Merge updates from Andrew Morton:
- a few misc things
- ocfs2 updates
- most of MM
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (132 commits)
hugetlbfs: dirty pages as they are added to pagecache
mm: export add_swap_extent()
mm: split SWP_FILE into SWP_ACTIVATED and SWP_FS
tools/testing/selftests/vm/map_fixed_noreplace.c: add test for MAP_FIXED_NOREPLACE
mm: thp: relocate flush_cache_range() in migrate_misplaced_transhuge_page()
mm: thp: fix mmu_notifier in migrate_misplaced_transhuge_page()
mm: thp: fix MADV_DONTNEED vs migrate_misplaced_transhuge_page race condition
mm/kasan/quarantine.c: make quarantine_lock a raw_spinlock_t
mm/gup: cache dev_pagemap while pinning pages
Revert "x86/e820: put !E820_TYPE_RAM regions into memblock.reserved"
mm: return zero_resv_unavail optimization
mm: zero remaining unavailable struct pages
tools/testing/selftests/vm/gup_benchmark.c: add MAP_HUGETLB option
tools/testing/selftests/vm/gup_benchmark.c: add MAP_SHARED option
tools/testing/selftests/vm/gup_benchmark.c: allow user specified file
tools/testing/selftests/vm/gup_benchmark.c: fix 'write' flag usage
mm/gup_benchmark.c: add additional pinning methods
mm/gup_benchmark.c: time put_page()
mm: don't raise MEMCG_OOM event due to failed high-order allocation
mm/page-writeback.c: fix range_cyclic writeback vs writepages deadlock
Arch code may have asm implementation of string/memory API functions
instead of using generic one from lib/string.c. KASAN don't see memory
accesses in asm code, thus can miss many bugs.
E.g. on ARM64 KASAN don't see bugs in memchr(), memcmp(), str[r]chr(),
str[n]cmp(), str[n]len(). Add tests for these functions to be sure that
we notice the problem on other architectures.
Link: http://lkml.kernel.org/r/20180920135631.23833-3-aryabinin@virtuozzo.com
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Kyeongdon Kim <kyeongdon.kim@lge.com>
Cc: Mark Rutland <mark.rutland@arm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull Devicetree updates from Rob Herring:
"A bit bigger than normal as I've been busy this cycle.
There's a few things with dependencies and a few things subsystem
maintainers didn't pick up, so I'm taking them thru my tree.
The fixes from Johan didn't get into linux-next, but they've been
waiting for some time now and they are what's left of what subsystem
maintainers didn't pick up.
Summary:
- Sync dtc with upstream version v1.4.7-14-gc86da84d30e4
- Work to get rid of direct accesses to struct device_node name and
type pointers in preparation for removing them. New helpers for
parsing DT cpu nodes and conversions to use the helpers. printk
conversions to %pOFn for printing DT node names. Most went thru
subystem trees, so this is the remainder.
- Fixes to DT child node lookups to actually be restricted to child
nodes instead of treewide.
- Refactoring of dtb targets out of arch code. This makes the support
more uniform and enables building all dtbs on c6x, microblaze, and
powerpc.
- Various DT binding updates for Renesas r8a7744 SoC
- Vendor prefixes for Facebook, OLPC
- Restructuring of some ARM binding docs moving some peripheral
bindings out of board/SoC binding files
- New "secure-chosen" binding for secure world settings on ARM
- Dual licensing of 2 DT IRQ binding headers"
* tag 'devicetree-for-4.20' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (78 commits)
ARM: dt: relicense two DT binding IRQ headers
power: supply: twl4030-charger: fix OF sibling-node lookup
NFC: nfcmrvl_uart: fix OF child-node lookup
net: stmmac: dwmac-sun8i: fix OF child-node lookup
net: bcmgenet: fix OF child-node lookup
drm/msm: fix OF child-node lookup
drm/mediatek: fix OF sibling-node lookup
of: Add missing exports of node name compare functions
dt-bindings: Add OLPC vendor prefix
dt-bindings: misc: bk4: Add device tree binding for Liebherr's BK4 SPI bus
dt-bindings: thermal: samsung: Add SPDX license identifier
dt-bindings: clock: samsung: Add SPDX license identifiers
dt-bindings: timer: ostm: Add R7S9210 support
dt-bindings: phy: rcar-gen2: Add r8a7744 support
dt-bindings: can: rcar_can: Add r8a7744 support
dt-bindings: timer: renesas, cmt: Document r8a7744 CMT support
dt-bindings: watchdog: renesas-wdt: Document r8a7744 support
dt-bindings: thermal: rcar: Add device tree support for r8a7744
Documentation: dt: Add binding for /secure-chosen/stdout-path
dt-bindings: arm: zte: Move sysctrl bindings to their own doc
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver updates from Greg KH:
"Here is the big set of char/misc patches for 4.20-rc1.
Loads of things here, we have new code in all of these driver
subsystems:
- fpga
- stm
- extcon
- nvmem
- eeprom
- hyper-v
- gsmi
- coresight
- thunderbolt
- vmw_balloon
- goldfish
- soundwire
along with lots of fixes and minor changes to other small drivers.
All of these have been in linux-next for a while with no reported
issues"
* tag 'char-misc-4.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (245 commits)
Documentation/security-bugs: Clarify treatment of embargoed information
lib: Fix ia64 bootloader linkage
MAINTAINERS: Clarify UIO vs UIOVEC maintainer
docs/uio: fix a grammar nitpick
docs: fpga: document programming fpgas using regions
fpga: add devm_fpga_region_create
fpga: bridge: add devm_fpga_bridge_create
fpga: mgr: add devm_fpga_mgr_create
hv_balloon: Replace spin_is_locked() with lockdep
sgi-xp: Replace spin_is_locked() with lockdep
eeprom: New ee1004 driver for DDR4 memory
eeprom: at25: remove unneeded 'at25_remove'
w1: IAD Register is yet readable trough iad sys file. Fix snprintf (%u for unsigned, count for max size).
misc: mic: scif: remove set but not used variables 'src_dma_addr, dst_dma_addr'
misc: mic: fix a DMA pool free failure
platform: goldfish: pipe: Add a blank line to separate varibles and code
platform: goldfish: pipe: Remove redundant casting
platform: goldfish: pipe: Call misc_deregister if init fails
platform: goldfish: pipe: Move the file-scope goldfish_pipe_dev variable into the driver state
platform: goldfish: pipe: Move the file-scope goldfish_pipe_miscdev variable into the driver state
git://git.kernel.org/pub/scm/linux/kernel/git/palmer/riscv-linux
Pull RISC-V updates from Palmer Dabbelt:
"This patch set contains a lot (at least, for me) of improvements to
the RISC-V kernel port:
- The removal of some cacheinfo values that were bogus.
- On systems with F but without D the kernel will not show the F
extension to userspace, as it isn't actually supported.
- Support for futexes.
- Removal of some unused code.
- Cleanup of some menuconfig entries.
- Support for systems without a floating-point unit, and for building
kernels that will never use the floating-point unit.
- More fixes to the RV32I port, which regressed again. It's really
time to get this into a regression test somewhere so I stop
breaking it. Thanks to Zong for resurrecting it again!
- Various fixes that resulted from a year old review of our original
patch set that I finally got around to.
- Various improvements to SMP support, largely based around having
switched to logical hart numbering, as well as some interrupt
improvements. This one is in the same patch set as above, thanks to
Atish for sheparding everything though as my patch set was a bit of
a mess.
I'm pretty sure this is our largest patch set since the original
kernel contribution, and it's certainly the one with the most
contributors. While I don't have anything else I know I'm going to
submit for the merge window, I would be somewhat surprised if I didn't
screw anything up.
Thanks for the help, everyone!"
* tag 'riscv-for-linus-4.20-mw0' of git://git.kernel.org/pub/scm/linux/kernel/git/palmer/riscv-linux: (31 commits)
RISC-V: Cosmetic menuconfig changes
riscv: move GCC version check for ARCH_SUPPORTS_INT128 to Kconfig
RISC-V: remove the unused return_to_handler export
RISC-V: Add futex support.
RISC-V: Add FP register ptrace support for gdb.
RISC-V: Mask out the F extension on systems without D
RISC-V: Don't set cacheinfo.{physical_line_partition,attributes}
RISC-V: Show IPI stats
RISC-V: Show CPU ID and Hart ID separately in /proc/cpuinfo
RISC-V: Use Linux logical CPU number instead of hartid
RISC-V: Add logical CPU indexing for RISC-V
RISC-V: Use WRITE_ONCE instead of direct access
RISC-V: Use mmgrab()
RISC-V: Rename im_okay_therefore_i_am to found_boot_cpu
RISC-V: Rename riscv_of_processor_hart to riscv_of_processor_hartid
RISC-V: Provide a cleaner raw_smp_processor_id()
RISC-V: Disable preemption before enabling interrupts
RISC-V: Comment on the TLB flush in smp_callin()
RISC-V: Filter ISA and MMU values in cpuinfo
git://git.kernel.org/pub/scm/linux/kernel/git/pmladek/printk
Pull printk updates from Petr Mladek:
- Fix two more locations where printf formatting leaked pointers
- Better log_buf_len parameter handling
- Add prefix to messages from printk code
- Do not miss messages on other consoles when the log is replayed on a
new one
- Reduce race between console registration and panic() when the log
might get replayed on all consoles
- Some cont buffer code clean up
- Call console only when there is something to do (log vs cont buffer)
* tag 'printk-for-4.20' of git://git.kernel.org/pub/scm/linux/kernel/git/pmladek/printk:
lib/vsprintf: Hash printed address for netdev bits fallback
lib/vsprintf: Hash legacy clock addresses
lib/vsprintf: Prepare for more general use of ptr_to_id()
lib/vsprintf: Make ptr argument conts in ptr_to_id()
printk: fix integer overflow in setup_log_buf()
printk: do not preliminary split up cont buffer
printk: lock/unlock console only for new logbuf entries
printk: keep kernel cont support always enabled
printk: Give error on attempt to set log buffer length to over 2G
printk: Add KBUILD_MODNAME and remove a redundant print prefix
printk: Correct wrong casting
printk: Fix panic caused by passing log_buf_len to command line
printk: CON_PRINTBUFFER console registration is a bit racy
printk: Do not miss new messages when replaying the log
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6
Pull crypto updates from Herbert Xu:
"API:
- Remove VLA usage
- Add cryptostat user-space interface
- Add notifier for new crypto algorithms
Algorithms:
- Add OFB mode
- Remove speck
Drivers:
- Remove x86/sha*-mb as they are buggy
- Remove pcbc(aes) from x86/aesni
- Improve performance of arm/ghash-ce by up to 85%
- Implement CTS-CBC in arm64/aes-blk, faster by up to 50%
- Remove PMULL based arm64/crc32 driver
- Use PMULL in arm64/crct10dif
- Add aes-ctr support in s5p-sss
- Add caam/qi2 driver
Others:
- Pick better transform if one becomes available in crc-t10dif"
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (124 commits)
crypto: chelsio - Update ntx queue received from cxgb4
crypto: ccree - avoid implicit enum conversion
crypto: caam - add SPDX license identifier to all files
crypto: caam/qi - simplify CGR allocation, freeing
crypto: mxs-dcp - make symbols 'sha1_null_hash' and 'sha256_null_hash' static
crypto: arm64/aes-blk - ensure XTS mask is always loaded
crypto: testmgr - fix sizeof() on COMP_BUF_SIZE
crypto: chtls - remove set but not used variable 'csk'
crypto: axis - fix platform_no_drv_owner.cocci warnings
crypto: x86/aes-ni - fix build error following fpu template removal
crypto: arm64/aes - fix handling sub-block CTS-CBC inputs
crypto: caam/qi2 - avoid double export
crypto: mxs-dcp - Fix AES issues
crypto: mxs-dcp - Fix SHA null hashes and output length
crypto: mxs-dcp - Implement sha import/export
crypto: aegis/generic - fix for big endian systems
crypto: morus/generic - fix for big endian systems
crypto: lrw - fix rebase error after out of bounds fix
crypto: cavium/nitrox - use pci_alloc_irq_vectors() while enabling MSI-X.
crypto: cavium/nitrox - NITROX command queue changes.
Pull documentation updates from Jonathan Corbet:
"This is a fairly typical cycle for documentation. There's some welcome
readability improvements for the formatted output, some LICENSES
updates including the addition of the ISC license, the removal of the
unloved and unmaintained 00-INDEX files, the deprecated APIs document
from Kees, more MM docs from Mike Rapoport, and the usual pile of typo
fixes and corrections"
* tag 'docs-4.20' of git://git.lwn.net/linux: (41 commits)
docs: Fix typos in histogram.rst
docs: Introduce deprecated APIs list
kernel-doc: fix declaration type determination
doc: fix a typo in adding-syscalls.rst
docs/admin-guide: memory-hotplug: remove table of contents
doc: printk-formats: Remove bogus kobject references for device nodes
Documentation: preempt-locking: Use better example
dm flakey: Document "error_writes" feature
docs/completion.txt: Fix a couple of punctuation nits
LICENSES: Add ISC license text
LICENSES: Add note to CDDL-1.0 license that it should not be used
docs/core-api: memory-hotplug: add some details about locking internals
docs/core-api: rename memory-hotplug-notifier to memory-hotplug
docs: improve readability for people with poorer eyesight
yama: clarify ptrace_scope=2 in Yama documentation
docs/vm: split memory hotplug notifier description to Documentation/core-api
docs: move memory hotplug description into admin-guide/mm
doc: Fix acronym "FEKEK" in ecryptfs
docs: fix some broken documentation references
iommu: Fix passthrough option documentation
Pull networking updates from David Miller:
1) Add VF IPSEC offload support in ixgbe, from Shannon Nelson.
2) Add zero-copy AF_XDP support to i40e, from Björn Töpel.
3) All in-tree drivers are converted to {g,s}et_link_ksettings() so we
can get rid of the {g,s}et_settings ethtool callbacks, from Michal
Kubecek.
4) Add software timestamping to veth driver, from Michael Walle.
5) More work to make packet classifiers and actions lockless, from Vlad
Buslov.
6) Support sticky FDB entries in bridge, from Nikolay Aleksandrov.
7) Add ipv6 version of IP_MULTICAST_ALL sockopt, from Andre Naujoks.
8) Support batching of XDP buffers in vhost_net, from Jason Wang.
9) Add flow dissector BPF hook, from Petar Penkov.
10) i40e vf --> generic iavf conversion, from Jesse Brandeburg.
11) Add NLA_REJECT netlink attribute policy type, to signal when users
provide attributes in situations which don't make sense. From
Johannes Berg.
12) Switch TCP and fair-queue scheduler over to earliest departure time
model. From Eric Dumazet.
13) Improve guest receive performance by doing rx busy polling in tx
path of vhost networking driver, from Tonghao Zhang.
14) Add per-cgroup local storage to bpf
15) Add reference tracking to BPF, from Joe Stringer. The verifier can
now make sure that references taken to objects are properly released
by the program.
16) Support in-place encryption in TLS, from Vakul Garg.
17) Add new taprio packet scheduler, from Vinicius Costa Gomes.
18) Lots of selftests additions, too numerous to mention one by one here
but all of which are very much appreciated.
19) Support offloading of eBPF programs containing BPF to BPF calls in
nfp driver, frm Quentin Monnet.
20) Move dpaa2_ptp driver out of staging, from Yangbo Lu.
21) Lots of u32 classifier cleanups and simplifications, from Al Viro.
22) Add new strict versions of netlink message parsers, and enable them
for some situations. From David Ahern.
23) Evict neighbour entries on carrier down, also from David Ahern.
24) Support BPF sk_msg verdict programs with kTLS, from Daniel Borkmann
and John Fastabend.
25) Add support for filtering route dumps, from David Ahern.
26) New igc Intel driver for 2.5G parts, from Sasha Neftin et al.
27) Allow vxlan enslavement to bridges in mlxsw driver, from Ido
Schimmel.
28) Add queue and stack map types to eBPF, from Mauricio Vasquez B.
29) Add back byte-queue-limit support to r8169, with all the bug fixes
in other areas of the driver it works now! From Florian Westphal and
Heiner Kallweit.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (2147 commits)
tcp: add tcp_reset_xmit_timer() helper
qed: Fix static checker warning
Revert "be2net: remove desc field from be_eq_obj"
Revert "net: simplify sock_poll_wait"
net: socionext: Reset tx queue in ndo_stop
net: socionext: Add dummy PHY register read in phy_write()
net: socionext: Stop PHY before resetting netsec
net: stmmac: Set OWN bit for jumbo frames
arm64: dts: stratix10: Support Ethernet Jumbo frame
tls: Add maintainers
net: ethernet: ti: cpsw: unsync mcast entries while switch promisc mode
octeontx2-af: Support for NIXLF's UCAST/PROMISC/ALLMULTI modes
octeontx2-af: Support for setting MAC address
octeontx2-af: Support for changing RSS algorithm
octeontx2-af: NIX Rx flowkey configuration for RSS
octeontx2-af: Install ucast and bcast pkt forwarding rules
octeontx2-af: Add LMAC channel info to NIXLF_ALLOC response
octeontx2-af: NPC MCAM and LDATA extract minimal configuration
octeontx2-af: Enable packet length and csum validation
octeontx2-af: Support for VTAG strip and capture
Add a new iterator, ITER_DISCARD, that can only be used in READ mode and
just discards any data copied to it.
This is useful in a network filesystem for discarding any unwanted data
sent by a server.
In the iov_iter struct, separate the iterator type from the iterator
direction and use accessor functions to access them in most places.
Convert a bunch of places to use switch-statements to access them rather
then chains of bitwise-AND statements. This makes it easier to add further
iterator types. Also, this can be more efficient as to implement a switch
of small contiguous integers, the compiler can use ~50% fewer compare
instructions than it has to use bitwise-and instructions.
Further, cease passing the iterator type into the iterator setup function.
The iterator function can set that itself. Only the direction is required.
Use accessor functions to access an iterator's type and direction. This
allows for the possibility of using some other method of determining the
type of iterator than if-chains with bitwise-AND conditions.
Pull ARM updates from Russell King:
"The main item in this pull request are the Spectre variant 1.1 fixes
from Julien Thierry.
A few other patches to improve various areas, and removal of some
obsolete mcount bits and a redundant kbuild conditional"
* 'for-linus' of git://git.armlinux.org.uk/~rmk/linux-arm:
ARM: 8802/1: Call syscall_trace_exit even when system call skipped
ARM: 8797/1: spectre-v1.1: harden __copy_to_user
ARM: 8796/1: spectre-v1,v1.1: provide helpers for address sanitization
ARM: 8795/1: spectre-v1.1: use put_user() for __put_user()
ARM: 8794/1: uaccess: Prevent speculative use of the current addr_limit
ARM: 8793/1: signal: replace __put_user_error with __put_user
ARM: 8792/1: oabi-compat: copy oabi events using __copy_to_user()
ARM: 8791/1: vfp: use __copy_to_user() when saving VFP state
ARM: 8790/1: signal: always use __copy_to_user to save iwmmxt context
ARM: 8789/1: signal: copy registers using __copy_to_user()
ARM: 8801/1: makefile: use ARMv3M mode for RiscPC
ARM: 8800/1: use choice for kernel unwinders
ARM: 8798/1: remove unnecessary KBUILD_SRC ifeq conditional
ARM: 8788/1: ftrace: remove old mcount support
ARM: 8786/1: Debug kernel copy by printing
Pull locking and misc x86 updates from Ingo Molnar:
"Lots of changes in this cycle - in part because locking/core attracted
a number of related x86 low level work which was easier to handle in a
single tree:
- Linux Kernel Memory Consistency Model updates (Alan Stern, Paul E.
McKenney, Andrea Parri)
- lockdep scalability improvements and micro-optimizations (Waiman
Long)
- rwsem improvements (Waiman Long)
- spinlock micro-optimization (Matthew Wilcox)
- qspinlocks: Provide a liveness guarantee (more fairness) on x86.
(Peter Zijlstra)
- Add support for relative references in jump tables on arm64, x86
and s390 to optimize jump labels (Ard Biesheuvel, Heiko Carstens)
- Be a lot less permissive on weird (kernel address) uaccess faults
on x86: BUG() when uaccess helpers fault on kernel addresses (Jann
Horn)
- macrofy x86 asm statements to un-confuse the GCC inliner. (Nadav
Amit)
- ... and a handful of other smaller changes as well"
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (57 commits)
locking/lockdep: Make global debug_locks* variables read-mostly
locking/lockdep: Fix debug_locks off performance problem
locking/pvqspinlock: Extend node size when pvqspinlock is configured
locking/qspinlock_stat: Count instances of nested lock slowpaths
locking/qspinlock, x86: Provide liveness guarantee
x86/asm: 'Simplify' GEN_*_RMWcc() macros
locking/qspinlock: Rework some comments
locking/qspinlock: Re-order code
locking/lockdep: Remove duplicated 'lock_class_ops' percpu array
x86/defconfig: Enable CONFIG_USB_XHCI_HCD=y
futex: Replace spin_is_locked() with lockdep
locking/lockdep: Make class->ops a percpu counter and move it under CONFIG_DEBUG_LOCKDEP=y
x86/jump-labels: Macrofy inline assembly code to work around GCC inlining bugs
x86/cpufeature: Macrofy inline assembly code to work around GCC inlining bugs
x86/extable: Macrofy inline assembly code to work around GCC inlining bugs
x86/paravirt: Work around GCC inlining bugs when compiling paravirt ops
x86/bug: Macrofy the BUG table section handling, to work around GCC inlining bugs
x86/alternatives: Macrofy lock prefixes to work around GCC inlining bugs
x86/refcount: Work around GCC inlining bug
x86/objtool: Use asm macros to work around GCC inlining bugs
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 updates from Martin Schwidefsky:
- Improved access control for the zcrypt driver, multiple device nodes
can now be created with different access control lists
- Extend the pkey API to provide random protected keys, this is useful
for encrypted swap device with ephemeral protected keys
- Add support for virtually mapped kernel stacks
- Rework the early boot code, this moves the memory detection into the
boot code that runs prior to decompression.
- Add KASAN support
- Bug fixes and cleanups
* tag 's390-4.20-1' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (83 commits)
s390/pkey: move pckmo subfunction available checks away from module init
s390/kasan: support preemptible kernel build
s390/pkey: Load pkey kernel module automatically
s390/perf: Return error when debug_register fails
s390/sthyi: Fix machine name validity indication
s390/zcrypt: fix broken zcrypt_send_cprb in-kernel api function
s390/vmalloc: fix VMALLOC_START calculation
s390/mem_detect: add missing include
s390/dumpstack: print psw mask and address again
s390/crypto: Enhance paes cipher to accept variable length key material
s390/pkey: Introduce new API for transforming key blobs
s390/pkey: Introduce new API for random protected key verification
s390/pkey: Add sysfs attributes to emit secure key blobs
s390/pkey: Add sysfs attributes to emit protected key blobs
s390/pkey: Define protected key blob format
s390/pkey: Introduce new API for random protected key generation
s390/zcrypt: add ap_adapter_mask sysfs attribute
s390/zcrypt: provide apfs failure code on type 86 error reply
s390/zcrypt: zcrypt device driver cleanup
s390/kasan: add support for mem= kernel parameter
Add umoddi3 and udivmoddi4 support for 32-bit.
The RV32 need the umoddi3 to do modulo when the operands are long long
type, like other libraries implementation such as ucmpdi2, lshrdi3 and
so on.
I encounter the undefined reference 'umoddi3' when I use the in
house dma driver, although it is in house driver, but I think that
umoddi3 is a common function for RV32.
The udivmoddi4 and umoddi3 are copies from libgcc in gcc. There are other
functions use the udivmoddi4 in libgcc, so I separate the umoddi3 and
udivmoddi4 for flexible extension in the future.
Signed-off-by: Zong Li <zong@andestech.com>
Signed-off-by: Palmer Dabbelt <palmer@sifive.com>
Pull block layer updates from Jens Axboe:
"This is the main pull request for block changes for 4.20. This
contains:
- Series enabling runtime PM for blk-mq (Bart).
- Two pull requests from Christoph for NVMe, with items such as;
- Better AEN tracking
- Multipath improvements
- RDMA fixes
- Rework of FC for target removal
- Fixes for issues identified by static checkers
- Fabric cleanups, as prep for TCP transport
- Various cleanups and bug fixes
- Block merging cleanups (Christoph)
- Conversion of drivers to generic DMA mapping API (Christoph)
- Series fixing ref count issues with blkcg (Dennis)
- Series improving BFQ heuristics (Paolo, et al)
- Series improving heuristics for the Kyber IO scheduler (Omar)
- Removal of dangerous bio_rewind_iter() API (Ming)
- Apply single queue IPI redirection logic to blk-mq (Ming)
- Set of fixes and improvements for bcache (Coly et al)
- Series closing a hotplug race with sysfs group attributes (Hannes)
- Set of patches for lightnvm:
- pblk trace support (Hans)
- SPDX license header update (Javier)
- Tons of refactoring patches to cleanly abstract the 1.2 and 2.0
specs behind a common core interface. (Javier, Matias)
- Enable pblk to use a common interface to retrieve chunk metadata
(Matias)
- Bug fixes (Various)
- Set of fixes and updates to the blk IO latency target (Josef)
- blk-mq queue number updates fixes (Jianchao)
- Convert a bunch of drivers from the old legacy IO interface to
blk-mq. This will conclude with the removal of the legacy IO
interface itself in 4.21, with the rest of the drivers (me, Omar)
- Removal of the DAC960 driver. The SCSI tree will introduce two
replacement drivers for this (Hannes)"
* tag 'for-4.20/block-20181021' of git://git.kernel.dk/linux-block: (204 commits)
block: setup bounce bio_sets properly
blkcg: reassociate bios when make_request() is called recursively
blkcg: fix edge case for blk_get_rl() under memory pressure
nvme-fabrics: move controller options matching to fabrics
nvme-rdma: always have a valid trsvcid
mtip32xx: fully switch to the generic DMA API
rsxx: switch to the generic DMA API
umem: switch to the generic DMA API
sx8: switch to the generic DMA API
sx8: remove dead IF_64BIT_DMA_IS_POSSIBLE code
skd: switch to the generic DMA API
ubd: remove use of blk_rq_map_sg
nvme-pci: remove duplicate check
drivers/block: Remove DAC960 driver
nvme-pci: fix hot removal during error handling
nvmet-fcloop: suppress a compiler warning
nvme-core: make implicit seed truncation explicit
nvmet-fc: fix kernel-doc headers
nvme-fc: rework the request initialization code
nvme-fc: introduce struct nvme_fcp_op_w_sgl
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 updates from Catalin Marinas:
"Apart from some new arm64 features and clean-ups, this also contains
the core mmu_gather changes for tracking the levels of the page table
being cleared and a minor update to the generic
compat_sys_sigaltstack() introducing COMPAT_SIGMINSKSZ.
Summary:
- Core mmu_gather changes which allow tracking the levels of
page-table being cleared together with the arm64 low-level flushing
routines
- Support for the new ARMv8.5 PSTATE.SSBS bit which can be used to
mitigate Spectre-v4 dynamically without trapping to EL3 firmware
- Introduce COMPAT_SIGMINSTKSZ for use in compat_sys_sigaltstack
- Optimise emulation of MRS instructions to ID_* registers on ARMv8.4
- Support for Common Not Private (CnP) translations allowing threads
of the same CPU to share the TLB entries
- Accelerated crc32 routines
- Move swapper_pg_dir to the rodata section
- Trap WFI instruction executed in user space
- ARM erratum 1188874 workaround (arch_timer)
- Miscellaneous fixes and clean-ups"
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (78 commits)
arm64: KVM: Guests can skip __install_bp_hardening_cb()s HYP work
arm64: cpufeature: Trap CTR_EL0 access only where it is necessary
arm64: cpufeature: Fix handling of CTR_EL0.IDC field
arm64: cpufeature: ctr: Fix cpu capability check for late CPUs
Documentation/arm64: HugeTLB page implementation
arm64: mm: Use __pa_symbol() for set_swapper_pgd()
arm64: Add silicon-errata.txt entry for ARM erratum 1188873
Revert "arm64: uaccess: implement unsafe accessors"
arm64: mm: Drop the unused cpu parameter
MAINTAINERS: fix bad sdei paths
arm64: mm: Use #ifdef for the __PAGETABLE_P?D_FOLDED defines
arm64: Fix typo in a comment in arch/arm64/mm/kasan_init.c
arm64: xen: Use existing helper to check interrupt status
arm64: Use daifflag_restore after bp_hardening
arm64: daifflags: Use irqflags functions for daifflags
arm64: arch_timer: avoid unused function warning
arm64: Trap WFI executed in userspace
arm64: docs: Document SSBS HWCAP
arm64: docs: Fix typos in ELF hwcaps
arm64/kprobes: remove an extra semicolon in arch_prepare_kprobe
All users have now been converted to the XArray. Removing the support
reduces code size and ensures new users will use the XArray instead.
Signed-off-by: Matthew Wilcox <willy@infradead.org>
This version of xa_store_range() really only supports load and store.
Our only user only needs basic load and store functionality, so there's
no need to do the extra work to support marking and overlapping stores
correctly yet.
This version is a little less thorough in order to be a little quicker,
but tests the important edge cases. Also test adding a multiorder entry
at a non-canonical index, and erasing it.
Test this functionality inside the kernel as well as in userspace.
Also remove insert_bug() as there's no comparable thing to test
in the XArray code.
Move this test to the in-kernel test suite, and enhance it to test
several different orders.
The tag_tagged_items() function is supposed to test the page-writeback
tagging code. Since that has been converted to the XArray, there's
not much point in testing the radix tree's tagging code. This requires
using the pthread mutex embedded in the xarray instead of an external
lock, so remove the pthread mutexes which protect xarrays/radix trees.
Also remove radix_tree_iter_tag_set() as this was the last user.
The page cache was the only user of this interface and it has now
been converted to the XArray. Transform the test into a test of
xas_init_marks().
This function was only used by the page cache which is now converted
to the XArray.
radix_tree_split and radix_tree_join were never used upstream. Remove
them; if they're needed in future they will be replaced by XArray
equivalents.
The only user of this functionality was the workingset code, and it's
now been converted to the XArray. Remove __radix_tree_delete_node()
entirely as it was also only used by the workingset code.
xa_find() is a slightly easier API to use than
radix_tree_gang_lookup_slot() because it contains its own RCU locking.
This commit removes the last user of radix_tree_gang_lookup_slot()
so remove the function too.
This is a 1:1 conversion. The major part of this patch is converting
the test framework from userspace to kernel space and mirroring the
algorithm now used in find_swap_entry().
We construct an XA_STATE and use it to delete the node with
xas_store() rather than adding a special function for this unique
use case. Includes a test that simulates this usage for the
test suite.
Use the XArray APIs to add and replace pages in the page cache. This
removes two uses of the radix tree preload API and is significantly
shorter code. It also removes the last user of __radix_tree_create()
outside radix-tree.c itself, so make it static.
Use the XA_TRACK_FREE ability to track which entries have a free bit,
similarly to how it uses the radix tree's IDR_FREE tag. This eliminates
the per-cpu ida_bitmap preload, and fixes the memory consumption
regression I introduced when making the IDR able to store any pointer.
Add the optional ability to track which entries in an XArray are free
and provide xa_alloc() to replace most of the functionality of the IDR.
This function reserves a slot in the XArray for users which need
to acquire multiple locks before storing their entry in the tree and
so cannot use a plain xa_store().
This hopefully temporary function is useful for users who have not yet
been converted to multi-index entries.
This iterator iterates over each entry that is stored in the index or
indices specified by the xa_state. This is intended for use for a
conditional store of a multiindex entry, or to allow entries which are
about to be removed from the xarray to be disposed of properly.
The xas_next and xas_prev functions move the xas index by one position,
and adjust the rest of the iterator state to match it. This is more
efficient than calling xas_set() as it keeps the iterator at the leaves
of the tree instead of walking the iterator from the root each time.
This function frees all the internal memory allocated to the xarray
and reinitialises it to be empty.
The xa_extract function combines the functionality of
radix_tree_gang_lookup() and radix_tree_gang_lookup_tagged().
It extracts entries matching the specified filter into a normal array.
The xa_for_each iterator allows the user to efficiently walk a range
of the array, executing the loop body once for each entry in that
range that matches the filter. This commit also includes xa_find()
and xa_find_after() which are helper functions for xa_for_each() but
may also be useful in their own right.
In the xas family of functions, we have xas_for_each(), xas_find(),
xas_next_entry(), xas_for_each_tagged(), xas_find_tagged(),
xas_next_tagged() and xas_pause().
Like cmpxchg(), xa_cmpxchg will only store to the index if the current
entry matches the old entry. It returns the current entry, which is
usually more useful than the errno returned by radix_tree_insert().
For the users who really only want the errno, the xa_insert() wrapper
provides a more convenient calling convention.
xa_store() differs from radix_tree_insert() in that it will overwrite an
existing element in the array rather than returning an error. This is
the behaviour which most users want, and those that want more complex
behaviour generally want to use the xas family of routines anyway.
For memory allocation, xa_store() will first attempt to request memory
from the slab allocator; if memory is not immediately available, it will
drop the xa_lock and allocate memory, keeping a pointer in the xa_state.
It does not use the per-CPU cache, although those will continue to exist
until all radix tree users are converted to the xarray.
This patch also includes xa_erase() and __xa_erase() for a streamlined
way to store NULL. Since there is no need to allocate memory in order
to store a NULL in the XArray, we do not need to trouble the user with
deciding what memory allocation flags to use.
XArray marks are like the radix tree tags, only slightly more strongly
typed. They are renamed in order to distinguish them from tagged
pointers. This commit adds the basic get/set/clear operations.
The xa_load function brings with it a lot of infrastructure; xa_empty(),
xa_is_err(), and large chunks of the XArray advanced API that are used
to implement xa_load.
As the test-suite demonstrates, it is possible to use the XArray functions
on a radix tree. The radix tree functions depend on the GFP flags being
stored in the root of the tree, so it's not possible to use the radix
tree functions on an XArray.
This is a direct replacement for struct radix_tree_node. A couple of
struct members have changed name, so convert those. Use a #define so
that radix tree users continue to work without change.
Reviewed-by: Josef Bacik <jbacik@fb.com>
This is a direct replacement for struct radix_tree_root. Some of the
struct members have changed name; convert those, and use a #define so
that radix_tree users continue to work without change.
net/sched/cls_api.c has overlapping changes to a call to
nlmsg_parse(), one (from 'net') added rtm_tca_policy instead of NULL
to the 5th argument, and another (from 'net-next') added cb->extack
instead of NULL to the 6th argument.
net/ipv4/ipmr_base.c is a case of a bug fix in 'net' being done to
code which moved (to mr_table_dump)) in 'net-next'. Thanks to David
Ahern for the heads up.
Make the frequently used lockdep global variable debug_locks read-mostly.
As debug_locks_silent is sometime used together with debug_locks,
it is also made read-mostly so that they can be close together.
With false cacheline sharing, cacheline contention problem can happen
depending on what get put into the same cacheline as debug_locks.
Signed-off-by: Waiman Long <longman@redhat.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/1539913518-15598-2-git-send-email-longman@redhat.com
It was found that when debug_locks was turned off because of a problem
found by the lockdep code, the system performance could drop quite
significantly when the lock_stat code was also configured into the
kernel. For instance, parallel kernel build time on a 4-socket x86-64
server nearly doubled.
Further analysis into the cause of the slowdown traced back to the
frequent call to debug_locks_off() from the __lock_acquired() function
probably due to some inconsistent lockdep states with debug_locks
off. The debug_locks_off() function did an unconditional atomic xchg
to write a 0 value into debug_locks which had already been set to 0.
This led to severe cacheline contention in the cacheline that held
debug_locks. As debug_locks is being referenced in quite a few different
places in the kernel, this greatly slow down the system performance.
To prevent that trashing of debug_locks cacheline, lock_acquired()
and lock_contended() now checks the state of debug_locks before
proceeding. The debug_locks_off() function is also modified to check
debug_locks before calling __debug_locks_off().
Link: http://lkml.kernel.org/r/1539913518-15598-1-git-send-email-longman@redhat.com
