the online cpus, so every caller needs to do it itself. That also includes error rollback. What's the new design? The base of the new design is a symmetric state machine, where both the control processor and the booting/dying cpu execute a well defined set of states. Each state is symmetric in the end, except for some well defined exceptions, and the bringup/teardown can be stopped and reversed at almost all states. So the bringup of a cpu will look like this in the future: Control CPU Booting CPU do preparatory steps kick cpu into life do low level init sync with booting cpu sync with control cpu bring itself up The synchronization step does not require the control cpu to wait. That mechanism can be done asynchronously via a worker or some other mechanism. The teardown can be made very similar, so that the dying cpu cleans up and brings itself down. Cleanups which need to be done after the cpu is gone, can be scheduled asynchronously as well. There is a long way to this, as we need to refactor the notion when a cpu is available. Today we set the cpu online right after it comes out of the low level bringup, which is not really correct. The proper mechanism is to set it to available, i.e. cpu local threads, like softirqd, hotplug thread etc. can be scheduled on that cpu, and once it finished all booting steps, it's set to online, so general workloads can be scheduled on it. The reverse happens on teardown. First thing to do is to forbid scheduling of general workloads, then teardown all the per cpu resources and finally shut it off completely. This patch series implements the basic infrastructure for this at the core level. This includes the following: - Basic state machine implementation with well defined states, so ordering and prioritization can be expressed. - Interfaces to [un]register state callbacks This invokes the bringup/teardown callback on all online cpus with the proper protection in place and [un]installs the callbacks in the state machine array. For callbacks which have no particular ordering requirement we have a dynamic state space, so that drivers don't have to register an explicit hotplug state. If a callback fails, the code automatically does a rollback to the previous state. - Sysfs interface to drive the state machine to a particular step. This is only partially functional today. Full functionality and therefor testability will be achieved once we converted all existing hotplug notifiers over to the new scheme. - Run all CPU_ONLINE/DOWN_PREPARE notifiers on the booting/dying processor: Control CPU Booting CPU do preparatory steps kick cpu into life do low level init sync with booting cpu sync with control cpu wait for boot bring itself up Signal completion to control cpu In a previous step of this work we've done a full tree mechanical conversion of all hotplug notifiers to the new scheme. The balance is a net removal of about 4000 lines of code. This is not included in this series, as we decided to take a different approach. Instead of mechanically converting everything over, we will do a proper overhaul of the usage sites one by one so they nicely fit into the symmetric callback scheme. I decided to do that after I looked at the ugliness of some of the converted sites and figured out that their hotplug mechanism is completely buggered anyway. So there is no point to do a mechanical conversion first as we need to go through the usage sites one by one again in order to achieve a full symmetric and testable behaviour" * 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits) cpu/hotplug: Document states better cpu/hotplug: Fix smpboot thread ordering cpu/hotplug: Remove redundant state check cpu/hotplug: Plug death reporting race rcu: Make CPU_DYING_IDLE an explicit call cpu/hotplug: Make wait for dead cpu completion based cpu/hotplug: Let upcoming cpu bring itself fully up arch/hotplug: Call into idle with a proper state cpu/hotplug: Move online calls to hotplugged cpu cpu/hotplug: Create hotplug threads cpu/hotplug: Split out the state walk into functions cpu/hotplug: Unpark smpboot threads from the state machine cpu/hotplug: Move scheduler cpu_online notifier to hotplug core cpu/hotplug: Implement setup/removal interface cpu/hotplug: Make target state writeable cpu/hotplug: Add sysfs state interface cpu/hotplug: Hand in target state to _cpu_up/down cpu/hotplug: Convert the hotplugged cpu work to a state machine cpu/hotplug: Convert to a state machine for the control processor cpu/hotplug: Add tracepoints ...
2016-03-15Merge branch 'x86-asm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 asm updates from Ingo Molnar: "This is another big update. Main changes are: - lots of x86 system call (and other traps/exceptions) entry code enhancements. In particular the complex parts of the 64-bit entry code have been migrated to C code as well, and a number of dusty corners have been refreshed. (Andy Lutomirski) - vDSO special mapping robustification and general cleanups (Andy Lutomirski) - cpufeature refactoring, cleanups and speedups (Borislav Petkov) - lots of other changes ..." * 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (64 commits) x86/cpufeature: Enable new AVX-512 features x86/entry/traps: Show unhandled signal for i386 in do_trap() x86/entry: Call enter_from_user_mode() with IRQs off x86/entry/32: Change INT80 to be an interrupt gate x86/entry: Improve system call entry comments x86/entry: Remove TIF_SINGLESTEP entry work x86/entry/32: Add and check a stack canary for the SYSENTER stack x86/entry/32: Simplify and fix up the SYSENTER stack #DB/NMI fixup x86/entry: Only allocate space for tss_struct::SYSENTER_stack if needed x86/entry: Vastly simplify SYSENTER TF (single-step) handling x86/entry/traps: Clear DR6 early in do_debug() and improve the comment x86/entry/traps: Clear TIF_BLOCKSTEP on all debug exceptions x86/entry/32: Restore FLAGS on SYSEXIT x86/entry/32: Filter NT and speed up AC filtering in SYSENTER x86/entry/compat: In SYSENTER, sink AC clearing below the existing FLAGS test selftests/x86: In syscall_nt, test NT|TF as well x86/asm-offsets: Remove PARAVIRT_enabled x86/entry/32: Introduce and use X86_BUG_ESPFIX instead of paravirt_enabled uprobes: __create_xol_area() must nullify xol_mapping.fault x86/cpufeature: Create a new synthetic cpu capability for machine check recovery ...
2016-03-14Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Ingo Molnar: "Main kernel side changes: - Big reorganization of the x86 perf support code. The old code grew organically deep inside arch/x86/kernel/cpu/perf* and its naming became somewhat messy. The new location is under arch/x86/events/, using the following cleaner hierarchy of source code files: perf/x86: Move perf_event.c .................. => x86/events/core.c perf/x86: Move perf_event_amd.c .............. => x86/events/amd/core.c perf/x86: Move perf_event_amd_ibs.c .......... => x86/events/amd/ibs.c perf/x86: Move perf_event_amd_iommu.[ch] ..... => x86/events/amd/iommu.[ch] perf/x86: Move perf_event_amd_uncore.c ....... => x86/events/amd/uncore.c perf/x86: Move perf_event_intel_bts.c ........ => x86/events/intel/bts.c perf/x86: Move perf_event_intel.c ............ => x86/events/intel/core.c perf/x86: Move perf_event_intel_cqm.c ........ => x86/events/intel/cqm.c perf/x86: Move perf_event_intel_cstate.c ..... => x86/events/intel/cstate.c perf/x86: Move perf_event_intel_ds.c ......... => x86/events/intel/ds.c perf/x86: Move perf_event_intel_lbr.c ........ => x86/events/intel/lbr.c perf/x86: Move perf_event_intel_pt.[ch] ...... => x86/events/intel/pt.[ch] perf/x86: Move perf_event_intel_rapl.c ....... => x86/events/intel/rapl.c perf/x86: Move perf_event_intel_uncore.[ch] .. => x86/events/intel/uncore.[ch] perf/x86: Move perf_event_intel_uncore_nhmex.c => x86/events/intel/uncore_nmhex.c perf/x86: Move perf_event_intel_uncore_snb.c => x86/events/intel/uncore_snb.c perf/x86: Move perf_event_intel_uncore_snbep.c => x86/events/intel/uncore_snbep.c perf/x86: Move perf_event_knc.c .............. => x86/events/intel/knc.c perf/x86: Move perf_event_p4.c ............... => x86/events/intel/p4.c perf/x86: Move perf_event_p6.c ............... => x86/events/intel/p6.c perf/x86: Move perf_event_msr.c .............. => x86/events/msr.c (Borislav Petkov) - Update various x86 PMU constraint and hw support details (Stephane Eranian) - Optimize kprobes for BPF execution (Martin KaFai Lau) - Rewrite, refactor and fix the Intel uncore PMU driver code (Thomas Gleixner) - Rewrite, refactor and fix the Intel RAPL PMU code (Thomas Gleixner) - Various fixes and smaller cleanups. There are lots of perf tooling updates as well. A few highlights: perf report/top: - Hierarchy histogram mode for 'perf top' and 'perf report', showing multiple levels, one per --sort entry: (Namhyung Kim) On a mostly idle system: # perf top --hierarchy -s comm,dso Then expand some levels and use 'P' to take a snapshot: # cat perf.hist.0 - 92.32% perf 58.20% perf 22.29% libc-2.22.so 5.97% [kernel] 4.18% libelf-0.165.so 1.69% [unknown] - 4.71% qemu-system-x86 3.10% [kernel] 1.60% qemu-system-x86_64 (deleted) + 2.97% swapper # - Add 'L' hotkey to dynamicly set the percent threshold for histogram entries and callchains, i.e. dynamicly do what the --percent-limit command line option to 'top' and 'report' does. (Namhyung Kim) perf mem: - Allow specifying events via -e in 'perf mem record', also listing what events can be specified via 'perf mem record -e list' (Jiri Olsa) perf record: - Add 'perf record' --all-user/--all-kernel options, so that one can tell that all the events in the command line should be restricted to the user or kernel levels (Jiri Olsa), i.e.: perf record -e cycles:u,instructions:u is equivalent to: perf record --all-user -e cycles,instructions - Make 'perf record' collect CPU cache info in the perf.data file header: $ perf record usleep 1 [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.017 MB perf.data (7 samples) ] $ perf report --header-only -I | tail -10 | head -8 # CPU cache info: # L1 Data 32K [0-1] # L1 Instruction 32K [0-1] # L1 Data 32K [2-3] # L1 Instruction 32K [2-3] # L2 Unified 256K [0-1] # L2 Unified 256K [2-3] # L3 Unified 4096K [0-3] Will be used in 'perf c2c' and eventually in 'perf diff' to allow, for instance running the same workload in multiple machines and then when using 'diff' show the hardware difference. (Jiri Olsa) - Improved support for Java, using the JVMTI agent library to do jitdumps that then will be inserted in synthesized PERF_RECORD_MMAP2 events via 'perf inject' pointed to synthesized ELF files stored in ~/.debug and keyed with build-ids, to allow symbol resolution and even annotation with source line info, see the changeset comments to see how to use it (Stephane Eranian) perf script/trace: - Decode data_src values (e.g. perf.data files generated by 'perf mem record') in 'perf script': (Jiri Olsa) # perf script perf 693 [1] 4.088652: 1 cpu/mem-loads,ldlat=30/P: ffff88007d0b0f40 68100142 L1 hit|SNP None|TLB L1 or L2 hit|LCK No <SNIP> ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ - Improve support to 'data_src', 'weight' and 'addr' fields in 'perf script' (Jiri Olsa) - Handle empty print fmts in 'perf script -s' i.e. when running python or perl scripts (Taeung Song) perf stat: - 'perf stat' now shows shadow metrics (insn per cycle, etc) in interval mode too. E.g: # perf stat -I 1000 -e instructions,cycles sleep 1 # time counts unit events 1.000215928 519,620 instructions # 0.69 insn per cycle 1.000215928 752,003 cycles <SNIP> - Port 'perf kvm stat' to PowerPC (Hemant Kumar) - Implement CSV metrics output in 'perf stat' (Andi Kleen) perf BPF support: - Support converting data from bpf events in 'perf data' (Wang Nan) - Print bpf-output events in 'perf script': (Wang Nan). # perf record -e bpf-output/no-inherit,name=evt/ -e ./test_bpf_output_3.c/map:channel.event=evt/ usleep 1000 # perf script usleep 4882 21384.532523: evt: ffffffff810e97d1 sys_nanosleep ([kernel.kallsyms]) BPF output: 0000: 52 61 69 73 65 20 61 20 Raise a 0008: 42 50 46 20 65 76 65 6e BPF even 0010: 74 21 00 00 t!.. BPF string: "Raise a BPF event!" # - Add API to set values of map entries in a BPF object, be it individual map slots or ranges (Wang Nan) - Introduce support for the 'bpf-output' event (Wang Nan) - Add glue to read perf events in a BPF program (Wang Nan) - Improve support for bpf-output events in 'perf trace' (Wang Nan) ... and tons of other changes as well - see the shortlog and git log for details!" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (342 commits) perf stat: Add --metric-only support for -A perf stat: Implement --metric-only mode perf stat: Document CSV format in manpage perf hists browser: Check sort keys before hot key actions perf hists browser: Allow thread filtering for comm sort key perf tools: Add sort__has_comm variable perf tools: Recalc total periods using top-level entries in hierarchy perf tools: Remove nr_sort_keys field perf hists browser: Cleanup hist_browser__fprintf_hierarchy_entry() perf tools: Remove hist_entry->fmt field perf tools: Fix command line filters in hierarchy mode perf tools: Add more sort entry check functions perf tools: Fix hist_entry__filter() for hierarchy perf jitdump: Build only on supported archs tools lib traceevent: Add '~' operation within arg_num_eval() perf tools: Omit unnecessary cast in perf_pmu__parse_scale perf tools: Pass perf_hpp_list all the way through setup_sort_list perf tools: Fix perf script python database export crash perf jitdump: DWARF is also needed perf bench mem: Prepare the x86-64 build for upstream memcpy_mcsafe() changes ...
2016-03-13ipv4: Update parameters for csum_tcpudp_magic to their original typesAlexander Duyck
This patch updates all instances of csum_tcpudp_magic and csum_tcpudp_nofold to reflect the types that are usually used as the source inputs. For example the protocol field is populated based on nexthdr which is actually an unsigned 8 bit value. The length is usually populated based on skb->len which is an unsigned integer. This addresses an issue in which the IPv6 function csum_ipv6_magic was generating a checksum using the full 32b of skb->len while csum_tcpudp_magic was only using the lower 16 bits. As a result we could run into issues when attempting to adjust the checksum as there was no protocol agnostic way to update it. With this change the value is still truncated as many architectures use "(len + proto) << 8", however this truncation only occurs for values greater than 16776960 in length and as such is unlikely to occur as we stop the inner headers at ~64K in size. I did have to make a few minor changes in the arm, mn10300, nios2, and score versions of the function in order to support these changes as they were either using things such as an OR to combine the protocol and length, or were using ntohs to convert the length which would have truncated the value. I also updated a few spots in terms of whitespace and type differences for the addresses. Most of this was just to make sure all of the definitions were in sync going forward. Signed-off-by: Alexander Duyck <aduyck@mirantis.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-03-10Merge branch 'linus' into locking/core, to pick up fixesIngo Molnar
2016-03-09list: kill list_force_poison()Dan Williams
Given we have uninitialized list_heads being passed to list_add() it will always be the case that those uninitialized values randomly trigger the poison value. Especially since a list_add() operation will seed the stack with the poison value for later stack allocations to trip over. For example, see these two false positive reports: list_add attempted on force-poisoned entry WARNING: at lib/list_debug.c:34 [..] NIP [c00000000043c390] __list_add+0xb0/0x150 LR [c00000000043c38c] __list_add+0xac/0x150 Call Trace: __list_add+0xac/0x150 (unreliable) __down+0x4c/0xf8 down+0x68/0x70 xfs_buf_lock+0x4c/0x150 [xfs] list_add attempted on force-poisoned entry(0000000000000500), new->next == d0000000059ecdb0, new->prev == 0000000000000500 WARNING: at lib/list_debug.c:33 [..] NIP [c00000000042db78] __list_add+0xa8/0x140 LR [c00000000042db74] __list_add+0xa4/0x140 Call Trace: __list_add+0xa4/0x140 (unreliable) rwsem_down_read_failed+0x6c/0x1a0 down_read+0x58/0x60 xfs_log_commit_cil+0x7c/0x600 [xfs] Fixes: commit 5c2c2587b132 ("mm, dax, pmem: introduce {get|put}_dev_pagemap() for dax-gup") Signed-off-by: Dan Williams <dan.j.williams@intel.com> Reported-by: Eryu Guan <eguan@redhat.com> Tested-by: Eryu Guan <eguan@redhat.com> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-02dma: Provide simple noop dma opsChristian Borntraeger
We are going to require dma_ops for several common drivers, even for systems that do have an identity mapping. Lets provide some minimal no-op dma_ops that can be used for that purpose. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Reviewed-by: Joerg Roedel <jroedel@suse.de> Signed-off-by: Andy Lutomirski <luto@kernel.org> Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2016-03-01Merge 4.5-rc6 into char-misc-nextGreg Kroah-Hartman
We want the fixes in here, and others are sending us pull requests based on this kernel tree. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-01cpu/hotplug: Make target state writeableThomas Gleixner
Make it possible to write a target state to the per cpu state file, so we can switch between states. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arch@vger.kernel.org Cc: Rik van Riel <riel@redhat.com> Cc: Rafael Wysocki <rafael.j.wysocki@intel.com> Cc: "Srivatsa S. Bhat" <srivatsa@mit.edu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Sebastian Siewior <bigeasy@linutronix.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul Turner <pjt@google.com> Link: http://lkml.kernel.org/r/20160226182341.022814799@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-02-29netfilter: meta: add PRANDOM supportFlorian Westphal
Can be used to randomly match packets e.g. for statistic traffic sampling. See commit 3ad0040573b0c00f8848 ("bpf: split state from prandom_u32() and consolidate {c, e}BPF prngs") for more info why this doesn't use prandom_u32 directly. Unlike bpf nft_meta can be built as a module, so add an EXPORT_SYMBOL for prandom_seed_full_state too. Cc: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2016-02-29Merge tag 'v4.5-rc6' into locking/core, to pick up fixesIngo Molnar
2016-02-29cpumask: Export cpumask_any_but()Thomas Gleixner
Almost every cpumask function is exported, just not the one I need to make the Intel uncore driver modular. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andi Kleen <andi.kleen@intel.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Borislav Petkov <bp@alien8.de> Cc: David S. Miller <davem@davemloft.net> Cc: Harish Chegondi <harish.chegondi@intel.com> Cc: Jacob Pan <jacob.jun.pan@linux.intel.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Kan Liang <kan.liang@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Stephane Eranian <eranian@google.com> Cc: Vince Weaver <vincent.weaver@maine.edu> Cc: linux-kernel@vger.kernel.org Link: http://lkml.kernel.org/r/20160222221011.878299859@linutronix.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-02-29objtool: Add CONFIG_STACK_VALIDATION optionJosh Poimboeuf
Add a CONFIG_STACK_VALIDATION option which will run "objtool check" for each .o file to ensure the validity of its stack metadata. Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@kernel.org> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Bernd Petrovitsch <bernd@petrovitsch.priv.at> Cc: Borislav Petkov <bp@alien8.de> Cc: Chris J Arges <chris.j.arges@canonical.com> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michal Marek <mmarek@suse.cz> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Pedro Alves <palves@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: live-patching@vger.kernel.org Link: http://lkml.kernel.org/r/92baab69a6bf9bc7043af0bfca9fb964a1d45546.1456719558.git.jpoimboe@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-02-28lib/mpi: use "static inline" instead of "extern inline"Arnd Bergmann
When we use CONFIG_PROFILE_ALL_BRANCHES, every 'if()' introduces a static variable, but that is not allowed in 'extern inline' functions: mpi-inline.h:116:204: warning: '______f' is static but declared in inline function 'mpihelp_sub' which is not static mpi-inline.h:113:184: warning: '______f' is static but declared in inline function 'mpihelp_sub' which is not static mpi-inline.h:70:184: warning: '______f' is static but declared in inline function 'mpihelp_add' which is not static mpi-inline.h:56:204: warning: '______f' is static but declared in inline function 'mpihelp_add_1' which is not static This changes the MPI code to use 'static inline' instead, to get rid of hundreds of warnings. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-02-28lib/mpi: avoid assembler warningArnd Bergmann
A wrapper around the umull assembly instruction might reuse the input register as an output, which is undefined on some ARM machines, as pointed out by this assembler warning: CC lib/mpi/generic_mpih-mul1.o /tmp/ccxJuxIy.s: Assembler messages: /tmp/ccxJuxIy.s:53: rdhi, rdlo and rm must all be different CC lib/mpi/generic_mpih-mul2.o /tmp/ccI0scAD.s: Assembler messages: /tmp/ccI0scAD.s:53: rdhi, rdlo and rm must all be different CC lib/mpi/generic_mpih-mul3.o /tmp/ccMvVQcp.s: Assembler messages: /tmp/ccMvVQcp.s:53: rdhi, rdlo and rm must all be different This changes the constraints to force different registers to be used as output. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-02-28lib/mpi: Endianness fixMichal Marek
The limbs are integers in the host endianness, so we can't simply iterate over the individual bytes. The current code happens to work on little-endian, because the order of the limbs in the MPI array is the same as the order of the bytes in each limb, but it breaks on big-endian. Fixes: 0f74fbf77d45 ("MPI: Fix mpi_read_buffer") Signed-off-by: Michal Marek <mmarek@suse.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-02-24extable: add support for relative extables to search and sort routinesArd Biesheuvel
This adds support to the generic search_extable() and sort_extable() implementations for dealing with exception table entries whose fields contain relative offsets rather than absolute addresses. Acked-by: Helge Deller <deller@gmx.de> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: H. Peter Anvin <hpa@linux.intel.com> Acked-by: Tony Luck <tony.luck@intel.com> Acked-by: Will Deacon <will.deacon@arm.com> Acked-by: Richard Henderson <rth@twiddle.net> Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2016-02-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/phy/bcm7xxx.c drivers/net/phy/marvell.c drivers/net/vxlan.c All three conflicts were cases of simple overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2016-02-19test_bitmap: unit tests for lib/bitmap.cDavid Decotigny
This is mainly testing bitmap construction and conversion to/from u32[] for now. Tested: qemu i386, x86_64, ppc, ppc64 BE and LE, ARM. Signed-off-by: David Decotigny <decot@googlers.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-02-19lib/bitmap.c: conversion routines to/from u32 arrayDavid Decotigny
Aimed at transferring bitmaps to/from user-space in a 32/64-bit agnostic way. Tested: unit tests (next patch) on qemu i386, x86_64, ppc, ppc64 BE and LE, ARM. Signed-off-by: David Decotigny <decot@googlers.com> Reviewed-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-02-18Merge branch 'x86/urgent' into x86/asm, to pick up fixesIngo Molnar
