[ Upstream commit 305e519ce48e935702c32241f07d393c3c8fed3e ]
Walter Wu has reported a potential case in which init_stack_slab() is
called after stack_slabs[STACK_ALLOC_MAX_SLABS - 1] has already been
initialized. In that case init_stack_slab() will overwrite
stack_slabs[STACK_ALLOC_MAX_SLABS], which may result in a memory
corruption.
Link: http://lkml.kernel.org/r/20200218102950.260263-1-glider@google.com
Fixes: cd11016e5f521 ("mm, kasan: stackdepot implementation. Enable stackdepot for SLAB")
Signed-off-by: Alexander Potapenko <glider@google.com>
Reported-by: Walter Wu <walter-zh.wu@mediatek.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Matthias Brugger <matthias.bgg@gmail.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Kate Stewart <kstewart@linuxfoundation.org>
Cc: <stable@vger.kernel.org>
[ Upstream commit 4e456fee215677584cafa7f67298a76917e89c64 ]
Clang warns:
../lib/scatterlist.c:314:5: warning: misleading indentation; statement
is not part of the previous 'if' [-Wmisleading-indentation]
return -ENOMEM;
../lib/scatterlist.c:311:4: note: previous statement is here
if (prv)
1 warning generated.
This warning occurs because there is a space before the tab on this
line. Remove it so that the indentation is consistent with the Linux
kernel coding style and clang no longer warns.
Link: http://lkml.kernel.org/r/20191218033606.11942-1-natechancellor@gmail.com
Link: https://github.com/ClangBuiltLinux/linux/issues/830
Fixes: edce6820a9fd ("scatterlist: prevent invalid free when alloc fails")
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
commit 3e21d9a501bf99aee2e5835d7f34d8c823f115b5 upstream.
In case memory resources for _ptr2_ were allocated, release them before
return.
Notice that in case _ptr1_ happens to be NULL, krealloc() behaves
exactly like kmalloc().
Addresses-Coverity-ID: 1490594 ("Resource leak")
Link: http://lkml.kernel.org/r/20200123160115.GA4202@embeddedor
Fixes: 3f15801cdc23 ("lib: add kasan test module")
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
Reviewed-by: Dmitry Vyukov <dvyukov@google.com>
commit c42b65e363ce97a828f81b59033c3558f8fa7f70 upstream.
A lot of code become ugly because of open coding allocations for bitmaps.
Introduce three helpers to allow users be more clear of intention
and keep their code neat.
Note, due to multiple circular dependencies we may not provide
the helpers as inliners. For now we keep them exported and, perhaps,
at some point in the future we will sort out header inclusion and
inheritance.
[ Upstream commit ab9bb6318b0967671e0c9b6537c1537d51ca4f45 ]
Commit dfe2a77fd243 ("kfifo: fix kfifo_alloc() and kfifo_init()") made
the kfifo code round the number of elements up. That was good for
__kfifo_alloc(), but it's actually wrong for __kfifo_init().
The difference? __kfifo_alloc() will allocate the rounded-up number of
elements, but __kfifo_init() uses an allocation done by the caller. We
can't just say "use more elements than the caller allocated", and have
to round down.
The good news? All the normal cases will be using power-of-two arrays
anyway, and most users of kfifo's don't use kfifo_init() at all, but one
of the helper macros to declare a KFIFO that enforce the proper
power-of-two behavior. But it looks like at least ibmvscsis might be
affected.
The bad news? Will Deacon refers to an old thread and points points out
that the memory ordering in kfifo's is questionable. See
https://lore.kernel.org/lkml/20181211034032.32338-1-yuleixzhang@tencent.com/
for more.
Fixes: dfe2a77fd243 ("kfifo: fix kfifo_alloc() and kfifo_init()")
Reported-by: laokz <laokz@foxmail.com>
Cc: Stefani Seibold <stefani@seibold.net>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Cc: Greg KH <greg@kroah.com>
Cc: Will Deacon <will@kernel.org>
[ Upstream commit 9dea44c91469512d346e638694c22c30a5273992 ]
devm_ioremap_resource() does not currently take 'const' arguments,
which results in a warning from the first driver trying to do it
anyway:
drivers/gpio/gpio-amd-fch.c: In function 'amd_fch_gpio_probe':
drivers/gpio/gpio-amd-fch.c:171:49: error: passing argument 2 of 'devm_ioremap_resource' discards 'const' qualifier from pointer target type [-Werror=discarded-qualifiers]
priv->base = devm_ioremap_resource(&pdev->dev, &amd_fch_gpio_iores);
Change the prototype to allow it, as there is no real reason not to.
Fixes: 9bb2e0452508 ("gpio: amd: Make resource struct const")
Link: https://lore.kernel.org/r/20190628150049.1108048-1-arnd@arndb.de
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Reviwed-By: Enrico Weigelt <info@metux.net>
commit c70c176ff8c3ff0ac6ef9a831cd591ea9a66bd1a upstream.
Make the function available for outside use and fortify it against NULL
kobject.
CC: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
Acked-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Jens Axboe <axboe@fb.com>
[ Upstream commit 9ff6aa027dbb98755f0265695354f2dd07c0d1ce ]
debug_dma_dump_mappings() can take a lot of cpu cycles :
lpk43:/# time wc -l /sys/kernel/debug/dma-api/dump
163435 /sys/kernel/debug/dma-api/dump
real 0m0.463s
user 0m0.003s
sys 0m0.459s
Let's add a cond_resched() to avoid holding cpu for too long.
Cc: Corentin Labbe <clabbe@baylibre.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
commit 702600eef73033ddd4eafcefcbb6560f3e3a90f7 upstream.
Newer versions of awk spit out these fun warnings:
awk: ../lib/raid6/unroll.awk:16: warning: regexp escape sequence `\#' is not a known regexp operator
As commit 700c1018b86d ("x86/insn: Fix awk regexp warnings") showed, it
turns out that there are a number of awk strings that do not need to be
escaped and newer versions of awk now warn about this.
Fix the string up so that no warning is produced. The exact same kernel
module gets created before and after this patch, showing that it wasn't
needed.
Link: https://lore.kernel.org/r/20191206152600.GA75093@kroah.com
[ Upstream commit 35004f2e55807a1a1491db24ab512dd2f770a130 ]
Fixes build break on most ARM/ARM64 defconfigs:
lib/genalloc.c: In function 'gen_pool_add_virt':
lib/genalloc.c:190:10: error: implicit declaration of function 'vzalloc_node'; did you mean 'kzalloc_node'?
lib/genalloc.c:190:8: warning: assignment to 'struct gen_pool_chunk *' from 'int' makes pointer from integer without a cast [-Wint-conversion]
lib/genalloc.c: In function 'gen_pool_destroy':
lib/genalloc.c:254:3: error: implicit declaration of function 'vfree'; did you mean 'kfree'?
Fixes: 6862d2fc8185 ('lib/genalloc.c: use vzalloc_node() to allocate the bitmap')
Cc: Huang Shijie <sjhuang@iluvatar.ai>
Cc: Alexey Skidanov <alexey.skidanov@intel.com>
[ Upstream commit 6862d2fc81859f88c1f3f660886427893f2b4f3f ]
Some devices may have big memory on chip, such as over 1G. In some
cases, the nbytes maybe bigger then 4M which is the bounday of the
memory buddy system (4K default).
So use vzalloc_node() to allocate the bitmap. Also use vfree to free
it.
Link: http://lkml.kernel.org/r/20181225015701.6289-1-sjhuang@iluvatar.ai
Signed-off-by: Huang Shijie <sjhuang@iluvatar.ai>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
[ Upstream commit 52fbf1134d479234d7e64ba9dcbaea23405f229e ]
gen_pool_alloc_algo() uses different allocation functions implementing
different allocation algorithms. With gen_pool_first_fit_align()
allocation function, the returned address should be aligned on the
requested boundary.
If chunk start address isn't aligned on the requested boundary, the
returned address isn't aligned too. The only way to get properly
aligned address is to initialize the pool with chunks aligned on the
requested boundary. If want to have an ability to allocate buffers
aligned on different boundaries (for example, 4K, 1MB, ...), the chunk
start address should be aligned on the max possible alignment.
This happens because gen_pool_first_fit_align() looks for properly
aligned memory block without taking into account the chunk start address
alignment.
To fix this, we provide chunk start address to
gen_pool_first_fit_align() and change its implementation such that it
starts looking for properly aligned block with appropriate offset
(exactly as is done in CMA).
Link: https://lkml.kernel.org/lkml/a170cf65-6884-3592-1de9-4c235888cc8a@intel.com
Link: http://lkml.kernel.org/r/1541690953-4623-1-git-send-email-alexey.skidanov@intel.com
Signed-off-by: Alexey Skidanov <alexey.skidanov@intel.com>
Cc: Logan Gunthorpe <logang@deltatee.com>
Cc: Daniel Mentz <danielmentz@google.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: Laura Abbott <labbott@redhat.com>
commit 5cbf2fff3bba8d3c6a4d47c1754de1cf57e2b01f upstream.
In the current code, we use the atomic_cmpxchg() to serialize the output
of the dump_stack(), but this implementation suffers the thundering herd
problem. We have observed such kind of livelock on a Marvell cn96xx
board(24 cpus) when heavily using the dump_stack() in a kprobe handler.
Actually we can let the competitors to wait for the releasing of the
lock before jumping to atomic_cmpxchg(). This will definitely mitigate
the thundering herd problem. Thanks Linus for the suggestion.
[akpm@linux-foundation.org: fix comment]
Link: http://lkml.kernel.org/r/20191030031637.6025-1-haokexin@gmail.com
Fixes: b58d977432c8 ("dump_stack: serialize the output from dump_stack()")
Signed-off-by: Kevin Hao <haokexin@gmail.com>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
[ Upstream commit b751c52bb587ae66f773b15204ef7a147467f4c7 ]
The current default value (400) is too low on many systems (e.g. some
ARM64 platform takes up 1000+ entries).
syzbot uses 16000 as default value, and has proved to be enough on beefy
configurations, so let's pick that value.
This consumes more RAM on boot (each entry is 160 bytes, so in total
~2.5MB of RAM), but the memory would later be freed (early_log is
__initdata).
Link: http://lkml.kernel.org/r/20190730154027.101525-1-drinkcat@chromium.org
Signed-off-by: Nicolas Boichat <drinkcat@chromium.org>
Suggested-by: Dmitry Vyukov <dvyukov@google.com>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Acked-by: Dmitry Vyukov <dvyukov@google.com>
Cc: Petr Mladek <pmladek@suse.com>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: Joe Lawrence <joe.lawrence@redhat.com>
Cc: Uladzislau Rezki <urezki@gmail.com>
Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
commit 1ae2324f732c9c4e2fa4ebd885fa1001b70d52e1 upstream.
HalfSipHash, or hsiphash, is a shortened version of SipHash, which
generates 32-bit outputs using a weaker 64-bit key. It has *much* lower
security margins, and shouldn't be used for anything too sensitive, but
it could be used as a hashtable key function replacement, if the output
is never exposed, and if the security requirement is not too high.
The goal is to make this something that performance-critical jhash users
would be willing to use.
On 64-bit machines, HalfSipHash1-3 is slower than SipHash1-3, so we alias
SipHash1-3 to HalfSipHash1-3 on those systems.
64-bit x86_64:
[ 0.509409] test_siphash: SipHash2-4 cycles: 4049181
[ 0.510650] test_siphash: SipHash1-3 cycles: 2512884
[ 0.512205] test_siphash: HalfSipHash1-3 cycles: 3429920
[ 0.512904] test_siphash: JenkinsHash cycles: 978267
So, we map hsiphash() -> SipHash1-3
32-bit x86:
[ 0.509868] test_siphash: SipHash2-4 cycles: 14812892
[ 0.513601] test_siphash: SipHash1-3 cycles: 9510710
[ 0.515263] test_siphash: HalfSipHash1-3 cycles: 3856157
[ 0.515952] test_siphash: JenkinsHash cycles: 1148567
So, we map hsiphash() -> HalfSipHash1-3
hsiphash() is roughly 3 times slower than jhash(), but comes with a
considerable security improvement.
Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com>
Reviewed-by: Jean-Philippe Aumasson <jeanphilippe.aumasson@gmail.com>
[bwh: Backported to 4.9 to avoid regression for WireGuard with only half
the siphash API present]
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit 2c956a60778cbb6a27e0c7a8a52a91378c90e1d1 upstream.
SipHash is a 64-bit keyed hash function that is actually a
cryptographically secure PRF, like HMAC. Except SipHash is super fast,
and is meant to be used as a hashtable keyed lookup function, or as a
general PRF for short input use cases, such as sequence numbers or RNG
chaining.
For the first usage:
There are a variety of attacks known as "hashtable poisoning" in which an
attacker forms some data such that the hash of that data will be the
same, and then preceeds to fill up all entries of a hashbucket. This is
a realistic and well-known denial-of-service vector. Currently
hashtables use jhash, which is fast but not secure, and some kind of
rotating key scheme (or none at all, which isn't good). SipHash is meant
as a replacement for jhash in these cases.
There are a modicum of places in the kernel that are vulnerable to
hashtable poisoning attacks, either via userspace vectors or network
vectors, and there's not a reliable mechanism inside the kernel at the
moment to fix it. The first step toward fixing these issues is actually
getting a secure primitive into the kernel for developers to use. Then
we can, bit by bit, port things over to it as deemed appropriate.
While SipHash is extremely fast for a cryptographically secure function,
it is likely a bit slower than the insecure jhash, and so replacements
will be evaluated on a case-by-case basis based on whether or not the
difference in speed is negligible and whether or not the current jhash usage
poses a real security risk.
For the second usage:
A few places in the kernel are using MD5 or SHA1 for creating secure
sequence numbers, syn cookies, port numbers, or fast random numbers.
SipHash is a faster and more fitting, and more secure replacement for MD5
in those situations. Replacing MD5 and SHA1 with SipHash for these uses is
obvious and straight-forward, and so is submitted along with this patch
series. There shouldn't be much of a debate over its efficacy.
Dozens of languages are already using this internally for their hash
tables and PRFs. Some of the BSDs already use this in their kernels.
SipHash is a widely known high-speed solution to a widely known set of
problems, and it's time we catch-up.
Cc: Eric Biggers <ebiggers3@gmail.com>
Cc: David Laight <David.Laight@aculab.com>
[bwh: Backported to 4.9 as dependency of commits df453700e8d8 "inet: switch
IP ID generator to siphash" and 3c79107631db "netfilter: ctnetlink: don't
use conntrack/expect object addresses as id"]
[ Upstream commit 1a3241ff10d038ecd096d03380327f2a0b5840a6 ]
strscpy() performs the word-at-a-time optimistic reads. So it may may
access the memory past the end of the object, which is perfectly fine
since strscpy() doesn't use that (past-the-end) data and makes sure the
optimistic read won't cross a page boundary.
Use new read_word_at_a_time() to shut up the KASAN.
Note that this potentially could hide some bugs. In example bellow,
stscpy() will copy more than we should (1-3 extra uninitialized bytes):
char dst[8];
char *src;
src = kmalloc(5, GFP_KERNEL);
memset(src, 0xff, 5);
strscpy(dst, src, 8);
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
commit aeb87246537a83c2aff482f3f34a2e0991e02cbc upstream.
All mapping iterator logic is based on the assumption that sg->offset
is always lower than PAGE_SIZE.
But there are situations where sg->offset is such that the SG item
is on the second page. In that case sg_copy_to_buffer() fails
properly copying the data into the buffer. One of the reason is
that the data will be outside the kmapped area used to access that
data.
This patch fixes the issue by adjusting the mapping iterator
offset and pgoffset fields such that offset is always lower than
PAGE_SIZE.
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
Fixes: 4225fc8555a9 ("lib/scatterlist: use page iterator in the mapping iterator")
Cc: stable@vger.kernel.org
[ Upstream commit ef4d6a8556b637ad27c8c2a2cff1dda3da38e9a9 ]
Check if the syndrome provided by the caller is zero, and act
accordingly.
Signed-off-by: Ferdinand Blomqvist <ferdinand.blomqvist@gmail.com>
Link: https://lkml.kernel.org/r/20190620141039.9874-6-ferdinand.blomqvist@gmail.com
[ Upstream commit 2034a42d1747fc1e1eeef2c6f1789c4d0762cb9c ]
The decoding of shortenend codes is broken. It only works as expected if
there are no erasures.
When decoding with erasures, Lambda (the error and erasure locator
polynomial) is initialized from the given erasure positions. The pad
parameter is not accounted for by the initialisation code, and hence
Lambda is initialized from incorrect erasure positions.
The fix is to adjust the erasure positions by the supplied pad.
Link: https://lkml.kernel.org/r/20190620141039.9874-3-ferdinand.blomqvist@gmail.com
commit c8ea9fce2baf7b643384f36f29e4194fa40d33a6 upstream.
Sometimes mpi_powm will leak karactx because a memory allocation
failure causes a bail-out that skips the freeing of karactx. This
patch moves the freeing of karactx to the end of the function like
everything else so that it can't be skipped.
Reported-by: syzbot+f7baccc38dcc1e094e77@syzkaller.appspotmail.com
Fixes: cdec9cb5167a ("crypto: GnuPG based MPI lib - source files...")
Reviewed-by: Eric Biggers <ebiggers@kernel.org>
[ Upstream commit 29da93fea3ea39ab9b12270cc6be1b70ef201c9e ]
Randy reported objtool triggered on his (GCC-7.4) build:
lib/strncpy_from_user.o: warning: objtool: strncpy_from_user()+0x315: call to __ubsan_handle_add_overflow() with UACCESS enabled
lib/strnlen_user.o: warning: objtool: strnlen_user()+0x337: call to __ubsan_handle_sub_overflow() with UACCESS enabled
This is due to UBSAN generating signed-overflow-UB warnings where it
should not. Prior to GCC-8 UBSAN ignored -fwrapv (which the kernel
uses through -fno-strict-overflow).
Make the functions use 'unsigned long' throughout.
Reported-by: Randy Dunlap <rdunlap@infradead.org>
Acked-by: Randy Dunlap <rdunlap@infradead.org> # build-tested
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: luto@kernel.org
Link: http://lkml.kernel.org/r/20190424072208.754094071@infradead.org
commit f0996bc2978e02d2ea898101462b960f6119b18f upstream.
Building lib/ubsan.c with gcc-9 results in a ton of nasty warnings like
this one:
lib/ubsan.c warning: conflicting types for built-in function
‘__ubsan_handle_negate_overflow’; expected ‘void(void *, void *)’ [-Wbuiltin-declaration-mismatch]
The kernel's declarations of __ubsan_handle_*() often uses 'unsigned
long' types in parameters while GCC these parameters as 'void *' types,
hence the mismatch.
Fix this by using 'void *' to match GCC's declarations.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Fixes: c6d308534aef ("UBSAN: run-time undefined behavior sanity checker")
commit 69ca372c100fba99c78ef826a1795aa86e4f01a8 upstream.
A compiler can optimize away memset calls by replacing them with mov
instructions. There are KASAN tests that specifically test that KASAN
correctly handles memset calls so we don't want this optimization to
happen.
The solution is to add -fno-builtin flag to test_kasan.ko
Link: http://lkml.kernel.org/r/105ec9a308b2abedb1a0d1fdced0c22d765e4732.1519924383.git.andreyknvl@google.com
Signed-off-by: Andrey Konovalov <andreyknvl@google.com>
Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Nick Terrell <terrelln@fb.com>
Cc: Chris Mason <clm@fb.com>
Cc: Yury Norov <ynorov@caviumnetworks.com>
Cc: "Luis R . Rodriguez" <mcgrof@kernel.org>
Cc: Palmer Dabbelt <palmer@dabbelt.com>
Cc: "Paul E . McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Jeff Layton <jlayton@redhat.com>
Cc: "Jason A . Donenfeld" <Jason@zx2c4.com>
Cc: Kostya Serebryany <kcc@google.com>
commit 48c232395431c23d35cf3b4c5a090bd793316578 upstream.
Variable real_size is initialized with a value that is never read, it is
re-assigned a new value later on, hence the initialization is redundant
and can be removed.
Cleans up clang warning:
lib/test_kasan.c:422:21: warning: Value stored to 'real_size' during its initialization is never read
Link: http://lkml.kernel.org/r/20180206144950.32457-1-colin.king@canonical.com
[ Upstream commit cdc94a37493135e355dfc0b0e086d84e3eadb50d ]
fls counts bits starting from 1 to 32 (returns 0 for zero argument). If
we add 1 we shift right one bit more and loose precision from divisor,
what cause function incorect results with some numbers.
Corrected code was tested in user-space, see bugzilla:
https://bugzilla.kernel.org/show_bug.cgi?id=202391
Link: http://lkml.kernel.org/r/1548686944-11891-1-git-send-email-sgruszka@redhat.com
Fixes: 658716d19f8f ("div64_u64(): improve precision on 32bit platforms")
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Reported-by: Siarhei Volkau <lis8215@gmail.com>
Tested-by: Siarhei Volkau <lis8215@gmail.com>
Acked-by: Oleg Nesterov <oleg@redhat.com>
[ Upstream commit 5f074f3e192f10c9fade898b9b3b8812e3d83342 ]
A recent optimization in Clang (r355672) lowers comparisons of the
return value of memcmp against zero to comparisons of the return value
of bcmp against zero. This helps some platforms that implement bcmp
more efficiently than memcmp. glibc simply aliases bcmp to memcmp, but
an optimized implementation is in the works.
This results in linkage failures for all targets with Clang due to the
undefined symbol. For now, just implement bcmp as a tailcail to memcmp
to unbreak the build. This routine can be further optimized in the
future.
Other ideas discussed:
* A weak alias was discussed, but breaks for architectures that define
their own implementations of memcmp since aliases to declarations are
not permitted (only definitions). Arch-specific memcmp
implementations typically declare memcmp in C headers, but implement
them in assembly.
* -ffreestanding also is used sporadically throughout the kernel.
* -fno-builtin-bcmp doesn't work when doing LTO.
Link: https://bugs.llvm.org/show_bug.cgi?id=41035
Link: https://code.woboq.org/userspace/glibc/string/memcmp.c.html#bcmp
Link: https://github.com/llvm/llvm-project/commit/8e16d73346f8091461319a7dfc4ddd18eedcff13
Link: https://github.com/ClangBuiltLinux/linux/issues/416
Link: http://lkml.kernel.org/r/20190313211335.165605-1-ndesaulniers@google.com
Signed-off-by: Nick Desaulniers <ndesaulniers@google.com>
Reported-by: Nathan Chancellor <natechancellor@gmail.com>
Reported-by: Adhemerval Zanella <adhemerval.zanella@linaro.org>
Suggested-by: Arnd Bergmann <arnd@arndb.de>
Suggested-by: James Y Knight <jyknight@google.com>
Suggested-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Suggested-by: Nathan Chancellor <natechancellor@gmail.com>
Suggested-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Reviewed-by: Nathan Chancellor <natechancellor@gmail.com>
Tested-by: Nathan Chancellor <natechancellor@gmail.com>
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: David Laight <David.Laight@ACULAB.COM>
Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Dan Williams <dan.j.williams@intel.com>
[ Upstream commit de9c0d49d85dc563549972edc5589d195cd5e859 ]
While building arm32 allyesconfig, I ran into the following errors:
arch/arm/lib/xor-neon.c:17:2: error: You should compile this file with
'-mfloat-abi=softfp -mfpu=neon'
In file included from lib/raid6/neon1.c:27:
/home/nathan/cbl/prebuilt/lib/clang/8.0.0/include/arm_neon.h:28:2:
error: "NEON support not enabled"
Building V=1 showed NEON_FLAGS getting passed along to Clang but
__ARM_NEON__ was not getting defined. Ultimately, it boils down to Clang
only defining __ARM_NEON__ when targeting armv7, rather than armv6k,
which is the '-march' value for allyesconfig.
>From lib/Basic/Targets/ARM.cpp in the Clang source:
// This only gets set when Neon instructions are actually available, unlike
// the VFP define, hence the soft float and arch check. This is subtly
// different from gcc, we follow the intent which was that it should be set
// when Neon instructions are actually available.
if ((FPU & NeonFPU) && !SoftFloat && ArchVersion >= 7) {
Builder.defineMacro("__ARM_NEON", "1");
Builder.defineMacro("__ARM_NEON__");
// current AArch32 NEON implementations do not support double-precision
// floating-point even when it is present in VFP.
Builder.defineMacro("__ARM_NEON_FP",
"0x" + Twine::utohexstr(HW_FP & ~HW_FP_DP));
Ard Biesheuvel recommended explicitly adding '-march=armv7-a' at the
beginning of the NEON_FLAGS definitions so that __ARM_NEON__ always gets
definined by Clang. This doesn't functionally change anything because
that code will only run where NEON is supported, which is implicitly
armv7.
Link: https://github.com/ClangBuiltLinux/linux/issues/287
Suggested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
Reviewed-by: Nick Desaulniers <ndesaulniers@google.com>
Reviewed-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
[ Upstream commit 02106f883cd745523f7766d90a739f983f19e650 ]
Since kprobe breakpoing handler is using bsearch(), probing on this
routine can cause recursive breakpoint problem.
int3
->do_int3()
->ftrace_int3_handler()
->ftrace_location()
->ftrace_location_range()
->bsearch() -> int3
Prohibit probing on bsearch().
Signed-off-by: Andrea Righi <righi.andrea@gmail.com>
Acked-by: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/154998813406.31052.8791425358974650922.stgit@devbox
commit f8ae107eef209bff29a5816bc1aad40d5cd69a80 upstream.
The initial value (@m) compute is:
m = 1UL << (BITS_PER_LONG - 2);
while (m > x)
m >>= 2;
Which is a linear search for the highest even bit smaller or equal to @x
We can implement this using a binary search using __fls() (or better when
its hardware implemented).
m = 1UL << (__fls(x) & ~1UL);
Especially for small values of @x; which are the more common arguments
when doing a CDF on idle times; the linear search is near to worst case,
while the binary search of __fls() is a constant 6 (or 5 on 32bit)
branches.
cycles: branches: branch-misses:
PRE:
hot: 43.633557 +- 0.034373 45.333132 +- 0.002277 0.023529 +- 0.000681
cold: 207.438411 +- 0.125840 45.333132 +- 0.002277 6.976486 +- 0.004219
SOFTWARE FLS:
hot: 29.576176 +- 0.028850 26.666730 +- 0.004511 0.019463 +- 0.000663
cold: 165.947136 +- 0.188406 26.666746 +- 0.004511 6.133897 +- 0.004386
HARDWARE FLS:
hot: 24.720922 +- 0.025161 20.666784 +- 0.004509 0.020836 +- 0.000677
cold: 132.777197 +- 0.127471 20.666776 +- 0.004509 5.080285 +- 0.003874
Averages computed over all values <128k using a LFSR to generate order.
Cold numbers have a LFSR based branch trace buffer 'confuser' ran between
each int_sqrt() invocation.
Link: http://lkml.kernel.org/r/20171020164644.936577234@infradead.org
Suggested-by: Joe Perches <joe@perches.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Cc: Anshul Garg <aksgarg1989@gmail.com>
Cc: Davidlohr Bueso <dave@stgolabs.net>
Cc: Matthew Wilcox <mawilcox@microsoft.com>
Cc: Michael Davidson <md@google.com>
Cc: Joe Perches <joe@perches.com>
commit 3f3295709edea6268ff1609855f498035286af73 upstream.
The current int_sqrt() computation is sub-optimal for the case of small
@x. Which is the interesting case when we're going to do cumulative
distribution functions on idle times, which we assume to be a random
variable, where the target residency of the deepest idle state gives an
upper bound on the variable (5e6ns on recent Intel chips).
In the case of small @x, the compute loop:
while (m != 0) {
b = y + m;
y >>= 1;
if (x >= b) {
x -= b;
y += m;
m >>= 2;
can be reduced to:
while (m > x)
m >>= 2;
Because y==0, b==m and until x>=m y will remain 0.
And while this is computationally equivalent, it runs much faster
because there's less code, in particular less branches.
OLD:
hot: 45.109444 +- 0.044117 44.333392 +- 0.002254 0.018723 +- 0.000593
cold: 187.737379 +- 0.156678 44.333407 +- 0.002254 6.272844 +- 0.004305
PRE:
hot: 67.937492 +- 0.064124 66.999535 +- 0.000488 0.066720 +- 0.001113
cold: 232.004379 +- 0.332811 66.999527 +- 0.000488 6.914634 +- 0.006568
POST:
Link: http://lkml.kernel.org/r/20171020164644.876503355@infradead.org
Fixes: 30493cc9dddb ("lib/int_sqrt.c: optimize square root algorithm")
Suggested-by: Anshul Garg <aksgarg1989@gmail.com>
[ Upstream commit bb2ba2d75a2d673e76ddaf13a9bd30d6a8b1bb08 ]
Fix the creation of shortcuts for which the length of the index key value
is an exact multiple of the machine word size. The problem is that the
code that blanks off the unused bits of the shortcut value malfunctions if
the number of bits in the last word equals machine word size. This is due
to the "<<" operator being given a shift of zero in this case, and so the
mask that should be all zeros is all ones instead. This causes the
subsequent masking operation to clear everything rather than clearing
nothing.
Ordinarily, the presence of the hash at the beginning of the tree index key
makes the issue very hard to test for, but in this case, it was encountered
due to a development mistake that caused the hash output to be either 0
(keyring) or 1 (non-keyring) only. This made it susceptible to the
keyctl/unlink/valid test in the keyutils package.
The fix is simply to skip the blanking if the shift would be 0. For
example, an index key that is 64 bits long would produce a 0 shift and thus
a 'blank' of all 1s. This would then be inverted and AND'd onto the
index_key, incorrectly clearing the entire last word.
Fixes: 3cb989501c26 ("Add a generic associative array implementation.")
Signed-off-by: James Morris <james.morris@microsoft.com>
[ Upstream commit 0464ed24380905d640030d368cd84a4e4d1e15e2 ]
Currently seq_buf_puts() will happily create a non null-terminated
string for you in the buffer. This is particularly dangerous if the
buffer is on the stack.
For example:
char buf[8];
char secret = "secret";
struct seq_buf s;
seq_buf_init(&s, buf, sizeof(buf));
seq_buf_puts(&s, "foo");
printk("Message is %s\n", buf);
Can result in:
Message is fooªªªªªsecret
We could require all users to memset() their buffer to zero before
use. But that seems likely to be forgotten and lead to bugs.
Instead we can change seq_buf_puts() to always leave the buffer in a
null-terminated state.
The only downside is that this makes the buffer 1 character smaller
for seq_buf_puts(), but that seems like a good trade off.
Link: http://lkml.kernel.org/r/20181019042109.8064-1-mpe@ellerman.id.au
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
[ Upstream commit a8ec14d4f6aa8e245efacc992c8ee6ea0464ce2a ]
Add a 'max_endpoint' parameter such that users may easily limit the size
of the intervals that are randomly generated.
Link: http://lkml.kernel.org/r/20170518174936.20265-4-dave@stgolabs.net
Signed-off-by: Davidlohr Bueso <dbueso@suse.de>
[ Upstream commit 0b548e33e6cb2bff240fdaf1783783be15c29080 ]
Fengguang reported soft lockups while running the rbtree and interval
tree test modules. The logic for these tests all occur in init phase,
and we currently are pounding with the default values for number of
nodes and number of iterations of each test. Reduce the latter by two
orders of magnitude. This does not influence the value of the tests in
that one thousand times by default is enough to get the picture.
Link: http://lkml.kernel.org/r/20171109161715.xai2dtwqw2frhkcm@linux-n805
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
[ Upstream commit 223f8911eace60c787f8767c25148b80ece9732a ]
Allows for more flexible debugging.
Link: http://lkml.kernel.org/r/20170719014603.19029-5-dave@stgolabs.net
[ Upstream commit c46ecce431ebe6b1a9551d1f530eb432dae5c39b ]
... such that a user can specify visiting all the nodes in the tree
(intersects with the world). This is a nice opposite from the very
basic default query which is a single point.
Link: http://lkml.kernel.org/r/20170518174936.20265-5-dave@stgolabs.net
[ Upstream commit a54dae0338b7f01eb0f9c7571fb9b74f791d1c6b ]
Link: http://lkml.kernel.org/r/20170518174936.20265-3-dave@stgolabs.net
[ Upstream commit 8de456cf87ba863e028c4dd01bae44255ce3d835 ]
CONFIG_DEBUG_OBJECTS_RCU_HEAD does not play well with kmemleak due to
recursive calls.
fill_pool
kmemleak_ignore
make_black_object
put_object
__call_rcu (kernel/rcu/tree.c)
debug_rcu_head_queue
debug_object_activate
debug_object_init
fill_pool
kmemleak_ignore
make_black_object
So add SLAB_NOLEAKTRACE to kmem_cache_create() to not register newly
allocated debug objects at all.
Link: http://lkml.kernel.org/r/20181126165343.2339-1-cai@gmx.us
Signed-off-by: Qian Cai <cai@gmx.us>
Suggested-by: Catalin Marinas <catalin.marinas@arm.com>
Acked-by: Waiman Long <longman@redhat.com>
Cc: Yang Shi <yang.shi@linux.alibaba.com>
commit 7d63fb3af87aa67aa7d24466e792f9d7c57d8e79 upstream.
This removes needless use of '%p', and refactors the printk calls to
use pr_*() helpers instead.
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
[bwh: Backported to 4.9:
- Adjust filename
- Remove "swiotlb: " prefix from an additional log message]
commit 77d2a24b6107bd9b3bf2403a65c1428a9da83dd0 upstream.
gcc 8.1.0 complains:
lib/kobject.c:128:3: warning:
'strncpy' output truncated before terminating nul copying as many
bytes from a string as its length [-Wstringop-truncation]
lib/kobject.c: In function 'kobject_get_path':
lib/kobject.c:125:13: note: length computed here
Using strncpy() is indeed less than perfect since the length of data to
be copied has already been determined with strlen(). Replace strncpy()
with memcpy() to address the warning and optimize the code a little.
commit b1286ed7158e9b62787508066283ab0b8850b518 upstream.
New versions of gcc reasonably warn about the odd pattern of
strncpy(p, q, strlen(q));
which really doesn't make sense: the strncpy() ends up being just a slow
and odd way to write memcpy() in this case.
Apparently there was a patch for this floating around earlier, but it
got lost.
Acked-again-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
[ Upstream commit 313a06e636808387822af24c507cba92703568b1 ]
The lib/raid6/test fails to build the neon objects
on arm64 because the correct machine type is 'aarch64'.
Once this is correctly enabled, the neon recovery objects
need to be added to the build.
Reviewed-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Signed-off-by: Jeremy Linton <jeremy.linton@arm.com>
commit 1c23b4108d716cc848b38532063a8aca4f86add8 upstream.
gcc-8 complains about the prototype for this function:
lib/ubsan.c:432:1: error: ignoring attribute 'noreturn' in declaration of a built-in function '__ubsan_handle_builtin_unreachable' because it conflicts with attribute 'const' [-Werror=attributes]
This is actually a GCC's bug. In GCC internals
__ubsan_handle_builtin_unreachable() declared with both 'noreturn' and
'const' attributes instead of only 'noreturn':
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=84210
Workaround this by removing the noreturn attribute.
[aryabinin: add information about GCC bug in changelog]
Link: http://lkml.kernel.org/r/20181107144516.4587-1-aryabinin@virtuozzo.com
Acked-by: Olof Johansson <olof@lixom.net>
[ Upstream commit 9506a7425b094d2f1d9c877ed5a78f416669269b ]
It was found that when debug_locks was turned off because of a problem
found by the lockdep code, the system performance could drop quite
significantly when the lock_stat code was also configured into the
kernel. For instance, parallel kernel build time on a 4-socket x86-64
server nearly doubled.
Further analysis into the cause of the slowdown traced back to the
frequent call to debug_locks_off() from the __lock_acquired() function
probably due to some inconsistent lockdep states with debug_locks
off. The debug_locks_off() function did an unconditional atomic xchg
to write a 0 value into debug_locks which had already been set to 0.
This led to severe cacheline contention in the cacheline that held
debug_locks. As debug_locks is being referenced in quite a few different
places in the kernel, this greatly slow down the system performance.
To prevent that trashing of debug_locks cacheline, lock_acquired()
and lock_contended() now checks the state of debug_locks before
proceeding. The debug_locks_off() function is also modified to check
debug_locks before calling __debug_locks_off().
Signed-off-by: Waiman Long <longman@redhat.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/1539913518-15598-1-git-send-email-longman@redhat.com
[ Upstream commit 52fda36d63bfc8c8e8ae5eda8eb5ac6f52cd67ed ]
Function bpf_fill_maxinsns11 is designed to not be able to be JITed on
x86_64. So, it fails when CONFIG_BPF_JIT_ALWAYS_ON=y, and
commit 09584b406742 ("bpf: fix selftests/bpf test_kmod.sh failure when
CONFIG_BPF_JIT_ALWAYS_ON=y") makes sure that failure is detected on that
case.
However, it does not fail on other architectures, which have a different
JIT compiler design. So, test_bpf has started to fail to load on those.
After this fix, test_bpf loads fine on both x86_64 and ppc64el.
Fixes: 09584b406742 ("bpf: fix selftests/bpf test_kmod.sh failure when CONFIG_BPF_JIT_ALWAYS_ON=y")
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@canonical.com>
Reviewed-by: Yonghong Song <yhs@fb.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Rehashing and destroying large hash table takes a lot of time,
and happens in process context. It is safe to add cond_resched()
in rhashtable_rehash_table() and rhashtable_free_and_destroy()
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
(cherry picked from commit ae6da1f503abb5a5081f9f6c4a6881de97830f3e)
[ Upstream commit 624fa7790f80575a4ec28fbdb2034097dc18d051 ]
In the scsi_transport_srp implementation it cannot be avoided to
iterate over a klist from atomic context when using the legacy block
layer instead of blk-mq. Hence this patch that makes it safe to use
klists in atomic context. This patch avoids that lockdep reports the
following:
WARNING: SOFTIRQ-safe -> SOFTIRQ-unsafe lock order detected
Possible interrupt unsafe locking scenario:
CPU0 CPU1
lock(&(&k->k_lock)->rlock);
local_irq_disable();
lock(&(&q->__queue_lock)->rlock);
<Interrupt>
stack backtrace:
Workqueue: kblockd blk_timeout_work
Call Trace:
dump_stack+0xa4/0xf5
check_usage+0x6e6/0x700
__lock_acquire+0x185d/0x1b50
lock_acquire+0xd2/0x260
_raw_spin_lock+0x32/0x50
klist_next+0x47/0x190
device_for_each_child+0x8e/0x100
srp_timed_out+0xaf/0x1d0 [scsi_transport_srp]
scsi_times_out+0xd4/0x410 [scsi_mod]
blk_rq_timed_out+0x36/0x70
blk_timeout_work+0x1b5/0x220
process_one_work+0x4fe/0xad0
worker_thread+0x63/0x5a0
kthread+0x1c1/0x1e0
ret_from_fork+0x24/0x30
See also commit c9ddf73476ff ("scsi: scsi_transport_srp: Fix shost to
rport translation").
Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com>
Cc: Martin K. Petersen <martin.petersen@oracle.com>
Cc: James Bottomley <jejb@linux.vnet.ibm.com>
commit fc91a3c4c27acdca0bc13af6fbb68c35cfd519f2 upstream.
While debugging an issue debugobject tracking warned about an annotation
issue of an object on stack. It turned out that the issue was due to the
object in concern being on a different stack which was due to another
issue.
Thomas suggested to print the pointers and the location of the stack for
the currently running task. This helped to figure out that the object was
on the wrong stack.
As this is general useful information for debugging similar issues, make
the error message more informative by printing the pointers.
[ tglx: Massaged changelog ]
Signed-off-by: Joel Fernandes (Google) <joel@joelfernandes.org>
Acked-by: Yang Shi <yang.shi@linux.alibaba.com>
Cc: kernel-team@android.com
Cc: astrachan@google.com
Link: https://lkml.kernel.org/r/20180723212531.202328-1-joel@joelfernandes.org
commit 785a19f9d1dd8a4ab2d0633be4656653bd3de1fc upstream.
The following kernel panic was observed on ARM64 platform due to a stale
TLB entry.
1. ioremap with 4K size, a valid pte page table is set.
2. iounmap it, its pte entry is set to 0.
3. ioremap the same address with 2M size, update its pmd entry with
a new value.
4. CPU may hit an exception because the old pmd entry is still in TLB,
which leads to a kernel panic.
Commit b6bdb7517c3d ("mm/vmalloc: add interfaces to free unmapped page
table") has addressed this panic by falling to pte mappings in the above
case on ARM64.
To support pmd mappings in all cases, TLB purge needs to be performed
in this case on ARM64.
Add a new arg, 'addr', to pud_free_pmd_page() and pmd_free_pte_page()
so that TLB purge can be added later in seprate patches.
[toshi.kani@hpe.com: merge changes, rewrite patch description]
Fixes: 28ee90fe6048 ("x86/mm: implement free pmd/pte page interfaces")
Signed-off-by: Chintan Pandya <cpandya@codeaurora.org>
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Cc: mhocko@suse.com
Cc: akpm@linux-foundation.org
Cc: hpa@zytor.com
Cc: linux-mm@kvack.org
Cc: Joerg Roedel <joro@8bytes.org>
Cc: Michal Hocko <mhocko@suse.com>
Link: https://lkml.kernel.org/r/20180627141348.21777-3-toshi.kani@hpe.com
