path: root/lib
2018-10-03scsi: klist: Make it safe to use klists in atomic contextBart Van Assche
[ Upstream commit 624fa7790f80575a4ec28fbdb2034097dc18d051 ] In the scsi_transport_srp implementation it cannot be avoided to iterate over a klist from atomic context when using the legacy block layer instead of blk-mq. Hence this patch that makes it safe to use klists in atomic context. This patch avoids that lockdep reports the following: WARNING: SOFTIRQ-safe -> SOFTIRQ-unsafe lock order detected Possible interrupt unsafe locking scenario: CPU0 CPU1 ---- ---- lock(&(&k->k_lock)->rlock); local_irq_disable(); lock(&(&q->__queue_lock)->rlock); lock(&(&k->k_lock)->rlock); <Interrupt> lock(&(&q->__queue_lock)->rlock); stack backtrace: Workqueue: kblockd blk_timeout_work Call Trace: dump_stack+0xa4/0xf5 check_usage+0x6e6/0x700 __lock_acquire+0x185d/0x1b50 lock_acquire+0xd2/0x260 _raw_spin_lock+0x32/0x50 klist_next+0x47/0x190 device_for_each_child+0x8e/0x100 srp_timed_out+0xaf/0x1d0 [scsi_transport_srp] scsi_times_out+0xd4/0x410 [scsi_mod] blk_rq_timed_out+0x36/0x70 blk_timeout_work+0x1b5/0x220 process_one_work+0x4fe/0xad0 worker_thread+0x63/0x5a0 kthread+0x1c1/0x1e0 ret_from_fork+0x24/0x30 See also commit c9ddf73476ff ("scsi: scsi_transport_srp: Fix shost to rport translation"). Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com> Cc: Martin K. Petersen <martin.petersen@oracle.com> Cc: James Bottomley <jejb@linux.vnet.ibm.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19rhashtable: add schedule pointsEric Dumazet
Rehashing and destroying large hash table takes a lot of time, and happens in process context. It is safe to add cond_resched() in rhashtable_rehash_table() and rhashtable_free_and_destroy() Signed-off-by: Eric Dumazet <edumazet@google.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> (cherry picked from commit ae6da1f503abb5a5081f9f6c4a6881de97830f3e) Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-15debugobjects: Make stack check warning more informativeJoel Fernandes (Google)
commit fc91a3c4c27acdca0bc13af6fbb68c35cfd519f2 upstream. While debugging an issue debugobject tracking warned about an annotation issue of an object on stack. It turned out that the issue was due to the object in concern being on a different stack which was due to another issue. Thomas suggested to print the pointers and the location of the stack for the currently running task. This helped to figure out that the object was on the wrong stack. As this is general useful information for debugging similar issues, make the error message more informative by printing the pointers. [ tglx: Massaged changelog ] Signed-off-by: Joel Fernandes (Google) <joel@joelfernandes.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Waiman Long <longman@redhat.com> Acked-by: Yang Shi <yang.shi@linux.alibaba.com> Cc: kernel-team@android.com Cc: Arnd Bergmann <arnd@arndb.de> Cc: astrachan@google.com Link: https://lkml.kernel.org/r/20180723212531.202328-1-joel@joelfernandes.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05printk/nmi: Prevent deadlock when accessing the main log buffer in NMIPetr Mladek
commit 03fc7f9c99c1e7ae2925d459e8487f1a6f199f79 upstream. The commit 719f6a7040f1bdaf96 ("printk: Use the main logbuf in NMI when logbuf_lock is available") brought back the possible deadlocks in printk() and NMI. The check of logbuf_lock is done only in printk_nmi_enter() to prevent mixed output. But another CPU might take the lock later, enter NMI, and: + Both NMIs might be serialized by yet another lock, for example, the one in nmi_cpu_backtrace(). + The other CPU might get stopped in NMI, see smp_send_stop() in panic(). The only safe solution is to use trylock when storing the message into the main log-buffer. It might cause reordering when some lines go to the main lock buffer directly and others are delayed via the per-CPU buffer. It means that it is not useful in general. This patch replaces the problematic NMI deferred context with NMI direct context. It can be used to mark a code that might produce many messages in NMI and the risk of losing them is more critical than problems with eventual reordering. The context is then used when dumping trace buffers on oops. It was the primary motivation for the original fix. Also the reordering is even smaller issue there because some traces have their own time stamps. Finally, nmi_cpu_backtrace() need not longer be serialized because it will always us the per-CPU buffers again. Fixes: 719f6a7040f1bdaf96 ("printk: Use the main logbuf in NMI when logbuf_lock is available") Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/20180627142028.11259-1-pmladek@suse.com To: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Cc: linux-kernel@vger.kernel.org Cc: stable@vger.kernel.org Acked-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-17ioremap: Update pgtable free interfaces with addrChintan Pandya
commit 785a19f9d1dd8a4ab2d0633be4656653bd3de1fc upstream. The following kernel panic was observed on ARM64 platform due to a stale TLB entry. 1. ioremap with 4K size, a valid pte page table is set. 2. iounmap it, its pte entry is set to 0. 3. ioremap the same address with 2M size, update its pmd entry with a new value. 4. CPU may hit an exception because the old pmd entry is still in TLB, which leads to a kernel panic. Commit b6bdb7517c3d ("mm/vmalloc: add interfaces to free unmapped page table") has addressed this panic by falling to pte mappings in the above case on ARM64. To support pmd mappings in all cases, TLB purge needs to be performed in this case on ARM64. Add a new arg, 'addr', to pud_free_pmd_page() and pmd_free_pte_page() so that TLB purge can be added later in seprate patches. [toshi.kani@hpe.com: merge changes, rewrite patch description] Fixes: 28ee90fe6048 ("x86/mm: implement free pmd/pte page interfaces") Signed-off-by: Chintan Pandya <cpandya@codeaurora.org> Signed-off-by: Toshi Kani <toshi.kani@hpe.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: mhocko@suse.com Cc: akpm@linux-foundation.org Cc: hpa@zytor.com Cc: linux-mm@kvack.org Cc: linux-arm-kernel@lists.infradead.org Cc: Will Deacon <will.deacon@arm.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: stable@vger.kernel.org Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Michal Hocko <mhocko@suse.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: <stable@vger.kernel.org> Link: https://lkml.kernel.org/r/20180627141348.21777-3-toshi.kani@hpe.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-25lib/rhashtable: consider param->min_size when setting initial table sizeDavidlohr Bueso
[ Upstream commit 107d01f5ba10f4162c38109496607eb197059064 ] rhashtable_init() currently does not take into account the user-passed min_size parameter unless param->nelem_hint is set as well. As such, the default size (number of buckets) will always be HASH_DEFAULT_SIZE even if the smallest allowed size is larger than that. Remediate this by unconditionally calling into rounded_hashtable_size() and handling things accordingly. Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03lib/vsprintf: Remove atomic-unsafe support for %pCrGeert Uytterhoeven
commit 666902e42fd8344b923c02dc5b0f37948ff4f225 upstream. "%pCr" formats the current rate of a clock, and calls clk_get_rate(). The latter obtains a mutex, hence it must not be called from atomic context. Remove support for this rarely-used format, as vsprintf() (and e.g. printk()) must be callable from any context. Any remaining out-of-tree users will start seeing the clock's name printed instead of its rate. Reported-by: Jia-Ju Bai <baijiaju1990@gmail.com> Fixes: 900cca2944254edd ("lib/vsprintf: add %pC{,n,r} format specifiers for clocks") Link: http://lkml.kernel.org/r/1527845302-12159-5-git-send-email-geert+renesas@glider.be To: Jia-Ju Bai <baijiaju1990@gmail.com> To: Jonathan Corbet <corbet@lwn.net> To: Michael Turquette <mturquette@baylibre.com> To: Stephen Boyd <sboyd@kernel.org> To: Zhang Rui <rui.zhang@intel.com> To: Eduardo Valentin <edubezval@gmail.com> To: Eric Anholt <eric@anholt.net> To: Stefan Wahren <stefan.wahren@i2se.com> To: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Cc: Petr Mladek <pmladek@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: linux-doc@vger.kernel.org Cc: linux-clk@vger.kernel.org Cc: linux-pm@vger.kernel.org Cc: linux-serial@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-renesas-soc@vger.kernel.org Cc: linux-kernel@vger.kernel.org Cc: Geert Uytterhoeven <geert+renesas@glider.be> Cc: stable@vger.kernel.org # 4.1+ Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Petr Mladek <pmladek@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30lib/test_kmod.c: fix limit check on number of test devices createdLuis R. Rodriguez
[ Upstream commit ac68b1b3b9c73e652dc7ce0585672e23c5a2dca4 ] As reported by Dan the parentheses is in the wrong place, and since unlikely() call returns either 0 or 1 it's never less than zero. The second issue is that signed integer overflows like "INT_MAX + 1" are undefined behavior. Since num_test_devs represents the number of devices, we want to stop prior to hitting the max, and not rely on the wrap arround at all. So just cap at num_test_devs + 1, prior to assigning a new device. Link: http://lkml.kernel.org/r/20180224030046.24238-1-mcgrof@kernel.org Fixes: d9c6a72d6fa2 ("kmod: add test driver to stress test the module loader") Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30idr: fix invalid ptr dereference on item deleteMatthew Wilcox
commit 7a4deea1aa8bddfed4ef1b35fc2b6732563d8ad5 upstream. If the radix tree underlying the IDR happens to be full and we attempt to remove an id which is larger than any id in the IDR, we will call __radix_tree_delete() with an uninitialised 'slot' pointer, at which point anything could happen. This was easiest to hit with a single entry at id 0 and attempting to remove a non-0 id, but it could have happened with 64 entries and attempting to remove an id >= 64. Roman said: The syzcaller test boils down to opening /dev/kvm, creating an eventfd, and calling a couple of KVM ioctls. None of this requires superuser. And the result is dereferencing an uninitialized pointer which is likely a crash. The specific path caught by syzbot is via KVM_HYPERV_EVENTD ioctl which is new in 4.17. But I guess there are other user-triggerable paths, so cc:stable is probably justified. Matthew added: We have around 250 calls to idr_remove() in the kernel today. Many of them pass an ID which is embedded in the object they're removing, so they're safe. Picking a few likely candidates: drivers/firewire/core-cdev.c looks unsafe; the ID comes from an ioctl. drivers/gpu/drm/amd/amdgpu/amdgpu_ctx.c is similar drivers/atm/nicstar.c could be taken down by a handcrafted packet Link: http://lkml.kernel.org/r/20180518175025.GD6361@bombadil.infradead.org Fixes: 0a835c4f090a ("Reimplement IDR and IDA using the radix tree") Reported-by: <syzbot+35666cba7f0a337e2e79@syzkaller.appspotmail.com> Debugged-by: Roman Kagan <rkagan@virtuozzo.com> Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22radix tree: fix multi-order iteration raceRoss Zwisler
commit 9f418224e8114156d995b98fa4e0f4fd21f685fe upstream. Fix a race in the multi-order iteration code which causes the kernel to hit a GP fault. This was first seen with a production v4.15 based kernel (4.15.6-300.fc27.x86_64) utilizing a DAX workload which used order 9 PMD DAX entries. The race has to do with how we tear down multi-order sibling entries when we are removing an item from the tree. Remember for example that an order 2 entry looks like this: struct radix_tree_node.slots[] = [entry][sibling][sibling][sibling] where 'entry' is in some slot in the struct radix_tree_node, and the three slots following 'entry' contain sibling pointers which point back to 'entry.' When we delete 'entry' from the tree, we call : radix_tree_delete() radix_tree_delete_item() __radix_tree_delete() replace_slot() replace_slot() first removes the siblings in order from the first to the last, then at then replaces 'entry' with NULL. This means that for a brief period of time we end up with one or more of the siblings removed, so: struct radix_tree_node.slots[] = [entry][NULL][sibling][sibling] This causes an issue if you have a reader iterating over the slots in the tree via radix_tree_for_each_slot() while only under rcu_read_lock()/rcu_read_unlock() protection. This is a common case in mm/filemap.c. The issue is that when __radix_tree_next_slot() => skip_siblings() tries to skip over the sibling entries in the slots, it currently does so with an exact match on the slot directly preceding our current slot. Normally this works: V preceding slot struct radix_tree_node.slots[] = [entry][sibling][sibling][sibling] ^ current slot This lets you find the first sibling, and you skip them all in order. But in the case where one of the siblings is NULL, that slot is skipped and then our sibling detection is interrupted: V preceding slot struct radix_tree_node.slots[] = [entry][NULL][sibling][sibling] ^ current slot This means that the sibling pointers aren't recognized since they point all the way back to 'entry', so we think that they are normal internal radix tree pointers. This causes us to think we need to walk down to a struct radix_tree_node starting at the address of 'entry'. In a real running kernel this will crash the thread with a GP fault when you try and dereference the slots in your broken node starting at 'entry'. We fix this race by fixing the way that skip_siblings() detects sibling nodes. Instead of testing against the preceding slot we instead look for siblings via is_sibling_entry() which compares against the position of the struct radix_tree_node.slots[] array. This ensures that sibling entries are properly identified, even if they are no longer contiguous with the 'entry' they point to. Link: http://lkml.kernel.org/r/20180503192430.7582-6-ross.zwisler@linux.intel.com Fixes: 148deab223b2 ("radix-tree: improve multiorder iterators") Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com> Reported-by: CR, Sapthagirish <sapthagirish.cr@intel.com> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Matthew Wilcox <willy@infradead.org> Cc: Christoph Hellwig <hch@lst.de> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Dave Chinner <david@fromorbit.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22lib/test_bitmap.c: fix bitmap optimisation tests to report errors correctlyMatthew Wilcox
commit 1e3054b98c5415d5cb5f8824fc33b548ae5644c3 upstream. I had neglected to increment the error counter when the tests failed, which made the tests noisy when they fail, but not actually return an error code. Link: http://lkml.kernel.org/r/20180509114328.9887-1-mpe@ellerman.id.au Fixes: 3cc78125a081 ("lib/test_bitmap.c: add optimisation tests") Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Reported-by: Michael Ellerman <mpe@ellerman.id.au> Tested-by: Michael Ellerman <mpe@ellerman.id.au> Reviewed-by: Kees Cook <keescook@chromium.org> Cc: Yury Norov <ynorov@caviumnetworks.com> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: <stable@vger.kernel.org> [4.13+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-09errseq: Always report a writeback error onceMatthew Wilcox
commit b4678df184b314a2bd47d2329feca2c2534aa12b upstream. The errseq_t infrastructure assumes that errors which occurred before the file descriptor was opened are of no interest to the application. This turns out to be a regression for some applications, notably Postgres. Before errseq_t, a writeback error would be reported exactly once (as long as the inode remained in memory), so Postgres could open a file, call fsync() and find out whether there had been a writeback error on that file from another process. This patch changes the errseq infrastructure to report errors to all file descriptors which are opened after the error occurred, but before it was reported to any file descriptor. This restores the user-visible behaviour. Cc: stable@vger.kernel.org Fixes: 5660e13d2fd6 ("fs: new infrastructure for writeback error handling and reporting") Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com> Reviewed-by: Jeff Layton <jlayton@kernel.org> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-01kobject: don't use WARN for registration failuresDmitry Vyukov
commit 3e14c6abbfb5c94506edda9d8e2c145d79375798 upstream. This WARNING proved to be noisy. The function still returns an error and callers should handle it. That's how most of kernel code works. Downgrade the WARNING to pr_err() and leave WARNINGs for kernel bugs. Signed-off-by: Dmitry Vyukov <dvyukov@google.com> Reported-by: syzbot+209c0f67f99fec8eb14b@syzkaller.appspotmail.com Reported-by: syzbot+7fb6d9525a4528104e05@syzkaller.appspotmail.com Reported-by: syzbot+2e63711063e2d8f9ea27@syzkaller.appspotmail.com Reported-by: syzbot+de73361ee4971b6e6f75@syzkaller.appspotmail.com Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-26bpf: fix selftests/bpf test_kmod.sh failure when CONFIG_BPF_JIT_ALWAYS_ON=yYonghong Song
[ Upstream commit 09584b406742413ac4c8d7e030374d4daa045b69 ] With CONFIG_BPF_JIT_ALWAYS_ON is defined in the config file, tools/testing/selftests/bpf/test_kmod.sh failed like below: [root@localhost bpf]# ./test_kmod.sh sysctl: setting key "net.core.bpf_jit_enable": Invalid argument [ JIT enabled:0 hardened:0 ] [ 132.175681] test_bpf: #297 BPF_MAXINSNS: Jump, gap, jump, ... FAIL to prog_create err=-524 len=4096 [ 132.458834] test_bpf: Summary: 348 PASSED, 1 FAILED, [340/340 JIT'ed] [ JIT enabled:1 hardened:0 ] [ 133.456025] test_bpf: #297 BPF_MAXINSNS: Jump, gap, jump, ... FAIL to prog_create err=-524 len=4096 [ 133.730935] test_bpf: Summary: 348 PASSED, 1 FAILED, [340/340 JIT'ed] [ JIT enabled:1 hardened:1 ] [ 134.769730] test_bpf: #297 BPF_MAXINSNS: Jump, gap, jump, ... FAIL to prog_create err=-524 len=4096 [ 135.050864] test_bpf: Summary: 348 PASSED, 1 FAILED, [340/340 JIT'ed] [ JIT enabled:1 hardened:2 ] [ 136.442882] test_bpf: #297 BPF_MAXINSNS: Jump, gap, jump, ... FAIL to prog_create err=-524 len=4096 [ 136.821810] test_bpf: Summary: 348 PASSED, 1 FAILED, [340/340 JIT'ed] [root@localhost bpf]# The test_kmod.sh load/remove test_bpf.ko multiple times with different settings for sysctl net.core.bpf_jit_{enable,harden}. The failed test #297 of test_bpf.ko is designed such that JIT always fails. Commit 290af86629b2 (bpf: introduce BPF_JIT_ALWAYS_ON config) introduced the following tightening logic: ... if (!bpf_prog_is_dev_bound(fp->aux)) { fp = bpf_int_jit_compile(fp); #ifdef CONFIG_BPF_JIT_ALWAYS_ON if (!fp->jited) { *err = -ENOTSUPP; return fp; } #endif ... With this logic, Test #297 always gets return value -ENOTSUPP when CONFIG_BPF_JIT_ALWAYS_ON is defined, causing the test failure. This patch fixed the failure by marking Test #297 as expected failure when CONFIG_BPF_JIT_ALWAYS_ON is defined. Fixes: 290af86629b2 (bpf: introduce BPF_JIT_ALWAYS_ON config) Signed-off-by: Yonghong Song <yhs@fb.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-19lib: fix stall in __bitmap_parselist()Yury Norov
commit 8351760ff5b2042039554b4948ddabaac644a976 upstream. syzbot is catching stalls at __bitmap_parselist() (https://syzkaller.appspot.com/bug?id=ad7e0351fbc90535558514a71cd3edc11681997a). The trigger is unsigned long v = 0; bitmap_parselist("7:,", &v, BITS_PER_LONG); which results in hitting infinite loop at while (a <= b) { off = min(b - a + 1, used_size); bitmap_set(maskp, a, off); a += group_size; } due to used_size == group_size == 0. Link: http://lkml.kernel.org/r/20180404162647.15763-1-ynorov@caviumnetworks.com Fixes: 0a5ce0831d04382a ("lib/bitmap.c: make bitmap_parselist() thread-safe and much faster") Signed-off-by: Yury Norov <ynorov@caviumnetworks.com> Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Reported-by: syzbot <syzbot+6887cbb011c8054e8a3d@syzkaller.appspotmail.com> Cc: Noam Camus <noamca@mellanox.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Matthew Wilcox <mawilcox@microsoft.com> Cc: Mauro Carvalho Chehab <mchehab@kernel.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-31rhashtable: Fix rhlist duplicates insertionPaul Blakey
[ Upstream commit d3dcf8eb615537526bd42ff27a081d46d337816e ] When inserting duplicate objects (those with the same key), current rhlist implementation messes up the chain pointers by updating the bucket pointer instead of prev next pointer to the newly inserted node. This causes missing elements on removal and travesal. Fix that by properly updating pprev pointer to point to the correct rhash_head next pointer. Issue: 1241076 Change-Id: I86b2c140bcb4aeb10b70a72a267ff590bb2b17e7 Fixes: ca26893f05e8 ('rhashtable: Add rhlist interface') Signed-off-by: Paul Blakey <paulb@mellanox.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-28mm/vmalloc: add interfaces to free unmapped page tableToshi Kani
commit b6bdb7517c3d3f41f20e5c2948d6bc3f8897394e upstream. On architectures with CONFIG_HAVE_ARCH_HUGE_VMAP set, ioremap() may create pud/pmd mappings. A kernel panic was observed on arm64 systems with Cortex-A75 in the following steps as described by Hanjun Guo. 1. ioremap a 4K size, valid page table will build, 2. iounmap it, pte0 will set to 0; 3. ioremap the same address with 2M size, pgd/pmd is unchanged, then set the a new value for pmd; 4. pte0 is leaked; 5. CPU may meet exception because the old pmd is still in TLB, which will lead to kernel panic. This panic is not reproducible on x86. INVLPG, called from iounmap, purges all levels of entries associated with purged address on x86. x86 still has memory leak. The patch changes the ioremap path to free unmapped page table(s) since doing so in the unmap path has the following issues: - The iounmap() path is shared with vunmap(). Since vmap() only supports pte mappings, making vunmap() to free a pte page is an overhead for regular vmap users as they do not need a pte page freed up. - Checking if all entries in a pte page are cleared in the unmap path is racy, and serializing this check is expensive. - The unmap path calls free_vmap_area_noflush() to do lazy TLB purges. Clearing a pud/pmd entry before the lazy TLB purges needs extra TLB purge. Add two interfaces, pud_free_pmd_page() and pmd_free_pte_page(), which clear a given pud/pmd entry and free up a page for the lower level entries. This patch implements their stub functions on x86 and arm64, which work as workaround. [akpm@linux-foundation.org: fix typo in pmd_free_pte_page() stub] Link: http://lkml.kernel.org/r/20180314180155.19492-2-toshi.kani@hpe.com Fixes: e61ce6ade404e ("mm: change ioremap to set up huge I/O mappings") Reported-by: Lei Li <lious.lilei@hisilicon.com> Signed-off-by: Toshi Kani <toshi.kani@hpe.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Wang Xuefeng <wxf.wang@hisilicon.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Hanjun Guo <guohanjun@huawei.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Borislav Petkov <bp@suse.de> Cc: Matthew Wilcox <willy@infradead.org> Cc: Chintan Pandya <cpandya@codeaurora.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-19Fix misannotated out-of-line _copy_to_user()Christophe Leroy
[ Upstream commit a0e94598e6b6c0d1df6a5fa14eb7c767ca817a20 ] Destination is a kernel pointer and source - a userland one in _copy_from_user(); _copy_to_user() is the other way round. Fixes: d597580d37377 ("generic ...copy_..._user primitives") Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-15lib/bug.c: exclude non-BUG/WARN exceptions from report_bug()Kees Cook
commit 1b4cfe3c0a30dde968fb43c577a8d7e262a145ee upstream. Commit b8347c219649 ("x86/debug: Handle warnings before the notifier chain, to fix KGDB crash") changed the ordering of fixups, and did not take into account the case of x86 processing non-WARN() and non-BUG() exceptions. This would lead to output of a false BUG line with no other information. In the case of a refcount exception, it would be immediately followed by the refcount WARN(), producing very strange double-"cut here": lkdtm: attempting bad refcount_inc() overflow ------------[ cut here ]------------ Kernel BUG at 0000000065f29de5 [verbose debug info unavailable] ------------[ cut here ]------------ refcount_t overflow at lkdtm_REFCOUNT_INC_OVERFLOW+0x6b/0x90 in cat[3065], uid/euid: 0/0 WARNING: CPU: 0 PID: 3065 at kernel/panic.c:657 refcount_error_report+0x9a/0xa4 ... In the prior ordering, exceptions were searched first: do_trap_no_signal(struct task_struct *tsk, int trapnr, char *str, ... if (fixup_exception(regs, trapnr)) return 0; - if (fixup_bug(regs, trapnr)) - return 0; - As a result, fixup_bugs()'s is_valid_bugaddr() didn't take into account needing to search the exception list first, since that had already happened. So, instead of searching the exception list twice (once in is_valid_bugaddr() and then again in fixup_exception()), just add a simple sanity check to report_bug() that will immediately bail out if a BUG() (or WARN()) entry is not found. Link: http://lkml.kernel.org/r/20180301225934.GA34350@beast Fixes: b8347c219649 ("x86/debug: Handle warnings before the notifier chain, to fix KGDB crash") Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Richard Weinberger <richard.weinberger@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-03lib/mpi: Fix umul_ppmm() for MIPS64r6James Hogan
[ Upstream commit bbc25bee37d2b32cf3a1fab9195b6da3a185614a ] Current MIPS64r6 toolchains aren't able to generate efficient DMULU/DMUHU based code for the C implementation of umul_ppmm(), which performs an unsigned 64 x 64 bit multiply and returns the upper and lower 64-bit halves of the 128-bit result. Instead it widens the 64-bit inputs to 128-bits and emits a __multi3 intrinsic call to perform a 128 x 128 multiply. This is both inefficient, and it results in a link error since we don't include __multi3 in MIPS linux. For example commit 90a53e4432b1 ("cfg80211: implement regdb signature checking") merged in v4.15-rc1 recently broke the 64r6_defconfig and 64r6el_defconfig builds by indirectly selecting MPILIB. The same build errors can be reproduced on older kernels by enabling e.g. CRYPTO_RSA: lib/mpi/generic_mpih-mul1.o: In function `mpihelp_mul_1': lib/mpi/generic_mpih-mul1.c:50: undefined reference to `__multi3' lib/mpi/generic_mpih-mul2.o: In function `mpihelp_addmul_1': lib/mpi/generic_mpih-mul2.c:49: undefined reference to `__multi3' lib/mpi/generic_mpih-mul3.o: In function `mpihelp_submul_1': lib/mpi/generic_mpih-mul3.c:49: undefined reference to `__multi3' lib/mpi/mpih-div.o In function `mpihelp_divrem': lib/mpi/mpih-div.c:205: undefined reference to `__multi3' lib/mpi/mpih-div.c:142: undefined reference to `__multi3' Therefore add an efficient MIPS64r6 implementation of umul_ppmm() using inline assembly and the DMULU/DMUHU instructions, to prevent __multi3 calls being emitted. Fixes: 7fd08ca58ae6 ("MIPS: Add build support for the MIPS R6 ISA") Signed-off-by: James Hogan <jhogan@kernel.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: "David S. Miller" <davem@davemloft.net> Cc: linux-mips@linux-mips.org Cc: linux-crypto@vger.kernel.org Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25509: fix printing uninitialized stack memory when OID is emptyEric Biggers
[ Upstream commit 8dfd2f22d3bf3ab7714f7495ad5d897b8845e8c1 ] Callers of sprint_oid() do not check its return value before printing the result. In the case where the OID is zero-length, -EBADMSG was being returned without anything being written to the buffer, resulting in uninitialized stack memory being printed. Fix this by writing "(bad)" to the buffer in the cases where -EBADMSG is returned. Fixes: 4f73175d0375 ("X.509: Add utility functions to render OIDs as strings") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-22kmemcheck: rip it outLevin, Alexander (Sasha Levin)
commit 4675ff05de2d76d167336b368bd07f3fef6ed5a6 upstream. Fix up makefiles, remove references, and git rm kmemcheck. Link: http://lkml.kernel.org/r/20171007030159.22241-4-alexander.levin@verizon.com Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Vegard Nossum <vegardno@ifi.uio.no> Cc: Pekka Enberg <penberg@kernel.org> Cc: Michal Hocko <mhocko@kernel.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Alexander Potapenko <glider@google.com> Cc: Tim Hansen <devtimhansen@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-22swiotlb: suppress warning when __GFP_NOWARN is setChristian König
commit d0bc0c2a31c95002d37c3cc511ffdcab851b3256 upstream. TTM tries to allocate coherent memory in chunks of 2MB first to improve TLB efficiency and falls back to allocating 4K pages if that fails. Suppress the warning when the 2MB allocations fails since there is a valid fall back path. Signed-off-by: Christian König <christian.koenig@amd.com> Reported-by: Mike Galbraith <efault@gmx.de> Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Bug: https://bugs.freedesktop.org/show_bug.cgi?id=104082 Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-16lib/ubsan: add type mismatch handler for new GCC/ClangAndrey Ryabinin
commit 42440c1f9911b4b7b8ba3dc4e90c1197bc561211 upstream. UBSAN=y fails to build with new GCC/clang: arch/x86/kernel/head64.o: In function `sanitize_boot_params': arch/x86/include/asm/bootparam_utils.h:37: undefined reference to `__ubsan_handle_type_mismatch_v1' because Clang and GCC 8 slightly changed ABI for 'type mismatch' errors. Compiler now uses new __ubsan_handle_type_mismatch_v1() function with slightly modified 'struct type_mismatch_data'. Let's add new 'struct type_mismatch_data_common' which is independent from compiler's layout of 'struct type_mismatch_data'. And make __ubsan_handle_type_mismatch[_v1]() functions transform compiler-dependent type mismatch data to our internal representation. This way, we can support both old and new compilers with minimal amount of change. Link: http://lkml.kernel.org/r/20180119152853.16806-1-aryabinin@virtuozzo.com Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Reported-by: Sodagudi Prasad <psodagud@codeaurora.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-16lib/ubsan.c: s/missaligned/misaligned/Andrew Morton
commit b8fe1120b4ba342b4f156d24e952d6e686b20298 upstream. A vist from the spelling fairy. Cc: David Laight <David.Laight@ACULAB.COM> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-16kasan: rework Kconfig settingsArnd Bergmann
commit e7c52b84fb18f08ce49b6067ae6285aca79084a8 upstream. We get a lot of very large stack frames using gcc-7.0.1 with the default -fsanitize-address-use-after-scope --param asan-stack=1 options, which can easily cause an overflow of the kernel stack, e.g. drivers/gpu/drm/i915/gvt/handlers.c:2434:1: warning: the frame size of 46176 bytes is larger than 3072 bytes drivers/net/wireless/ralink/rt2x00/rt2800lib.c:5650:1: warning: the frame size of 23632 bytes is larger than 3072 bytes lib/atomic64_test.c:250:1: warning: the frame size of 11200 bytes is larger than 3072 bytes drivers/gpu/drm/i915/gvt/handlers.c:2621:1: warning: the frame size of 9208 bytes is larger than 3072 bytes drivers/media/dvb-frontends/stv090x.c:3431:1: warning: the frame size of 6816 bytes is larger than 3072 bytes fs/fscache/stats.c:287:1: warning: the frame size of 6536 bytes is larger than 3072 bytes To reduce this risk, -fsanitize-address-use-after-scope is now split out into a separate CONFIG_KASAN_EXTRA Kconfig option, leading to stack frames that are smaller than 2 kilobytes most of the time on x86_64. An earlier version of this patch also prevented combining KASAN_EXTRA with KASAN_INLINE, but that is no longer necessary with gcc-7.0.1. All patches to get the frame size below 2048 bytes with CONFIG_KASAN=y and CONFIG_KASAN_EXTRA=n have been merged by maintainers now, so we can bring back that default now. KASAN_EXTRA=y still causes lots of warnings but now defaults to !COMPILE_TEST to disable it in allmodconfig, and it remains disabled in all other defconfigs since it is a new option. I arbitrarily raise the warning limit for KASAN_EXTRA to 3072 to reduce the noise, but an allmodconfig kernel still has around 50 warnings on gcc-7. I experimented a bit more with smaller stack frames and have another follow-up series that reduces the warning limit for 64-bit architectures to 1280 bytes (without CONFIG_KASAN). With earlier versions of this patch series, I also had patches to address the warnings we get with KASAN and/or KASAN_EXTRA, using a "noinline_if_stackbloat" annotation. That annotation now got replaced with a gcc-8 bugfix (see https://gcc.gnu.org/bugzilla/show_bug.cgi?id=81715) and a workaround for older compilers, which means that KASAN_EXTRA is now just as bad as before and will lead to an instant stack overflow in a few extreme cases. This reverts parts of commit 3f181b4d8652 ("lib/Kconfig.debug: disable -Wframe-larger-than warnings with KASAN=y"). Two patches in linux-next should be merged first to avoid introducing warnings in an allmodconfig build: 3cd890dbe2a4 ("media: dvb-frontends: fix i2c access helpers for KASAN") 16c3ada89cff ("media: r820t: fix r820t_write_reg for KASAN") Do we really need to backport this? I think we do: without this patch, enabling KASAN will lead to unavoidable kernel stack overflow in certain device drivers when built with gcc-7 or higher on linux-4.10+ or any version that contains a backport of commit c5caf21ab0cf8. Most people are probably still on older compilers, but it will get worse over time as they upgrade their distros. The warnings we get on kernels older than this should all be for code that uses dangerously large stack frames, though most of them do not cause an actual stack overflow by themselves.The asan-stack option was added in linux-4.0, and commit 3f181b4d8652 ("lib/Kconfig.debug: disable -Wframe-larger-than warnings with KASAN=y") effectively turned off the warning for allmodconfig kernels, so I would like to see this fix backported to any kernels later than 4.0. I have done dozens of fixes for individual functions with stack frames larger than 2048 bytes with asan-stack, and I plan to make sure that all those fixes make it into the stable kernels as well (most are already there). Part of the complication here is that asan-stack (from 4.0) was originally assumed to always require much larger stacks, but that turned out to be a combination of multiple gcc bugs that we have now worked around and fixed, but sanitize-address-use-after-scope (from v4.10) has a much higher inherent stack usage and also suffers from at least three other problems that we have analyzed but not yet fixed upstream, each of them makes the stack usage more severe than it should be. Link: http://lkml.kernel.org/r/20171221134744.2295529-1-arnd@arndb.de Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Mauro Carvalho Chehab <mchehab@kernel.org> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Alexander Potapenko <glider@google.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-03test_firmware: fix missing unlock on error in config_num_requests_store()Wei Yongjun
commit a5e1923356505e46476c2fb518559b7a4d9d25b1 upstream. Add the missing unlock before return from function config_num_requests_store() in the error handling case. Fixes: c92316bf8e94 ("test_firmware: add batched firmware tests") Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-31bpf: introduce BPF_JIT_ALWAYS_ON configAlexei Starovoitov
[ upstream commit 290af86629b25ffd1ed6232c4e9107da031705cb ] The BPF interpreter has been used as part of the spectre 2 attack CVE-2017-5715. A quote from goolge project zero blog: "At this point, it would normally be necessary to locate gadgets in the host kernel code that can be used to actually leak data by reading from an attacker-controlled location, shifting and masking the result appropriately and then using the result of that as offset to an attacker-controlled address for a load. But piecing gadgets together and figuring out which ones work in a speculation context seems annoying. So instead, we decided to use the eBPF interpreter, which is built into the host kernel - while there is no legitimate way to invoke it from inside a VM, the presence of the code in the host kernel's text section is sufficient to make it usable for the attack, just like with ordinary ROP gadgets." To make attacker job harder introduce BPF_JIT_ALWAYS_ON config option that removes interpreter from the kernel in favor of JIT-only mode. So far eBPF JIT is supported by: x64, arm64, arm32, sparc64, s390, powerpc64, mips64 The start of JITed program is randomized and code page is marked as read-only. In addition "constant blinding" can be turned on with net.core.bpf_jit_harden v2->v3: - move __bpf_prog_ret0 under ifdef (Daniel) v1->v2: - fix init order, test_bpf and cBPF (Daniel's feedback) - fix offloaded bpf (Jakub's feedback) - add 'return 0' dummy in case something can invoke prog->bpf_func - retarget bpf tree. For bpf-next the patch would need one extra hunk. It will be sent when the trees are merged back to net-next Considered doing: int bpf_jit_enable __read_mostly = BPF_EBPF_JIT_DEFAULT; but it seems better to land the patch as-is and in bpf-next remove bpf_jit_enable global variable from all JITs, consolidate in one place and remove this jit_init() function. Signed-off-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25x86/unwind: Rename unwinder config options to 'CONFIG_UNWINDER_*'Josh Poimboeuf
commit 11af847446ed0d131cf24d16a7ef3d5ea7a49554 upstream. Rename the unwinder config options from: CONFIG_ORC_UNWINDER CONFIG_FRAME_POINTER_UNWINDER CONFIG_GUESS_UNWINDER to: CONFIG_UNWINDER_ORC CONFIG_UNWINDER_FRAME_POINTER CONFIG_UNWINDER_GUESS ... in order to give them a more logical config namespace. Suggested-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/73972fc7e2762e91912c6b9584582703d6f1b8cc.1507924831.git.jpoimboe@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14dynamic-debug-howto: fix optional/omitted ending line number to be LARGE ↵Randy Dunlap
instead of 0 [ Upstream commit 1f3c790bd5989fcfec9e53ad8fa09f5b740c958f ] line-range is supposed to treat "1-" as "1-endoffile", so handle the special case by setting last_lineno to UINT_MAX. Fixes this error: dynamic_debug:ddebug_parse_query: last-line:0 < 1st-line:1 dynamic_debug:ddebug_exec_query: query parse failed Link: http://lkml.kernel.org/r/10a6a101-e2be-209f-1f41-54637824788e@infradead.org Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Acked-by: Jason Baron <jbaron@akamai.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14lib/genalloc.c: make the avail variable an atomic_long_tStephen Bates
[ Upstream commit 36a3d1dd4e16bcd0d2ddfb4a2ec7092f0ae0d931 ] If the amount of resources allocated to a gen_pool exceeds 2^32 then the avail atomic overflows and this causes problems when clients try and borrow resources from the pool. This is only expected to be an issue on 64 bit systems. Add the <linux/atomic.h> header to pull in atomic_long* operations. So that 32 bit systems continue to use atomic32_t but 64 bit systems can use atomic64_t. Link: http://lkml.kernel.org/r/1509033843-25667-1-git-send-email-sbates@raithlin.com Signed-off-by: Stephen Bates <sbates@raithlin.com> Reviewed-by: Logan Gunthorpe <logang@deltatee.com> Reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Reviewed-by: Daniel Mentz <danielmentz@google.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Will Deacon <will.deacon@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14ASN.1: check for error from ASN1_OP_END__ACT actionsEric Biggers
commit 81a7be2cd69b412ab6aeacfe5ebf1bb6e5bce955 upstream. asn1_ber_decoder() was ignoring errors from actions associated with the opcodes ASN1_OP_END_SEQ_ACT, ASN1_OP_END_SET_ACT, ASN1_OP_END_SEQ_OF_ACT, and ASN1_OP_END_SET_OF_ACT. In practice, this meant the pkcs7_note_signed_info() action (since that was the only user of those opcodes). Fix it by checking for the error, just like the decoder does for actions associated with the other opcodes. This bug allowed users to leak slab memory by repeatedly trying to add a specially crafted "pkcs7_test" key (requires CONFIG_PKCS7_TEST_KEY). In theory, this bug could also be used to bypass module signature verification, by providing a PKCS#7 message that is misparsed such that a signature's ->authattrs do not contain its ->msgdigest. But it doesn't seem practical in normal cases, due to restrictions on the format of the ->authattrs. Fixes: 42d5ec27f873 ("X.509: Add an ASN.1 decoder") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14ASN.1: fix out-of-bounds read when parsing indefinite length itemEric Biggers
commit e0058f3a874ebb48b25be7ff79bc3b4e59929f90 upstream. In asn1_ber_decoder(), indefinitely-sized ASN.1 items were being passed to the action functions before their lengths had been computed, using the bogus length of 0x80 (ASN1_INDEFINITE_LENGTH). This resulted in reading data past the end of the input buffer, when given a specially crafted message. Fix it by rearranging the code so that the indefinite length is resolved before the action is called. This bug was originally found by fuzzing the X.509 parser in userspace using libFuzzer from the LLVM project. KASAN report (cleaned up slightly): BUG: KASAN: slab-out-of-bounds in memcpy ./include/linux/string.h:341 [inline] BUG: KASAN: slab-out-of-bounds in x509_fabricate_name.constprop.1+0x1a4/0x940 crypto/asymmetric_keys/x509_cert_parser.c:366 Read of size 128 at addr ffff880035dd9eaf by task keyctl/195 CPU: 1 PID: 195 Comm: keyctl Not tainted 4.14.0-09238-g1d3b78bbc6e9 #26 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.11.0-20171110_100015-anatol 04/01/2014 Call Trace: __dump_stack lib/dump_stack.c:17 [inline] dump_stack+0xd1/0x175 lib/dump_stack.c:53 print_address_description+0x78/0x260 mm/kasan/report.c:252 kasan_report_error mm/kasan/report.c:351 [inline] kasan_report+0x23f/0x350 mm/kasan/report.c:409 memcpy+0x1f/0x50 mm/kasan/kasan.c:302 memcpy ./include/linux/string.h:341 [inline] x509_fabricate_name.constprop.1+0x1a4/0x940 crypto/asymmetric_keys/x509_cert_parser.c:366 asn1_ber_decoder+0xb4a/0x1fd0 lib/asn1_decoder.c:447 x509_cert_parse+0x1c7/0x620 crypto/asymmetric_keys/x509_cert_parser.c:89 x509_key_preparse+0x61/0x750 crypto/asymmetric_keys/x509_public_key.c:174 asymmetric_key_preparse+0xa4/0x150 crypto/asymmetric_keys/asymmetric_type.c:388 key_create_or_update+0x4d4/0x10a0 security/keys/key.c:850 SYSC_add_key security/keys/keyctl.c:122 [inline] SyS_add_key+0xe8/0x290 security/keys/keyctl.c:62 entry_SYSCALL_64_fastpath+0x1f/0x96 Allocated by task 195: __do_kmalloc_node mm/slab.c:3675 [inline] __kmalloc_node+0x47/0x60 mm/slab.c:3682 kvmalloc ./include/linux/mm.h:540 [inline] SYSC_add_key security/keys/keyctl.c:104 [inline] SyS_add_key+0x19e/0x290 security/keys/keyctl.c:62 entry_SYSCALL_64_fastpath+0x1f/0x96 Fixes: 42d5ec27f873 ("X.509: Add an ASN.1 decoder") Reported-by: Alexander Potapenko <glider@google.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-30lib/mpi: call cond_resched() from mpi_powm() loopEric Biggers
commit 1d9ddde12e3c9bab7f3d3484eb9446315e3571ca upstream. On a non-preemptible kernel, if KEYCTL_DH_COMPUTE is called with the largest permitted inputs (16384 bits), the kernel spends 10+ seconds doing modular exponentiation in mpi_powm() without rescheduling. If all threads do it, it locks up the system. Moreover, it can cause rcu_sched-stall warnings. Notwithstanding the insanity of doing this calculation in kernel mode rather than in userspace, fix it by calling cond_resched() as each bit from the exponent is processed. It's still noninterruptible, but at least it's preemptible now. Do the cond_resched() once per bit rather than once per MPI limb because each limb might still easily take 100+ milliseconds on slow CPUs. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-09KEYS: fix NULL pointer dereference during ASN.1 parsing [ver #2]Eric Biggers
syzkaller reported a NULL pointer dereference in asn1_ber_decoder(). It can be reproduced by the following command, assuming CONFIG_PKCS7_TEST_KEY=y: keyctl add pkcs7_test desc '' @s The bug is that if the data buffer is empty, an integer underflow occurs in the following check: if (unlikely(dp >= datalen - 1)) goto data_overrun_error; This results in the NULL data pointer being dereferenced. Fix it by checking for 'datalen - dp < 2' instead. Also fix the similar check for 'dp >= datalen - n' later in the same function. That one possibly could result in a buffer overread. The NULL pointer dereference was reproducible using the "pkcs7_test" key type but not the "asymmetric" key type because the "asymmetric" key type checks for a 0-length payload before calling into the ASN.1 decoder but the "pkcs7_test" key type does not. The bug report was: BUG: unable to handle kernel NULL pointer dereference at (null) IP: asn1_ber_decoder+0x17f/0xe60 lib/asn1_decoder.c:233 PGD 7b708067 P4D 7b708067 PUD 7b6ee067 PMD 0 Oops: 0000 [#1] SMP Modules linked in: CPU: 0 PID: 522 Comm: syz-executor1 Not tainted 4.14.0-rc8 #7 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.3-20171021_125229-anatol 04/01/2014 task: ffff9b6b3798c040 task.stack: ffff9b6b37970000 RIP: 0010:asn1_ber_decoder+0x17f/0xe60 lib/asn1_decoder.c:233 RSP: 0018:ffff9b6b37973c78 EFLAGS: 00010216 RAX: 0000000000000000 RBX: 0000000000000000 RCX: 000000000000021c RDX: ffffffff814a04ed RSI: ffffb1524066e000 RDI: ffffffff910759e0 RBP: ffff9b6b37973d60 R08: 0000000000000001 R09: ffff9b6b3caa4180 R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000002 R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000 FS: 00007f10ed1f2700(0000) GS:ffff9b6b3ea00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000000 CR3: 000000007b6f3000 CR4: 00000000000006f0 Call Trace: pkcs7_parse_message+0xee/0x240 crypto/asymmetric_keys/pkcs7_parser.c:139 verify_pkcs7_signature+0x33/0x180 certs/system_keyring.c:216 pkcs7_preparse+0x41/0x70 crypto/asymmetric_keys/pkcs7_key_type.c:63 key_create_or_update+0x180/0x530 security/keys/key.c:855 SYSC_add_key security/keys/keyctl.c:122 [inline] SyS_add_key+0xbf/0x250 security/keys/keyctl.c:62 entry_SYSCALL_64_fastpath+0x1f/0xbe RIP: 0033:0x4585c9 RSP: 002b:00007f10ed1f1bd8 EFLAGS: 00000216 ORIG_RAX: 00000000000000f8 RAX: ffffffffffffffda RBX: 00007f10ed1f2700 RCX: 00000000004585c9 RDX: 0000000020000000 RSI: 0000000020008ffb RDI: 0000000020008000 RBP: 0000000000000000 R08: ffffffffffffffff R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000216 R12: 00007fff1b2260ae R13: 00007fff1b2260af R14: 00007f10ed1f2700 R15: 0000000000000000 Code: dd ca ff 48 8b 45 88 48 83 e8 01 4c 39 f0 0f 86 a8 07 00 00 e8 53 dd ca ff 49 8d 46 01 48 89 85 58 ff ff ff 48 8b 85 60 ff ff ff <42> 0f b6 0c 30 89 c8 88 8d 75 ff ff ff 83 e0 1f 89 8d 28 ff ff RIP: asn1_ber_decoder+0x17f/0xe60 lib/asn1_decoder.c:233 RSP: ffff9b6b37973c78 CR2: 0000000000000000 Fixes: 42d5ec27f873 ("X.509: Add an ASN.1 decoder") Reported-by: syzbot <syzkaller@googlegroups.com> Cc: <stable@vger.kernel.org> # v3.7+ Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2017-11-02Merge tag 'spdx_identifiers-4.14-rc8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull initial SPDX identifiers from Greg KH: "License cleanup: add SPDX license identifiers to some files Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'spdx_identifiers-4.14-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: License cleanup: add SPDX license identifier to uapi header files with a license License cleanup: add SPDX license identifier to uapi header files with no license License cleanup: add SPDX GPL-2.0 license identifier to files with no license
2017-11-02KEYS: fix out-of-bounds read during ASN.1 parsingEric Biggers
syzkaller with KASAN reported an out-of-bounds read in asn1_ber_decoder(). It can be reproduced by the following command, assuming CONFIG_X509_CERTIFICATE_PARSER=y and CONFIG_KASAN=y: keyctl add asymmetric desc $'\x30\x30' @s The bug is that the length of an ASN.1 data value isn't validated in the case where it is encoded using the short form, causing the decoder to read past the end of the input buffer. Fix it by validating the length. The bug report was: BUG: KASAN: slab-out-of-bounds in asn1_ber_decoder+0x10cb/0x1730 lib/asn1_decoder.c:233 Read of size 1 at addr ffff88003cccfa02 by task syz-executor0/6818 CPU: 1 PID: 6818 Comm: syz-executor0 Not tainted 4.14.0-rc7-00008-g5f479447d983 #2 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 Call Trace: __dump_stack lib/dump_stack.c:16 [inline] dump_stack+0xb3/0x10b lib/dump_stack.c:52 print_address_description+0x79/0x2a0 mm/kasan/report.c:252 kasan_report_error mm/kasan/report.c:351 [inline] kasan_report+0x236/0x340 mm/kasan/report.c:409 __asan_report_load1_noabort+0x14/0x20 mm/kasan/report.c:427 asn1_ber_decoder+0x10cb/0x1730 lib/asn1_decoder.c:233 x509_cert_parse+0x1db/0x650 crypto/asymmetric_keys/x509_cert_parser.c:89 x509_key_preparse+0x64/0x7a0 crypto/asymmetric_keys/x509_public_key.c:174 asymmetric_key_preparse+0xcb/0x1a0 crypto/asymmetric_keys/asymmetric_type.c:388 key_create_or_update+0x347/0xb20 security/keys/key.c:855 SYSC_add_key security/keys/keyctl.c:122 [inline] SyS_add_key+0x1cd/0x340 security/keys/keyctl.c:62 entry_SYSCALL_64_fastpath+0x1f/0xbe RIP: 0033:0x447c89 RSP: 002b:00007fca7a5d3bd8 EFLAGS: 00000246 ORIG_RAX: 00000000000000f8 RAX: ffffffffffffffda RBX: 00007fca7a5d46cc RCX: 0000000000447c89 RDX: 0000000020006f4a RSI: 0000000020006000 RDI: 0000000020001ff5 RBP: 0000000000000046 R08: fffffffffffffffd R09: 0000000000000000 R10: 0000000000000002 R11: 0000000000000246 R12: 0000000000000000 R13: 0000000000000000 R14: 00007fca7a5d49c0 R15: 00007fca7a5d4700 Fixes: 42d5ec27f873 ("X.509: Add an ASN.1 decoder") Cc: <stable@vger.kernel.org> # v3.7+ Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2017-10-30Mark 'ioremap_page_range()' as possibly sleepingLinus Torvalds
It turns out that some drivers seem to think it's ok to remap page ranges from within interrupts and even NMI's. That is definitely not the case, since the page table build-up is simply not interrupt-safe. This showed up in the zero-day robot that reported it for the ACPI APEI GHES ("Generic Hardware Error Source") driver. Normally it had been hidden by the fact that no page table operations had been needed because the vmalloc area had been set up by other things. Apparently due to a recent change to the GHEI driver: commit 77b246b32b2c ("acpi: apei: check for pending errors when probing GHES entries") 0day actually caught a case during bootup whenthe ioremap called down to page allocation. But that recent change only showed the symptom, it wasn't the root cause of the problem. Hopefully it is limited to just that one driver. If you need to access random physical memory, you either need to ioremap in process context, or you need to use the FIXMAP facility to set one particular fixmap entry to the required mapping - that can be done safely. Cc: Borislav Petkov <bp@suse.de> Cc: Len Brown <lenb@kernel.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Tyler Baicar <tbaicar@codeaurora.org> Cc: Will Deacon <will.deacon@arm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-10-28assoc_array: Fix a buggy node-splitting caseDavid Howells
This fixes CVE-2017-12193. Fix a case in the assoc_array implementation in which a new leaf is added that needs to go into a node that happens to be full, where the existing leaves in that node cluster together at that level to the exclusion of new leaf. What needs to happen is that the existing leaves get moved out to a new node, N1, at level + 1 and the existing node needs replacing with one, N0, that has pointers to the new leaf and to N1. The code that tries to do this gets this wrong in two ways: (1) The pointer that should've pointed from N0 to N1 is set to point recursively to N0 instead. (2) The backpointer from N0 needs to be set correctly in the case N0 is either the root node or reached through a shortcut. Fix this by removing this path and using the split_node path instead, which achieves the same end, but in a more general way (thanks to Eric Biggers for spotting the redundancy). The problem manifests itself as: BUG: unable to handle kernel NULL pointer dereference at 0000000000000010 IP: assoc_array_apply_edit+0x59/0xe5 Fixes: 3cb989501c26 ("Add a generic associative array implementation.") Reported-and-tested-by: WU Fan <u3536072@connect.hku.hk> Signed-off-by: David Howells <dhowells@redhat.com> Cc: stable@vger.kernel.org [v3.13-rc1+] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-10-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "A little more than usual this time around. Been travelling, so that is part of it. Anyways, here are the highlights: 1) Deal with memcontrol races wrt. listener dismantle, from Eric Dumazet. 2) Handle page allocation failures properly in nfp driver, from Jaku Kicinski. 3) Fix memory leaks in macsec, from Sabrina Dubroca. 4) Fix crashes in pppol2tp_session_ioctl(), from Guillaume Nault. 5) Several fixes in bnxt_en driver, including preventing potential NVRAM parameter corruption from Michael Chan. 6) Fix for KRACK attacks in wireless, from Johannes Berg. 7) rtnetlink event generation fixes from Xin Long. 8) Deadlock in mlxsw driver, from Ido Schimmel. 9) Disallow arithmetic operations on context pointers in bpf, from Jakub Kicinski. 10) Missing sock_owned_by_user() check in sctp_icmp_redirect(), from Xin Long. 11) Only TCP is supported for sockmap, make that explicit with a check, from John Fastabend. 12) Fix IP options state races in DCCP and TCP, from Eric Dumazet. 13) Fix panic in packet_getsockopt(), also from Eric Dumazet. 14) Add missing locked in hv_sock layer, from Dexuan Cui. 15) Various aquantia bug fixes, including several statistics handling cures. From Igor Russkikh et al. 16) Fix arithmetic overflow in devmap code, from John Fastabend. 17) Fix busted socket memory accounting when we get a fault in the tcp zero copy paths. From Willem de Bruijn. 18) Don't leave opt->tot_len uninitialized in ipv6, from Eric Dumazet" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (106 commits) stmmac: Don't access tx_q->dirty_tx before netif_tx_lock ipv6: flowlabel: do not leave opt->tot_len with garbage of_mdio: Fix broken PHY IRQ in case of probe deferral textsearch: fix typos in library helpers rxrpc: Don't release call mutex on error pointer net: stmmac: Prevent infinite loop in get_rx_timestamp_status() net: stmmac: Fix stmmac_get_rx_hwtstamp() net: stmmac: Add missing call to dev_kfree_skb() mlxsw: spectrum_router: Configure TIGCR on init mlxsw: reg: Add Tunneling IPinIP General Configuration Register net: ethtool: remove error check for legacy setting transceiver type soreuseport: fix initialization race net: bridge: fix returning of vlan range op errors sock: correct sk_wmem_queued accounting on efault in tcp zerocopy bpf: add test cases to bpf selftests to cover all access tests bpf: fix pattern matches for direct packet access bpf: fix off by one for range markings with L{T, E} patterns bpf: devmap fix arithmetic overflow in bitmap_size calculation net: aquantia: Bad udp rate on default interrupt coalescing net: aquantia: Enable coalescing management via ethtool interface ...
2017-10-22textsearch: fix typos in library helpersRandy Dunlap
Fix spellos (typos) in textsearch library helpers. Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-10-19Merge commit 'tags/keys-fixes-20171018' into fixes-v4.14-rc5James Morris
2017-10-14Merge branch 'locking-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking fixes from Ingo Molnar: "Two lockdep fixes for bugs introduced by the cross-release dependency tracking feature - plus a commit that disables it because performance regressed in an absymal fashion on some systems" * 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: locking/lockdep: Disable cross-release features for now locking/selftest: Avoid false BUG report locking/lockdep: Fix stacktrace mess
2017-10-14locking/lockdep: Disable cross-release features for nowIngo Molnar
Johan Hovold reported a big lockdep slowdown on his system, caused by lockdep: > I had noticed that the BeagleBone Black boot time appeared to have > increased significantly with 4.14 and yesterday I finally had time to > investigate it. > > Boot time (from "Linux version" to login prompt) had in fact doubled > since 4.13 where it took 17 seconds (with my current config) compared to > the 35 seconds I now see with 4.14-rc4. > > I quick bisect pointed to lockdep and specifically the following commit: > > 28a903f63ec0 ("locking/lockdep: Handle non(or multi)-acquisition of a crosslock") Because the final v4.14 release is close, disable the cross-release lockdep features for now. Bisected-by: Johan Hovold <johan@kernel.org> Debugged-by: Johan Hovold <johan@kernel.org> Reported-by: Johan Hovold <johan@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Byungchul Park <byungchul.park@lge.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Lindgren <tony@atomide.com> Cc: kernel-team@lge.com Cc: linux-arm-kernel@lists.infradead.org Cc: linux-mm@kvack.org Cc: linux-omap@vger.kernel.org Link: http://lkml.kernel.org/r/20171014072659.f2yr6mhm5ha3eou7@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-10-13lib/Kconfig.debug: kernel hacking menu: runtime testing: keep tests togetherRandy Dunlap
Expand the "Runtime testing" menu by including more entries inside it instead of after it. This is just Kconfig symbol movement. This causes the (arch-independent) Runtime tests to be presented (listed) all in one place instead of in multiple places. Link: http://lkml.kernel.org/r/c194e5c4-2042-bf94-a2d8-7aa13756e257@infradead.org Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Acked-by: Kees Cook <keescook@chromium.org> Cc: Dave Hansen <dave.hansen@intel.com> Cc: "Luis R. Rodriguez" <mcgrof@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-10-12lib/digsig: fix dereference of NULL user_key_payloadEric Biggers
digsig_verify() requests a user key, then accesses its payload. However, a revoked key has a NULL payload, and we failed to check for this. request_key() *does* skip revoked keys, but there is still a window where the key can be revoked before we acquire its semaphore. Fix it by checking for a NULL payload, treating it like a key which was already revoked at the time it was requested. Fixes: 051dbb918c7f ("crypto: digital signature verification support") Reviewed-by: James Morris <james.l.morris@oracle.com> Cc: <stable@vger.kernel.org> [v3.3+] Cc: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com>
2017-10-10locking/selftest: Avoid false BUG reportPeter Zijlstra
The work-around for the expected failure is providing another failure :/ Only when CONFIG_PROVE_LOCKING=y do we increment unexpected_testcase_failures, so only then do we need to decrement, otherwise we'll end up with a negative number and that will again trigger a BUG (printout, not crash). Reported-by: Fengguang Wu <fengguang.wu@intel.com> Tested-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: d82fed752942 ("locking/lockdep/selftests: Fix mixed read-write ABBA tests") Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-10-03lib/ratelimit.c: use deferred printk() versionSergey Senozhatsky
printk_ratelimit() invokes ___ratelimit() which may invoke a normal printk() (pr_warn() in this particular case) to warn about suppressed output. Given that printk_ratelimit() may be called from anywhere, that pr_warn() is dangerous - it may end up deadlocking the system. Fix ___ratelimit() by using deferred printk(). Sasha reported the following lockdep error: : Unregister pv shared memory for cpu 8 : select_fallback_rq: 3 callbacks suppressed : process 8583 (trinity-c78) no longer affine to cpu8 : : ====================================================== : WARNING: possible circular locking dependency detected : 4.14.0-rc2-next-20170927+ #252 Not tainted : ------------------------------------------------------ : migration/8/62 is trying to acquire lock: : (&port_lock_key){-.-.}, at: serial8250_console_write() : : but task is already holding lock: : (&rq->lock){-.-.}, at: sched_cpu_dying() : : which lock already depends on the new lock. : : : the existing dependency chain (in reverse order) is: : : -> #3 (&rq->lock){-.-.}: : __lock_acquire() : lock_acquire() : _raw_spin_lock() : task_fork_fair() : sched_fork() : copy_process.part.31() : _do_fork() : kernel_thread() : rest_init() : start_kernel() : x86_64_start_reservations() : x86_64_start_kernel() : verify_cpu() : : -> #2 (&p->pi_lock){-.-.}: : __lock_acquire() : lock_acquire() : _raw_spin_lock_irqsave() : try_to_wake_up() : default_wake_function() : woken_wake_function() : __wake_up_common() : __wake_up_common_lock() : __wake_up() : tty_wakeup() : tty_port_default_wakeup() : tty_port_tty_wakeup() : uart_write_wakeup() : serial8250_tx_chars() : serial8250_handle_irq.part.25() : serial8250_default_handle_irq() : serial8250_interrupt() : __handle_irq_event_percpu() : handle_irq_event_percpu() : handle_irq_event() : handle_level_irq() : handle_irq() : do_IRQ() : ret_from_intr() : native_safe_halt() : default_idle() : arch_cpu_idle() : default_idle_call() : do_idle() : cpu_startup_entry() : rest_init() : start_kernel() : x86_64_start_reservations() : x86_64_start_kernel() : verify_cpu() : : -> #1 (&tty->write_wait){-.-.}: : __lock_acquire() : lock_acquire() : _raw_spin_lock_irqsave() : __wake_up_common_lock() : __wake_up() : tty_wakeup() : tty_port_default_wakeup() : tty_port_tty_wakeup() : uart_write_wakeup() : serial8250_tx_chars() : serial8250_handle_irq.part.25() : serial8250_default_handle_irq() : serial8250_interrupt() : __handle_irq_event_percpu() : handle_irq_event_percpu() : handle_irq_event() : handle_level_irq() : handle_irq() : do_IRQ() : ret_from_intr() : native_safe_halt() : default_idle() : arch_cpu_idle() : default_idle_call() : do_idle() : cpu_startup_entry() : rest_init() : start_kernel() : x86_64_start_reservations() : x86_64_start_kernel() : verify_cpu() : : -> #0 (&port_lock_key){-.-.}: : check_prev_add() : __lock_acquire() : lock_acquire() : _raw_spin_lock_irqsave() : serial8250_console_write() : univ8250_console_write() : console_unlock() : vprintk_emit() : vprintk_default() : vprintk_func() : printk() : ___ratelimit() : __printk_ratelimit() : select_fallback_rq() : sched_cpu_dying() : cpuhp_invoke_callback() : take_cpu_down() : multi_cpu_stop() : cpu_stopper_thread() : smpboot_thread_fn() : kthread() : ret_from_fork() : : other info that might help us debug this: : : Chain exists of: : &port_lock_key --> &p->pi_lock --> &rq->lock : : Possible unsafe locking scenario: : : CPU0 CPU1 : ---- ---- : lock(&rq->lock); : lock(&p->pi_lock); : lock(&rq->lock); : lock(&port_lock_key); : : *** DEADLOCK *** : : 4 locks held by migration/8/62: : #0: (&p->pi_lock){-.-.}, at: sched_cpu_dying() : #1: (&rq->lock){-.-.}, at: sched_cpu_dying() : #2: (printk_ratelimit_state.lock){....}, at: ___ratelimit() : #3: (console_lock){+.+.}, at: vprintk_emit() : : stack backtrace: : CPU: 8 PID: 62 Comm: migration/8 Not tainted 4.14.0-rc2-next-20170927+ #252 : Call Trace: : dump_stack() : print_circular_bug() : check_prev_add() : ? add_lock_to_list.isra.26() : ? check_usage() : ? kvm_clock_read() : ? kvm_sched_clock_read() : ? sched_clock() : ? check_preemption_disabled() : __lock_acquire() : ? __lock_acquire() : ? add_lock_to_list.isra.26() : ? debug_check_no_locks_freed() : ? memcpy() : lock_acquire() : ? serial8250_console_write() : _raw_spin_lock_irqsave() : ? serial8250_console_write() : serial8250_console_write() : ? serial8250_start_tx() : ? lock_acquire() : ? memcpy() : univ8250_console_write() : console_unlock() : ? __down_trylock_console_sem() : vprintk_emit() : vprintk_default() : vprintk_func() : printk() : ? show_regs_print_info() : ? lock_acquire() : ___ratelimit() : __printk_ratelimit() : select_fallback_rq() : sched_cpu_dying() : ? sched_cpu_starting() : ? rcutree_dying_cpu() : ? sched_cpu_starting() : cpuhp_invoke_callback() : ? cpu_disable_common() : take_cpu_down() : ? trace_hardirqs_off_caller() : ? cpuhp_invoke_callback() : multi_cpu_stop() : ? __this_cpu_preempt_check() : ? cpu_stop_queue_work() : cpu_stopper_thread() : ? cpu_stop_create() : smpboot_thread_fn() : ? sort_range() : ? schedule() : ? __kthread_parkme() : kthread() : ? sort_range() : ? kthread_create_on_node() : ret_from_fork() : process 9121 (trinity-c78) no longer affine to cpu8 : smpboot: CPU 8 is now offline Link: http://lkml.kernel.org/r/20170928120405.18273-1-sergey.senozhatsky@gmail.com Fixes: 6b1d174b0c27b ("ratelimit: extend to print suppressed messages on release") Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Reported-by: Sasha Levin <levinsasha928@gmail.com> Reviewed-by: Petr Mladek <pmladek@suse.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Borislav Petkov <bp@suse.de> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-10-03lib/idr.c: fix comment for idr_replace()Eric Biggers
idr_replace() returns the old value on success, not 0. Link: http://lkml.kernel.org/r/20170918162642.37511-1-ebiggers3@gmail.com Signed-off-by: Eric Biggers <ebiggers@google.com> Cc: Matthew Wilcox <mawilcox@microsoft.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
