path: root/lib
2009-09-08Make bitmask 'and' operators return a result codeLinus Torvalds
commit f4b0373b26567cafd421d91101852ed7a34e9e94 upstream. When 'and'ing two bitmasks (where 'andnot' is a variation on it), some cases want to know whether the result is the empty set or not. In particular, the TLB IPI sending code wants to do cpumask operations and determine if there are any CPU's left in the final set. So this just makes the bitmask (and cpumask) functions return a boolean for whether the result has any bits set. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-19dma-debug: fix off-by-one error in overlap functionJoerg Roedel
commit c79ee4e466dd12347f112e2af306dca35198458f upstream. This patch fixes a bug in the overlap function which returned true if one region ends exactly before the second region begins. This is no overlap but the function returned true in that case. Reported-by: Andrew Randrianasulu <randrik@mail.ru> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-02lib/genalloc.c: remove unmatched write_lock() in gen_pool_destroyZygo Blaxell
commit 8e8a2dea0ca91fe2cb7de7ea212124cfe8c82c35 upstream. There is a call to write_lock() in gen_pool_destroy which is not balanced by any corresponding write_unlock(). This causes problems with preemption because the preemption-disable counter is incremented in the write_lock() call, but never decremented by any call to write_unlock(). This bug is gen_pool_destroy, and one of them is non-x86 arch-specific code. Signed-off-by: Zygo Blaxell <zygo.blaxell@xandros.com> Cc: Jiri Kosina <trivial@kernel.org> Cc: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-02lockdep: Select frame pointers on x86Peter Zijlstra
commit 00540e5d54be972a94a3b2ce6da8621bebe731a2 upstream. x86 stack traces are a piece of crap without frame pointers, and its not like the 'performance gain' of not having stack pointers matters when you selected lockdep. Reported-by: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <new-submission> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-02dma-debug: change hash_bucket_find from first-fit to best-fitJoerg Roedel
commit 7caf6a49bb17d0377210693af5737563b31aa5ee upstream. Some device drivers map the same physical address multiple times to a dma address. Without an IOMMU this results in the same dma address being put into the dma-debug hash multiple times. With a first-fit match in hash_bucket_find() this function may return the wrong dma_debug_entry. This can result in false positive warnings. This patch fixes it by changing the first-fit behavior of hash_bucket_find() into a best-fit algorithm. Reported-by: Torsten Kaiser <just.for.lkml@googlemail.com> Reported-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Cc: lethal@linux-sh.org Cc: just.for.lkml@googlemail.com Cc: hancockrwd@gmail.com Cc: jens.axboe@oracle.com Cc: bharrosh@panasas.com Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <20090605104132.GE24836@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-09cpumask: introduce zalloc_cpumask_varYinghai Lu
So can get cpumask_var with cpumask_clear Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-05-08Remove old PRINTK_DEBUG config itemJason Baron
On Tue, Apr 21, 2009 at 01:55:53PM +0200, Stefan Richter wrote: > Robert P. J. Day wrote: > > lib/Kconfig.debug: select PRINTK_DEBUG > > > > should that perhaps refer to "DYNAMIC_PRINTK_DEBUG"? since there is > > no such thing as a PRINTK_DEBUG Kconfig variable. > > Looks like a rudiment from an earlier version of Jason's "driver core: > basic infrastructure for per-module dynamic debug messages", > http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=346e15beb5343c2eb8216d820f2ed8f150822b08 > Search an LKML archive for '+#ifdef CONFIG_PRINTK_DEBUG'. > > Jason, should it be deleted or replaced by something? We re-named 'DYNAMIC_PRINTK_DEBUG' to 'DYNAMIC_DEBUG' in 2.6.30.... 'PRINTK_DEBUG' as pointed out never existed. So, it appears to be extraneous, and should be removed. thanks for pointing it out. Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-05-05Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: kernel/posix-cpu-timers.c: fix sparse warning dma-debug: remove broken dma memory leak detection for 2.6.30 locking: Documentation: lockdep-design.txt, fix note of state bits
2009-04-26dma-debug: remove broken dma memory leak detection for 2.6.30Joerg Roedel
The feature needs some more work because the notfier which is used to check for pending allocations is called before the device drivers ->remove() function. Therefore this feature reports false positives. A real fix for this issue is to introduce a new notifier event which sent _after_ the driver has deinitialized itself. That will done for the next kernel version. [ Impact: reduce the scope of CONFIG_DMA_API_DEBUG=y checks ] Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Cc: iommu@lists.linux-foundation.org LKML-Reference: <1240576557-22442-1-git-send-email-joerg.roedel@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-24lib: find_last_bit.o needed by a module only, move it from lib to objFred Isaman
Currently, although find_last_bit is EXPORTed, it is statically linked with the kernel and is referenced only under CONFIG_SMP. When CONFIG_SMP is undefined and find_last_bit is referenced only by modules, linking fails with: ERROR: "find_last_bit" [fs/nfs/nfs.ko] undefined! Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Fred Isaman <iisaman@citi.umich.edu> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-24Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: [S390] update default configuration. [S390] omit frame pointers on s390 when possible [S390] Use tape_generic_offline directly. [S390] /proc/stat idle field for idle cpus [S390] appldata: avoid deadlock with appldata_mem [S390] ipl: fix compile breakage
2009-04-23[S390] omit frame pointers on s390 when possibleHeiko Carstens
Always omit frame pointers on s390. They aren't too useful for the kernel since we have already the kernel stack backchain which allows us to walk the kernel stack. So eleminate the extra code for frame pointers. Only allow the extra code for the function tracer since the gcc compile options -pg and -fomit-frame-pointer are incompatible. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-04-22scatterlist: make sure sg_miter_next() doesn't return 0 sized mappingsTejun Heo
Impact: fix not-so-critical but annoying bug sg_miter_next() returns 0 sized mapping if there is an zero sized sg entry in the list or at the end of each iteration. As the users always check the ->length field, this bug shouldn't be critical other than causing unnecessary iteration. Fix it. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-20driver: dont update dev_name via device_add pathKay Sievers
notice one system /proc/iomem some entries missed the name for pci_devices it turns that dev->dev.kobj name is changed after device_add. for pci code: via acpi_pci_root_driver.ops.add (aka acpi_pci_root_add) ==> pci_acpi_scan_root is used to scan pci bus/device, and at the same time we read the resource for pci_dev in the pci_read_bases, we have res->name = pci_name(pci_dev); pci_name is calling dev_name. later via acpi_pci_root_driver.ops.start (aka acpi_pci_root_start) ==> pci_bus_add_device to add all pci_dev in kobj tree. pci_bus_add_device will call device_add. actually in device_add /* first, register with generic layer. */ error = kobject_add(&dev->kobj, dev->kobj.parent, "%s", dev_name(dev)); if (error) goto Error; will get one new name for that kobj, old name is freed. [Impact: fix corrupted names in /proc/iomem ] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-16driver core: allow non-root users to listen to ueventsKay Sievers
Users can read sysfs files, there is no reason they should not be allowed to listen to uevents. This lets xorg and other userspace programs properly get these messages without having to be root. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-16Revert "kobject: don't block for each kobject_uevent".Hugh Dickins
This reverts commit f520360d93cdc37de5d972dac4bf3bdef6a7f6a7. Tetsuo Handa, running a kernel with CONFIG_DEBUG_PAGEALLOC=y and CONFIG_UEVENT_HELPER_PATH=/sbin/hotplug, has been hitting RCU detected CPU stalls: it's been spinning in the loop where do_execve() counts up the args (but why wasn't fixup_exception working? dunno). The recent change, switching kobject_uevent_env() from UMH_WAIT_EXEC to UMH_NO_WAIT, is broken: the exec uses args on the local stack here, and an env which is kfreed as soon as call_usermodehelper() returns. It very much needs to wait for the exec to be done. An alternative would be to keep the UMH_NO_WAIT, and complicate the code to allocate and free these resources correctly? but no, as GregKH pointed out when making the commit, CONFIG_UEVENT_HELPER_PATH="" is a much better optimization - though some distros are still saying /sbin/hotplug in their .config, yet with no such binary in their initrd or their root. Reported-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Signed-off-by: Hugh Dickins <hugh@veritas.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Will Newton <will.newton@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-12lockdep: warn about lockdep disabling after kernel taintFrederic Weisbecker
Impact: provide useful missing info for developers Kernel taint can occur in several situations such as warnings, load of prorietary or staging modules, bad page, etc... But when such taint happens, a developer might still be working on the kernel, expecting that lockdep is still enabled. But a taint disables lockdep without ever warning about it. Such a kernel behaviour doesn't really help for kernel development. This patch adds this missing warning. Since the taint is done most of the time after the main message that explain the real source issue, it seems safe to warn about it inside add_taint() so that it appears at last, without hurting the main information. v2: Use a generic helper to disable lockdep instead of an open coded xchg(). Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <1239412638-6739-1-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-08printk: fix wrong format string iter for printkZhaolei
printk("%Q"); Output before patch: %QQ Output after patch: %Q Signed-off-by: Zhao Lei <zhaolei@cn.fujitsu.com> Acked-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: torvalds@linux-foundation.org Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <49CC97B6.7040809@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-07Merge branch 'core/softlockup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core/softlockup' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: softlockup: make DETECT_HUNG_TASK default depend on DETECT_SOFTLOCKUP softlockup: move 'one' to the softlockup section in sysctl.c softlockup: ensure the task has been switched out once softlockup: remove timestamp checking from hung_task softlockup: convert read_lock in hung_task to rcu_read_lock softlockup: check all tasks in hung_task softlockup: remove unused definition for spawn_softlockup_task softlockup: fix potential race in hung_task when resetting timeout softlockup: fix to allow compiling with !DETECT_HUNG_TASK softlockup: decouple hung tasks check from softlockup detection
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Merge branch 'linus' into core/softlockupIngo Molnar
Conflicts: kernel/sysctl.c
2009-04-07softlockup: make DETECT_HUNG_TASK default depend on DETECT_SOFTLOCKUPIngo Molnar
Don't offer a default-y option when the user has turned off CONFIG_DETECT_SOFTLOCKUP already. Do offer it as 'y' only if DETECT_SOFTLOCKUP is on already. This makes it match previous behavior - where the hung-task check was embedded i CONFIG_DETECT_SOFTLOCKUP code. Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-06Merge branch 'kmemtrace-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'kmemtrace-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: kmemtrace: trace kfree() calls with NULL or zero-length objects kmemtrace: small cleanups kmemtrace: restore original tracing data binary format, improve ABI kmemtrace: kmemtrace_alloc() must fill type_id kmemtrace: use tracepoints kmemtrace, rcu: don't include unnecessary headers, allow kmemtrace w/ tracepoints kmemtrace, rcu: fix rcupreempt.c data structure dependencies kmemtrace, rcu: fix rcu_tree_trace.c data structure dependencies kmemtrace, rcu: fix linux/rcutree.h and linux/rcuclassic.h dependencies kmemtrace, mm: fix slab.h dependency problem in mm/failslab.c kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_unlzma.c kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_bunzip2.c kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_inflate.c kmemtrace, squashfs: fix slab.h dependency problem in squasfs kmemtrace, befs: fix slab.h dependency problem kmemtrace, security: fix linux/key.h header file dependencies kmemtrace, fs: fix linux/fdtable.h header file dependencies kmemtrace, fs: uninline simple_transaction_set() kmemtrace, fs, security: move alloc_secdata() and free_secdata() to linux/security.h
2009-04-05Merge branch 'core/debugobjects' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core/debugobjects' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: debugobjects: delay free of internal objects debugobjects: replace static objects when slab cache becomes available debug_objects: add boot-parameter toggle to turn object debugging off again
2009-04-05Merge branch 'printk-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'printk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: printk: correct the behavior of printk_timed_ratelimit() vsprintf: unify the format decoding layer for its 3 users, cleanup fix regression from "vsprintf: unify the format decoding layer for its 3 users" vsprintf: fix bug in negative value printing vsprintf: unify the format decoding layer for its 3 users vsprintf: add binary printf printk: introduce printk_once() Fix trivial conflicts (printk_once vs log_buf_kexec_setup() added near each other) in include/linux/kernel.h.
2009-04-03Merge branch 'locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: locking: rename trace_softirq_[enter|exit] => lockdep_softirq_[enter|exit] lockdep: remove duplicate CONFIG_DEBUG_LOCKDEP definitions lockdep: require framepointers for x86 lockdep: remove extra "irq" string lockdep: fix incorrect state name
2009-04-03kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_unlzma.cPekka Enberg
Impact: cleanup lib/decompress_unlzma.c depends on slab.h without including it: CC lib/decompress_unlzma.o lib/decompress_unlzma.c: In function ‘rc_free’: lib/decompress_unlzma.c:122: error: implicit declaration of function ‘kfree’ lib/decompress_unlzma.c: In function ‘unlzma’: lib/decompress_unlzma.c:551: error: implicit declaration of function ‘kmalloc’ lib/decompress_unlzma.c:551: warning: assignment makes pointer from integer without a cast make[1]: *** [lib/decompress_unlzma.o] Error 1 make: *** [lib/] Error 2 It gets included implicitly currently - but this will not be the case with upcoming kmemtrace changes. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> LKML-Reference: <1237886521.25315.58.camel@penberg-laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-03kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_bunzip2.cPekka Enberg
Impact: cleanup lib/decompress_bunzip2.c depends on slab.h without including it: CC lib/decompress_bunzip2.o lib/decompress_bunzip2.c: In function ‘start_bunzip’: lib/decompress_bunzip2.c:636: error: implicit declaration of function ‘kmalloc’ lib/decompress_bunzip2.c:636: warning: assignment makes pointer from integer without a cast lib/decompress_bunzip2.c: In function ‘bunzip2’: lib/decompress_bunzip2.c:682: warning: assignment makes pointer from integer without a cast lib/decompress_bunzip2.c:693: warning: assignment makes pointer from integer without a cast lib/decompress_bunzip2.c:726: error: implicit declaration of function ‘kfree’ make[1]: *** [lib/decompress_bunzip2.o] Error 1 make: *** [lib/] Error 2 It gets included implicitly currently - but this will not be the case with upcoming kmemtrace changes. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> LKML-Reference: <1237886032.25315.48.camel@penberg-laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-03kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_inflate.cPekka Enberg
Impact: fix build lib/decompress_inflate.c depends on slab.h without including it: CC lib/decompress_inflate.o lib/decompress_inflate.c: In function ‘gunzip’: lib/decompress_inflate.c:45: error: implicit declaration of function ‘kmalloc’ lib/decompress_inflate.c:45: warning: assignment makes pointer from integer without a cast lib/decompress_inflate.c:57: warning: assignment makes pointer from integer without a cast lib/decompress_inflate.c:65: warning: assignment makes pointer from integer without a cast lib/decompress_inflate.c:71: warning: assignment makes pointer from integer without a cast lib/decompress_inflate.c:154: error: implicit declaration of function ‘kfree’ make[1]: *** [lib/decompress_inflate.o] Error 1 make: *** [lib/] Error 2 It gets included implicitly currently - but this will not be the case with upcoming kmemtrace changes. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> LKML-Reference: <1237886030.25315.47.camel@penberg-laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-02cpumask: fix slab corruption caused by alloc_cpumask_var_node()Jack Steiner
Fix slab corruption caused by alloc_cpumask_var_node() overwriting the tail end of an off-stack cpumask. The function zeros out cpumask bits beyond the last possible cpu. The starting point for zeroing should be the beginning of the mask offset by a byte count derived from the number of possible cpus. The offset was calculated in bits instead of bytes. This resulted in overwriting the end of the cpumask. Signed-off-by: Jack Steiner <steiner@sgi.com> Acked-by: Mike Travis <travis.sgi.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: <stable@kernel.org> [2.6.29.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02cgroup: CSS ID supportKAMEZAWA Hiroyuki
Patch for Per-CSS(Cgroup Subsys State) ID and private hierarchy code. This patch attaches unique ID to each css and provides following. - css_lookup(subsys, id) returns pointer to struct cgroup_subysys_state of id. - css_get_next(subsys, id, rootid, depth, foundid) returns the next css under "root" by scanning When cgroup_subsys->use_id is set, an id for css is maintained. The cgroup framework only parepares - css_id of root css for subsys - id is automatically attached at creation of css. - id is *not* freed automatically. Because the cgroup framework don't know lifetime of cgroup_subsys_state. free_css_id() function is provided. This must be called by subsys. There are several reasons to develop this. - Saving space .... For example, memcg's swap_cgroup is array of pointers to cgroup. But it is not necessary to be very fast. By replacing pointers(8bytes per ent) to ID (2byes per ent), we can reduce much amount of memory usage. - Scanning without lock. CSS_ID provides "scan id under this ROOT" function. By this, scanning css under root can be written without locks. ex) do { rcu_read_lock(); next = cgroup_get_next(subsys, id, root, &found); /* check sanity of next here */ css_tryget(); rcu_read_unlock(); id = found + 1 } while(...) Characteristics: - Each css has unique ID under subsys. - Lifetime of ID is controlled by subsys. - css ID contains "ID" and "Depth in hierarchy" and stack of hierarchy - Allowed ID is 1-65535, ID 0 is UNUSED ID. Design Choices: - scan-by-ID v.s. scan-by-tree-walk. As /proc's pid scan does, scan-by-ID is robust when scanning is done by following kind of routine. scan -> rest a while(release a lock) -> conitunue from interrupted memcg's hierarchical reclaim does this. - When subsys->use_id is set, # of css in the system is limited to 65535. [bharata@linux.vnet.ibm.com: remove rcu_read_lock() from css_get_next()] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Bharata B Rao <bharata@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02Merge branch 'tracing/core-v2' into tracing-for-linusIngo Molnar
Conflicts: include/linux/slub_def.h lib/Kconfig.debug mm/slob.c mm/slub.c
2009-04-01lib/rbtree.c: optimize rb_erase()Wolfram Strepp
Tfour 4 redundant if-conditions in function __rb_erase_color() in lib/rbtree.c are removed. In pseudo-source-code, the structure of the code is as follows: if ((!A || B) && (!C || D)) { . . . } else { if (!C || D) {//if this is true, it implies: (A == true) && (B == false) if (A) {//hence this always evaluates to 'true'... . } . //at this point, C always becomes true, because of: __rb_rotate_right/left(); //and: other = parent->rb_right/left; } . . if (C) {//...and this too ! . } } Signed-off-by: Wolfram Strepp <wstrepp@gmx.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andrea Arcangeli <andrea@qumranet.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01generic debug pageallocAkinobu Mita
CONFIG_DEBUG_PAGEALLOC is now supported by x86, powerpc, sparc64, and s390. This patch implements it for the rest of the architectures by filling the pages with poison byte patterns after free_pages() and verifying the poison patterns before alloc_pages(). This generic one cannot detect invalid page accesses immediately but invalid read access may cause invalid dereference by poisoned memory and invalid write access can be detected after a long delay. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31Merge branch 'linus' into locking-for-linusIngo Molnar
Conflicts: lib/Kconfig.debug
2009-03-30dma-debug: fix printk formats (i386)Randy Dunlap
Fix printk format warnings in dma-debug: lib/dma-debug.c:645: warning: format '%016llx' expects type 'long long unsigned int', but argument 6 has type 'dma_addr_t' lib/dma-debug.c:662: warning: format '%016llx' expects type 'long long unsigned int', but argument 6 has type 'dma_addr_t' lib/dma-debug.c:676: warning: format '%016llx' expects type 'long long unsigned int', but argument 6 has type 'dma_addr_t' lib/dma-debug.c:686: warning: format '%016llx' expects type 'long long unsigned int', but argument 6 has type 'dma_addr_t' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30Merge branch 'iommu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'iommu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (60 commits) dma-debug: make memory range checks more consistent dma-debug: warn of unmapping an invalid dma address dma-debug: fix dma_debug_add_bus() definition for !CONFIG_DMA_API_DEBUG dma-debug/x86: register pci bus for dma-debug leak detection dma-debug: add a check dma memory leaks dma-debug: add checks for kernel text and rodata dma-debug: print stacktrace of mapping path on unmap error dma-debug: Documentation update dma-debug: x86 architecture bindings dma-debug: add function to dump dma mappings dma-debug: add checks for sync_single_sg_* dma-debug: add checks for sync_single_range_* dma-debug: add checks for sync_single_* dma-debug: add checking for [alloc|free]_coherent dma-debug: add add checking for map/unmap_sg dma-debug: add checking for map/unmap_page/single dma-debug: add core checking functions dma-debug: add debugfs interface dma-debug: add kernel command line parameters dma-debug: add initialization code ... Fix trivial conflicts due to whitespace changes in arch/x86/kernel/pci-nommu.c
2009-03-30Merge commit 'origin/master' into nextBenjamin Herrenschmidt
Manual merge of: arch/powerpc/include/asm/elf.h drivers/i2c/busses/i2c-mpc.c
2009-03-28Merge branch 'linus' into core/printkIngo Molnar
2009-03-28Merge branch 'linus' into core/iommuIngo Molnar
Conflicts: arch/x86/Kconfig
2009-03-28Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (422 commits) [ARM] 5435/1: fix compile warning in sanity_check_meminfo() [ARM] 5434/1: ARM: OMAP: Fix mailbox compile for 24xx [ARM] pxa: fix the bad assumption that PCMCIA sockets always start with 0 [ARM] pxa: fix Colibri PXA300 and PXA320 LCD backlight pins imxfb: Fix TFT mode i.MX21/27: remove ifdef CONFIG_FB_IMX imxfb: add clock support mxc: add arch_reset() function clkdev: add possibility to get a clock based on the device name i.MX1: remove fb support from mach-imx [ARM] pxa: build arch/arm/plat-pxa/mfp.c only when PXA3xx or ARCH_MMP defined Gemini: Add support for Teltonika RUT100 Gemini: gpiolib based GPIO support v2 MAINTAINERS: add myself as Gemini architecture maintainer ARM: Add Gemini architecture v3 [ARM] OMAP: Fix compile for omap2_init_common_hw() MAINTAINERS: Add myself as Faraday ARM core variant maintainer ARM: Add support for FA526 v2 [ARM] acorn,ebsa110,footbridge,integrator,sa1100: Convert asm/io.h to linux/io.h [ARM] collie: fix two minor formatting nits ...
2009-03-28Merge branch 'origin' into develRussell King
Conflicts: sound/soc/pxa/pxa2xx-i2s.c
2009-03-28Merge branch 'linus' into percpu-cpumask-x86-for-linus-2Ingo Molnar
Conflicts: arch/sparc/kernel/time_64.c drivers/gpu/drm/drm_proc.c Manual merge to resolve build warning due to phys_addr_t type change on x86: drivers/gpu/drm/drm_info.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-27Merge branch 'core/percpu' into percpu-cpumask-x86-for-linus-2Ingo Molnar
Conflicts: arch/parisc/kernel/irq.c arch/x86/include/asm/fixmap_64.h arch/x86/include/asm/setup.h kernel/irq/handle.c Semantic merge: arch/x86/include/asm/fixmap.h Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-26Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-next-2.6
2009-03-26Merge branch 'sched-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (46 commits) sched: Add comments to find_busiest_group() function sched: Refactor the power savings balance code sched: Optimize the !power_savings_balance during fbg() sched: Create a helper function to calculate imbalance sched: Create helper to calculate small_imbalance in fbg() sched: Create a helper function to calculate sched_domain stats for fbg() sched: Define structure to store the sched_domain statistics for fbg() sched: Create a helper function to calculate sched_group stats for fbg() sched: Define structure to store the sched_group statistics for fbg() sched: Fix indentations in find_busiest_group() using gotos sched: Simple helper functions for find_busiest_group() sched: remove unused fields from struct rq sched: jiffies not printed per CPU sched: small optimisation of can_migrate_task() sched: fix typos in documentation sched: add avg_overlap decay x86, sched_clock(): mark variables read-mostly sched: optimize ttwu vs group scheduling sched: TIF_NEED_RESCHED -> need_reshed() cleanup sched: don't rebalance if attached on NULL domain ...
2009-03-26Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: drivers/net/wimax/i2400m/usb-notif.c
2009-03-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (61 commits) Dynamic debug: fix pr_fmt() build error Dynamic debug: allow simple quoting of words dynamic debug: update docs dynamic debug: combine dprintk and dynamic printk sysfs: fix some bin_vm_ops errors kobject: don't block for each kobject_uevent sysfs: only allow one scheduled removal callback per kobj Driver core: Fix device_move() vs. dpm list ordering, v2 Driver core: some cleanup on drivers/base/sys.c Driver core: implement uevent suppress in kobject vcs: hook sysfs devices into object lifetime instead of "binding" driver core: fix passing platform_data driver core: move platform_data into platform_device sysfs: don't block indefinitely for unmapped files. driver core: move knode_bus into private structure driver core: move knode_driver into private structure driver core: move klist_children into private structure driver core: create a private portion of struct device driver core: remove polling for driver_probe_done(v5) sysfs: reference sysfs_dirent from sysfs inodes ... Fixed conflicts in drivers/sh/maple/maple.c manually
2009-03-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (29 commits) crypto: sha512-s390 - Add missing block size hwrng: timeriomem - Breaks an allyesconfig build on s390: nlattr: Fix build error with NET off crypto: testmgr - add zlib test crypto: zlib - New zlib crypto module, using pcomp crypto: testmgr - Add support for the pcomp interface crypto: compress - Add pcomp interface netlink: Move netlink attribute parsing support to lib crypto: Fix dead links hwrng: timeriomem - New driver crypto: chainiv - Use kcrypto_wq instead of keventd_wq crypto: cryptd - Per-CPU thread implementation based on kcrypto_wq crypto: api - Use dedicated workqueue for crypto subsystem crypto: testmgr - Test skciphers with no IVs crypto: aead - Avoid infinite loop when nivaead fails selftest crypto: skcipher - Avoid infinite loop when cipher fails selftest crypto: api - Fix crypto_alloc_tfm/create_create_tfm return convention crypto: api - crypto_alg_mod_lookup either tested or untested crypto: amcc - Add crypt4xx driver crypto: ansi_cprng - Add maintainer ...
2009-03-25Merge branch 'for-next' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 into devel
