path: root/lib
2016-01-23Merge tag 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma Pull rdma updates from Doug Ledford: "Initial roundup of 4.5 merge window patches - Remove usage of ib_query_device and instead store attributes in ib_device struct - Move iopoll out of block and into lib, rename to irqpoll, and use in several places in the rdma stack as our new completion queue polling library mechanism. Update the other block drivers that already used iopoll to use the new mechanism too. - Replace the per-entry GID table locks with a single GID table lock - IPoIB multicast cleanup - Cleanups to the IB MR facility - Add support for 64bit extended IB counters - Fix for netlink oops while parsing RDMA nl messages - RoCEv2 support for the core IB code - mlx4 RoCEv2 support - mlx5 RoCEv2 support - Cross Channel support for mlx5 - Timestamp support for mlx5 - Atomic support for mlx5 - Raw QP support for mlx5 - MAINTAINERS update for mlx4/mlx5 - Misc ocrdma, qib, nes, usNIC, cxgb3, cxgb4, mlx4, mlx5 updates - Add support for remote invalidate to the iSER driver (pushed through the RDMA tree due to dependencies, acknowledged by nab) - Update to NFSoRDMA (pushed through the RDMA tree due to dependencies, acknowledged by Bruce)" * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (169 commits) IB/mlx5: Unify CQ create flags check IB/mlx5: Expose Raw Packet QP to user space consumers {IB, net}/mlx5: Move the modify QP operation table to mlx5_ib IB/mlx5: Support setting Ethernet priority for Raw Packet QPs IB/mlx5: Add Raw Packet QP query functionality IB/mlx5: Add create and destroy functionality for Raw Packet QP IB/mlx5: Refactor mlx5_ib_qp to accommodate other QP types IB/mlx5: Allocate a Transport Domain for each ucontext net/mlx5_core: Warn on unsupported events of QP/RQ/SQ net/mlx5_core: Add RQ and SQ event handling net/mlx5_core: Export transport objects IB/mlx5: Expose CQE version to user-space IB/mlx5: Add CQE version 1 support to user QPs and SRQs IB/mlx5: Fix data validation in mlx5_ib_alloc_ucontext IB/sa: Fix netlink local service GFP crash IB/srpt: Remove redundant wc array IB/qib: Improve ipoib UD performance IB/mlx4: Advertise RoCE v2 support IB/mlx4: Create and use another QP1 for RoCEv2 IB/mlx4: Enable send of RoCE QP1 packets with IP/UDP headers ...
2016-01-22Merge branch 'linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6 Pull crypto fixes from Herbert Xu: "This fixes the following issues: API: - A large number of bug fixes for the af_alg interface, credit goes to Dmitry Vyukov for discovering and reporting these issues. Algorithms: - sw842 needs to select crc32. - The soft dependency on crc32c is now in the correct spot. Drivers: - The atmel AES driver needs HAS_DMA. - The atmel AES driver was a missing break statement, fortunately it's only a debug function. - A number of bug fixes for the Intel qat driver" * 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (24 commits) crypto: algif_skcipher - sendmsg SG marking is off by one crypto: crc32c - Fix crc32c soft dependency crypto: algif_skcipher - Load TX SG list after waiting crypto: atmel-aes - Add missing break to atmel_aes_reg_name crypto: algif_skcipher - Fix race condition in skcipher_check_key crypto: algif_hash - Fix race condition in hash_check_key crypto: CRYPTO_DEV_ATMEL_AES should depend on HAS_DMA lib: sw842: select crc32 crypto: af_alg - Forbid bind(2) when nokey child sockets are present crypto: algif_skcipher - Remove custom release parent function crypto: algif_hash - Remove custom release parent function crypto: af_alg - Allow af_af_alg_release_parent to be called on nokey path crypto: qat - update init_esram for C3xxx dev type crypto: qat - fix timeout issues crypto: qat - remove to call get_sram_bar_id for qat_c3xxx crypto: algif_skcipher - Add key check exception for cipher_null crypto: skcipher - Add crypto_skcipher_has_setkey crypto: algif_hash - Require setkey before accept(2) crypto: hash - Add crypto_ahash_has_setkey crypto: algif_skcipher - Add nokey compatibility path ...
2016-01-22Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge misc fixes from Andrew Morton: "Six fixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: ocfs2: NFS hangs in __ocfs2_cluster_lock due to race with ocfs2_unblock_lock reiserfs: fix dereference of ERR_PTR ratelimit: fix bug in time interval by resetting right begin time mm: fix kernel crash in khugepaged thread mm: fix mlock accouting thp: change pmd_trans_huge_lock() interface to return ptl
2016-01-21Merge branch 'for-4.5/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block driver updates from Jens Axboe: "This is the block driver pull request for 4.5, with the exception of NVMe, which is in a separate branch and will be posted after this one. This pull request contains: - A set of bcache stability fixes, which have been acked by Kent. These have been used and tested for more than a year by the community, so it's about time that they got in. - A set of drbd updates from the drbd team (Andreas, Lars, Philipp) and Markus Elfring, Oleg Drokin. - A set of fixes for xen blkback/front from the usual suspects, (Bob, Konrad) as well as community based fixes from Kiri, Julien, and Peng. - A 2038 time fix for sx8 from Shraddha, with a fix from me. - A small mtip32xx cleanup from Zhu Yanjun. - A null_blk division fix from Arnd" * 'for-4.5/drivers' of git://git.kernel.dk/linux-block: (71 commits) null_blk: use sector_div instead of do_div mtip32xx: restrict variables visible in current code module xen/blkfront: Fix crash if backend doesn't follow the right states. xen/blkback: Fix two memory leaks. xen/blkback: make st_ statistics per ring xen/blkfront: Handle non-indirect grant with 64KB pages xen-blkfront: Introduce blkif_ring_get_request xen-blkback: clear PF_NOFREEZE for xen_blkif_schedule() xen/blkback: Free resources if connect_ring failed. xen/blocks: Return -EXX instead of -1 xen/blkback: make pool of persistent grants and free pages per-queue xen/blkback: get the number of hardware queues/rings from blkfront xen/blkback: pseudo support for multi hardware queues/rings xen/blkback: separate ring information out of struct xen_blkif xen/blkfront: correct setting for xen_blkif_max_ring_order xen/blkfront: make persistent grants pool per-queue xen/blkfront: Remove duplicate setting of ->xbdev. xen/blkfront: Cleanup of comments, fix unaligned variables, and syntax errors. xen/blkfront: negotiate number of queues/rings to be used with backend xen/blkfront: split per device io_lock ...
2016-01-21ratelimit: fix bug in time interval by resetting right begin timeJaewon Kim
rs->begin in ratelimit is set in two cases. 1) when rs->begin was not initialized 2) when rs->interval was passed For case #2, current ratelimit sets the begin to 0. This incurrs improper suppression. The begin value will be set in the next ratelimit call by 1). Then the time interval check will be always false, and rs->printed will not be initialized. Although enough time passed, ratelimit may return 0 if rs->printed is not less than rs->burst. To reset interval properly, begin should be jiffies rather than 0. For an example code below: static DEFINE_RATELIMIT_STATE(mylimit, 1, 1); for (i = 1; i <= 10; i++) { if (__ratelimit(&mylimit)) printk("ratelimit test count %d\n", i); msleep(3000); } test result in the current code shows suppression even there is 3 seconds sleep. [ 78.391148] ratelimit test count 1 [ 81.295988] ratelimit test count 2 [ 87.315981] ratelimit test count 4 [ 93.336267] ratelimit test count 6 [ 99.356031] ratelimit test count 8 [ 105.376367] ratelimit test count 10 Signed-off-by: Jaewon Kim <jaewon31.kim@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-21Merge branch 'uaccess' (batched user access infrastructure)Linus Torvalds
Expose an interface to allow users to mark several accesses together as being user space accesses, allowing batching of the surrounding user space access markers (SMAP on x86, PAN on arm64, domain register switching on arm). This is currently only used for the user string lenth and copying functions, where the SMAP overhead on x86 drowned the actual user accesses (only noticeable on newer microarchitectures that support SMAP in the first place, of course). * user access batching branch: Use the new batched user accesses in generic user string handling Add 'unsafe' user access functions for batched accesses x86: reorganize SMAP handling in user space accesses
2016-01-21Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge third patch-bomb from Andrew Morton: "I'm pretty much done for -rc1 now: - the rest of MM, basically - lib/ updates - checkpatch, epoll, hfs, fatfs, ptrace, coredump, exit - cpu_mask simplifications - kexec, rapidio, MAINTAINERS etc, etc. - more dma-mapping cleanups/simplifications from hch" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (109 commits) MAINTAINERS: add/fix git URLs for various subsystems mm: memcontrol: add "sock" to cgroup2 memory.stat mm: memcontrol: basic memory statistics in cgroup2 memory controller mm: memcontrol: do not uncharge old page in page cache replacement Documentation: cgroup: add memory.swap.{current,max} description mm: free swap cache aggressively if memcg swap is full mm: vmscan: do not scan anon pages if memcg swap limit is hit swap.h: move memcg related stuff to the end of the file mm: memcontrol: replace mem_cgroup_lruvec_online with mem_cgroup_online mm: vmscan: pass memcg to get_scan_count() mm: memcontrol: charge swap to cgroup2 mm: memcontrol: clean up alloc, online, offline, free functions mm: memcontrol: flatten struct cg_proto mm: memcontrol: rein in the CONFIG space madness net: drop tcp_memcontrol.c mm: memcontrol: introduce CONFIG_MEMCG_LEGACY_KMEM mm: memcontrol: allow to disable kmem accounting for cgroup2 mm: memcontrol: account "kmem" consumers in cgroup2 memory controller mm: memcontrol: move kmem accounting code to CONFIG_MEMCG mm: memcontrol: separate kmem code from legacy tcp accounting code ...
2016-01-20Merge tag 'asm-generic-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic Pull asm-generic updates from Arnd Bergmann: "The asm-generic tree this time contains one series from Nicolas Pitre that makes the optimized do_div() implementation from the ARM architecture available to all architectures. This also adds stricter type checking for callers of do_div, which has uncovered a number of bugs in existing code, and fixes up the ones we have found" * tag 'asm-generic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: ARM: asm/div64.h: adjust to generic codde __div64_32(): make it overridable at compile time __div64_const32(): abstract out the actual 128-bit cross product code do_div(): generic optimization for constant divisor on 32-bit machines div64.h: optimize do_div() for power-of-two constant divisors mtd/sm_ftl.c: fix wrong do_div() usage drm/mgag200/mgag200_mode.c: fix wrong do_div() usage hid-sensor-hub.c: fix wrong do_div() usage ti/fapll: fix wrong do_div() usage ti/clkt_dpll: fix wrong do_div() usage tegra/clk-divider: fix wrong do_div() usage imx/clk-pllv2: fix wrong do_div() usage imx/clk-pllv1: fix wrong do_div() usage nouveau/nvkm/subdev/clk/gk20a.c: fix wrong do_div() usage
2016-01-20Do not enable CONFIG_IO_STRICT_DEVMEM by defaultDan Williams
Larry Finger reports: "My PowerBook G4 Aluminum with a 32-bit PPC processor fails to boot for the 4.4-git series". This is likely due to X still needing /dev/mem access on this platform. CONFIG_IO_STRICT_DEVMEM is not yet safe to turn on when CONFIG_STRICT_DEVMEM=y. Remove the default so that old configurations do not change behavior. Fixes: 90a545e98126 ("restrict /dev/mem to idle io memory ranges") Reported-by: Larry Finger <Larry.Finger@lwfinger.net> Tested-by: Larry Finger <Larry.Finger@lwfinger.net> Link: http://marc.info/?l=linux-kernel&m=145332012023825&w=2 Acked-by: Kees Cook <keescook@chromium.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-20UBSAN: run-time undefined behavior sanity checkerAndrey Ryabinin
UBSAN uses compile-time instrumentation to catch undefined behavior (UB). Compiler inserts code that perform certain kinds of checks before operations that could cause UB. If check fails (i.e. UB detected) __ubsan_handle_* function called to print error message. So the most of the work is done by compiler. This patch just implements ubsan handlers printing errors. GCC has this capability since 4.9.x [1] (see -fsanitize=undefined option and its suboptions). However GCC 5.x has more checkers implemented [2]. Article [3] has a bit more details about UBSAN in the GCC. [1] - https://gcc.gnu.org/onlinedocs/gcc-4.9.0/gcc/Debugging-Options.html [2] - https://gcc.gnu.org/onlinedocs/gcc/Debugging-Options.html [3] - http://developerblog.redhat.com/2014/10/16/gcc-undefined-behavior-sanitizer-ubsan/ Issues which UBSAN has found thus far are: Found bugs: * out-of-bounds access - 97840cb67ff5 ("netfilter: nfnetlink: fix insufficient validation in nfnetlink_bind") undefined shifts: * d48458d4a768 ("jbd2: use a better hash function for the revoke table") * 10632008b9e1 ("clockevents: Prevent shift out of bounds") * 'x << -1' shift in ext4 - http://lkml.kernel.org/r/<5444EF21.8020501@samsung.com> * undefined rol32(0) - http://lkml.kernel.org/r/<1449198241-20654-1-git-send-email-sasha.levin@oracle.com> * undefined dirty_ratelimit calculation - http://lkml.kernel.org/r/<566594E2.3050306@odin.com> * undefined roundown_pow_of_two(0) - http://lkml.kernel.org/r/<1449156616-11474-1-git-send-email-sasha.levin@oracle.com> * [WONTFIX] undefined shift in __bpf_prog_run - http://lkml.kernel.org/r/<CACT4Y+ZxoR3UjLgcNdUm4fECLMx2VdtfrENMtRRCdgHB2n0bJA@mail.gmail.com> WONTFIX here because it should be fixed in bpf program, not in kernel. signed overflows: * 32a8df4e0b33f ("sched: Fix odd values in effective_load() calculations") * mul overflow in ntp - http://lkml.kernel.org/r/<1449175608-1146-1-git-send-email-sasha.levin@oracle.com> * incorrect conversion into rtc_time in rtc_time64_to_tm() - http://lkml.kernel.org/r/<1449187944-11730-1-git-send-email-sasha.levin@oracle.com> * unvalidated timespec in io_getevents() - http://lkml.kernel.org/r/<CACT4Y+bBxVYLQ6LtOKrKtnLthqLHcw-BMp3aqP3mjdAvr9FULQ@mail.gmail.com> * [NOTABUG] signed overflow in ktime_add_safe() - http://lkml.kernel.org/r/<CACT4Y+aJ4muRnWxsUe1CMnA6P8nooO33kwG-c8YZg=0Xc8rJqw@mail.gmail.com> [akpm@linux-foundation.org: fix unused local warning] [akpm@linux-foundation.org: fix __int128 build woes] Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Michal Marek <mmarek@suse.cz> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Yury Gribov <y.gribov@samsung.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Kostya Serebryany <kcc@google.com> Cc: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-20lib/clz_tab.c: put in lib-y rather than obj-yChris Metcalf
The clz table (__clz_tab) in lib/clz_tab.c is also provided as part of libgcc.a, and many architectures link against libgcc. To allow the linker to avoid a multiple-definition link failure, clz_tab.o has to be in lib/lib.a rather than lib/builtin.o. The specific issue is that libgcc.a comes before lib/builtin.o on vmlinux.o's link command line, so its _clz.o is pulled to satisfy __clz_tab, and then when the remainder of lib/builtin.o is pulled in to satisfy all the other dependencies, the __clz_tab symbols conflict. By putting clz_tab.o in lib.a, the linker can simply avoid pulling it into vmlinux.o when this situation arises. The definitions of __clz_tab are the same in libgcc.a and in the kernel; arguably we could also simply rename the kernel version, but it's unlikely the libgcc version will ever change to become incompatible, so just using it seems reasonably safe. Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-20test_hexdump: print statistics at the endAndy Shevchenko
Like others test are doing print the gathered statistics after test module is finished. Return from the module based on the result. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-20test_hexdump: test all possible group sizes for overflowAndy Shevchenko
Currently the only one combination is tested for overflow, i.e. rowsize = 16, groupsize = 1, len = 1. Do various test to go through all possible branches. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-20test_hexdump: check all bytes in real bufferAndy Shevchenko
After processing by hex_dump_to_buffer() check all the parts to be expected. Part 1. The actual expected hex dump with or without ASCII part. Part 2. Check if the buffer is dirty beyond needed. Part 3. Return code should be as expected. This is done by using comparison of the return code and memcmp() against the test buffer. We fill the buffer by FILL_CHAR ('#') characters, so, we expect to have a tail of the buffer will be left untouched. The terminating NUL is also checked by memcmp(). Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-20test_hexdump: switch to memcmp()Andy Shevchenko
Better to use memcmp() against entire buffer to check that nothing is happened to the data in the tail. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-20test_hexdump: replace magic numbers by their meaningAndy Shevchenko
The magic numbers of the length are converted to their actual meaning, such as end of the buffer with and without ASCII part. We don't touch the rest of the magic constants that will be removed in the following commits. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-20test_hexdump: go through all possible lengths of bufferAndy Shevchenko
When test for overflow do iterate the buffer length in a range 0 .. BUF_SIZE. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-20test_hexdump: define FILL_CHAR constantAndy Shevchenko
Define a character to fill the test buffers. Though the character should be printable since it's used when errors are reported. It should neither be from hex digit [a-fA-F0-9] dictionary nor space. It is recommended not to use one which is present in ASCII part of the test data. Later on we might switch to unprintable character to make test case more robust. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Suggested-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-20test_hexdump: introduce test_hexdump_prepare_test() helperAndy Shevchenko
The function prepares the expected result in the provided buffer. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-20test_hexdump: rename to test_hexdumpAndy Shevchenko
The test suite currently doesn't cover many corner cases when hex_dump_to_buffer() runs into overflow. Refactor and amend test suite to cover most of the cases. This patch (of 9): Just to follow the scheme that most of the test modules are using. There is no fuctional change. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-20lib/iomap_copy.c: add __ioread32_copy()Stephen Boyd
Some drivers need to read data out of iomem areas 32-bits at a time. Add an API to do this. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Bjorn Andersson <bjorn.andersson@sonymobile.com> Cc: <zajec5@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: Hauke Mehrtens <hauke@hauke-m.de> Cc: Paul Walmsley <paul@pwsan.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-20string_helpers: fix precision loss for some inputsJames Bottomley
It was noticed that we lose precision in the final calculation for some inputs. The most egregious example is size=3000 blk_size=1900 in units of 10 should yield 5.70 MB but in fact yields 3.00 MB (oops). This is because the current algorithm doesn't correctly account for all the remainders in the logarithms. Fix this by doing a correct calculation in the remainders based on napier's algorithm. Additionally, now we have the correct result, we have to account for arithmetic rounding because we're printing 3 digits of precision. This means that if the fourth digit is five or greater, we have to round up, so add a section to ensure correct rounding. Finally account for all possible inputs correctly, including zero for block size. Fixes: b9f28d863594c429e1df35a0474d2663ca28b307 Signed-off-by: James Bottomley <JBottomley@Odin.com> Reported-by: Vitaly Kuznetsov <vkuznets@redhat.com> Cc: <stable@vger.kernel.org> [delay until after 4.4 release] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-20lib/libcrc32c.c: fix build warningJean Delvare
Fix the following build warning: lib/libcrc32c.c:42:5: warning: no previous prototype for "crc32c" [-Wmissing-prototypes] u32 crc32c(u32 crc, const void *address, unsigned int length) ^ Signed-off-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-19irq_poll: Fix irq_poll_sched()Bart Van Assche
The IRQ_POLL_F_SCHED bit is set as long as polling is ongoing. This means that irq_poll_sched() must proceed if this bit has not yet been set. Fixes: commit ea51190c0315 ("irq_poll: fold irq_poll_sched_prep into irq_poll_sched"). Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19crypto: crc32c - Fix crc32c soft dependencyJean Delvare
I don't think it makes sense for a module to have a soft dependency on itself. This seems quite cyclic by nature and I can't see what purpose it could serve. OTOH libcrc32c calls crypto_alloc_shash("crc32c", 0, 0) so it pretty much assumes that some incarnation of the "crc32c" hash algorithm has been loaded. Therefore it makes sense to have the soft dependency there (as crc-t10dif does.) Cc: stable@vger.kernel.org Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-01-18lib: sw842: select crc32Arnd Bergmann
The sw842 library code was merged in linux-4.1 and causes a very rare randconfig failure when CONFIG_CRC32 is not set: lib/built-in.o: In function `sw842_compress': oid_registry.c:(.text+0x12ddc): undefined reference to `crc32_be' lib/built-in.o: In function `sw842_decompress': oid_registry.c:(.text+0x137e4): undefined reference to `crc32_be' This adds an explict 'select CRC32' statement, similar to what the other users of the crc32 code have. In practice, CRC32 is always enabled anyway because over 100 other symbols select it. Cc: stable@vger.kernel.org Signed-off-by: Arnd Bergmann <arnd@arndb.de> Fixes: 2da572c959dd ("lib: add software 842 compression/decompression") Acked-by: Dan Streetman <ddstreet@ieee.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-01-17Merge tag 'linux-kselftest-4.5-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest Pull kselftest updates from Shuah Khan: "This 14 patch update: - adds a new test for intel_pstate driver - adds empty string and async test cases to firmware class tests - fixes and cleans up several existing tests" * tag 'linux-kselftest-4.5-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest: selftests: firmware: add empty string and async tests firmware: actually return NULL on failed request_firmware_nowait() test: firmware_class: add asynchronous request trigger test: firmware_class: use kstrndup() where appropriate test: firmware_class: report errors properly on failure selftests/seccomp: fix 32-bit build warnings add breakpoints/.gitignore add ptrace/.gitignore update .gitignore in selftests/timers update .gitignore in selftests/vm tools, testing, add test for intel_pstate driver selftest/ipc: actually test it selftests/capabilities: actually test it selftests/capabilities: clean up for Makefile
2016-01-16lib/vsprintf: factor out %pN[F] handler as netdev_bits()Andy Shevchenko
Move switch case to the netdev_features_string() and rename it to netdev_bits(). In the future we can extend it as needed. Here we replace the fallback of %pN from '%p' with possible flags to sticter '0x%p' without any flags variation. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-16lib/vsprintf: refactor duplicate code to special_hex_number()Andy Shevchenko
special_hex_number() is a helper to print a fixed size type in a hex format with '0x' prefix, zero padding, and small letters. In the module we have already several copies of such code. Consolidate them under special_hex_number() helper. There are couple of differences though. It seems nobody cared about the output in case of CONFIG_KALLSYMS=n, when printing symbol address, because the asked field width is not enough to care last 2 characters in the string represantation of the pointer. Fixed here. The %pNF specifier used to be allowed with a specific field width, though there is neither any user of it nor mention the possibility in the documentation. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-16lib/test_printf.c: test dentry printingRasmus Villemoes
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Joe Perches <joe@perches.com> Cc: Kees Cook <keescook@chromium.org> Cc: Maurizio Lombardi <mlombard@redhat.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-16lib/test_printf.c: add test for large bitmapsRasmus Villemoes
Following "lib/vsprintf.c: expand field_width to 24 bits", let's add a test to see that we now actually support bitmaps with 65536 bits. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Acked-by: Kees Cook <keescook@chromium.org> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Joe Perches <joe@perches.com> Cc: Maurizio Lombardi <mlombard@redhat.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-16lib/test_printf.c: account for kvasprintf testsRasmus Villemoes
These should also count as performed tests. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Acked-by: Kees Cook <keescook@chromium.org> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Joe Perches <joe@perches.com> Cc: Maurizio Lombardi <mlombard@redhat.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-16lib/test_printf.c: add a few number() testsRasmus Villemoes
This adds a few tests to test_number, one of which serves to document another deviation from POSIX/C99 (printing 0 with an explicit precision of 0). Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Joe Perches <joe@perches.com> Cc: Kees Cook <keescook@chromium.org> Cc: Maurizio Lombardi <mlombard@redhat.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-16lib/test_printf.c: test precision quirksRasmus Villemoes
The kernel's printf doesn't follow the standards in a few corner cases (which are probably mostly irrelevant). Add tests that document the current behaviour. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Joe Perches <joe@perches.com> Cc: Kees Cook <keescook@chromium.org> Cc: Maurizio Lombardi <mlombard@redhat.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-16lib/test_printf.c: check for out-of-bound writesRasmus Villemoes
Add a few padding bytes on either side of the test buffer, and check that these (and the part of the buffer not used) are untouched by vsnprintf. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Acked-by: Kees Cook <keescook@chromium.org> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Joe Perches <joe@perches.com> Cc: Maurizio Lombardi <mlombard@redhat.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-16lib/test_printf.c: don't BUGRasmus Villemoes
BUG is a completely unnecessarily big hammer, and we're more likely to get the internal bug reported if we just pr_err() and ensure the test suite fails. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Acked-by: Kees Cook <keescook@chromium.org> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Joe Perches <joe@perches.com> Cc: Maurizio Lombardi <mlombard@redhat.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-16lib/kasprintf.c: add sanity check to kvasprintfRasmus Villemoes
kasprintf relies on being able to replay the formatting and getting the same result (in particular, the same length). This will almost always work, but it is possible that the object pointed to by a %s or %p argument changed under us (so we might get truncated output). Add a somewhat paranoid sanity check and let's see if it ever triggers. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Joe Perches <joe@perches.com> Cc: Kees Cook <keescook@chromium.org> Cc: Maurizio Lombardi <mlombard@redhat.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-16lib/vsprintf.c: warn about too large precisions and field widthsRasmus Villemoes
The field width is overloaded to pass some extra information for some %p extensions (e.g. #bits for %pb). But we might silently truncate the passed value when we stash it in struct printf_spec (see e.g. "lib/vsprintf.c: expand field_width to 24 bits"). Hopefully 23 value bits should now be enough for everybody, but if not, let's make some noise. Do the same for the precision. In both cases, clamping seems more sensible than truncating. While, according to POSIX, "A negative precision is taken as if the precision were omitted.", the kernel's printf has always treated that case as if the precision was 0, so we use that as lower bound. For the field width, the smallest representable value is actually -(1<<23), but a negative field width means 'set the LEFT flag and use the absolute value', so we want the absolute value to fit. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Joe Perches <joe@perches.com> Cc: Kees Cook <keescook@chromium.org> Cc: Maurizio Lombardi <mlombard@redhat.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-16lib/vsprintf.c: help gcc make number() smallerRasmus Villemoes
One consequence of the reorganization of struct printf_spec to make field_width 24 bits was that number() gained about 180 bytes. Since spec is never passed to other functions, we can help gcc make number() lose most of that extra weight by using local variables for the field width and precision. Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Ingo Molnar <mingo@kernel.org> Cc: Joe Perches <joe@perches.com> Cc: Kees Cook <keescook@chromium.org> Cc: Maurizio Lombardi <mlombard@redhat.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-16lib/vsprintf.c: expand field_width to 24 bitsRasmus Villemoes
Maurizio Lombardi reported a problem [1] with the %pb extension: It doesn't work for sufficiently large bitmaps, since the size is stashed in the field_width field of the struct printf_spec, which is currently an s16. Concretely, this manifested itself in /sys/bus/pseudo/drivers/scsi_debug/map being empty, since the bitmap printer got a size of 0, which is the 16 bit truncation of the actual bitmap size. We do want to keep struct printf_spec at 8 bytes so that it can cheaply be passed by value. The qualifier field is only used for internal bookkeeping in format_decode, so we might as well use a local variable for that. This gives us an additional 8 bits, which we can then use for the field width. To stay in 8 bytes, we need to do a little rearranging and make the type member a bitfield as well. For consistency, change all the members to bit fields. gcc doesn't generate much worse code with these changes (in fact, bloat-o-meter says we save 300 bytes - which I think is a little surprising). I didn't find a BUILD_BUG/compiletime_assertion/... which would work outside function context, so for now I just open-coded it. [1] http://thread.gmane.org/gmane.linux.kernel/2034835 [akpm@linux-foundation.org: avoid open-coded BUILD_BUG_ON] Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Reported-by: Maurizio Lombardi <mlombard@redhat.com> Acked-by: Tejun Heo <tj@kernel.org> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Joe Perches <joe@perches.com> Cc: Kees Cook <keescook@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-16lib/vsprintf.c: eliminate potential race in string()Rasmus Villemoes
If the string corresponding to a %s specifier can change under us, we might end up copying a \0 byte to the output buffer. There might be callers who expect the output buffer to contain a genuine C string whose length is exactly the snprintf return value (assuming truncation hasn't happened or has been checked for). We can avoid this by only passing over the source string once, stopping the first time we meet a nul byte (or when we reach the given precision), and then letting widen_string() handle left/right space padding. As a small bonus, this code reuse also makes the generated code slightly smaller. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Joe Perches <joe@perches.com> Cc: Kees Cook <keescook@chromium.org> Cc: Maurizio Lombardi <mlombard@redhat.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-16lib/vsprintf.c: move string() below widen_string()Rasmus Villemoes
This is pure code movement, making sure the widen_string() helper is defined before the string() function. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Joe Perches <joe@perches.com> Cc: Kees Cook <keescook@chromium.org> Cc: Maurizio Lombardi <mlombard@redhat.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-16lib/vsprintf.c: pull out padding code from dentry_name()Rasmus Villemoes
Pull out the logic in dentry_name() which handles field width space padding, in preparation for reusing it from string(). Rename the widen() helper to move_right(), since it is used for handling the !(flags & LEFT) case. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Joe Perches <joe@perches.com> Cc: Kees Cook <keescook@chromium.org> Cc: Maurizio Lombardi <mlombard@redhat.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-16Kconfig: remove HAVE_LATENCYTOP_SUPPORTWill Deacon
As illustrated by commit a3afe70b83fd ("[S390] latencytop s390 support."), HAVE_LATENCYTOP_SUPPORT is defined by an architecture to advertise an implementation of save_stack_trace_tsk. However, as of 9212ddb5eada ("stacktrace: provide save_stack_trace_tsk() weak alias") a dummy implementation is provided if STACKTRACE=y. Given that LATENCYTOP already depends on STACKTRACE_SUPPORT and selects STACKTRACE, we can remove HAVE_LATENCYTOP_SUPPORT altogether. Signed-off-by: Will Deacon <will.deacon@arm.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: James Hogan <james.hogan@imgtec.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Helge Deller <deller@gmx.de> Acked-by: Michael Ellerman <mpe@ellerman.id.au> Cc: "David S. Miller" <davem@davemloft.net> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Ingo Molnar <mingo@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-15mm, dax, pmem: introduce {get|put}_dev_pagemap() for dax-gupDan Williams
get_dev_page() enables paths like get_user_pages() to pin a dynamically mapped pfn-range (devm_memremap_pages()) while the resulting struct page objects are in use. Unlike get_page() it may fail if the device is, or is in the process of being, disabled. While the initial lookup of the range may be an expensive list walk, the result is cached to speed up subsequent lookups which are likely to be in the same mapped range. devm_memremap_pages() now requires a reference counter to be specified at init time. For pmem this means moving request_queue allocation into pmem_alloc() so the existing queue usage counter can track "device pages". ZONE_DEVICE pages always have an elevated count and will never be on an lru reclaim list. That space in 'struct page' can be redirected for other uses, but for safety introduce a poison value that will always trip __list_add() to assert. This allows half of the struct list_head storage to be reclaimed with some assurance to back up the assumption that the page count never goes to zero and a list_add() is never attempted. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Tested-by: Logan Gunthorpe <logang@deltatee.com> Cc: Dave Hansen <dave@sr71.net> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-15page-flags: introduce page flags policies wrt compound pagesKirill A. Shutemov
This patch adds a third argument to macros which create function definitions for page flags. This argument defines how page-flags helpers behave on compound functions. For now we define four policies: - PF_ANY: the helper function operates on the page it gets, regardless if it's non-compound, head or tail. - PF_HEAD: the helper function operates on the head page of the compound page if it gets tail page. - PF_NO_TAIL: only head and non-compond pages are acceptable for this helper function. - PF_NO_COMPOUND: only non-compound pages are acceptable for this helper function. For now we use policy PF_ANY for all helpers, which matches current behaviour. We do not enforce the policy for TESTPAGEFLAG, because we have flags checked for random pages all over the kernel. Noticeable exception to this is PageTransHuge() which triggers VM_BUG_ON() for tail page. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Christoph Lameter <cl@linux.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Steve Capper <steve.capper@linaro.org> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Jerome Marchand <jmarchan@redhat.com> Cc: Jérôme Glisse <jglisse@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-15Merge tag 'powerpc-4.5-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux Pull powerpc updates from Michael Ellerman: "Core: - Ground work for the new Power9 MMU from Aneesh Kumar K.V - Optimise FP/VMX/VSX context switching from Anton Blanchard Misc: - Various cleanups from Krzysztof Kozlowski, John Ogness, Rashmica Gupta, Russell Currey, Gavin Shan, Daniel Axtens, Michael Neuling, Andrew Donnellan - Allow wrapper to work on non-english system from Laurent Vivier - Add rN aliases to the pt_regs_offset table from Rashmica Gupta - Fix module autoload for rackmeter & axonram drivers from Luis de Bethencourt - Include KVM guest test in all interrupt vectors from Paul Mackerras - Fix DSCR inheritance over fork() from Anton Blanchard - Make value-returning atomics & {cmp}xchg* & their atomic_ versions fully ordered from Boqun Feng - Print MSR TM bits in oops messages from Michael Neuling - Add TM signal return & invalid stack selftests from Michael Neuling - Limit EPOW reset event warnings from Vipin K Parashar - Remove the Cell QPACE code from Rashmica Gupta - Append linux_banner to exception information in xmon from Rashmica Gupta - Add selftest to check if VSRs are corrupted from Rashmica Gupta - Remove broken GregorianDay() from Daniel Axtens - Import Anton's context_switch2 benchmark into selftests from Michael Ellerman - Add selftest script to test HMI functionality from Daniel Axtens - Remove obsolete OPAL v2 support from Stewart Smith - Make enter_rtas() private from Michael Ellerman - PPR exception cleanups from Michael Ellerman - Add page soft dirty tracking from Laurent Dufour - Add support for Nvlink NPUs from Alistair Popple - Add support for kexec on 476fpe from Alistair Popple - Enable kernel CPU dlpar from sysfs from Nathan Fontenot - Copy only required pieces of the mm_context_t to the paca from Michael Neuling - Add a kmsg_dumper that flushes OPAL console output on panic from Russell Currey - Implement save_stack_trace_regs() to enable kprobe stack tracing from Steven Rostedt - Add HWCAP bits for Power9 from Michael Ellerman - Fix _PAGE_PTE breaking swapoff from Aneesh Kumar K.V - Fix _PAGE_SWP_SOFT_DIRTY breaking swapoff from Hugh Dickins - scripts/recordmcount.pl: support data in text section on powerpc from Ulrich Weigand - Handle R_PPC64_ENTRY relocations in modules from Ulrich Weigand cxl: - cxl: Fix possible idr warning when contexts are released from Vaibhav Jain - cxl: use correct operator when writing pcie config space values from Andrew Donnellan - cxl: Fix DSI misses when the context owning task exits from Vaibhav Jain - cxl: fix build for GCC 4.6.x from Brian Norris - cxl: use -Werror only with CONFIG_PPC_WERROR from Brian Norris - cxl: Enable PCI device ID for future IBM CXL adapter from Uma Krishnan Freescale: - Freescale updates from Scott: Highlights include moving QE code out of arch/powerpc (to be shared with arm), device tree updates, and minor fixes" * tag 'powerpc-4.5-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (149 commits) powerpc/module: Handle R_PPC64_ENTRY relocations scripts/recordmcount.pl: support data in text section on powerpc powerpc/powernv: Fix OPAL_CONSOLE_FLUSH prototype and usages powerpc/mm: fix _PAGE_SWP_SOFT_DIRTY breaking swapoff powerpc/mm: Fix _PAGE_PTE breaking swapoff cxl: Enable PCI device ID for future IBM CXL adapter cxl: use -Werror only with CONFIG_PPC_WERROR cxl: fix build for GCC 4.6.x powerpc: Add HWCAP bits for Power9 powerpc/powernv: Reserve PE#0 on NPU powerpc/powernv: Change NPU PE# assignment powerpc/powernv: Fix update of NVLink DMA mask powerpc/powernv: Remove misleading comment in pci.c powerpc: Implement save_stack_trace_regs() to enable kprobe stack tracing powerpc: Fix build break due to paca mm_context_t changes cxl: Fix DSI misses when the context owning task exits MAINTAINERS: Update Scott Wood's e-mail address powerpc/powernv: Fix minor off-by-one error in opal_mce_check_early_recovery() powerpc: Fix style of self-test config prompts powerpc/powernv: Only delay opal_rtc_read() retry when necessary ...
2016-01-15Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge first patch-bomb from Andrew Morton: - A few hotfixes which missed 4.4 becasue I was asleep. cc'ed to -stable - A few misc fixes - OCFS2 updates - Part of MM. Including pretty large changes to page-flags handling and to thp management which have been buffered up for 2-3 cycles now. I have a lot of MM material this time. [ It turns out the THP part wasn't quite ready, so that got dropped from this series - Linus ] * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (117 commits) zsmalloc: reorganize struct size_class to pack 4 bytes hole mm/zbud.c: use list_last_entry() instead of list_tail_entry() zram/zcomp: do not zero out zcomp private pages zram: pass gfp from zcomp frontend to backend zram: try vmalloc() after kmalloc() zram/zcomp: use GFP_NOIO to allocate streams mm: add tracepoint for scanning pages drivers/base/memory.c: fix kernel warning during memory hotplug on ppc64 mm/page_isolation: use macro to judge the alignment mm: fix noisy sparse warning in LIBCFS_ALLOC_PRE() mm: rework virtual memory accounting include/linux/memblock.h: fix ordering of 'flags' argument in comments mm: move lru_to_page to mm_inline.h Documentation/filesystems: describe the shared memory usage/accounting memory-hotplug: don't BUG() in register_memory_resource() hugetlb: make mm and fs code explicitly non-modular mm/swapfile.c: use list_for_each_entry_safe in free_swap_count_continuations mm: /proc/pid/clear_refs: no need to clear VM_SOFTDIRTY in clear_soft_dirty_pmd() mm: make sure isolate_lru_page() is never called for tail page vmstat: make vmstat_updater deferrable again and shut down on idle ...
2016-01-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: floppy: make local variable non-static exynos: fixes an incorrect header guard dt-bindings: fixes some incorrect header guards cpufreq-dt: correct dead link in documentation cpufreq: ARM big LITTLE: correct dead link in documentation treewide: Fix typos in printk Documentation: filesystem: Fix typo in fs/eventfd.c fs/super.c: use && instead of & for warn_on condition Documentation: fix sysfs-ptp lib: scatterlist: fix Kconfig description
2016-01-14dma-debug: switch check from _text to _stextLaura Abbott
In include/asm-generic/sections.h: /* * Usage guidelines: * _text, _data: architecture specific, don't use them in * arch-independent code * [_stext, _etext]: contains .text.* sections, may also contain * .rodata.* * and/or .init.* sections _text is not guaranteed across architectures. Architectures such as ARM may reuse parts which are not actually text and erroneously trigger a bug. Switch to using _stext which is guaranteed to contain text sections. Came out of https://lkml.kernel.org/g/<567B1176.4000106@redhat.com> Signed-off-by: Laura Abbott <labbott@fedoraproject.org> Reviewed-by: Kees Cook <keescook@chromium.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
