[ Upstream commit 9ff6aa027dbb98755f0265695354f2dd07c0d1ce ]
debug_dma_dump_mappings() can take a lot of cpu cycles :
lpk43:/# time wc -l /sys/kernel/debug/dma-api/dump
163435 /sys/kernel/debug/dma-api/dump
real 0m0.463s
user 0m0.003s
sys 0m0.459s
Let's add a cond_resched() to avoid holding cpu for too long.
Cc: Corentin Labbe <clabbe@baylibre.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
commit 702600eef73033ddd4eafcefcbb6560f3e3a90f7 upstream.
Newer versions of awk spit out these fun warnings:
awk: ../lib/raid6/unroll.awk:16: warning: regexp escape sequence `\#' is not a known regexp operator
As commit 700c1018b86d ("x86/insn: Fix awk regexp warnings") showed, it
turns out that there are a number of awk strings that do not need to be
escaped and newer versions of awk now warn about this.
Fix the string up so that no warning is produced. The exact same kernel
module gets created before and after this patch, showing that it wasn't
needed.
Link: https://lore.kernel.org/r/20191206152600.GA75093@kroah.com
[ Upstream commit 35004f2e55807a1a1491db24ab512dd2f770a130 ]
Fixes build break on most ARM/ARM64 defconfigs:
lib/genalloc.c: In function 'gen_pool_add_virt':
lib/genalloc.c:190:10: error: implicit declaration of function 'vzalloc_node'; did you mean 'kzalloc_node'?
lib/genalloc.c:190:8: warning: assignment to 'struct gen_pool_chunk *' from 'int' makes pointer from integer without a cast [-Wint-conversion]
lib/genalloc.c: In function 'gen_pool_destroy':
lib/genalloc.c:254:3: error: implicit declaration of function 'vfree'; did you mean 'kfree'?
Fixes: 6862d2fc8185 ('lib/genalloc.c: use vzalloc_node() to allocate the bitmap')
Cc: Huang Shijie <sjhuang@iluvatar.ai>
Cc: Alexey Skidanov <alexey.skidanov@intel.com>
[ Upstream commit 6862d2fc81859f88c1f3f660886427893f2b4f3f ]
Some devices may have big memory on chip, such as over 1G. In some
cases, the nbytes maybe bigger then 4M which is the bounday of the
memory buddy system (4K default).
So use vzalloc_node() to allocate the bitmap. Also use vfree to free
it.
Link: http://lkml.kernel.org/r/20181225015701.6289-1-sjhuang@iluvatar.ai
Signed-off-by: Huang Shijie <sjhuang@iluvatar.ai>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
[ Upstream commit 52fbf1134d479234d7e64ba9dcbaea23405f229e ]
gen_pool_alloc_algo() uses different allocation functions implementing
different allocation algorithms. With gen_pool_first_fit_align()
allocation function, the returned address should be aligned on the
requested boundary.
If chunk start address isn't aligned on the requested boundary, the
returned address isn't aligned too. The only way to get properly
aligned address is to initialize the pool with chunks aligned on the
requested boundary. If want to have an ability to allocate buffers
aligned on different boundaries (for example, 4K, 1MB, ...), the chunk
start address should be aligned on the max possible alignment.
This happens because gen_pool_first_fit_align() looks for properly
aligned memory block without taking into account the chunk start address
alignment.
To fix this, we provide chunk start address to
gen_pool_first_fit_align() and change its implementation such that it
starts looking for properly aligned block with appropriate offset
(exactly as is done in CMA).
Link: https://lkml.kernel.org/lkml/a170cf65-6884-3592-1de9-4c235888cc8a@intel.com
Link: http://lkml.kernel.org/r/1541690953-4623-1-git-send-email-alexey.skidanov@intel.com
Signed-off-by: Alexey Skidanov <alexey.skidanov@intel.com>
Cc: Logan Gunthorpe <logang@deltatee.com>
Cc: Daniel Mentz <danielmentz@google.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: Laura Abbott <labbott@redhat.com>
[ Upstream commit b7e9728f3d7fc5c5c8508d99f1675212af5cfd49 ]
Attempting to allocate an entry at 0xffffffff when one is already
present would succeed in allocating one at 2^32, which would confuse
everything. Return -ENOSPC in this case, as expected.
Signed-off-by: Matthew Wilcox (Oracle) <willy@infradead.org>
commit 5c089fd0c73411f2170ab795c9ffc16718c7d007 upstream.
If the entry is deleted from the IDR between the call to
radix_tree_iter_find() and rcu_dereference_raw(), idr_get_next()
will return NULL, which will end the iteration prematurely. We should
instead continue to the next entry in the IDR. This only happens if the
iteration is protected by the RCU lock. Most IDR users use a spinlock
or semaphore to exclude simultaneous modifications. It was noticed once
the PID allocator was converted to use the IDR, as it uses the RCU lock,
but there may be other users elsewhere in the kernel.
We can't use the normal pattern of calling radix_tree_deref_retry()
(which catches both a retry entry in a leaf node and a node entry in
the root) as the IDR supports storing entries which are unaligned,
which will trigger an infinite loop if they are encountered. Instead,
we have to explicitly check whether the entry is a retry entry.
Fixes: 0a835c4f090a ("Reimplement IDR and IDA using the radix tree")
Reported-by: Brendan Gregg <bgregg@netflix.com>
Tested-by: Brendan Gregg <bgregg@netflix.com>
commit e80a0af4759a164214f02da157a3800753ce135f upstream.
Many kernel drivers contain code that allocates and frees both a
scatterlist and the pages that populate that scatterlist.
Introduce functions in lib/scatterlist.c that perform these tasks
instead of duplicating this functionality in multiple drivers.
Only include these functions in the build if CONFIG_SGL_ALLOC=y
to avoid that the kernel size increases if this functionality is
not used.
Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
commit 5cbf2fff3bba8d3c6a4d47c1754de1cf57e2b01f upstream.
In the current code, we use the atomic_cmpxchg() to serialize the output
of the dump_stack(), but this implementation suffers the thundering herd
problem. We have observed such kind of livelock on a Marvell cn96xx
board(24 cpus) when heavily using the dump_stack() in a kprobe handler.
Actually we can let the competitors to wait for the releasing of the
lock before jumping to atomic_cmpxchg(). This will definitely mitigate
the thundering herd problem. Thanks Linus for the suggestion.
[akpm@linux-foundation.org: fix comment]
Link: http://lkml.kernel.org/r/20191030031637.6025-1-haokexin@gmail.com
Fixes: b58d977432c8 ("dump_stack: serialize the output from dump_stack()")
Signed-off-by: Kevin Hao <haokexin@gmail.com>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: <stable@vger.kernel.org>
[ Upstream commit b751c52bb587ae66f773b15204ef7a147467f4c7 ]
The current default value (400) is too low on many systems (e.g. some
ARM64 platform takes up 1000+ entries).
syzbot uses 16000 as default value, and has proved to be enough on beefy
configurations, so let's pick that value.
This consumes more RAM on boot (each entry is 160 bytes, so in total
~2.5MB of RAM), but the memory would later be freed (early_log is
__initdata).
Link: http://lkml.kernel.org/r/20190730154027.101525-1-drinkcat@chromium.org
Signed-off-by: Nicolas Boichat <drinkcat@chromium.org>
Suggested-by: Dmitry Vyukov <dvyukov@google.com>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Acked-by: Dmitry Vyukov <dvyukov@google.com>
Cc: Petr Mladek <pmladek@suse.com>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: Joe Lawrence <joe.lawrence@redhat.com>
Cc: Uladzislau Rezki <urezki@gmail.com>
Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
[ Upstream commit d4fddac5a51c378c5d3e68658816c37132611e1f ]
In test_firmware_init(), the buffer pointed to by the global pointer
'test_fw_config' is allocated through kzalloc(). Then, the buffer is
initialized in __test_firmware_config_init(). In the case that the
initialization fails, the following execution in test_firmware_init() needs
to be terminated with an error code returned to indicate this failure.
However, the allocated buffer is not freed on this execution path, leading
to a memory leak bug.
To fix the above issue, free the allocated buffer before returning from
test_firmware_init().
Signed-off-by: Wenwen Wang <wenwen@cs.uga.edu>
Link: https://lore.kernel.org/r/1563084696-6865-1-git-send-email-wang6495@umn.edu
[ Upstream commit 1a3241ff10d038ecd096d03380327f2a0b5840a6 ]
strscpy() performs the word-at-a-time optimistic reads. So it may may
access the memory past the end of the object, which is perfectly fine
since strscpy() doesn't use that (past-the-end) data and makes sure the
optimistic read won't cross a page boundary.
Use new read_word_at_a_time() to shut up the KASAN.
Note that this potentially could hide some bugs. In example bellow,
stscpy() will copy more than we should (1-3 extra uninitialized bytes):
char dst[8];
char *src;
src = kmalloc(5, GFP_KERNEL);
memset(src, 0xff, 5);
strscpy(dst, src, 8);
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
commit aeb87246537a83c2aff482f3f34a2e0991e02cbc upstream.
All mapping iterator logic is based on the assumption that sg->offset
is always lower than PAGE_SIZE.
But there are situations where sg->offset is such that the SG item
is on the second page. In that case sg_copy_to_buffer() fails
properly copying the data into the buffer. One of the reason is
that the data will be outside the kmapped area used to access that
data.
This patch fixes the issue by adjusting the mapping iterator
offset and pgoffset fields such that offset is always lower than
PAGE_SIZE.
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
Fixes: 4225fc8555a9 ("lib/scatterlist: use page iterator in the mapping iterator")
Cc: stable@vger.kernel.org
[ Upstream commit ef4d6a8556b637ad27c8c2a2cff1dda3da38e9a9 ]
Check if the syndrome provided by the caller is zero, and act
accordingly.
Signed-off-by: Ferdinand Blomqvist <ferdinand.blomqvist@gmail.com>
Link: https://lkml.kernel.org/r/20190620141039.9874-6-ferdinand.blomqvist@gmail.com
[ Upstream commit 2034a42d1747fc1e1eeef2c6f1789c4d0762cb9c ]
The decoding of shortenend codes is broken. It only works as expected if
there are no erasures.
When decoding with erasures, Lambda (the error and erasure locator
polynomial) is initialized from the given erasure positions. The pad
parameter is not accounted for by the initialisation code, and hence
Lambda is initialized from incorrect erasure positions.
The fix is to adjust the erasure positions by the supplied pad.
Link: https://lkml.kernel.org/r/20190620141039.9874-3-ferdinand.blomqvist@gmail.com
commit c8ea9fce2baf7b643384f36f29e4194fa40d33a6 upstream.
Sometimes mpi_powm will leak karactx because a memory allocation
failure causes a bail-out that skips the freeing of karactx. This
patch moves the freeing of karactx to the end of the function like
everything else so that it can't be skipped.
Reported-by: syzbot+f7baccc38dcc1e094e77@syzkaller.appspotmail.com
Fixes: cdec9cb5167a ("crypto: GnuPG based MPI lib - source files...")
Reviewed-by: Eric Biggers <ebiggers@kernel.org>
commit bd17cc5a20ae9aaa3ed775f360b75ff93cd66a1d upstream.
The limit here is supposed to be how much of the page is left, but it's
just using PAGE_SIZE as the limit.
The other thing to remember is that snprintf() returns the number of
bytes which would have been copied if we had had enough room. So that
means that if we run out of space then this code would end up passing a
negative value as the limit and the kernel would print an error message.
I have change the code to use scnprintf() which returns the number of
bytes that were successfully printed (not counting the NUL terminator).
Fixes: c92316bf8e94 ("test_firmware: add batched firmware tests")
Cc: stable <stable@vger.kernel.org>
[ Upstream commit c03a0fd0b609e2f5c669c2b7f27c8e1928e9196e ]
syzbot is hitting use-after-free bug in uinput module [1]. This is because
kobject_uevent(KOBJ_REMOVE) is called again due to commit 0f4dafc0563c6c49
("Kobject: auto-cleanup on final unref") after memory allocation fault
injection made kobject_uevent(KOBJ_REMOVE) from device_del() from
input_unregister_device() fail, while uinput_destroy_device() is expecting
that kobject_uevent(KOBJ_REMOVE) is not called after device_del() from
input_unregister_device() completed.
That commit intended to catch cases where nobody even attempted to send
"remove" uevents. But there is no guarantee that an event will ultimately
be sent. We are at the point of no return as far as the rest of the kernel
is concerned; there are no repeats or do-overs.
Also, it is not clear whether some subsystem depends on that commit.
If no subsystem depends on that commit, it will be better to remove
the state_{add,remove}_uevent_sent logic. But we don't want to risk
a regression (in a patch which will be backported) by trying to remove
that logic. Therefore, as a first step, let's avoid the use-after-free bug
by making sure that kobject_uevent(KOBJ_REMOVE) won't be triggered twice.
[1] https://syzkaller.appspot.com/bug?id=8b17c134fe938bbddd75a45afaa9e68af43a362d
Reported-by: syzbot <syzbot+f648cfb7e0b52bf7ae32@syzkaller.appspotmail.com>
Analyzed-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Fixes: 0f4dafc0563c6c49 ("Kobject: auto-cleanup on final unref")
Cc: Kay Sievers <kay@vrfy.org>
[ Upstream commit 29da93fea3ea39ab9b12270cc6be1b70ef201c9e ]
Randy reported objtool triggered on his (GCC-7.4) build:
lib/strncpy_from_user.o: warning: objtool: strncpy_from_user()+0x315: call to __ubsan_handle_add_overflow() with UACCESS enabled
lib/strnlen_user.o: warning: objtool: strnlen_user()+0x337: call to __ubsan_handle_sub_overflow() with UACCESS enabled
This is due to UBSAN generating signed-overflow-UB warnings where it
should not. Prior to GCC-8 UBSAN ignored -fwrapv (which the kernel
uses through -fno-strict-overflow).
Make the functions use 'unsigned long' throughout.
Reported-by: Randy Dunlap <rdunlap@infradead.org>
Acked-by: Randy Dunlap <rdunlap@infradead.org> # build-tested
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: luto@kernel.org
Link: http://lkml.kernel.org/r/20190424072208.754094071@infradead.org
commit a0934fd2b1208458e55fc4b48f55889809fce666 upstream.
This barrier only applies to the read-modify-write operations; in
particular, it does not apply to the atomic_set() primitive.
Replace the barrier with an smp_mb().
Fixes: 6c0ca7ae292ad ("sbitmap: fix wakeup hang after sbq resize")
Reported-by: "Paul E. McKenney" <paulmck@linux.ibm.com>
Reported-by: Peter Zijlstra <peterz@infradead.org>
Signed-off-by: Andrea Parri <andrea.parri@amarulasolutions.com>
Reviewed-by: Ming Lei <ming.lei@redhat.com>
Cc: Omar Sandoval <osandov@fb.com>
Cc: Ming Lei <ming.lei@redhat.com>
Cc: linux-block@vger.kernel.org
Cc: "Paul E. McKenney" <paulmck@linux.ibm.com>
[ Upstream commit b51ce3744f115850166f3d6c292b9c8cb849ad4f ]
Enablement of AMD's Secure Memory Encryption feature is determined very
early after start_kernel() is entered. Part of this procedure involves
scanning the command line for the parameter 'mem_encrypt'.
To determine intended state, the function sme_enable() uses library
functions cmdline_find_option() and strncmp(). Their use occurs early
enough such that it cannot be assumed that any instrumentation subsystem
is initialized.
For example, making calls to a KASAN-instrumented function before KASAN
is set up will result in the use of uninitialized memory and a boot
failure.
When AMD's SME support is enabled, conditionally disable instrumentation
of these dependent functions in lib/string.c and arch/x86/lib/cmdline.c.
[ bp: Get rid of intermediary nostackp var and cleanup whitespace. ]
Fixes: aca20d546214 ("x86/mm: Add support to make use of Secure Memory Encryption")
Reported-by: Li RongQing <lirongqing@baidu.com>
Signed-off-by: Gary R Hook <gary.hook@amd.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Boris Brezillon <bbrezillon@kernel.org>
Cc: Coly Li <colyli@suse.de>
Cc: "dave.hansen@linux.intel.com" <dave.hansen@linux.intel.com>
Cc: Kent Overstreet <kent.overstreet@gmail.com>
Cc: "luto@kernel.org" <luto@kernel.org>
Cc: Matthew Wilcox <willy@infradead.org>
Cc: "mingo@redhat.com" <mingo@redhat.com>
Cc: "peterz@infradead.org" <peterz@infradead.org>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: x86-ml <x86@kernel.org>
Link: https://lkml.kernel.org/r/155657657552.7116.18363762932464011367.stgit@sosrh3.amd.com
commit 6daef95b8c914866a46247232a048447fff97279 upstream.
Avoid cache line miss dereferencing struct page if we can.
page_copy_sane() mostly deals with order-0 pages.
Extra cache line miss is visible on TCP recvmsg() calls dealing
with GRO packets (typically 45 page frags are attached to one skb).
Bringing the 45 struct pages into cpu cache while copying the data
is not free, since the freeing of the skb (and associated
page frags put_page()) can happen after cache lines have been evicted.
commit f0996bc2978e02d2ea898101462b960f6119b18f upstream.
Building lib/ubsan.c with gcc-9 results in a ton of nasty warnings like
this one:
lib/ubsan.c warning: conflicting types for built-in function
‘__ubsan_handle_negate_overflow’; expected ‘void(void *, void *)’ [-Wbuiltin-declaration-mismatch]
The kernel's declarations of __ubsan_handle_*() often uses 'unsigned
long' types in parameters while GCC these parameters as 'void *' types,
hence the mismatch.
Fix this by using 'void *' to match GCC's declarations.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Fixes: c6d308534aef ("UBSAN: run-time undefined behavior sanity checker")
commit 69ca372c100fba99c78ef826a1795aa86e4f01a8 upstream.
A compiler can optimize away memset calls by replacing them with mov
instructions. There are KASAN tests that specifically test that KASAN
correctly handles memset calls so we don't want this optimization to
happen.
The solution is to add -fno-builtin flag to test_kasan.ko
Link: http://lkml.kernel.org/r/105ec9a308b2abedb1a0d1fdced0c22d765e4732.1519924383.git.andreyknvl@google.com
Signed-off-by: Andrey Konovalov <andreyknvl@google.com>
Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Nick Terrell <terrelln@fb.com>
Cc: Chris Mason <clm@fb.com>
Cc: Yury Norov <ynorov@caviumnetworks.com>
Cc: "Luis R . Rodriguez" <mcgrof@kernel.org>
Cc: Palmer Dabbelt <palmer@dabbelt.com>
Cc: "Paul E . McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Jeff Layton <jlayton@redhat.com>
Cc: "Jason A . Donenfeld" <Jason@zx2c4.com>
Cc: Kostya Serebryany <kcc@google.com>
commit 48c232395431c23d35cf3b4c5a090bd793316578 upstream.
Variable real_size is initialized with a value that is never read, it is
re-assigned a new value later on, hence the initialization is redundant
and can be removed.
Cleans up clang warning:
lib/test_kasan.c:422:21: warning: Value stored to 'real_size' during its initialization is never read
Link: http://lkml.kernel.org/r/20180206144950.32457-1-colin.king@canonical.com
commit ae3d6a323347940f0548bbb4b17f0bb2e9164169 upstream.
If CONFIG_TEST_KMOD is set to M, while CONFIG_BLOCK is not set, XFS and
BTRFS can not be compiled successly.
Link: http://lkml.kernel.org/r/20190410075434.35220-1-yuehaibing@huawei.com
Fixes: d9c6a72d6fa2 ("kmod: add test driver to stress test the module loader")
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Cc: Robin Murphy <robin.murphy@arm.com>
Cc: Luis Chamberlain <mcgrof@kernel.org>
[ Upstream commit cdc94a37493135e355dfc0b0e086d84e3eadb50d ]
fls counts bits starting from 1 to 32 (returns 0 for zero argument). If
we add 1 we shift right one bit more and loose precision from divisor,
what cause function incorect results with some numbers.
Corrected code was tested in user-space, see bugzilla:
https://bugzilla.kernel.org/show_bug.cgi?id=202391
Link: http://lkml.kernel.org/r/1548686944-11891-1-git-send-email-sgruszka@redhat.com
Fixes: 658716d19f8f ("div64_u64(): improve precision on 32bit platforms")
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Reported-by: Siarhei Volkau <lis8215@gmail.com>
Tested-by: Siarhei Volkau <lis8215@gmail.com>
Acked-by: Oleg Nesterov <oleg@redhat.com>
[ Upstream commit 5f074f3e192f10c9fade898b9b3b8812e3d83342 ]
A recent optimization in Clang (r355672) lowers comparisons of the
return value of memcmp against zero to comparisons of the return value
of bcmp against zero. This helps some platforms that implement bcmp
more efficiently than memcmp. glibc simply aliases bcmp to memcmp, but
an optimized implementation is in the works.
This results in linkage failures for all targets with Clang due to the
undefined symbol. For now, just implement bcmp as a tailcail to memcmp
to unbreak the build. This routine can be further optimized in the
future.
Other ideas discussed:
* A weak alias was discussed, but breaks for architectures that define
their own implementations of memcmp since aliases to declarations are
not permitted (only definitions). Arch-specific memcmp
implementations typically declare memcmp in C headers, but implement
them in assembly.
* -ffreestanding also is used sporadically throughout the kernel.
* -fno-builtin-bcmp doesn't work when doing LTO.
Link: https://bugs.llvm.org/show_bug.cgi?id=41035
Link: https://code.woboq.org/userspace/glibc/string/memcmp.c.html#bcmp
Link: https://github.com/llvm/llvm-project/commit/8e16d73346f8091461319a7dfc4ddd18eedcff13
Link: https://github.com/ClangBuiltLinux/linux/issues/416
Link: http://lkml.kernel.org/r/20190313211335.165605-1-ndesaulniers@google.com
Signed-off-by: Nick Desaulniers <ndesaulniers@google.com>
Reported-by: Nathan Chancellor <natechancellor@gmail.com>
Reported-by: Adhemerval Zanella <adhemerval.zanella@linaro.org>
Suggested-by: Arnd Bergmann <arnd@arndb.de>
Suggested-by: James Y Knight <jyknight@google.com>
Suggested-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Suggested-by: Nathan Chancellor <natechancellor@gmail.com>
Suggested-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Reviewed-by: Nathan Chancellor <natechancellor@gmail.com>
Tested-by: Nathan Chancellor <natechancellor@gmail.com>
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: David Laight <David.Laight@ACULAB.COM>
Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Dan Williams <dan.j.williams@intel.com>
[ Upstream commit de9c0d49d85dc563549972edc5589d195cd5e859 ]
While building arm32 allyesconfig, I ran into the following errors:
arch/arm/lib/xor-neon.c:17:2: error: You should compile this file with
'-mfloat-abi=softfp -mfpu=neon'
In file included from lib/raid6/neon1.c:27:
/home/nathan/cbl/prebuilt/lib/clang/8.0.0/include/arm_neon.h:28:2:
error: "NEON support not enabled"
Building V=1 showed NEON_FLAGS getting passed along to Clang but
__ARM_NEON__ was not getting defined. Ultimately, it boils down to Clang
only defining __ARM_NEON__ when targeting armv7, rather than armv6k,
which is the '-march' value for allyesconfig.
>From lib/Basic/Targets/ARM.cpp in the Clang source:
// This only gets set when Neon instructions are actually available, unlike
// the VFP define, hence the soft float and arch check. This is subtly
// different from gcc, we follow the intent which was that it should be set
// when Neon instructions are actually available.
if ((FPU & NeonFPU) && !SoftFloat && ArchVersion >= 7) {
Builder.defineMacro("__ARM_NEON", "1");
Builder.defineMacro("__ARM_NEON__");
// current AArch32 NEON implementations do not support double-precision
// floating-point even when it is present in VFP.
Builder.defineMacro("__ARM_NEON_FP",
"0x" + Twine::utohexstr(HW_FP & ~HW_FP_DP));
Ard Biesheuvel recommended explicitly adding '-march=armv7-a' at the
beginning of the NEON_FLAGS definitions so that __ARM_NEON__ always gets
definined by Clang. This doesn't functionally change anything because
that code will only run where NEON is supported, which is implicitly
armv7.
Link: https://github.com/ClangBuiltLinux/linux/issues/287
Suggested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
Acked-by: Nicolas Pitre <nico@linaro.org>
Reviewed-by: Nick Desaulniers <ndesaulniers@google.com>
Reviewed-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
[ Upstream commit 02106f883cd745523f7766d90a739f983f19e650 ]
Since kprobe breakpoing handler is using bsearch(), probing on this
routine can cause recursive breakpoint problem.
int3
->do_int3()
->ftrace_int3_handler()
->ftrace_location()
->ftrace_location_range()
->bsearch() -> int3
Prohibit probing on bsearch().
Signed-off-by: Andrea Righi <righi.andrea@gmail.com>
Acked-by: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/154998813406.31052.8791425358974650922.stgit@devbox
commit f8ae107eef209bff29a5816bc1aad40d5cd69a80 upstream.
The initial value (@m) compute is:
m = 1UL << (BITS_PER_LONG - 2);
while (m > x)
m >>= 2;
Which is a linear search for the highest even bit smaller or equal to @x
We can implement this using a binary search using __fls() (or better when
its hardware implemented).
m = 1UL << (__fls(x) & ~1UL);
Especially for small values of @x; which are the more common arguments
when doing a CDF on idle times; the linear search is near to worst case,
while the binary search of __fls() is a constant 6 (or 5 on 32bit)
branches.
cycles: branches: branch-misses:
PRE:
hot: 43.633557 +- 0.034373 45.333132 +- 0.002277 0.023529 +- 0.000681
cold: 207.438411 +- 0.125840 45.333132 +- 0.002277 6.976486 +- 0.004219
SOFTWARE FLS:
hot: 29.576176 +- 0.028850 26.666730 +- 0.004511 0.019463 +- 0.000663
cold: 165.947136 +- 0.188406 26.666746 +- 0.004511 6.133897 +- 0.004386
HARDWARE FLS:
hot: 24.720922 +- 0.025161 20.666784 +- 0.004509 0.020836 +- 0.000677
cold: 132.777197 +- 0.127471 20.666776 +- 0.004509 5.080285 +- 0.003874
Averages computed over all values <128k using a LFSR to generate order.
Cold numbers have a LFSR based branch trace buffer 'confuser' ran between
each int_sqrt() invocation.
Link: http://lkml.kernel.org/r/20171020164644.936577234@infradead.org
Suggested-by: Joe Perches <joe@perches.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Cc: Anshul Garg <aksgarg1989@gmail.com>
Cc: Davidlohr Bueso <dave@stgolabs.net>
Cc: Matthew Wilcox <mawilcox@microsoft.com>
Cc: Michael Davidson <md@google.com>
Cc: Joe Perches <joe@perches.com>
[ Upstream commit 408f13ef358aa5ad56dc6230c2c7deb92cf462b1 ]
As it stands if a shrink is delayed because of an outstanding
rehash, we will go into a rescheduling loop without ever doing
the rehash.
This patch fixes this by still carrying out the rehash and then
rescheduling so that we can shrink after the completion of the
rehash should it still be necessary.
The return value of EEXIST captures this case and other cases
(e.g., another thread expanded/rehashed the table at the same
time) where we should still proceed with the rehash.
Fixes: da20420f83ea ("rhashtable: Add nested tables")
Reported-by: Josh Elsasser <jelsasser@appneta.com>
Tested-by: Josh Elsasser <jelsasser@appneta.com>
commit 3f3295709edea6268ff1609855f498035286af73 upstream.
The current int_sqrt() computation is sub-optimal for the case of small
@x. Which is the interesting case when we're going to do cumulative
distribution functions on idle times, which we assume to be a random
variable, where the target residency of the deepest idle state gives an
upper bound on the variable (5e6ns on recent Intel chips).
In the case of small @x, the compute loop:
while (m != 0) {
b = y + m;
y >>= 1;
if (x >= b) {
x -= b;
y += m;
m >>= 2;
can be reduced to:
while (m > x)
m >>= 2;
Because y==0, b==m and until x>=m y will remain 0.
And while this is computationally equivalent, it runs much faster
because there's less code, in particular less branches.
OLD:
hot: 45.109444 +- 0.044117 44.333392 +- 0.002254 0.018723 +- 0.000593
cold: 187.737379 +- 0.156678 44.333407 +- 0.002254 6.272844 +- 0.004305
PRE:
hot: 67.937492 +- 0.064124 66.999535 +- 0.000488 0.066720 +- 0.001113
cold: 232.004379 +- 0.332811 66.999527 +- 0.000488 6.914634 +- 0.006568
POST:
Link: http://lkml.kernel.org/r/20171020164644.876503355@infradead.org
Fixes: 30493cc9dddb ("lib/int_sqrt.c: optimize square root algorithm")
Suggested-by: Anshul Garg <aksgarg1989@gmail.com>
[ Upstream commit bb2ba2d75a2d673e76ddaf13a9bd30d6a8b1bb08 ]
Fix the creation of shortcuts for which the length of the index key value
is an exact multiple of the machine word size. The problem is that the
code that blanks off the unused bits of the shortcut value malfunctions if
the number of bits in the last word equals machine word size. This is due
to the "<<" operator being given a shift of zero in this case, and so the
mask that should be all zeros is all ones instead. This causes the
subsequent masking operation to clear everything rather than clearing
nothing.
Ordinarily, the presence of the hash at the beginning of the tree index key
makes the issue very hard to test for, but in this case, it was encountered
due to a development mistake that caused the hash output to be either 0
(keyring) or 1 (non-keyring) only. This made it susceptible to the
keyctl/unlink/valid test in the keyutils package.
The fix is simply to skip the blanking if the shift would be 0. For
example, an index key that is 64 bits long would produce a 0 shift and thus
a 'blank' of all 1s. This would then be inverted and AND'd onto the
index_key, incorrectly clearing the entire last word.
Fixes: 3cb989501c26 ("Add a generic associative array implementation.")
Signed-off-by: James Morris <james.morris@microsoft.com>
[ Upstream commit db7ddeab3ce5d64c9696e70d61f45ea9909cd196 ]
There is a copy and paste bug so we set "config->test_driver" to NULL
twice instead of setting "config->test_fs". Smatch complains that it
leads to a double free:
lib/test_kmod.c:840 __kmod_config_init() warn: 'config->test_fs' double freed
Link: http://lkml.kernel.org/r/20190121140011.GA14283@kadam
Acked-by: Luis Chamberlain <mcgrof@kernel.org>
[ Upstream commit 0464ed24380905d640030d368cd84a4e4d1e15e2 ]
Currently seq_buf_puts() will happily create a non null-terminated
string for you in the buffer. This is particularly dangerous if the
buffer is on the stack.
For example:
char buf[8];
char secret = "secret";
struct seq_buf s;
seq_buf_init(&s, buf, sizeof(buf));
seq_buf_puts(&s, "foo");
printk("Message is %s\n", buf);
Can result in:
Message is fooªªªªªsecret
We could require all users to memset() their buffer to zero before
use. But that seems likely to be forgotten and lead to bugs.
Instead we can change seq_buf_puts() to always leave the buffer in a
null-terminated state.
The only downside is that this makes the buffer 1 character smaller
for seq_buf_puts(), but that seems like a good trade off.
Link: http://lkml.kernel.org/r/20181019042109.8064-1-mpe@ellerman.id.au
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
commit 10fdf838e5f540beca466e9d1325999c072e5d3f upstream.
On several arches, virt_to_phys() is in io.h
Build fails without it:
CC lib/test_debug_virtual.o
lib/test_debug_virtual.c: In function 'test_debug_virtual_init':
lib/test_debug_virtual.c:26:7: error: implicit declaration of function 'virt_to_phys' [-Werror=implicit-function-declaration]
pa = virt_to_phys(va);
Fixes: e4dace361552 ("lib: add test module for CONFIG_DEBUG_VIRTUAL")
CC: stable@vger.kernel.org
commit e213574a449f7a57d4202c1869bbc7680b6b5521 upstream.
We cannot build these files with clang as it does not allow altivec
instructions in assembly when -msoft-float is passed.
Jinsong Ji <jji@us.ibm.com> wrote:
> We currently disable Altivec/VSX support when enabling soft-float. So
> any usage of vector builtins will break.
> Enable Altivec/VSX with soft-float may need quite some clean up work, so
> I guess this is currently a limitation.
> Removing -msoft-float will make it work (and we are lucky that no
> floating point instructions will be generated as well).
This is a workaround until the issue is resolved in clang.
Link: https://bugs.llvm.org/show_bug.cgi?id=31177
Link: https://github.com/ClangBuiltLinux/linux/issues/239
Signed-off-by: Joel Stanley <joel@jms.id.au>
[nc: Use 'ifeq ($(cc-name),clang)' instead of 'ifdef CONFIG_CC_IS_CLANG'
because that config does not exist in 4.14; the Kconfig rewrite
that added that config happened in 4.18]
commit 0b548e33e6cb2bff240fdaf1783783be15c29080 upstream.
Fengguang reported soft lockups while running the rbtree and interval
tree test modules. The logic for these tests all occur in init phase,
and we currently are pounding with the default values for number of
nodes and number of iterations of each test. Reduce the latter by two
orders of magnitude. This does not influence the value of the tests in
that one thousand times by default is enough to get the picture.
Link: http://lkml.kernel.org/r/20171109161715.xai2dtwqw2frhkcm@linux-n805
Signed-off-by: Davidlohr Bueso <dbueso@suse.de>
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
[ Upstream commit 8de456cf87ba863e028c4dd01bae44255ce3d835 ]
CONFIG_DEBUG_OBJECTS_RCU_HEAD does not play well with kmemleak due to
recursive calls.
fill_pool
kmemleak_ignore
make_black_object
put_object
__call_rcu (kernel/rcu/tree.c)
debug_rcu_head_queue
debug_object_activate
debug_object_init
fill_pool
kmemleak_ignore
make_black_object
So add SLAB_NOLEAKTRACE to kmem_cache_create() to not register newly
allocated debug objects at all.
Link: http://lkml.kernel.org/r/20181126165343.2339-1-cai@gmx.us
Signed-off-by: Qian Cai <cai@gmx.us>
Suggested-by: Catalin Marinas <catalin.marinas@arm.com>
Acked-by: Waiman Long <longman@redhat.com>
Cc: Yang Shi <yang.shi@linux.alibaba.com>
commit 7d63fb3af87aa67aa7d24466e792f9d7c57d8e79 upstream.
This removes needless use of '%p', and refactors the printk calls to
use pr_*() helpers instead.
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
[bwh: Backported to 4.14:
- Adjust filename
- Remove "swiotlb: " prefix from an additional log message]
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
[ Upstream commit 8bb0a88600f0267cfcc245d34f8c4abe8c282713 ]
In the case where eq->fw->size > PAGE_SIZE the error return rc
is being set to EINVAL however this is being overwritten to
rc = req->fw->size because the error exit path via label 'out' is
not being taken. Fix this by adding the jump to the error exit
path 'out'.
Detected by CoverityScan, CID#1453465 ("Unused value")
commit 77d2a24b6107bd9b3bf2403a65c1428a9da83dd0 upstream.
gcc 8.1.0 complains:
lib/kobject.c:128:3: warning:
'strncpy' output truncated before terminating nul copying as many
bytes from a string as its length [-Wstringop-truncation]
lib/kobject.c: In function 'kobject_get_path':
lib/kobject.c:125:13: note: length computed here
Using strncpy() is indeed less than perfect since the length of data to
be copied has already been determined with strlen(). Replace strncpy()
with memcpy() to address the warning and optimize the code a little.
commit b1286ed7158e9b62787508066283ab0b8850b518 upstream.
New versions of gcc reasonably warn about the odd pattern of
strncpy(p, q, strlen(q));
which really doesn't make sense: the strncpy() ends up being just a slow
and odd way to write memcpy() in this case.
Apparently there was a patch for this floating around earlier, but it
got lost.
Acked-again-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
commit 5618cf031fecda63847cafd1091e7b8bd626cdb1 upstream.
We free the misc device string twice on rmmod; fix this. Without this
we cannot remove the module without crashing.
Link: http://lkml.kernel.org/r/20181124050500.5257-1-mcgrof@kernel.org
Signed-off-by: Luis Chamberlain <mcgrof@kernel.org>
Cc: <stable@vger.kernel.org> [4.12+]
[ Upstream commit 313a06e636808387822af24c507cba92703568b1 ]
The lib/raid6/test fails to build the neon objects
on arm64 because the correct machine type is 'aarch64'.
Once this is correctly enabled, the neon recovery objects
need to be added to the build.
Reviewed-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Signed-off-by: Jeremy Linton <jeremy.linton@arm.com>
commit 1c23b4108d716cc848b38532063a8aca4f86add8 upstream.
gcc-8 complains about the prototype for this function:
lib/ubsan.c:432:1: error: ignoring attribute 'noreturn' in declaration of a built-in function '__ubsan_handle_builtin_unreachable' because it conflicts with attribute 'const' [-Werror=attributes]
This is actually a GCC's bug. In GCC internals
__ubsan_handle_builtin_unreachable() declared with both 'noreturn' and
'const' attributes instead of only 'noreturn':
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=84210
Workaround this by removing the noreturn attribute.
[aryabinin: add information about GCC bug in changelog]
Link: http://lkml.kernel.org/r/20181107144516.4587-1-aryabinin@virtuozzo.com
Acked-by: Olof Johansson <olof@lixom.net>
[ Upstream commit 9506a7425b094d2f1d9c877ed5a78f416669269b ]
It was found that when debug_locks was turned off because of a problem
found by the lockdep code, the system performance could drop quite
significantly when the lock_stat code was also configured into the
kernel. For instance, parallel kernel build time on a 4-socket x86-64
server nearly doubled.
Further analysis into the cause of the slowdown traced back to the
frequent call to debug_locks_off() from the __lock_acquired() function
probably due to some inconsistent lockdep states with debug_locks
off. The debug_locks_off() function did an unconditional atomic xchg
to write a 0 value into debug_locks which had already been set to 0.
This led to severe cacheline contention in the cacheline that held
debug_locks. As debug_locks is being referenced in quite a few different
places in the kernel, this greatly slow down the system performance.
To prevent that trashing of debug_locks cacheline, lock_acquired()
and lock_contended() now checks the state of debug_locks before
proceeding. The debug_locks_off() function is also modified to check
debug_locks before calling __debug_locks_off().
Signed-off-by: Waiman Long <longman@redhat.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/1539913518-15598-1-git-send-email-longman@redhat.com
[ Upstream commit 52fda36d63bfc8c8e8ae5eda8eb5ac6f52cd67ed ]
Function bpf_fill_maxinsns11 is designed to not be able to be JITed on
x86_64. So, it fails when CONFIG_BPF_JIT_ALWAYS_ON=y, and
commit 09584b406742 ("bpf: fix selftests/bpf test_kmod.sh failure when
CONFIG_BPF_JIT_ALWAYS_ON=y") makes sure that failure is detected on that
case.
However, it does not fail on other architectures, which have a different
JIT compiler design. So, test_bpf has started to fail to load on those.
After this fix, test_bpf loads fine on both x86_64 and ppc64el.
Fixes: 09584b406742 ("bpf: fix selftests/bpf test_kmod.sh failure when CONFIG_BPF_JIT_ALWAYS_ON=y")
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@canonical.com>
Reviewed-by: Yonghong Song <yhs@fb.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit 624fa7790f80575a4ec28fbdb2034097dc18d051 ]
In the scsi_transport_srp implementation it cannot be avoided to
iterate over a klist from atomic context when using the legacy block
layer instead of blk-mq. Hence this patch that makes it safe to use
klists in atomic context. This patch avoids that lockdep reports the
following:
WARNING: SOFTIRQ-safe -> SOFTIRQ-unsafe lock order detected
Possible interrupt unsafe locking scenario:
CPU0 CPU1
lock(&(&k->k_lock)->rlock);
local_irq_disable();
lock(&(&q->__queue_lock)->rlock);
<Interrupt>
stack backtrace:
Workqueue: kblockd blk_timeout_work
Call Trace:
dump_stack+0xa4/0xf5
check_usage+0x6e6/0x700
__lock_acquire+0x185d/0x1b50
lock_acquire+0xd2/0x260
_raw_spin_lock+0x32/0x50
klist_next+0x47/0x190
device_for_each_child+0x8e/0x100
srp_timed_out+0xaf/0x1d0 [scsi_transport_srp]
scsi_times_out+0xd4/0x410 [scsi_mod]
blk_rq_timed_out+0x36/0x70
blk_timeout_work+0x1b5/0x220
process_one_work+0x4fe/0xad0
worker_thread+0x63/0x5a0
kthread+0x1c1/0x1e0
ret_from_fork+0x24/0x30
See also commit c9ddf73476ff ("scsi: scsi_transport_srp: Fix shost to
rport translation").
Cc: Martin K. Petersen <martin.petersen@oracle.com>
Cc: James Bottomley <jejb@linux.vnet.ibm.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
