path: root/lib
2014-06-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) Seccomp BPF filters can now be JIT'd, from Alexei Starovoitov. 2) Multiqueue support in xen-netback and xen-netfront, from Andrew J Benniston. 3) Allow tweaking of aggregation settings in cdc_ncm driver, from Bjørn Mork. 4) BPF now has a "random" opcode, from Chema Gonzalez. 5) Add more BPF documentation and improve test framework, from Daniel Borkmann. 6) Support TCP fastopen over ipv6, from Daniel Lee. 7) Add software TSO helper functions and use them to support software TSO in mvneta and mv643xx_eth drivers. From Ezequiel Garcia. 8) Support software TSO in fec driver too, from Nimrod Andy. 9) Add Broadcom SYSTEMPORT driver, from Florian Fainelli. 10) Handle broadcasts more gracefully over macvlan when there are large numbers of interfaces configured, from Herbert Xu. 11) Allow more control over fwmark used for non-socket based responses, from Lorenzo Colitti. 12) Do TCP congestion window limiting based upon measurements, from Neal Cardwell. 13) Support busy polling in SCTP, from Neal Horman. 14) Allow RSS key to be configured via ethtool, from Venkata Duvvuru. 15) Bridge promisc mode handling improvements from Vlad Yasevich. 16) Don't use inetpeer entries to implement ID generation any more, it performs poorly, from Eric Dumazet. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1522 commits) rtnetlink: fix userspace API breakage for iproute2 < v3.9.0 tcp: fixing TLP's FIN recovery net: fec: Add software TSO support net: fec: Add Scatter/gather support net: fec: Increase buffer descriptor entry number net: fec: Factorize feature setting net: fec: Enable IP header hardware checksum net: fec: Factorize the .xmit transmit function bridge: fix compile error when compiling without IPv6 support bridge: fix smatch warning / potential null pointer dereference via-rhine: fix full-duplex with autoneg disable bnx2x: Enlarge the dorq threshold for VFs bnx2x: Check for UNDI in uncommon branch bnx2x: Fix 1G-baseT link bnx2x: Fix link for KR with swapped polarity lane sctp: Fix sk_ack_backlog wrap-around problem net/core: Add VF link state control policy net/fsl: xgmac_mdio is dependent on OF_MDIO net/fsl: Make xgmac_mdio read error message useful net_sched: drr: warn when qdisc is not work conserving ...
2014-06-12Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "This is the main drm merge window pull request, changes all over the place, mostly normal levels of churn. Highlights: Core drm: More cleanups, fix race on connector/encoder naming, docs updates, object locking rework in prep for atomic modeset i915: mipi DSI support, valleyview power fixes, cursor size fixes, execlist refactoring, vblank improvements, userptr support, OOM handling improvements radeon: GPUVM tuning and large page size support, gart fixes, deep color HDMI support, HDMI audio cleanups nouveau: - displayport rework should fix lots of issues - initial gk20a support - gk110b support - gk208 fixes exynos: probe order fixes, HDMI changes, IPP consolidation msm: debugfs updates, misc fixes ast: ast2400 support, sync with UMS driver tegra: cleanups, hdmi + hw cursor for Tegra 124. panel: fixes existing panels add some new ones. ipuv3: moved from staging to drivers/gpu" * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (761 commits) drm/nouveau/disp/dp: fix tmds passthrough on dp connector drm/nouveau/dp: probe dpcd to determine connectedness drm/nv50-: trigger update after all connectors disabled drm/nv50-: prepare for attaching a SOR to multiple heads drm/gf119-/disp: fix debug output on update failure drm/nouveau/disp/dp: make use of postcursor when its available drm/g94-/disp/dp: take max pullup value across all lanes drm/nouveau/bios/dp: parse lane postcursor data drm/nouveau/dp: fix support for dpms drm/nouveau: register a drm_dp_aux channel for each dp connector drm/g94-/disp: add method to power-off dp lanes drm/nouveau/disp/dp: maintain link in response to hpd signal drm/g94-/disp: bash and wait for something after changing lane power regs drm/nouveau/disp/dp: split link config/power into two steps drm/nv50/disp: train PIOR-attached DP from second supervisor drm/nouveau/disp/dp: make use of existing output data for link training drm/gf119/disp: start removing direct vbios parsing from supervisor drm/nv50/disp: start removing direct vbios parsing from supervisor drm/nouveau/disp/dp: maintain receiver caps in response to hpd signal drm/nouveau/disp/dp: create subclass for dp outputs ...
2014-06-11cpumask: Utility function to set n'th cpu - local cpu firstAmir Vadai
This function sets the n'th cpu - local cpu's first. For example: in a 16 cores server with even cpu's local, will get the following values: cpumask_set_cpu_local_first(0, numa, cpumask) => cpu 0 is set cpumask_set_cpu_local_first(1, numa, cpumask) => cpu 2 is set ... cpumask_set_cpu_local_first(7, numa, cpumask) => cpu 14 is set cpumask_set_cpu_local_first(8, numa, cpumask) => cpu 1 is set cpumask_set_cpu_local_first(9, numa, cpumask) => cpu 3 is set ... cpumask_set_cpu_local_first(15, numa, cpumask) => cpu 15 is set Curently this function will be used by multi queue networking devices to calculate the irq affinity mask, such that as many local cpu's as possible will be utilized to handle the mq device irq's. Signed-off-by: Amir Vadai <amirv@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-11net: filter: fix nlattr and nlattr_nest BPF testsAlexei Starovoitov
- 'struct nlattr' must be 2 byte aligned - provide big-endian input data for nlattr/nlattr_nest tests Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Acked-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-08Merge branch 'next' (accumulated 3.16 merge window patches) into masterLinus Torvalds
Now that 3.15 is released, this merges the 'next' branch into 'master', bringing us to the normal situation where my 'master' branch is the merge window. * accumulated work in next: (6809 commits) ufs: sb mutex merge + mutex_destroy powerpc: update comments for generic idle conversion cris: update comments for generic idle conversion idle: remove cpu_idle() forward declarations nbd: zero from and len fields in NBD_CMD_DISCONNECT. mm: convert some level-less printks to pr_* MAINTAINERS: adi-buildroot-devel is moderated MAINTAINERS: add linux-api for review of API/ABI changes mm/kmemleak-test.c: use pr_fmt for logging fs/dlm/debug_fs.c: replace seq_printf by seq_puts fs/dlm/lockspace.c: convert simple_str to kstr fs/dlm/config.c: convert simple_str to kstr mm: mark remap_file_pages() syscall as deprecated mm: memcontrol: remove unnecessary memcg argument from soft limit functions mm: memcontrol: clean up memcg zoneinfo lookup mm/memblock.c: call kmemleak directly from memblock_(alloc|free) mm/mempool.c: update the kmemleak stack trace for mempool allocations lib/radix-tree.c: update the kmemleak stack trace for radix tree allocations mm: introduce kmemleak_update_trace() mm/kmemleak.c: use %u to print ->checksum ...
2014-06-06lib/radix-tree.c: update the kmemleak stack trace for radix tree allocationsCatalin Marinas
Since radix_tree_preload() stack trace is not always useful for debugging an actual radix tree memory leak, this patch updates the kmemleak allocation stack trace in the radix_tree_node_alloc() function. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06idr: reduce the unneeded check in free_layer()Lai Jiangshan
If "idr->hint == p" is true, it also implies "idr->hint" is true(not NULL). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06idr: don't need to shink the free list when idr_remove()Lai Jiangshan
After idr subsystem is changed to RCU-awared, the free layer will not go to the free list. The free list will not be filled up when idr_remove(). So we don't need to shink it too. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06idr: fix idr_replace()'s returned error codeLai Jiangshan
When the smaller id is not found, idr_replace() returns -ENOENT. But when the id is bigger enough, idr_replace() returns -EINVAL, actually there is no difference between these two kinds of ids. These are all unallocated id, the return values of the idr_replace() for these ids should be the same: -ENOENT. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06idr: fix NULL pointer dereference when ida_remove(unallocated_id)Lai Jiangshan
If the ida has at least one existing id, and when an unallocated ID which meets a certain condition is passed to the ida_remove(), the system will crash because it hits NULL pointer dereference. The condition is that the unallocated ID shares the same lowest idr layer with the existing ID, but the idr slot would be different if the unallocated ID were to be allocated. In this case the matching idr slot for the unallocated_id is NULL, causing @bitmap to be NULL which the function dereferences without checking crashing the kernel. See the test code: static void test3(void) { int id; DEFINE_IDA(test_ida); printk(KERN_INFO "Start test3\n"); if (ida_pre_get(&test_ida, GFP_KERNEL) < 0) return; if (ida_get_new(&test_ida, &id) < 0) return; ida_remove(&test_ida, 4000); /* bug: null deference here */ printk(KERN_INFO "End of test3\n"); } It happens only when the caller tries to free an unallocated ID which is the caller's fault. It is not a bug. But it is better to add the proper check and complain rather than crashing the kernel. [tj@kernel.org: updated patch description] Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06idr: fix unexpected ID-removal when idr_remove(unallocated_id)Lai Jiangshan
If unallocated_id = (ANY * idr_max(idp->layers) + existing_id) is passed to idr_remove(). The existing_id will be removed unexpectedly. The following test shows this unexpected id-removal: static void test4(void) { int id; DEFINE_IDR(test_idr); printk(KERN_INFO "Start test4\n"); id = idr_alloc(&test_idr, (void *)1, 42, 43, GFP_KERNEL); BUG_ON(id != 42); idr_remove(&test_idr, 42 + IDR_SIZE); TEST_BUG_ON(idr_find(&test_idr, 42) != (void *)1); idr_destroy(&test_idr); printk(KERN_INFO "End of test4\n"); } ida_remove() shares the similar problem. It happens only when the caller tries to free an unallocated ID which is the caller's fault. It is not a bug. But it is better to add the proper check and complain rather than removing an existing_id silently. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06idr: fix overflow bug during maximum ID calculation at maximum heightLai Jiangshan
idr_replace() open-codes the logic to calculate the maximum valid ID given the height of the idr tree; unfortunately, the open-coded logic doesn't account for the fact that the top layer may have unused slots and over-shifts the limit to zero when the tree is at its maximum height. The following test code shows it fails to replace the value for id=((1<<27)+42): static void test5(void) { int id; DEFINE_IDR(test_idr); #define TEST5_START ((1<<27)+42) /* use the highest layer */ printk(KERN_INFO "Start test5\n"); id = idr_alloc(&test_idr, (void *)1, TEST5_START, 0, GFP_KERNEL); BUG_ON(id != TEST5_START); TEST_BUG_ON(idr_replace(&test_idr, (void *)2, TEST5_START) != (void *)1); idr_destroy(&test_idr); printk(KERN_INFO "End of test5\n"); } Fix the bug by using idr_max() which correctly takes into account the maximum allowed shift. sub_alloc() shares the same problem and may incorrectly fail with -EAGAIN; however, this bug doesn't affect correct operation because idr_get_empty_slot(), which already uses idr_max(), retries with the increased @id in such cases. [tj@kernel.org: Updated patch description.] Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Tejun Heo <tj@kernel.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-05Merge branch 'arm64-efi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next Pull ARM64 EFI update from Peter Anvin: "By agreement with the ARM64 EFI maintainers, we have agreed to make -tip the upstream for all EFI patches. That is why this patchset comes from me :) This patchset enables EFI stub support for ARM64, like we already have on x86" * 'arm64-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: arm64: efi: only attempt efi map setup if booting via EFI efi/arm64: ignore dtb= when UEFI SecureBoot is enabled doc: arm64: add description of EFI stub support arm64: efi: add EFI stub doc: arm: add UEFI support documentation arm64: add EFI runtime services efi: Add shared FDT related functions for ARM/ARM64 arm64: Add function to create identity mappings efi: add helper function to get UEFI params from FDT doc: efi-stub.txt updates for ARM lib: add fdt_empty_tree.c
2014-06-05Merge commit '9e9a928eed8796a0a1aaed7e0b676db86ba84594' into drm-nextDave Airlie
Merge drm-fixes into drm-next. Both i915 and radeon need this done for later patches. Conflicts: drivers/gpu/drm/drm_crtc_helper.c drivers/gpu/drm/i915/i915_drv.h drivers/gpu/drm/i915/i915_gem.c drivers/gpu/drm/i915/i915_gem_execbuffer.c drivers/gpu/drm/i915/i915_gem_gtt.c
2014-06-04lib/asn1_decoder.c: kernel-doc warning fixFabian Frederick
Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04lib/atomic64_test.c: convert printk(KERN_INFO to pr_infoFabian Frederick
Convert printk to current pr_foo() logging functions. Also add pr_fmt based on KBUILD_MODNAME to avoid repeating prefix. Prefix is now "atomic64_test: " Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Luca Barbieri <luca@luca-barbieri.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04lib/bug.c: convert printk to pr_foo()Fabian Frederick
- Coalesce formats - "WARNING:" prefix unchanged to keep bug format. - printk(KERN_DEFAULT not converted. - define pr_fmt without prefix to avoid any default prefix update (suggested by Joe Perches). Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04lib/textsearch.c: move EXPORT_SYMBOL after functionsFabian Frederick
Fix checkpatch warning: "WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable" Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04lib/nlattr.c: move EXPORT_SYMBOL after functionsFabian Frederick
Fix some checkpatch warnings: WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Pablo Neira <pablo@netfilter.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04lib/digsig.c: kernel-doc warning fixesFabian Frederick
Small typo and @return: -> Returns ... Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Duan Jiong <duanj.fnst@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04lib/crc32.c: remove unnecessary __constantFabian Frederick
Use cpu_to_le32 instead of __constant_cpu_to_le32. Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04lib/radix-tree.c: kernel-doc warning fixFabian Frederick
index has been removed from __radix_tree_delete_node in 449dd6984d0e47 ("mm: keep page cache radix tree nodes in check") Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04lib/plist.c: make CONFIG_DEBUG_PI_LIST selectableDan Streetman
Change CONFIG_DEBUG_PI_LIST to be user-selectable, and add a title and description. Remove the dependency on DEBUG_RT_MUTEXES since they were changed to use rbtrees, and there are other users of plists now. Signed-off-by: Dan Streetman <ddstreet@ieee.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04lib/btree.c: fix leak of whole btree nodesMinfei Huang
I use btree from 3.14-rc2 in my own module. When the btree module is removed, a warning arises: kmem_cache_destroy btree_node: Slab cache still has objects CPU: 13 PID: 9150 Comm: rmmod Tainted: GF O 3.14.0-rc2 #1 Hardware name: Inspur NF5270M3/NF5270M3, BIOS CHEETAH_2.1.3 09/10/2013 Call Trace: dump_stack+0x49/0x5d kmem_cache_destroy+0xcf/0xe0 btree_module_exit+0x10/0x12 [btree] SyS_delete_module+0x198/0x1f0 system_call_fastpath+0x16/0x1b The cause is that it doesn't release the last btree node, when height = 1 and fill = 1. [akpm@linux-foundation.org: remove unneeded test of NULL] Signed-off-by: Minfei Huang <huangminfei@ucloud.cn> Cc: Joern Engel <joern@logfs.org> Cc: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04lib/vsprintf.c: fix comparison to boolFabian Frederick
Fixing 2 coccinelle warnings: lib/vsprintf.c:2350:2-9: WARNING: Assignment of bool to 0/1 lib/vsprintf.c:2389:3-10: WARNING: Assignment of bool to 0/1 Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04lib/libcrc32c.c: use PTR_ERR_OR_ZEROFabian Frederick
replace IS_ERR/PTR_ERR Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04lib/xz: enable all filters by default in KconfigLasse Collin
This restores the old behavior that existed before 2013-02-22, when changes were made by 64dbfb444c150 ("decompressors: drop dependency on CONFIG_EXPERT") and 5dc49c75a2 ("decompressors: make the default XZ_DEC_* config match the selected architecture"). Disabling the filters only makes sense on embedded systems. Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Acked-by: Kyle McMartin <kyle@infradead.org> Cc: Florian Fainelli <f.fainelli@gmail.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04lib/plist.c: replace pr_debug with printk in plist_test()Dan Streetman
Replace pr_debug() in lib/plist.c test function plist_test() with printk(KERN_DEBUG ...). Without DEBUG defined, pr_debug() is complied out, but the entire plist_test() function is already inside CONFIG_DEBUG_PI_LIST, so printk should just be used directly. Signed-off-by: Dan Streetman <ddstreet@ieee.org> Reviewed-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04lib/xz: add comments for the intentionally missing break statementsLasse Collin
Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04lib/string.c: use the name "C-string" in commentsDan Carpenter
For strncpy() and friends the source string may or may not have an actual NUL character at the end. The documentation is confusing in this because it specifically mentions that you are passing a "NUL-terminated" string. Wikipedia says that "C-string" is an alternative name we can use instead. http://en.wikipedia.org/wiki/Null-terminated_string Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04lib/plist: add plist_requeueDan Streetman
Add plist_requeue(), which moves the specified plist_node after all other same-priority plist_nodes in the list. This is essentially an optimized plist_del() followed by plist_add(). This is needed by swap, which (with the next patch in this set) uses a plist of available swap devices. When a swap device (either a swap partition or swap file) are added to the system with swapon(), the device is added to a plist, ordered by the swap device's priority. When swap needs to allocate a page from one of the swap devices, it takes the page from the first swap device on the plist, which is the highest priority swap device. The swap device is left in the plist until all its pages are used, and then removed from the plist when it becomes full. However, as described in man 2 swapon, swap must allocate pages from swap devices with the same priority in round-robin order; to do this, on each swap page allocation, swap uses a page from the first swap device in the plist, and then calls plist_requeue() to move that swap device entry to after any other same-priority swap devices. The next swap page allocation will again use a page from the first swap device in the plist and requeue it, and so on, resulting in round-robin usage of equal-priority swap devices. Also add plist_test_requeue() test function, for use by plist_test() to test plist_requeue() function. Signed-off-by: Dan Streetman <ddstreet@ieee.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Acked-by: Mel Gorman <mgorman@suse.de> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Shaohua Li <shli@fusionio.com> Cc: Hugh Dickins <hughd@google.com> Cc: Dan Streetman <ddstreet@ieee.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com> Cc: Weijie Yang <weijieut@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Bob Liu <bob.liu@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04mm: replace __get_cpu_var uses with this_cpu_ptrChristoph Lameter
Replace places where __get_cpu_var() is used for an address calculation with this_cpu_ptr(). Signed-off-by: Christoph Lameter <cl@linux.com> Cc: Tejun Heo <tj@kernel.org> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04x86: enable DMA CMA with swiotlbAkinobu Mita
The DMA Contiguous Memory Allocator support on x86 is disabled when swiotlb config option is enabled. So DMA CMA is always disabled on x86_64 because swiotlb is always enabled. This attempts to support for DMA CMA with enabling swiotlb config option. The contiguous memory allocator on x86 is integrated in the function dma_generic_alloc_coherent() which is .alloc callback in nommu_dma_ops for dma_alloc_coherent(). x86_swiotlb_alloc_coherent() which is .alloc callback in swiotlb_dma_ops tries to allocate with dma_generic_alloc_coherent() firstly and then swiotlb_alloc_coherent() is called as a fallback. The main part of supporting DMA CMA with swiotlb is that changing x86_swiotlb_free_coherent() which is .free callback in swiotlb_dma_ops for dma_free_coherent() so that it can distinguish memory allocated by dma_generic_alloc_coherent() from one allocated by swiotlb_alloc_coherent() and release it with dma_generic_free_coherent() which can handle contiguous memory. This change requires making is_swiotlb_buffer() global function. This also needs to change .free callback in the dma_map_ops for amd_gart and sta2x11, because these dma_ops are also using dma_generic_alloc_coherent(). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Don Dutile <ddutile@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04mm,vmacache: add debug dataDavidlohr Bueso
Introduce a CONFIG_DEBUG_VM_VMACACHE option to enable counting the cache hit rate -- exported in /proc/vmstat. Any updates to the caching scheme needs this kind of data, thus it can save some work re-implementing the counting all the time. Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Cc: Aswin Chandramouleeswaran <aswin@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04lib/debugobjects.c: convert printk(KERN_DEBUG to pr_debugFabian Frederick
Direct conversion of one KERN_DEBUG message without DEBUG definition (suggested by Josh Triplett) That message will now be disabled by default. (see Documentation/CodingStyle Chapter 13) Signed-off-by: Fabian Frederick <fabf@skynet.be> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04lib/debugobjects.c: add pr_fmt to loggingFabian Frederick
Add ODEBUG: prefix to pr_fmt Signed-off-by: Fabian Frederick <fabf@skynet.be> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04lib/debugobjects.c: convert printk to pr_foo()Fabian Frederick
Convert all printk to pr_foo() except KERN_DEBUG (see Documentation/CodingStyle Chapter 13) Signed-off-by: Fabian Frederick <fabf@skynet.be> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04Merge tag 'devicetree-for-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux into next Pull DeviceTree updates from Rob Herring: - Another round of clean-up of FDT related code in architecture code. This removes knowledge of internal FDT details from most architectures except powerpc. - Conversion of kernel's custom FDT parsing code to use libfdt. - DT based initialization for generic serial earlycon. The introduction of generic serial earlycon support went in through the tty tree. - Improve the platform device naming for DT probed devices to ensure unique naming and use parent names instead of a global index. - Fix a race condition in of_update_property. - Unify the various linker section OF match tables and fix several function prototype errors. - Update platform_get_irq_byname to work in deferred probe cases. - 2 binding doc updates * tag 'devicetree-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (58 commits) of: handle NULL node in next_child iterators of/irq: provide more wrappers for !CONFIG_OF devicetree: bindings: Document micrel vendor prefix dt: bindings: dwc2: fix required value for the phy-names property of_pci_irq: kill useless variable in of_irq_parse_pci() of/irq: do irq resolution in platform_get_irq_byname() of: Add a testcase for of_find_node_by_path() of: Make of_find_node_by_path() handle /aliases of: Create unlocked version of for_each_child_of_node() lib: add glibc style strchrnul() variant of: Handle memory@0 node on PPC32 only pci/of: Remove dead code of: fix race between search and remove in of_update_property() of: Use NULL for pointers of: Stop naming platform_device using dcr address of: Ensure unique names without sacrificing determinism tty/serial: pl011: add DT based earlycon support of/fdt: add FDT serial scanning for earlycon of/fdt: add FDT address translation support serial: earlycon: add DT support ...
2014-06-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial into next Pull trivial tree changes from Jiri Kosina: "Usual pile of patches from trivial tree that make the world go round" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (23 commits) staging: go7007: remove reference to CONFIG_KMOD aic7xxx: Remove obsolete preprocessor define of: dma: doc fixes doc: fix incorrect formula to calculate CommitLimit value doc: Note need of bc in the kernel build from 3.10 onwards mm: Fix printk typo in dmapool.c modpost: Fix comment typo "Modules.symvers" Kconfig.debug: Grammar s/addition/additional/ wimax: Spelling s/than/that/, wording s/destinatary/recipient/ aic7xxx: Spelling s/termnation/termination/ arm64: mm: Remove superfluous "the" in comment of: Spelling s/anonymouns/anonymous/ dma: imx-sdma: Spelling s/determnine/determine/ ath10k: Improve grammar in comments ath6kl: Spelling s/determnine/determine/ of: Improve grammar for of_alias_get_id() documentation drm/exynos: Spelling s/contro/control/ radio-bcm2048.c: fix wrong overflow check doc: printk-formats: do not mention casts for u64/s64 doc: spelling error changes ...
2014-06-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: include/net/inetpeer.h net/ipv6/output_core.c Changes in net were fixing bugs in code removed in net-next. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-02net: filter: fix length calculation in BPF testsuiteChema Gonzalez
The current probe_filter_length() (the function that calculates the length of a test BPF filter) behavior is to declare the end of the filter as soon as it finds {0, *, *, 0}. This is actually a valid insn ("ld #0"), so any filter with includes "BPF_STMT(BPF_LD | BPF_IMM, 0)" fails (its length is cut short). We are changing probe_filter_length() so as to start from the end, and declare the end of the filter as the first instruction which is not {0, *, *, 0}. This solution produces a simpler patch than the alternative of using an explicit end-of-filter mark. It is technically incorrect if your filter ends up with "ld #0", but that should not happen anyway. We also add a new test (LD_IMM_0) that includes ld #0 (does not work without this patch). Signed-off-by: Chema Gonzalez <chema@google.com> Acked-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-02netlink: rate-limit leftover bytes warning and print process nameMichal Schmidt
Any process is able to send netlink messages with leftover bytes. Make the warning rate-limited to prevent too much log spam. The warning is supposed to help find userspace bugs, so print the triggering command name to implicate the buggy program. [v2: Use pr_warn_ratelimited instead of printk_ratelimited.] Signed-off-by: Michal Schmidt <mschmidt@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-01net: filter: add test for loading SKF_AD_OFF limitsDaniel Borkmann
This check tests that overloading BPF_LD | BPF_ABS with an always invalid BPF extension, that is SKF_AD_MAX, fails to make sure classic BPF behaviour is correct in filter checker. Also, we add a test for loading at packet offset SKF_AD_OFF-1 which should pass the filter, but later on fail during runtime. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-01net: filter: add slot overlapping test with fully filled M[]Daniel Borkmann
Also add a test for the scratch memory store that first fills all slots and then sucessively reads all of them back adding up to A, and eventually returning A. This and the previous M[] test with alternating fill/spill will detect possible JIT errors on M[]. Suggested-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-01net: Revert mlx4 cpumask changes.David S. Miller
This reverts commit 70a640d0dae3a9b1b222ce673eb5d92c263ddd61 ("net/mlx4_en: Use affinity hint") and commit c8865b64b05b2f4eeefd369373e9c8aeb069e7a1 ("cpumask: Utility function to set n'th cpu - local cpu first") because these changes break the build when SMP is disabled amongst other things. Reported-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-01cpumask: Utility function to set n'th cpu - local cpu firstAmir Vadai
2014-05-30Merge branch 'for-davem' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next John W. Linville says: ==================== Please pull this batch of updates intended for 3.16... For the mac80211 bits, Johannes says: "Here I just have Heikki's rfkill GPIO cleanups. The ARM/tegra patch is OK with the maintainer (Stephen). Let me know of any problems." and; "We have a whole bunch of work on CSA by Andrei, Luca and Michal, but unfortunately it doesn't seem quite complete yet so it's still disabled. There's some TDLS work from Arik, and the rest is mostly minor fixes and cleanups." For the NFC bits, Samuel says: "This is the NFC pull request for 3.16. We have: - STMicroeectronics st21nfca support. The st21nfca is an HCI chipset and thus relies on the HCI stack. This submission provides support for tag redaer/writer mode (including Type 5) and device tree bindings. - PM runtime support and a bunch of bug fixes for TI's trf7970a. - Device tree support for NXP's pn544. Legacy platform data support is obviously kept intact. - NFC Tag type 4B support to the NFC Digital stack. - SOCK_RAW type support to the raw NFC socket, and allow NCI sniffing from that. This can be extended to report HCI frames and also proprietarry ones like e.g. the pn533 ones." For the iwlwifi bits, Emmanuel says: "Eran continues to work on new devices, Eyal is still digging in the rate control stuff, and Johannes added new functionality to the debug system we have in place now along with a few cleanups he made on the way. That's pretty much it." and; "Avri continues to work on the power code and Eran is improving the NVM handling as a preparations for new devices on which he works with Liad. Luca cleans up a bit the code while working on CSA. I have the regular BT Coex stuff and a small lockdep fix. Johannes has his regular amount of clean ups and improvements, the main one is the ability to leave 2 chains open to improve diversity and hence the throughput in high attenuation scenarios." and; "The regular amount of housekeeping here. I merged iwlwifi-fixes.git to be able to add the patch you didn't want in wireless.git at that stage of the -rc cycle. Luca has a few preparations for CSA implementation and also what seems to be a bugfix for P2P but hasn't caused issues we could notice." For the Atheros bits, Kalle says: "For ath10k Michal did various small fixes on how we handle hardware/firmware problems and he also fixed two memory leaks." Also included are a couple of pulls from the wireless tree to avoid/resolve merge issues... ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-30net: filter: use block statements in tcpdump testsDaniel Borkmann
This patch converts raw opcodes for tcpdump tests into BPF_STMT()/BPF_JUMP() combinations, which brings it into conformity with the rest of the patches and it also makes life easier to grasp what's going on in these particular test cases when they ever fail. Also arrange payload from the jump+holes test in a way as we have with other packet payloads in the test suite. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-30net: filter: test fill/spill of all M[] regsDaniel Borkmann
This test for classic BPF probes stores and load combination via X on all 16 registers of the scratch memory store. It initially loads integer 100 and passes this value around to each register while incrementing it every time, thus we expect to have 116 as a result. Might be useful for JIT testing. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-27Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem
