commit 3e14c6abbfb5c94506edda9d8e2c145d79375798 upstream.
This WARNING proved to be noisy. The function still returns an error
and callers should handle it. That's how most of kernel code works.
Downgrade the WARNING to pr_err() and leave WARNINGs for kernel bugs.
Signed-off-by: Dmitry Vyukov <dvyukov@google.com>
Reported-by: syzbot+209c0f67f99fec8eb14b@syzkaller.appspotmail.com
Reported-by: syzbot+7fb6d9525a4528104e05@syzkaller.appspotmail.com
Reported-by: syzbot+2e63711063e2d8f9ea27@syzkaller.appspotmail.com
Reported-by: syzbot+de73361ee4971b6e6f75@syzkaller.appspotmail.com
Cc: stable <stable@vger.kernel.org>
commit f5967101e9de12addcda4510dfbac66d7c5779c3 upstream.
People complained about ARCH_HWEIGHT_CFLAGS and how it throws a wrench
into kcov, lto, etc, experimentations.
Add asm versions for __sw_hweight{32,64}() and do explicit saving and
restoring of clobbered registers. This gets rid of the special calling
convention. We get to call those functions on !X86_FEATURE_POPCNT CPUs.
We still need to hardcode POPCNT and register operands as some old gas
versions which we support, do not know about POPCNT.
Btw, remove redundant REX prefix from 32-bit POPCNT because alternatives
can do padding now.
Suggested-by: H. Peter Anvin <hpa@zytor.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Link: http://lkml.kernel.org/r/1464605787-20603-1-git-send-email-bp@alien8.de
Signed-off-by: Matthias Kaehlcke <mka@chromium.org>
commit b6bdb7517c3d3f41f20e5c2948d6bc3f8897394e upstream.
On architectures with CONFIG_HAVE_ARCH_HUGE_VMAP set, ioremap() may
create pud/pmd mappings. A kernel panic was observed on arm64 systems
with Cortex-A75 in the following steps as described by Hanjun Guo.
1. ioremap a 4K size, valid page table will build,
2. iounmap it, pte0 will set to 0;
3. ioremap the same address with 2M size, pgd/pmd is unchanged,
then set the a new value for pmd;
4. pte0 is leaked;
5. CPU may meet exception because the old pmd is still in TLB,
which will lead to kernel panic.
This panic is not reproducible on x86. INVLPG, called from iounmap,
purges all levels of entries associated with purged address on x86. x86
still has memory leak.
The patch changes the ioremap path to free unmapped page table(s) since
doing so in the unmap path has the following issues:
- The iounmap() path is shared with vunmap(). Since vmap() only
supports pte mappings, making vunmap() to free a pte page is an
overhead for regular vmap users as they do not need a pte page freed
up.
- Checking if all entries in a pte page are cleared in the unmap path
is racy, and serializing this check is expensive.
- The unmap path calls free_vmap_area_noflush() to do lazy TLB purges.
Clearing a pud/pmd entry before the lazy TLB purges needs extra TLB
purge.
Add two interfaces, pud_free_pmd_page() and pmd_free_pte_page(), which
clear a given pud/pmd entry and free up a page for the lower level
entries.
This patch implements their stub functions on x86 and arm64, which work
as workaround.
[akpm@linux-foundation.org: fix typo in pmd_free_pte_page() stub]
Link: http://lkml.kernel.org/r/20180314180155.19492-2-toshi.kani@hpe.com
Fixes: e61ce6ade404e ("mm: change ioremap to set up huge I/O mappings")
Reported-by: Lei Li <lious.lilei@hisilicon.com>
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Cc: Wang Xuefeng <wxf.wang@hisilicon.com>
Cc: Hanjun Guo <guohanjun@huawei.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Matthew Wilcox <willy@infradead.org>
Cc: Chintan Pandya <cpandya@codeaurora.org>
Cc: <stable@vger.kernel.org>
[ tweak arm64 portion to rely on CONFIG_ARCH_HAVE_HUGE_VMAP - gregkh]
[ Upstream commit bbc25bee37d2b32cf3a1fab9195b6da3a185614a ]
Current MIPS64r6 toolchains aren't able to generate efficient
DMULU/DMUHU based code for the C implementation of umul_ppmm(), which
performs an unsigned 64 x 64 bit multiply and returns the upper and
lower 64-bit halves of the 128-bit result. Instead it widens the 64-bit
inputs to 128-bits and emits a __multi3 intrinsic call to perform a 128
x 128 multiply. This is both inefficient, and it results in a link error
since we don't include __multi3 in MIPS linux.
For example commit 90a53e4432b1 ("cfg80211: implement regdb signature
checking") merged in v4.15-rc1 recently broke the 64r6_defconfig and
64r6el_defconfig builds by indirectly selecting MPILIB. The same build
errors can be reproduced on older kernels by enabling e.g. CRYPTO_RSA:
lib/mpi/generic_mpih-mul1.o: In function `mpihelp_mul_1':
lib/mpi/generic_mpih-mul1.c:50: undefined reference to `__multi3'
lib/mpi/generic_mpih-mul2.o: In function `mpihelp_addmul_1':
lib/mpi/generic_mpih-mul2.c:49: undefined reference to `__multi3'
lib/mpi/generic_mpih-mul3.o: In function `mpihelp_submul_1':
lib/mpi/generic_mpih-mul3.c:49: undefined reference to `__multi3'
lib/mpi/mpih-div.o In function `mpihelp_divrem':
lib/mpi/mpih-div.c:205: undefined reference to `__multi3'
lib/mpi/mpih-div.c:142: undefined reference to `__multi3'
Therefore add an efficient MIPS64r6 implementation of umul_ppmm() using
inline assembly and the DMULU/DMUHU instructions, to prevent __multi3
calls being emitted.
Fixes: 7fd08ca58ae6 ("MIPS: Add build support for the MIPS R6 ISA")
Signed-off-by: James Hogan <jhogan@kernel.org>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: linux-mips@linux-mips.org
Cc: linux-crypto@vger.kernel.org
commit e7c52b84fb18f08ce49b6067ae6285aca79084a8 upstream.
We get a lot of very large stack frames using gcc-7.0.1 with the default
-fsanitize-address-use-after-scope --param asan-stack=1 options, which can
easily cause an overflow of the kernel stack, e.g.
drivers/gpu/drm/i915/gvt/handlers.c:2434:1: warning: the frame size of 46176 bytes is larger than 3072 bytes
drivers/net/wireless/ralink/rt2x00/rt2800lib.c:5650:1: warning: the frame size of 23632 bytes is larger than 3072 bytes
lib/atomic64_test.c:250:1: warning: the frame size of 11200 bytes is larger than 3072 bytes
drivers/gpu/drm/i915/gvt/handlers.c:2621:1: warning: the frame size of 9208 bytes is larger than 3072 bytes
drivers/media/dvb-frontends/stv090x.c:3431:1: warning: the frame size of 6816 bytes is larger than 3072 bytes
fs/fscache/stats.c:287:1: warning: the frame size of 6536 bytes is larger than 3072 bytes
To reduce this risk, -fsanitize-address-use-after-scope is now split out
into a separate CONFIG_KASAN_EXTRA Kconfig option, leading to stack
frames that are smaller than 2 kilobytes most of the time on x86_64. An
earlier version of this patch also prevented combining KASAN_EXTRA with
KASAN_INLINE, but that is no longer necessary with gcc-7.0.1.
All patches to get the frame size below 2048 bytes with CONFIG_KASAN=y
and CONFIG_KASAN_EXTRA=n have been merged by maintainers now, so we can
bring back that default now. KASAN_EXTRA=y still causes lots of
warnings but now defaults to !COMPILE_TEST to disable it in
allmodconfig, and it remains disabled in all other defconfigs since it
is a new option. I arbitrarily raise the warning limit for KASAN_EXTRA
to 3072 to reduce the noise, but an allmodconfig kernel still has around
50 warnings on gcc-7.
I experimented a bit more with smaller stack frames and have another
follow-up series that reduces the warning limit for 64-bit architectures
to 1280 bytes (without CONFIG_KASAN).
With earlier versions of this patch series, I also had patches to address
the warnings we get with KASAN and/or KASAN_EXTRA, using a
"noinline_if_stackbloat" annotation.
That annotation now got replaced with a gcc-8 bugfix (see
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=81715) and a workaround for
older compilers, which means that KASAN_EXTRA is now just as bad as
before and will lead to an instant stack overflow in a few extreme
cases.
This reverts parts of commit 3f181b4d8652 ("lib/Kconfig.debug: disable
-Wframe-larger-than warnings with KASAN=y"). Two patches in linux-next
should be merged first to avoid introducing warnings in an allmodconfig
build:
3cd890dbe2a4 ("media: dvb-frontends: fix i2c access helpers for KASAN")
16c3ada89cff ("media: r820t: fix r820t_write_reg for KASAN")
Do we really need to backport this?
I think we do: without this patch, enabling KASAN will lead to
unavoidable kernel stack overflow in certain device drivers when built
with gcc-7 or higher on linux-4.10+ or any version that contains a
backport of commit c5caf21ab0cf8. Most people are probably still on
older compilers, but it will get worse over time as they upgrade their
distros.
The warnings we get on kernels older than this should all be for code
that uses dangerously large stack frames, though most of them do not
cause an actual stack overflow by themselves.The asan-stack option was
added in linux-4.0, and commit 3f181b4d8652 ("lib/Kconfig.debug:
disable -Wframe-larger-than warnings with KASAN=y") effectively turned
off the warning for allmodconfig kernels, so I would like to see this
fix backported to any kernels later than 4.0.
I have done dozens of fixes for individual functions with stack frames
larger than 2048 bytes with asan-stack, and I plan to make sure that
all those fixes make it into the stable kernels as well (most are
already there).
Part of the complication here is that asan-stack (from 4.0) was
originally assumed to always require much larger stacks, but that
turned out to be a combination of multiple gcc bugs that we have now
worked around and fixed, but sanitize-address-use-after-scope (from
v4.10) has a much higher inherent stack usage and also suffers from at
least three other problems that we have analyzed but not yet fixed
upstream, each of them makes the stack usage more severe than it should
be.
Link: http://lkml.kernel.org/r/20171221134744.2295529-1-arnd@arndb.de
Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Mauro Carvalho Chehab <mchehab@kernel.org>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Andrey Konovalov <andreyknvl@google.com>
[arnd: rebase to v4.4; only re-enable warning]
[ Upstream commit 8dfd2f22d3bf3ab7714f7495ad5d897b8845e8c1 ]
Callers of sprint_oid() do not check its return value before printing
the result. In the case where the OID is zero-length, -EBADMSG was
being returned without anything being written to the buffer, resulting
in uninitialized stack memory being printed. Fix this by writing
"(bad)" to the buffer in the cases where -EBADMSG is returned.
Fixes: 4f73175d0375 ("X.509: Add utility functions to render OIDs as strings")
[ upstream commit 290af86629b25ffd1ed6232c4e9107da031705cb ]
The BPF interpreter has been used as part of the spectre 2 attack CVE-2017-5715.
A quote from goolge project zero blog:
"At this point, it would normally be necessary to locate gadgets in
the host kernel code that can be used to actually leak data by reading
from an attacker-controlled location, shifting and masking the result
appropriately and then using the result of that as offset to an
attacker-controlled address for a load. But piecing gadgets together
and figuring out which ones work in a speculation context seems annoying.
So instead, we decided to use the eBPF interpreter, which is built into
the host kernel - while there is no legitimate way to invoke it from inside
a VM, the presence of the code in the host kernel's text section is sufficient
to make it usable for the attack, just like with ordinary ROP gadgets."
To make attacker job harder introduce BPF_JIT_ALWAYS_ON config
option that removes interpreter from the kernel in favor of JIT-only mode.
So far eBPF JIT is supported by:
x64, arm64, arm32, sparc64, s390, powerpc64, mips64
The start of JITed program is randomized and code page is marked as read-only.
In addition "constant blinding" can be turned on with net.core.bpf_jit_harden
v2->v3:
- move __bpf_prog_ret0 under ifdef (Daniel)
v1->v2:
- fix init order, test_bpf and cBPF (Daniel's feedback)
- fix offloaded bpf (Jakub's feedback)
- add 'return 0' dummy in case something can invoke prog->bpf_func
- retarget bpf tree. For bpf-next the patch would need one extra hunk.
It will be sent when the trees are merged back to net-next
Considered doing:
int bpf_jit_enable __read_mostly = BPF_EBPF_JIT_DEFAULT;
but it seems better to land the patch as-is and in bpf-next remove
bpf_jit_enable global variable from all JITs, consolidate in one place
and remove this jit_init() function.
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
instead of 0
[ Upstream commit 1f3c790bd5989fcfec9e53ad8fa09f5b740c958f ]
line-range is supposed to treat "1-" as "1-endoffile", so
handle the special case by setting last_lineno to UINT_MAX.
Fixes this error:
dynamic_debug:ddebug_parse_query: last-line:0 < 1st-line:1
dynamic_debug:ddebug_exec_query: query parse failed
Link: http://lkml.kernel.org/r/10a6a101-e2be-209f-1f41-54637824788e@infradead.org
Acked-by: Jason Baron <jbaron@akamai.com>
[ Upstream commit 36a3d1dd4e16bcd0d2ddfb4a2ec7092f0ae0d931 ]
If the amount of resources allocated to a gen_pool exceeds 2^32 then the
avail atomic overflows and this causes problems when clients try and
borrow resources from the pool. This is only expected to be an issue on
64 bit systems.
Add the <linux/atomic.h> header to pull in atomic_long* operations. So
that 32 bit systems continue to use atomic32_t but 64 bit systems can
use atomic64_t.
Link: http://lkml.kernel.org/r/1509033843-25667-1-git-send-email-sbates@raithlin.com
Signed-off-by: Stephen Bates <sbates@raithlin.com>
Reviewed-by: Logan Gunthorpe <logang@deltatee.com>
Reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Reviewed-by: Daniel Mentz <danielmentz@google.com>
Cc: Jonathan Corbet <corbet@lwn.net>
commit 81a7be2cd69b412ab6aeacfe5ebf1bb6e5bce955 upstream.
asn1_ber_decoder() was ignoring errors from actions associated with the
opcodes ASN1_OP_END_SEQ_ACT, ASN1_OP_END_SET_ACT,
ASN1_OP_END_SEQ_OF_ACT, and ASN1_OP_END_SET_OF_ACT. In practice, this
meant the pkcs7_note_signed_info() action (since that was the only user
of those opcodes). Fix it by checking for the error, just like the
decoder does for actions associated with the other opcodes.
This bug allowed users to leak slab memory by repeatedly trying to add a
specially crafted "pkcs7_test" key (requires CONFIG_PKCS7_TEST_KEY).
In theory, this bug could also be used to bypass module signature
verification, by providing a PKCS#7 message that is misparsed such that
a signature's ->authattrs do not contain its ->msgdigest. But it
doesn't seem practical in normal cases, due to restrictions on the
format of the ->authattrs.
Fixes: 42d5ec27f873 ("X.509: Add an ASN.1 decoder")
Reviewed-by: James Morris <james.l.morris@oracle.com>
commit e0058f3a874ebb48b25be7ff79bc3b4e59929f90 upstream.
In asn1_ber_decoder(), indefinitely-sized ASN.1 items were being passed
to the action functions before their lengths had been computed, using
the bogus length of 0x80 (ASN1_INDEFINITE_LENGTH). This resulted in
reading data past the end of the input buffer, when given a specially
crafted message.
Fix it by rearranging the code so that the indefinite length is resolved
before the action is called.
This bug was originally found by fuzzing the X.509 parser in userspace
using libFuzzer from the LLVM project.
KASAN report (cleaned up slightly):
BUG: KASAN: slab-out-of-bounds in memcpy ./include/linux/string.h:341 [inline]
BUG: KASAN: slab-out-of-bounds in x509_fabricate_name.constprop.1+0x1a4/0x940 crypto/asymmetric_keys/x509_cert_parser.c:366
Read of size 128 at addr ffff880035dd9eaf by task keyctl/195
CPU: 1 PID: 195 Comm: keyctl Not tainted 4.14.0-09238-g1d3b78bbc6e9 #26
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.11.0-20171110_100015-anatol 04/01/2014
Call Trace:
__dump_stack lib/dump_stack.c:17 [inline]
dump_stack+0xd1/0x175 lib/dump_stack.c:53
print_address_description+0x78/0x260 mm/kasan/report.c:252
kasan_report_error mm/kasan/report.c:351 [inline]
kasan_report+0x23f/0x350 mm/kasan/report.c:409
memcpy+0x1f/0x50 mm/kasan/kasan.c:302
asn1_ber_decoder+0xb4a/0x1fd0 lib/asn1_decoder.c:447
x509_cert_parse+0x1c7/0x620 crypto/asymmetric_keys/x509_cert_parser.c:89
x509_key_preparse+0x61/0x750 crypto/asymmetric_keys/x509_public_key.c:174
asymmetric_key_preparse+0xa4/0x150 crypto/asymmetric_keys/asymmetric_type.c:388
key_create_or_update+0x4d4/0x10a0 security/keys/key.c:850
SYSC_add_key security/keys/keyctl.c:122 [inline]
SyS_add_key+0xe8/0x290 security/keys/keyctl.c:62
entry_SYSCALL_64_fastpath+0x1f/0x96
Allocated by task 195:
__do_kmalloc_node mm/slab.c:3675 [inline]
__kmalloc_node+0x47/0x60 mm/slab.c:3682
kvmalloc ./include/linux/mm.h:540 [inline]
SYSC_add_key security/keys/keyctl.c:104 [inline]
SyS_add_key+0x19e/0x290 security/keys/keyctl.c:62
Reported-by: Alexander Potapenko <glider@google.com>
commit 1d9ddde12e3c9bab7f3d3484eb9446315e3571ca upstream.
On a non-preemptible kernel, if KEYCTL_DH_COMPUTE is called with the
largest permitted inputs (16384 bits), the kernel spends 10+ seconds
doing modular exponentiation in mpi_powm() without rescheduling. If all
threads do it, it locks up the system. Moreover, it can cause
rcu_sched-stall warnings.
Notwithstanding the insanity of doing this calculation in kernel mode
rather than in userspace, fix it by calling cond_resched() as each bit
from the exponent is processed. It's still noninterruptible, but at
least it's preemptible now.
Do the cond_resched() once per bit rather than once per MPI limb because
each limb might still easily take 100+ milliseconds on slow CPUs.
commit 47e0bbb7fa985a0f1b5794a8653fae4f8f49de77 upstream.
request_firmware() failures currently won't get reported at all (the
error code is discarded). What's more, we get confusing messages, like:
# echo -n notafile > /sys/devices/virtual/misc/test_firmware/trigger_request
[ 8280.311856] test_firmware: loading 'notafile'
[ 8280.317042] test_firmware: load of 'notafile' failed: -2
[ 8280.322445] test_firmware: loaded: 0
# echo $?
0
Report the failures via write() errors, and don't say we "loaded"
anything.
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
commit 624f5ab8720b3371367327a822c267699c1823b8 upstream.
syzkaller reported a NULL pointer dereference in asn1_ber_decoder(). It
can be reproduced by the following command, assuming
CONFIG_PKCS7_TEST_KEY=y:
keyctl add pkcs7_test desc '' @s
The bug is that if the data buffer is empty, an integer underflow occurs
in the following check:
if (unlikely(dp >= datalen - 1))
goto data_overrun_error;
This results in the NULL data pointer being dereferenced.
Fix it by checking for 'datalen - dp < 2' instead.
Also fix the similar check for 'dp >= datalen - n' later in the same
function. That one possibly could result in a buffer overread.
The NULL pointer dereference was reproducible using the "pkcs7_test" key
type but not the "asymmetric" key type because the "asymmetric" key type
checks for a 0-length payload before calling into the ASN.1 decoder but
the "pkcs7_test" key type does not.
The bug report was:
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: asn1_ber_decoder+0x17f/0xe60 lib/asn1_decoder.c:233
PGD 7b708067 P4D 7b708067 PUD 7b6ee067 PMD 0
Oops: 0000 [#1] SMP
Modules linked in:
CPU: 0 PID: 522 Comm: syz-executor1 Not tainted 4.14.0-rc8 #7
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.3-20171021_125229-anatol 04/01/2014
task: ffff9b6b3798c040 task.stack: ffff9b6b37970000
RIP: 0010:asn1_ber_decoder+0x17f/0xe60 lib/asn1_decoder.c:233
RSP: 0018:ffff9b6b37973c78 EFLAGS: 00010216
RAX: 0000000000000000 RBX: 0000000000000000 RCX: 000000000000021c
RDX: ffffffff814a04ed RSI: ffffb1524066e000 RDI: ffffffff910759e0
RBP: ffff9b6b37973d60 R08: 0000000000000001 R09: ffff9b6b3caa4180
R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000002
R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
FS: 00007f10ed1f2700(0000) GS:ffff9b6b3ea00000(0000) knlGS:0000000000000000
CR2: 0000000000000000 CR3: 000000007b6f3000 CR4: 00000000000006f0
Call Trace:
pkcs7_parse_message+0xee/0x240 crypto/asymmetric_keys/pkcs7_parser.c:139
verify_pkcs7_signature+0x33/0x180 certs/system_keyring.c:216
pkcs7_preparse+0x41/0x70 crypto/asymmetric_keys/pkcs7_key_type.c:63
key_create_or_update+0x180/0x530 security/keys/key.c:855
SyS_add_key+0xbf/0x250 security/keys/keyctl.c:62
entry_SYSCALL_64_fastpath+0x1f/0xbe
RIP: 0033:0x4585c9
RSP: 002b:00007f10ed1f1bd8 EFLAGS: 00000216 ORIG_RAX: 00000000000000f8
RAX: ffffffffffffffda RBX: 00007f10ed1f2700 RCX: 00000000004585c9
RDX: 0000000020000000 RSI: 0000000020008ffb RDI: 0000000020008000
RBP: 0000000000000000 R08: ffffffffffffffff R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000216 R12: 00007fff1b2260ae
R13: 00007fff1b2260af R14: 00007f10ed1f2700 R15: 0000000000000000
Code: dd ca ff 48 8b 45 88 48 83 e8 01 4c 39 f0 0f 86 a8 07 00 00 e8 53 dd ca ff 49 8d 46 01 48 89 85 58 ff ff ff 48 8b 85 60 ff ff ff <42> 0f b6 0c 30 89 c8 88 8d 75 ff ff ff 83 e0 1f 89 8d 28 ff ff
RIP: asn1_ber_decoder+0x17f/0xe60 lib/asn1_decoder.c:233 RSP: ffff9b6b37973c78
Reported-by: syzbot <syzkaller@googlegroups.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
commit 2eb9eabf1e868fda15808954fb29b0f105ed65f1 upstream.
syzkaller with KASAN reported an out-of-bounds read in
asn1_ber_decoder(). It can be reproduced by the following command,
assuming CONFIG_X509_CERTIFICATE_PARSER=y and CONFIG_KASAN=y:
keyctl add asymmetric desc $'\x30\x30' @s
The bug is that the length of an ASN.1 data value isn't validated in the
case where it is encoded using the short form, causing the decoder to
read past the end of the input buffer. Fix it by validating the length.
The bug report was:
BUG: KASAN: slab-out-of-bounds in asn1_ber_decoder+0x10cb/0x1730 lib/asn1_decoder.c:233
Read of size 1 at addr ffff88003cccfa02 by task syz-executor0/6818
CPU: 1 PID: 6818 Comm: syz-executor0 Not tainted 4.14.0-rc7-00008-g5f479447d983 #2
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:16 [inline]
dump_stack+0xb3/0x10b lib/dump_stack.c:52
print_address_description+0x79/0x2a0 mm/kasan/report.c:252
kasan_report+0x236/0x340 mm/kasan/report.c:409
__asan_report_load1_noabort+0x14/0x20 mm/kasan/report.c:427
x509_cert_parse+0x1db/0x650 crypto/asymmetric_keys/x509_cert_parser.c:89
x509_key_preparse+0x64/0x7a0 crypto/asymmetric_keys/x509_public_key.c:174
asymmetric_key_preparse+0xcb/0x1a0 crypto/asymmetric_keys/asymmetric_type.c:388
key_create_or_update+0x347/0xb20 security/keys/key.c:855
SyS_add_key+0x1cd/0x340 security/keys/keyctl.c:62
RIP: 0033:0x447c89
RSP: 002b:00007fca7a5d3bd8 EFLAGS: 00000246 ORIG_RAX: 00000000000000f8
RAX: ffffffffffffffda RBX: 00007fca7a5d46cc RCX: 0000000000447c89
RDX: 0000000020006f4a RSI: 0000000020006000 RDI: 0000000020001ff5
RBP: 0000000000000046 R08: fffffffffffffffd R09: 0000000000000000
R10: 0000000000000002 R11: 0000000000000246 R12: 0000000000000000
R13: 0000000000000000 R14: 00007fca7a5d49c0 R15: 00007fca7a5d4700
commit ea6789980fdaa610d7eb63602c746bf6ec70cd2b upstream.
This fixes CVE-2017-12193.
Fix a case in the assoc_array implementation in which a new leaf is
added that needs to go into a node that happens to be full, where the
existing leaves in that node cluster together at that level to the
exclusion of new leaf.
What needs to happen is that the existing leaves get moved out to a new
node, N1, at level + 1 and the existing node needs replacing with one,
N0, that has pointers to the new leaf and to N1.
The code that tries to do this gets this wrong in two ways:
(1) The pointer that should've pointed from N0 to N1 is set to point
recursively to N0 instead.
(2) The backpointer from N0 needs to be set correctly in the case N0 is
either the root node or reached through a shortcut.
Fix this by removing this path and using the split_node path instead,
which achieves the same end, but in a more general way (thanks to Eric
Biggers for spotting the redundancy).
The problem manifests itself as:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000010
IP: assoc_array_apply_edit+0x59/0xe5
Fixes: 3cb989501c26 ("Add a generic associative array implementation.")
Reported-and-tested-by: WU Fan <u3536072@connect.hku.hk>
commit 192cabd6a296cbc57b3d8c05c4c89d87fc102506 upstream.
digsig_verify() requests a user key, then accesses its payload.
However, a revoked key has a NULL payload, and we failed to check for
this. request_key() *does* skip revoked keys, but there is still a
window where the key can be revoked before we acquire its semaphore.
Fix it by checking for a NULL payload, treating it like a key which was
already revoked at the time it was requested.
Fixes: 051dbb918c7f ("crypto: digital signature verification support")
Cc: Dmitry Kasatkin <dmitry.kasatkin@intel.com>
[ Upstream commit da0510c47519fe0999cffe316e1d370e29f952be ]
The build of frv allmodconfig was failing with the errors like:
/tmp/cc0JSPc3.s: Assembler messages:
/tmp/cc0JSPc3.s:1839: Error: symbol `.LSLT0' is already defined
/tmp/cc0JSPc3.s:1842: Error: symbol `.LASLTP0' is already defined
/tmp/cc0JSPc3.s:1969: Error: symbol `.LELTP0' is already defined
/tmp/cc0JSPc3.s:1970: Error: symbol `.LELT0' is already defined
Commit 866ced950bcd ("kbuild: Support split debug info v4") introduced
splitting the debug info and keeping that in a separate file. Somehow,
the frv-linux gcc did not like that and I am guessing that instead of
splitting it started copying. The first report about this is at:
https://lists.01.org/pipermail/kbuild-all/2015-July/010527.html.
I will try and see if this can work with frv and if still fails I will
open a bug report with gcc. But meanwhile this is the easiest option to
solve build failure of frv.
Fixes: 866ced950bcd ("kbuild: Support split debug info v4")
Link: http://lkml.kernel.org/r/1482062348-5352-1-git-send-email-sudipm.mukherjee@gmail.com
Signed-off-by: Sudip Mukherjee <sudip.mukherjee@codethink.co.uk>
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
[ Upstream commit 602d9858f07c72eab64f5f00e2fae55f9902cfbe ]
Some drivers do depend on page mappings to be page aligned.
Swiotlb already enforces such alignment for mappings greater than page,
extend that to page-sized mappings as well.
Without this fix, nvme hits BUG() in nvme_setup_prps(), because that routine
assumes page-aligned mappings.
Signed-off-by: Nikita Yushchenko <nikita.yoush@cogentembedded.com>
Reviewed-by: Sagi Grimberg <sagi@grimberg.me>
Signed-off-by: Konrad Rzeszutek Wilk <konrad@kernel.org>
commit a91e0f680bcd9e10c253ae8b62462a38bd48f09f upstream.
When using get_options() it's possible to specify a range of numbers,
like 1-100500. The problem is that it doesn't track array size while
calling internally to get_range() which iterates over the range and
fills the memory with numbers.
Link: http://lkml.kernel.org/r/2613C75C-B04D-4BFF-82A6-12F97BA0F620@gmail.com
Signed-off-by: Ilya V. Matveychikov <matvejchikov@gmail.com>
commit f5f893c57e37ca730808cb2eee3820abd05e7507 upstream.
Under SMAP/PAN/etc, we cannot write directly to userspace memory, so
this rearranges the test bytes to get written through copy_to_user().
Additionally drops the bad copy_from_user() test that would trigger a
memcpy() against userspace on failure.
[arnd: the test module was added in 3.14, and this backported patch
should apply cleanly on all version from 3.14 to 4.10.
The original patch was in 4.11 on top of a context change
I saw the bug triggered with kselftest on a 4.4.y stable kernel]
[ Upstream commit ddc665a4bb4b728b4e6ecec8db1b64efa9184b9c ]
When the instruction right before the branch destination is
a 64 bit load immediate, we currently calculate the wrong
jump offset in the ctx->offset[] array as we only account
one instruction slot for the 64 bit load immediate although
it uses two BPF instructions. Fix it up by setting the offset
into the right slot after we incremented the index.
Before (ldimm64 test 1):
00000020: 52800007 mov w7, #0x0 // #0
00000024: d2800060 mov x0, #0x3 // #3
00000028: d2800041 mov x1, #0x2 // #2
0000002c: eb01001f cmp x0, x1
00000030: 54ffff82 b.cs 0x00000020
00000034: d29fffe7 mov x7, #0xffff // #65535
00000038: f2bfffe7 movk x7, #0xffff, lsl #16
0000003c: f2dfffe7 movk x7, #0xffff, lsl #32
00000040: f2ffffe7 movk x7, #0xffff, lsl #48
00000044: d29dddc7 mov x7, #0xeeee // #61166
00000048: f2bdddc7 movk x7, #0xeeee, lsl #16
0000004c: f2ddddc7 movk x7, #0xeeee, lsl #32
00000050: f2fdddc7 movk x7, #0xeeee, lsl #48
After (ldimm64 test 1):
00000030: 540000a2 b.cs 0x00000044
Also, add a couple of test cases to make sure JITs pass
this test. Tested on Cavium ThunderX ARMv8. The added
test cases all pass after the fix.
Fixes: 8eee539ddea0 ("arm64: bpf: fix out-of-bounds read in bpf2a64_offset()")
Reported-by: David S. Miller <davem@davemloft.net>
Acked-by: Alexei Starovoitov <ast@kernel.org>
Cc: Xi Wang <xi.wang@gmail.com>
commit f5527fffff3f002b0a6b376163613b82f69de073 upstream.
This fixes CVE-2016-8650.
If mpi_powm() is given a zero exponent, it wants to immediately return
either 1 or 0, depending on the modulus. However, if the result was
initalised with zero limb space, no limbs space is allocated and a
NULL-pointer exception ensues.
Fix this by allocating a minimal amount of limb space for the result when
the 0-exponent case when the result is 1 and not touching the limb space
when the result is 0.
This affects the use of RSA keys and X.509 certificates that carry them.
IP: [<ffffffff8138ce5d>] mpi_powm+0x32/0x7e6
PGD 0
Oops: 0002 [#1] SMP
Modules linked in:
CPU: 3 PID: 3014 Comm: keyctl Not tainted 4.9.0-rc6-fscache+ #278
Hardware name: ASUS All Series/H97-PLUS, BIOS 2306 10/09/2014
task: ffff8804011944c0 task.stack: ffff880401294000
RIP: 0010:[<ffffffff8138ce5d>] [<ffffffff8138ce5d>] mpi_powm+0x32/0x7e6
RSP: 0018:ffff880401297ad8 EFLAGS: 00010212
RAX: 0000000000000000 RBX: ffff88040868bec0 RCX: ffff88040868bba0
RDX: ffff88040868b260 RSI: ffff88040868bec0 RDI: ffff88040868bee0
RBP: ffff880401297ba8 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000047 R11: ffffffff8183b210 R12: 0000000000000000
R13: ffff8804087c7600 R14: 000000000000001f R15: ffff880401297c50
FS: 00007f7a7918c700(0000) GS:ffff88041fb80000(0000) knlGS:0000000000000000
CR2: 0000000000000000 CR3: 0000000401250000 CR4: 00000000001406e0
Stack:
ffff88040868bec0 0000000000000020 ffff880401297b00 ffffffff81376cd4
0000000000000100 ffff880401297b10 ffffffff81376d12 ffff880401297b30
ffffffff81376f37 0000000000000100 0000000000000000 ffff880401297ba8
Call Trace:
[<ffffffff81376cd4>] ? __sg_page_iter_next+0x43/0x66
[<ffffffff81376d12>] ? sg_miter_get_next_page+0x1b/0x5d
[<ffffffff81376f37>] ? sg_miter_next+0x17/0xbd
[<ffffffff8138ba3a>] ? mpi_read_raw_from_sgl+0xf2/0x146
[<ffffffff8132a95c>] rsa_verify+0x9d/0xee
[<ffffffff8132acca>] ? pkcs1pad_sg_set_buf+0x2e/0xbb
[<ffffffff8132af40>] pkcs1pad_verify+0xc0/0xe1
[<ffffffff8133cb5e>] public_key_verify_signature+0x1b0/0x228
[<ffffffff8133d974>] x509_check_for_self_signed+0xa1/0xc4
[<ffffffff8133cdde>] x509_cert_parse+0x167/0x1a1
[<ffffffff8133d609>] x509_key_preparse+0x21/0x1a1
[<ffffffff8133c3d7>] asymmetric_key_preparse+0x34/0x61
[<ffffffff812fc9f3>] key_create_or_update+0x145/0x399
[<ffffffff812fe227>] SyS_add_key+0x154/0x19e
[<ffffffff81001c2b>] do_syscall_64+0x80/0x191
[<ffffffff816825e4>] entry_SYSCALL64_slow_path+0x25/0x25
Code: 56 41 55 41 54 53 48 81 ec a8 00 00 00 44 8b 71 04 8b 42 04 4c 8b 67 18 45 85 f6 89 45 80 0f 84 b4 06 00 00 85 c0 75 2f 41 ff ce <49> c7 04 24 01 00 00 00 b0 01 75 0b 48 8b 41 18 48 83 38 01 0f
RIP [<ffffffff8138ce5d>] mpi_powm+0x32/0x7e6
RSP <ffff880401297ad8>
---[ end trace d82015255d4a5d8d ]---
Basically, this is a backport of a libgcrypt patch:
http://git.gnupg.org/cgi-bin/gitweb.cgi?p=libgcrypt.git;a=patch;h=6e1adb05d290aeeb1c230c763970695f4a538526
Fixes: cdec9cb5167a ("crypto: GnuPG based MPI lib - source files (part 1)")
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
cc: Dmitry Kasatkin <dmitry.kasatkin@gmail.com>
cc: linux-ima-devel@lists.sourceforge.net
commit 62e931fac45b17c2a42549389879411572f75804 upstream.
gen_pool_alloc_algo() iterates over the chunks of a pool trying to find
a contiguous block of memory that satisfies the allocation request.
The shortcut
if (size > atomic_read(&chunk->avail))
continue;
makes the loop skip over chunks that do not have enough bytes left to
fulfill the request. There are two situations, though, where an
allocation might still fail:
(1) The available memory is not contiguous, i.e. the request cannot
be fulfilled due to external fragmentation.
(2) A race condition. Another thread runs the same code concurrently
and is quicker to grab the available memory.
In those situations, the loop calls pool->algo() to search the entire
chunk, and pool->algo() returns some value that is >= end_bit to
indicate that the search failed. This return value is then assigned to
start_bit. The variables start_bit and end_bit describe the range that
should be searched, and this range should be reset for every chunk that
is searched. Today, the code fails to reset start_bit to 0. As a
result, prefixes of subsequent chunks are ignored. Memory allocations
might fail even though there is plenty of room left in these prefixes of
those other chunks.
Fixes: 7f184275aa30 ("lib, Make gen_pool memory allocator lockless")
Link: http://lkml.kernel.org/r/1477420604-28918-1-git-send-email-danielmentz@google.com
Signed-off-by: Daniel Mentz <danielmentz@google.com>
Acked-by: Will Deacon <will.deacon@arm.com>
commit a81a5a17d44b26521fb1199f8ccf27f4af337a67 upstream.
Add support for "on" and "off" when converting to boolean.
Cc: Amitkumar Karwar <akarwar@marvell.com>
Cc: Andy Shevchenko <andy.shevchenko@gmail.com>
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: Joe Perches <joe@perches.com>
Cc: Kalle Valo <kvalo@codeaurora.org>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Nishant Sarmukadam <nishants@marvell.com>
Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Cc: Steve French <sfrench@samba.org>
commit ef951599074ba4fad2d0efa0a977129b41e6d203 upstream.
Create the kstrtobool_from_user() helper and move strtobool() logic into
the new kstrtobool() (matching all the other kstrto* functions).
Provides an inline wrapper for existing strtobool() callers.
commit d4690f1e1cdabb4d61207b6787b1605a0dc0aeab upstream.
... by turning it into what used to be multipages counterpart
commit f2d1362ff7d266b3d2b1c764d6c2ef4a3b457f23 upstream.
Currently, if the number of leading zeros is greater than fits into a
complete limb, mpi_write_sgl() skips them by iterating over them limb-wise.
However, it fails to adjust its internal leading zeros tracking variable,
lzeros, accordingly: it does a
p -= sizeof(alimb);
continue;
which should really have been a
lzeros -= sizeof(alimb);
continue;
Since lzeros never decreases if its initial value >= sizeof(alimb), nothing
gets copied by mpi_write_sgl() in that case.
Instead of skipping the high order zero limbs within the loop as shown
above, fix the issue by adjusting the copying loop's bounds.
Fixes: 2d4d1eea540b ("lib/mpi: Add mpi sgl helpers")
Signed-off-by: Nicolai Stange <nicstange@gmail.com>
[ Upstream commit 23c8a812dc3c621009e4f0e5342aa4e2ede1ceaa ]
This fixes CVE-2016-0758.
In the ASN.1 decoder, when the length field of an ASN.1 value is extracted,
it isn't validated against the remaining amount of data before being added
to the cursor. With a sufficiently large size indicated, the check:
datalen - dp < 2
may then fail due to integer overflow.
Fix this by checking the length indicated against the amount of remaining
data in both places a definite length is determined.
Whilst we're at it, make the following changes:
(1) Check the maximum size of extended length does not exceed the capacity
of the variable it's being stored in (len) rather than the type that
variable is assumed to be (size_t).
(2) Compare the EOC tag to the symbolic constant ASN1_EOC rather than the
integer 0.
(3) To reduce confusion, move the initialisation of len outside of:
for (len = 0; n > 0; n--) {
since it doesn't have anything to do with the loop counter n.
Reviewed-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
Acked-by: David Woodhouse <David.Woodhouse@intel.com>
Acked-by: Peter Jones <pjones@redhat.com>
commit 3017cd63f26fc655d56875aaf497153ba60e9edf upstream.
With netconsole (at least) the pr_err("... disablingn") call can
recurse back into the dma-debug code, where it'll try to grab
free_entries_lock again. Avoid the problem by doing the printk after
dropping the lock.
Link: http://lkml.kernel.org/r/1463678421-18683-1-git-send-email-ville.syrjala@linux.intel.com
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
commit 72676bb53f33fd0ef3a1484fc1ecfd306dc6ff40 upstream.
Recently added commit 564b026fbd0d ("string_helpers: fix precision loss
for some inputs") fixed precision issues for string_get_size() and broke
tests.
Fix and improve them: test both STRING_UNITS_2 and STRING_UNITS_10 at a
time, better failure reporting, test small an huge values.
Fixes: 564b026fbd0d28e9 ("string_helpers: fix precision loss for some inputs")
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: James Bottomley <JBottomley@Odin.com>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
commit 3ee0cb5fb5eea2110db1b5cb7f67029b7be8a376 upstream.
The limbs are integers in the host endianness, so we can't simply
iterate over the individual bytes. The current code happens to work on
little-endian, because the order of the limbs in the MPI array is the
same as the order of the bytes in each limb, but it breaks on
big-endian.
Fixes: 0f74fbf77d45 ("MPI: Fix mpi_read_buffer")
Signed-off-by: Michal Marek <mmarek@suse.com>
commit 3e26a691fe3fe1e02a76e5bab0c143ace4b137b4 upstream.
Based on Sergey's test patch [1], this fixes zram with lz4 compression
on big endian cpus.
Note that the 64-bit preprocessor test is not a cleanup, it's part of
the fix, since those identifiers are bogus (for example, __ppc64__
isn't defined anywhere else in the kernel, which means we'd fall into
the 32-bit definitions on ppc64).
Tested on ppc64 with no regression on x86_64.
[1] http://marc.info/?l=linux-kernel&m=145994470805853&w=4
Suggested-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Signed-off-by: Rui Salvaterra <rsalvaterra@gmail.com>
Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
commit 8d4a2ec1e0b41b0cf9a0c5cd4511da7f8e4f3de2 upstream.
Changes since V1: fixed the description and added KASan warning.
In assoc_array_insert_into_terminal_node(), we call the
compare_object() method on all non-empty slots, even when they're
not leaves, passing a pointer to an unexpected structure to
compare_object(). Currently it causes an out-of-bound read access
in keyring_compare_object detected by KASan (see below). The issue
is easily reproduced with keyutils testsuite.
Only call compare_object() when the slot is a leave.
KASan warning:
BUG: KASAN: slab-out-of-bounds in keyring_compare_object+0x213/0x240 at addr ffff880060a6f838
Read of size 8 by task keyctl/1655
BUG kmalloc-192 (Not tainted): kasan: bad access detected
Disabling lock debugging due to kernel taint
INFO: Allocated in assoc_array_insert+0xfd0/0x3a60 age=69 cpu=1 pid=1647
___slab_alloc+0x563/0x5c0
__slab_alloc+0x51/0x90
kmem_cache_alloc_trace+0x263/0x300
__key_link_begin+0xfc/0x270
key_create_or_update+0x459/0xaf0
SyS_add_key+0x1ba/0x350
entry_SYSCALL_64_fastpath+0x12/0x76
INFO: Slab 0xffffea0001829b80 objects=16 used=8 fp=0xffff880060a6f550 flags=0x3fff8000004080
INFO: Object 0xffff880060a6f740 @offset=5952 fp=0xffff880060a6e5d1
Bytes b4 ffff880060a6f730: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Object ffff880060a6f740: d1 e5 a6 60 00 88 ff ff 0e 00 00 00 00 00 00 00 ...`............
Object ffff880060a6f750: 02 cf 8e 60 00 88 ff ff 02 c0 8e 60 00 88 ff ff ...`.......`....
Object ffff880060a6f760: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Object ffff880060a6f770: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Object ffff880060a6f780: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Object ffff880060a6f790: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Object ffff880060a6f7a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Object ffff880060a6f7b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Object ffff880060a6f7c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Object ffff880060a6f7d0: 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Object ffff880060a6f7e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Object ffff880060a6f7f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
CPU: 0 PID: 1655 Comm: keyctl Tainted: G B 4.5.0-rc4-kasan+ #291
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
0000000000000000 000000001b2800b4 ffff880060a179e0 ffffffff81b60491
ffff88006c802900 ffff880060a6f740 ffff880060a17a10 ffffffff815e2969
ffff88006c802900 ffffea0001829b80 ffff880060a6f740 ffff880060a6e650
Call Trace:
[<ffffffff81b60491>] dump_stack+0x85/0xc4
[<ffffffff815e2969>] print_trailer+0xf9/0x150
[<ffffffff815e9454>] object_err+0x34/0x40
[<ffffffff815ebe50>] kasan_report_error+0x230/0x550
[<ffffffff819949be>] ? keyring_get_key_chunk+0x13e/0x210
[<ffffffff815ec62d>] __asan_report_load_n_noabort+0x5d/0x70
[<ffffffff81994cc3>] ? keyring_compare_object+0x213/0x240
[<ffffffff81994cc3>] keyring_compare_object+0x213/0x240
[<ffffffff81bc238c>] assoc_array_insert+0x86c/0x3a60
[<ffffffff81bc1b20>] ? assoc_array_cancel_edit+0x70/0x70
[<ffffffff8199797d>] ? __key_link_begin+0x20d/0x270
[<ffffffff8199786c>] __key_link_begin+0xfc/0x270
[<ffffffff81993389>] key_create_or_update+0x459/0xaf0
[<ffffffff8128ce0d>] ? trace_hardirqs_on+0xd/0x10
[<ffffffff81992f30>] ? key_type_lookup+0xc0/0xc0
[<ffffffff8199e19d>] ? lookup_user_key+0x13d/0xcd0
[<ffffffff81534763>] ? memdup_user+0x53/0x80
[<ffffffff819983ea>] SyS_add_key+0x1ba/0x350
[<ffffffff81998230>] ? key_get_type_from_user.constprop.6+0xa0/0xa0
[<ffffffff828bcf4e>] ? retint_user+0x18/0x23
[<ffffffff8128cc7e>] ? trace_hardirqs_on_caller+0x3fe/0x580
[<ffffffff81004017>] ? trace_hardirqs_on_thunk+0x17/0x19
[<ffffffff828bc432>] entry_SYSCALL_64_fastpath+0x12/0x76
Memory state around the buggy address:
ffff880060a6f700: fc fc fc fc fc fc fc fc 00 00 00 00 00 00 00 00
ffff880060a6f780: 00 00 00 00 00 00 00 00 00 00 00 fc fc fc fc fc
>ffff880060a6f800: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffff880060a6f880: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffff880060a6f900: fc fc fc fc fc fc 00 00 00 00 00 00 00 00 00 00
Signed-off-by: Jerome Marchand <jmarchan@redhat.com>
commit 5b57167749274961baf15ed1f05a4996b3ab0487 upstream.
The sw842 library code was merged in linux-4.1 and causes a very rare randconfig
failure when CONFIG_CRC32 is not set:
lib/built-in.o: In function `sw842_compress':
oid_registry.c:(.text+0x12ddc): undefined reference to `crc32_be'
lib/built-in.o: In function `sw842_decompress':
oid_registry.c:(.text+0x137e4): undefined reference to `crc32_be'
This adds an explict 'select CRC32' statement, similar to what the other users
of the crc32 code have. In practice, CRC32 is always enabled anyway because
over 100 other symbols select it.
Fixes: 2da572c959dd ("lib: add software 842 compression/decompression")
Acked-by: Dan Streetman <ddstreet@ieee.org>
commit a68075908a37850918ad96b056acc9ac4ce1bd90 upstream.
The comparisons should be >= since 0x800 and 0x80 require an additional bit
to store.
For the 3 byte case, the existing shift would drop off 2 more bits than
intended.
For the 2 byte case, there should be 5 bits bits in byte 1, and 6 bits in
byte 2.
Signed-off-by: Jason Andryuk <jandryuk@gmail.com>
Reviewed-by: Laszlo Ersek <lersek@redhat.com>
Cc: Peter Jones <pjones@redhat.com>
Cc: Matthew Garrett <mjg59@coreos.com>
Cc: "Lee, Chun-Yi" <jlee@suse.com>
Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk>
commit 73500267c930baadadb0d02284909731baf151f7 upstream.
This adds ucs2_utf8size(), which tells us how big our ucs2 string is in
bytes, and ucs2_as_utf8, which translates from ucs2 to utf8..
Signed-off-by: Peter Jones <pjones@redhat.com>
Tested-by: Lee, Chun-Yi <jlee@suse.com>
Acked-by: Matthew Garrett <mjg59@coreos.com>
commit d7ce36924344ace0dbdc855b1206cacc46b36d45 upstream.
Some servers experienced fatal deadlocks because of a combination of
bugs, leading to multiple cpus calling dump_stack().
The checksumming bug was fixed in commit 34ae6a1aa054 ("ipv6: update
skb->csum when CE mark is propagated").
The second problem is a faulty locking in dump_stack()
CPU1 runs in process context and calls dump_stack(), grabs dump_lock.
CPU2 receives a TCP packet under softirq, grabs socket spinlock, and
call dump_stack() from netdev_rx_csum_fault().
dump_stack() spins on atomic_cmpxchg(&dump_lock, -1, 2), since
dump_lock is owned by CPU1
While dumping its stack, CPU1 is interrupted by a softirq, and happens
to process a packet for the TCP socket locked by CPU2.
CPU1 spins forever in spin_lock() : deadlock
Stack trace on CPU1 looked like :
NMI backtrace for cpu 1
RIP: _raw_spin_lock+0x25/0x30
Call Trace:
<IRQ>
tcp_v6_rcv+0x243/0x620
ip6_input_finish+0x11f/0x330
ip6_input+0x38/0x40
ip6_rcv_finish+0x3c/0x90
ipv6_rcv+0x2a9/0x500
process_backlog+0x461/0xaa0
net_rx_action+0x147/0x430
__do_softirq+0x167/0x2d0
call_softirq+0x1c/0x30
do_softirq+0x3f/0x80
irq_exit+0x6e/0xc0
smp_call_function_single_interrupt+0x35/0x40
call_function_single_interrupt+0x6a/0x70
<EOI>
printk+0x4d/0x4f
printk_address+0x31/0x33
print_trace_address+0x33/0x3c
print_context_stack+0x7f/0x119
dump_trace+0x26b/0x28e
show_trace_log_lvl+0x4f/0x5c
show_stack_log_lvl+0x104/0x113
show_stack+0x42/0x44
dump_stack+0x46/0x58
netdev_rx_csum_fault+0x38/0x3c
__skb_checksum_complete_head+0x6e/0x80
__skb_checksum_complete+0x11/0x20
tcp_rcv_established+0x2bd5/0x2fd0
tcp_v6_do_rcv+0x13c/0x620
sk_backlog_rcv+0x15/0x30
release_sock+0xd2/0x150
tcp_recvmsg+0x1c1/0xfc0
inet_recvmsg+0x7d/0x90
sock_recvmsg+0xaf/0xe0
___sys_recvmsg+0x111/0x3b0
SyS_recvmsg+0x5c/0xb0
system_call_fastpath+0x16/0x1b
Fixes: b58d977432c8 ("dump_stack: serialize the output from dump_stack()")
Cc: Alex Thorlton <athorlton@sgi.com>
commit 46437f9a554fbe3e110580ca08ab703b59f2f95a upstream.
If the indirect_ptr bit is set on a slot, that indicates we need to redo
the lookup. Introduce a new function radix_tree_iter_retry() which
forces the loop to retry the lookup by setting 'slot' to NULL and
turning the iterator back to point at the problematic entry.
This is a pretty rare problem to hit at the moment; the lookup has to
race with a grow of the radix tree from a height of 0. The consequences
of hitting this race are that gang lookup could return a pointer to a
radix_tree_node instead of a pointer to whatever the user had inserted
in the tree.
Fixes: cebbd29e1c2f ("radix-tree: rewrite gang lookup using iterator")
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
Cc: Ohad Ben-Cohen <ohad@wizery.com>
Cc: Konstantin Khlebnikov <khlebnikov@openvz.org>
commit ea535e418c01837d07b6c94e817540f50bfdadb0 upstream.
In include/asm-generic/sections.h:
* Usage guidelines:
* _text, _data: architecture specific, don't use them in
* arch-independent code
* [_stext, _etext]: contains .text.* sections, may also contain
* .rodata.*
* and/or .init.* sections
_text is not guaranteed across architectures. Architectures such as ARM
may reuse parts which are not actually text and erroneously trigger a bug.
Switch to using _stext which is guaranteed to contain text sections.
Came out of https://lkml.kernel.org/g/<567B1176.4000106@redhat.com>
Signed-off-by: Laura Abbott <labbott@fedoraproject.org>
commit 564b026fbd0d28e9f70fb3831293d2922bb7855b upstream.
It was noticed that we lose precision in the final calculation for some
inputs. The most egregious example is size=3000 blk_size=1900 in units
of 10 should yield 5.70 MB but in fact yields 3.00 MB (oops).
This is because the current algorithm doesn't correctly account for
all the remainders in the logarithms. Fix this by doing a correct
calculation in the remainders based on napier's algorithm.
Additionally, now we have the correct result, we have to account for
arithmetic rounding because we're printing 3 digits of precision. This
means that if the fourth digit is five or greater, we have to round up,
so add a section to ensure correct rounding. Finally account for all
possible inputs correctly, including zero for block size.
Fixes: b9f28d863594c429e1df35a0474d2663ca28b307
Signed-off-by: James Bottomley <JBottomley@Odin.com>
Reported-by: Vitaly Kuznetsov <vkuznets@redhat.com>
commit 00cd29b799e3449f0c68b1cc77cd4a5f95b42d17 upstream.
The starting node for a klist iteration is often passed in from
somewhere way above the klist infrastructure, meaning there's no
guarantee the node is still on the list. We've seen this in SCSI where
we use bus_find_device() to iterate through a list of devices. In the
face of heavy hotplug activity, the last device returned by
bus_find_device() can be removed before the next call. This leads to
Dec 3 13:22:02 localhost kernel: WARNING: CPU: 2 PID: 28073 at include/linux/kref.h:47 klist_iter_init_node+0x3d/0x50()
Dec 3 13:22:02 localhost kernel: Modules linked in: scsi_debug x86_pkg_temp_thermal kvm_intel kvm irqbypass crc32c_intel joydev iTCO_wdt dcdbas ipmi_devintf acpi_power_meter iTCO_vendor_support ipmi_si imsghandler pcspkr wmi acpi_cpufreq tpm_tis tpm shpchp lpc_ich mfd_core nfsd nfs_acl lockd grace sunrpc tg3 ptp pps_core
Dec 3 13:22:02 localhost kernel: CPU: 2 PID: 28073 Comm: cat Not tainted 4.4.0-rc1+ #2
Dec 3 13:22:02 localhost kernel: Hardware name: Dell Inc. PowerEdge R320/08VT7V, BIOS 2.0.22 11/19/2013
Dec 3 13:22:02 localhost kernel: ffffffff81a20e77 ffff880613acfd18 ffffffff81321eef 0000000000000000
Dec 3 13:22:02 localhost kernel: ffff880613acfd50 ffffffff8107ca52 ffff88061176b198 0000000000000000
Dec 3 13:22:02 localhost kernel: ffffffff814542b0 ffff880610cfb100 ffff88061176b198 ffff880613acfd60
Dec 3 13:22:02 localhost kernel: Call Trace:
Dec 3 13:22:02 localhost kernel: [<ffffffff81321eef>] dump_stack+0x44/0x55
Dec 3 13:22:02 localhost kernel: [<ffffffff8107ca52>] warn_slowpath_common+0x82/0xc0
Dec 3 13:22:02 localhost kernel: [<ffffffff814542b0>] ? proc_scsi_show+0x20/0x20
Dec 3 13:22:02 localhost kernel: [<ffffffff8107cb4a>] warn_slowpath_null+0x1a/0x20
Dec 3 13:22:02 localhost kernel: [<ffffffff8167225d>] klist_iter_init_node+0x3d/0x50
Dec 3 13:22:02 localhost kernel: [<ffffffff81421d41>] bus_find_device+0x51/0xb0
Dec 3 13:22:02 localhost kernel: [<ffffffff814545ad>] scsi_seq_next+0x2d/0x40
And an eventual crash. It can actually occur in any hotplug system
which has a device finder and a starting device.
We can fix this globally by making sure the starting node for
klist_iter_init_node() is actually a member of the list before using it
(and by starting from the beginning if it isn't).
Reported-by: Ewan D. Milne <emilne@redhat.com>
Tested-by: Ewan D. Milne <emilne@redhat.com>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
commit fd7f6727102a1ccf6b4c1dfcc631f9b546526b26 upstream.
I don't think it makes sense for a module to have a soft dependency
on itself. This seems quite cyclic by nature and I can't see what
purpose it could serve.
OTOH libcrc32c calls crypto_alloc_shash("crc32c", 0, 0) so it pretty
much assumes that some incarnation of the "crc32c" hash algorithm has
been loaded. Therefore it makes sense to have the soft dependency
there (as crc-t10dif does.)
Cc: Tim Chen <tim.c.chen@linux.intel.com>
Signed-off-by: Jean Delvare <jdelvare@suse.de>
The commit c6ff5268293ef98e48a99597e765ffc417e39fa5 ("rhashtable:
Fix walker list corruption") causes a suspicious RCU usage warning
because we no longer hold ht->mutex when we dereference ht->tbl.
However, this is a false positive because we now hold ht->lock
which also guarantees that ht->tbl won't disppear from under us.
This patch kills the warning by using rcu_dereference_protected.
Reported-by: kernel test robot <ying.huang@linux.intel.com>
Pull networking fixes from David Miller:
1) Fix uninitialized variable warnings in nfnetlink_queue, a lot of
people reported this... From Arnd Bergmann.
2) Don't init mutex twice in i40e driver, from Jesse Brandeburg.
3) Fix spurious EBUSY in rhashtable, from Herbert Xu.
4) Missing DMA unmaps in mvpp2 driver, from Marcin Wojtas.
5) Fix race with work structure access in pppoe driver causing
corruptions, from Guillaume Nault.
6) Fix OOPS due to sh_eth_rx() not checking whether netdev_alloc_skb()
actually succeeded or not, from Sergei Shtylyov.
7) Don't lose flags when settifn IFA_F_OPTIMISTIC in ipv6 code, from
Bjørn Mork.
8) VXLAN_HD_RCO defined incorrectly, fix from Jiri Benc.
9) Fix clock source used for cookies in SCTP, from Marcelo Ricardo
Leitner.
10) aurora driver needs HAS_DMA dependency, from Geert Uytterhoeven.
11) ndo_fill_metadata_dst op of vxlan has to handle ipv6 tunneling
properly as well, from Jiri Benc.
12) Handle request sockets properly in xfrm layer, from Eric Dumazet.
13) Double stats update in ipv6 geneve transmit path, fix from Pravin B
Shelar.
14) sk->sk_policy[] needs RCU protection, and as a result
xfrm_policy_destroy() needs to free policies using an RCU grace
period, from Eric Dumazet.
15) SCTP needs to clone ipv6 tx options in order to avoid use after
free, from Eric Dumazet.
16) Missing kbuild export if ila.h, from Stephen Hemminger.
17) Missing mdiobus_alloc() return value checking in mdio-mux.c, from
Tobias Klauser.
18) Validate protocol value range in ->create() methods, from Hannes
Frederic Sowa.
19) Fix early socket demux races that result in illegal dst reuse, from
Eric Dumazet.
20) Validate socket address length in pptp code, from WANG Cong.
21) skb_reorder_vlan_header() uses incorrect offset and can corrupt
packets, from Vlad Yasevich.
22) Fix memory leaks in nl80211 registry code, from Ola Olsson.
23) Timeout loop count handing fixes in mISDN, xgbe, qlge, sfc, and
qlcnic. From Dan Carpenter.
24) msg.msg_iocb needs to be cleared in recvfrom() otherwise, for
example, AF_ALG will interpret it as an async call. From Tadeusz
Struk.
25) inetpeer_set_addr_v4 forgets to initialize the 'vif' field, from
Eric Dumazet.
26) rhashtable enforces the minimum table size not early enough,
breaking how we calculate the per-cpu lock allocations. From
Herbert Xu.
27) Fix FCC port lockup in 82xx driver, from Martin Roth.
28) FOU sockets need to be freed using RCU, from Hannes Frederic Sowa.
29) Fix out-of-bounds access in __skb_complete_tx_timestamp() and
sock_setsockopt() wrt. timestamp handling. From WANG Cong.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (117 commits)
net: check both type and procotol for tcp sockets
drivers: net: xgene: fix Tx flow control
tcp: restore fastopen with no data in SYN packet
af_unix: Revert 'lock_interruptible' in stream receive code
fou: clean up socket with kfree_rcu
82xx: FCC: Fixing a bug causing to FCC port lock-up
gianfar: Don't enable RX Filer if not supported
net: fix warnings in 'make htmldocs' by moving macro definition out of field declaration
rhashtable: Fix walker list corruption
rhashtable: Enforce minimum size on initial hash table
inet: tcp: fix inetpeer_set_addr_v4()
ipv6: automatically enable stable privacy mode if stable_secret set
net: fix uninitialized variable issue
bluetooth: Validate socket address length in sco_sock_bind().
net_sched: make qdisc_tree_decrease_qlen() work for non mq
ser_gigaset: remove unnecessary kfree() calls from release method
ser_gigaset: fix deallocation of platform device structure
ser_gigaset: turn nonsense checks into WARN_ON
ser_gigaset: fix up NULL checks
qlcnic: fix a timeout loop
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm
Pull libnvdimm fixes from Dan Williams:
- Two bug fixes for misuse of PAGE_MASK in scatterlist and dma-debug.
These are tagged for -stable. The scatterlist impact is potentially
corrupted dma addresses on HIGHMEM enabled platforms.
- A minor locking fix for the NFIT hot-add implementation that is new
in 4.4-rc. This would only trigger in the case a hot-add raced
driver removal.
* 'libnvdimm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm:
dma-debug: Fix dma_debug_entry offset calculation
Revert "scatterlist: use sg_phys()"
nfit: acpi_nfit_notify(): Do not leave device locked
dma-debug uses struct dma_debug_entry to keep track of dma coherent
memory allocation requests. The virtual address is converted into a pfn
and an offset. Previously, the offset was calculated using an incorrect
bit mask. As a result, we saw incorrect error messages from dma-debug
like the following:
"DMA-API: exceeded 7 overlapping mappings of cacheline 0x03e00000"
Cacheline 0x03e00000 does not exist on our platform.
Fixes: 0abdd7a81b7e ("dma-debug: introduce debug_dma_assert_idle()")
The commit ba7c95ea3870fe7b847466d39a049ab6f156aa2c ("rhashtable:
Fix sleeping inside RCU critical section in walk_stop") introduced
a new spinlock for the walker list. However, it did not convert
all existing users of the list over to the new spin lock. Some
continued to use the old mutext for this purpose. This obviously
led to corruption of the list.
The fix is to use the spin lock everywhere where we touch the list.
This also allows us to do rcu_rad_lock before we take the lock in
rhashtable_walk_start. With the old mutex this would've deadlocked
but it's safe with the new spin lock.
Fixes: ba7c95ea3870 ("rhashtable: Fix sleeping inside RCU...")
Reported-by: Colin Ian King <colin.king@canonical.com>
William Hua <william.hua@canonical.com> wrote:
> I wasn't aware there was an enforced minimum size. I simply set the
> nelem_hint in the rhastable_params struct to 1, expecting it to grow as
> needed. This caused a segfault afterwards when trying to insert an
> element.
OK we're doing the size computation before we enforce the limit
on min_size.
---8<---
We need to do the initial hash table size computation after we
have obtained the correct min_size/max_size parameters. Otherwise
we may end up with a hash table whose size is outside the allowed
envelope.
Fixes: a998f712f77e ("rhashtable: Round up/down min/max_size to...")
Reported-by: William Hua <william.hua@canonical.com>
This reverts commit d3716f18a7d841565c930efde30737a3557eee69.
vmalloc cannot be used in BH disabled contexts, even
with GFP_ATOMIC. And we certainly want to support
rhashtable users inserting entries with software
interrupts disabled.
