Rehashing and destroying large hash table takes a lot of time,
and happens in process context. It is safe to add cond_resched()
in rhashtable_rehash_table() and rhashtable_free_and_destroy()
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
(cherry picked from commit ae6da1f503abb5a5081f9f6c4a6881de97830f3e)
commit fc91a3c4c27acdca0bc13af6fbb68c35cfd519f2 upstream.
While debugging an issue debugobject tracking warned about an annotation
issue of an object on stack. It turned out that the issue was due to the
object in concern being on a different stack which was due to another
issue.
Thomas suggested to print the pointers and the location of the stack for
the currently running task. This helped to figure out that the object was
on the wrong stack.
As this is general useful information for debugging similar issues, make
the error message more informative by printing the pointers.
[ tglx: Massaged changelog ]
Signed-off-by: Joel Fernandes (Google) <joel@joelfernandes.org>
Acked-by: Waiman Long <longman@redhat.com>
Acked-by: Yang Shi <yang.shi@linux.alibaba.com>
Cc: kernel-team@android.com
Cc: astrachan@google.com
Link: https://lkml.kernel.org/r/20180723212531.202328-1-joel@joelfernandes.org
commit 03fc7f9c99c1e7ae2925d459e8487f1a6f199f79 upstream.
The commit 719f6a7040f1bdaf96 ("printk: Use the main logbuf in NMI
when logbuf_lock is available") brought back the possible deadlocks
in printk() and NMI.
The check of logbuf_lock is done only in printk_nmi_enter() to prevent
mixed output. But another CPU might take the lock later, enter NMI, and:
+ Both NMIs might be serialized by yet another lock, for example,
the one in nmi_cpu_backtrace().
+ The other CPU might get stopped in NMI, see smp_send_stop()
in panic().
The only safe solution is to use trylock when storing the message
into the main log-buffer. It might cause reordering when some lines
go to the main lock buffer directly and others are delayed via
the per-CPU buffer. It means that it is not useful in general.
This patch replaces the problematic NMI deferred context with NMI
direct context. It can be used to mark a code that might produce
many messages in NMI and the risk of losing them is more critical
than problems with eventual reordering.
The context is then used when dumping trace buffers on oops. It was
the primary motivation for the original fix. Also the reordering is
even smaller issue there because some traces have their own time stamps.
Finally, nmi_cpu_backtrace() need not longer be serialized because
it will always us the per-CPU buffers again.
Fixes: 719f6a7040f1bdaf96 ("printk: Use the main logbuf in NMI when logbuf_lock is available")
Cc: stable@vger.kernel.org
Link: http://lkml.kernel.org/r/20180627142028.11259-1-pmladek@suse.com
To: Steven Rostedt <rostedt@goodmis.org>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com>
Acked-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Signed-off-by: Petr Mladek <pmladek@suse.com>
commit 785a19f9d1dd8a4ab2d0633be4656653bd3de1fc upstream.
The following kernel panic was observed on ARM64 platform due to a stale
TLB entry.
1. ioremap with 4K size, a valid pte page table is set.
2. iounmap it, its pte entry is set to 0.
3. ioremap the same address with 2M size, update its pmd entry with
a new value.
4. CPU may hit an exception because the old pmd entry is still in TLB,
which leads to a kernel panic.
Commit b6bdb7517c3d ("mm/vmalloc: add interfaces to free unmapped page
table") has addressed this panic by falling to pte mappings in the above
case on ARM64.
To support pmd mappings in all cases, TLB purge needs to be performed
in this case on ARM64.
Add a new arg, 'addr', to pud_free_pmd_page() and pmd_free_pte_page()
so that TLB purge can be added later in seprate patches.
[toshi.kani@hpe.com: merge changes, rewrite patch description]
Fixes: 28ee90fe6048 ("x86/mm: implement free pmd/pte page interfaces")
Signed-off-by: Chintan Pandya <cpandya@codeaurora.org>
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Cc: mhocko@suse.com
Cc: akpm@linux-foundation.org
Cc: hpa@zytor.com
Cc: linux-mm@kvack.org
Cc: Joerg Roedel <joro@8bytes.org>
Cc: Michal Hocko <mhocko@suse.com>
Cc: <stable@vger.kernel.org>
Link: https://lkml.kernel.org/r/20180627141348.21777-3-toshi.kani@hpe.com
[ Upstream commit 107d01f5ba10f4162c38109496607eb197059064 ]
rhashtable_init() currently does not take into account the user-passed
min_size parameter unless param->nelem_hint is set as well. As such,
the default size (number of buckets) will always be HASH_DEFAULT_SIZE
even if the smallest allowed size is larger than that. Remediate this
by unconditionally calling into rounded_hashtable_size() and handling
things accordingly.
Signed-off-by: Davidlohr Bueso <dbueso@suse.de>
commit 666902e42fd8344b923c02dc5b0f37948ff4f225 upstream.
"%pCr" formats the current rate of a clock, and calls clk_get_rate().
The latter obtains a mutex, hence it must not be called from atomic
context.
Remove support for this rarely-used format, as vsprintf() (and e.g.
printk()) must be callable from any context.
Any remaining out-of-tree users will start seeing the clock's name
printed instead of its rate.
Reported-by: Jia-Ju Bai <baijiaju1990@gmail.com>
Fixes: 900cca2944254edd ("lib/vsprintf: add %pC{,n,r} format specifiers for clocks")
Link: http://lkml.kernel.org/r/1527845302-12159-5-git-send-email-geert+renesas@glider.be
To: Jia-Ju Bai <baijiaju1990@gmail.com>
To: Jonathan Corbet <corbet@lwn.net>
To: Michael Turquette <mturquette@baylibre.com>
To: Stephen Boyd <sboyd@kernel.org>
To: Zhang Rui <rui.zhang@intel.com>
To: Eduardo Valentin <edubezval@gmail.com>
To: Eric Anholt <eric@anholt.net>
To: Stefan Wahren <stefan.wahren@i2se.com>
To: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Cc: Petr Mladek <pmladek@suse.com>
Cc: linux-doc@vger.kernel.org
Cc: linux-clk@vger.kernel.org
Cc: linux-pm@vger.kernel.org
Cc: linux-serial@vger.kernel.org
Cc: linux-renesas-soc@vger.kernel.org
Cc: Geert Uytterhoeven <geert+renesas@glider.be>
Cc: stable@vger.kernel.org # 4.1+
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
[ Upstream commit ac68b1b3b9c73e652dc7ce0585672e23c5a2dca4 ]
As reported by Dan the parentheses is in the wrong place, and since
unlikely() call returns either 0 or 1 it's never less than zero. The
second issue is that signed integer overflows like "INT_MAX + 1" are
undefined behavior.
Since num_test_devs represents the number of devices, we want to stop
prior to hitting the max, and not rely on the wrap arround at all. So
just cap at num_test_devs + 1, prior to assigning a new device.
Link: http://lkml.kernel.org/r/20180224030046.24238-1-mcgrof@kernel.org
Fixes: d9c6a72d6fa2 ("kmod: add test driver to stress test the module loader")
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org>
commit 7a4deea1aa8bddfed4ef1b35fc2b6732563d8ad5 upstream.
If the radix tree underlying the IDR happens to be full and we attempt
to remove an id which is larger than any id in the IDR, we will call
__radix_tree_delete() with an uninitialised 'slot' pointer, at which
point anything could happen. This was easiest to hit with a single
entry at id 0 and attempting to remove a non-0 id, but it could have
happened with 64 entries and attempting to remove an id >= 64.
Roman said:
The syzcaller test boils down to opening /dev/kvm, creating an
eventfd, and calling a couple of KVM ioctls. None of this requires
superuser. And the result is dereferencing an uninitialized pointer
which is likely a crash. The specific path caught by syzbot is via
KVM_HYPERV_EVENTD ioctl which is new in 4.17. But I guess there are
other user-triggerable paths, so cc:stable is probably justified.
Matthew added:
We have around 250 calls to idr_remove() in the kernel today. Many of
them pass an ID which is embedded in the object they're removing, so
they're safe. Picking a few likely candidates:
drivers/firewire/core-cdev.c looks unsafe; the ID comes from an ioctl.
drivers/gpu/drm/amd/amdgpu/amdgpu_ctx.c is similar
drivers/atm/nicstar.c could be taken down by a handcrafted packet
Link: http://lkml.kernel.org/r/20180518175025.GD6361@bombadil.infradead.org
Fixes: 0a835c4f090a ("Reimplement IDR and IDA using the radix tree")
Reported-by: <syzbot+35666cba7f0a337e2e79@syzkaller.appspotmail.com>
Debugged-by: Roman Kagan <rkagan@virtuozzo.com>
Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com>
commit 9f418224e8114156d995b98fa4e0f4fd21f685fe upstream.
Fix a race in the multi-order iteration code which causes the kernel to
hit a GP fault. This was first seen with a production v4.15 based
kernel (4.15.6-300.fc27.x86_64) utilizing a DAX workload which used
order 9 PMD DAX entries.
The race has to do with how we tear down multi-order sibling entries
when we are removing an item from the tree. Remember for example that
an order 2 entry looks like this:
struct radix_tree_node.slots[] = [entry][sibling][sibling][sibling]
where 'entry' is in some slot in the struct radix_tree_node, and the
three slots following 'entry' contain sibling pointers which point back
to 'entry.'
When we delete 'entry' from the tree, we call :
radix_tree_delete()
radix_tree_delete_item()
replace_slot()
replace_slot() first removes the siblings in order from the first to the
last, then at then replaces 'entry' with NULL. This means that for a
brief period of time we end up with one or more of the siblings removed,
so:
struct radix_tree_node.slots[] = [entry][NULL][sibling][sibling]
This causes an issue if you have a reader iterating over the slots in
the tree via radix_tree_for_each_slot() while only under
rcu_read_lock()/rcu_read_unlock() protection. This is a common case in
mm/filemap.c.
The issue is that when __radix_tree_next_slot() => skip_siblings() tries
to skip over the sibling entries in the slots, it currently does so with
an exact match on the slot directly preceding our current slot.
Normally this works:
V preceding slot
^ current slot
This lets you find the first sibling, and you skip them all in order.
But in the case where one of the siblings is NULL, that slot is skipped
and then our sibling detection is interrupted:
V preceding slot
^ current slot
This means that the sibling pointers aren't recognized since they point
all the way back to 'entry', so we think that they are normal internal
radix tree pointers. This causes us to think we need to walk down to a
struct radix_tree_node starting at the address of 'entry'.
In a real running kernel this will crash the thread with a GP fault when
you try and dereference the slots in your broken node starting at
'entry'.
We fix this race by fixing the way that skip_siblings() detects sibling
nodes. Instead of testing against the preceding slot we instead look
for siblings via is_sibling_entry() which compares against the position
of the struct radix_tree_node.slots[] array. This ensures that sibling
entries are properly identified, even if they are no longer contiguous
with the 'entry' they point to.
Link: http://lkml.kernel.org/r/20180503192430.7582-6-ross.zwisler@linux.intel.com
Fixes: 148deab223b2 ("radix-tree: improve multiorder iterators")
Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Reported-by: CR, Sapthagirish <sapthagirish.cr@intel.com>
Cc: Matthew Wilcox <willy@infradead.org>
Cc: Dan Williams <dan.j.williams@intel.com>
commit 1e3054b98c5415d5cb5f8824fc33b548ae5644c3 upstream.
I had neglected to increment the error counter when the tests failed,
which made the tests noisy when they fail, but not actually return an
error code.
Link: http://lkml.kernel.org/r/20180509114328.9887-1-mpe@ellerman.id.au
Fixes: 3cc78125a081 ("lib/test_bitmap.c: add optimisation tests")
Reported-by: Michael Ellerman <mpe@ellerman.id.au>
Tested-by: Michael Ellerman <mpe@ellerman.id.au>
Cc: Yury Norov <ynorov@caviumnetworks.com>
Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: <stable@vger.kernel.org> [4.13+]
commit b4678df184b314a2bd47d2329feca2c2534aa12b upstream.
The errseq_t infrastructure assumes that errors which occurred before
the file descriptor was opened are of no interest to the application.
This turns out to be a regression for some applications, notably Postgres.
Before errseq_t, a writeback error would be reported exactly once (as
long as the inode remained in memory), so Postgres could open a file,
call fsync() and find out whether there had been a writeback error on
that file from another process.
This patch changes the errseq infrastructure to report errors to all
file descriptors which are opened after the error occurred, but before
it was reported to any file descriptor. This restores the user-visible
behaviour.
Fixes: 5660e13d2fd6 ("fs: new infrastructure for writeback error handling and reporting")
Reviewed-by: Jeff Layton <jlayton@kernel.org>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
commit 3e14c6abbfb5c94506edda9d8e2c145d79375798 upstream.
This WARNING proved to be noisy. The function still returns an error
and callers should handle it. That's how most of kernel code works.
Downgrade the WARNING to pr_err() and leave WARNINGs for kernel bugs.
Signed-off-by: Dmitry Vyukov <dvyukov@google.com>
Reported-by: syzbot+209c0f67f99fec8eb14b@syzkaller.appspotmail.com
Reported-by: syzbot+7fb6d9525a4528104e05@syzkaller.appspotmail.com
Reported-by: syzbot+2e63711063e2d8f9ea27@syzkaller.appspotmail.com
Reported-by: syzbot+de73361ee4971b6e6f75@syzkaller.appspotmail.com
Cc: stable <stable@vger.kernel.org>
[ Upstream commit 09584b406742413ac4c8d7e030374d4daa045b69 ]
With CONFIG_BPF_JIT_ALWAYS_ON is defined in the config file,
tools/testing/selftests/bpf/test_kmod.sh failed like below:
[root@localhost bpf]# ./test_kmod.sh
sysctl: setting key "net.core.bpf_jit_enable": Invalid argument
[ JIT enabled:0 hardened:0 ]
[ 132.175681] test_bpf: #297 BPF_MAXINSNS: Jump, gap, jump, ... FAIL to prog_create err=-524 len=4096
[ 132.458834] test_bpf: Summary: 348 PASSED, 1 FAILED, [340/340 JIT'ed]
[ JIT enabled:1 hardened:0 ]
[ 133.456025] test_bpf: #297 BPF_MAXINSNS: Jump, gap, jump, ... FAIL to prog_create err=-524 len=4096
[ 133.730935] test_bpf: Summary: 348 PASSED, 1 FAILED, [340/340 JIT'ed]
[ JIT enabled:1 hardened:1 ]
[ 134.769730] test_bpf: #297 BPF_MAXINSNS: Jump, gap, jump, ... FAIL to prog_create err=-524 len=4096
[ 135.050864] test_bpf: Summary: 348 PASSED, 1 FAILED, [340/340 JIT'ed]
[ JIT enabled:1 hardened:2 ]
[ 136.442882] test_bpf: #297 BPF_MAXINSNS: Jump, gap, jump, ... FAIL to prog_create err=-524 len=4096
[ 136.821810] test_bpf: Summary: 348 PASSED, 1 FAILED, [340/340 JIT'ed]
The test_kmod.sh load/remove test_bpf.ko multiple times with different
settings for sysctl net.core.bpf_jit_{enable,harden}. The failed test #297
of test_bpf.ko is designed such that JIT always fails.
Commit 290af86629b2 (bpf: introduce BPF_JIT_ALWAYS_ON config)
introduced the following tightening logic:
if (!bpf_prog_is_dev_bound(fp->aux)) {
fp = bpf_int_jit_compile(fp);
#ifdef CONFIG_BPF_JIT_ALWAYS_ON
if (!fp->jited) {
*err = -ENOTSUPP;
return fp;
#endif
With this logic, Test #297 always gets return value -ENOTSUPP
when CONFIG_BPF_JIT_ALWAYS_ON is defined, causing the test failure.
This patch fixed the failure by marking Test #297 as expected failure
when CONFIG_BPF_JIT_ALWAYS_ON is defined.
Fixes: 290af86629b2 (bpf: introduce BPF_JIT_ALWAYS_ON config)
Signed-off-by: Yonghong Song <yhs@fb.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
commit 8351760ff5b2042039554b4948ddabaac644a976 upstream.
syzbot is catching stalls at __bitmap_parselist()
(https://syzkaller.appspot.com/bug?id=ad7e0351fbc90535558514a71cd3edc11681997a).
The trigger is
unsigned long v = 0;
bitmap_parselist("7:,", &v, BITS_PER_LONG);
which results in hitting infinite loop at
while (a <= b) {
off = min(b - a + 1, used_size);
bitmap_set(maskp, a, off);
a += group_size;
due to used_size == group_size == 0.
Link: http://lkml.kernel.org/r/20180404162647.15763-1-ynorov@caviumnetworks.com
Fixes: 0a5ce0831d04382a ("lib/bitmap.c: make bitmap_parselist() thread-safe and much faster")
Signed-off-by: Yury Norov <ynorov@caviumnetworks.com>
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Reported-by: syzbot <syzbot+6887cbb011c8054e8a3d@syzkaller.appspotmail.com>
Cc: Noam Camus <noamca@mellanox.com>
Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Cc: Matthew Wilcox <mawilcox@microsoft.com>
Cc: Mauro Carvalho Chehab <mchehab@kernel.org>
[ Upstream commit d3dcf8eb615537526bd42ff27a081d46d337816e ]
When inserting duplicate objects (those with the same key),
current rhlist implementation messes up the chain pointers by
updating the bucket pointer instead of prev next pointer to the
newly inserted node. This causes missing elements on removal and
travesal.
Fix that by properly updating pprev pointer to point to
the correct rhash_head next pointer.
Issue: 1241076
Change-Id: I86b2c140bcb4aeb10b70a72a267ff590bb2b17e7
Fixes: ca26893f05e8 ('rhashtable: Add rhlist interface')
Signed-off-by: Paul Blakey <paulb@mellanox.com>
commit b6bdb7517c3d3f41f20e5c2948d6bc3f8897394e upstream.
On architectures with CONFIG_HAVE_ARCH_HUGE_VMAP set, ioremap() may
create pud/pmd mappings. A kernel panic was observed on arm64 systems
with Cortex-A75 in the following steps as described by Hanjun Guo.
1. ioremap a 4K size, valid page table will build,
2. iounmap it, pte0 will set to 0;
3. ioremap the same address with 2M size, pgd/pmd is unchanged,
then set the a new value for pmd;
4. pte0 is leaked;
5. CPU may meet exception because the old pmd is still in TLB,
which will lead to kernel panic.
This panic is not reproducible on x86. INVLPG, called from iounmap,
purges all levels of entries associated with purged address on x86. x86
still has memory leak.
The patch changes the ioremap path to free unmapped page table(s) since
doing so in the unmap path has the following issues:
- The iounmap() path is shared with vunmap(). Since vmap() only
supports pte mappings, making vunmap() to free a pte page is an
overhead for regular vmap users as they do not need a pte page freed
up.
- Checking if all entries in a pte page are cleared in the unmap path
is racy, and serializing this check is expensive.
- The unmap path calls free_vmap_area_noflush() to do lazy TLB purges.
Clearing a pud/pmd entry before the lazy TLB purges needs extra TLB
purge.
Add two interfaces, pud_free_pmd_page() and pmd_free_pte_page(), which
clear a given pud/pmd entry and free up a page for the lower level
entries.
This patch implements their stub functions on x86 and arm64, which work
as workaround.
[akpm@linux-foundation.org: fix typo in pmd_free_pte_page() stub]
Link: http://lkml.kernel.org/r/20180314180155.19492-2-toshi.kani@hpe.com
Fixes: e61ce6ade404e ("mm: change ioremap to set up huge I/O mappings")
Reported-by: Lei Li <lious.lilei@hisilicon.com>
Cc: Wang Xuefeng <wxf.wang@hisilicon.com>
Cc: Hanjun Guo <guohanjun@huawei.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Chintan Pandya <cpandya@codeaurora.org>
[ Upstream commit a0e94598e6b6c0d1df6a5fa14eb7c767ca817a20 ]
Destination is a kernel pointer and source - a userland one
in _copy_from_user(); _copy_to_user() is the other way round.
Fixes: d597580d37377 ("generic ...copy_..._user primitives")
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
commit 1b4cfe3c0a30dde968fb43c577a8d7e262a145ee upstream.
Commit b8347c219649 ("x86/debug: Handle warnings before the notifier
chain, to fix KGDB crash") changed the ordering of fixups, and did not
take into account the case of x86 processing non-WARN() and non-BUG()
exceptions. This would lead to output of a false BUG line with no other
information.
In the case of a refcount exception, it would be immediately followed by
the refcount WARN(), producing very strange double-"cut here":
lkdtm: attempting bad refcount_inc() overflow
Kernel BUG at 0000000065f29de5 [verbose debug info unavailable]
refcount_t overflow at lkdtm_REFCOUNT_INC_OVERFLOW+0x6b/0x90 in cat[3065], uid/euid: 0/0
WARNING: CPU: 0 PID: 3065 at kernel/panic.c:657 refcount_error_report+0x9a/0xa4
In the prior ordering, exceptions were searched first:
do_trap_no_signal(struct task_struct *tsk, int trapnr, char *str,
if (fixup_exception(regs, trapnr))
return 0;
- if (fixup_bug(regs, trapnr))
- return 0;
As a result, fixup_bugs()'s is_valid_bugaddr() didn't take into account
needing to search the exception list first, since that had already
happened.
So, instead of searching the exception list twice (once in
is_valid_bugaddr() and then again in fixup_exception()), just add a
simple sanity check to report_bug() that will immediately bail out if a
BUG() (or WARN()) entry is not found.
Link: http://lkml.kernel.org/r/20180301225934.GA34350@beast
Fixes: b8347c219649 ("x86/debug: Handle warnings before the notifier chain, to fix KGDB crash")
Cc: Richard Weinberger <richard.weinberger@gmail.com>
[ Upstream commit bbc25bee37d2b32cf3a1fab9195b6da3a185614a ]
Current MIPS64r6 toolchains aren't able to generate efficient
DMULU/DMUHU based code for the C implementation of umul_ppmm(), which
performs an unsigned 64 x 64 bit multiply and returns the upper and
lower 64-bit halves of the 128-bit result. Instead it widens the 64-bit
inputs to 128-bits and emits a __multi3 intrinsic call to perform a 128
x 128 multiply. This is both inefficient, and it results in a link error
since we don't include __multi3 in MIPS linux.
For example commit 90a53e4432b1 ("cfg80211: implement regdb signature
checking") merged in v4.15-rc1 recently broke the 64r6_defconfig and
64r6el_defconfig builds by indirectly selecting MPILIB. The same build
errors can be reproduced on older kernels by enabling e.g. CRYPTO_RSA:
lib/mpi/generic_mpih-mul1.o: In function `mpihelp_mul_1':
lib/mpi/generic_mpih-mul1.c:50: undefined reference to `__multi3'
lib/mpi/generic_mpih-mul2.o: In function `mpihelp_addmul_1':
lib/mpi/generic_mpih-mul2.c:49: undefined reference to `__multi3'
lib/mpi/generic_mpih-mul3.o: In function `mpihelp_submul_1':
lib/mpi/generic_mpih-mul3.c:49: undefined reference to `__multi3'
lib/mpi/mpih-div.o In function `mpihelp_divrem':
lib/mpi/mpih-div.c:205: undefined reference to `__multi3'
lib/mpi/mpih-div.c:142: undefined reference to `__multi3'
Therefore add an efficient MIPS64r6 implementation of umul_ppmm() using
inline assembly and the DMULU/DMUHU instructions, to prevent __multi3
calls being emitted.
Fixes: 7fd08ca58ae6 ("MIPS: Add build support for the MIPS R6 ISA")
Signed-off-by: James Hogan <jhogan@kernel.org>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: linux-mips@linux-mips.org
Cc: linux-crypto@vger.kernel.org
[ Upstream commit 8dfd2f22d3bf3ab7714f7495ad5d897b8845e8c1 ]
Callers of sprint_oid() do not check its return value before printing
the result. In the case where the OID is zero-length, -EBADMSG was
being returned without anything being written to the buffer, resulting
in uninitialized stack memory being printed. Fix this by writing
"(bad)" to the buffer in the cases where -EBADMSG is returned.
Fixes: 4f73175d0375 ("X.509: Add utility functions to render OIDs as strings")
commit 4675ff05de2d76d167336b368bd07f3fef6ed5a6 upstream.
Fix up makefiles, remove references, and git rm kmemcheck.
Link: http://lkml.kernel.org/r/20171007030159.22241-4-alexander.levin@verizon.com
Cc: Vegard Nossum <vegardno@ifi.uio.no>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Tim Hansen <devtimhansen@gmail.com>
commit d0bc0c2a31c95002d37c3cc511ffdcab851b3256 upstream.
TTM tries to allocate coherent memory in chunks of 2MB first to improve
TLB efficiency and falls back to allocating 4K pages if that fails.
Suppress the warning when the 2MB allocations fails since there is a
valid fall back path.
Signed-off-by: Christian König <christian.koenig@amd.com>
Reported-by: Mike Galbraith <efault@gmx.de>
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Bug: https://bugs.freedesktop.org/show_bug.cgi?id=104082
commit 42440c1f9911b4b7b8ba3dc4e90c1197bc561211 upstream.
UBSAN=y fails to build with new GCC/clang:
arch/x86/kernel/head64.o: In function `sanitize_boot_params':
arch/x86/include/asm/bootparam_utils.h:37: undefined reference to `__ubsan_handle_type_mismatch_v1'
because Clang and GCC 8 slightly changed ABI for 'type mismatch' errors.
Compiler now uses new __ubsan_handle_type_mismatch_v1() function with
slightly modified 'struct type_mismatch_data'.
Let's add new 'struct type_mismatch_data_common' which is independent from
compiler's layout of 'struct type_mismatch_data'. And make
__ubsan_handle_type_mismatch[_v1]() functions transform compiler-dependent
type mismatch data to our internal representation. This way, we can
support both old and new compilers with minimal amount of change.
Link: http://lkml.kernel.org/r/20180119152853.16806-1-aryabinin@virtuozzo.com
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Reported-by: Sodagudi Prasad <psodagud@codeaurora.org>
commit b8fe1120b4ba342b4f156d24e952d6e686b20298 upstream.
A vist from the spelling fairy.
Cc: David Laight <David.Laight@ACULAB.COM>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
commit e7c52b84fb18f08ce49b6067ae6285aca79084a8 upstream.
We get a lot of very large stack frames using gcc-7.0.1 with the default
-fsanitize-address-use-after-scope --param asan-stack=1 options, which can
easily cause an overflow of the kernel stack, e.g.
drivers/gpu/drm/i915/gvt/handlers.c:2434:1: warning: the frame size of 46176 bytes is larger than 3072 bytes
drivers/net/wireless/ralink/rt2x00/rt2800lib.c:5650:1: warning: the frame size of 23632 bytes is larger than 3072 bytes
lib/atomic64_test.c:250:1: warning: the frame size of 11200 bytes is larger than 3072 bytes
drivers/gpu/drm/i915/gvt/handlers.c:2621:1: warning: the frame size of 9208 bytes is larger than 3072 bytes
drivers/media/dvb-frontends/stv090x.c:3431:1: warning: the frame size of 6816 bytes is larger than 3072 bytes
fs/fscache/stats.c:287:1: warning: the frame size of 6536 bytes is larger than 3072 bytes
To reduce this risk, -fsanitize-address-use-after-scope is now split out
into a separate CONFIG_KASAN_EXTRA Kconfig option, leading to stack
frames that are smaller than 2 kilobytes most of the time on x86_64. An
earlier version of this patch also prevented combining KASAN_EXTRA with
KASAN_INLINE, but that is no longer necessary with gcc-7.0.1.
All patches to get the frame size below 2048 bytes with CONFIG_KASAN=y
and CONFIG_KASAN_EXTRA=n have been merged by maintainers now, so we can
bring back that default now. KASAN_EXTRA=y still causes lots of
warnings but now defaults to !COMPILE_TEST to disable it in
allmodconfig, and it remains disabled in all other defconfigs since it
is a new option. I arbitrarily raise the warning limit for KASAN_EXTRA
to 3072 to reduce the noise, but an allmodconfig kernel still has around
50 warnings on gcc-7.
I experimented a bit more with smaller stack frames and have another
follow-up series that reduces the warning limit for 64-bit architectures
to 1280 bytes (without CONFIG_KASAN).
With earlier versions of this patch series, I also had patches to address
the warnings we get with KASAN and/or KASAN_EXTRA, using a
"noinline_if_stackbloat" annotation.
That annotation now got replaced with a gcc-8 bugfix (see
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=81715) and a workaround for
older compilers, which means that KASAN_EXTRA is now just as bad as
before and will lead to an instant stack overflow in a few extreme
cases.
This reverts parts of commit 3f181b4d8652 ("lib/Kconfig.debug: disable
-Wframe-larger-than warnings with KASAN=y"). Two patches in linux-next
should be merged first to avoid introducing warnings in an allmodconfig
build:
3cd890dbe2a4 ("media: dvb-frontends: fix i2c access helpers for KASAN")
16c3ada89cff ("media: r820t: fix r820t_write_reg for KASAN")
Do we really need to backport this?
I think we do: without this patch, enabling KASAN will lead to
unavoidable kernel stack overflow in certain device drivers when built
with gcc-7 or higher on linux-4.10+ or any version that contains a
backport of commit c5caf21ab0cf8. Most people are probably still on
older compilers, but it will get worse over time as they upgrade their
distros.
The warnings we get on kernels older than this should all be for code
that uses dangerously large stack frames, though most of them do not
cause an actual stack overflow by themselves.The asan-stack option was
added in linux-4.0, and commit 3f181b4d8652 ("lib/Kconfig.debug:
disable -Wframe-larger-than warnings with KASAN=y") effectively turned
off the warning for allmodconfig kernels, so I would like to see this
fix backported to any kernels later than 4.0.
I have done dozens of fixes for individual functions with stack frames
larger than 2048 bytes with asan-stack, and I plan to make sure that
all those fixes make it into the stable kernels as well (most are
already there).
Part of the complication here is that asan-stack (from 4.0) was
originally assumed to always require much larger stacks, but that
turned out to be a combination of multiple gcc bugs that we have now
worked around and fixed, but sanitize-address-use-after-scope (from
v4.10) has a much higher inherent stack usage and also suffers from at
least three other problems that we have analyzed but not yet fixed
upstream, each of them makes the stack usage more severe than it should
be.
Link: http://lkml.kernel.org/r/20171221134744.2295529-1-arnd@arndb.de
Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Andrey Konovalov <andreyknvl@google.com>
commit a5e1923356505e46476c2fb518559b7a4d9d25b1 upstream.
Add the missing unlock before return from function
config_num_requests_store() in the error handling case.
Fixes: c92316bf8e94 ("test_firmware: add batched firmware tests")
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
[ upstream commit 290af86629b25ffd1ed6232c4e9107da031705cb ]
The BPF interpreter has been used as part of the spectre 2 attack CVE-2017-5715.
A quote from goolge project zero blog:
"At this point, it would normally be necessary to locate gadgets in
the host kernel code that can be used to actually leak data by reading
from an attacker-controlled location, shifting and masking the result
appropriately and then using the result of that as offset to an
attacker-controlled address for a load. But piecing gadgets together
and figuring out which ones work in a speculation context seems annoying.
So instead, we decided to use the eBPF interpreter, which is built into
the host kernel - while there is no legitimate way to invoke it from inside
a VM, the presence of the code in the host kernel's text section is sufficient
to make it usable for the attack, just like with ordinary ROP gadgets."
To make attacker job harder introduce BPF_JIT_ALWAYS_ON config
option that removes interpreter from the kernel in favor of JIT-only mode.
So far eBPF JIT is supported by:
x64, arm64, arm32, sparc64, s390, powerpc64, mips64
The start of JITed program is randomized and code page is marked as read-only.
In addition "constant blinding" can be turned on with net.core.bpf_jit_harden
v2->v3:
- move __bpf_prog_ret0 under ifdef (Daniel)
v1->v2:
- fix init order, test_bpf and cBPF (Daniel's feedback)
- fix offloaded bpf (Jakub's feedback)
- add 'return 0' dummy in case something can invoke prog->bpf_func
- retarget bpf tree. For bpf-next the patch would need one extra hunk.
It will be sent when the trees are merged back to net-next
Considered doing:
int bpf_jit_enable __read_mostly = BPF_EBPF_JIT_DEFAULT;
but it seems better to land the patch as-is and in bpf-next remove
bpf_jit_enable global variable from all JITs, consolidate in one place
and remove this jit_init() function.
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
commit 11af847446ed0d131cf24d16a7ef3d5ea7a49554 upstream.
Rename the unwinder config options from:
CONFIG_ORC_UNWINDER
CONFIG_FRAME_POINTER_UNWINDER
CONFIG_GUESS_UNWINDER
to:
CONFIG_UNWINDER_ORC
CONFIG_UNWINDER_FRAME_POINTER
CONFIG_UNWINDER_GUESS
... in order to give them a more logical config namespace.
Suggested-by: Ingo Molnar <mingo@kernel.org>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Link: http://lkml.kernel.org/r/73972fc7e2762e91912c6b9584582703d6f1b8cc.1507924831.git.jpoimboe@redhat.com
instead of 0
[ Upstream commit 1f3c790bd5989fcfec9e53ad8fa09f5b740c958f ]
line-range is supposed to treat "1-" as "1-endoffile", so
handle the special case by setting last_lineno to UINT_MAX.
Fixes this error:
dynamic_debug:ddebug_parse_query: last-line:0 < 1st-line:1
dynamic_debug:ddebug_exec_query: query parse failed
Link: http://lkml.kernel.org/r/10a6a101-e2be-209f-1f41-54637824788e@infradead.org
Acked-by: Jason Baron <jbaron@akamai.com>
[ Upstream commit 36a3d1dd4e16bcd0d2ddfb4a2ec7092f0ae0d931 ]
If the amount of resources allocated to a gen_pool exceeds 2^32 then the
avail atomic overflows and this causes problems when clients try and
borrow resources from the pool. This is only expected to be an issue on
64 bit systems.
Add the <linux/atomic.h> header to pull in atomic_long* operations. So
that 32 bit systems continue to use atomic32_t but 64 bit systems can
use atomic64_t.
Link: http://lkml.kernel.org/r/1509033843-25667-1-git-send-email-sbates@raithlin.com
Signed-off-by: Stephen Bates <sbates@raithlin.com>
Reviewed-by: Logan Gunthorpe <logang@deltatee.com>
Reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Reviewed-by: Daniel Mentz <danielmentz@google.com>
Cc: Jonathan Corbet <corbet@lwn.net>
commit 81a7be2cd69b412ab6aeacfe5ebf1bb6e5bce955 upstream.
asn1_ber_decoder() was ignoring errors from actions associated with the
opcodes ASN1_OP_END_SEQ_ACT, ASN1_OP_END_SET_ACT,
ASN1_OP_END_SEQ_OF_ACT, and ASN1_OP_END_SET_OF_ACT. In practice, this
meant the pkcs7_note_signed_info() action (since that was the only user
of those opcodes). Fix it by checking for the error, just like the
decoder does for actions associated with the other opcodes.
This bug allowed users to leak slab memory by repeatedly trying to add a
specially crafted "pkcs7_test" key (requires CONFIG_PKCS7_TEST_KEY).
In theory, this bug could also be used to bypass module signature
verification, by providing a PKCS#7 message that is misparsed such that
a signature's ->authattrs do not contain its ->msgdigest. But it
doesn't seem practical in normal cases, due to restrictions on the
format of the ->authattrs.
Fixes: 42d5ec27f873 ("X.509: Add an ASN.1 decoder")
Reviewed-by: James Morris <james.l.morris@oracle.com>
commit e0058f3a874ebb48b25be7ff79bc3b4e59929f90 upstream.
In asn1_ber_decoder(), indefinitely-sized ASN.1 items were being passed
to the action functions before their lengths had been computed, using
the bogus length of 0x80 (ASN1_INDEFINITE_LENGTH). This resulted in
reading data past the end of the input buffer, when given a specially
crafted message.
Fix it by rearranging the code so that the indefinite length is resolved
before the action is called.
This bug was originally found by fuzzing the X.509 parser in userspace
using libFuzzer from the LLVM project.
KASAN report (cleaned up slightly):
BUG: KASAN: slab-out-of-bounds in memcpy ./include/linux/string.h:341 [inline]
BUG: KASAN: slab-out-of-bounds in x509_fabricate_name.constprop.1+0x1a4/0x940 crypto/asymmetric_keys/x509_cert_parser.c:366
Read of size 128 at addr ffff880035dd9eaf by task keyctl/195
CPU: 1 PID: 195 Comm: keyctl Not tainted 4.14.0-09238-g1d3b78bbc6e9 #26
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.11.0-20171110_100015-anatol 04/01/2014
Call Trace:
__dump_stack lib/dump_stack.c:17 [inline]
dump_stack+0xd1/0x175 lib/dump_stack.c:53
print_address_description+0x78/0x260 mm/kasan/report.c:252
kasan_report_error mm/kasan/report.c:351 [inline]
kasan_report+0x23f/0x350 mm/kasan/report.c:409
memcpy+0x1f/0x50 mm/kasan/kasan.c:302
asn1_ber_decoder+0xb4a/0x1fd0 lib/asn1_decoder.c:447
x509_cert_parse+0x1c7/0x620 crypto/asymmetric_keys/x509_cert_parser.c:89
x509_key_preparse+0x61/0x750 crypto/asymmetric_keys/x509_public_key.c:174
asymmetric_key_preparse+0xa4/0x150 crypto/asymmetric_keys/asymmetric_type.c:388
key_create_or_update+0x4d4/0x10a0 security/keys/key.c:850
SYSC_add_key security/keys/keyctl.c:122 [inline]
SyS_add_key+0xe8/0x290 security/keys/keyctl.c:62
entry_SYSCALL_64_fastpath+0x1f/0x96
Allocated by task 195:
__do_kmalloc_node mm/slab.c:3675 [inline]
__kmalloc_node+0x47/0x60 mm/slab.c:3682
kvmalloc ./include/linux/mm.h:540 [inline]
SYSC_add_key security/keys/keyctl.c:104 [inline]
SyS_add_key+0x19e/0x290 security/keys/keyctl.c:62
Reported-by: Alexander Potapenko <glider@google.com>
commit 1d9ddde12e3c9bab7f3d3484eb9446315e3571ca upstream.
On a non-preemptible kernel, if KEYCTL_DH_COMPUTE is called with the
largest permitted inputs (16384 bits), the kernel spends 10+ seconds
doing modular exponentiation in mpi_powm() without rescheduling. If all
threads do it, it locks up the system. Moreover, it can cause
rcu_sched-stall warnings.
Notwithstanding the insanity of doing this calculation in kernel mode
rather than in userspace, fix it by calling cond_resched() as each bit
from the exponent is processed. It's still noninterruptible, but at
least it's preemptible now.
Do the cond_resched() once per bit rather than once per MPI limb because
each limb might still easily take 100+ milliseconds on slow CPUs.
syzkaller reported a NULL pointer dereference in asn1_ber_decoder(). It
can be reproduced by the following command, assuming
CONFIG_PKCS7_TEST_KEY=y:
keyctl add pkcs7_test desc '' @s
The bug is that if the data buffer is empty, an integer underflow occurs
in the following check:
if (unlikely(dp >= datalen - 1))
goto data_overrun_error;
This results in the NULL data pointer being dereferenced.
Fix it by checking for 'datalen - dp < 2' instead.
Also fix the similar check for 'dp >= datalen - n' later in the same
function. That one possibly could result in a buffer overread.
The NULL pointer dereference was reproducible using the "pkcs7_test" key
type but not the "asymmetric" key type because the "asymmetric" key type
checks for a 0-length payload before calling into the ASN.1 decoder but
the "pkcs7_test" key type does not.
The bug report was:
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: asn1_ber_decoder+0x17f/0xe60 lib/asn1_decoder.c:233
PGD 7b708067 P4D 7b708067 PUD 7b6ee067 PMD 0
Oops: 0000 [#1] SMP
Modules linked in:
CPU: 0 PID: 522 Comm: syz-executor1 Not tainted 4.14.0-rc8 #7
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.3-20171021_125229-anatol 04/01/2014
task: ffff9b6b3798c040 task.stack: ffff9b6b37970000
RIP: 0010:asn1_ber_decoder+0x17f/0xe60 lib/asn1_decoder.c:233
RSP: 0018:ffff9b6b37973c78 EFLAGS: 00010216
RAX: 0000000000000000 RBX: 0000000000000000 RCX: 000000000000021c
RDX: ffffffff814a04ed RSI: ffffb1524066e000 RDI: ffffffff910759e0
RBP: ffff9b6b37973d60 R08: 0000000000000001 R09: ffff9b6b3caa4180
R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000002
R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
FS: 00007f10ed1f2700(0000) GS:ffff9b6b3ea00000(0000) knlGS:0000000000000000
CR2: 0000000000000000 CR3: 000000007b6f3000 CR4: 00000000000006f0
Call Trace:
pkcs7_parse_message+0xee/0x240 crypto/asymmetric_keys/pkcs7_parser.c:139
verify_pkcs7_signature+0x33/0x180 certs/system_keyring.c:216
pkcs7_preparse+0x41/0x70 crypto/asymmetric_keys/pkcs7_key_type.c:63
key_create_or_update+0x180/0x530 security/keys/key.c:855
SyS_add_key+0xbf/0x250 security/keys/keyctl.c:62
entry_SYSCALL_64_fastpath+0x1f/0xbe
RIP: 0033:0x4585c9
RSP: 002b:00007f10ed1f1bd8 EFLAGS: 00000216 ORIG_RAX: 00000000000000f8
RAX: ffffffffffffffda RBX: 00007f10ed1f2700 RCX: 00000000004585c9
RDX: 0000000020000000 RSI: 0000000020008ffb RDI: 0000000020008000
RBP: 0000000000000000 R08: ffffffffffffffff R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000216 R12: 00007fff1b2260ae
R13: 00007fff1b2260af R14: 00007f10ed1f2700 R15: 0000000000000000
Code: dd ca ff 48 8b 45 88 48 83 e8 01 4c 39 f0 0f 86 a8 07 00 00 e8 53 dd ca ff 49 8d 46 01 48 89 85 58 ff ff ff 48 8b 85 60 ff ff ff <42> 0f b6 0c 30 89 c8 88 8d 75 ff ff ff 83 e0 1f 89 8d 28 ff ff
RIP: asn1_ber_decoder+0x17f/0xe60 lib/asn1_decoder.c:233 RSP: ffff9b6b37973c78
Reported-by: syzbot <syzkaller@googlegroups.com>
Cc: <stable@vger.kernel.org> # v3.7+
Signed-off-by: James Morris <james.l.morris@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull initial SPDX identifiers from Greg KH:
"License cleanup: add SPDX license identifiers to some files
Update the files which contain no license information with the
'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally
binding shorthand, which can be used instead of the full boiler plate
text.
This patch is based on work done by Thomas Gleixner and Kate Stewart
and Philippe Ombredanne.
How this work was done:
Patches were generated and checked against linux-4.14-rc6 for a subset
of the use cases:
where non-standard license headers were used, and references to
license had to be inferred by heuristics based on keywords.
The analysis to determine which SPDX License Identifier to be applied
to a file was done in a spreadsheet of side by side results from of
the output of two independent scanners (ScanCode & Windriver)
producing SPDX tag:value files created by Philippe Ombredanne.
Philippe prepared the base worksheet, and did an initial spot review
of a few 1000 files.
The 4.13 kernel was the starting point of the analysis with 60,537
files assessed. Kate Stewart did a file by file comparison of the
scanner results in the spreadsheet to determine which SPDX license
identifier(s) to be applied to the file. She confirmed any
determination that was not immediately clear with lawyers working with
the Linux Foundation.
- Make and config files were included as candidates if they contained
>5 lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
Linux-syscall-note" otherwise it was "GPL-2.0". Results of that
was:
- when the two scanners agreed on the detected license(s), that
became the concluded license(s).
- when there was disagreement between the two scanners (one detected
a license but the other didn't, or they both detected different
resulted in a clear resolution of the license that should apply
(and which scanner probably needed to revisit its heuristics).
in time.
source files by Kate, Philippe, Thomas and, in some cases,
confirmation by lawyers working with the Linux Foundation.
disagreed against that SPDX file, to see if there was new insights.
The Windriver scanner is based on an older version of FOSSology in
part, so they are related.
files he inspected. For the non-uapi files Thomas did random spot
checks in about 15000 files.
copy/paste license identifier errors, and have been fixed to reflect
the correct identifier.
inspection and review of the 12,461 patched files from the initial
patch version early this week with:
license ids and scores
- reviewing anything where there was no detection but the patch
license was not GPL-2.0 WITH Linux-syscall-note to ensure that the
generate the patches.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
* tag 'spdx_identifiers-4.14-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
License cleanup: add SPDX license identifier to uapi header files with a license
License cleanup: add SPDX license identifier to uapi header files with no license
License cleanup: add SPDX GPL-2.0 license identifier to files with no license
the use cases:
lines of source
lines).
GPL-2.0 11139
in time.
they are related.
correct identifier.
syzkaller with KASAN reported an out-of-bounds read in
asn1_ber_decoder(). It can be reproduced by the following command,
assuming CONFIG_X509_CERTIFICATE_PARSER=y and CONFIG_KASAN=y:
keyctl add asymmetric desc $'\x30\x30' @s
The bug is that the length of an ASN.1 data value isn't validated in the
case where it is encoded using the short form, causing the decoder to
read past the end of the input buffer. Fix it by validating the length.
The bug report was:
BUG: KASAN: slab-out-of-bounds in asn1_ber_decoder+0x10cb/0x1730 lib/asn1_decoder.c:233
Read of size 1 at addr ffff88003cccfa02 by task syz-executor0/6818
CPU: 1 PID: 6818 Comm: syz-executor0 Not tainted 4.14.0-rc7-00008-g5f479447d983 #2
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:16 [inline]
dump_stack+0xb3/0x10b lib/dump_stack.c:52
print_address_description+0x79/0x2a0 mm/kasan/report.c:252
kasan_report+0x236/0x340 mm/kasan/report.c:409
__asan_report_load1_noabort+0x14/0x20 mm/kasan/report.c:427
x509_cert_parse+0x1db/0x650 crypto/asymmetric_keys/x509_cert_parser.c:89
x509_key_preparse+0x64/0x7a0 crypto/asymmetric_keys/x509_public_key.c:174
asymmetric_key_preparse+0xcb/0x1a0 crypto/asymmetric_keys/asymmetric_type.c:388
key_create_or_update+0x347/0xb20 security/keys/key.c:855
SyS_add_key+0x1cd/0x340 security/keys/keyctl.c:62
RIP: 0033:0x447c89
RSP: 002b:00007fca7a5d3bd8 EFLAGS: 00000246 ORIG_RAX: 00000000000000f8
RAX: ffffffffffffffda RBX: 00007fca7a5d46cc RCX: 0000000000447c89
RDX: 0000000020006f4a RSI: 0000000020006000 RDI: 0000000020001ff5
RBP: 0000000000000046 R08: fffffffffffffffd R09: 0000000000000000
R10: 0000000000000002 R11: 0000000000000246 R12: 0000000000000000
R13: 0000000000000000 R14: 00007fca7a5d49c0 R15: 00007fca7a5d4700
It turns out that some drivers seem to think it's ok to remap page
ranges from within interrupts and even NMI's. That is definitely not
the case, since the page table build-up is simply not interrupt-safe.
This showed up in the zero-day robot that reported it for the ACPI APEI
GHES ("Generic Hardware Error Source") driver. Normally it had been
hidden by the fact that no page table operations had been needed because
the vmalloc area had been set up by other things.
Apparently due to a recent change to the GHEI driver: commit
77b246b32b2c ("acpi: apei: check for pending errors when probing GHES
entries") 0day actually caught a case during bootup whenthe ioremap
called down to page allocation. But that recent change only showed the
symptom, it wasn't the root cause of the problem.
Hopefully it is limited to just that one driver.
If you need to access random physical memory, you either need to ioremap
in process context, or you need to use the FIXMAP facility to set one
particular fixmap entry to the required mapping - that can be done safely.
Cc: Len Brown <lenb@kernel.org>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Tyler Baicar <tbaicar@codeaurora.org>
This fixes CVE-2017-12193.
Fix a case in the assoc_array implementation in which a new leaf is
added that needs to go into a node that happens to be full, where the
existing leaves in that node cluster together at that level to the
exclusion of new leaf.
What needs to happen is that the existing leaves get moved out to a new
node, N1, at level + 1 and the existing node needs replacing with one,
N0, that has pointers to the new leaf and to N1.
The code that tries to do this gets this wrong in two ways:
(1) The pointer that should've pointed from N0 to N1 is set to point
recursively to N0 instead.
(2) The backpointer from N0 needs to be set correctly in the case N0 is
either the root node or reached through a shortcut.
Fix this by removing this path and using the split_node path instead,
which achieves the same end, but in a more general way (thanks to Eric
Biggers for spotting the redundancy).
The problem manifests itself as:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000010
IP: assoc_array_apply_edit+0x59/0xe5
Fixes: 3cb989501c26 ("Add a generic associative array implementation.")
Reported-and-tested-by: WU Fan <u3536072@connect.hku.hk>
Cc: stable@vger.kernel.org [v3.13-rc1+]
Pull networking fixes from David Miller:
"A little more than usual this time around. Been travelling, so that is
part of it.
Anyways, here are the highlights:
1) Deal with memcontrol races wrt. listener dismantle, from Eric
Dumazet.
2) Handle page allocation failures properly in nfp driver, from Jaku
Kicinski.
3) Fix memory leaks in macsec, from Sabrina Dubroca.
4) Fix crashes in pppol2tp_session_ioctl(), from Guillaume Nault.
5) Several fixes in bnxt_en driver, including preventing potential
NVRAM parameter corruption from Michael Chan.
6) Fix for KRACK attacks in wireless, from Johannes Berg.
7) rtnetlink event generation fixes from Xin Long.
8) Deadlock in mlxsw driver, from Ido Schimmel.
9) Disallow arithmetic operations on context pointers in bpf, from
Jakub Kicinski.
10) Missing sock_owned_by_user() check in sctp_icmp_redirect(), from
Xin Long.
11) Only TCP is supported for sockmap, make that explicit with a
check, from John Fastabend.
12) Fix IP options state races in DCCP and TCP, from Eric Dumazet.
13) Fix panic in packet_getsockopt(), also from Eric Dumazet.
14) Add missing locked in hv_sock layer, from Dexuan Cui.
15) Various aquantia bug fixes, including several statistics handling
cures. From Igor Russkikh et al.
16) Fix arithmetic overflow in devmap code, from John Fastabend.
17) Fix busted socket memory accounting when we get a fault in the tcp
zero copy paths. From Willem de Bruijn.
18) Don't leave opt->tot_len uninitialized in ipv6, from Eric Dumazet"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (106 commits)
stmmac: Don't access tx_q->dirty_tx before netif_tx_lock
ipv6: flowlabel: do not leave opt->tot_len with garbage
of_mdio: Fix broken PHY IRQ in case of probe deferral
textsearch: fix typos in library helpers
rxrpc: Don't release call mutex on error pointer
net: stmmac: Prevent infinite loop in get_rx_timestamp_status()
net: stmmac: Fix stmmac_get_rx_hwtstamp()
net: stmmac: Add missing call to dev_kfree_skb()
mlxsw: spectrum_router: Configure TIGCR on init
mlxsw: reg: Add Tunneling IPinIP General Configuration Register
net: ethtool: remove error check for legacy setting transceiver type
soreuseport: fix initialization race
net: bridge: fix returning of vlan range op errors
sock: correct sk_wmem_queued accounting on efault in tcp zerocopy
bpf: add test cases to bpf selftests to cover all access tests
bpf: fix pattern matches for direct packet access
bpf: fix off by one for range markings with L{T, E} patterns
bpf: devmap fix arithmetic overflow in bitmap_size calculation
net: aquantia: Bad udp rate on default interrupt coalescing
net: aquantia: Enable coalescing management via ethtool interface
Fix spellos (typos) in textsearch library helpers.
Pull locking fixes from Ingo Molnar:
"Two lockdep fixes for bugs introduced by the cross-release dependency
tracking feature - plus a commit that disables it because performance
regressed in an absymal fashion on some systems"
* 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
locking/lockdep: Disable cross-release features for now
locking/selftest: Avoid false BUG report
locking/lockdep: Fix stacktrace mess
Johan Hovold reported a big lockdep slowdown on his system, caused by lockdep:
> I had noticed that the BeagleBone Black boot time appeared to have
> increased significantly with 4.14 and yesterday I finally had time to
> investigate it.
> Boot time (from "Linux version" to login prompt) had in fact doubled
> since 4.13 where it took 17 seconds (with my current config) compared to
> the 35 seconds I now see with 4.14-rc4.
> I quick bisect pointed to lockdep and specifically the following commit:
> 28a903f63ec0 ("locking/lockdep: Handle non(or multi)-acquisition of a crosslock")
Because the final v4.14 release is close, disable the cross-release lockdep
features for now.
Bisected-by: Johan Hovold <johan@kernel.org>
Debugged-by: Johan Hovold <johan@kernel.org>
Reported-by: Johan Hovold <johan@kernel.org>
Cc: Byungchul Park <byungchul.park@lge.com>
Cc: Tony Lindgren <tony@atomide.com>
Cc: kernel-team@lge.com
Cc: linux-omap@vger.kernel.org
Link: http://lkml.kernel.org/r/20171014072659.f2yr6mhm5ha3eou7@gmail.com
Expand the "Runtime testing" menu by including more entries inside it
instead of after it. This is just Kconfig symbol movement.
This causes the (arch-independent) Runtime tests to be presented
(listed) all in one place instead of in multiple places.
Link: http://lkml.kernel.org/r/c194e5c4-2042-bf94-a2d8-7aa13756e257@infradead.org
Cc: "Luis R. Rodriguez" <mcgrof@kernel.org>
digsig_verify() requests a user key, then accesses its payload.
However, a revoked key has a NULL payload, and we failed to check for
this. request_key() *does* skip revoked keys, but there is still a
window where the key can be revoked before we acquire its semaphore.
Fix it by checking for a NULL payload, treating it like a key which was
already revoked at the time it was requested.
Fixes: 051dbb918c7f ("crypto: digital signature verification support")
Cc: <stable@vger.kernel.org> [v3.3+]
Cc: Dmitry Kasatkin <dmitry.kasatkin@intel.com>
The work-around for the expected failure is providing another failure :/
Only when CONFIG_PROVE_LOCKING=y do we increment unexpected_testcase_failures,
so only then do we need to decrement, otherwise we'll end up with a negative
number and that will again trigger a BUG (printout, not crash).
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Tested-by: Fengguang Wu <fengguang.wu@intel.com>
Fixes: d82fed752942 ("locking/lockdep/selftests: Fix mixed read-write ABBA tests")
printk_ratelimit() invokes ___ratelimit() which may invoke a normal
printk() (pr_warn() in this particular case) to warn about suppressed
output. Given that printk_ratelimit() may be called from anywhere, that
pr_warn() is dangerous - it may end up deadlocking the system. Fix
___ratelimit() by using deferred printk().
Sasha reported the following lockdep error:
: Unregister pv shared memory for cpu 8
: select_fallback_rq: 3 callbacks suppressed
: process 8583 (trinity-c78) no longer affine to cpu8
: WARNING: possible circular locking dependency detected
: 4.14.0-rc2-next-20170927+ #252 Not tainted
: migration/8/62 is trying to acquire lock:
: (&port_lock_key){-.-.}, at: serial8250_console_write()
: but task is already holding lock:
: (&rq->lock){-.-.}, at: sched_cpu_dying()
: which lock already depends on the new lock.
: the existing dependency chain (in reverse order) is:
: -> #3 (&rq->lock){-.-.}:
: __lock_acquire()
: lock_acquire()
: _raw_spin_lock()
: task_fork_fair()
: sched_fork()
: copy_process.part.31()
: _do_fork()
: kernel_thread()
: rest_init()
: start_kernel()
: x86_64_start_reservations()
: x86_64_start_kernel()
: verify_cpu()
: -> #2 (&p->pi_lock){-.-.}:
: __lock_acquire()
: lock_acquire()
: _raw_spin_lock_irqsave()
: try_to_wake_up()
: default_wake_function()
: woken_wake_function()
: __wake_up_common()
: __wake_up_common_lock()
: __wake_up()
: tty_wakeup()
: tty_port_default_wakeup()
: tty_port_tty_wakeup()
: uart_write_wakeup()
: serial8250_tx_chars()
: serial8250_handle_irq.part.25()
: serial8250_default_handle_irq()
: serial8250_interrupt()
: __handle_irq_event_percpu()
: handle_irq_event_percpu()
: handle_irq_event()
: handle_level_irq()
: handle_irq()
: do_IRQ()
: ret_from_intr()
: native_safe_halt()
: default_idle()
: arch_cpu_idle()
: default_idle_call()
: do_idle()
: cpu_startup_entry()
: rest_init()
: start_kernel()
: verify_cpu()
: -> #1 (&tty->write_wait){-.-.}:
: __lock_acquire()
: lock_acquire()
: __wake_up()
: tty_wakeup()
: handle_irq()
: do_IRQ()
: ret_from_intr()
: default_idle()
: arch_cpu_idle()
: do_idle()
: rest_init()
: start_kernel()
: verify_cpu()
: -> #0 (&port_lock_key){-.-.}:
: check_prev_add()
: __lock_acquire()
: lock_acquire()
: univ8250_console_write()
: console_unlock()
: vprintk_emit()
: vprintk_default()
: vprintk_func()
: printk()
: ___ratelimit()
: __printk_ratelimit()
: select_fallback_rq()
: sched_cpu_dying()
: cpuhp_invoke_callback()
: take_cpu_down()
: multi_cpu_stop()
: cpu_stopper_thread()
: smpboot_thread_fn()
: kthread()
: ret_from_fork()
: other info that might help us debug this:
: Chain exists of:
: &port_lock_key --> &p->pi_lock --> &rq->lock
: Possible unsafe locking scenario:
: CPU0 CPU1
: lock(&rq->lock);
: lock(&p->pi_lock);
: lock(&rq->lock);
: lock(&port_lock_key);
: *** DEADLOCK ***
: 4 locks held by migration/8/62:
: #0: (&p->pi_lock){-.-.}, at: sched_cpu_dying()
: #1: (&rq->lock){-.-.}, at: sched_cpu_dying()
: #2: (printk_ratelimit_state.lock){....}, at: ___ratelimit()
: #3: (console_lock){+.+.}, at: vprintk_emit()
: stack backtrace:
: CPU: 8 PID: 62 Comm: migration/8 Not tainted 4.14.0-rc2-next-20170927+ #252
: Call Trace:
: dump_stack()
: print_circular_bug()
: check_prev_add()
: ? add_lock_to_list.isra.26()
: ? check_usage()
: ? kvm_clock_read()
: ? kvm_sched_clock_read()
: ? sched_clock()
: ? check_preemption_disabled()
: __lock_acquire()
: ? __lock_acquire()
: ? debug_check_no_locks_freed()
: ? memcpy()
: lock_acquire()
: ? serial8250_console_write()
: ? serial8250_start_tx()
: ? lock_acquire()
: ? memcpy()
: console_unlock()
: ? __down_trylock_console_sem()
: vprintk_emit()
: vprintk_default()
: vprintk_func()
: printk()
: ? show_regs_print_info()
: ? lock_acquire()
: ___ratelimit()
: sched_cpu_dying()
: ? sched_cpu_starting()
: ? rcutree_dying_cpu()
: ? cpu_disable_common()
: take_cpu_down()
: ? trace_hardirqs_off_caller()
: ? cpuhp_invoke_callback()
: multi_cpu_stop()
: ? __this_cpu_preempt_check()
: ? cpu_stop_queue_work()
: ? cpu_stop_create()
: ? sort_range()
: ? schedule()
: ? __kthread_parkme()
: kthread()
: ? sort_range()
: ? kthread_create_on_node()
: ret_from_fork()
: process 9121 (trinity-c78) no longer affine to cpu8
: smpboot: CPU 8 is now offline
Link: http://lkml.kernel.org/r/20170928120405.18273-1-sergey.senozhatsky@gmail.com
Fixes: 6b1d174b0c27b ("ratelimit: extend to print suppressed messages on release")
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Reported-by: Sasha Levin <levinsasha928@gmail.com>
Reviewed-by: Petr Mladek <pmladek@suse.com>
idr_replace() returns the old value on success, not 0.
Link: http://lkml.kernel.org/r/20170918162642.37511-1-ebiggers3@gmail.com
Don't populate the read-only arrays dec32table and dec64table on the
stack, instead make them both static const. Makes the object code
smaller by over 10K bytes:
Before:
31500 0 0 31500 7b0c lib/lz4/lz4_decompress.o
After:
20237 176 0 20413 4fbd lib/lz4/lz4_decompress.o
(gcc version 7.2.0 x86_64)
Link: http://lkml.kernel.org/r/20170921221939.20820-1-colin.king@canonical.com
Cc: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Cc: Sven Schmidt <4sschmid@informatik.uni-hamburg.de>
Cc: Joe Perches <joe@perches.com>
