commit 3715c5309f6d175c3053672b73fd4f73be16fd07 upstream.
When using ALT+SysRq+Q all the pointers are replaced with "pK-error" like
this:
[23153.208033] .base: pK-error
with echo h > /proc/sysrq-trigger it works:
[23107.776363] .base: ffff88023e60d540
The intent behind this behavior was to return "pK-error" in cases where
the %pK format specifier was used in interrupt context, because the
CAP_SYSLOG check wouldn't be meaningful. Clearly this should only apply
when kptr_restrict is actually enabled though.
Reported-by: Stevie Trujillo <stevie.trujillo@gmail.com>
Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull IOMMU fixes from Joerg Roedel:
"The patches fix several issues in the AMD IOMMU driver, the NVidia
SMMU driver, and the DMA debug code.
The most important fix for the AMD IOMMU solves a problem with SR-IOV
devices where virtual functions did not work with IOMMU enabled. The
NVidia SMMU patch fixes a possible sleep while spin-lock situation
(queued the small fix for v3.5, a better but more intrusive fix is
coming for v3.6). The DMA debug patches fix a possible data
corruption issue due to bool vs u32 usage."
* tag 'iommu-fixes-v3.5-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu:
iommu/amd: fix type bug in flush code
dma-debug: debugfs_create_bool() takes a u32 pointer
iommu/tegra: smmu: Fix unsleepable memory allocation
iommu/amd: Initialize dma_ops for hotplug and sriov devices
iommu/amd: Fix missing iommu_shutdown initialization in passthrough mode
Even though it has "bool" in the name, you have pass a u32 pointer to
debugfs_create_bool(). Otherwise you get memory corruption in
write_file_bool(). Fortunately in this case the corruption happens in
an alignment hole between variables so it doesn't cause any problems.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
After enabling CONFIG_FAILSLAB I noticed random32 in profiles even if slub
fault injection wasn't enabled at runtime.
should_fail forces a comparison against random32() even if probability is
0:
if (attr->probability <= random32() % 100)
return false;
Add a check up front for probability == 0 and avoid all of the more
complicated checks.
Acked-by: Akinobu Mita <akinobu.mita@gmail.com>
Pull core updates (RCU and locking) from Ingo Molnar:
"Most of the diffstat comes from the RCU slow boot regression fixes,
but there's also a debuggability improvements/fixes."
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
memblock: Document memblock_is_region_{memory,reserved}()
rcu: Precompute RCU_FAST_NO_HZ timer offsets
rcu: Move RCU_FAST_NO_HZ per-CPU variables to rcu_dynticks structure
rcu: Update RCU_FAST_NO_HZ tracing for lazy callbacks
rcu: RCU_FAST_NO_HZ detection of callback adoption
spinlock: Indicate that a lockup is only suspected
kdump: Execute kmsg_dump(KMSG_DUMP_PANIC) after smp_send_stop()
panic: Make panic_on_oops configurable
Storing NULL values in the btree is illegal and can lead to memory
corruption and possible other fun as well. Catch it on insert, instead
of waiting for the inevitable.
Signed-off-by: Joern Engel <joern@logfs.org>
Signed-off-by: Roland Dreier <roland@purestorage.com>
The memory the parameter __key points to is used as an iterator in
btree_get_prev(), so if we save off a bkey() pointer in retry_key and
then assign that to __key, we'll end up corrupting the btree internals
when we do eg
longcpy(__key, bkey(geo, node, i), geo->keylen);
to return the key value. What we should do instead is use longcpy() to
copy the key value that retry_key points to __key.
This can cause a btree to get corrupted by seemingly read-only
operations such as btree_for_each_safe.
[akpm@linux-foundation.org: avoid the double longcpy()]
Acked-by: Joern Engel <joern@logfs.org>
Cc: <stable@vger.kernel.org>
Pull two md fixes from NeilBrown:
"One sparse-warning fix, one bugfix for 3.4-stable"
* tag 'md-3.5-fixes' of git://neil.brown.name/md:
md: raid1/raid10: fix problem with merge_bvec_fn
lib/raid6: fix sparse warnings in recovery functions
On an over-committed KVM system we got a:
"BUG: spinlock lockup on CPU#2, swapper/2/0"
message on the heavily contended virtio blk spinlock.
While we might want to reconsider the locking of virtio-blk
(lock is held while switching to the host) this patch tries to
make the message clearer: the lockup is only suspected.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Michael S. Tsirkin <mst@redhat.com>
Link: http://lkml.kernel.org/r/1338283124-7063-1-git-send-email-borntraeger@de.ibm.com
Merge two debugging patchlets that were waiting for
preparatory commits to hit upstream.
This patch fixes bug in macro radix_tree_for_each_contig().
If radix_tree_next_slot() sees NULL in next slot it returns NULL, but following
radix_tree_next_chunk() switches iterating into next chunk. As result iterating
becomes non-contiguous and breaks vfs "splice" and all its users.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Reported-and-bisected-by: Hans de Bruin <jmdebruin@xmsnet.nl>
Reported-and-bisected-by: Ondrej Zary <linux@rainbow-software.org>
Reported-bisected-and-tested-by: Toralf Förster <toralf.foerster@gmx.de>
Link: https://lkml.org/lkml/2012/6/5/64
Cc: stable <stable@vger.kernel.org> # 3.4.x
Pull networking updates from David Miller:
1) Make syn floods consume significantly less resources by
a) Not pre-COW'ing routing metrics for SYN/ACKs
b) Mirroring the device queue mapping of the SYN for the SYN/ACK
reply.
Both from Eric Dumazet.
2) Fix calculation errors in Byte Queue Limiting, from Hiroaki SHIMODA.
3) Validate the length requested when building a paged SKB for a
socket, so we don't overrun the page vector accidently. From Jason
Wang.
4) When netlabel is disabled, we abort all IP option processing when we
see a CIPSO option. This isn't the right thing to do, we should
simply skip over it and continue processing the remaining options
(if any). Fix from Paul Moore.
5) SRIOV fixes for the mellanox driver from Jack orgenstein and Marcel
Apfelbaum.
6) 8139cp enables the receiver before the ring address is properly
programmed, which potentially lets the device crap over random
memory. Fix from Jason Wang.
7) e1000/e1000e fixes for i217 RST handling, and an improper buffer
address reference in jumbo RX frame processing from Bruce Allan and
Sebastian Andrzej Siewior, respectively.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net:
fec_mpc52xx: fix timestamp filtering
mcs7830: Implement link state detection
e1000e: fix Rapid Start Technology support for i217
e1000: look into the page instead of skb->data for e1000_tbi_adjust_stats()
r8169: call netif_napi_del at errpaths and at driver unload
tcp: reflect SYN queue_mapping into SYNACK packets
tcp: do not create inetpeer on SYNACK message
8139cp/8139too: terminate the eeprom access with the right opmode
8139cp: set ring address before enabling receiver
cipso: handle CIPSO options correctly when NetLabel is disabled
net: sock: validate data_len before allocating skb in sock_alloc_send_pskb()
bql: Avoid possible inconsistent calculation.
bql: Avoid unneeded limit decrement.
bql: Fix POSDIFF() to integer overflow aware.
net/mlx4_core: Fix obscure mlx4_cmd_box parameter in QUERY_DEV_CAP
net/mlx4_core: Check port out-of-range before using in mlx4_slave_cap
net/mlx4_core: Fixes for VF / Guest startup flow
net/mlx4_en: Fix improper use of "port" parameter in mlx4_en_event
net/mlx4_core: Fix number of EQs used in ICM initialisation
net/mlx4_core: Fix the slave_id out-of-range test in mlx4_eq_int
Merge misc patches from Andrew Morton:
- the "misc" tree - stuff from all over the map
- checkpatch updates
- fatfs
- kmod changes
- procfs
- cpumask
- UML
- kexec
- mqueue
- rapidio
- pidns
- some checkpoint-restore feature work. Reluctantly. Most of it
delayed a release. I'm still rather worried that we don't have a
clear roadmap to completion for this work.
* emailed from Andrew Morton <akpm@linux-foundation.org>: (78 patches)
kconfig: update compression algorithm info
c/r: prctl: add ability to set new mm_struct::exe_file
c/r: prctl: extend PR_SET_MM to set up more mm_struct entries
c/r: procfs: add arg_start/end, env_start/end and exit_code members to /proc/$pid/stat
syscalls, x86: add __NR_kcmp syscall
fs, proc: introduce /proc/<pid>/task/<tid>/children entry
sysctl: make kernel.ns_last_pid control dependent on CHECKPOINT_RESTORE
aio/vfs: cleanup of rw_copy_check_uvector() and compat_rw_copy_check_uvector()
eventfd: change int to __u64 in eventfd_signal()
fs/nls: add Apple NLS
pidns: make killed children autoreap
pidns: use task_active_pid_ns in do_notify_parent
rapidio/tsi721: add DMA engine support
rapidio: add DMA engine support for RIO data transfers
ipc/mqueue: add rbtree node caching support
tools/selftests: add mq_perf_tests
ipc/mqueue: strengthen checks on mqueue creation
ipc/mqueue: correct mq_attr_ok test
ipc/mqueue: improve performance of send/recv
selftests: add mq_open_tests
Previous code was using optimizations which were developed to work well
even on narrow-word CPUs (by today's standards). But Linux runs only on
32-bit and wider CPUs. We can use that.
First: using 32x32->64 multiply and trivial 32-bit shift, we can correctly
divide by 10 much larger numbers, and thus we can print groups of 9 digits
instead of groups of 5 digits.
Next: there are two algorithms to print larger numbers. One is generic:
divide by 1000000000 and repeatedly print groups of (up to) 9 digits.
It's conceptually simple, but requires an (unsigned long long) /
1000000000 division.
Second algorithm splits 64-bit unsigned long long into 16-bit chunks,
manipulates them cleverly and generates groups of 4 decimal digits. It so
happens that it does NOT require long long division.
If long is > 32 bits, division of 64-bit values is relatively easy, and we
will use the first algorithm. If long long is > 64 bits (strange
architecture with VERY large long long), second algorithm can't be used,
and we again use the first one.
Else (if long is 32 bits and long long is 64 bits) we use second one.
And third: there is a simple optimization which takes fast path not only
for zero as was done before, but for all one-digit numbers.
In all tested cases new code is faster than old one, in many cases by 30%,
in few cases by more than 50% (for example, on x86-32, conversion of
12345678). Code growth is ~0 in 32-bit case and ~130 bytes in 64-bit
case.
This patch is based upon an original from Michal Nazarewicz.
[akpm@linux-foundation.org: checkpatch fixes]
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com>
Cc: Douglas W Jones <jones@cs.uiowa.edu>
The '%p' output of the kernel's vsprintf() uses spec.field_width to
determine how many digits to output based on 2 * sizeof(void*) so that all
digits of a pointer are shown. ie. a pointer will be output as
"001A2B3C" instead of "1A2B3C". However, if the '#' flag is used in the
format (%#p), then the code doesn't take into account the width of the
'0x' prefix and will end up outputing "0x1A2B3C" instead of "0x001A2B3C".
This patch reworks the "pointer()" format hook to include 2 characters for
the '0x' prefix if the '#' flag is included.
dql->num_queued could change while processing dql_completed().
To provide consistent calculation, added an on stack variable.
Signed-off-by: Hiroaki SHIMODA <shimoda.hiroaki@gmail.com>
Cc: Tom Herbert <therbert@google.com>
Cc: Denys Fedoryshchenko <denys@visp.net.lb>
When below pattern is observed,
TIME
dql_queued() dql_completed() |
a) initial state |
b) X bytes queued V
c) Y bytes queued
d) X bytes completed
e) Z bytes queued
f) Y bytes completed
a) dql->limit has already some value and there is no in-flight packet.
b) X bytes queued.
c) Y bytes queued and excess limit.
d) X bytes completed and dql->prev_ovlimit is set and also
dql->prev_num_queued is set Y.
e) Z bytes queued.
f) Y bytes completed. inprogress and prev_inprogress are true.
At f), according to the comment, all_prev_completed becomes
true and limit should be increased. But POSDIFF() ignores
(completed == dql->prev_num_queued) case, so limit is decreased.
POSDIFF() fails to take into account integer overflow case.
Pull IOMMU updates from Joerg Roedel:
"Not much stuff this time. The only change to the IOMMU core code is
the addition of a handle to the fault handling code. A few updates to
the AMD IOMMU driver to work around new errata. The other patches are
mostly fixes and enhancements to the existing ARM IOMMU drivers and
documentation updates.
A new IOMMU driver for the Exynos platform was also underway but got
merged via the Samsung tree and is not part of this tree."
* tag 'iommu-updates-v3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu:
Documentation: kernel-parameters.txt Add amd_iommu_dump
iommu/core: pass a user-provided token to fault handlers
iommu/tegra: gart: Fix register offset correctly
iommu: OMAP: device detach on domain destroy
iommu: tegra/gart: Add device tree support
iommu: tegra/gart: use correct gart_device
iommu/tegra: smmu: Print device name correctly
iommu/amd: Add workaround for event log erratum
iommu/amd: Check for the right TLP prefix bit
dma-debug: release free_entries_lock before saving stack trace
and 'x86/amd' into next
number()'s behaviour is slighly changed: 0 becomes "0" instead of "00"
when using the flag SPECIAL and base 8.
Before:
Number\Format %o %#o %x %#x
0 0 00 0 0x0
1 1 01 1 0x1
16 20 020 10 0x10
After:
0 0 0 0 0x0
1 1 01 1 0x1
16 20 020 10 0x10
Signed-off-by: Pierre Carrier <pierre@spotify.com>
Acked-by: Stephen Rothwell <sfr@canb.auug.org.au>
Cc: Joe Perches <joe@perches.com>
We are not preallocating a sufficient number of nodes.
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
When a spinlock warning is printed we usually get
BUG: spinlock bad magic on CPU#0, modprobe/111
lock: 0xdff09f38, .magic: 00000000, .owner: /0, .owner_cpu: 0
but it's nicer to print the symbol for the lock if we have it so that we
can avoid 'grep dff09f38 /proc/kallsyms' to find out which lock it was.
Use kallsyms to print the symbol name so we get something a bit easier to
read
BUG: spinlock bad magic on CPU#0, modprobe/112
lock: test_lock, .magic: 00000000, .owner: <none>/-1, .owner_cpu: 0
If the lock is not in kallsyms %ps will fall back to printing the address
directly.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Using %ps in a printk format will sometimes fail silently and print the
empty string if the address passed in does not match a symbol that
kallsyms knows about. But using %pS will fall back to printing the full
address if kallsyms can't find the symbol. Make %ps act the same as %pS
by falling back to printing the address.
While we're here also make %ps print the module that a symbol comes from
so that it matches what %pS already does. Take this simple function for
example (in a module):
static void test_printk(void)
int test;
pr_info("with pS: %pS\n", &test);
pr_info("with ps: %ps\n", &test);
Before this patch:
with pS: 0xdff7df44
with ps:
After this patch:
with pS: 0xdff7df44
with ps: 0xdff7df44
The code comments for bscnl_emit() and bitmap_scnlistprintf() are
describing snprintf() return semantics, but these functions use
scnprintf() return semantics. Fix that, and document the
bitmap_scnprintf() return value as well.
Cc: Ryota Ozaki <ozaki.ryota@gmail.com>
Moving these arrays into static storage shrinks the kernel a bit:
723 112 64 899 383 lib/string_helpers.o
516 272 64 852 354 lib/string_helpers.o
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
As long as there is no other non-const variable marked __initdata in the
same compilation unit it doesn't hurt. If there were one however
compilation would fail with
error: $variablename causes a section type conflict
because a section containing const variables is marked read only and so
cannot contain non-const variables.
Cc: Alexey Dobriyan <adobriyan@gmail.com>
We were bitten by this at one point and added an additional sanity test
for DEBUG_LIST. You can't validly add a list_head to a list where either
prev or next is the same as the thing you're adding.
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
Print swiotlb info in a style consistent with the %pR style used elsewhere
in the kernel. For example:
-Placing 64MB software IO TLB between ffff88007a662000 - ffff88007e662000
-software IO TLB at phys 0x7a662000 - 0x7e662000
+software IO TLB [mem 0x7a662000-0x7e661fff] (64MB) mapped at [ffff88007a662000-ffff88007e661fff]
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Make the recovery functions static to fix the following sparse warnings:
lib/raid6/recov.c:25:6: warning: symbol 'raid6_2data_recov_intx1' was
not declared. Should it be static?
lib/raid6/recov.c:69:6: warning: symbol 'raid6_datap_recov_intx1' was
lib/raid6/recov_ssse3.c:22:6: warning: symbol 'raid6_2data_recov_ssse3'
was not declared. Should it be static?
lib/raid6/recov_ssse3.c:197:6: warning: symbol 'raid6_datap_recov_ssse3'
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Jim Kukunas <james.t.kukunas@linux.intel.com>
Signed-off-by: NeilBrown <neilb@suse.de>
The aligned_byte_mask() definition is wrong for 32-bit big-endian
machines: the "7-(n)" part of the definition assumes a long is 8
bytes. This fixes it by using BITS_PER_LONG - 8 instead of 8*7.
Tested on 32-bit and 64-bit PowerPC.
This makes <asm/word-at-a-time.h> actually live up to its promise of
allowing architectures to help tune the string functions that do their
work a word at a time.
David had already taken the x86 strncpy_from_user() function, modified
it to work on sparc, and then done the extra work to make it generically
useful. This then expands on that work by making x86 use that generic
version, completing the circle.
But more importantly, it fixes up the word-at-a-time interfaces so that
it's now easy to also support things like strnlen_user(), and pretty
much most random string functions.
David reports that it all works fine on sparc, and Jonas Bonn reported
that an earlier version of this worked on OpenRISC too. It's pretty
easy for architectures to add support for this and just replace their
private versions with the generic code.
* generic-string-functions:
sparc: use the new generic strnlen_user() function
x86: use the new generic strnlen_user() function
lib: add generic strnlen_user() function
word-at-a-time: make the interfaces truly generic
x86: use generic strncpy_from_user routine
Pull arm-soc stmp-dev library code from Olof Johansson:
"A number of devices are using a common register layout, this adds
support code for it in lib/stmp_device.c so we do not need to
duplicate it in each driver."
Fix up trivial conflicts in drivers/i2c/busses/i2c-mxs.c and
lib/Makefile
* tag 'stmp-dev' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
i2c: mxs: use global reset function
lib: add support for stmp-style devices
This adds a new generic optimized strnlen_user() function that uses the
<asm/word-at-a-time.h> infrastructure to portably do efficient string
handling.
In many ways, strnlen is much simpler than strncpy, and in particular we
can always pre-align the words we load from memory. That means that all
the worries about alignment etc are a non-issue, so this one can easily
be used on any architecture. You obviously do have to do the
appropriate word-at-a-time.h macros.
This changes the interfaces in <asm/word-at-a-time.h> to be a bit more
complicated, but a lot more generic.
In particular, it allows us to really do the operations efficiently on
both little-endian and big-endian machines, pretty much regardless of
machine details. For example, if you can rely on a fast population
count instruction on your architecture, this will allow you to make your
optimized <asm/word-at-a-time.h> file with that.
NOTE! The "generic" version in include/asm-generic/word-at-a-time.h is
not truly generic, it actually only works on big-endian. Why? Because
on little-endian the generic algorithms are wasteful, since you can
inevitably do better. The x86 implementation is an example of that.
(The only truly non-generic part of the asm-generic implementation is
the "find_zero()" function, and you could make a little-endian version
of it. And if the Kbuild infrastructure allowed us to pick a particular
header file, that would be lovely)
The <asm/word-at-a-time.h> functions are as follows:
- WORD_AT_A_TIME_CONSTANTS: specific constants that the algorithm
uses.
- has_zero(): take a word, and determine if it has a zero byte in it.
It gets the word, the pointer to the constant pool, and a pointer to
an intermediate "data" field it can set.
This is the "quick-and-dirty" zero tester: it's what is run inside
the hot loops.
- "prep_zero_mask()": take the word, the data that has_zero() produced,
and the constant pool, and generate an *exact* mask of which byte had
the first zero. This is run directly *outside* the loop, and allows
the "has_zero()" function to answer the "is there a zero byte"
question without necessarily getting exactly *which* byte is the
first one to contain a zero.
If you do multiple byte lookups concurrently (eg "hash_name()", which
looks for both NUL and '/' bytes), after you've done the prep_zero_mask()
phase, the result of those can be or'ed together to get the "either
or" case.
- The result from "prep_zero_mask()" can then be fed into "find_zero()"
(to find the byte offset of the first byte that was zero) or into
"zero_bytemask()" (to find the bytemask of the bytes preceding the
zero byte).
The existence of zero_bytemask() is optional, and is not necessary
for the normal string routines. But dentry name hashing needs it, so
if you enable DENTRY_WORD_AT_A_TIME you need to expose it.
This changes the generic strncpy_from_user() function and the dentry
hashing functions to use these modified word-at-a-time interfaces. This
gets us back to the optimized state of the x86 strncpy that we lost in
the previous commit when moving over to the generic version.
Pull sparc changes from David S. Miller:
"This has the generic strncpy_from_user() implementation architectures
can now use, which we've been developing on linux-arch over the past
few days.
For good measure I ran both a 32-bit and a 64-bit glibc testsuite run,
and the latter of which pointed out an adjustment I needed to make to
sparc's user_addr_max() definition. Linus, you were right, STACK_TOP
was not the right thing to use, even on sparc itself :-)
From Sam Ravnborg, we have a conversion of sparc32 over to the common
alloc_thread_info_node(), since the aspect which originally blocked
our doing so (sun4c) has been removed."
Fix up trivial arch/sparc/Kconfig and lib/Makefile conflicts.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc:
sparc: Fix user_addr_max() definition.
lib: Sparc's strncpy_from_user is generic enough, move under lib/
kernel: Move REPEAT_BYTE definition into linux/kernel.h
sparc: Increase portability of strncpy_from_user() implementation.
sparc: Optimize strncpy_from_user() zero byte search.
sparc: Add full proper error handling to strncpy_from_user().
sparc32: use the common implementation of alloc_thread_info_node()
To use this, an architecture simply needs to:
1) Provide a user_addr_max() implementation via asm/uaccess.h
2) Add "select GENERIC_STRNCPY_FROM_USER" to their arch Kcnfig
3) Remove the existing strncpy_from_user() implementation and symbol
exports their architecture had.
Pull md updates from NeilBrown:
"It's been a busy cycle for md - lots of fun stuff here.. if you like
this kind of thing :-)
Main features:
- RAID10 arrays can be reshaped - adding and removing devices and
changing chunks (not 'far' array though)
- allow RAID5 arrays to be reshaped with a backup file (not tested
yet, but the priciple works fine for RAID10).
- arrays can be reshaped while a bitmap is present - you no longer
need to remove it first
- SSSE3 support for RAID6 syndrome calculations
and of course a number of minor fixes etc."
* tag 'md-3.5' of git://neil.brown.name/md: (56 commits)
md/bitmap: record the space available for the bitmap in the superblock.
md/raid10: Remove extras after reshape to smaller number of devices.
md/raid5: improve removal of extra devices after reshape.
md: check the return of mddev_find()
MD RAID1: Further conditionalize 'fullsync'
DM RAID: Use md_error() in place of simply setting Faulty bit
DM RAID: Record and handle missing devices
DM RAID: Set recovery flags on resume
md/raid5: Allow reshape while a bitmap is present.
md/raid10: resize bitmap when required during reshape.
md: allow array to be resized while bitmap is present.
md/bitmap: make sure reshape request are reflected in superblock.
md/bitmap: add bitmap_resize function to allow bitmap resizing.
md/bitmap: use DIV_ROUND_UP instead of open-code
md/bitmap: create a 'struct bitmap_counts' substructure of 'struct bitmap'
md/bitmap: make bitmap bitops atomic.
md/bitmap: make _page_attr bitops atomic.
md/bitmap: merge bitmap_file_unmap and bitmap_file_put.
md/bitmap: remove async freeing of bitmap file.
md/bitmap: convert some spin_lock_irqsave to spin_lock_irq
'x86-cpu-for-linus', 'x86-debug-for-linus' and 'x86-microcode-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip
Pull initial trivial x86 stuff from Ingo Molnar.
Various random cleanups and trivial fixes.
* 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86-64: Eliminate dead ia32 syscall handlers
* 'x86-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/pci-calgary_64.c: Remove obsoleted simple_strtoul() usage
x86: Don't continue booting if we can't load the specified initrd
x86: kernel/dumpstack.c simple_strtoul cleanup
x86: kernel/check.c simple_strtoul cleanup
debug: Add CONFIG_READABLE_ASM
x86: spinlock.h: Remove REG_PTR_MODE
* 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/cache_info: Fix setup of l2/l3 ids
* 'x86-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86: Avoid double stack traces with show_regs()
* 'x86-microcode-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, microcode: microcode_core.c simple_strtoul cleanup
Pull trivial updates from Jiri Kosina:
"As usual, it's mostly typo fixes, redundant code elimination and some
documentation updates."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (57 commits)
edac, mips: don't change code that has been removed in edac/mips tree
xtensa: Change mail addresses of Hannes Weiner and Oskar Schirmer
lib: Change mail address of Oskar Schirmer
net: Change mail address of Oskar Schirmer
arm/m68k: Change mail address of Sebastian Hess
i2c: Change mail address of Oskar Schirmer
net: Fix tcp_build_and_update_options comment in struct tcp_sock
atomic64_32.h: fix parameter naming mismatch
Kconfig: replace "--- help ---" with "---help---"
c2port: fix bogus Kconfig "default no"
edac: Fix spelling errors.
qla1280: Remove redundant NULL check before release_firmware() call
remoteproc: remove redundant NULL check before release_firmware()
qla2xxx: Remove redundant NULL check before release_firmware() call.
aic94xx: Get rid of redundant NULL check before release_firmware() call
tehuti: delete redundant NULL check before release_firmware()
qlogic: get rid of a redundant test for NULL before call to release_firmware()
bna: remove redundant NULL test before release_firmware()
tg3: remove redundant NULL test before release_firmware() call
typhoon: get rid of redundant conditional before all to release_firmware()
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core updates from Greg Kroah-Hartman:
"Here's the driver core, and other driver subsystems, pull request for
the 3.5-rc1 merge window.
Outside of a few minor driver core changes, we ended up with the
following different subsystem and core changes as well, due to
interdependancies on the driver core:
- hyperv driver updates
- drivers/memory being created and some drivers moved into it
- extcon driver subsystem created out of the old Android staging
switch driver code
- dynamic debug updates
- printk rework, and /dev/kmsg changes
All of this has been tested in the linux-next releases for a few weeks
with no reported problems.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
Fix up conflicts in drivers/extcon/extcon-max8997.c where git noticed
that a patch to the deleted drivers/misc/max8997-muic.c driver needs to
be applied to this one.
* tag 'driver-core-3.5-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (90 commits)
uio_pdrv_genirq: get irq through platform resource if not set otherwise
memory: tegra{20,30}-mc: Remove empty *_remove()
printk() - isolate KERN_CONT users from ordinary complete lines
sysfs: get rid of some lockdep false positives
Drivers: hv: util: Properly handle version negotiations.
Drivers: hv: Get rid of an unnecessary check in vmbus_prep_negotiate_resp()
memory: tegra{20,30}-mc: Use dev_err_ratelimited()
driver core: Add dev_*_ratelimited() family
Driver Core: don't oops with unregistered driver in driver_find_device()
printk() - restore prefix/timestamp printing for multi-newline strings
printk: add stub for prepend_timestamp()
ARM: tegra30: Make MC optional in Kconfig
ARM: tegra20: Make MC optional in Kconfig
ARM: tegra30: MC: Remove unnecessary BUG*()
ARM: tegra20: MC: Remove unnecessary BUG*()
printk: correctly align __log_buf
ARM: tegra30: Add Tegra Memory Controller(MC) driver
ARM: tegra20: Add Tegra Memory Controller(MC) driver
printk() - restore timestamp printing at console output
printk() - do not merge continuation lines of different threads
Reorders functions in raid6_algos as well as the preference check
to reduce the number of functions tested on initialization.
Also, creates symmetry between choosing the gen_syndrome functions
and choosing the recovery functions.
Test each combination of recovery and syndrome generation
functions.
Add SSSE3 optimized recovery functions, as well as a system
for selecting the most appropriate recovery functions to use.
Originally-by: H. Peter Anvin <hpa@zytor.com>
<linux/module.h> drags in headers which are not visible to userspace,
thus breaking the build for the test program.
Pull RCU changes from Ingo Molnar:
"This is the v3.5 RCU tree from Paul E. McKenney:
1) A set of improvements and fixes to the RCU_FAST_NO_HZ feature (with
more on the way for 3.6). Posted to LKML:
https://lkml.org/lkml/2012/4/23/324 (commits 1-3 and 5),
https://lkml.org/lkml/2012/4/16/611 (commit 4),
https://lkml.org/lkml/2012/4/30/390 (commit 6), and
https://lkml.org/lkml/2012/5/4/410 (commit 7, combined with
the other commits for the convenience of the tester).
2) Changes to make rcu_barrier() avoid disrupting execution of CPUs
that have no RCU callbacks. Posted to LKML:
https://lkml.org/lkml/2012/4/23/322.
3) A couple of commits that improve the efficiency of the interaction
between preemptible RCU and the scheduler, these two being all that
survived an abortive attempt to allow preemptible RCU's
__rcu_read_lock() to be inlined. The full set was posted to LKML at
https://lkml.org/lkml/2012/4/14/143, and the first and third patches
of that set remain.
4) Lai Jiangshan's algorithmic implementation of SRCU, which includes
call_srcu() and srcu_barrier(). A major feature of this new
implementation is that synchronize_srcu() no longer disturbs the
execution of other CPUs. This work is based on earlier
implementations by Peter Zijlstra and Paul E. McKenney. Posted to
LKML: https://lkml.org/lkml/2012/2/22/82.
5) A number of miscellaneous bug fixes and improvements which were
posted to LKML at: https://lkml.org/lkml/2012/4/23/353 with
subsequent updates posted to LKML."
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (32 commits)
rcu: Make rcu_barrier() less disruptive
rcu: Explicitly initialize RCU_FAST_NO_HZ per-CPU variables
rcu: Make RCU_FAST_NO_HZ handle timer migration
rcu: Update RCU maintainership
rcu: Make exit_rcu() more precise and consolidate
rcu: Move PREEMPT_RCU preemption to switch_to() invocation
rcu: Ensure that RCU_FAST_NO_HZ timers expire on correct CPU
rcu: Add rcutorture test for call_srcu()
rcu: Implement per-domain single-threaded call_srcu() state machine
rcu: Use single value to handle expedited SRCU grace periods
rcu: Improve srcu_readers_active_idx()'s cache locality
rcu: Remove unused srcu_barrier()
rcu: Implement a variant of Peter's SRCU algorithm
rcu: Improve SRCU's wait_idx() comments
rcu: Flip ->completed only once per SRCU grace period
rcu: Increment upper bit only for srcu_read_lock()
rcu: Remove fast check path from __synchronize_srcu()
rcu: Direct algorithmic SRCU implementation
rcu: Introduce rcutorture testing for rcu_barrier()
timer: Fix mod_timer_pinned() header comment
Pull core/debugobjects changes from Ingo Molnar:
"Not much happened: it includes a cleanup and an irq latency reduction
fixlet."
* 'core-debugobjects-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
debugobjects: Fill_pool() returns void now
debugobjects: printk with irqs enabled
debugobjects: Remove unused return value from fill_pool()
That old mail address doesnt exist any more.
This changes all occurences to my new address.
Signed-off-by: Oskar Schirmer <oskar@scara.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
The output of the timestamps got lost with the conversion of the
kmsg buffer to records; restore the old behavior.
Document, that CONFIG_PRINTK_TIME now only controls the output of
the timestamps in the syslog() system call and on the console, and
not the recording of the timestamps.
Cc: Sasha Levin <levinsasha928@gmail.com>
Reported-by: Yinghai Lu <yinghai@kernel.org>
Signed-off-by: Kay Sievers <kay@vrfy.org>
Signed-off-by: Zhi Yong Wu <wuzhy@linux.vnet.ibm.com>
