As a quick
git grep -E '%[ +0#-]*#[ +0#-]*(\*|[0-9]+)?(\.(\*|[0-9]+)?)?p'
shows, nobody uses the # flag with %p. Should one try to do so, one
will be met with
warning: `#' flag used with `%p' gnu_printf format [-Wformat]
(POSIX and C99 both say "... For other conversion specifiers, the
behavior is undefined.". Obviously, the kernel can choose to define
the behaviour however it wants, but as long as gcc issues that
warning, users are unlikely to show up.)
Since default_width is effectively always 2*sizeof(void*), we can
simplify the prologue of pointer() and save a few instructions.
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: Martin Kletzander <mkletzan@redhat.com>
Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Quoting from 2aa2f9e21e4e ("lib/vsprintf.c: improve sanity check in
vsnprintf()"):
On 64 bit, size may very well be huge even if bit 31 happens to be 0.
Somehow it doesn't feel right that one can pass a 5 GiB buffer but not a
3 GiB one. So cap at INT_MAX as was probably the intention all along.
This is also the made-up value passed by sprintf and vsprintf.
I should have seen this copy-pasted instance back then, but let's just
do it now.
If we meet any invalid or unsupported format specifier, 'handling' it by
just printing it as a literal string is not safe: Presumably the format
string and the arguments passed gcc's type checking, but that means
something like sprintf(buf, "%n %pd", &intvar, dentry) would end up
interpreting &intvar as a struct dentry*.
When the offending specifier was %n it used to be at the end of the format
string, but we can't rely on that always being the case. Also, gcc
doesn't complain about some more or less exotic qualifiers (or 'length
modifiers' in posix-speak) such as 'j' or 'q', but being unrecognized by
the kernel's printf implementation, they'd be interpreted as unknown
specifiers, and the rest of arguments would be interpreted wrongly.
So let's complain about anything we don't understand, not just %n, and
stop pretending that we'd be able to make sense of the rest of the
format/arguments. If the offending specifier is in a printk() call we
unfortunately only get a "BUG: recent printk recursion!", but at least
direct users of the sprintf family will be caught.
Move all pointer-formatting documentation to one place in the code and one
place in the documentation instead of keeping it in three places with
different level of completeness. Documentation/printk-formats.txt has
detailed information about each modifier, docstring above pointer() has
short descriptions of them (as that is the function dealing with %p) and
docstring above vsprintf() is removed as redundant. Both docstrings in
the code that were modified are updated with a reminder of updating the
documentation upon any further change.
[akpm@linux-foundation.org: fix comment]
Signed-off-by: Martin Kletzander <mkletzan@redhat.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Using kstrdup_const, thus reusing .rodata when possible, saves around 2 kB
of runtime memory on my laptop/.config combination.
Cc: Jason Baron <jbaron@akamai.com>
__GFP_WAIT was used to signal that the caller was in atomic context and
could not sleep. Now it is possible to distinguish between true atomic
context and callers that are not willing to sleep. The latter should
clear __GFP_DIRECT_RECLAIM so kswapd will still wake. As clearing
__GFP_WAIT behaves differently, there is a risk that people will clear the
wrong flags. This patch renames __GFP_WAIT to __GFP_RECLAIM to clearly
indicate what it does -- setting it allows all reclaim activity, clearing
them prevents it.
[akpm@linux-foundation.org: fix build]
Signed-off-by: Mel Gorman <mgorman@techsingularity.net>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Christoph Lameter <cl@linux.com>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Vitaly Wool <vitalywool@gmail.com>
sleep and avoiding waking kswapd
__GFP_WAIT has been used to identify atomic context in callers that hold
spinlocks or are in interrupts. They are expected to be high priority and
have access one of two watermarks lower than "min" which can be referred
to as the "atomic reserve". __GFP_HIGH users get access to the first
lower watermark and can be called the "high priority reserve".
Over time, callers had a requirement to not block when fallback options
were available. Some have abused __GFP_WAIT leading to a situation where
an optimisitic allocation with a fallback option can access atomic
reserves.
This patch uses __GFP_ATOMIC to identify callers that are truely atomic,
cannot sleep and have no alternative. High priority users continue to use
__GFP_HIGH. __GFP_DIRECT_RECLAIM identifies callers that can sleep and
are willing to enter direct reclaim. __GFP_KSWAPD_RECLAIM to identify
callers that want to wake kswapd for background reclaim. __GFP_WAIT is
redefined as a caller that is willing to enter direct reclaim and wake
This patch then converts a number of sites
o __GFP_ATOMIC is used by callers that are high priority and have memory
pools for those requests. GFP_ATOMIC uses this flag.
o Callers that have a limited mempool to guarantee forward progress clear
__GFP_DIRECT_RECLAIM but keep __GFP_KSWAPD_RECLAIM. bio allocations fall
into this category where kswapd will still be woken but atomic reserves
are not used as there is a one-entry mempool to guarantee progress.
o Callers that are checking if they are non-blocking should use the
helper gfpflags_allow_blocking() where possible. This is because
checking for __GFP_WAIT as was done historically now can trigger false
positives. Some exceptions like dm-crypt.c exist where the code intent
is clearer if __GFP_DIRECT_RECLAIM is used instead of the helper due to
flag manipulations.
o Callers that built their own GFP flags instead of starting with GFP_KERNEL
and friends now also need to specify __GFP_KSWAPD_RECLAIM.
The first key hazard to watch out for is callers that removed __GFP_WAIT
and was depending on access to atomic reserves for inconspicuous reasons.
In some cases it may be appropriate for them to use __GFP_HIGH.
The second key hazard is callers that assembled their own combination of
GFP flags instead of starting with something like GFP_KERNEL. They may
now wish to specify __GFP_KSWAPD_RECLAIM. It's almost certainly harmless
if it's missed in most cases as other activity will wake kswapd.
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic
Pull asm-generic cleanups from Arnd Bergmann:
"The asm-generic changes for 4.4 are mostly a series from Christoph
Hellwig to clean up various abuses of headers in there. The patch to
rename the io-64-nonatomic-*.h headers caused some conflicts with new
users, so I added a workaround that we can remove in the next merge
window.
The only other patch is a warning fix from Marek Vasut"
* tag 'asm-generic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic:
asm-generic: temporarily add back asm-generic/io-64-nonatomic*.h
asm-generic: cmpxchg: avoid warnings from macro-ized cmpxchg() implementations
gpio-mxc: stop including <asm-generic/bug>
n_tracesink: stop including <asm-generic/bug>
n_tracerouter: stop including <asm-generic/bug>
mlx5: stop including <asm-generic/kmap_types.h>
hifn_795x: stop including <asm-generic/kmap_types.h>
drbd: stop including <asm-generic/kmap_types.h>
move count_zeroes.h out of asm-generic
move io-64-nonatomic*.h out of asm-generic
Merge patch-bomb from Andrew Morton:
- inotify tweaks
- some ocfs2 updates (many more are awaiting review)
- various misc bits
- kernel/watchdog.c updates
- Some of mm. I have a huge number of MM patches this time and quite a
lot of it is quite difficult and much will be held over to next time.
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (162 commits)
selftests: vm: add tests for lock on fault
mm: mlock: add mlock flags to enable VM_LOCKONFAULT usage
mm: introduce VM_LOCKONFAULT
mm: mlock: add new mlock system call
mm: mlock: refactor mlock, munlock, and munlockall code
kasan: always taint kernel on report
mm, slub, kasan: enable user tracking by default with KASAN=y
kasan: use IS_ALIGNED in memory_is_poisoned_8()
kasan: Fix a type conversion error
lib: test_kasan: add some testcases
kasan: update reference to kasan prototype repo
kasan: move KASAN_SANITIZE in arch/x86/boot/Makefile
kasan: various fixes in documentation
kasan: update log messages
kasan: accurately determine the type of the bad access
kasan: update reported bug types for kernel memory accesses
kasan: update reported bug types for not user nor kernel memory accesses
mm/kasan: prevent deadlock in kasan reporting
mm/kasan: don't use kasan shadow pointer in generic functions
mm/kasan: MODULE_VADDR is not available on all archs
It's recommended to have slub's user tracking enabled with CONFIG_KASAN,
because:
a) User tracking disables slab merging which improves
detecting out-of-bounds accesses.
b) User tracking metadata acts as redzone which also improves
c) User tracking provides additional information about object.
This information helps to understand bugs.
Currently it is not enabled by default. Besides recompiling the kernel
with KASAN and reinstalling it, user also have to change the boot cmdline,
which is not very handy.
Enable slub user tracking by default with KASAN=y, since there is no good
reason to not do this.
[akpm@linux-foundation.org: little fixes, per David]
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Add some out of bounds testcases to test_kasan module.
Signed-off-by: Wang Long <long.wanglong@huawei.com>
Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Vladimir Murzin <vladimir.murzin@arm.com>
Pull sparc updates from David Miller:
"Just a couple of fixes/cleanups:
- Correct NUMA latency calculations on sparc64, from Nitin Gupta.
- ASI_ST_BLKINIT_MRU_S value was wrong, from Rob Gardner.
- Fix non-faulting load handling of non-quad values, also from Rob
Gardner.
- Cleanup VISsave assembler, from Sam Ravnborg.
- Fix iommu-common code so it doesn't emit rediculous warnings on
some architectures, particularly ARM"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc:
sparc64: Fix numa distance values
sparc64: Don't restrict fp regs for no-fault loads
iommu-common: Fix error code used in iommu_tbl_range_{alloc,free}().
sparc64: use ENTRY/ENDPROC in VISsave
sparc64: Fix incorrect ASI_ST_BLKINIT_MRU_S value
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem update from James Morris:
"This is mostly maintenance updates across the subsystem, with a
notable update for TPM 2.0, and addition of Jarkko Sakkinen as a
maintainer of that"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (40 commits)
apparmor: clarify CRYPTO dependency
selinux: Use a kmem_cache for allocation struct file_security_struct
selinux: ioctl_has_perm should be static
selinux: use sprintf return value
selinux: use kstrdup() in security_get_bools()
selinux: use kmemdup in security_sid_to_context_core()
selinux: remove pointless cast in selinux_inode_setsecurity()
selinux: introduce security_context_str_to_sid
selinux: do not check open perm on ftruncate call
selinux: change CONFIG_SECURITY_SELINUX_CHECKREQPROT_VALUE default
KEYS: Merge the type-specific data with the payload data
KEYS: Provide a script to extract a module signature
KEYS: Provide a script to extract the sys cert list from a vmlinux file
keys: Be more consistent in selection of union members used
certs: add .gitignore to stop git nagging about x509_certificate_list
KEYS: use kvfree() in add_key
Smack: limited capability for changing process label
TPM: remove unnecessary little endian conversion
vTPM: support little endian guests
char: Drop owner assignment from i2c_driver
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core updates from Greg KH:
"Here's the "big" driver core updates for 4.4-rc1. Primarily a bunch
of debugfs updates, with a smattering of minor driver core fixes and
updates as well.
All have been in linux-next for a long time"
* tag 'driver-core-4.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
debugfs: Add debugfs_create_ulong()
of: to support binding numa node to specified device in devicetree
debugfs: Add read-only/write-only bool file ops
debugfs: Add read-only/write-only size_t file ops
debugfs: Add read-only/write-only x64 file ops
debugfs: Consolidate file mode checks in debugfs_create_*()
Revert "mm: Check if section present during memory block (un)registering"
driver-core: platform: Provide helpers for multi-driver modules
devres: fix a for loop bounds check
CMA: fix CONFIG_CMA_SIZE_MBYTES overflow in 64bit
base/platform: assert that dev_pm_domain callbacks are called unconditionally
sysfs: correctly handle short reads on PREALLOC attrs.
base: soc: siplify ida usage
kobject: move EXPORT_SYMBOL() macros next to corresponding definitions
kobject: explain what kobject's sd field is
debugfs: document that debugfs_remove*() accepts NULL and error values
debugfs: Pass bool pointer to debugfs_create_bool()
ACPI / EC: Fix broken 64bit big-endian users of 'global_lock'
When running "mod X" operation, if X is 0 the filter has to be halt.
Add new test cases to cover A = A mod X if X is 0, and A = A mod 1.
CC: Xi Wang <xi.wang@gmail.com>
CC: Zi Shen Lim <zlim.lnx@gmail.com>
Signed-off-by: Yang Shi <yang.shi@linaro.org>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Alexei Starovoitov <ast@kernel.org>
Acked-by: Zi Shen Lim <zlim.lnx@gmail.com>
Acked-by: Xi Wang <xi.wang@gmail.com>
The value returned from iommu_tbl_range_alloc() (and the one passed
in as a fourth argument to iommu_tbl_range_free) is not a DMA address,
it is rather an index into the IOMMU page table.
Therefore using DMA_ERROR_CODE is not appropriate.
Use a more type matching error code define, IOMMU_ERROR_CODE, and
update all users of this interface.
Reported-by: Andre Przywara <andre.przywara@arm.com>
Pull networking updates from David Miller:
Changes of note:
1) Allow to schedule ICMP packets in IPVS, from Alex Gartrell.
2) Provide FIB table ID in ipv4 route dumps just as ipv6 does, from
David Ahern.
3) Allow the user to ask for the statistics to be filtered out of
ipv4/ipv6 address netlink dumps. From Sowmini Varadhan.
4) More work to pass the network namespace context around deep into
various packet path APIs, starting with the netfilter hooks. From
Eric W Biederman.
5) Add layer 2 TX/RX checksum offloading to qeth driver, from Thomas
Richter.
6) Use usec resolution for SYN/ACK RTTs in TCP, from Yuchung Cheng.
7) Support Very High Throughput in wireless MESH code, from Bob
Copeland.
8) Allow setting the ageing_time in switchdev/rocker. From Scott
Feldman.
9) Properly autoload L2TP type modules, from Stephen Hemminger.
10) Fix and enable offload features by default in 8139cp driver, from
David Woodhouse.
11) Support both ipv4 and ipv6 sockets in a single vxlan device, from
Jiri Benc.
12) Fix CWND limiting of thin streams in TCP, from Bendik Rønning
Opstad.
13) Fix IPSEC flowcache overflows on large systems, from Steffen
Klassert.
14) Convert bridging to track VLANs using rhashtable entries rather than
a bitmap. From Nikolay Aleksandrov.
15) Make TCP listener handling completely lockless, this is a major
accomplishment. Incoming request sockets now live in the
established hash table just like any other socket too.
From Eric Dumazet.
15) Provide more bridging attributes to netlink, from Nikolay
Aleksandrov.
16) Use hash based algorithm for ipv4 multipath routing, this was very
long overdue. From Peter Nørlund.
17) Several y2038 cures, mostly avoiding timespec. From Arnd Bergmann.
18) Allow non-root execution of EBPF programs, from Alexei Starovoitov.
19) Support SO_INCOMING_CPU as setsockopt, from Eric Dumazet. This
influences the port binding selection logic used by SO_REUSEPORT.
20) Add ipv6 support to VRF, from David Ahern.
21) Add support for Mellanox Spectrum switch ASIC, from Jiri Pirko.
22) Add rtl8xxxu Realtek wireless driver, from Jes Sorensen.
23) Implement RACK loss recovery in TCP, from Yuchung Cheng.
24) Support multipath routes in MPLS, from Roopa Prabhu.
25) Fix POLLOUT notification for listening sockets in AF_UNIX, from Eric
Dumazet.
26) Add new QED Qlogic river, from Yuval Mintz, Manish Chopra, and
Sudarsana Kalluru.
27) Don't fetch timestamps on AF_UNIX sockets, from Hannes Frederic
Sowa.
28) Support ipv6 geneve tunnels, from John W Linville.
29) Add flood control support to switchdev layer, from Ido Schimmel.
30) Fix CHECKSUM_PARTIAL handling of potentially fragmented frames, from
Hannes Frederic Sowa.
31) Support persistent maps and progs in bpf, from Daniel Borkmann.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1790 commits)
sh_eth: use DMA barriers
switchdev: respect SKIP_EOPNOTSUPP flag in case there is no recursion
net: sched: kill dead code in sch_choke.c
irda: Delete an unnecessary check before the function call "irlmp_unregister_service"
net: dsa: mv88e6xxx: include DSA ports in VLANs
net: dsa: mv88e6xxx: disable SA learning for DSA and CPU ports
net/core: fix for_each_netdev_feature
vlan: Invoke driver vlan hooks only if device is present
arcnet/com20020: add LEDS_CLASS dependency
bpf, verifier: annotate verbose printer with __printf
dp83640: Only wait for timestamps for packets with timestamping enabled.
ptp: Change ptp_class to a proper bitmask
dp83640: Prune rx timestamp list before reading from it
dp83640: Delay scheduled work.
dp83640: Include hash in timestamp/packet matching
ipv6: fix tunnel error handling
net/mlx5e: Fix LSO vlan insertion
net/mlx5e: Re-eanble client vlan TX acceleration
net/mlx5e: Return error in case mlx5e_set_features() fails
net/mlx5e: Don't allow more than max supported channels
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6
Pull crypto update from Herbert Xu:
"API:
- Add support for cipher output IVs in testmgr
- Add missing crypto_ahash_blocksize helper
- Mark authenc and des ciphers as not allowed under FIPS.
Algorithms:
- Add CRC support to 842 compression
- Add keywrap algorithm
- A number of changes to the akcipher interface:
+ Separate functions for setting public/private keys.
+ Use SG lists.
Drivers:
- Add Intel SHA Extension optimised SHA1 and SHA256
- Use dma_map_sg instead of custom functions in crypto drivers
- Add support for STM32 RNG
- Add support for ST RNG
- Add Device Tree support to exynos RNG driver
- Add support for mxs-dcp crypto device on MX6SL
- Add xts(aes) support to caam
- Add ctr(aes) and xts(aes) support to qat
- A large set of fixes from Russell King for the marvell/cesa driver"
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (115 commits)
crypto: asymmetric_keys - Fix unaligned access in x509_get_sig_params()
crypto: akcipher - Don't #include crypto/public_key.h as the contents aren't used
hwrng: exynos - Add Device Tree support
hwrng: exynos - Fix missing configuration after suspend to RAM
hwrng: exynos - Add timeout for waiting on init done
dt-bindings: rng: Describe Exynos4 PRNG bindings
crypto: marvell/cesa - use __le32 for hardware descriptors
crypto: marvell/cesa - fix missing cpu_to_le32() in mv_cesa_dma_add_op()
crypto: marvell/cesa - use memcpy_fromio()/memcpy_toio()
crypto: marvell/cesa - use gfp_t for gfp flags
crypto: marvell/cesa - use dma_addr_t for cur_dma
crypto: marvell/cesa - use readl_relaxed()/writel_relaxed()
crypto: caam - fix indentation of close braces
crypto: caam - only export the state we really need to export
crypto: caam - fix non-block aligned hash calculation
crypto: caam - avoid needlessly saving and restoring caam_hash_ctx
crypto: caam - print errno code when hash registration fails
crypto: marvell/cesa - fix memory leak
crypto: marvell/cesa - fix first-fragment handling in mv_cesa_ahash_dma_last_req()
crypto: marvell/cesa - rearrange handling for sw padded hashes
Pull ARM updates from Russell King:
"In this ARM merge, we remove more lines than we add. Changes include:
- Enable imprecise aborts early, so that bus errors aren't masked
until later in the boot. This has the side effect that boot
loaders which provoke these aborts can cause the kernel to crash
early in boot, so we install a handler to report this event around
the site where these are enabled.
- Remove the buggy but impossible to enable cmpxchg syscall code.
- Add unwinding annotations to some assembly code.
- Add support for atomic half-word exchange for ARMv6k+.
- Reduce ioremap() alignment for SMP/LPAE cases where we don't need
the large alignment.
- Addition of an "optimal" 3G configuration for systems with 1G of
RAM.
- Increase vmalloc space by 128M.
- Constify some SMP operations structures, which have never been
writable.
- Improve ARMs dma_mmap() support for mapping DMA coherent mappings
into userspace.
- Fix to the NMI backtrace code in the IPI case on ARM where the
failing CPU gets stuck for 10s waiting for its own IPI to be
delivered.
- Removal of legacy PM support from the AMBA bus driver.
- Another fix for the previous fix of vdsomunge"
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (23 commits)
ARM: 8449/1: fix bug in vdsomunge swab32 macro
arm: add missing of_node_put
ARM: 8447/1: catch pending imprecise abort on unmask
ARM: 8446/1: amba: Remove unused callbacks for legacy system PM
ARM: 8443/1: Adding support for atomic half word exchange
ARM: clean up TWD after previous patch
ARM: 8441/2: twd: Don't set CLOCK_EVT_FEAT_C3STOP unconditionally
ARM: 8440/1: remove obsolete documentation
ARM: make highpte an expert option
ARM: 8433/1: add a VMSPLIT_3G_OPT config option
ARM: 8439/1: Fix backtrace generation when IPI is masked
ARM: 8428/1: kgdb: Fix registers on sleeping tasks
ARM: 8427/1: dma-mapping: add support for offset parameter in dma_mmap()
ARM: 8426/1: dma-mapping: add missing range check in dma_mmap()
ARM: remove user cmpxchg syscall
ARM: 8438/1: Add unwinding to __clear_user_std()
ARM: 8436/1: hw_breakpoint: remove unnecessary header
ARM: 8434/2: Revert "7655/1: smp_twd: make twd_local_timer_of_register() no-op for nosmp"
ARM: 8432/1: move VMALLOC_END from 0xff000000 to 0xff800000
ARM: 8430/1: use default ioremap alignment for SMP or LPAE
interval displays the probability and vice versa.
Fixes: 6adc4a22f20bb ("fault-inject: add ratelimit option")
Acked-by: Akinobu Mita <akinobu.mita@gmail.com>
Cc: <stable@vger.kernel.org>
When the kernel compiled with KASAN=y, GCC adds redzones for each
variable on stack. This enlarges function's stack frame and causes:
'warning: the frame size of X bytes is larger than Y bytes'
The worst case I've seen for now is following:
../net/wireless/nl80211.c: In function `nl80211_send_wiphy':
../net/wireless/nl80211.c:1731:1: warning: the frame size of 5448 bytes is larger than 2048 bytes [-Wframe-larger-than=]
That kind of warning becomes useless with KASAN=y. It doesn't
necessarily indicate that there is some problem in the code, thus we
should turn it off.
(The KASAN=y stack size in increased from 16k to 32k for this reason)
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Acked-by: Abylay Ospan <aospan@netup.ru>
Cc: Mauro Carvalho Chehab <m.chehab@samsung.com>
Cc: Kozlov Sergey <serjk@netup.ru>
Merge the type-specific data with the payload data into one four-word chunk
as it seems pointless to keep them separate.
Use user_key_payload() for accessing the payloads of overloaded
user-defined keys.
cc: linux-cifs@vger.kernel.org
cc: ecryptfs@vger.kernel.org
cc: linux-ext4@vger.kernel.org
cc: linux-f2fs-devel@lists.sourceforge.net
cc: linux-nfs@vger.kernel.org
cc: ceph-devel@vger.kernel.org
cc: linux-ima-devel@lists.sourceforge.net
The patch fixes the analysis of the input data which contains an off
by one.
The issue is visible when the SGL contains one byte per SG entry.
The code for checking for zero bytes does not operate on the data byte.
Signed-off-by: Stephan Mueller <smueller@chronox.de>
drivers/net/usb/asix_common.c
net/ipv4/inet_connection_sock.c
net/switchdev/switchdev.c
In the inet_connection_sock.c case the request socket hashing scheme
is completely different in net-next.
The other two conflicts were overlapping changes.
lib/built-in.o: In function `__bitrev32':
deftree.c:(.text+0x1e799): undefined reference to `byte_rev_table'
deftree.c:(.text+0x1e7a0): undefined reference to `byte_rev_table'
deftree.c:(.text+0x1e7b4): undefined reference to `byte_rev_table'
deftree.c:(.text+0x1e7c1): undefined reference to `byte_rev_table'
Anything which uses bitrevX() has to select BITREVERSE, to grab
lib/bitrev.o.
Reported-by: Jim Davis <jim.epost@gmail.com>
This header contains a few helpers currenly only used by the mpi
implementation, and not default implementation of architecture code.
This patch adds CRC generation and validation support for nx-842.
Add CRC flag so that nx842 coprocessor includes CRC during compression
and validates during decompression.
Also changes in 842 SW compression to append CRC value at the end
of template and checks during decompression.
Signed-off-by: Haren Myneni <haren@us.ibm.com>
Add mpi_read_raw_from_sgl and mpi_write_to_sgl helpers.
Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com>
Add a prandom_init_once() facility that works on the rnd_state, so that
users that are keeping their own state independent from prandom_u32() can
initialize their taus113 per cpu states.
The motivation here is similar to net_get_random_once(): initialize the
state as late as possible in the hope that enough entropy has been
collected for the seeding. prandom_init_once() makes use of the recently
introduced prandom_seed_full_state() helper and is generic enough so that
it could also be used on fast-paths due to the DO_ONCE().
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Factor out the full reseed handling code that populates the state
through get_random_bytes() and runs prandom_warmup(). The resulting
prandom_seed_full_state() will be used later on in more than the
current __prandom_reseed() user. Fix also two minor whitespace
issues along the way.
Make the get_random_once() helper generic enough, so that functions
in general would only be called once, where one user of this is then
net_get_random_once().
The only implementation specific call is to get_random_bytes(), all
the rest of this *_once() facility would be duplicated among different
subsystems otherwise. The new DO_ONCE() helper will be used by prandom()
later on, but might also be useful for other scenarios/subsystems as
well where a one-time initialization in often-called, possibly fast
path code could occur.
There's no good reason why users outside of networking should not
be using this facility, f.e. for initializing their seeds.
Therefore, make it accessible from there as get_random_once().
It's possible that the destination can be shadowed in userspace
(as, for example, the perf buffers are now). So we should take
care not to leak data that could be inspected by userspace.
Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com>
The section mismatch warning can be easy to miss during the kernel build
process. Allow it to be marked as fatal to be easily caught and prevent
bugs from slipping in.
Setting CONFIG_SECTION_MISMATCH_WARN_ONLY=y causes these warnings to be
non-fatal, since there are a number of section mismatches when using
allmodconfig on some architectures, and we do not want to break these
builds by default.
Signed-off-by: Nicolas Boichat <drinkcat@chromium.org>
Change-Id: Ic346706e3297c9f0d790e3552aa94e5cff9897a6
The iomap[] array has PCIM_IOMAP_MAX (6) elements and not
DEVICE_COUNT_RESOURCE (16). This bug was found using a static checker.
It may be that the "if (!(mask & (1 << i)))" check means we never
actually go past the end of the array in real life.
Fixes: ec04b075843d ('iomap: implement pcim_iounmap_regions()')
Acked-by: Tejun Heo <tj@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile
Pull strscpy string copy function implementation from Chris Metcalf.
Chris sent this during the merge window, but I waffled back and forth on
the pull request, which is why it's going in only now.
The new "strscpy()" function is definitely easier to use and more secure
than either strncpy() or strlcpy(), both of which are horrible nasty
interfaces that have serious and irredeemable problems.
strncpy() has a useless return value, and doesn't NUL-terminate an
overlong result. To make matters worse, it pads a short result with
zeroes, which is a performance disaster if you have big buffers.
strlcpy(), by contrast, is a mis-designed "fix" for strlcpy(), lacking
the insane NUL padding, but having a differently broken return value
which returns the original length of the source string. Which means
that it will read characters past the count from the source buffer, and
you have to trust the source to be properly terminated. It also makes
error handling fragile, since the test for overflow is unnecessarily
subtle.
strscpy() avoids both these problems, guaranteeing the NUL termination
(but not excessive padding) if the destination size wasn't zero, and
making the overflow condition very obvious by returning -E2BIG. It also
doesn't read past the size of the source, and can thus be used for
untrusted source data too.
So why did I waffle about this for so long?
Every time we introduce a new-and-improved interface, people start doing
these interminable series of trivial conversion patches.
And every time that happens, somebody does some silly mistake, and the
conversion patch to the improved interface actually makes things worse.
Because the patch is mindnumbing and trivial, nobody has the attention
span to look at it carefully, and it's usually done over large swatches
of source code which means that not every conversion gets tested.
So I'm pulling the strscpy() support because it *is* a better interface.
But I will refuse to pull mindless conversion patches. Use this in
places where it makes sense, but don't do trivial patches to fix things
that aren't actually known to be broken.
* 'strscpy' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile:
tile: use global strscpy() rather than private copy
string: provide strscpy()
Make asm/word-at-a-time.h available on all architectures
Move EXPORT_SYMBOL() macros in kobject.c from the end of the file
next to the function definitions to which they belong.
Signed-off-by: Gabriel Somlo <somlo@cmu.edu>
Its a bit odd that debugfs_create_bool() takes 'u32 *' as an argument,
when all it needs is a boolean pointer.
It would be better to update this API to make it accept 'bool *'
instead, as that will make it more consistent and often more convenient.
Over that bool takes just a byte.
That required updates to all user sites as well, in the same commit
updating the API. regmap core was also using
debugfs_{read|write}_file_bool(), directly and variable types were
updated for that to be bool as well.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Mark Brown <broonie@kernel.org>
Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
Currently on ARM when <SysRq-L> is triggered from an interrupt handler
(e.g. a SysRq issued using UART or kbd) the main CPU will wedge for ten
seconds with interrupts masked before issuing a backtrace for every CPU
except itself.
The new backtrace code introduced by commit 96f0e00378d4 ("ARM: add
basic support for on-demand backtrace of other CPUs") does not work
correctly when run from an interrupt handler because IPI_CPU_BACKTRACE
is used to generate the backtrace on all CPUs but cannot preempt the
current calling context.
This can be fixed by detecting that the calling context cannot be
preempted and issuing the backtrace directly in this case. Issuing
directly leaves us without any pt_regs to pass to nmi_cpu_backtrace()
so we also modify the generic code to call dump_stack() when its
argument is NULL.
Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com>
Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org>
Pull networking fixes from David Miller:
1) When we run a tap on netlink sockets, we have to copy mmap'd SKBs
instead of cloning them. From Daniel Borkmann.
2) When converting classical BPF into eBPF, fix the setting of the
source reg to BPF_REG_X. From Tycho Andersen.
3) Fix igmpv3/mldv2 report parsing in the bridge multicast code, from
Linus Lussing.
4) Fix dst refcounting for ipv6 tunnels, from Martin KaFai Lau.
5) Set NLM_F_REPLACE flag properly when replacing ipv6 routes, from
Roopa Prabhu.
6) Add some new cxgb4 PCI device IDs, from Hariprasad Shenai.
7) Fix headroom tests and SKB leaks in ipv6 fragmentation code, from
Florian Westphal.
8) Check DMA mapping errors in bna driver, from Ivan Vecera.
9) Several 8139cp bug fixes (dev_kfree_skb_any in interrupt context,
misclearing of interrupt status in TX timeout handler, etc.) from
David Woodhouse.
10) In tipc, reset SKB header pointer after skb_linearize(), from Erik
Hugne.
11) Fix autobind races et al. in netlink code, from Herbert Xu with
help from Tejun Heo and others.
12) Missing SET_NETDEV_DEV in sunvnet driver, from Sowmini Varadhan.
13) Fix various races in timewait timer and reqsk_queue_hadh_req, from
Eric Dumazet.
14) Fix array overruns in mac80211, from Johannes Berg and Dan
Carpenter.
15) Fix data race in rhashtable_rehash_one(), from Dmitriy Vyukov.
16) Fix race between poll_one_napi and napi_disable, from Neil Horman.
17) Fix byte order in geneve tunnel port config, from John W Linville.
18) Fix handling of ARP replies over lightweight tunnels, from Jiri
Benc.
19) We can loop when fib rule dumps cross multiple SKBs, fix from Wilson
Kok and Roopa Prabhu.
20) Several reference count handling bug fixes in the PHY/MDIO layer
from Russel King.
21) Fix lockdep splat in ppp_dev_uninit(), from Guillaume Nault.
22) Fix crash in icmp_route_lookup(), from David Ahern.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (116 commits)
net: Fix panic in icmp_route_lookup
net: update docbook comment for __mdiobus_register()
ppp: fix lockdep splat in ppp_dev_uninit()
net: via/Kconfig: GENERIC_PCI_IOMAP required if PCI not selected
phy: marvell: add link partner advertised modes
net: fix net_device refcounting
phy: add phy_device_remove()
phy: fixed-phy: properly validate phy in fixed_phy_update_state()
net: fix phy refcounting in a bunch of drivers
of_mdio: fix MDIO phy device refcounting
phy: add proper phy struct device refcounting
phy: fix mdiobus module safety
net: dsa: fix of_mdio_find_bus() device refcount leak
phy: fix of_mdio_find_bus() device refcount leak
ip6_tunnel: Reduce log level in ip6_tnl_err() to debug
ip6_gre: Reduce log level in ip6gre_err() to debug
fib_rules: fix fib rule dumps across multiple skbs
bnx2x: byte swap rss_key to comply to Toeplitz specs
net: revert "net_sched: move tp->root allocation into fw_init()"
lwtunnel: remove source and destination UDP port config option
rhashtable_rehash_one() uses complex logic to update entry->next field,
after INIT_RHT_NULLS_HEAD and NULLS_MARKER expansion:
entry->next = 1 | ((base + off) << 1)
This can be compiled along the lines of:
entry->next = base + off
entry->next <<= 1
entry->next |= 1
Which will break concurrent readers.
NULLS value recomputation is not needed here, so just remove
the complex logic.
The data race was found with KernelThreadSanitizer (KTSAN).
Signed-off-by: Dmitry Vyukov <dvyukov@google.com>
Acked-by: Thomas Graf <tgraf@suug.ch>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
when n < pool->hint
The check for invoking iommu->lazy_flush() from iommu_tbl_range_alloc()
has to be refactored so that we only call ->lazy_flush() if it is
non-null.
I had a sparc kernel that was crashing when I was trying to process some
very large perf.data files- the crash happens when the scsi driver calls
into dma_4v_map_sg and thus the iommu_tbl_range_alloc().
Signed-off-by: Sowmini Varadhan <sowmini.varadhan@oracle.com>
Some string_get_size() calls (e.g.:
string_get_size(1, 512, STRING_UNITS_10, ..., ...)
string_get_size(15, 64, STRING_UNITS_10, ..., ...)
) result in an infinite loop. The problem is that if size is equal to
divisor[units]/blk_size and is smaller than divisor[units] we'll end
up with size == 0 when we start doing sf_cap calculations:
For string_get_size(1, 512, STRING_UNITS_10, ..., ...) case:
remainder = do_div(size, divisor[units]); -> size is 0, remainder is 1
remainder *= blk_size; -> remainder is 512
size *= blk_size; -> size is still 0
size += remainder / divisor[units]; -> size is still 0
The caller causing the issue is sd_read_capacity(), the problem was
noticed on Hyper-V, such weird size was reported by host when scanning
collides with device removal. This is probably a separate issue worth
fixing, this patch is intended to prevent the library routine from
infinite looping.
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Acked-by: James Bottomley <JBottomley@Odin.com>
Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: "K. Y. Srinivasan" <kys@microsoft.com>
Remove bi_reverse() and use generic bitrev32() instead - it should have
better performance on some platforms.
Signed-off-by: yalin wang <yalin.wang2010@gmail.com>
Compare pointer-typed values to NULL rather than 0.
The semantic patch that makes this change is available
in scripts/coccinelle/null/badzero.cocci.
When loading x86 64bit kernel above 4GiB with patched grub2, got kernel
gunzip error.
| early console in decompress_kernel
| decompress_kernel:
| input: [0x807f2143b4-0x807ff61aee]
| output: [0x807cc00000-0x807f3ea29b] 0x027ea29c: output_len
| boot via startup_64
| KASLR using RDTSC...
| new output: [0x46fe000000-0x470138cfff] 0x0338d000: output_run_size
| decompress: [0x46fe000000-0x47007ea29b] <=== [0x807f2143b4-0x807ff61aee]
| Decompressing Linux... gz...
| uncompression error
| -- System halted
the new buffer is at 0x46fe000000ULL, decompressor_gzip is using
0xffffffb901ffffff as out_len. gunzip in lib/zlib_inflate/inflate.c cap
that len to 0x01ffffff and decompress fails later.
We could hit this problem with crashkernel booting that uses kexec loading
kernel above 4GiB.
We have decompress_* support:
1. inbuf[]/outbuf[] for kernel preboot.
2. inbuf[]/flush() for initramfs
3. fill()/flush() for initrd.
This bug only affect kernel preboot path that use outbuf[].
Add __decompress and take real out_buf_len for gunzip instead of guessing
wrong buf size.
Fixes: 1431574a1c4 (lib/decompressors: fix "no limit" output buffer length)
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Cc: Alexandre Courbot <acourbot@nvidia.com>
Cc: Jon Medhurst <tixy@linaro.org>
Cc: Stephen Warren <swarren@wwwdotorg.org>
In kmalloc_oob_krealloc_less, I think it is better to test
the size2 boundary.
If we do not call krealloc, the access of position size1 will still cause
out-of-bounds and access of position size2 does not. After call krealloc,
the access of position size2 cause out-of-bounds. So using size2 is more
correct.
Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com>
