path: root/lib
2009-11-05Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, fs: Fix x86 procfs stack information for threads on 64-bit x86: Add reboot quirk for 3 series Mac mini x86: Fix printk message typo in mtrr cleanup code dma-debug: Fix compile warning with PAE enabled x86/amd-iommu: Un__init function required on shutdown x86/amd-iommu: Workaround for erratum 63
2009-10-29dma-debug: Fix compile warning with PAE enabledJoerg Roedel
When PAE is enabled in the kernel configuration the size of phys_addr_t differs from the size of a void pointer. The gcc prints a warning about that in dma-debug code. This patch fixes the warning by converting the output to unsigned long long instead of a pointer. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-10-27powerpc: Minor cleanup to lib/Kconfig.debugKumar Gala
We don't need an explicit PPC64 in the DEBUG_PREEMPT dependancies as all PPC platforms now support TRACE_IRQFLAGS_SUPPORT. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-10-11Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: (21 commits) [S390] dasd: fix race condition in resume code [S390] Add EX_TABLE for addressing exception in usercopy functions. [S390] 64-bit register support for 31-bit processes [S390] hibernate: Use correct place for CPU address in lowcore [S390] pm: ignore time spend in suspended state [S390] zcrypt: Improve some comments [S390] zcrypt: Fix sparse warning. [S390] perf_counter: fix vdso detection [S390] ftrace: drop nmi protection [S390] compat: fix truncate system call wrapper [S390] Provide arch specific mdelay implementation. [S390] Fix enabled udelay for short delays. [S390] cio: allow setting boxed devices offline [S390] cio: make not operational handling consistent [S390] cio: make disconnected handling consistent [S390] Fix memory leak in /proc/cio_ignore [S390] cio: channel path memory leak [S390] module: fix memory leak in s390 module loader [S390] Enable kmemleak on s390. [S390] 3270 console build fix ...
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-10-06[S390] Enable kmemleak on s390.Heiko Carstens
Also increase the maximum possible kmemleak early log entries since 2000 are not sufficient on s390. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-10-01sscanf(): fix %*s%nAndy Spencer
When using %*s, sscanf should honor conversion specifiers immediately following the %*s. For example, the following code should find the position of the end of the string "hello". int end; char buf[] = "hello world"; sscanf(buf, "%*s%n", &end); printf("%d\n", end); Ideally, sscanf would advance the fmt and str pointers the same as it would without the *, but the code for that is rather complicated and is not included in the patch. Signed-off-by: Andy Spencer <andy753421@gmail.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: drivers/staging/Kconfig drivers/staging/Makefile drivers/staging/cpc-usb/TODO drivers/staging/cpc-usb/cpc-usb_drv.c drivers/staging/cpc-usb/cpc.h drivers/staging/cpc-usb/cpc_int.h drivers/staging/cpc-usb/cpcusb.h
2009-09-24lzma/gzip: fix potential oops when input data is truncatedPhillip Lougher
If the lzma/gzip decompressors are called with insufficient input data (len > 0 & fill = NULL), they will attempt to call the fill function to obtain more data, leading to a kernel oops. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (30 commits) Use macros for .data.page_aligned section. Use macros for .bss.page_aligned section. Use new __init_task_data macro in arch init_task.c files. kbuild: Don't define ALIGN and ENTRY when preprocessing linker scripts. arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0 kbuild: add static to prototypes kbuild: fail build if recordmcount.pl fails kbuild: set -fconserve-stack option for gcc 4.5 kbuild: echo the record_mcount command gconfig: disable "typeahead find" search in treeviews kbuild: fix cc1 options check to ensure we do not use -fPIC when compiling checkincludes.pl: add option to remove duplicates in place markup_oops: use modinfo to avoid confusion with underscored module names checkincludes.pl: provide usage helper checkincludes.pl: close file as soon as we're done with it ctags: usability fix kernel hacking: move STRIP_ASM_SYMS from General gitignore usr/initramfs_data.cpio.bz2 and usr/initramfs_data.cpio.lzma kbuild: Check if linker supports the -X option kbuild: introduce ld-option ... Fix trivial conflict in scripts/basic/fixdep.c
2009-09-22lib/vsprintf.c: Avoid possible unaligned accesses in %pI6cJoe Perches
Jens Rosenboom noticed that a possibly unaligned const char* is cast to a const struct in6_addr *. Avoid this at the cost of a struct in6_addr copy on the stack. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vegard/kmemcheck * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/vegard/kmemcheck: kmemcheck: add missing braces to do-while in kmemcheck_annotate_bitfield kmemcheck: update documentation kmemcheck: depend on HAVE_ARCH_KMEMCHECK kmemcheck: remove useless check kmemcheck: remove duplicated #include
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) trivial: fix typo in aic7xxx comment trivial: fix comment typo in drivers/ata/pata_hpt37x.c trivial: typo in kernel-parameters.txt trivial: fix typo in tracing documentation trivial: add __init/__exit macros in drivers/gpio/bt8xxgpio.c trivial: add __init macro/ fix of __exit macro location in ipmi_poweroff.c trivial: remove unnecessary semicolons trivial: Fix duplicated word "options" in comment trivial: kbuild: remove extraneous blank line after declaration of usage() trivial: improve help text for mm debug config options trivial: doc: hpfall: accept disk device to unload as argument trivial: doc: hpfall: reduce risk that hpfall can do harm trivial: SubmittingPatches: Fix reference to renumbered step trivial: fix typos "man[ae]g?ment" -> "management" trivial: media/video/cx88: add __init/__exit macros to cx88 drivers trivial: fix typo in CONFIG_DEBUG_FS in gcov doc trivial: fix missing printk space in amd_k7_smp_check trivial: fix typo s/ketymap/keymap/ in comment trivial: fix typo "to to" in multiple files trivial: fix typos in comments s/DGBU/DBGU/ ...
2009-09-22flex_array: add missing kerneldoc annotationsDavid Rientjes
Add kerneldoc annotations for function formals of type struct flex_array and gfp_t which are currently lacking. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22flex_array: introduce DEFINE_FLEX_ARRAYDavid Rientjes
FLEX_ARRAY_INIT(element_size, total_nr_elements) cannot determine if either parameter is valid, so flex arrays which are statically allocated with this interface can easily become corrupted or reference beyond its allocated memory. This removes FLEX_ARRAY_INIT() as a struct flex_array initializer since no initializer may perform the required checking. Instead, the array is now defined with a new interface: DEFINE_FLEX_ARRAY(name, element_size, total_nr_elements) This may be prefixed with `static' for file scope. This interface includes compile-time checking of the parameters to ensure they are valid. Since the validity of both element_size and total_nr_elements depend on FLEX_ARRAY_BASE_SIZE and FLEX_ARRAY_PART_SIZE, the kernel build will fail if either of these predefined values changes such that the array parameters are no longer valid. Since BUILD_BUG_ON() requires compile time constants, several of the static inline functions that were once local to lib/flex_array.c had to be moved to include/linux/flex_array.h. Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22flex_array: add flex_array_shrink functionDavid Rientjes
Add a new function to the flex_array API: int flex_array_shrink(struct flex_array *fa) This function will free all unused second-level pages. Since elements are now poisoned if they are not allocated with __GFP_ZERO, it's possible to identify parts that consist solely of unused elements. flex_array_shrink() returns the number of pages freed. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22flex_array: poison free elementsDavid Rientjes
Newly initialized flex_array's and/or flex_array_part's are now poisoned with a new poison value, FLEX_ARRAY_FREE. It's value is similar to POISON_FREE used in the various slab allocators, but is different to distinguish between flex array's poisoned kmem and slab allocator poisoned kmem. This will allow us to identify flex_array_part's that only contain free elements (and free them with an addition to the flex_array API). This could also be extended in the future to identify `get' uses on elements that have not been `put'. If __GFP_ZERO is passed for a part's gfp mask, the poisoning is avoided. These elements are considered to be in-use since they have been initialized. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22flex_array: add flex_array_clear functionDavid Rientjes
Add a new function to the flex_array API: int flex_array_clear(struct flex_array *fa, unsigned int element_nr) This function will zero the element at element_nr in the flex_array. Although this is equivalent to using flex_array_put() and passing a pointer to zero'd memory, flex_array_clear() does not require such a pointer to memory that would most likely need to be allocated on the caller's stack which could be significantly large depending on element_size. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22vsprintf: use WARN_ON_ONCEMarcin Slusarz
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-21trivial: fix typo "to to" in multiple filesAnand Gadiyar
Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-20kernel hacking: move STRIP_ASM_SYMS from GeneralRandy Dunlap
Sam suggested moving STRIP_ASM_SYMS into the Kernel hacking menu from the General Setup menu. It makes more sense there. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-17vsnprintf: remove duplicate comment of vsnprintfSteven Rostedt
Remove the duplicate comment of bstr_printf that is the same as the vsnprintf. Add the 's' option to the comment for the pointer function. This is more of an internal function so the little duplication of the comment here is OK. Reported-by: Zhaolei <zhaolei@cn.fujitsu.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-09-17vsprintf: add %ps that is the same as %pS but is like %pfSteven Rostedt
On PowerPC64 function pointers do not point directly at the functions, but instead point to pointers to the functions. The output of %pF expects to point to a pointer to the function, whereas %pS will show the function itself. mcount returns the direct pointer to the function and not the pointer to the pointer. Thus %pS must be used to show this. The function tracer requires printing of the functions without offsets and uses the %pf instead. %pF produces run_local_timers+0x4/0x1f %pf produces just run_local_timers For PowerPC64, we need to use the direct pointer, and we only have %pS which will produce .run_local_timers+0x4/0x1f This patch creates a %ps that matches the %pf as %pS matches %pF. Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Zhao Lei <zhaolei@cn.fujitsu.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-09-15Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (134 commits) powerpc/nvram: Enable use Generic NVRAM driver for different size chips powerpc/iseries: Fix oops reading from /proc/iSeries/mf/*/cmdline powerpc/ps3: Workaround for flash memory I/O error powerpc/booke: Don't set DABR on 64-bit BookE, use DAC1 instead powerpc/perf_counters: Reduce stack usage of power_check_constraints powerpc: Fix bug where perf_counters breaks oprofile powerpc/85xx: Fix SMP compile error and allow NULL for smp_ops powerpc/irq: Improve nanodoc powerpc: Fix some late PowerMac G5 with PCIe ATI graphics powerpc/fsl-booke: Use HW PTE format if CONFIG_PTE_64BIT powerpc/book3e: Add missing page sizes powerpc/pseries: Fix to handle slb resize across migration powerpc/powermac: Thermal control turns system off too eagerly powerpc/pci: Merge ppc32 and ppc64 versions of phb_scan() powerpc/405ex: support cuImage via included dtb powerpc/405ex: provide necessary fixup function to support cuImage powerpc/40x: Add support for the ESTeem 195E (PPC405EP) SBC powerpc/44x: Add Eiger AMCC (AppliedMicro) PPC460SX evaluation board support. powerpc/44x: Update Arches defconfig powerpc/44x: Update Arches dts ... Fix up conflicts in drivers/char/agp/uninorth-agp.c
2009-09-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (46 commits) powerpc64: convert to dynamic percpu allocator sparc64: use embedding percpu first chunk allocator percpu: kill lpage first chunk allocator x86,percpu: use embedding for 64bit NUMA and page for 32bit NUMA percpu: update embedding first chunk allocator to handle sparse units percpu: use group information to allocate vmap areas sparsely vmalloc: implement pcpu_get_vm_areas() vmalloc: separate out insert_vmalloc_vm() percpu: add chunk->base_addr percpu: add pcpu_unit_offsets[] percpu: introduce pcpu_alloc_info and pcpu_group_info percpu: move pcpu_lpage_build_unit_map() and pcpul_lpage_dump_cfg() upward percpu: add @align to pcpu_fc_alloc_fn_t percpu: make @dyn_size mandatory for pcpu_setup_first_chunk() percpu: drop @static_size from first chunk allocators percpu: generalize first chunk allocator selection percpu: build first chunk allocators selectively percpu: rename 4k first chunk allocator to page percpu: improve boot messages percpu: fix pcpu_reclaim() locking ... Fix trivial conflict as by Tejun Heo in kernel/sched.c
2009-09-15Nicolas Pitre has a new email addressNicolas Pitre
Due to problems at cam.org, my nico@cam.org email address is no longer valid. FRom now on, nico@fluxnic.net should be used instead. Signed-off-by: Nicolas Pitre <nico@fluxnic.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1623 commits) netxen: update copyright netxen: fix tx timeout recovery netxen: fix file firmware leak netxen: improve pci memory access netxen: change firmware write size tg3: Fix return ring size breakage netxen: build fix for INET=n cdc-phonet: autoconfigure Phonet address Phonet: back-end for autoconfigured addresses Phonet: fix netlink address dump error handling ipv6: Add IFA_F_DADFAILED flag net: Add DEVTYPE support for Ethernet based devices mv643xx_eth.c: remove unused txq_set_wrr() ucc_geth: Fix hangs after switching from full to half duplex ucc_geth: Rearrange some code to avoid forward declarations phy/marvell: Make non-aneg speed/duplex forcing work for 88E1111 PHYs drivers/net/phy: introduce missing kfree drivers/net/wan: introduce missing kfree net: force bridge module(s) to be GPL Subject: [PATCH] appletalk: Fix skb leak when ipddp interface is not loaded ... Fixed up trivial conflicts: - arch/x86/include/asm/socket.h converted to <asm-generic/socket.h> in the x86 tree. The generic header has the same new #define's, so that works out fine. - drivers/net/tun.c fix conflict between 89f56d1e9 ("tun: reuse struct sock fields") that switched over to using 'tun->socket.sk' instead of the redundantly available (and thus removed) 'tun->sk', and 2b980dbd ("lsm: Add hooks to the TUN driver") which added a new 'tun->sk' use. Noted in 'next' by Stephen Rothwell.
2009-09-11Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (28 commits) rcu: Move end of special early-boot RCU operation earlier rcu: Changes from reviews: avoid casts, fix/add warnings, improve comments rcu: Create rcutree plugins to handle hotplug CPU for multi-level trees rcu: Remove lockdep annotations from RCU's _notrace() API members rcu: Add #ifdef to suppress __rcu_offline_cpu() warning in !HOTPLUG_CPU builds rcu: Add CPU-offline processing for single-node configurations rcu: Add "notrace" to RCU function headers used by ftrace rcu: Remove CONFIG_PREEMPT_RCU rcu: Merge preemptable-RCU functionality into hierarchical RCU rcu: Simplify rcu_pending()/rcu_check_callbacks() API rcu: Use debugfs_remove_recursive() simplify code. rcu: Merge per-RCU-flavor initialization into pre-existing macro rcu: Fix online/offline indication for rcudata.csv trace file rcu: Consolidate sparse and lockdep declarations in include/linux/rcupdate.h rcu: Renamings to increase RCU clarity rcu: Move private definitions from include/linux/rcutree.h to kernel/rcutree.h rcu: Expunge lingering references to CONFIG_CLASSIC_RCU, optimize on !SMP rcu: Delay rcu_barrier() wait until beginning of next CPU-hotunplug operation. rcu: Fix typo in rcu_irq_exit() comment header rcu: Make rcupreempt_trace.c look at offline CPUs ...
2009-09-11Merge branch 'core-iommu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-iommu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (59 commits) x86/gart: Do not select AGP for GART_IOMMU x86/amd-iommu: Initialize passthrough mode when requested x86/amd-iommu: Don't detach device from pt domain on driver unbind x86/amd-iommu: Make sure a device is assigned in passthrough mode x86/amd-iommu: Align locking between attach_device and detach_device x86/amd-iommu: Fix device table write order x86/amd-iommu: Add passthrough mode initialization functions x86/amd-iommu: Add core functions for pd allocation/freeing x86/dma: Mark iommu_pass_through as __read_mostly x86/amd-iommu: Change iommu_map_page to support multiple page sizes x86/amd-iommu: Support higher level PTEs in iommu_page_unmap x86/amd-iommu: Remove old page table handling macros x86/amd-iommu: Use 2-level page tables for dma_ops domains x86/amd-iommu: Remove bus_addr check in iommu_map_page x86/amd-iommu: Remove last usages of IOMMU_PTE_L0_INDEX x86/amd-iommu: Change alloc_pte to support 64 bit address space x86/amd-iommu: Introduce increase_address_space function x86/amd-iommu: Flush domains if address space size was increased x86/amd-iommu: Introduce set_dte_entry function x86/amd-iommu: Add a gneric version of amd_iommu_flush_all_devices ...
2009-09-11Merge branch 'next' into for-linusJames Morris
2009-09-04Merge branch 'amd-iommu/2.6.32' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/joro/linux-2.6-iommu into core/iommu
2009-09-04Merge branch 'linus' into core/rcuIngo Molnar
Merge reason: Avoid fuzz in init/main.c and update from rc6 to rc8. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-02CRED: Add some configurable debugging [try #6]David Howells
Add a config option (CONFIG_DEBUG_CREDENTIALS) to turn on some debug checking for credential management. The additional code keeps track of the number of pointers from task_structs to any given cred struct, and checks to see that this number never exceeds the usage count of the cred struct (which includes all references, not just those from task_structs). Furthermore, if SELinux is enabled, the code also checks that the security pointer in the cred struct is never seen to be invalid. This attempts to catch the bug whereby inode_has_perm() faults in an nfsd kernel thread on seeing cred->security be a NULL pointer (it appears that the credential struct has been previously released): http://www.kerneloops.org/oops.php?number=252883 Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-08-29lib/vsprintf.c: Add "%pI6c" - print pointer as compressed ipv6 addressJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Tested-by: Jens Rosenboom <jens@mcbone.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-28Merge commit 'tip/iommu-for-powerpc' into nextBenjamin Herrenschmidt
2009-08-27lmb: Remove __init from lmb_end_of_DRAM()Benjamin Herrenschmidt
We call lmb_end_of_DRAM() to test whether a DMA mask is ok on a machine without IOMMU, but this function is marked as __init. I don't think there's a clean way to get the top of RAM max_pfn doesn't appear to include highmem or I missed (or we have a bug :-) so for now, let's just avoid having a broken 2.6.31 by making this function non-__init and we can revisit later. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-27Merge commit 'origin/master' into nextBenjamin Herrenschmidt
2009-08-26flex_array: convert element_nr formals to unsignedDavid Rientjes
It's problematic to allow signed element_nr's or total's to be passed as part of the flex array API. flex_array_alloc() allows total_nr_elements to be set to a negative quantity, which is obviously erroneous. flex_array_get() and flex_array_put() allows negative array indices in dereferencing an array part, which could address memory mapped before struct flex_array. The fix is to convert all existing element_nr formals to be qualified as unsigned. Existing checks to compare it to total_nr_elements or the max array size based on element_size need not be changed. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-26flex_array: fix flex_array_free_parts commentDavid Rientjes
flex_array_free_parts() does not take `src' or `element_nr' formals, so remove their respective comments. Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-26flex_array: fix get function for elements in base starting at non-zeroDavid Rientjes
If all array elements fit into the base structure and data is copied using flex_array_put() starting at a non-zero index, flex_array_get() will fail to return the data. This fixes the bug by only checking for NULL parts when all elements do not fit in the base structure when flex_array_get() is used. Otherwise, fa_element_to_part_nr() will always be 0 since there are no parts structures needed and such element may never have been put. Thus, it will remain NULL due to the kzalloc() of the base. Additionally, flex_array_put() now only checks for a NULL part when all elements do not fit in the base structure. This is otherwise unnecessary since the base structure is guaranteed to exist (or we would have already hit a NULL pointer). Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-25Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: dma-debug: Fix check_unmap null pointer dereference
2009-08-23rcu: Remove CONFIG_PREEMPT_RCUPaul E. McKenney
Now that CONFIG_TREE_PREEMPT_RCU is in place, there is no further need for CONFIG_PREEMPT_RCU. Remove it, along with whatever subtle bugs it may (or may not) contain. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org LKML-Reference: <125097461396-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-23rcu: Merge preemptable-RCU functionality into hierarchical RCUPaul E. McKenney
Create a kernel/rcutree_plugin.h file that contains definitions for preemptable RCU (or, under the #else branch of the #ifdef, empty definitions for the classic non-preemptable semantics). These definitions fit into plugins defined in kernel/rcutree.c for this purpose. This variant of preemptable RCU uses a new algorithm whose read-side expense is roughly that of classic hierarchical RCU under CONFIG_PREEMPT. This new algorithm's update-side expense is similar to that of classic hierarchical RCU, and, in absence of read-side preemption or blocking, is exactly that of classic hierarchical RCU. Perhaps more important, this new algorithm has a much simpler implementation, saving well over 1,000 lines of code compared to mainline's implementation of preemptable RCU, which will hopefully be retired in favor of this new algorithm. The simplifications are obtained by maintaining per-task nesting state for running tasks, and using a simple lock-protected algorithm to handle accounting when tasks block within RCU read-side critical sections, making use of lessons learned while creating numerous user-level RCU implementations over the past 18 months. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org LKML-Reference: <12509746134003-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-21Make bitmask 'and' operators return a result codeLinus Torvalds
When 'and'ing two bitmasks (where 'andnot' is a variation on it), some cases want to know whether the result is the empty set or not. In particular, the TLB IPI sending code wants to do cpumask operations and determine if there are any CPU's left in the final set. So this just makes the bitmask (and cpumask) functions return a boolean for whether the result has any bits set. Cc: stable@kernel.org (2.6.30, needed by TLB shootdown fix) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-21lib/swiotlb.c: Fix strange panic message selection logic when swiotlb fills upCasey Dahlin
swiotlb_full() in lib/swiotlb.c throws one of two panic messages based on whether the direction of transfer is from the device or to the device. The logic around this is somewhat weird in the case of bidirectional transfers. It appears to want to throw both in succession, but since its a panic only the first makes it. This patch adds a third, separate error for DMA_BIDIRECTIONAL to make things a bit clearer. Signed-off-by: Casey Dahlin <cdahlin@redhat.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Becky Bruce <beckyb@kernel.crashing.org> [ further fixed the error message ] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <200908202327.n7KNRuqK001504@imap1.linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-21dma-debug: Fix check_unmap null pointer dereferenceKyle McMartin
While it's debatable whether or not a NULL device argument to the DMA API functions is valid... since it certainly isn't valid on devices with an IOMMU... dma-debug really shouldn't be dereferencing null pointers either. Guard against that in err_printk and the driver_filter functions. A Fedora rawhide user was seeing this in one of the dvb drivers resulting in an oops on boot. [ A patch has been sent for testing to the driver, but I feel the dma debugging support should be fixed as well. (There's still a pile of legacy garbage in the kernel passing null pointers to dma_{alloc,free}_*. :( ] Signed-off-by: Kyle McMartin <kyle@redhat.com> Cc: mchehab@infradead.org Cc: Joerg Roedel <joerg.roedel@amd.com> LKML-Reference: <20090820011708.GP25206@bombadil.infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-20kmemleak: Allow kmemleak to be built on powerpcMichael Ellerman
Very lightly tested, doesn't crash the kernel. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-08-14Merge branch 'percpu-for-linus' into percpu-for-nextTejun Heo
Conflicts: arch/sparc/kernel/smp_64.c arch/x86/kernel/cpu/perf_counter.c arch/x86/kernel/setup_percpu.c drivers/cpufreq/cpufreq_ondemand.c mm/percpu.c Conflicts in core and arch percpu codes are mostly from commit ed78e1e078dd44249f88b1dd8c76dafb39567161 which substituted many num_possible_cpus() with nr_cpu_ids. As for-next branch has moved all the first chunk allocators into mm/percpu.c, the changes are moved from arch code to mm/percpu.c. Signed-off-by: Tejun Heo <tj@kernel.org>
2009-08-11Merge branch 'master' into nextJames Morris
2009-08-07lib/decompress_*: only include <linux/slab.h> if STATIC is not definedAlbin Tonnerre
These includes were added by 079effb6933f34b9b1b67b08bd4fd7fb672d16ef ("kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_inflate.c") to fix the build when using kmemtrace. However this is not necessary when used to create a compressed kernel, and actually creates issues (brings a lot of things unavailable in the decompression environment), so don't include it if STATIC is defined. Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
