path: root/lib
2009-04-06Merge branch 'kmemtrace-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'kmemtrace-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: kmemtrace: trace kfree() calls with NULL or zero-length objects kmemtrace: small cleanups kmemtrace: restore original tracing data binary format, improve ABI kmemtrace: kmemtrace_alloc() must fill type_id kmemtrace: use tracepoints kmemtrace, rcu: don't include unnecessary headers, allow kmemtrace w/ tracepoints kmemtrace, rcu: fix rcupreempt.c data structure dependencies kmemtrace, rcu: fix rcu_tree_trace.c data structure dependencies kmemtrace, rcu: fix linux/rcutree.h and linux/rcuclassic.h dependencies kmemtrace, mm: fix slab.h dependency problem in mm/failslab.c kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_unlzma.c kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_bunzip2.c kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_inflate.c kmemtrace, squashfs: fix slab.h dependency problem in squasfs kmemtrace, befs: fix slab.h dependency problem kmemtrace, security: fix linux/key.h header file dependencies kmemtrace, fs: fix linux/fdtable.h header file dependencies kmemtrace, fs: uninline simple_transaction_set() kmemtrace, fs, security: move alloc_secdata() and free_secdata() to linux/security.h
2009-04-05Merge branch 'core/debugobjects' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core/debugobjects' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: debugobjects: delay free of internal objects debugobjects: replace static objects when slab cache becomes available debug_objects: add boot-parameter toggle to turn object debugging off again
2009-04-05Merge branch 'printk-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'printk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: printk: correct the behavior of printk_timed_ratelimit() vsprintf: unify the format decoding layer for its 3 users, cleanup fix regression from "vsprintf: unify the format decoding layer for its 3 users" vsprintf: fix bug in negative value printing vsprintf: unify the format decoding layer for its 3 users vsprintf: add binary printf printk: introduce printk_once() Fix trivial conflicts (printk_once vs log_buf_kexec_setup() added near each other) in include/linux/kernel.h.
2009-04-03Merge branch 'locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: locking: rename trace_softirq_[enter|exit] => lockdep_softirq_[enter|exit] lockdep: remove duplicate CONFIG_DEBUG_LOCKDEP definitions lockdep: require framepointers for x86 lockdep: remove extra "irq" string lockdep: fix incorrect state name
2009-04-03kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_unlzma.cPekka Enberg
Impact: cleanup lib/decompress_unlzma.c depends on slab.h without including it: CC lib/decompress_unlzma.o lib/decompress_unlzma.c: In function ‘rc_free’: lib/decompress_unlzma.c:122: error: implicit declaration of function ‘kfree’ lib/decompress_unlzma.c: In function ‘unlzma’: lib/decompress_unlzma.c:551: error: implicit declaration of function ‘kmalloc’ lib/decompress_unlzma.c:551: warning: assignment makes pointer from integer without a cast make[1]: *** [lib/decompress_unlzma.o] Error 1 make: *** [lib/] Error 2 It gets included implicitly currently - but this will not be the case with upcoming kmemtrace changes. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> LKML-Reference: <1237886521.25315.58.camel@penberg-laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-03kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_bunzip2.cPekka Enberg
Impact: cleanup lib/decompress_bunzip2.c depends on slab.h without including it: CC lib/decompress_bunzip2.o lib/decompress_bunzip2.c: In function ‘start_bunzip’: lib/decompress_bunzip2.c:636: error: implicit declaration of function ‘kmalloc’ lib/decompress_bunzip2.c:636: warning: assignment makes pointer from integer without a cast lib/decompress_bunzip2.c: In function ‘bunzip2’: lib/decompress_bunzip2.c:682: warning: assignment makes pointer from integer without a cast lib/decompress_bunzip2.c:693: warning: assignment makes pointer from integer without a cast lib/decompress_bunzip2.c:726: error: implicit declaration of function ‘kfree’ make[1]: *** [lib/decompress_bunzip2.o] Error 1 make: *** [lib/] Error 2 It gets included implicitly currently - but this will not be the case with upcoming kmemtrace changes. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> LKML-Reference: <1237886032.25315.48.camel@penberg-laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-03kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_inflate.cPekka Enberg
Impact: fix build lib/decompress_inflate.c depends on slab.h without including it: CC lib/decompress_inflate.o lib/decompress_inflate.c: In function ‘gunzip’: lib/decompress_inflate.c:45: error: implicit declaration of function ‘kmalloc’ lib/decompress_inflate.c:45: warning: assignment makes pointer from integer without a cast lib/decompress_inflate.c:57: warning: assignment makes pointer from integer without a cast lib/decompress_inflate.c:65: warning: assignment makes pointer from integer without a cast lib/decompress_inflate.c:71: warning: assignment makes pointer from integer without a cast lib/decompress_inflate.c:154: error: implicit declaration of function ‘kfree’ make[1]: *** [lib/decompress_inflate.o] Error 1 make: *** [lib/] Error 2 It gets included implicitly currently - but this will not be the case with upcoming kmemtrace changes. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> LKML-Reference: <1237886030.25315.47.camel@penberg-laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-02cpumask: fix slab corruption caused by alloc_cpumask_var_node()Jack Steiner
Fix slab corruption caused by alloc_cpumask_var_node() overwriting the tail end of an off-stack cpumask. The function zeros out cpumask bits beyond the last possible cpu. The starting point for zeroing should be the beginning of the mask offset by a byte count derived from the number of possible cpus. The offset was calculated in bits instead of bytes. This resulted in overwriting the end of the cpumask. Signed-off-by: Jack Steiner <steiner@sgi.com> Acked-by: Mike Travis <travis.sgi.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: <stable@kernel.org> [2.6.29.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02cgroup: CSS ID supportKAMEZAWA Hiroyuki
Patch for Per-CSS(Cgroup Subsys State) ID and private hierarchy code. This patch attaches unique ID to each css and provides following. - css_lookup(subsys, id) returns pointer to struct cgroup_subysys_state of id. - css_get_next(subsys, id, rootid, depth, foundid) returns the next css under "root" by scanning When cgroup_subsys->use_id is set, an id for css is maintained. The cgroup framework only parepares - css_id of root css for subsys - id is automatically attached at creation of css. - id is *not* freed automatically. Because the cgroup framework don't know lifetime of cgroup_subsys_state. free_css_id() function is provided. This must be called by subsys. There are several reasons to develop this. - Saving space .... For example, memcg's swap_cgroup is array of pointers to cgroup. But it is not necessary to be very fast. By replacing pointers(8bytes per ent) to ID (2byes per ent), we can reduce much amount of memory usage. - Scanning without lock. CSS_ID provides "scan id under this ROOT" function. By this, scanning css under root can be written without locks. ex) do { rcu_read_lock(); next = cgroup_get_next(subsys, id, root, &found); /* check sanity of next here */ css_tryget(); rcu_read_unlock(); id = found + 1 } while(...) Characteristics: - Each css has unique ID under subsys. - Lifetime of ID is controlled by subsys. - css ID contains "ID" and "Depth in hierarchy" and stack of hierarchy - Allowed ID is 1-65535, ID 0 is UNUSED ID. Design Choices: - scan-by-ID v.s. scan-by-tree-walk. As /proc's pid scan does, scan-by-ID is robust when scanning is done by following kind of routine. scan -> rest a while(release a lock) -> conitunue from interrupted memcg's hierarchical reclaim does this. - When subsys->use_id is set, # of css in the system is limited to 65535. [bharata@linux.vnet.ibm.com: remove rcu_read_lock() from css_get_next()] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Bharata B Rao <bharata@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02Merge branch 'tracing/core-v2' into tracing-for-linusIngo Molnar
Conflicts: include/linux/slub_def.h lib/Kconfig.debug mm/slob.c mm/slub.c
2009-04-01lib/rbtree.c: optimize rb_erase()Wolfram Strepp
Tfour 4 redundant if-conditions in function __rb_erase_color() in lib/rbtree.c are removed. In pseudo-source-code, the structure of the code is as follows: if ((!A || B) && (!C || D)) { . . . } else { if (!C || D) {//if this is true, it implies: (A == true) && (B == false) if (A) {//hence this always evaluates to 'true'... . } . //at this point, C always becomes true, because of: __rb_rotate_right/left(); //and: other = parent->rb_right/left; } . . if (C) {//...and this too ! . } } Signed-off-by: Wolfram Strepp <wstrepp@gmx.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andrea Arcangeli <andrea@qumranet.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01generic debug pageallocAkinobu Mita
CONFIG_DEBUG_PAGEALLOC is now supported by x86, powerpc, sparc64, and s390. This patch implements it for the rest of the architectures by filling the pages with poison byte patterns after free_pages() and verifying the poison patterns before alloc_pages(). This generic one cannot detect invalid page accesses immediately but invalid read access may cause invalid dereference by poisoned memory and invalid write access can be detected after a long delay. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31Merge branch 'linus' into locking-for-linusIngo Molnar
Conflicts: lib/Kconfig.debug
2009-03-30dma-debug: fix printk formats (i386)Randy Dunlap
Fix printk format warnings in dma-debug: lib/dma-debug.c:645: warning: format '%016llx' expects type 'long long unsigned int', but argument 6 has type 'dma_addr_t' lib/dma-debug.c:662: warning: format '%016llx' expects type 'long long unsigned int', but argument 6 has type 'dma_addr_t' lib/dma-debug.c:676: warning: format '%016llx' expects type 'long long unsigned int', but argument 6 has type 'dma_addr_t' lib/dma-debug.c:686: warning: format '%016llx' expects type 'long long unsigned int', but argument 6 has type 'dma_addr_t' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30Merge branch 'iommu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'iommu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (60 commits) dma-debug: make memory range checks more consistent dma-debug: warn of unmapping an invalid dma address dma-debug: fix dma_debug_add_bus() definition for !CONFIG_DMA_API_DEBUG dma-debug/x86: register pci bus for dma-debug leak detection dma-debug: add a check dma memory leaks dma-debug: add checks for kernel text and rodata dma-debug: print stacktrace of mapping path on unmap error dma-debug: Documentation update dma-debug: x86 architecture bindings dma-debug: add function to dump dma mappings dma-debug: add checks for sync_single_sg_* dma-debug: add checks for sync_single_range_* dma-debug: add checks for sync_single_* dma-debug: add checking for [alloc|free]_coherent dma-debug: add add checking for map/unmap_sg dma-debug: add checking for map/unmap_page/single dma-debug: add core checking functions dma-debug: add debugfs interface dma-debug: add kernel command line parameters dma-debug: add initialization code ... Fix trivial conflicts due to whitespace changes in arch/x86/kernel/pci-nommu.c
2009-03-30Merge commit 'origin/master' into nextBenjamin Herrenschmidt
Manual merge of: arch/powerpc/include/asm/elf.h drivers/i2c/busses/i2c-mpc.c
2009-03-28Merge branch 'linus' into core/printkIngo Molnar
2009-03-28Merge branch 'linus' into core/iommuIngo Molnar
Conflicts: arch/x86/Kconfig
2009-03-28Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (422 commits) [ARM] 5435/1: fix compile warning in sanity_check_meminfo() [ARM] 5434/1: ARM: OMAP: Fix mailbox compile for 24xx [ARM] pxa: fix the bad assumption that PCMCIA sockets always start with 0 [ARM] pxa: fix Colibri PXA300 and PXA320 LCD backlight pins imxfb: Fix TFT mode i.MX21/27: remove ifdef CONFIG_FB_IMX imxfb: add clock support mxc: add arch_reset() function clkdev: add possibility to get a clock based on the device name i.MX1: remove fb support from mach-imx [ARM] pxa: build arch/arm/plat-pxa/mfp.c only when PXA3xx or ARCH_MMP defined Gemini: Add support for Teltonika RUT100 Gemini: gpiolib based GPIO support v2 MAINTAINERS: add myself as Gemini architecture maintainer ARM: Add Gemini architecture v3 [ARM] OMAP: Fix compile for omap2_init_common_hw() MAINTAINERS: Add myself as Faraday ARM core variant maintainer ARM: Add support for FA526 v2 [ARM] acorn,ebsa110,footbridge,integrator,sa1100: Convert asm/io.h to linux/io.h [ARM] collie: fix two minor formatting nits ...
2009-03-28Merge branch 'origin' into develRussell King
Conflicts: sound/soc/pxa/pxa2xx-i2s.c
2009-03-28Merge branch 'linus' into percpu-cpumask-x86-for-linus-2Ingo Molnar
Conflicts: arch/sparc/kernel/time_64.c drivers/gpu/drm/drm_proc.c Manual merge to resolve build warning due to phys_addr_t type change on x86: drivers/gpu/drm/drm_info.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-27Merge branch 'core/percpu' into percpu-cpumask-x86-for-linus-2Ingo Molnar
Conflicts: arch/parisc/kernel/irq.c arch/x86/include/asm/fixmap_64.h arch/x86/include/asm/setup.h kernel/irq/handle.c Semantic merge: arch/x86/include/asm/fixmap.h Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-26Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-next-2.6
2009-03-26Merge branch 'sched-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (46 commits) sched: Add comments to find_busiest_group() function sched: Refactor the power savings balance code sched: Optimize the !power_savings_balance during fbg() sched: Create a helper function to calculate imbalance sched: Create helper to calculate small_imbalance in fbg() sched: Create a helper function to calculate sched_domain stats for fbg() sched: Define structure to store the sched_domain statistics for fbg() sched: Create a helper function to calculate sched_group stats for fbg() sched: Define structure to store the sched_group statistics for fbg() sched: Fix indentations in find_busiest_group() using gotos sched: Simple helper functions for find_busiest_group() sched: remove unused fields from struct rq sched: jiffies not printed per CPU sched: small optimisation of can_migrate_task() sched: fix typos in documentation sched: add avg_overlap decay x86, sched_clock(): mark variables read-mostly sched: optimize ttwu vs group scheduling sched: TIF_NEED_RESCHED -> need_reshed() cleanup sched: don't rebalance if attached on NULL domain ...
2009-03-26Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: drivers/net/wimax/i2400m/usb-notif.c
2009-03-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (61 commits) Dynamic debug: fix pr_fmt() build error Dynamic debug: allow simple quoting of words dynamic debug: update docs dynamic debug: combine dprintk and dynamic printk sysfs: fix some bin_vm_ops errors kobject: don't block for each kobject_uevent sysfs: only allow one scheduled removal callback per kobj Driver core: Fix device_move() vs. dpm list ordering, v2 Driver core: some cleanup on drivers/base/sys.c Driver core: implement uevent suppress in kobject vcs: hook sysfs devices into object lifetime instead of "binding" driver core: fix passing platform_data driver core: move platform_data into platform_device sysfs: don't block indefinitely for unmapped files. driver core: move knode_bus into private structure driver core: move knode_driver into private structure driver core: move klist_children into private structure driver core: create a private portion of struct device driver core: remove polling for driver_probe_done(v5) sysfs: reference sysfs_dirent from sysfs inodes ... Fixed conflicts in drivers/sh/maple/maple.c manually
2009-03-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (29 commits) crypto: sha512-s390 - Add missing block size hwrng: timeriomem - Breaks an allyesconfig build on s390: nlattr: Fix build error with NET off crypto: testmgr - add zlib test crypto: zlib - New zlib crypto module, using pcomp crypto: testmgr - Add support for the pcomp interface crypto: compress - Add pcomp interface netlink: Move netlink attribute parsing support to lib crypto: Fix dead links hwrng: timeriomem - New driver crypto: chainiv - Use kcrypto_wq instead of keventd_wq crypto: cryptd - Per-CPU thread implementation based on kcrypto_wq crypto: api - Use dedicated workqueue for crypto subsystem crypto: testmgr - Test skciphers with no IVs crypto: aead - Avoid infinite loop when nivaead fails selftest crypto: skcipher - Avoid infinite loop when cipher fails selftest crypto: api - Fix crypto_alloc_tfm/create_create_tfm return convention crypto: api - crypto_alg_mod_lookup either tested or untested crypto: amcc - Add crypt4xx driver crypto: ansi_cprng - Add maintainer ...
2009-03-25Merge branch 'for-next' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 into devel
2009-03-24Dynamic debug: allow simple quoting of wordsGreg Banks
Allow simple quoting of words in the dynamic debug control language. This allows more natural specification when using the control language to match against printk formats, e.g #echo -n 'format "Setting node for non-present cpu" +p' > /mnt/debugfs/dynamic_debug/control instead of #echo -n 'format Setting\040node\040for\040non-present\040cpu +p' > /mnt/debugfs/dynamic_debug/control Adjust the dynamic debug documention to describe that and provide a new example. Adjust the existing examples in the documentation to reflect the current whitespace escaping behaviour when reading the control file. Fix some minor documentation trailing whitespace. Signed-off-by: Greg Banks <gnb@melbourne.sgi.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24dynamic debug: update docsJason Baron
updates the documentation for 'dynamic debug' feature. Signed-off-by: Greg Banks <gnb@sgi.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24dynamic debug: combine dprintk and dynamic printkJason Baron
This patch combines Greg Bank's dprintk() work with the existing dynamic printk patchset, we are now calling it 'dynamic debug'. The new feature of this patchset is a richer /debugfs control file interface, (an example output from my system is at the bottom), which allows fined grained control over the the debug output. The output can be controlled by function, file, module, format string, and line number. for example, enabled all debug messages in module 'nf_conntrack': echo -n 'module nf_conntrack +p' > /mnt/debugfs/dynamic_debug/control to disable them: echo -n 'module nf_conntrack -p' > /mnt/debugfs/dynamic_debug/control A further explanation can be found in the documentation patch. Signed-off-by: Greg Banks <gnb@sgi.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24kobject: don't block for each kobject_ueventArjan van de Ven
Right now, the kobject_uevent code blocks for each uevent that's being generated, due to using (for hystoric reasons) UHM_WAIT_EXEC as flag to call_usermode_helper(). Specifically, the effect is that each uevent that is being sent causes the code to wake up keventd, then block until keventd has processed the work. Needless to say, this happens many times during the system boot. This patches changes that to UHN_NO_WAIT (brilliant name for a constant btw) so that we only schedule the work to fire the uevent message, but do not wait for keventd to process the work. This removes one of the bottlenecks during boot; each one of them is only a small effect, but the sum of them does add up. [Note, distros that need this are broken, they should be setting CONFIG_UEVENT_HELPER_PATH to "", that way this code path will never be excuted at all -- gregkh] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24Driver core: implement uevent suppress in kobjectMing Lei
This patch implements uevent suppress in kobject and removes it from struct device, based on the following ideas: 1,Uevent sending should be one attribute of kobject, so suppressing it in kobject layer is more natural than in device layer. By this way, we can do it for other objects embedded with kobject. 2,It may save several bytes for each instance of struct device.(On my omap3(32bit ARM) based box, can save 8bytes per device object) This patch also introduces dev_set|get_uevent_suppress() helpers to set and query uevent_suppress attribute in case to help kobject as private part of struct device in future. [This version is against the latest driver-core patch set of Greg,please ignore the last version.] Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24driver core: get rid of struct device's bus_id string arrayKay Sievers
Now that all users of bus_id is gone, we can remove it from struct device. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24dma-debug: make memory range checks more consistentJoerg Roedel
Impact: extend on-kernel-stack DMA debug checks to all !highmem pages We only checked dma_map_single() - extend it to dma_map_page() and dma_map_sg() as well. Also, fix dma_map_single() corner case bug: make sure we dont stack-check highmem (not mapped) pages. Reported-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Cc: iommu@lists.linux-foundation.org LKML-Reference: <1237818908-26516-1-git-send-email-joerg.roedel@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-24Merge commit 'origin/master' into nextBenjamin Herrenschmidt
2009-03-19dma-debug: warn of unmapping an invalid dma addressFUJITA Tomonori
Impact: extend DMA-debug checks Calling dma_unmap families against an invalid dma address should be a bug. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Joerg Roedel <joerg.roedel@amd.com> LKML-Reference: <20090319103743N.fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-18Merge branch 'dma-api/debug' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/joro/linux-2.6-iommu into core/iommu
2009-03-18Merge branch 'linus' into core/iommuIngo Molnar
2009-03-18Merge branches 'sched/cleanups' and 'linus' into sched/coreIngo Molnar
2009-03-17Merge branch 'linus' into core/printkIngo Molnar
2009-03-17dma-debug: add a check dma memory leaksJoerg Roedel
Impact: allow architectures to monitor busses for dma mem leakage This patch adds checking code to detect if a device has pending DMA operations when it is about to be unbound from its device driver. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-03-17dma-debug: add checks for kernel text and rodataJoerg Roedel
Impact: get notified if a device dma maps illegal areas This patch adds a check to print a warning message when a device driver tries to map a memory area from the kernel text segment or rodata. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-03-17dma-debug: print stacktrace of mapping path on unmap errorDavid Woodhouse
Impact: saves stacktrace of a dma mapping and prints it if there is an error Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-03-17dma-debug: add function to dump dma mappingsDavid Woodhouse
This adds a function to dump the DMA mappings that the debugging code is aware of -- either for a single device, or for _all_ devices. This can be useful for debugging -- sticking a call to it in the DMA page fault handler, for example, to see if the faulting address _should_ be mapped or not, and hence work out whether it's IOMMU bugs we're seeing, or driver bugs. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-03-17debugobjects: delay free of internal objectsThomas Gleixner
Impact: avoid recursive kfree calls, less slab activity on heavy load debugobjects checks on kfree whether tracked objects are freed. When a tracked object is freed debugobjects frees the internal reference object as well. The debug object slab cache is marked to not recurse into debugobjects when a slab objects is freed, but the recursive call can be problematic versus locking in the memory allocator. Defer the freeing of debug slab objects via schedule_work. The reasons not to use RCU are: 1) rcu makes the data structure larger 2) there is no real need for rcu as nothing references the obj after we freed it 3) under heavy load it is easier to reuse the to be freed objects instead of allocating new objects from the slab. This lowered the slab activity significantly in a heavy load networking test where lots of timers are created/destroyed. The workqueue based delayed free allows us just to put the to be freed objects back into the object pool and reuse them right away. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> LKML-Reference: <200903162049.58058.nickpiggin@yahoo.com.au>
2009-03-17debugobjects: replace static objects when slab cache becomes availableThomas Gleixner
Impact: refactor/consolidate object management, prepare for delayed free debugobjects allocates static reference objects to track objects which are initialized or activated before the slab cache becomes available. These static reference objects have to be handled seperately in free_object(). The handling of these objects is in the way of implementing a delayed free functionality. The delayed free is required to avoid callbacks into the mm code from debug_check_no_obj_freed(). Replace the static object references with dynamic ones after the slab cache has been initialized. The static objects are now marked initdata. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> LKML-Reference: <200903162049.58058.nickpiggin@yahoo.com.au>
2009-03-14vsprintf: unify the format decoding layer for its 3 users, cleanupVegard Nossum
Impact: cleanup Rename FORMAT_TYPE_WITDH to => FORMAT_TYPE_WIDTH Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-14fix regression from "vsprintf: unify the format decoding layer for its 3 users"Vegard Nossum
Jeremy Fitzhardinge reported: > Change fef20d9c1380f04ba9492d6463148db07b413708, "vsprintf: > unify the format decoding layer for its 3 users", causes a > regression in xenbus which results in no devices getting > attached to a new domain. %.*s is broken - fix it. Reported-by: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-13Merge branch 'for-rmk' of git://git.pengutronix.de/git/imx/linux-2.6 into develRussell King
Conflicts: arch/arm/mach-at91/gpio.c
