path: root/lib
2009-12-22lib/string.c: fix kernel-doc warningsRandy Dunlap
Fix kernel-doc warnings (@arg name) in string.c::skip_spaces(). Warning(lib/string.c:347): No description found for parameter 'str' Warning(lib/string.c:347): Excess function parameter 's' description in 'skip_spaces' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-19Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, irq: Allow 0xff for /proc/irq/[n]/smp_affinity on an 8-cpu system Makefile: Unexport LC_ALL instead of clearing it x86: Fix objdump version check in arch/x86/tools/chkobjdump.awk x86: Reenable TSC sync check at boot, even with NONSTOP_TSC x86: Don't use POSIX character classes in gen-insn-attr-x86.awk Makefile: set LC_CTYPE, LC_COLLATE, LC_NUMERIC to C x86: Increase MAX_EARLY_RES; insufficient on 32-bit NUMA x86: Fix checking of SRAT when node 0 ram is not from 0 x86, cpuid: Add "volatile" to asm in native_cpuid() x86, msr: msrs_alloc/free for CONFIG_SMP=n x86, amd: Get multi-node CPU info from NodeId MSR instead of PCI config space x86: Add IA32_TSC_AUX MSR and use it x86, msr/cpuid: Register enough minors for the MSR and CPUID drivers initramfs: add missing decompressor error check bzip2: Add missing checks for malloc returning NULL bzip2/lzma/gzip: pre-boot malloc doesn't return NULL on failure
2009-12-17Merge branch 'kmemleak' of git://linux-arm.org/linux-2.6Linus Torvalds
* 'kmemleak' of git://linux-arm.org/linux-2.6: kmemleak: fix kconfig for crc32 build error kmemleak: Reduce the false positives by checking for modified objects kmemleak: Show the age of an unreferenced object kmemleak: Release the object lock before calling put_object() kmemleak: Scan the _ftrace_events section in modules kmemleak: Simplify the kmemleak_scan_area() function prototype kmemleak: Do not use off-slab management with SLAB_NOLEAKTRACE
2009-12-17lib/vsprintf.c: document more vsnprintf extensionsUwe Kleine-König
These were added in 9ac6e44 (lib/vsprintf.c: add %pU to print UUID/GUIDs) c7dabef (vsprintf: use %pR, %pr instead of %pRt, %pRf) 8a27f7c (lib/vsprintf.c: Add "%pI6c" - print pointer as compressed ipv6 address) 4aa9960 (printk: add %I4, %I6, %i4, %i6 format specifiers) dd45c9c (printk: add %pM format specifier for MAC addresses) but only added comments to pointer() not vsnprintf() that is refered to by printk's comments. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Harvey Harrison <harvey.harrison@gmail.com> Cc: David S. Miller <davem@davemloft.net> Cc: Joe Perches <joe@perches.com> Cc: Jens Rosenboom <jens@mcbone.net> Cc: David S. Miller <davem@davemloft.net> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16Merge branch 'next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next' of git://git.secretlab.ca/git/linux-2.6: (23 commits) powerpc: fix up for mmu_mapin_ram api change powerpc: wii: allow ioremap within the memory hole powerpc: allow ioremap within reserved memory regions wii: use both mem1 and mem2 as ram wii: bootwrapper: add fixup to calc useable mem2 powerpc: gamecube/wii: early debugging using usbgecko powerpc: reserve fixmap entries for early debug powerpc: wii: default config powerpc: wii: platform support powerpc: wii: hollywood interrupt controller support powerpc: broadway processor support powerpc: wii: bootwrapper bits powerpc: wii: device tree powerpc: gamecube: default config powerpc: gamecube: platform support powerpc: gamecube/wii: flipper interrupt controller support powerpc: gamecube/wii: udbg support for usbgecko powerpc: gamecube/wii: do not include PCI support powerpc: gamecube/wii: declare as non-coherent platforms powerpc: gamecube/wii: introduce GAMECUBE_COMMON ... Fix up conflicts in arch/powerpc/mm/fsl_booke_mmu.c. Hopefully even close to correctly.
2009-12-16genalloc: use bitmap_find_next_zero_areaAkinobu Mita
Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16iommu-helper: use bitmap libraryAkinobu Mita
Use bitmap library and kill some unused iommu helper functions. 1. s/iommu_area_free/bitmap_clear/ 2. s/iommu_area_reserve/bitmap_set/ 3. Use bitmap_find_next_zero_area instead of find_next_zero_area This cannot be simple substitution because find_next_zero_area doesn't check the last bit of the limit in bitmap 4. Remove iommu_area_free, iommu_area_reserve, and find_next_zero_area Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16bitmap: introduce bitmap_set, bitmap_clear, bitmap_find_next_zero_areaAkinobu Mita
This introduces new bitmap functions: bitmap_set: Set specified bit area bitmap_clear: Clear specified bit area bitmap_find_next_zero_area: Find free bit area These are mostly stolen from iommu helper. The differences are: - Use find_next_bit instead of doing test_bit for each bit - Rewrite bitmap_set and bitmap_clear Instead of setting or clearing for each bit. - Check the last bit of the limit iommu-helper doesn't want to find such area - The return value if there is no zero area find_next_zero_area in iommu helper: returns -1 bitmap_find_next_zero_area: return >= bitmap size Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Lothar Wassmann <LW@KARO-electronics.de> Cc: Roland Dreier <rolandd@cisco.com> Cc: Yevgeny Petrilin <yevgenyp@mellanox.co.il> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16dma-mapping: fix off-by-one error in dma_capable()Jan Beulich
dma_mask is, when interpreted as address, the last valid byte, and hence comparison msut also be done using the last valid of the buffer in question. Also fix the open-coded instances in lib/swiotlb.c. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Becky Bruce <beckyb@kernel.crashing.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15bzip2: Add missing checks for malloc returning NULLPhillip Lougher
Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk> LKML-Reference: <4b26b1ef.ln20bM9Mn4gzB21L%phillip@lougher.demon.co.uk> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-12-15Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (26 commits) clockevents: Convert to raw_spinlock clockevents: Make tick_device_lock static debugobjects: Convert to raw_spinlocks perf_event: Convert to raw_spinlock hrtimers: Convert to raw_spinlocks genirq: Convert irq_desc.lock to raw_spinlock smp: Convert smplocks to raw_spinlocks rtmutes: Convert rtmutex.lock to raw_spinlock sched: Convert pi_lock to raw_spinlock sched: Convert cpupri lock to raw_spinlock sched: Convert rt_runtime_lock to raw_spinlock sched: Convert rq->lock to raw_spinlock plist: Make plist debugging raw_spinlock aware bkl: Fixup core_lock fallout locking: Cleanup the name space completely locking: Further name space cleanups alpha: Fix fallout from locking changes locking: Implement new raw_spinlock locking: Convert raw_rwlock functions to arch_rwlock locking: Convert raw_rwlock to arch_rwlock ...
2009-12-15crc32: minor optimizations and cleanupJoakim Tjernlund
Move common crc body to new function crc32_body() cleaup and micro optimize crc32_body for speed and less size. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15Subject: Re: [PATCH] strstrip incorrectly marked __must_checkKOSAKI Motohiro
Recently, We marked strstrip() as must_check. because it was frequently misused and it should be checked. However, we found one exception. scsi/ipr.c intentionally ignore return value of strstrip. Because it wishes to keep the whitespace at the beginning. Thus we need to keep with and without checked whitespace trim function. This patch adds a new strim() and changes ipr.c to use it. [akpm@linux-foundation.org: coding-style fixes] Suggested-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15lib/vsprintf.c: add %pU to print UUID/GUIDsJoe Perches
UUID/GUIDs are somewhat common in kernel source. Standardize the printed style of UUID/GUIDs by using another extension to %p. %pUb: 01020304-0506-0708-090a-0b0c0d0e0f10 %pUB: 01020304-0506-0708-090A-0B0C0D0E0F10 (upper case) %pUl: 04030201-0605-0807-090a-0b0c0d0e0f10 %pUL: 04030201-0605-0807-090A-0B0C0D0E0F10 (upper case) %pU defaults to %pUb Signed-off-by: Joe Perches <joe@perches.com> Cc: Jeff Garzik <jgarzik@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Alex Elder <aelder@sgi.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Artem Bityutskiy <dedekind@infradead.org> Cc: Adrian Hunter <adrian.hunter@nokia.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15parser: remove unnecessary strlen()André Goddard Rosa
No functional change. Cache strlen() result to avoid recalculating it up to 3 times on the worst case. Reduces code size a little by 32 bytes: text data bss dec hex filename 1385 0 0 1385 569 lib/parser.o-BEFORE 1353 0 0 1353 549 lib/parser.o-AFTER Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15tree-wide: convert open calls to remove spaces to skip_spaces() lib functionAndré Goddard Rosa
Makes use of skip_spaces() defined in lib/string.c for removing leading spaces from strings all over the tree. It decreases lib.a code size by 47 bytes and reuses the function tree-wide: text data bss dec hex filename 64688 584 592 65864 10148 (TOTALS-BEFORE) 64641 584 592 65817 10119 (TOTALS-AFTER) Also, while at it, if we see (*str && isspace(*str)), we can be sure to remove the first condition (*str) as the second one (isspace(*str)) also evaluates to 0 whenever *str == 0, making it redundant. In other words, "a char equals zero is never a space". Julia Lawall tried the semantic patch (http://coccinelle.lip6.fr) below, and found occurrences of this pattern on 3 more files: drivers/leds/led-class.c drivers/leds/ledtrig-timer.c drivers/video/output.c @@ expression str; @@ ( // ignore skip_spaces cases while (*str && isspace(*str)) { \(str++;\|++str;\) } | - *str && isspace(*str) ) Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Cc: Julia Lawall <julia@diku.dk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Neil Brown <neilb@suse.de> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: David Howells <dhowells@redhat.com> Cc: <linux-ext4@vger.kernel.org> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: Patrick McHardy <kaber@trash.net> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15string: on strstrip(), first remove leading spaces before running over strAndré Goddard Rosa
... so that strlen() iterates over a smaller string comprising of the remaining characters only. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15string: factorize skip_spaces and export it to be generally availableAndré Goddard Rosa
On the following sentence: while (*s && isspace(*s)) s++; If *s == 0, isspace() evaluates to ((_ctype[*s] & 0x20) != 0), which evaluates to ((0x08 & 0x20) != 0) which equals to 0 as well. If *s == 1, we depend on isspace() result anyway. In other words, "a char equals zero is never a space", so remove this check. Also, *s != 0 is most common case (non-null string). Fixed const return as noticed by Jan Engelhardt and James Bottomley. Fixed unnecessary extra cast on strstrip() as noticed by Jan Engelhardt. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15ctype: constify read-only _ctype stringAndré Goddard Rosa
While at it, use tabs to indent the comments. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15vsprintf: reuse almost identical simple_strtoulX() functionsAndré Goddard Rosa
The difference between simple_strtoul() and simple_strtoull() is just the size of the variable used to keep track of the sum of characters converted to numbers: unsigned long simple_strtoul() {...} unsigned long long simple_strtoull(){...} Both are same size on my Core 2/gcc 4.4.1. Overflow condition is not checked on both functions, so an extremely large string can break these functions so that they don't even notice it. As we do not care for overflowing on these functions, always keep the sum using the larger variable around (unsigned long long) on simple_strtoull() and cast it to (unsigned long) on simple_strtoul(), which then becomes just a wrapper around simple_strtoull(). Code size decreases by 304 bytes: text data bss dec hex filename 15534 0 8 15542 3cb6 vsprintf.o (ex lib/lib.a-BEFORE) 15230 0 8 15238 3b86 vsprintf.o (ex lib/lib.a-AFTER) Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15vsprintf: factor out skip_space code in a separate functionAndré Goddard Rosa
When converting more caller sites, the inline decision will be left up to gcc. It decreases code size: text data bss dec hex filename 15710 0 8 15718 3d66 vsprintf.o (ex lib/lib.a-BEFORE) 15534 0 8 15542 3cb6 vsprintf.o (ex lib/lib.a-AFTER) Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15vsprintf: move local vars to block local vars and remove unneeded onesAndré Goddard Rosa
Cleanup by moving variables closer to the scope where they're used in fact. Also, remove unneeded ones. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15vsprintf: reduce code size by avoiding extra checkAndré Goddard Rosa
No functional change, just refactor the code so that it avoid checking "if (hi)" two times in a sequence, taking advantage of previous check made. It also reduces code size: text data bss dec hex filename 15726 0 8 15734 3d76 vsprintf.o (ex lib/lib.a-BEFORE) 15710 0 8 15718 3d66 vsprintf.o (ex lib/lib.a-AFTER) Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15vsprintf: use TOLOWER whenever possibleAndré Goddard Rosa
It decreases code size as well: text data bss dec hex filename 15758 0 8 15766 3d96 vsprintf.o (ex lib/lib.a-BEFORE) 15726 0 8 15734 3d76 vsprintf.o (ex lib/lib.a-TOLOWER) Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15vsprintf: give it some care to please checkpatch.plAndré Goddard Rosa
Most relevant complaints were addressed. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15vsprintf: pre-calculate final string length for later useAndré Goddard Rosa
2009-12-15vsprintf: factorize "(null)" stringAndré Goddard Rosa
This patchset reduces lib/lib.a code size by 482 bytes on my Core 2 with gcc 4.4.1 even considering that it exports a newly defined function skip_spaces() to drivers: text data bss dec hex filename 64867 840 592 66299 102fb (TOTALS-lib.a-BEFORE) 64641 584 592 65817 10119 (TOTALS-lib.a-AFTER) and implements some code tidy up. Besides reducing lib.a size, it converts many in-tree drivers to use the newly defined function, which makes another small reduction on kernel size overall when those drivers are used. This patch: Change "<NULL>" to "(null)", unifying 3 equal strings. glibc also uses "(null)" for the same purpose. It decreases code size by 7 bytes: text data bss dec hex filename 15765 0 8 15773 3d9d vsprintf.o (ex lib/lib.a-BEFORE) 15758 0 8 15766 3d96 vsprintf.o (ex lib/lib.a-AFTER) Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15Make DEBUG_BUGVERBOSE default to yAlexey Dobriyan
It's easy to lose useful DEBUG_BUGVERBOSE by switching EMBEDDED left and right. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15rwsem: fix rwsem_is_locked() bugsAmerigo Wang
rwsem_is_locked() tests ->activity without locks, so we should always keep ->activity consistent. However, the code in __rwsem_do_wake() breaks this rule, it updates ->activity after _all_ readers waken up, this may give some reader a wrong ->activity value, thus cause rwsem_is_locked() behaves wrong. Quote from Andrew: " - we have one or more processes sleeping in down_read(), waiting for access. - we wake one or more processes up without altering ->activity - they start to run and they do rwsem_is_locked(). This incorrectly returns "false", because the waker process is still crunching away in __rwsem_do_wake(). - the waker now alters ->activity, but it was too late. " So we need get a spinlock to protect this. And rwsem_is_locked() should not block, thus we use spin_trylock_irqsave(). [akpm@linux-foundation.org: simplify code] Reported-by: Brian Behlendorf <behlendorf1@llnl.gov> Cc: Ben Woodard <bwoodard@llnl.gov> Cc: David Howells <dhowells@redhat.com> Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15rwsem-spinlock: remove useless function exportsAmerigo Wang
These functions need not to be exported, since no drivers should use them. __init_rwsem() is an exception, because init_rwsem(), which is a macro, is used. Signed-off-by: WANG Cong <amwang@redhat.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-14debugobjects: Convert to raw_spinlocksThomas Gleixner
Convert locks which cannot be sleeping locks in preempt-rt to raw_spinlocks. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-12-14plist: Make plist debugging raw_spinlock awareThomas Gleixner
plists are used with spinlocks and raw_spinlocks. Change the plist debugging to handle both types. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-12-14bkl: Fixup core_lock falloutThomas Gleixner
kernel_lock.c emits a warning because a raw spinlock function is used with a spinlock. Convert BKL to raw_spinlock. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-12-14locking: Further name space cleanupsThomas Gleixner
The name space hierarchy for the internal lock functions is now a bit backwards. raw_spin* functions map to _spin* which use __spin*, while we would like to have _raw_spin* and __raw_spin*. _raw_spin* is already used by lock debugging, so rename those funtions to do_raw_spin* to free up the _raw_spin* name space. No functional change. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-12-14locking: Implement new raw_spinlockThomas Gleixner
Now that the raw_spin name space is freed up, we can implement raw_spinlock and the related functions which are used to annotate the locks which are not converted to sleeping spinlocks in preempt-rt. A side effect is that only such locks can be used with the low level lock fsunctions which circumvent lockdep. For !rt spin_* functions are mapped to the raw_spin* implementations. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-12-14locking: Convert raw_rwlock functions to arch_rwlockThomas Gleixner
Name space cleanup for rwlock functions. No functional change. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: linux-arch@vger.kernel.org
2009-12-14locking: Convert raw_rwlock to arch_rwlockThomas Gleixner
Not strictly necessary for -rt as -rt does not have non sleeping rwlocks, but it's odd to not have a consistent naming convention. No functional change. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: linux-arch@vger.kernel.org
2009-12-14locking: Convert __raw_spin* functions to arch_spin*Thomas Gleixner
Name space cleanup. No functional change. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: linux-arch@vger.kernel.org
2009-12-14locking: Rename __RAW_SPIN_LOCK_UNLOCKED to __ARCH_SPIN_LOCK_UNLOCKEDThomas Gleixner
Further name space cleanup. No functional change Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: linux-arch@vger.kernel.org
2009-12-14locking: Convert raw_spinlock to arch_spinlockThomas Gleixner
The raw_spin* namespace was taken by lockdep for the architecture specific implementations. raw_spin_* would be the ideal name space for the spinlocks which are not converted to sleeping locks in preempt-rt. Linus suggested to convert the raw_ to arch_ locks and cleanup the name space instead of using an artifical name like core_spin, atomic_spin or whatever No functional change. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: linux-arch@vger.kernel.org
2009-12-12powerpc: allow ioremap within reserved memory regionsAlbert Herranz
Add a flag to let a platform ioremap memory regions marked as reserved. This flag will be used later by the Nintendo Wii support code to allow ioremapping the I/O region sitting between MEM1 and MEM2 and marked as reserved RAM in the patch "wii: use both mem1 and mem2 as ram". This will no longer be needed when proper discontig memory support for 32-bit PowerPC is added to the kernel. Signed-off-by: Albert Herranz <albert_herranz@yahoo.es> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2009-12-12[BKL] add 'might_sleep()' to the outermost lock takerLinus Torvalds
As shown by the previous patch (6698e3472: "tty: Fix BKL taken under a spinlock bug introduced in the BKL split") the BKL removal is prone to some subtle issues, where removing the BKL in one place may in fact make a previously nested BKL call the new outer call, and then prone to nasty deadlocks with other spinlocks. In general, we should never take the BKL while we're holding a spinlock, so let's just add a "might_sleep()" to it (even though the BKL doesn't technically sleep - at least not yet), and we'll get nice warnings the next time this kind of problem happens during BKL removal. Acked-and-Tested-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-genericLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: asm-generic: add sys_recvmmsg to unistd.h asm-generic: add sys_accept4 to unistd.h asm-generic/gpio.h: add some forward decls of the device struct asm-generic: Fix typo in asm-generic/unistd.h. lib/checksum: fix one more thinko lib/checksum.c: make do_csum optional lib/checksum.c: use 32-bit arithmetic consistently
2009-12-11Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (109 commits) PCI: fix coding style issue in pci_save_state() PCI: add pci_request_acs PCI: fix BUG_ON triggered by logical PCIe root port removal PCI: remove ifdefed pci_cleanup_aer_correct_error_status PCI: unconditionally clear AER uncorr status register during cleanup x86/PCI: claim SR-IOV BARs in pcibios_allocate_resource PCI: portdrv: remove redundant definitions PCI: portdrv: remove unnecessary struct pcie_port_data PCI: portdrv: minor cleanup for pcie_port_device_register PCI: portdrv: add missing irq cleanup PCI: portdrv: enable device before irq initialization PCI: portdrv: cleanup service irqs initialization PCI: portdrv: check capabilities first PCI: portdrv: move PME capability check PCI: portdrv: remove redundant pcie type calculation PCI: portdrv: cleanup pcie_device registration PCI: portdrv: remove redundant pcie_port_device_probe PCI: Always set prefetchable base/limit upper32 registers PCI: read-modify-write the pcie device control register when initiating pcie flr PCI: show dma_mask bits in /sys ... Fixed up conflicts in: arch/x86/kernel/amd_iommu_init.c drivers/pci/dmar.c drivers/pci/hotplug/acpiphp_glue.c
2009-12-10Merge branch 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: Add debugobjects support
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-08Merge branch 'for-2.6.33' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.33' of git://git.kernel.dk/linux-2.6-block: (113 commits) cfq-iosched: Do not access cfqq after freeing it block: include linux/err.h to use ERR_PTR cfq-iosched: use call_rcu() instead of doing grace period stall on queue exit blkio: Allow CFQ group IO scheduling even when CFQ is a module blkio: Implement dynamic io controlling policy registration blkio: Export some symbols from blkio as its user CFQ can be a module block: Fix io_context leak after failure of clone with CLONE_IO block: Fix io_context leak after clone with CLONE_IO cfq-iosched: make nonrot check logic consistent io controller: quick fix for blk-cgroup and modular CFQ cfq-iosched: move IO controller declerations to a header file cfq-iosched: fix compile problem with !CONFIG_CGROUP blkio: Documentation blkio: Wait on sync-noidle queue even if rq_noidle = 1 blkio: Implement group_isolation tunable blkio: Determine async workload length based on total number of queues blkio: Wait for cfq queue to get backlogged if group is empty blkio: Propagate cgroup weight updation to cfq groups blkio: Drop the reference to queue once the task changes cgroup blkio: Provide some isolation between groups ...
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl-2.6: (43 commits) security/tomoyo: Remove now unnecessary handling of security_sysctl. security/tomoyo: Add a special case to handle accesses through the internal proc mount. sysctl: Drop & in front of every proc_handler. sysctl: Remove CTL_NONE and CTL_UNNUMBERED sysctl: kill dead ctl_handler definitions. sysctl: Remove the last of the generic binary sysctl support sysctl net: Remove unused binary sysctl code sysctl security/tomoyo: Don't look at ctl_name sysctl arm: Remove binary sysctl support sysctl x86: Remove dead binary sysctl support sysctl sh: Remove dead binary sysctl support sysctl powerpc: Remove dead binary sysctl support sysctl ia64: Remove dead binary sysctl support sysctl s390: Remove dead sysctl binary support sysctl frv: Remove dead binary sysctl support sysctl mips/lasat: Remove dead binary sysctl support sysctl drivers: Remove dead binary sysctl support sysctl crypto: Remove dead binary sysctl support sysctl security/keys: Remove dead binary sysctl support sysctl kernel: Remove binary sysctl logic ...
2009-12-07Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: kernel/irq/chip.c
2009-12-05Merge branch 'tracing-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (40 commits) tracing: Separate raw syscall from syscall tracer ring-buffer-benchmark: Add parameters to set produce/consumer priorities tracing, function tracer: Clean up strstrip() usage ring-buffer benchmark: Run producer/consumer threads at nice +19 tracing: Remove the stale include/trace/power.h tracing: Only print objcopy version warning once from recordmcount tracing: Prevent build warning: 'ftrace_graph_buf' defined but not used ring-buffer: Move access to commit_page up into function used tracing: do not disable interrupts for trace_clock_local ring-buffer: Add multiple iterations between benchmark timestamps kprobes: Sanitize struct kretprobe_instance allocations tracing: Fix to use __always_unused attribute compiler: Introduce __always_unused tracing: Exit with error if a weak function is used in recordmcount.pl tracing: Move conditional into update_funcs() in recordmcount.pl tracing: Add regex for weak functions in recordmcount.pl tracing: Move mcount section search to front of loop in recordmcount.pl tracing: Fix objcopy revision check in recordmcount.pl tracing: Check absolute path of input file in recordmcount.pl tracing: Correct the check for number of arguments in recordmcount.pl ...
