path: root/lib
2011-06-03lib: cordic: add library module providing cordic angle calculationArend van Spriel
The brcm80211 driver in the staging tree has a cordic function to determine cosine and sine for a given angle. Feedback received from John Linville suggested that these kind of functions should be made available to others as a library function in the kernel tree. The b43 driver also has a cordic angle calculation implemented. Cc: linux-kernel@vger.kernel.org Cc: linux-wireless@vger.kernel.org Cc: "John W. Linville" <linville@tuxdriver.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Dan Carpenter <error27@gmail.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Larry Finger <Larry.Finger@lwfinger.net> Reviewed-by: Roland Vossen <rvossen@broadcom.com> Reviewed-by: Henry Ptasinski <henryp@broadcom.com> Reviewed-by: Franky (Zhenhui) Lin <frankyl@broadcom.com> Signed-off-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-03lib: crc8: add new library module providing crc8 algorithmArend van Spriel
The brcm80211 driver in staging tree uses a crc8 function. Based on feedback from John Linville to move this to lib directory, the linux source has been searched. Although there is currently only one other kernel driver using this algorithm (ie. drivers/ssb) we are providing this as a library function for others to use. Cc: linux-kernel@vger.kernel.org Cc: linux-wireless@vger.kernel.org Cc: Dan Carpenter <error27@gmail.com> Cc: George Spelvin <linux@horizon.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Reviewed-by: Henry Ptasinski <henryp@broadcom.com> Reviewed-by: Roland Vossen <rvossen@broadcom.com> Reviewed-by: "Franky (Zhenhui) Lin" <frankyl@broadcom.com> Signed-off-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
2011-05-19Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (78 commits) Revert "rcu: Decrease memory-barrier usage based on semi-formal proof" net,rcu: convert call_rcu(prl_entry_destroy_rcu) to kfree batman,rcu: convert call_rcu(softif_neigh_free_rcu) to kfree_rcu batman,rcu: convert call_rcu(neigh_node_free_rcu) to kfree() batman,rcu: convert call_rcu(gw_node_free_rcu) to kfree_rcu net,rcu: convert call_rcu(kfree_tid_tx) to kfree_rcu() net,rcu: convert call_rcu(xt_osf_finger_free_rcu) to kfree_rcu() net/mac80211,rcu: convert call_rcu(work_free_rcu) to kfree_rcu() net,rcu: convert call_rcu(wq_free_rcu) to kfree_rcu() net,rcu: convert call_rcu(phonet_device_rcu_free) to kfree_rcu() perf,rcu: convert call_rcu(swevent_hlist_release_rcu) to kfree_rcu() perf,rcu: convert call_rcu(free_ctx) to kfree_rcu() net,rcu: convert call_rcu(__nf_ct_ext_free_rcu) to kfree_rcu() net,rcu: convert call_rcu(net_generic_release) to kfree_rcu() net,rcu: convert call_rcu(netlbl_unlhsh_free_addr6) to kfree_rcu() net,rcu: convert call_rcu(netlbl_unlhsh_free_addr4) to kfree_rcu() security,rcu: convert call_rcu(sel_netif_free) to kfree_rcu() net,rcu: convert call_rcu(xps_dev_maps_release) to kfree_rcu() net,rcu: convert call_rcu(xps_map_release) to kfree_rcu() net,rcu: convert call_rcu(rps_map_release) to kfree_rcu() ...
2011-05-19Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: seqlock: Don't smp_rmb in seqlock reader spin loop watchdog, hung_task_timeout: Add Kconfig configurable default lockdep: Remove cmpxchg to update nr_chain_hlocks lockdep: Print a nicer description for simple irq lock inversions lockdep: Replace "Bad BFS generated tree" message with something less cryptic lockdep: Print a nicer description for irq inversion bugs lockdep: Print a nicer description for simple deadlocks lockdep: Print a nicer description for normal deadlocks lockdep: Print a nicer description for irq lock inversions
2011-05-19Merge branch 'core-iommu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-iommu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, gart: Rename pci-gart_64.c to amd_gart_64.c x86/amd-iommu: Use threaded interupt handler arch/x86/kernel/pci-iommu_table.c: Convert sprintf_symbol to %pS x86/amd-iommu: Add support for invalidate_all command x86/amd-iommu: Add extended feature detection x86/amd-iommu: Add ATS enable/disable code x86/amd-iommu: Add flag to indicate IOTLB support x86/amd-iommu: Flush device IOTLB if ATS is enabled x86/amd-iommu: Select PCI_IOV with AMD IOMMU driver PCI: Move ATS declarations in seperate header file dma-debug: print information about leaked entry x86/amd-iommu: Flush all internal TLBs when IOMMUs are enabled x86/amd-iommu: Rename iommu_flush_device x86/amd-iommu: Improve handling of full command buffer x86/amd-iommu: Rename iommu_flush* to domain_flush* x86/amd-iommu: Remove command buffer resetting logic x86/amd-iommu: Cleanup completion-wait handling x86/amd-iommu: Cleanup inv_pages command handling x86/amd-iommu: Move inv-dte command building to own function x86/amd-iommu: Move compl-wait command building to own function
2011-05-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-2.6-cm * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-2.6-cm: kmemleak: Initialise kmemleak after debug_objects_mem_init() kmemleak: Select DEBUG_FS unconditionally in DEBUG_KMEMLEAK kmemleak: Do not return a pointer to an object that kmemleak did not get
2011-05-19Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus: (48 commits) MIPS: Move arch_get_unmapped_area and gang to new file. MIPS: Cleanup arch_get_unmapped_area MIPS: Octeon: Don't request interrupts for unused IPI mailbox bits. Octeon: Fix interrupt irq settings for performance counters. MIPS: Fix build warnings on defconfigs MIPS: Lemote 2F, Malta: Fix build warning MIPS: Set ELF AT_PLATFORM string for Loongson2 processors MIPS: Set ELF AT_PLATFORM string for BMIPS processors MIPS: Introduce set_elf_platform() helper function MIPS: JZ4740: setup: Autodetect physical memory. MIPS: BCM47xx: Fix MAC address parsing. MIPS: BCM47xx: Extend the filling of SPROM from NVRAM MIPS: BCM47xx: Register SSB fallback sprom callback MIPS: BCM47xx: Extend bcm47xx_fill_sprom with prefix. SSB: Change fallback sprom to callback mechanism. MIPS: Alchemy: Clean up GPIO registers and accessors MIPS: Alchemy: Cleanup DMA addresses MIPS: Alchemy: Rewrite ethernet platform setup MIPS: Alchemy: Rewrite UART setup and constants. MIPS: Alchemy: Convert dbdma.c to syscore_ops ...
2011-05-19kmemleak: Select DEBUG_FS unconditionally in DEBUG_KMEMLEAKCatalin Marinas
In the past DEBUG_FS used to depend on SYSFS and DEBUG_KMEMLEAK selected it conditionally. This is no longer the case, so always select DEBUG_FS via DEBUG_KMEMLEAK. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2011-05-19MIPS: Enable kmemleak for MIPSMaxin John
Signed-off-by: Maxin B. John <maxin.john@gmail.com> To: Catalin Marinas <catalin.marinas@arm.com> Cc: Daniel Baluta <dbaluta@ixiacom.com> Cc: naveen yadav <yad.naveen@gmail.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Cc: linux-mm@kvack.org Patchwork: https://patchwork.linux-mips.org/patch/2244/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19Add a strtobool function matching semantics of existing in kernel equivalentsJonathan Cameron
This is a rename of the usr_strtobool proposal, which was a renamed, relocated and fixed version of previous kstrtobool RFC Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-05-19lib: Add generic binary search function to the kernel.Tim Abbott
There a large number hand-coded binary searches in the kernel (run "git grep search | grep binary" to find many of them). Since in my experience, hand-coding binary searches can be error-prone, it seems worth cleaning this up by providing a generic binary search function. This generic binary search implementation comes from Ksplice. It has the same basic API as the C library bsearch() function. Ksplice uses it in half a dozen places with 4 different comparison functions, and I think our code is substantially cleaner because of this. Signed-off-by: Tim Abbott <tabbott@ksplice.com> Extra-bikeshedding-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Extra-bikeshedding-by: André Goddard Rosa <andre.goddard@gmail.com> Extra-bikeshedding-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Alessio Igor Bogani <abogani@kernel.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-05-12vsprintf: Turn kptr_restrict off by defaultIngo Molnar
kptr_restrict has been triggering bugs in apps such as perf, and it also makes the system less useful by default, so turn it off by default. This is how we generally handle security features that remove functionality, such as firewall code or SELinux - they have to be configured and activated from user-space. Distributions can turn kptr_restrict on again via this line in /etc/sysctrl.conf: kernel.kptr_restrict = 1 ( Also mark the variable __read_mostly while at it, as it's typically modified only once per bootup, or not at all. ) Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-10Merge branches 'dma-debug/next', 'amd-iommu/command-cleanups', ↵Joerg Roedel
'amd-iommu/ats' and 'amd-iommu/extended-features' into iommu/2.6.40 Conflicts: arch/x86/include/asm/amd_iommu_types.h arch/x86/kernel/amd_iommu.c arch/x86/kernel/amd_iommu_init.c
2011-05-05rcu: Enable DEBUG_OBJECTS_RCU_HEAD from !PREEMPTMathieu Desnoyers
The prohibition of DEBUG_OBJECTS_RCU_HEAD from !PREEMPT was due to the fixup actions. So just produce a warning from !PREEMPT. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-05-05rcu: Remove conditional compilation for RCU CPU stall warningsPaul E. McKenney
The RCU CPU stall warnings can now be controlled using the rcu_cpu_stall_suppress boot-time parameter or via the same parameter from sysfs. There is therefore no longer any reason to have kernel config parameters for this feature. This commit therefore removes the RCU_CPU_STALL_DETECTOR and RCU_CPU_STALL_DETECTOR_RUNNABLE kernel config parameters. The RCU_CPU_STALL_TIMEOUT parameter remains to allow the timeout to be tuned and the RCU_CPU_STALL_VERBOSE parameter remains to allow task-stall information to be suppressed if desired. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-05-04Merge branch 'for-linus' of git://git.infradead.org/users/eparis/selinux ↵James Morris
into for-linus
2011-05-02XZ decompressor: Fix decoding of empty LZMA2 streamsLasse Collin
The old code considered valid empty LZMA2 streams to be corrupt. Note that a typical empty .xz file has no LZMA2 data at all, and thus most .xz files having no uncompressed data are handled correctly even without this fix. Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-28flex_arrays: allow zero length flex arraysEric Paris
Just like kmalloc will allow one to allocate a 0 length segment of memory flex arrays should do the same thing. It should bomb if you try to use something, but it should at least allow the allocation. This is needed because when SELinux switched to using flex_arrays in 2.6.38 the inability to allocate a 0 length array resulted in SELinux policy load returning -ENOSPC when previously it worked. Based-on-patch-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Eric Paris <eparis@redhat.com> Tested-by: Chris Richards <gizmo@giz-works.com> Cc: stable@kernel.org [2.6.38+]
2011-04-28flex_array: flex_array_prealloc takes a number of elements, not an endEric Paris
Change flex_array_prealloc to take the number of elements for which space should be allocated instead of the last (inclusive) element. Users and documentation are updated accordingly. flex_arrays got introduced before they had users. When folks started using it, they ended up needing a different API than was coded up originally. This swaps over to the API that folks apparently need. Based-on-patch-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Eric Paris <eparis@redhat.com> Tested-by: Chris Richards <gizmo@giz-works.com> Acked-by: Dave Hansen <dave@linux.vnet.ibm.com> Cc: stable@kernel.org [2.6.38+]
2011-04-28watchdog, hung_task_timeout: Add Kconfig configurable defaultJeff Mahoney
This patch allows the default value for sysctl_hung_task_timeout_secs to be set at build time. The feature carries virtually no overhead, so it makes sense to keep it enabled. On heavily loaded systems, though, it can end up triggering stack traces when there is no bug other than the system being underprovisioned. We use this patch to keep the hung task facility available but disabled at boot-time. The default of 120 seconds is preserved. As a note, commit e162b39a may have accidentally reverted commit fb822db4, which raised the default from 120 seconds to 480 seconds. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Acked-by: Mandeep Singh Baines <msb@google.com> Link: http://lkml.kernel.org/r/4DB8600C.8080000@suse.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-04-26Merge branch 'master' into for-nextJiri Kosina
Fast-forwarded to current state of Linus' tree as there are patches to be applied for files that didn't exist on the old branch.
2011-04-14kstrtox: simpler code in _kstrtoull()Alexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-14kstrtox: fix compile warnings in testAlexey Dobriyan
Fix the following warnings: CC [M] lib/test-kstrtox.o lib/test-kstrtox.c: In function 'test_kstrtou64_ok': lib/test-kstrtox.c:318: warning: this decimal constant is unsigned only in ISO C90 ... Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-10add printk.time=1 boot-time hint to Kconfig.debug help textJim Cromie
Cite Documentation/kernel-parameters.txt for an alternative to building with PRINTK_TIME compiled in. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-04-07Merge branch 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6Linus Torvalds
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6: Fix common misspellings
2011-04-07dma-debug: print information about leaked entryStanislaw Gruszka
When driver leak dma mapping, print additional information about one of leaked entries, to to help investigate problem. Patch should be useful for debugging drivers, which maps many different class of buffers. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2011-04-06vsprintf: make comment about vs{n,cn,}printf more understandableUwe Kleine-König
"You probably want ... instead." sounds like a recommendation better not to use the v... functions. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-04-04kemleak-test: build as module onlyDaniel Baluta
mm/kmemleak-test.c is used to provide an example of how kmemleak tool works. Memory is leaked at module unload-time, so building the test in kernel (Y) makes the leaks impossible and the test useless. Qualify DEBUG_KMEMLEAK_TEST config symbol with "depends on m", to restrict module-only building. Signed-off-by: Daniel Baluta <dbaluta@ixiacom.com> Acked-by: Pekka Enberg <penberg@kernel.org> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-27Merge branch 'for-linus-1' of git://git.infradead.org/mtd-2.6Linus Torvalds
* 'for-linus-1' of git://git.infradead.org/mtd-2.6: (49 commits) mtd: mtdswap: fix compilation warning mtdswap: kill strict error handling option mtd: nand: enable software BCH ECC in nand simulator mtd: nand: add software BCH ECC support mtd: fix printf format warnings, mostly lack of %zd for size_t, in mtdswap mtd: sm_rtl: check kmalloc return value mtd: cfi: add support for AMIC flashes (e.g. A29L160AT) lib: add shared BCH ECC library mtd: mxc_nand: fix OOB corruption when page size > 2KiB mtd: DaVinci: Removed header file that is not required mtd: pxa3xx_nand: clean the keep configure code mtd: pxa3xx_nand: mtd scan id process could be defined by driver itself mtd: pxa3xx_nand: unify prepare command mtd: pxa3xx_nand: discard wait_for_event,write_cmd,__readid function mtd: pxa3xx_nand: rework irq logic mtd: pxa3xx_nand: make scan procedure more clear mtd: speedtest: fix integer overflow mtd: mxc_nand: fix read past buffer end mtd: omap3: nand: report corrected ecc errors jffs2: remove a trailing white space in commentaries ...
2011-03-25Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: futex: Fix WARN_ON() test for UP WARN_ON_SMP(): Allow use in if() statements on UP x86, dumpstack: Use %pB format specifier for stack trace vsprintf: Introduce %pB format specifier lockdep: Remove unused 'factor' variable from lockdep_stats_show()
2011-03-25Merge branch 'master' of ↵Artem Bityutskiy
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into for-linus-1 * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6: (9356 commits) [media] rc: update for bitop name changes fs: simplify iget & friends fs: pull inode->i_lock up out of writeback_single_inode fs: rename inode_lock to inode_hash_lock fs: move i_wb_list out from under inode_lock fs: move i_sb_list out from under inode_lock fs: remove inode_lock from iput_final and prune_icache fs: Lock the inode LRU list separately fs: factor inode disposal fs: protect inode->i_state with inode->i_lock lib, arch: add filter argument to show_mem and fix private implementations SLUB: Write to per cpu data when allocating it slub: Fix debugobjects with lockless fastpath autofs4: Do not potentially dereference NULL pointer returned by fget() in autofs_dev_ioctl_setpipefd() autofs4 - remove autofs4_lock autofs4 - fix d_manage() return on rcu-walk autofs4 - fix autofs4_expire_indirect() traversal autofs4 - fix dentry leak in autofs4_expire_direct() autofs4 - reinstate last used update on access vfs - check non-mountpoint dentry might block in __follow_mount_rcu() ... NOTE! This merge commit was created to fix compilation error. The block tree was merged upstream and removed the 'elv_queue_empty()' function which the new 'mtdswap' driver is using. So a simple merge of the mtd tree with upstream does not compile. And the mtd tree has already be published, so re-basing it is not an option. To fix this unfortunate situation, I had to merge upstream into the mtd-2.6.git tree without committing, put the fixup patch on top of this, and then commit this. The result is that we do not have commits which do not compile. In other words, this merge commit "merges" 3 things: the MTD tree, the upstream tree, and the fixup patch.
2011-03-24lib, arch: add filter argument to show_mem and fix private implementationsDavid Rientjes
Commit ddd588b5dd55 ("oom: suppress nodes that are not allowed from meminfo on oom kill") moved lib/show_mem.o out of lib/lib.a, which resulted in build warnings on all architectures that implement their own versions of show_mem(): lib/lib.a(show_mem.o): In function `show_mem': show_mem.c:(.text+0x1f4): multiple definition of `show_mem' arch/sparc/mm/built-in.o:(.text+0xd70): first defined here The fix is to remove __show_mem() and add its argument to show_mem() in all implementations to prevent this breakage. Architectures that implement their own show_mem() actually don't do anything with the argument yet, but they could be made to filter nodes that aren't allowed in the current context in the future just like the generic implementation. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Reported-by: James Bottomley <James.Bottomley@hansenpartnership.com> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-24vsprintf: Introduce %pB format specifierNamhyung Kim
The %pB format specifier is for stack backtrace. Its handler sprint_backtrace() does symbol lookup using (address-1) to ensure the address will not point outside of the function. If there is a tail-call to the function marked "noreturn", gcc optimized out the code after the call then causes saved return address points outside of the function (i.e. the start of the next function), so pollutes call trace somewhat. This patch adds the %pB printk mechanism that allows architecture call-trace printout functions to improve backtrace printouts. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-arch@vger.kernel.org LKML-Reference: <1300934550-21394-1-git-send-email-namhyung@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-23bitops: introduce CONFIG_GENERIC_FIND_BIT_LEAkinobu Mita
This introduces CONFIG_GENERIC_FIND_BIT_LE to tell whether to use generic implementation of find_*_bit_le() in lib/find_next_bit.c or not. For now we select CONFIG_GENERIC_FIND_BIT_LE for all architectures which enable CONFIG_GENERIC_FIND_NEXT_BIT. But m68knommu wants to define own faster find_next_zero_bit_le() and continues using generic find_next_{,zero_}bit(). (CONFIG_GENERIC_FIND_NEXT_BIT and !CONFIG_GENERIC_FIND_BIT_LE) Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23asm-generic: change little-endian bitops to take any pointer typesAkinobu Mita
This makes the little-endian bitops take any pointer types by changing the prototypes and adding casts in the preprocessor macros. That would seem to at least make all the filesystem code happier, and they can continue to do just something like #define ext2_set_bit __test_and_set_bit_le (or whatever the exact sequence ends up being). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23asm-generic: rename generic little-endian bitops functionsAkinobu Mita
As a preparation for providing little-endian bitops for all architectures, This renames generic implementation of little-endian bitops. (remove "generic_" prefix and postfix "_le") s/generic_find_next_le_bit/find_next_bit_le/ s/generic_find_next_zero_le_bit/find_next_zero_bit_le/ s/generic_find_first_zero_le_bit/find_first_zero_bit_le/ s/generic___test_and_set_le_bit/__test_and_set_bit_le/ s/generic___test_and_clear_le_bit/__test_and_clear_bit_le/ s/generic_test_le_bit/test_bit_le/ s/generic___set_le_bit/__set_bit_le/ s/generic___clear_le_bit/__clear_bit_le/ s/generic_test_and_set_le_bit/test_and_set_bit_le/ s/generic_test_and_clear_le_bit/test_and_clear_bit_le/ Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22zlib: slim down zlib_deflate() workspace when possibleJim Keniston
Instead of always creating a huge (268K) deflate_workspace with the maximum compression parameters (windowBits=15, memLevel=8), allow the caller to obtain a smaller workspace by specifying smaller parameter values. For example, when capturing oops and panic reports to a medium with limited capacity, such as NVRAM, compression may be the only way to capture the whole report. In this case, a small workspace (24K works fine) is a win, whether you allocate the workspace when you need it (i.e., during an oops or panic) or at boot time. I've verified that this patch works with all accepted values of windowBits (positive and negative), memLevel, and compression level. Signed-off-by: Jim Keniston <jkenisto@us.ibm.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: David Miller <davem@davemloft.net> Cc: Chris Mason <chris.mason@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22kstrto*: converting strings to integers done (hopefully) rightAlexey Dobriyan
1. simple_strto*() do not contain overflow checks and crufty, libc way to indicate failure. 2. strict_strto*() also do not have overflow checks but the name and comments pretend they do. 3. Both families have only "long long" and "long" variants, but users want strtou8() 4. Both "simple" and "strict" prefixes are wrong: Simple doesn't exactly say what's so simple, strict should not exist because conversion should be strict by default. The solution is to use "k" prefix and add convertors for more types. Enter kstrtoull() kstrtoll() kstrtoul() kstrtol() kstrtouint() kstrtoint() kstrtou64() kstrtos64() kstrtou32() kstrtos32() kstrtou16() kstrtos16() kstrtou8() kstrtos8() Include runtime testsuite (somewhat incomplete) as well. strict_strto*() become deprecated, stubbed to kstrto*() and eventually will be removed altogether. Use kstrto*() in code today! Note: on some archs _kstrtoul() and _kstrtol() are left in tree, even if they'll be unused at runtime. This is temporarily solution, because I don't want to hardcode list of archs where these functions aren't needed. Current solution with sizeof() and __alignof__ at least always works. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22printk: allow setting DEFAULT_MESSAGE_LEVEL via KconfigMandeep Singh Baines
We've been burned by regressions/bugs which we later realized could have been triaged quicker if only we'd paid closer attention to dmesg. To make it easier to audit dmesg, we'd like to make DEFAULT_MESSAGE_LEVEL Kconfig-settable. That way we can set it to KERN_NOTICE and audit any messages <= KERN_WARNING. Signed-off-by: Mandeep Singh Baines <msb@chromium.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joe Perches <joe@perches.com> Cc: Olof Johansson <olofj@chromium.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22printk: use %pK for /proc/kallsyms and /proc/modulesKees Cook
In an effort to reduce kernel address leaks that might be used to help target kernel privilege escalation exploits, this patch uses %pK when displaying addresses in /proc/kallsyms, /proc/modules, and /sys/module/*/sections/*. Note that this changes %x to %p, so some legitimately 0 values in /proc/kallsyms would have changed from 00000000 to "(null)". To avoid this, "(null)" is not used when using the "K" format. Anything that was already successfully parsing "(null)" in addition to full hex digits should have no problem with this change. (Thanks to Joe Perches for the suggestion.) Due to the %x to %p, "void *" casts are needed since these addresses are already "unsigned long" everywhere internally, due to their starting life as ELF section offsets. Signed-off-by: Kees Cook <kees.cook@canonical.com> Cc: Eugene Teo <eugene@redhat.com> Cc: Dan Rosenberg <drosenberg@vsecurity.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22vsprintf: neaten %pK kptr_restrict, save a bit of code spaceJoe Perches
If kptr restrictions are on, just set the passed pointer to NULL. $ size lib/vsprintf.o.* text data bss dec hex filename 8247 4 2 8253 203d lib/vsprintf.o.new 8282 4 2 8288 2060 lib/vsprintf.o.old Signed-off-by: Joe Perches <joe@perches.com> Cc: Dan Rosenberg <drosenberg@vsecurity.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22kernel/watchdog.c: allow hardlockup to panic by defaultDon Zickus
When a cpu is considered stuck, instead of limping along and just printing a warning, it is sometimes preferred to just panic, let kdump capture the vmcore and reboot. This gets the machine back into a stable state quickly while saving the info that got it into a stuck state to begin with. Add a Kconfig option to allow users to set the hardlockup to panic by default. Also add in a 'nmi_watchdog=nopanic' to override this. [akpm@linux-foundation.org: fix strncmp length] Signed-off-by: Don Zickus <dzickus@redhat.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22oom: suppress nodes that are not allowed from meminfo on oom killDavid Rientjes
The oom killer is extremely verbose for machines with a large number of cpus and/or nodes. This verbosity can often be harmful if it causes other important messages to be scrolled from the kernel log and incurs a signicant time delay, specifically for kernels with CONFIG_NODES_SHIFT > 8. This patch causes only memory information to be displayed for nodes that are allowed by current's cpuset when dumping the VM state. Information for all other nodes is irrelevant to the oom condition; we don't care if there's an abundance of memory elsewhere if we can't access it. This only affects the behavior of dumping memory information when an oom is triggered. Other dumps, such as for sysrq+m, still display the unfiltered form when using the existing show_mem() interface. Additionally, the per-cpu pageset statistics are extremely verbose in oom killer output, so it is now suppressed. This removes nodes_weight(current->mems_allowed) * (1 + nr_cpus) lines from the oom killer output. Callers may use __show_mem(SHOW_MEM_FILTER_NODES) to filter disallowed nodes. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-21Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: kbuild: Make DEBUG_SECTION_MISMATCH selectable, but not on by default genksyms: Regenerate lexer and parser genksyms: Track changes to enum constants genksyms: simplify usage of find_symbol() genksyms: Add helpers for building string lists genksyms: Simplify printing of symbol types genksyms: Simplify lexer genksyms: Do not paste the bison header file to lex.c modpost: fix trailing comma KBuild: silence "'scripts/unifdef' is up to date." kbuild: Add extra gcc checks kbuild: reenable section mismatch analysis unifdef: update to upstream version 2.5
2011-03-21kbuild: Make DEBUG_SECTION_MISMATCH selectable, but not on by defaultMichal Marek
CONFIG_DEBUG_SECTION_MISMATCH has also runtime effects due to the -fno-inline-functions-called-once compiler flag, so forcing it on everyone is not a good idea. Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-03-16Merge branch 'config' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'config' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: BKL: That's all, folks fs/locks.c: Remove stale FIXME left over from BKL conversion ipx: remove the BKL appletalk: remove the BKL x25: remove the BKL ufs: remove the BKL hpfs: remove the BKL drivers: remove extraneous includes of smp_lock.h tracing: don't trace the BKL adfs: remove the big kernel lock
2011-03-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1480 commits) bonding: enable netpoll without checking link status xfrm: Refcount destination entry on xfrm_lookup net: introduce rx_handler results and logic around that bonding: get rid of IFF_SLAVE_INACTIVE netdev->priv_flag bonding: wrap slave state work net: get rid of multiple bond-related netdevice->priv_flags bonding: register slave pointer for rx_handler be2net: Bump up the version number be2net: Copyright notice change. Update to Emulex instead of ServerEngines e1000e: fix kconfig for crc32 dependency netfilter ebtables: fix xt_AUDIT to work with ebtables xen network backend driver bonding: Improve syslog message at device creation time bonding: Call netif_carrier_off after register_netdevice bonding: Incorrect TX queue offset net_sched: fix ip_tos2prio xfrm: fix __xfrm_route_forward() be2net: Fix UDP packet detected status in RX compl Phonet: fix aligned-mode pipe socket buffer header reserve netxen: support for GbE port settings ... Fix up conflicts in drivers/staging/brcm80211/brcmsmac/wl_mac80211.c with the staging updates.
2011-03-16Merge branch 'driver-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6 * 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (50 commits) printk: do not mangle valid userspace syslog prefixes efivars: Add Documentation efivars: Expose efivars functionality to external drivers. efivars: Parameterize operations. efivars: Split out variable registration efivars: parameterize efivars efivars: Make efivars bin_attributes dynamic efivars: move efivars globals into struct efivars drivers:misc: ti-st: fix debugging code kref: Fix typo in kref documentation UIO: add PRUSS UIO driver support Fix spelling mistakes in Documentation/zh_CN/SubmittingPatches firmware: Fix unaligned memory accesses in dmi-sysfs firmware: Add documentation for /sys/firmware/dmi firmware: Expose DMI type 15 System Event Log firmware: Break out system_event_log in dmi-sysfs firmware: Basic dmi-sysfs support firmware: Add DMI entry types to the headers Driver core: convert platform_{get,set}_drvdata to static inline functions Translate linux-2.6/Documentation/magic-number.txt into Chinese ...
