path: root/lib
2010-08-04Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits) Documentation: update broken web addresses. fix comment typo "choosed" -> "chosen" hostap:hostap_hw.c Fix typo in comment Fix spelling contorller -> controller in comments Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault fs/Kconfig: Fix typo Userpace -> Userspace Removing dead MACH_U300_BS26 drivers/infiniband: Remove unnecessary casts of private_data fs/ocfs2: Remove unnecessary casts of private_data libfc: use ARRAY_SIZE scsi: bfa: use ARRAY_SIZE drm: i915: use ARRAY_SIZE drm: drm_edid: use ARRAY_SIZE synclink: use ARRAY_SIZE block: cciss: use ARRAY_SIZE comment typo fixes: charater => character fix comment typos concerning "challenge" arm: plat-spear: fix typo in kerneldoc reiserfs: typo comment fix update email address ...
2010-08-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1443 commits) phy/marvell: add 88ec048 support igb: Program MDICNFG register prior to PHY init e1000e: correct MAC-PHY interconnect register offset for 82579 hso: Add new product ID can: Add driver for esd CAN-USB/2 device l2tp: fix export of header file for userspace can-raw: Fix skb_orphan_try handling Revert "net: remove zap_completion_queue" net: cleanup inclusion phy/marvell: add 88e1121 interface mode support u32: negative offset fix net: Fix a typo from "dev" to "ndev" igb: Use irq_synchronize per vector when using MSI-X ixgbevf: fix null pointer dereference due to filter being set for VLAN 0 e1000e: Fix irq_synchronize in MSI-X case e1000e: register pm_qos request on hardware activation ip_fragment: fix subtracting PPPOE_SES_HLEN from mtu twice net: Add getsockopt support for TCP thin-streams cxgb4: update driver version cxgb4: add new PCI IDs ... Manually fix up conflicts in: - drivers/net/e1000e/netdev.c: due to pm_qos registration infrastructure changes - drivers/net/phy/marvell.c: conflict between adding 88ec048 support and cleaning up the IDs - drivers/net/wireless/ipw2x00/ipw2100.c: trivial ipw2100_pm_qos_req conflict (registration change vs marking it static)
2010-08-04Merge branch 'stable/swiotlb-0.8.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/swiotlb-2.6 * 'stable/swiotlb-0.8.3' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/swiotlb-2.6: swiotlb: Make swiotlb bookkeeping functions visible in the header file. swiotlb: search and replace "int dir" with "enum dma_data_direction dir" swiotlb: Make internal bookkeeping functions have 'swiotlb_tbl' prefix. swiotlb: add the swiotlb initialization function with iotlb memory swiotlb: add swiotlb_tbl_map_single library function
2010-08-04Merge branch 'master' into for-nextJiri Kosina
2010-07-27ARM: 6213/1: atomic64_test: add ARM as supported architectureWill Deacon
ARM has support for the atomic64_dec_if_positive operation so ensure that it is tested by the atomic64_test routine. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-21Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> FaultTakuya Yoshikawa
The last 't' of 'fault' is missing in the description of FAIL_IO_TIMEOUT. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-14lmb: rename to memblockYinghai Lu
via following scripts FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/lmb/memblock/g' \ -e 's/LMB/MEMBLOCK/g' \ $FILES for N in $(find . -name lmb.[ch]); do M=$(echo $N | sed 's/lmb/memblock/g') mv $N $M done and remove some wrong change like lmbench and dlmb etc. also move memblock.c from lib/ to mm/ Suggested-by: Ingo Molnar <mingo@elte.hu> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-07-11lib/devres.c: fix comment typoKulikov Vasiliy
'Unamp' should be 'Unmap'. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-06Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rbtree: Undo augmented trees performance damage and regression x86, Calgary: Limit the max PHB number to 256
2010-07-05rbtree: Undo augmented trees performance damage and regressionPeter Zijlstra
Reimplement augmented RB-trees without sprinkling extra branches all over the RB-tree code (which lives in the scheduler hot path). This approach is 'borrowed' from Fabio's BFQ implementation and relies on traversing the rebalance path after the RB-tree-op to correct the heap property for insertion/removal and make up for the damage done by the tree rotations. For insertion the rebalance path is trivially that from the new node upwards to the root, for removal it is that from the deepest node in the path from the to be removed node that will still be around after the removal. [ This patch also fixes a video driver regression reported by Ali Gholami Rudi - the memtype->subtree_max_end was updated incorrectly. ] Acked-by: Suresh Siddha <suresh.b.siddha@intel.com> Acked-by: Venkatesh Pallipadi <venki@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Tested-by: Ali Gholami Rudi <ali@rudi.ir> Cc: Fabio Checconi <fabio@gandalf.sssup.it> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <1275414172.27810.27961.camel@twins> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-07-04module: initialize module dynamic debug laterYehuda Sadeh
We should initialize the module dynamic debug datastructures only after determining that the module is not loaded yet. This fixes a bug that introduced in 2.6.35-rc2, where when a trying to load a module twice, we also load it's dynamic printing data twice which causes all sorts of nasty issues. Also handle the dynamic debug cleanup later on failure. Signed-off-by: Yehuda Sadeh <yehuda@hq.newdream.net> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (removed a #ifdef) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-04vsprintf: Recursive vsnprintf: Add "%pV", struct va_formatJoe Perches
Add the ability to print a format and va_list from a structure pointer Allows __dev_printk to be implemented as a single printk while minimizing string space duplication. %pV should not be used without some mechanism to verify the format and argument use ala __attribute__(format (printf(...))). Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-29genalloc: fix allocation from end of poolImre Deak
bitmap_find_next_zero_area requires the size of the bitmap, we instead passed the last suitable position. This made it impossible to allocate from the end of the pool. Fixes a regression introduced by 243797f59b748f679ab88d456fcc4f92236d724b ("genalloc: use bitmap_find_next_zero_area"). Signed-off-by: Imre Deak <imre.deak@nokia.com> Cc: Zygo Blaxell <zygo.blaxell@xandros.com> Cc: Tejun Heo <tj@kernel.org> Acked-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-23idr: fix RCU lockdep splat in idr_get_next()Paul E. McKenney
Convert to rcu_dereference_raw() given that many callers may have many different locking models. Located-by: Miles Lane <miles.lane@gmail.com> Tested-by: Miles Lane <miles.lane@gmail.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-06-16Merge branch 'master' into for-nextJiri Kosina
2010-06-16fix typos concerning "initiali[zs]e"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-06-07swiotlb: Make swiotlb bookkeeping functions visible in the header file.Konrad Rzeszutek Wilk
We put the functions dealing with the operations on the SWIOTLB buffer in the header and make those functions non-static. And also make the functions exported via EXPORT_SYMBOL_GPL. See "swiotlb: swiotlb: add swiotlb_tbl_map_single library function" for full description of patchset. [v2: swiotlb_sync_single_range_for_* no more. Remove usage.] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Tested-by: Albert Herranz <albert_herranz@yahoo.es>
2010-06-07swiotlb: search and replace "int dir" with "enum dma_data_direction dir"Konrad Rzeszutek Wilk
.. to catch anybody doing something funky. See "swiotlb: swiotlb: add swiotlb_tbl_map_single library function" for full description of patchset. [v2: swiotlb_sync_single_range_* no more - removed usage] [v3: enum dma_data_direction direction -> enum dma_data_direction dir] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Tested-by: Albert Herranz <albert_herranz@yahoo.es>
2010-06-07swiotlb: Make internal bookkeeping functions have 'swiotlb_tbl' prefix.Konrad Rzeszutek Wilk
The functions that operate on io_tlb_list/io_tlb_start/io_tlb_orig_addr have the prefix 'swiotlb_tbl' now. See "swiotlb: swiotlb: add swiotlb_tbl_map_single library function" for full description of patchset. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Tested-by: Albert Herranz <albert_herranz@yahoo.es>
2010-06-07swiotlb: add the swiotlb initialization function with iotlb memoryFUJITA Tomonori
This enables the caller to initialize swiotlb with its own iotlb memory. See "swiotlb: swiotlb: add swiotlb_tbl_map_single library function" for full description of patchset. [v2: changed ..with_tlb to ..with_tbl] Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Tested-by: Albert Herranz <albert_herranz@yahoo.es>
2010-06-07swiotlb: add swiotlb_tbl_map_single library functionFUJITA Tomonori
swiotlb_tbl_map_single() takes the dma address of iotlb instead of using swiotlb_virt_to_bus(). [v2: changed swiotlb_tlb to swiotlb_tbl] [v3: changed u64 to dma_addr_t] This patch: This is a set of patches that separate the address translation (virt_to_phys, virt_to_bus, etc) and allocation of the SWIOTLB buffer from the SWIOTLB library. The idea behind this set of patches is to make it possible to have separate mechanisms for translating virtual to physical or virtual to DMA addresses on platforms which need an SWIOTLB, and where physical != PCI bus address and also to allocate the core IOTLB memory outside SWIOTLB. One customers of this is the pv-ops project, which can switch between different modes of operation depending on the environment it is running in: bare-metal or virtualized (Xen for now). Another is the Wii DMA - used to implement the MEM2 DMA facility needed by its EHCI controller (for details: http://lkml.org/lkml/2010/5/18/303) On bare-metal SWIOTLB is used when there are no hardware IOMMU. In virtualized environment it used when PCI pass-through is enabled for the guest. The problems with PCI pass-through is that the guest's idea of PFN's is not the real thing. To fix that, there is translation layer for PFN->machine frame number and vice-versa. To bubble that up to the SWIOTLB layer there are two possible solutions. One solution has been to wholesale copy the SWIOTLB, stick it in arch/x86/xen/swiotlb.c and modify the virt_to_phys, phys_to_virt and others to use the Xen address translation functions. Unfortunately, since the kernel can run on bare-metal, there would be big code overlap with the real SWIOTLB. (git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen.git xen/dom0/swiotlb-new) Another approach, which this set of patches explores, is to abstract the address translation and address determination functions away from the SWIOTLB book-keeping functions. This way the core SWIOTLB library functions are present in one place, while the address related functions are in a separate library that can be loaded when running under non-bare-metal platform. Changelog: Since the last posting [v8.2] Konrad has done: - Added this changelog in the patch and referenced in the other patches this description. - 'enum dma_data_direction direction' to 'enum dma.. dir' so to be unified. [v8-v8.2 changes:] - Rolled-up the last two patches in one. - Rebased against linus latest. That meant dealing with swiotlb_sync_single_range_* changes. - added Acked-by: Fujita Tomonori and Tested-by: Albert Herranz [v7-v8 changes:] - Minimized the list of exported functions. - Integrated Fujita's patches and changed "swiotlb_tlb" to "swiotlb_tbl" in them. [v6-v7 changes:] - Minimized the amount of exported functions/variable with a prefix of: "swiotbl_tbl". - Made the usage of 'int dir' to be 'enum dma_data_direction'. [v5-v6 changes:] - Made the exported functions/variables have the 'swiotlb_bk' prefix. - dropped the checkpatches/other reworks Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Tested-by: Albert Herranz <albert_herranz@yahoo.es>
2010-06-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: fix setattr error handling in sysfs, configfs kobject: free memory if netlink_kernel_create() fails lib/kobject_uevent.c: fix CONIG_NET=n warning
2010-06-04lib: add s390 to atomic64_dec_if_positive archsHeiko Carstens
Add s390 to list of architectures that have atomic64_dec_if_positive implemented so we get rid of this warning: lib/atomic64_test.c:129:2: warning: #warning Please implement atomic64_dec_if_positive for your architecture, and add it to the IF above Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Luca Barbieri <luca@luca-barbieri.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-04kobject: free memory if netlink_kernel_create() failsDan Carpenter
There is a kfree(ue_sk) missing on the error path if netlink_kernel_create() fails. Signed-off-by: Dan Carpenter <error27@gmail.com> Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-06-04lib/kobject_uevent.c: fix CONIG_NET=n warningAndrew Morton
lib/kobject_uevent.c:87: warning: 'kobj_bcast_filter' defined but not used Repairs "hotplug: netns aware uevent_helper" Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-30Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, cpufeature: Unbreak compile with gcc 3.x x86, pat: Fix memory leak in free_memtype x86, k8: Fix section mismatch for powernowk8_exit() lib/atomic64_test: fix missing include of linux/kernel.h x86: remove last traces of quicklist usage x86, setup: Phoenix BIOS fixup is needed on Dell Inspiron Mini 1012 x86: "nosmp" command line option should force the system into UP mode arch/x86/pci: use kasprintf x86, apic: ack all pending irqs when crashed/on kexec
2010-05-30Revert "cpusets: randomize node rotor used in cpuset_mem_spread_node()"Linus Torvalds
This reverts commit 0ac0c0d0f837c499afd02a802f9cf52d3027fa3b, which caused cross-architecture build problems for all the wrong reasons. IA64 already added its own version of __node_random(), but the fact is, there is nothing architectural about the function, and the original commit was just badly done. Revert it, since no fix is forthcoming. Requested-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-28Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (27 commits) ACPI: Don't let acpi_pad needlessly mark TSC unstable drivers/acpi/sleep.h: Checkpatch cleanup ACPI: Minor cleanup eliminating redundant PMTIMER_TICKS to NS conversion ACPI: delete unused c-state promotion/demotion data strucutures ACPI: video: fix acpi_backlight=video ACPI: EC: Use kmemdup drivers/acpi: use kasprintf ACPI, APEI, EINJ injection parameters support Add x64 support to debugfs ACPI, APEI, Use ERST for persistent storage of MCE ACPI, APEI, Error Record Serialization Table (ERST) support ACPI, APEI, Generic Hardware Error Source memory error support ACPI, APEI, UEFI Common Platform Error Record (CPER) header Unified UUID/GUID definition ACPI Hardware Error Device (PNP0C33) support ACPI, APEI, PCIE AER, use general HEST table parsing in AER firmware_first setup ACPI, APEI, Document for APEI ACPI, APEI, EINJ support ACPI, APEI, HEST table parsing ACPI, APEI, APEI supporting infrastructure ...
2010-05-27radix-tree: fix radix_tree_prev_hole() underflow caseCesar Eduardo Barros
radix_tree_prev_hole() used LONG_MAX to detect underflow; however, ULONG_MAX is clearly what was intended, both here and by its only user (count_history_pages at mm/readahead.c). Reviewed-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27swiotlb: remove unnecessary swiotlb_sync_single_range_*FUJITA Tomonori
swiotlb_sync_single_range_for_cpu and swiotlb_sync_single_range_for_device are unnecessary because swiotlb_sync_single_for_cpu and swiotlb_sync_single_for_device can be used instead. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27lib/random32: export pseudo-random number generator for modulesJoe Eykholt
This patch moves the definition of struct rnd_state and the inline __seed() function to linux/random.h. It renames the static __random32() function to prandom32() and exports it for use in modules. prandom32() is useful as a privately-seeded pseudo random number generator that can give the same result every time it is initialized. For FCoE FC-BB-6 VN2VN mode self-selected unique FC address generation, we need an pseudo-random number generator seeded with the 64-bit world-wide port name. A truly random generator or one seeded with randomness won't do because the same sequence of numbers should be generated each time we boot or the link comes up. A prandom32_seed() inline function is added to the header file. It is inlined not for speed, but so the function won't be expanded in the base kernel, but only in the module that uses it. Signed-off-by: Joe Eykholt <jeykholt@cisco.com> Acked-by: Matt Mackall <mpm@selenic.com> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27idr: fix backtrack logic in idr_remove_allImre Deak
Currently idr_remove_all will fail with a use after free error if idr::layers is bigger than 2, which on 32 bit systems corresponds to items more than 1024. This is due to stepping back too many levels during backtracking. For simplicity let's assume that IDR_BITS=1 -> we have 2 nodes at each level below the root node and each leaf node stores two IDs. (In reality for 32 bit systems IDR_BITS=5, with 32 nodes at each sub-root level and 32 IDs in each leaf node). The sequence of freeing the nodes at the moment is as follows: layer 1 -> a(7) 2 -> b(3) c(5) 3 -> d(1) e(2) f(4) g(6) Until step 4 things go fine, but then node c is freed, whereas node g should be freed first. Since node c contains the pointer to node g we'll have a use after free error at step 6. How many levels we step back after visiting the leaf nodes is currently determined by the msb of the id we are currently visiting: Step 1. node d with IDs 0,1 is freed, current ID is advanced to 2. msb of the current ID bit 1. This means we need to step back 1 level to node b and take the next sibling, node e. 2-3. node e with IDs 2,3 is freed, current ID is 4, msb is bit 2. This means we need to step back 2 levels to node a, freeing node b on the way. 4-5. node f with IDs 4,5 is freed, current ID is 6, msb is still bit 2. This means we again need to step back 2 levels to node a and free c on the way. 6. We should visit node g, but its pointer is not available as node c was freed. The fix changes how we determine the number of levels to step back. Instead of deducting this merely from the msb of the current ID, we should really check if advancing the ID causes an overflow to a bit position corresponding to a given layer. In the above example overflow from bit 0 to bit 1 should mean stepping back 1 level. Overflow from bit 1 to bit 2 should mean stepping back 2 levels and so on. The fix was tested with IDs up to 1 << 20, which corresponds to 4 layers on 32 bit systems. Signed-off-by: Imre Deak <imre.deak@nokia.com> Reviewed-by: Tejun Heo <tj@kernel.org> Cc: Eric Paris <eparis@redhat.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: <stable@kernel.org> [2.6.34.1] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27fault-injection: add CPU notifier error injection moduleAkinobu Mita
I used this module to test the series of modification to the cpu notifiers code. Example1: inject CPU offline error (-1 == -EPERM) # modprobe cpu-notifier-error-inject cpu_down_prepare_error=-1 # echo 0 > /sys/devices/system/cpu/cpu1/online bash: echo: write error: Operation not permitted Example2: inject CPU online error (-2 == -ENOENT) # modprobe cpu-notifier-error-inject cpu_up_prepare_error=-2 # echo 1 > /sys/devices/system/cpu/cpu1/online bash: echo: write error: No such file or directory [akpm@linux-foundation.org: fix Kconfig help text] Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27cpusets: randomize node rotor used in cpuset_mem_spread_node()Jack Steiner
Some workloads that create a large number of small files tend to assign too many pages to node 0 (multi-node systems). Part of the reason is that the rotor (in cpuset_mem_spread_node()) used to assign nodes starts at node 0 for newly created tasks. This patch changes the rotor to be initialized to a random node number of the cpuset. [akpm@linux-foundation.org: fix layout] [Lee.Schermerhorn@hp.com: Define stub numa_random() for !NUMA configuration] Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Paul Menage <menage@google.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-26revert "crc32: use __BYTE_ORDER macro for endian detection"Andrew Morton
It doesn't work on big-endian - those architectures don't define __LITTLE_ENDIAN. Cc: Joakim Tjernlund <joakim.tjernlund@transmode.se> Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25crc32: use __BYTE_ORDER macro for endian detection.Joakim Tjernlund
Since crc32.c contains a nifty test program that can be executed in user space, make sure endian detection works reliably in user space too. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25crc32: major optimizationJoakim Tjernlund
Precompute more crc32 values(0xcc00, 0xcc0000 and 0xcc000000) into tables. This increases the table size from 1KB to 4KB but the performance benfit makes it worth it: 28% faster on MPC8321, 266 MHz 2x faster on Core 2 Duo, 3.1GHz [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25lib: introduce common method to convert hex digitsAndy Shevchenko
hex_to_bin() is a little method which converts hex digit to its actual value. There are plenty of places where such functionality is needed. [akpm@linux-foundation.org: use tolower(), saving 3 bytes, test the more common case first - it's quicker] [akpm@linux-foundation.org: relocate tolower to make it even faster! (Joe)] Signed-off-by: Andy Shevchenko <ext-andriy.shevchenko@nokia.com> Cc: Tilman Schmidt <tilman@imap.cc> Cc: Duncan Sands <duncan.sands@free.fr> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: "Richard Russon (FlatCap)" <ldm@flatcap.org> Cc: John W. Linville <linville@tuxdriver.com> Cc: Len Brown <lenb@kernel.org> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25lib/hexdump.c: reduce stack variable size and cleanupsJoe Perches
Reduce char linebuf[200] to the actual size required., which is 32 * 3 + 2 + 32 + 1, ie: linebuf[131]. Change examples to use bool true not int 1. Align multiline argument indentation to open parenthesis. Use temporary for ptr[j] so trigraph fits on single line. Convert printk ptr from %*p, (int)(2 * sizeof(void *)) to %p as %p uses the same calculation for size. Signed-off-by: Joe Perches <joe@perches.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25DYNAMIC_DEBUG: fix documentation errorsFlorian Ragwitz
[akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Florian Ragwitz <rafl@debian.org> Cc: Jason Baron <jbaron@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25dynamic_debug: small cleanup in ddebug_proc_write()Dan Carpenter
This doesn't change behavior at all. In the original code, if nwords was zero then ddebug_parse_query() would return -EINVAL, now we just do it earlier. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25vsprintf.c: use noinline_for_stackJoe Perches
Mark static functions with noinline_for_stack Before: akpm:/usr/src/25> objdump -d lib/vsprintf.o | perl scripts/checkstack.pl 0x00000e82 pointer [vsprintf.o]: 344 0x0000198c pointer [vsprintf.o]: 344 0x000025d6 scnprintf [vsprintf.o]: 216 0x00002648 scnprintf [vsprintf.o]: 216 0x00002565 snprintf [vsprintf.o]: 208 0x0000267c sprintf [vsprintf.o]: 208 0x000030a3 bprintf [vsprintf.o]: 208 0x00003b1e sscanf [vsprintf.o]: 208 0x00000608 number [vsprintf.o]: 136 0x00000937 number [vsprintf.o]: 136 After: akpm:/usr/src/25> objdump -d lib/vsprintf.o | perl scripts/checkstack.pl 0x00000a7c symbol_string [vsprintf.o]: 248 0x00000ae8 symbol_string [vsprintf.o]: 248 0x00002310 scnprintf [vsprintf.o]: 216 0x00002382 scnprintf [vsprintf.o]: 216 0x0000229f snprintf [vsprintf.o]: 208 0x000023b6 sprintf [vsprintf.o]: 208 0x00002ddd bprintf [vsprintf.o]: 208 0x00003858 sscanf [vsprintf.o]: 208 0x00000625 number [vsprintf.o]: 136 0x00000954 number [vsprintf.o]: 136 Signed-off-by: Joe Perches <joe@perches.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25kernel-wide: replace USHORT_MAX, SHORT_MAX and SHORT_MIN with USHRT_MAX, ↵Alexey Dobriyan
SHRT_MAX and SHRT_MIN - C99 knows about USHRT_MAX/SHRT_MAX/SHRT_MIN, not USHORT_MAX/SHORT_MAX/SHORT_MIN. - Make SHRT_MIN of type s16, not int, for consistency. [akpm@linux-foundation.org: fix drivers/dma/timb_dma.c] [akpm@linux-foundation.org: fix security/keys/keyring.c] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-24lib/atomic64_test: fix missing include of linux/kernel.hPeter Huewe
Fix a build-failure (http://kisskb.ellerman.id.au/kisskb/buildresult/2601239/) by adding the missing include file (linux/kernel.h) for printk and KERN_INFO. Signed-off-by: Peter Huewe <peterhuewe@gmx.de> LKML-Reference: <201005241913.o4OJDKdf010884@imap1.linux-foundation.org> Cc: Luca Barbieri <luca@luca-barbieri.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-05-21Merge git://git.infradead.org/iommu-2.6Linus Torvalds
* git://git.infradead.org/iommu-2.6: intel-iommu: Set a more specific taint flag for invalid BIOS DMAR tables intel-iommu: Combine the BIOS DMAR table warning messages panic: Add taint flag TAINT_FIRMWARE_WORKAROUND ('I') panic: Allow warnings to set different taint flags intel-iommu: intel_iommu_map_range failed at very end of address space intel-iommu: errors with smaller iommu widths intel-iommu: Fix boot inside 64bit virtualbox with io-apic disabled intel-iommu: use physfn to search drhd for VF intel-iommu: Print out iommu seq_id intel-iommu: Don't complain that ACPI_DMAR_SCOPE_TYPE_IOAPIC is not supported intel-iommu: Avoid global flushes with caching mode. intel-iommu: Use correct domain ID when caching mode is enabled intel-iommu mistakenly uses offset_pfn when caching mode is enabled intel-iommu: use for_each_set_bit() intel-iommu: Fix section mismatch dmar_ir_support() uses dmar_tbl.
2010-05-21Merge branch 'kdb-merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb * 'kdb-merge' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb: (25 commits) kdb,debug_core: Allow the debug core to receive a panic notification MAINTAINERS: update kgdb, kdb, and debug_core info debug_core,kdb: Allow the debug core to process a recursive debug entry printk,kdb: capture printk() when in kdb shell kgdboc,kdb: Allow kdb to work on a non open console port kgdb: Add the ability to schedule a breakpoint via a tasklet mips,kgdb: kdb low level trap catch and stack trace powerpc,kgdb: Introduce low level trap catching x86,kgdb: Add low level debug hook kgdb: remove post_primary_code references kgdb,docs: Update the kgdb docs to include kdb kgdboc,keyboard: Keyboard driver for kdb with kgdb kgdb: gdb "monitor" -> kdb passthrough sparc,sunzilog: Add console polling support for sunzilog serial driver sh,sh-sci: Use NO_POLL_CHAR in the SCIF polled console code kgdb,8250,pl011: Return immediately from console poll kgdb: core changes to support kdb kdb: core for kgdb back end (2 of 2) kdb: core for kgdb back end (1 of 2) kgdb,blackfin: Add in kgdb_arch_set_pc for blackfin ...
2010-05-21hotplug: netns aware uevent_helperEric W. Biederman
It only makes sense for uevent_helper to get events in the intial namespaces. It's invocation is not per namespace and it is not clear how we could make it's invocation namespace aware. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-21kobj: Send hotplug events in the proper namespace.Eric W. Biederman
Utilize netlink_broacast_filtered to allow sending hotplug events in the proper namespace. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-21kobject: Send hotplug events in all network namespacesEric W. Biederman
Open a copy of the uevent kernel socket in each network namespace so we can send uevents in all network namespaces. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-21sysfs: Comment sysfs directory tagging logicSerge E. Hallyn
Add some in-line comments to explain the new infrastructure, which was introduced to support sysfs directory tagging with namespaces. I think an overall description someplace might be good too, but it didn't really seem to fit into Documentation/filesystems/sysfs.txt, which appears more geared toward users, rather than maintainers, of sysfs. (Tejun, please let me know if I can make anything clearer or failed altogether to comment something that should be commented.) Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
